--- ray/src/rt/source.c 1989/03/03 20:58:33 1.2 +++ ray/src/rt/source.c 1991/07/30 18:23:41 1.40 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1990 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -12,41 +12,51 @@ static char SCCSid[] = "$SunId$ LBL"; #include "ray.h" -#include "source.h" +#include "octree.h" #include "otypes.h" -#include "cone.h" +#include "source.h" -#include "face.h" - #include "random.h" +/* + * Structures used by direct() + */ -extern double dstrsrc; /* source distribution amount */ +typedef struct { + FVECT dir; /* source direction */ + COLOR coef; /* material coefficient */ + COLOR val; /* contribution */ +} CONTRIB; /* direct contribution */ -SOURCE srcval[MAXSOURCE]; /* our array of sources */ -int nsources = 0; /* the number of sources */ +typedef struct { + int sno; /* source number */ + float brt; /* brightness (for comparison) */ +} CNTPTR; /* contribution pointer */ +static CONTRIB *srccnt; /* source contributions in direct() */ +static CNTPTR *cntord; /* source ordering in direct() */ + marksources() /* find and mark source objects */ { + int i; register OBJREC *o, *m; - register int i; - + register int ns; + /* initialize dispatch table */ + initstypes(); + /* find direct sources */ for (i = 0; i < nobjects; i++) { o = objptr(i); - if (o->omod == OVOID) + if (!issurface(o->otype) || o->omod == OVOID) continue; m = objptr(o->omod); - if (m->otype != MAT_LIGHT && - m->otype != MAT_ILLUM && - m->otype != MAT_GLOW && - m->otype != MAT_SPOT) + if (!islight(m->otype)) continue; if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 : @@ -58,263 +68,278 @@ marksources() /* find and mark source objects */ m->oargs.farg[3] <= FTINY) continue; /* don't bother */ - if (nsources >= MAXSOURCE) - error(INTERNAL, "too many sources in marksources"); + if (sfun[o->otype].of == NULL || + sfun[o->otype].of->setsrc == NULL) + objerror(o, USER, "illegal material"); - newsource(&srcval[nsources], o); + if ((ns = newsource()) < 0) + goto memerr; + setsource(&source[ns], o); + if (m->otype == MAT_GLOW) { - srcval[nsources].sflags |= SPROX; - srcval[nsources].sl.prox = m->oargs.farg[3]; + source[ns].sflags |= SPROX; + source[ns].sl.prox = m->oargs.farg[3]; if (o->otype == OBJ_SOURCE) - srcval[nsources].sflags |= SSKIP; + source[ns].sflags |= SSKIP; } else if (m->otype == MAT_SPOT) { - srcval[nsources].sflags |= SSPOT; - srcval[nsources].sl.s = makespot(m); + source[ns].sflags |= SSPOT; + if ((source[ns].sl.s = makespot(m)) == NULL) + goto memerr; + if (source[ns].sflags & SFLAT && + !checkspot(source[ns].sl.s,source[ns].snorm)) { + objerror(o, WARNING, + "invalid spotlight direction"); + source[ns].sflags |= SSKIP; + } } - nsources++; } -} - - -newsource(src, so) /* add a source to the array */ -register SOURCE *src; -register OBJREC *so; -{ - double cos(), tan(), sqrt(); - double theta; - FACE *f; - CONE *co; - int j; - register int i; - - src->sflags = 0; - src->so = so; - - switch (so->otype) { - case OBJ_SOURCE: - if (so->oargs.nfargs != 4) - objerror(so, USER, "bad arguments"); - src->sflags |= SDISTANT; - VCOPY(src->sloc, so->oargs.farg); - if (normalize(src->sloc) == 0.0) - objerror(so, USER, "zero direction"); - theta = PI/180.0/2.0 * so->oargs.farg[3]; - if (theta <= FTINY) - objerror(so, USER, "zero size"); - src->ss = theta >= PI/4 ? 