--- ray/src/rt/source.c 1991/06/19 16:36:44 1.33 +++ ray/src/rt/source.c 1991/08/13 12:16:37 1.43 @@ -1,4 +1,4 @@ -/* Copyright (c) 1990 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -14,23 +14,26 @@ static char SCCSid[] = "$SunId$ LBL"; #include "octree.h" -#include "source.h" - #include "otypes.h" -#include "cone.h" +#include "source.h" -#include "face.h" - #include "random.h" +/* + * Structures used by direct() + */ -extern double dstrsrc; /* source distribution amount */ -extern double shadthresh; /* relative shadow threshold */ -extern double shadcert; /* shadow testing certainty */ +typedef struct { + FVECT dir; /* source direction */ + COLOR coef; /* material coefficient */ + COLOR val; /* contribution */ +} CONTRIB; /* direct contribution */ -SRCREC *source = NULL; /* our list of sources */ -int nsources = 0; /* the number of sources */ +typedef struct { + int sno; /* source number */ + float brt; /* brightness (for comparison) */ +} CNTPTR; /* contribution pointer */ static CONTRIB *srccnt; /* source contributions in direct() */ static CNTPTR *cntord; /* source ordering in direct() */ @@ -40,13 +43,15 @@ marksources() /* find and mark source objects */ { int i; register OBJREC *o, *m; - register SRCREC *ns; - + register int ns; + /* initialize dispatch table */ + initstypes(); + /* find direct sources */ for (i = 0; i < nobjects; i++) { o = objptr(i); - if (o->omod == OVOID) + if (!issurface(o->otype) || o->omod == OVOID) continue; m = objptr(o->omod); @@ -63,20 +68,30 @@ marksources() /* find and mark source objects */ m->oargs.farg[3] <= FTINY) continue; /* don't bother */ - if ((ns = newsource()) == NULL) + if (sfun[o->otype].of == NULL || + sfun[o->otype].of->setsrc == NULL) + objerror(o, USER, "illegal material"); + + if ((ns = newsource()) < 0) goto memerr; - setsource(ns, o); + setsource(&source[ns], o); if (m->otype == MAT_GLOW) { - ns->sflags |= SPROX; - ns->sl.prox = m->oargs.farg[3]; + source[ns].sflags |= SPROX; + source[ns].sl.prox = m->oargs.farg[3]; if (o->otype == OBJ_SOURCE) - ns->sflags |= SSKIP; + source[ns].sflags |= SSKIP; } else if (m->otype == MAT_SPOT) { - ns->sflags |= SSPOT; - if ((ns->sl.s = makespot(m)) == NULL) + source[ns].sflags |= SSPOT; + if ((source[ns].sl.s = makespot(m)) == NULL) goto memerr; + if (source[ns].sflags & SFLAT && + !checkspot(source[ns].sl.s,source[ns].snorm)) { + objerror(o, WARNING, + "invalid spotlight direction"); + source[ns].sflags |= SSKIP; + } } } if (nsources <= 0) { @@ -86,7 +101,7 @@ marksources() /* find and mark source objects */ markvirtuals(); /* find and add virtual sources */ srccnt = (CONTRIB *)malloc(nsources*sizeof(CONTRIB)); cntord = (CNTPTR *)malloc(nsources*sizeof(CNTPTR)); - if (srccnt != NULL && cntord != NULL) + if (srccnt == NULL || cntord == NULL) goto memerr; return; memerr: @@ -94,107 +109,6 @@ memerr: } -SRCREC * -newsource() /* allocate new source in our array */ -{ - if (nsources == 0) - source = (SRCREC *)malloc(sizeof(SRCREC)); - else - source = (SRCREC *)realloc((char *)source, - (unsigned)(nsources+1)*sizeof(SRCREC)); - if (source == NULL) - return(NULL); - source[nsources].sflags = 0; - source[nsources].nhits = 1; - source[nsources].ntests = 2; /* initial