root/radiance/ray/src/rt/source.c
Revision: 2.57
Committed: Thu Jul 17 18:26:01 2008 UTC (17 years ago) by greg
Changed intens() call back to bright() as recommended by David Geisler-Moroder
2 static const char RCSid[] = "$Id: source.c,v 2.56 2007/07/25 04:12:36 greg Exp $";
5 * source.c - routines dealing with illumination sources.
6 *
7 * External symbols declared in source.h
8 */
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "rtotypes.h"
13 #include "source.h"
14 #include "random.h"
15
16 extern double ssampdist; /* scatter sampling distance */
17
18 #ifndef MAXSSAMP
19 #define MAXSSAMP 16 /* maximum samples per ray */
20 #endif
21
22 /*
23 * Structures used by direct()
24 */
25
26 typedef struct {
27 int sno; /* source number */
28 FVECT dir; /* source direction */
29 COLOR coef; /* material coefficient */
30 COLOR val; /* contribution */
31 } CONTRIB; /* direct contribution */
32
33 typedef struct {
34 int sndx; /* source index (to CONTRIB array) */
35 float brt; /* brightness (for comparison) */
36 } CNTPTR; /* contribution pointer */
37
38 static CONTRIB *srccnt; /* source contributions in direct() */
39 static CNTPTR *cntord; /* source ordering in direct() */
40 static int maxcntr = 0; /* size of contribution arrays */
41
42 static int cntcmp(const void *p1, const void *p2);
43
44
45 extern OBJREC * /* find an object's actual material */
46 findmaterial(register OBJREC *o)
47 {
48 while (!ismaterial(o->otype)) {
49 if (o->otype == MOD_ALIAS && o->oargs.nsargs) {
50 OBJECT aobj;
51 OBJREC *ao;
52 aobj = lastmod(objndx(o), o->oargs.sarg[0]);
53 if (aobj < 0)
54 objerror(o, USER, "bad reference");
55 ao = objptr(aobj);
56 if (ismaterial(ao->otype))
57 return(ao);
58 if (ao->otype == MOD_ALIAS) {
59 o = ao;
60 continue;
61 }
62 }
63 if (o->omod == OVOID)
64 return(NULL);
65 o = objptr(o->omod);
66 }
67 return(o); /* mixtures will return NULL */
68 }
69
70
71 extern void
72 marksources(void) /* find and mark source objects */
73 {
74 int foundsource = 0;
75 int i;
76 register OBJREC *o, *m;
77 register int ns;
78 /* initialize dispatch table */
79 initstypes();
80 /* find direct sources */
81 for (i = 0; i < nsceneobjs; i++) {
82
83 o = objptr(i);
84
85 if (!issurface(o->otype) || o->omod == OVOID)
86 continue;
87 /* find material */
88 m = findmaterial(objptr(o->omod));
89 if (m == NULL)
90 continue;
91 if (m->otype == MAT_CLIP) {
92 markclip(m); /* special case for antimatter */
93 continue;
94 }
95 if (!islight(m->otype))
96 continue; /* not source modifier */
97
98 if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
99 m->otype == MAT_SPOT ? 7 : 3))
100 objerror(m, USER, "bad # arguments");
101
102 if (m->otype == MAT_GLOW &&
103 o->otype != OBJ_SOURCE &&
104 m->oargs.farg[3] <= FTINY)
105 continue; /* don't bother */
106 if (m->oargs.farg[0] <= FTINY && m->oargs.farg[1] <= FTINY &&
107 m->oargs.farg[2] <= FTINY)
108 continue; /* don't bother */
109
110 if (sfun[o->otype].of == NULL ||
111 sfun[o->otype].of->setsrc == NULL)
112 objerror(o, USER, "illegal material");
113
114 if ((ns = newsource()) < 0)
115 goto memerr;
116
117 setsource(&source[ns], o);
118
119 if (m->otype == MAT_GLOW) {
120 source[ns].sflags |= SPROX;
121 source[ns].sl.prox = m->oargs.farg[3];
122 if (source[ns].sflags & SDISTANT)
123 source[ns].sflags |= SSKIP;
124 } else if (m->otype == MAT_SPOT) {
125 source[ns].sflags |= SSPOT;
126 if ((source[ns].sl.s = makespot(m)) == NULL)
127 goto memerr;
128 if (source[ns].sflags & SFLAT &&
129 !checkspot(source[ns].sl.s,source[ns].snorm)) {
130 objerror(o, WARNING,
131 "invalid spotlight direction");
132 source[ns].sflags |= SSKIP;
133 }
134 }
135 #if SHADCACHE
136 initobscache(ns);
137 #endif
138 if (!(source[ns].sflags & SSKIP))
139 foundsource++;
140 }
141 if (!foundsource) {
142 error(WARNING, "no light sources found");
143 return;
144 }
145 markvirtuals(); /* find and add virtual sources */
146 /* allocate our contribution arrays */