1.0 : tan(theta); - src->ss2 = 2.0*PI * (1.0 - cos(theta)); - break; - case OBJ_SPHERE: - VCOPY(src->sloc, so->oargs.farg); - src->ss = so->oargs.farg[3]; - src->ss2 = PI * src->ss * src->ss; - break; - case OBJ_FACE: - /* get the face */ - f = getface(so); - /* find the center */ - for (j = 0; j < 3; j++) { - src->sloc[j] = 0.0; - for (i = 0; i < f->nv; i++) - src->sloc[j] += VERTEX(f,i)[j]; - src->sloc[j] /= f->nv; - } - if (!inface(src->sloc, f)) - objerror(so, USER, "cannot hit center"); - src->ss = sqrt(f->area / PI); - src->ss2 = f->area; - break; - case OBJ_RING: - /* get the ring */ - co = getcone(so, 0); - VCOPY(src->sloc, CO_P0(co)); - if (CO_R0(co) > 0.0) - objerror(so, USER, "cannot hit center"); - src->ss = CO_R1(co); - src->ss2 = PI * src->ss * src->ss; - break; - default: - objerror(so, USER, "illegal material"); + if (nsources <= 0) { + error(WARNING, "no light sources found"); + return; } + markvirtuals(); /* find and add virtual sources */ + srccnt = (CONTRIB *)malloc(nsources*sizeof(CONTRIB)); + cntord = (CNTPTR *)malloc(nsources*sizeof(CNTPTR)); + if (srccnt == NULL || cntord == NULL) + goto memerr; + return; +memerr: + error(SYSTEM, "out of memory in marksources"); } -SPOT * -makespot(m) /* make a spotlight */ -register OBJREC *m; -{ - extern double cos(); - register SPOT *ns; - - if ((ns = (SPOT *)malloc(sizeof(SPOT))) == NULL) - error(SYSTEM, "out of memory in makespot"); - ns->siz = 2.0*PI * (1.0 - cos(PI/180.0/2.0 * m->oargs.farg[3])); - VCOPY(ns->aim, m->oargs.farg+4); - if ((ns->flen = normalize(ns->aim)) == 0.0) - objerror(m, USER, "zero focus vector"); - return(ns); -} - - double srcray(sr, r, sn) /* send a ray to a source, return domega */ register RAY *sr; /* returned source ray */ RAY *r; /* ray which hit object */ register int sn; /* source number */ { - register double *norm = NULL; /* plane normal */ double ddot; /* (distance times) cosine */ FVECT vd; double d; register int i; - if (srcval[sn].sflags & SSKIP) + if (source[sn].sflags & SSKIP) return(0.0); /* skip this source */ rayorigin(sr, r, SHADOW, 1.0); /* ignore limits */ sr->rsrc = sn; /* remember source */ /* get source direction */ - if (srcval[sn].sflags & SDISTANT) + if (source[sn].sflags & SDISTANT) { /* constant direction */ - VCOPY(sr->rdir, srcval[sn].sloc); - else { /* compute direction */ + VCOPY(sr->rdir, source[sn].sloc); + } else { /* compute direction */ for (i = 0; i < 3; i++) - sr->rdir[i] = srcval[sn].sloc[i] - sr->rorg[i]; + sr->rdir[i] = source[sn].sloc[i] - sr->rorg[i]; - if (srcval[sn].so->otype == OBJ_FACE) - norm = getface(srcval[sn].so)->norm; - else if (srcval[sn].so->otype == OBJ_RING) - norm = getcone(srcval[sn].so,0)->ad; - - if (norm != NULL && (ddot = -DOT(sr->rdir, norm)) <= FTINY) + if (source[sn].sflags & SFLAT && + (ddot = -DOT(sr->rdir, source[sn].snorm)) <= FTINY) return(0.0); /* behind surface! */ } if (dstrsrc > FTINY) { /* distribute source direction */ - for (i = 0; i < 3; i++) - vd[i] = dstrsrc * srcval[sn].ss * (1.0 - 2.0*frandom()); - - if (norm != NULL) { /* project offset */ - d = DOT(vd, norm); + dimlist[ndims++] = sn; + for (i = 0; i < 3; i++) { + dimlist[ndims] = i + 8831; + vd[i] = dstrsrc * source[sn].ss * + (1.0 - 2.0*urand(urind(ilhash(dimlist,ndims+1),samplendx))); + } + ndims--; + if (source[sn].sflags & SFLAT) { /* project offset */ + d = DOT(vd, source[sn].snorm); for (i = 0; i < 3; i++) - vd[i] -= d * norm[i]; + vd[i] -= d * source[sn].snorm[i]; } for (i = 0; i < 3; i++) /* offset source direction */ sr->rdir[i] += vd[i]; + /* normalize */ + d = normalize(sr->rdir); - } else if (srcval[sn].sflags & SDISTANT) - /* already normalized */ - return(srcval[sn].ss2); + } else if (!