hit probability = 1/2 */ - return(&source[nsources++]); -} - - -setsource(src, so) /* add a source to the array */ -register SRCREC *src; -register OBJREC *so; -{ - double cos(), tan(), sqrt(); - double theta; - FACE *f; - CONE *co; - int j; - register int i; - - src->sa.success = 2*AIMREQT-1; /* bitch on second failure */ - src->so = so; - - switch (so->otype) { - case OBJ_SOURCE: - if (so->oargs.nfargs != 4) - objerror(so, USER, "bad arguments"); - src->sflags |= SDISTANT; - VCOPY(src->sloc, so->oargs.farg); - if (normalize(src->sloc) == 0.0) - objerror(so, USER, "zero direction"); - theta = PI/180.0/2.0 * so->oargs.farg[3]; - if (theta <= FTINY) - objerror(so, USER, "zero size"); - src->ss = theta >= PI/4 ? 1.0 : tan(theta); - src->ss2 = 2.0*PI * (1.0 - cos(theta)); - break; - case OBJ_SPHERE: - VCOPY(src->sloc, so->oargs.farg); - src->ss = so->oargs.farg[3]; - src->ss2 = PI * src->ss * src->ss; - break; - case OBJ_FACE: - /* get the face */ - f = getface(so); - /* find the center */ - for (j = 0; j < 3; j++) { - src->sloc[j] = 0.0; - for (i = 0; i < f->nv; i++) - src->sloc[j] += VERTEX(f,i)[j]; - src->sloc[j] /= (double)f->nv; - } - if (!inface(src->sloc, f)) - objerror(so, USER, "cannot hit center"); - src->sflags |= SFLAT; - VCOPY(src->snorm, f->norm); - src->ss = sqrt(f->area / PI); - src->ss2 = f->area; - break; - case OBJ_RING: - /* get the ring */ - co = getcone(so, 0); - VCOPY(src->sloc, CO_P0(co)); - if (CO_R0(co) > 0.0) - objerror(so, USER, "cannot hit center"); - src->sflags |= SFLAT; - VCOPY(src->snorm, co->ad); - src->ss = CO_R1(co); - src->ss2 = PI * src->ss * src->ss; - break; - default: - objerror(so, USER, "illegal material"); - } -} - - -SPOT * -makespot(m) /* make a spotlight */ -register OBJREC *m; -{ - extern double cos(); - register SPOT *ns; - - if ((ns = (SPOT *)malloc(sizeof(SPOT))) == NULL) - return(NULL); - ns->siz = 2.0*PI * (1.0 - cos(PI/180.0/2.0 * m->oargs.farg[3])); - VCOPY(ns->aim, m->oargs.farg+4); - if ((ns->flen = normalize(ns->aim)) == 0.0) - objerror(m, USER, "zero focus vector"); - return(ns); -} - - double srcray(sr, r, sn) /* send a ray to a source, return domega */ register RAY *sr; /* returned source ray */ @@ -214,14 +128,6 @@ register int sn; /* source number */ sr->rsrc = sn; /* remember source */ /* get source direction */ if (source[sn].sflags & SDISTANT) { - if (source[sn].sflags & SSPOT) { /* check location */ - for (i = 0; i < 3; i++) - vd[i] = sr->rorg[i] - source[sn].sl.s->aim[i]; - d = DOT(source[sn].sloc,vd); - d = DOT(vd,vd) - d*d; - if (PI*d > source[sn].sl.s->siz) - return(0.0); - } /* constant direction */ VCOPY(sr->rdir, source[sn].sloc); } else { /* compute direction */ @@ -234,13 +140,10 @@ register int sn; /* source number */ } if (dstrsrc > FTINY) { /* distribute source direction */ - dimlist[ndims++] = sn; - for (i = 0; i < 3; i++) { - dimlist[ndims] = i + 8831; - vd[i] = dstrsrc * source[sn].ss * - (1.0 - 2.0*urand(ilhash(dimlist,ndims+1)+samplendx)); - } - ndims--; + dimlist[ndims] = sn + 8831; + peano(vd, 3, urand(ilhash(dimlist,ndims+1)+samplendx), .01); + for (i = 0; i < 3; i++) + vd[i] = dstrsrc * source[sn].ss * (1. - 2.