--- ray/src/rt/source.c 1989/07/20 13:51:34 1.15 +++ ray/src/rt/source.c 1990/12/17 14:38:12 1.27 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1990 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -32,7 +32,10 @@ extern double shadcert; /* shadow testing certainty SRCREC *source = NULL; /* our list of sources */ int nsources = 0; /* the number of sources */ +static CONTRIB *srccnt; /* source contributions in direct() */ +static CNTPTR *cntord; /* source ordering in direct() */ + marksources() /* find and mark source objects */ { register OBJREC *o, *m; @@ -47,10 +50,7 @@ marksources() /* find and mark source objects */ m = objptr(o->omod); - if (m->otype != MAT_LIGHT && - m->otype != MAT_ILLUM && - m->otype != MAT_GLOW && - m->otype != MAT_SPOT) + if (!islight(m->otype)) continue; if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 : @@ -68,7 +68,7 @@ marksources() /* find and mark source objects */ source = (SRCREC *)realloc((char *)source, (unsigned)(nsources+1)*sizeof(SRCREC)); if (source == NULL) - error(SYSTEM, "out of memory in marksources"); + goto memerr; newsource(&source[nsources], o); @@ -83,6 +83,17 @@ marksources() /* find and mark source objects */ } nsources++; } + if (nsources <= 0) { + error(WARNING, "no light sources found"); + return; + } + srccnt = (CONTRIB *)malloc(nsources*sizeof(CONTRIB)); + cntord = (CNTPTR *)malloc(nsources*sizeof(CNTPTR)); + if (srccnt != NULL && cntord != NULL) + return; + /* fall through */ +memerr: + error(SYSTEM, "out of memory in marksources"); } @@ -226,26 +237,24 @@ register int sn; /* source number */ /* domega constant */ return(source[sn].ss2); - else { /* check proximity */ - if (source[sn].sflags & SPROX && - d > source[sn].sl.prox) - return(0.0); - - if (norm != NULL) - ddot /= d; - else - ddot = 1.0; + if (source[sn].sflags & SPROX && + d > source[sn].sl.prox) + return(0.0); + /* compute dot product */ + if (norm != NULL) + ddot /= d; + else + ddot = 1.0; /* check angle */ - if (source[sn].sflags & SSPOT) { - if (source[sn].sl.s->siz < 2.0*PI * + if (source[sn].sflags & SSPOT) { + if (source[sn].sl.s->siz < 2.0*PI * (1.0 + DOT(source[sn].sl.s->aim,sr->rdir))) - return(0.0); - d += source[sn].sl.s->flen; - } - /* return domega */ - return(ddot*source[sn].ss2/(d*d)); + return(0.0); + d += source[sn].sl.s->flen; /* adjust length */ } + /* compute domega */ + return(ddot*source[sn].ss2/(d*d)); } @@ -277,8 +286,7 @@ register RAY *r; for (i = 0; i < 3; i++) r->ron[i] = -r->rdir[i]; r->rod = 1.0; - r->rofs = 1.0; setident4(r->rofx); - r->robs = 1.0; setident4(r->robx); + r->rox = NULL; return(1); } return(0); @@ -304,16 +312,12 @@ char *p; /* data for f */ { extern double pow(); register int sn; - register CONTRIB *srccnt; - register CNTPTR *cntord; int nshadcheck, ncnts; double prob, ourthresh, hwt, test2, hit2; RAY sr; - - srccnt = (CONTRIB *)malloc(nsources*sizeof(CONTRIB)); - cntord = (CNTPTR *)malloc(nsources*sizeof(CNTPTR)); - if (srccnt == NULL || cntord == NULL) - error(SYSTEM, "out of memory in direct"); + /* NOTE: srccnt and cntord global so no recursion */ + if (nsources <= 0) + return; /* no sources?! */ /* compute number to check */ nshadcheck = pow((double)nsources, shadcert) + .5; /* modify threshold */ @@ -335,10 +339,15 @@ char *p; /* data for f */ if (!( source[sn].sflags & SDISTANT ? sourcehit(&sr) : (*ofun[source[sn].so->otype].funp) - (source[sn].so, &sr) )) + (source[sn].so, &sr) )) { + sprintf(errmsg, + "aiming failure for light source \"%s\"", + source[sn].so->oname); + error(WARNING, errmsg); continue; + } /* compute contribution */ - rayshade(&sr, sr.ro->omod); + raycont(&sr); multcolor(srccnt[sn].val, sr.rcol); cntord[sn].brt = bright(srccnt[sn].val); } @@ -365,8 +374,8 @@ char *p; /* data for f */ for (sn = 0; sn < ncnts; sn++) { /* check threshold */ if ((sn+nshadcheck>=ncnts ? cntord[sn].brt : - cntord[sn].brt-cntord[sn+nshadcheck].brt) < - ourthresh*bright(r->rcol)) + cntord[sn].brt-cntord[sn+nshadcheck].brt) + < ourthresh*bright(r->rcol)) break; /* get statistics */ hwt = (double)source[cntord[sn].sno].nhits / @@ -376,10 +385,11 @@ char *p; /* data for f */ /* test for hit */ rayorigin(&sr, r, SHADOW, 1.0); VCOPY(sr.rdir, srccnt[cntord[sn].sno].dir); + sr.rsrc = cntord[sn].sno; if (localhit(&sr, &thescene) && sr.ro != source[cntord[sn].sno].so) { /* check for transmission */ - rayshade(&sr, sr.ro->omod); + raycont(&sr); if (bright(sr.rcol) <= FTINY) continue; /* missed! */ (*f)(srccnt[cntord[sn].sno].val, p, @@ -406,9 +416,6 @@ char *p; /* data for f */ scalecolor(srccnt[cntord[sn].sno].val, prob); addcolor(r->rcol, srccnt[cntord[sn].sno].val); } - - free(srccnt); - free(cntord); } @@ -428,9 +435,6 @@ m_light(m, r) /* ray hit a light source */ register OBJREC *m; register RAY *r; { - /* check for behind */ - if (r->rod < 0.0) - return; /* check for over-counting */ if (wrongsource(m, r) || badambient(m, r)) return; @@ -444,6 +448,9 @@ register RAY *r; /* otherwise treat as source */ } else { + /* check for behind */ + if (r->rod < 0.0) + return; /* get distribution pattern */ raytexture(r, m->omod); /* get source color */ @@ -452,8 +459,7 @@ register RAY *r; m->oargs.farg[2]); /* modify value */ multcolor(r->rcol, r->pcol); + /* assign distance */ + r->rt = r->rot; } } - - -o_source() {} /* intersection with a source is done elsewhere */
