--- ray/src/rt/source.c 1996/04/17 14:02:18 2.24 +++ ray/src/rt/source.c 2003/12/31 02:03:08 2.39 @@ -1,21 +1,20 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: source.c,v 2.39 2003/12/31 02:03:08 greg Exp $"; #endif - /* * source.c - routines dealing with illumination sources. * - * 8/20/85 + * External symbols declared in source.h */ +#include "copyright.h" + #include "ray.h" -#include "octree.h" - #include "otypes.h" +#include "otspecial.h" + #include "source.h" #include "random.h" @@ -47,6 +46,31 @@ static CNTPTR *cntord; /* source ordering in direct static int maxcntr = 0; /* size of contribution arrays */ +OBJREC * /* find an object's actual material */ +findmaterial(register OBJREC *o) +{ + while (!ismaterial(o->otype)) { + if (ismixture(o->otype)) + return(NULL); /* reject mixed materials */ + if (o->otype == MOD_ALIAS && o->oargs.nsargs) { + OBJECT aobj; + OBJREC *ao; + aobj = lastmod(objndx(o), o->oargs.sarg[0]); + if (aobj < 0) + objerror(o, USER, "bad reference"); + ao = objptr(aobj); + if (ismaterial(ao->otype)) + return(ao); + } + if (o->omod == OVOID) + return(NULL); + o = objptr(o->omod); + } + return(o); +} + + +void marksources() /* find and mark source objects */ { int foundsource = 0; @@ -56,17 +80,16 @@ marksources() /* find and mark source objects */ /* initialize dispatch table */ initstypes(); /* find direct sources */ - for (i = 0; i < nobjects; i++) { + for (i = 0; i < nsceneobjs; i++) { o = objptr(i); if (!issurface(o->otype) || o->omod == OVOID) continue; - - m = objptr(o->omod); - - if (!islight(m->otype)) - continue; + /* find material */ + m = findmaterial(o); + if (m == NULL || !islight(m->otype)) + continue; /* not source modifier */ if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 : m->otype == MAT_SPOT ? 7 : 3)) @@ -105,6 +128,9 @@ marksources() /* find and mark source objects */ source[ns].sflags |= SSKIP; } } +#if SHADCACHE + source[ns].obscache = NULL; +#endif if (!(source[ns].sflags & SSKIP)) foundsource++; } @@ -117,7 +143,7 @@ marksources() /* find and mark source objects */ maxcntr = nsources + MAXSPART; /* start with this many */ srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB)); cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR)); - if (srccnt == NULL | cntord == NULL) + if ((srccnt == NULL) | (cntord == NULL)) goto memerr; return; memerr: @@ -125,11 +151,35 @@ memerr: } -srcray(sr, r, si) /* send a ray to a source, return domega */ -register RAY *sr; /* returned source ray */ -RAY *r; /* ray which hit object */ -SRCINDEX *si; /* source sample index */ +void +freesources() /* free all source structures */ { + if (nsources > 0) { +#if SHADCACHE + while (nsources--) + freeobscache(&source[nsources]); +#endif + free((void *)source); + source = NULL; + nsources = 0; + } + if (maxcntr <= 0) + return; + free((void *)srccnt); + srccnt = NULL; + free((void *)cntord); + cntord = NULL; + maxcntr = 0; +} + + +int +srcray( /* send a ray to a source, return domega */ +register RAY *sr, /* returned source ray */ +RAY *r, /* ray which hit object */ +SRCINDEX *si /* source sample index */ +) +{ double d; /* distance to source */ register SRCREC *srcp; @@ -162,8 +212,10 @@ SRCINDEX *si; /* source sample index */ } -srcvalue(r) /* punch ray to source and compute value */ -register RAY *r; +void +srcvalue( /* punch ray to source and compute value */ +register RAY *r +) { register SRCREC *sp; @@ -202,8 +254,10 @@ nomat: } -sourcehit(r) /* check to see if ray hit distant source */ -register RAY *r; +int +sourcehit( /* check to see if ray hit distant source */ +register RAY *r +) { int first, last; register int i; @@ -227,9 +281,12 @@ register RAY *r; } if (r->ro != NULL) { + r->robj = objndx(r->ro); for (i = 0; i < 3; i++) r->ron[i] = -r->rdir[i]; r->rod = 1.0; + r->pert[0] = r->pert[1] = r->pert[2] = 0.0; + r->uv[0] = r->uv[1] = 0.0; r->rox = NULL; return(1); } @@ -237,10 +294,204 @@ register RAY *r; } +#if SHADCACHE /* preemptive shadow checking */ +#define ABS(x) ((x)>0 ? (x) : -(x)) + +static void /* find closest blockers to source */ +initobscache(SRCREC *srcp) +{ + int i; + int cachelen; + + if (srcp->sflags & SDISTANT) + cachelen = 4*SHADCACHE*SHADCACHE; + else if (srcp->sflags & SFLAT) + cachelen = SHADCACHE*SHADCACHE*3 + (SHADCACHE&1)*SHADCACHE*4; + else /* spherical distribution */ + cachelen = SHADCACHE*SHADCACHE*6; + /* allocate cache */ + DCHECK(srcp->obscache != NULL, + CONSISTENCY, "initobscache() called twice"); + srcp->obscache = (OBSCACHE *)malloc(sizeof(OBSCACHE) + + sizeof(OBJECT)*(cachelen-1)); + if (srcp->obscache == NULL) + error(SYSTEM, "out of memory in initobscache()"); + /* set parameters */ + if (srcp->sflags & SDISTANT) { + int ax, ax1, ax2; + RREAL amax = 0; + for (ax1 = 3; ax1--; ) + if (ABS(srcp->sloc[ax1]) > amax) { + amax = ABS(srcp->sloc[ax1]); + ax = ax1; + } + srcp->obscache->p.d.ax = ax; + ax1 = (ax+1)%3; + ax2 = (ax+2)%3; + VCOPY(srcp->obscache->p.d.o, thescene.cuorg); + if (srcp->sloc[ax] > 0) + srcp->obscache->p.d.o[ax] += thescene.cusize; + if (srcp->sloc[ax1] < 0) + srcp->obscache->p.d.o[ax1] += thescene.cusize * + srcp->sloc[ax1] / ABS(srcp->sloc[ax]); + if (srcp->sloc[ax2] < 0) + srcp->obscache->p.d.o[ax2] += thescene.cusize * + srcp->sloc[ax2] / ABS(srcp->sloc[ax]); + srcp->obscache->p.d.e1 = (1.-FTINY) / (thescene.cusize*(1. + + fabs(srcp->sloc[ax1]/srcp->sloc[ax]))); + srcp->obscache->p.d.e2 = (1.-FTINY) / (thescene.cusize*(1. + + fabs(srcp->sloc[ax2]/srcp->sloc[ax]))); + } else if (srcp->sflags & SFLAT) { + VCOPY(srcp->obscache->p.f.u, srcp->ss[SU]); + normalize(srcp->obscache->p.f.u); + fcross(srcp->obscache->p.f.v, + srcp->snorm, srcp->obscache->p.f.u); + } + /* XXX Should cast rays from source */ + for (i = cachelen; i--; ) + srcp->obscache->obs[i] = OVOID; +} + + +static OBJECT * /* return occluder cache entry */ +srcobstructp(register RAY *r) +{ + static OBJECT noobs; + SRCREC *srcp; + int ondx; + + DCHECK(r->rsrc < 0, CONSISTENCY, + "srcobstructp() called with unaimed ray"); + noobs = OVOID; + srcp = &source[r->rsrc]; + if (srcp->obscache == NULL) /* initialize cache */ + initobscache(srcp); + /* compute cache index */ + if (srcp->sflags & SDISTANT) { + int ax, ax1, ax2; + double t; + ax = srcp->obscache->p.d.ax; + if ((ax1 = ax+1) >= 3) ax1 -= 3; + if ((ax2 = ax+2) >= 3) ax2 -= 3; + t = (srcp->obscache->p.d.o[ax] - r->rorg[ax]) / srcp->sloc[ax]; + if (t <= FTINY) + return &noobs; /* could happen if ray is outside */ + ondx = 2*SHADCACHE*(int)(2*SHADCACHE*srcp->obscache->p.d.e1 * + (r->rorg[ax1] + t*srcp->sloc[ax1] - + srcp->obscache->p.d.o[ax1])); + ondx += (int)(2*SHADCACHE*srcp->obscache->p.d.e2 * + (r->rorg[ax2] + t*srcp->sloc[ax2] - + srcp->obscache->p.d.o[ax2])); + if (ondx < 0 | ondx >= 4*SHADCACHE*SHADCACHE) + return &nobs; /* could happen if ray is outside */ + } else if (srcp->sflags & SFLAT) { + FVECT sd; + RREAL sd0m, sd1m; + sd[0] = -DOT(r->rdir, srcp->obscache->p.f.u); + sd[1] = -DOT(r->rdir, srcp->obscache->p.f.v); + sd[2] = -DOT(r->rdir, srcp->snorm); + if (sd[2] < 0) + return &noobs; /* shouldn't happen */ + sd0m = ABS(sd[0]); + sd1m = ABS(sd[1]); + if (sd[2] >= sd0m && sd[2] >= sd1m) { + ondx = SHADCACHE*(int)(SHADCACHE*(.5-FTINY) * + (1. + sd[0]/sd[2])); + ondx += (int)(SHADCACHE*(.5-FTINY) * + (1. + sd[1]/sd[2])); + } else if (sd0m >= sd1m) { + ondx = SHADCACHE*SHADCACHE; + if (sd[0] < 0) + ondx += ((SHADCACHE+1)>>1)*SHADCACHE; + ondx += SHADCACHE*(int)(SHADCACHE*(.5-FTINY) * + sd[2]/sd0m); + ondx += (int)(SHADCACHE*(.5-FTINY) * + (1. + sd[1]/sd0m)); + } else /* sd1m > sd0m */ { + ondx = SHADCACHE*SHADCACHE + + ((SHADCACHE+1)>>1)*SHADCACHE*2; + if (sd[1] < 0) + ondx += ((SHADCACHE+1)>>1)*SHADCACHE; + ondx += SHADCACHE*(int)(SHADCACHE*(.5-FTINY) * + sd[2]/sd1m); + ondx += (int)(SHADCACHE*(.5-FTINY) * + (1. + sd[0]/sd1m)); + } + } else /* spherical distribution */ { + int ax, ax1, ax2; + RREAL amax = 0; + for (ax1 = 3; ax1--; ) + if (ABS(r->rdir[ax1]) > amax) { + amax = ABS(r->rdir[ax1]); + ax = ax1; + } + if ((ax1 = ax+1) >= 3) ax1 -= 3; + if ((ax2 = ax+2) >= 3) ax2 -= 3; + ondx = 2*SHADCACHE*SHADCACHE * ax; + if (r->rdir[ax] < 0) + ondx += SHADCACHE*SHADCACHE; + ondx += SHADCACHE*(int)(SHADCACHE*(.5-FTINY) * + (1. + r->rdir[ax1]/amax)); + ondx += (int)(SHADCACHE*(.5-FTINY) * + (1. + r->rdir[ax2]/amax)); + } + /* return cache pointer */ + return(&srcp->obscache->obs[ondx]); +} + + +void /* free obstruction cache */ +freeobscache(SRCREC *srcp) +{ + if (srcp->obscache == NULL) + return; + free((void *)srcp->obscache); + srcp->obscache = NULL; +} + + +void /* record a source blocker */ +srcblocker(register RAY *r) +{ + OBJREC *m; + + if (r->robj == OVOID || objptr(r->robj) != r->ro || + isvolume(r->ro->otype)) + return; /* don't record complex blockers */ + m = findmaterial(r->ro); + if (m == NULL) + return; /* no material?! */ + if (!