*vd[i]); if (source[sn].sflags & SFLAT) { /* project offset */ d = DOT(vd, source[sn].snorm); for (i = 0; i < 3; i++) @@ -248,19 +151,29 @@ register int sn; /* source number */ } for (i = 0; i < 3; i++) /* offset source direction */ sr->rdir[i] += vd[i]; + /* normalize */ + d = normalize(sr->rdir); - } else if (source[sn].sflags & SDISTANT) - /* already normalized */ - return(source[sn].ss2); + } else if (!(source[sn].sflags & SDISTANT)) + /* normalize direction */ + d = normalize(sr->rdir); - if ((d = normalize(sr->rdir)) == 0.0) - /* at source! */ + if (source[sn].sflags & SDISTANT) { + if (source[sn].sflags & SSPOT) { /* check location */ + for (i = 0; i < 3; i++) + vd[i] = source[sn].sl.s->aim[i] - sr->rorg[i]; + d = DOT(sr->rdir,vd); + if (d <= FTINY) + return(0.0); + d = DOT(vd,vd) - d*d; + if (PI*d > source[sn].sl.s->siz) + return(0.0); + } + return(source[sn].ss2); /* domega constant */ + } + /* check direction */ + if (d == 0.0) return(0.0); - - if (source[sn].sflags & SDISTANT) - /* domega constant */ - return(source[sn].ss2); - /* check proximity */ if (source[sn].sflags & SPROX && d > source[sn].sl.prox) @@ -282,38 +195,35 @@ register int sn; /* source number */ } -sourcehit(r) /* check to see if ray hit distant source */ -register RAY *r; +srcvalue(r) /* punch ray to source and compute value */ +RAY *r; { - int first, last; - register int i; + register SRCREC *sp; - if (r->rsrc >= 0) { /* check only one if aimed */ - first = last = r->rsrc; - } else { /* otherwise check all */ - first = 0; last = nsources-1; + sp = &source[r->rsrc]; + if (sp->sflags & SVIRTUAL) { /* virtual source */ + /* check intersection */ + if (!(*ofun[sp->so->otype].funp)(sp->so, r)) + return; + raycont(r); /* compute contribution */ + return; } - for (i = first; i <= last; i++) - if (source[i].sflags & SDISTANT) - /* - * Check to see if ray is within - * solid angle of source. - */ - if (2.0*PI * (1.0 - DOT(source[i].sloc,r->rdir)) - <= source[i].ss2) { - r->ro = source[i].so; - if (!(source[i].sflags & SSKIP)) - break; - } - - if (r->ro != NULL) { - for (i = 0; i < 3; i++) - r->ron[i] = -r->rdir[i]; - r->rod = 1.0; - r->rox = NULL; - return(1); + /* compute intersection */ + if (sp->sflags & SDISTANT ? sourcehit(r) : + (*ofun[sp->so->otype].funp)(sp->so, r)) { + if (sp->sa.success >= 0) + sp->sa.success++; + raycont(r); /* compute contribution */ + return; } - return(0); + if (sp->sa.success < 0) + return; /* bitched already */ + sp->sa.success -= AIMREQT; + if (sp->sa.success >= 0) + return; /* leniency */ + sprintf(errmsg, "aiming failure for light source \"%s\"", + sp->so->oname); + error(WARNING, errmsg); /* issue warning */ } @@ -334,11 +244,12 @@ RAY *r; /* ray that hit surface */ int (*f)(); /* direct component coefficient function */ char *p; /* data for f */ { + extern int (*trace)(); extern double pow(); register int sn; int nshadcheck, ncnts; int nhits; - double prob, ourthresh, hwt; + double dom, prob, ourthresh, hwt; RAY sr; /* NOTE: srccnt and cntord global so no recursion */ if (nsources <= 0) @@ -352,17 +263,19 @@ char *p; /* data for f */ cntord[sn].sno = sn; cntord[sn].brt = 0.0; /* get source ray */ - if ((srccnt[sn].dom = srcray(&sr, r, sn)) == 0.0) + if ((dom = srcray(&sr, r, sn)) == 