(source[sn].sflags & SDISTANT)) + /* normalize direction */ + d = normalize(sr->rdir); - if ((d = normalize(sr->rdir)) == 0.0) - /* at source! */ + if (source[sn].sflags & SDISTANT) { + if (source[sn].sflags & SSPOT) { /* check location */ + for (i = 0; i < 3; i++) + vd[i] = sr->rorg[i] - source[sn].sl.s->aim[i]; + d = DOT(sr->rdir,vd); + d = DOT(vd,vd) - d*d; + if (PI*d > source[sn].sl.s->siz) + return(0.0); + } + return(source[sn].ss2); /* domega constant */ + } + /* check direction */ + if (d == 0.0) return(0.0); - - if (srcval[sn].sflags & SDISTANT) - /* domega constant */ - return(srcval[sn].ss2); - - else { /* check proximity */ - if (srcval[sn].sflags & SPROX && - d > srcval[sn].sl.prox) - return(0.0); - - if (norm != NULL) - ddot /= d; - else - ddot = 1.0; + if (source[sn].sflags & SPROX && + d > source[sn].sl.prox) + return(0.0); + /* compute dot product */ + if (source[sn].sflags & SFLAT) + ddot /= d; + else + ddot = 1.0; /* check angle */ - if (srcval[sn].sflags & SSPOT) { - if (srcval[sn].sl.s->siz < 2.0*PI * - (1.0 + DOT(srcval[sn].sl.s->aim,sr->rdir))) - return(0.0); - d += srcval[sn].sl.s->flen; - } - /* return domega */ - return(ddot*srcval[sn].ss2/(d*d)); + if (source[sn].sflags & SSPOT) { + if (source[sn].sl.s->siz < 2.0*PI * + (1.0 + DOT(source[sn].sl.s->aim,sr->rdir))) + return(0.0); + d += source[sn].sl.s->flen; /* adjust length */ } + /* compute domega */ + return(ddot*source[sn].ss2/(d*d)); } -sourcehit(r) /* check to see if ray hit distant source */ -register RAY *r; +srcvalue(r) /* punch ray to source and compute value */ +RAY *r; { - int first, last; - register int i; + register SRCREC *sp; - if (r->rsrc >= 0) { /* check only one if aimed */ - first = last = r->rsrc; - } else { /* otherwise check all */ - first = 0; last = nsources-1; + sp = &source[r->rsrc]; + if (sp->sflags & SVIRTUAL) { /* virtual source */ + /* check intersection */ + if (!(*ofun[sp->so->otype].funp)(sp->so, r)) + return; + raycont(r); /* compute contribution */ + return; } - for (i = first; i <= last; i++) - if (srcval[i].sflags & SDISTANT) - /* - * Check to see if ray is within - * solid angle of source. - */ - if (2.0*PI * (1.0 - DOT(srcval[i].sloc,r->rdir)) - <= srcval[i].ss2) { - r->ro = srcval[i].so; - if (!(srcval[i].sflags & SSKIP)) - break; - } + /* compute intersection */ + if (sp->sflags & SDISTANT ? sourcehit(r) : + (*ofun[sp->so->otype].funp)(sp->so, r)) { + if (sp->sa.success >= 0) + sp->sa.success++; + raycont(r); /* compute contribution */ + return; + } + if (sp->sa.success < 0) + return; /* bitched already */ + sp->sa.success -= AIMREQT; + if (sp->sa.success >= 0) + return; /* leniency */ + sprintf(errmsg, "aiming failure for light source \"%s\"", + sp->so->oname); + error(WARNING, errmsg); /* issue warning */ +} - if (r->ro != NULL) { - for (i = 0; i < 3; i++) - r->ron[i] = -r->rdir[i]; - r->rod = 1.0; + +static int +cntcmp(sc1, sc2) /* contribution compare (descending) */ +register CNTPTR *sc1, *sc2; +{ + if (sc1->brt > sc2->brt) + return(-1); + if (sc1->brt < sc2->brt) return(1); - } return(0); } -#define wrongsource(m, r) (m->otype!=MAT_ILLUM && \ - r->rsrc>=0 && \ - srcval[r->rsrc].so!=r->ro) - -#define badambient(m, r) ((r->crtype&(AMBIENT|SHADOW))==AMBIENT && \ - !(r->rtype&REFLECTED) && /* hack! */\ - !(m->otype==MAT_GLOW&&r->rot>m->oargs.farg[3])) - -#define passillum(m, r) (m->otype==MAT_ILLUM && \ - !