(ofun[m->otype].flags & T_OPAQUE)) + return; /* material not a reliable blocker */ + + *srcobstructp(r) = r->robj; /* else record obstructor */ +} + + +int /* check ray against cached blocker */ +srcblocked(RAY *r) +{ + OBJECT obs = *srcobstructp(r); + OBJREC *op; + + if (obs == OVOID) + return(0); + op = objptr(obs); /* check for intersection */ + return ((*ofun[op->otype].funp)(op, r)); +} + +#endif + + static int -cntcmp(sc1, sc2) /* contribution compare (descending) */ -register CNTPTR *sc1, *sc2; +cntcmp( /* contribution compare (descending) */ +const void *p1, +const void *p2 +) { + register const CNTPTR *sc1 = (const CNTPTR *)p1; + register const CNTPTR *sc2 = (const CNTPTR *)p2; + if (sc1->brt > sc2->brt) return(-1); if (sc1->brt < sc2->brt) @@ -249,12 +500,14 @@ register CNTPTR *sc1, *sc2; } -direct(r, f, p) /* add direct component */ -RAY *r; /* ray that hit surface */ -int (*f)(); /* direct component coefficient function */ -char *p; /* data for f */ +void +direct( /* add direct component */ +RAY *r, /* ray that hit surface */ +void (*f)(), /* direct component coefficient function */ +char *p /* data for f */ +) { - extern int (*trace)(); + extern void (*trace)(); register int sn; register CONTRIB *scp; SRCINDEX si; @@ -270,11 +523,11 @@ char *p; /* data for f */ for (sn = 0; srcray(&sr, r, &si); sn++) { if (sn >= maxcntr) { maxcntr = sn + MAXSPART; - srccnt = (CONTRIB *)realloc((char *)srccnt, + srccnt = (CONTRIB *)realloc((void *)srccnt, maxcntr*sizeof(CONTRIB)); - cntord = (CNTPTR *)realloc((char *)cntord, + cntord = (CNTPTR *)realloc((void *)cntord, maxcntr*sizeof(CNTPTR)); - if (srccnt == NULL | cntord == NULL) + if ((srccnt == NULL) | (cntord == NULL)) error(SYSTEM, "out of memory in direct"); } cntord[sn].sndx = sn; @@ -285,6 +538,13 @@ char *p; /* data for f */ cntord[sn].brt = bright(scp->coef); if (cntord[sn].brt <= 0.0) continue; +#if SHADCACHE + /* check shadow cache */ + if (si.np == 1 && srcblocked(&sr)) { + cntord[sn].brt = 0.0; + continue; + } +#endif VCOPY(scp->dir, sr.rdir); /* compute potential */ sr.revf = srcvalue; @@ -332,7 +592,11 @@ char *p; /* data for f */ rayorigin(&sr, r, SHADOW, 1.0); VCOPY(sr.rdir, scp->dir); sr.rsrc = scp->sno; - source[scp->sno].ntests++; /* keep statistics */ + /* keep statistics */ + if (source[scp->sno].ntests++ > 0xfffffff0) { + source[scp->sno].ntests >>= 1; + source[scp->sno].nhits >>= 1; + } if (localhit(&sr, &thescene) && ( sr.ro != source[scp->sno].so || source[scp->sno].sflags & SFOLLOW )) { @@ -341,8 +605,15 @@ char *p; /* data for f */ rayparticipate(&sr); if (trace != NULL) (*trace)(&sr); /* trace execution */ - if (bright(sr.rcol) <= FTINY) + if (bright(sr.rcol) <= FTINY) { +#if SHADCACHE + if ((scp <= srccnt || scp[-1].sno != scp->sno) + && (scp >= srccnt+ncnts || + scp[1].sno != scp->sno)) + srcblocker(&sr); +#endif continue; /* missed! */ + } copycolor(scp->val, sr.rcol); multcolor(scp->val, scp->coef); } @@ -374,15 +645,18 @@ char *p; /* data for f */ } -srcscatter(r) /* compute source scattering into ray */ -register RAY *r; +void +srcscatter( /* compute source scattering into ray */ +register RAY *r +) { int oldsampndx; int nsamps; RAY sr; SRCINDEX si; - double t, lastt, d; - COLOR cumval, ctmp; + double t, d; + double re, ge, be; + COLOR cvext; int i, j; if (r->slights == NULL || r->slights[0] == 0 @@ -397,11 +671,18 @@ register RAY *r; oldsampndx = samplendx; samplendx = random()&0x7fff; /* randomize */ for (i = r->slights[0]; i > 0; i--) { /* for each source */ - setcolor(cumval, 0., 0., 0.); - lastt = r->rot; - for (j = nsamps; j-- > 0; ) { /* for each sample position */ + for (j = 0; j < nsamps; j++) { /* for each sample position */ samplendx++; t = r->rot * (j+frandom())/nsamps; + /* extinction */ + re = t*colval(r->cext,RED); + ge = t*colval(r->cext,GRN); + be = t*colval(r->cext,BLU); + setcolor(cvext, re > 92. ? 