147 maxcntr = nsources + MAXSPART; /* start with this many */
148 srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB));
149 cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR));
150 if ((srccnt == NULL) | (cntord == NULL))
151 goto memerr;
152 return;
153 memerr:
154 error(SYSTEM, "out of memory in marksources");
155 }
156
157
158 extern void
159 freesources(void) /* free all source structures */
160 {
161 if (nsources > 0) {
162 #if SHADCACHE
163 while (nsources--)
164 freeobscache(&source[nsources]);
165 #endif
166 free((void *)source);
167 source = NULL;
168 nsources = 0;
169 }
170 if (maxcntr <= 0)
171 return;
172 free((void *)srccnt);
173 srccnt = NULL;
174 free((void *)cntord);
175 cntord = NULL;
176 maxcntr = 0;
177 }
178
179
180 extern int
181 srcray( /* send a ray to a source, return domega */
182 register RAY *sr, /* returned source ray */
183 RAY *r, /* ray which hit object */
184 SRCINDEX *si /* source sample index */
185 )
186 {
187 double d; /* distance to source */
188 register SRCREC *srcp;
189
190 rayorigin(sr, SHADOW, r, NULL); /* ignore limits */
191
192 while ((d = nextssamp(sr, si)) != 0.0) {
193 sr->rsrc = si->sn; /* remember source */
194 srcp = source + si->sn;
195 if (srcp->sflags & SDISTANT) {
196 if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s))
197 continue;
198 return(1); /* sample OK */
199 }
200 /* local source */
201 /* check proximity */
202 if (srcp->sflags & SPROX && d > srcp->sl.prox)
203 continue;
204 /* check angle */
205 if (srcp->sflags & SSPOT) {
206 if (spotout(sr, srcp->sl.s))
207 continue;
208 /* adjust solid angle */
209 si->dom *= d*d;
210 d += srcp->sl.s->flen;
211 si->dom /= d*d;
212 }
213 return(1); /* sample OK */
214 }
215 return(0); /* no more samples */
216 }
217
218
219 extern void
220 srcvalue( /* punch ray to source and compute value */
221 register RAY *r
222 )
223 {
224 register SRCREC *sp;
225
226 sp = &source[r->rsrc];
227 if (sp->sflags & SVIRTUAL) { /* virtual source */
228 /* check intersection */
229 if (!(*ofun[sp->so->otype].funp)(sp->so, r))
230 return;
231 if (!rayshade(r, r->ro->omod)) /* compute contribution */
232 goto nomat;
233 rayparticipate(r);
234 return;
235 }
236 /* compute intersection */
237 if (sp->sflags & SDISTANT ? sourcehit(r) :
238 (*ofun[sp->so->otype].funp)(sp->so, r)) {
239 if (sp->sa.success >= 0)
240 sp->sa.success++;
241 if (!rayshade(r, r->ro->omod)) /* compute contribution */
242 goto nomat;
243 rayparticipate(r);
244 return;
245 }
246 /* we missed our mark! */
247 if (sp->sa.success < 0)
248 return; /* bitched already */
249 sp->sa.success -= AIMREQT;
250 if (sp->sa.success >= 0)
251 return; /* leniency */
252 sprintf(errmsg, "aiming failure for light source \"%s\"",
253 sp->so->oname);
254 error(WARNING, errmsg); /* issue warning */
255 return;
256 nomat:
257 objerror(r->ro, USER, "material not found");
258 }
259
260
261 static int
262 transillum( /* check if material is transparent illum */
263 OBJECT obj
264 )
265 {
266 OBJREC *m = findmaterial(objptr(obj));
267
268 if (m == NULL)
269 return(1);
270 if (m->otype != MAT_ILLUM)
271 return(0);
272 return(!m->oargs.nsargs || !strcmp(m->oargs.sarg[0], VOIDID));
273 }
274
275
276 extern int
277 sourcehit( /* check to see if ray hit distant source */
278 register RAY *r
279 )
280 {
281 int glowsrc = -1;
282 int transrc = -1;
283 int first, last;
284 register int i;
285
286 if (r->rsrc >= 0) { /* check only one if aimed */
287 first = last = r->rsrc;
288 } else { /* otherwise check all */
289 first = 0; last = nsources-1;
290 }
291 for (i = first; i <= last; i++) {
292 if ((source[i].sflags & (SDISTANT|SVIRTUAL)) != SDISTANT)
293 continue;
294 /*
295 * Check to see if ray is within
296 * solid angle of source.
297 */
298 if (2.*PI*(1. - DOT(source[i].sloc,r->rdir)) > source[i].ss2)
299 continue;
300 /* is it the only possibility? */
301 if (first == last) {
302 r->ro = source[i].so;
303 break;
304 }
305 /*
306 * If it's a glow or transparent illum, just remember it.