(r->rsrc>=0&&srcval[r->rsrc].so==r->ro)) - - -m_light(m, r) /* ray hit a light source */ -register OBJREC *m; -register RAY *r; +direct(r, f, p) /* add direct component */ +RAY *r; /* ray that hit surface */ +int (*f)(); /* direct component coefficient function */ +char *p; /* data for f */ { - /* check for behind */ - if (r->rod < 0.0) - return; - /* check for over-counting */ - if (wrongsource(m, r) || badambient(m, r)) - return; - /* check for passed illum */ - if (passillum(m, r)) { + extern double pow(); + register int sn; + int nshadcheck, ncnts; + int nhits; + double dom, prob, ourthresh, hwt; + RAY sr; + /* NOTE: srccnt and cntord global so no recursion */ + if (nsources <= 0) + return; /* no sources?! */ + /* compute number to check */ + nshadcheck = pow((double)nsources, shadcert) + .5; + /* modify threshold */ + ourthresh = shadthresh / r->rweight; + /* potential contributions */ + for (sn = 0; sn < nsources; sn++) { + cntord[sn].sno = sn; + cntord[sn].brt = 0.0; + /* get source ray */ + if ((dom = srcray(&sr, r, sn)) == 0.0) + continue; + VCOPY(srccnt[sn].dir, sr.rdir); + /* compute coefficient */ + (*f)(srccnt[sn].coef, p, srccnt[sn].dir, dom); + cntord[sn].brt = bright(srccnt[sn].coef); + if (cntord[sn].brt <= 0.0) + continue; + /* compute potential */ + sr.revf = srcvalue; + rayvalue(&sr); + copycolor(srccnt[sn].val, sr.rcol); + multcolor(srccnt[sn].val, srccnt[sn].coef); + cntord[sn].brt = bright(srccnt[sn].val); + } + /* sort contributions */ + qsort(cntord, nsources, sizeof(CNTPTR), cntcmp); + { /* find last */ + register int l, m; - if (m->oargs.nsargs < 1 || !strcmp(m->oargs.sarg[0], VOIDID)) - raytrans(r); - else - rayshade(r, modifier(m->oargs.sarg[0])); - - /* otherwise treat as source */ - } else { - /* get distribution pattern */ - raytexture(r, m->omod); - /* get source color */ - setcolor(r->rcol, m->oargs.farg[0], - m->oargs.farg[1], - m->oargs.farg[2]); - /* modify value */ - multcolor(r->rcol, r->pcol); + sn = 0; ncnts = l = nsources; + while ((m = (sn + ncnts) >> 1) != l) { + if (cntord[m].brt > 0.0) + sn = m; + else + ncnts = m; + l = m; + } } + /* accumulate tail */ + for (sn = ncnts-1; sn > 0; sn--) + cntord[sn-1].brt += cntord[sn].brt; + /* test for shadows */ + nhits = 0; + for (sn = 0; sn < ncnts; sn++) { + /* check threshold */ + if ((sn+nshadcheck>=ncnts ? cntord[sn].brt : + cntord[sn].brt-cntord[sn+nshadcheck].brt) + < ourthresh*bright(r->rcol)) + break; + /* get statistics */ + source[cntord[sn].sno].ntests++; + /* test for hit */ + rayorigin(&sr, r, SHADOW, 1.0); + VCOPY(sr.rdir, srccnt[cntord[sn].sno].dir); + sr.rsrc = cntord[sn].sno; + if (localhit(&sr, &thescene) && + ( sr.ro != source[cntord[sn].sno].so || + source[cntord[sn].sno].sflags & SFOLLOW )) { + /* follow entire path */ + raycont(&sr); + if (bright(sr.rcol) <= FTINY) + continue; /* missed! */ + copycolor(srccnt[cntord[sn].sno].val, sr.rcol); + multcolor(srccnt[cntord[sn].sno].val, + srccnt[cntord[sn].sno].coef); + } + /* add contribution if hit */ + addcolor(r->rcol, srccnt[cntord[sn].sno].val); + nhits++; + source[cntord[sn].sno].nhits++; + } + /* surface hit rate */ + if (sn > 0) + hwt = (double)nhits / (double)sn; + else + hwt = 0.5; +#ifdef DEBUG + sprintf(errmsg, "%d tested, %d untested, %f hit rate\n", + sn, ncnts-sn, hwt); + eputs(errmsg); +#endif + /* add in untested sources */ + for ( ; sn < ncnts; sn++) { + prob = hwt * (double)source[cntord[sn].sno].nhits / + (double)source[cntord[sn].sno].ntests; + scalecolor(srccnt[cntord[sn].sno].val, prob); + addcolor(r->rcol, srccnt[cntord[sn].sno].val); + } } - - -o_source() {} /* intersection with a source is done elsewhere */