0.0) continue; VCOPY(srccnt[sn].dir, sr.rdir); /* compute coefficient */ - (*f)(srccnt[sn].val, p, srccnt[sn].dir, srccnt[sn].dom); - cntord[sn].brt = bright(srccnt[sn].val); + (*f)(srccnt[sn].coef, p, srccnt[sn].dir, dom); + cntord[sn].brt = bright(srccnt[sn].coef); if (cntord[sn].brt <= 0.0) continue; - /* compute contribution */ - srcvalue(&sr); - multcolor(srccnt[sn].val, sr.rcol); + /* compute potential */ + sr.revf = srcvalue; + rayvalue(&sr); + copycolor(srccnt[sn].val, sr.rcol); + multcolor(srccnt[sn].val, srccnt[sn].coef); cntord[sn].brt = bright(srccnt[sn].val); } /* sort contributions */ @@ -401,12 +314,13 @@ char *p; /* data for f */ source[cntord[sn].sno].sflags & SFOLLOW )) { /* follow entire path */ raycont(&sr); + if (trace != NULL) + (*trace)(&sr); /* trace execution */ if (bright(sr.rcol) <= FTINY) continue; /* missed! */ - (*f)(srccnt[cntord[sn].sno].val, p, - srccnt[cntord[sn].sno].dir, - srccnt[cntord[sn].sno].dom); - multcolor(srccnt[cntord[sn].sno].val, sr.rcol); + copycolor(srccnt[cntord[sn].sno].val, sr.rcol); + multcolor(srccnt[cntord[sn].sno].val, + srccnt[cntord[sn].sno].coef); } /* add contribution if hit */ addcolor(r->rcol, srccnt[cntord[sn].sno].val); @@ -429,83 +343,5 @@ char *p; /* data for f */ (double)source[cntord[sn].sno].ntests; scalecolor(srccnt[cntord[sn].sno].val, prob); addcolor(r->rcol, srccnt[cntord[sn].sno].val); - } -} - - -srcvalue(r) /* punch ray to source and compute value */ -RAY *r; -{ - register SRCREC *sp; - - sp = &source[r->rsrc]; - if (sp->sflags & SVIRTUAL) { /* virtual source */ - RAY nr; - /* check intersection */ - if (!(*ofun[sp->so->otype].funp)(sp->so, r)) - return; - /* relay ray to source */ - vsrcrelay(&nr, r); - srcvalue(&nr); - return; - } - /* compute intersection */ - if (sp->sflags & SDISTANT ? sourcehit(r) : - (*ofun[sp->so->otype].funp)(sp->so, r)) { - if (sp->sa.success >= 0) - sp->sa.success++; - raycont(r); /* compute contribution */ - return; - } - if (sp->sa.success < 0) - return; /* bitched already */ - sp->sa.success -= AIMREQT; - if (sp->sa.success >= 0) - return; /* leniency */ - sprintf(errmsg, "aiming failure for light source \"%s\"", - sp->so->oname); - error(WARNING, errmsg); /* issue warning */ -} - - -#define wrongsource(m, r) (m->otype!=MAT_ILLUM && \ - r->rsrc>=0 && \ - source[r->rsrc].so!=r->ro) - -#define badambient(m, r) ((r->crtype&(AMBIENT|SHADOW))==AMBIENT && \ - !(m->otype==MAT_GLOW&&r->rot>m->oargs.farg[3])) - -#define passillum(m, r) (m->otype==MAT_ILLUM && \ - !(r->rsrc>=0&&source[r->rsrc].so==r->ro)) - - -m_light(m, r) /* ray hit a light source */ -register OBJREC *m; -register RAY *r; -{ - /* check for over-counting */ - if (wrongsource(m, r) || badambient(m, r)) - return; - /* check for passed illum */ - if (passillum(m, r)) { - - if (m->oargs.nsargs < 1 || !strcmp(m->oargs.sarg[0], VOIDID)) - raytrans(r); - else - rayshade(r, modifier(m->oargs.sarg[0])); - - /* otherwise treat as source */ - } else { - /* check for behind */ - if (r->rod < 0.0) - return; - /* get distribution pattern */ - raytexture(r, m->omod); - /* get source color */ - setcolor(r->rcol, m->oargs.farg[0], - m->oargs.farg[1], - m->oargs.farg[2]); - /* modify value */ - multcolor(r->rcol, r->pcol); } }