307 */
308 if (source[i].sflags & SSKIP) {
309 glowsrc = i;
310 continue;
311 }
312 if (transillum(source[i].so->omod)) {
313 transrc = i;
314 continue;
315 }
316 r->ro = source[i].so; /* otherwise, use first hit */
317 break;
318 }
319 /*
320 * Do we need fallback?
321 */
322 if (r->ro == NULL) {
323 if (transrc >= 0 && r->crtype & (AMBIENT|SPECULAR))
324 return(0); /* avoid overcounting */
325 if (glowsrc >= 0)
326 r->ro = source[glowsrc].so;
327 else
328 return(0); /* nothing usable */
329 }
330 /*
331 * Make assignments.
332 */
333 r->robj = objndx(r->ro);
334 for (i = 0; i < 3; i++)
335 r->ron[i] = -r->rdir[i];
336 r->rod = 1.0;
337 r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
338 r->uv[0] = r->uv[1] = 0.0;
339 r->rox = NULL;
340 return(1);
341 }
342
343
344 static int
345 cntcmp( /* contribution compare (descending) */
346 const void *p1,
347 const void *p2
348 )
349 {
350 register const CNTPTR *sc1 = (const CNTPTR *)p1;
351 register const CNTPTR *sc2 = (const CNTPTR *)p2;
352
353 if (sc1->brt > sc2->brt)
354 return(-1);
355 if (sc1->brt < sc2->brt)
356 return(1);
357 return(0);
358 }
359
360
361 extern void
362 direct( /* add direct component */
363 RAY *r, /* ray that hit surface */
364 srcdirf_t *f, /* direct component coefficient function */
365 void *p /* data for f */
366 )
367 {
368 register int sn;
369 register CONTRIB *scp;
370 SRCINDEX si;
371 int nshadcheck, ncnts;
372 int nhits;
373 double prob, ourthresh, hwt;
374 RAY sr;
375 /* NOTE: srccnt and cntord global so no recursion */
376 if (nsources <= 0)
377 return; /* no sources?! */
378 /* potential contributions */
379 initsrcindex(&si);
380 for (sn = 0; srcray(&sr, r, &si); sn++) {
381 if (sn >= maxcntr) {
382 maxcntr = sn + MAXSPART;
383 srccnt = (CONTRIB *)realloc((void *)srccnt,
384 maxcntr*sizeof(CONTRIB));
385 cntord = (CNTPTR *)realloc((void *)cntord,
386 maxcntr*sizeof(CNTPTR));
387 if ((srccnt == NULL) | (cntord == NULL))
388 error(SYSTEM, "out of memory in direct");
389 }
390 cntord[sn].sndx = sn;
391 scp = srccnt + sn;
392 scp->sno = sr.rsrc;
393 /* compute coefficient */
394 (*f)(scp->coef, p, sr.rdir, si.dom);
395 cntord[sn].brt = intens(scp->coef);
396 if (cntord[sn].brt <= 0.0)
397 continue;
398 #if SHADCACHE
399 /* check shadow cache */
400 if (si.np == 1 && srcblocked(&sr)) {
401 cntord[sn].brt = 0.0;
402 continue;
403 }
404 #endif
405 VCOPY(scp->dir, sr.rdir);
406 copycolor(sr.rcoef, scp->coef);
407 /* compute potential */
408 sr.revf = srcvalue;
409 rayvalue(&sr);
410 multcolor(sr.rcol, sr.rcoef);
411 copycolor(scp->val, sr.rcol);
412 cntord[sn].brt = bright(sr.rcol);
413 }
414 /* sort contributions */
415 qsort(cntord, sn, sizeof(CNTPTR), cntcmp);
416 { /* find last */
417 register int l, m;
418
419 ncnts = l = sn;
420 sn = 0;
421 while ((m = (sn + ncnts) >> 1) != l) {
422 if (cntord[m].brt > 0.0)
423 sn = m;
424 else
425 ncnts = m;
426 l = m;
427 }
428 }
429 if (ncnts == 0)
430 return; /* no contributions! */
431 /* accumulate tail */
432 for (sn = ncnts-1; sn > 0; sn--)
433 cntord[sn-1].brt += cntord[sn].brt;
434 /* compute number to check */
435 nshadcheck = pow((double)ncnts, shadcert) + .5;
436 /* modify threshold */
437 ourthresh = shadthresh / r->rweight;
438 /* test for shadows */
439 for (nhits = 0, hwt = 0.0, sn = 0; sn < ncnts;
440 hwt += (double)source[scp->sno].nhits /
441 (double)source[scp->sno].ntests,
442 sn++) {
443 /* check threshold */