0. : exp(-re), + ge > 92. ? 0. : exp(-ge), + be > 92. ? 0. : exp(-be)); + if (intens(cvext) <= FTINY) + break; /* too far away */ sr.rorg[0] = r->rorg[0] + r->rdir[0]*t; sr.rorg[1] = r->rorg[1] + r->rdir[1]*t; sr.rorg[2] = r->rorg[2] + r->rdir[2]*t; @@ -415,36 +696,25 @@ register RAY *r; copycolor(sr.cext, r->cext); copycolor(sr.albedo, r->albedo); sr.gecc = r->gecc; + sr.slights = r->slights; rayvalue(&sr); /* eval. source ray */ if (bright(sr.rcol) <= FTINY) continue; - /* compute fall-off */ - d = lastt - t; - setcolor(ctmp, 1.-d*colval(r->cext,RED), - 1.-d*colval(r->cext,GRN), - 1.-d*colval(r->cext,BLU)); - multcolor(cumval, ctmp); - lastt = t; if (r->gecc <= FTINY) /* compute P(theta) */ d = 1.; else { d = DOT(r->rdir, sr.rdir); - d = sqrt(1. + r->gecc*r->gecc - 2.*r->gecc*d); - d = (1. - r->gecc*r->gecc) / (d*d*d); + d = 1. + r->gecc*r->gecc - 2.*r->gecc*d; + d = (1. - r->gecc*r->gecc) / (d*sqrt(d)); } /* other factors */ d *= si.dom * r->rot / (4.*PI*nsamps); multcolor(sr.rcol, r->cext); multcolor(sr.rcol, r->albedo); scalecolor(sr.rcol, d); - addcolor(cumval, sr.rcol); + multcolor(sr.rcol, cvext); + addcolor(r->rcol, sr.rcol); /* add it in */ } - /* final fall-off */ - setcolor(ctmp, 1.-lastt*colval(r->cext,RED), - 1.-lastt*colval(r->cext,GRN), - 1.-lastt*colval(r->cext,BLU)); - multcolor(cumval, ctmp); - addcolor(r->rcol, cumval); /* sum into ray result */ } samplendx = oldsampndx; } @@ -466,13 +736,19 @@ register RAY *r; * geometry behind (or inside) an effective radiator. */ -static int weaksrcmod(obj) int obj; /* efficiency booster function */ -{register OBJREC *o = objptr(obj); -return(o->otype==MAT_ILLUM|o->otype==MAT_GLOW);} +static int +weaksrcmat(int obj) /* identify material */ +{ + register OBJREC *o = objptr(obj); + + while (!ismaterial(o->otype)) /* find material */ + o = objptr(o->omod); + return((o->otype==MAT_ILLUM)|(o->otype==MAT_GLOW)); +} #define illumblock(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \ r->rod > 0.0 && \ - weaksrcmod(source[r->rsrc].so->omod)) + weaksrcmat(source[r->rsrc].so->omod)) /* wrongsource * * @@ -528,9 +804,11 @@ return(o->otype==MAT_ILLUM|o->otype==MAT_GLOW);} distglow(m, r, raydist(r,PRIMARY))) -m_light(m, r) /* ray hit a light source */ -register OBJREC *m; -register RAY *r; +int +m_light( /* ray hit a light source */ +register OBJREC *m, +register RAY *r +) { /* check for over-counting */ if (badcomponent(m, r)) @@ -540,7 +818,7 @@ register RAY *r; /* check for passed illum */ if (passillum(m, r)) { if (m->oargs.nsargs && strcmp(m->oargs.sarg[0], VOIDID)) - return(rayshade(r, modifier(m->oargs.sarg[0]))); + return(rayshade(r,lastmod(objndx(m),m->oargs.sarg[0]))); raytrans(r); return(1); }