444 if ((sn+nshadcheck>=ncnts ? cntord[sn].brt :
445 cntord[sn].brt-cntord[sn+nshadcheck].brt)
446 < ourthresh*bright(r->rcol))
447 break;
448 scp = srccnt + cntord[sn].sndx;
449 /* test for hit */
450 rayorigin(&sr, SHADOW, r, NULL);
451 copycolor(sr.rcoef, scp->coef);
452 VCOPY(sr.rdir, scp->dir);
453 sr.rsrc = scp->sno;
454 /* keep statistics */
455 if (source[scp->sno].ntests++ > 0xfffffff0) {
456 source[scp->sno].ntests >>= 1;
457 source[scp->sno].nhits >>= 1;
458 }
459 if (localhit(&sr, &thescene) &&
460 ( sr.ro != source[scp->sno].so ||
461 source[scp->sno].sflags & SFOLLOW )) {
462 /* follow entire path */
463 raycont(&sr);
464 if (trace != NULL)
465 (*trace)(&sr); /* trace execution */
466 if (bright(sr.rcol) <= FTINY) {
467 #if SHADCACHE
468 if ((scp <= srccnt || scp[-1].sno != scp->sno)
469 && (scp >= srccnt+ncnts-1 ||
470 scp[1].sno != scp->sno))
471 srcblocker(&sr);
472 #endif
473 continue; /* missed! */
474 }
475 rayparticipate(&sr);
476 multcolor(sr.rcol, sr.rcoef);
477 copycolor(scp->val, sr.rcol);
478 } else if (trace != NULL &&
479 (source[scp->sno].sflags & (SDISTANT|SVIRTUAL|SFOLLOW))
480 == (SDISTANT|SFOLLOW) &&
481 sourcehit(&sr) && rayshade(&sr, sr.ro->omod)) {
482 (*trace)(&sr); /* trace execution */
483 /* skip call to rayparticipate() & scp->val update */
484 }
485 /* add contribution if hit */
486 addcolor(r->rcol, scp->val);
487 nhits++;
488 source[scp->sno].nhits++;
489 }
490 /* source hit rate */
491 if (hwt > FTINY)
492 hwt = (double)nhits / hwt;
493 else
494 hwt = 0.5;
495 #ifdef DEBUG
496 sprintf(errmsg, "%d tested, %d untested, %f conditional hit rate\n",
497 sn, ncnts-sn, hwt);
498 eputs(errmsg);
499 #endif
500 /* add in untested sources */
501 for ( ; sn < ncnts; sn++) {
502 scp = srccnt + cntord[sn].sndx;
503 prob = hwt * (double)source[scp->sno].nhits /
504 (double)source[scp->sno].ntests;
505 if (prob < 1.0)
506 scalecolor(scp->val, prob);
507 addcolor(r->rcol, scp->val);
508 }
509 }
510
511
512 extern void
513 srcscatter( /* compute source scattering into ray */
514 register RAY *r
515 )
516 {
517 int oldsampndx;
518 int nsamps;
519 RAY sr;
520 SRCINDEX si;
521 double t, d;
522 double re, ge, be;
523 COLOR cvext;
524 int i, j;
525
526 if (r->slights == NULL || r->slights[0] == 0
527 || r->gecc >= 1.-FTINY || r->rot >= FHUGE)
528 return;
529 if (ssampdist <= FTINY || (nsamps = r->rot/ssampdist + .5) < 1)
530 nsamps = 1;
531 #if MAXSSAMP
532 else if (nsamps > MAXSSAMP)
533 nsamps = MAXSSAMP;
534 #endif
535 oldsampndx = samplendx;
536 samplendx = random()&0x7fff; /* randomize */
537 for (i = r->slights[0]; i > 0; i--) { /* for each source */
538 for (j = 0; j < nsamps; j++) { /* for each sample position */
539 samplendx++;
540 t = r->rot * (j+frandom())/nsamps;
541 /* extinction */
542 re = t*colval(r->cext,RED);
543 ge = t*colval(r->cext,GRN);
544 be = t*colval(r->cext,BLU);
545 setcolor(cvext, re > 92. ? 0. : exp(-re),
546 ge > 92. ? 0. : exp(-ge),
547 be > 92. ? 0. : exp(-be));
548 if (intens(cvext) <= FTINY)
549 break; /* too far away */
550 sr.rorg[0] = r->rorg[0] + r->rdir[0]*t;
551 sr.rorg[1] = r->rorg[1] + r->rdir[1]*t;
552 sr.rorg[2] = r->rorg[2] + r->rdir[2]*t;
553 sr.rmax = 0.;
554 initsrcindex(&si); /* sample ray to this source */
555 si.sn = r->slights[i];
556 nopart(&si, &sr);
557 if (!srcray(&sr, NULL, &si) ||
558 sr.rsrc != r->slights[i])
559 continue; /* no path */
560 #if SHADCACHE
561 if (srcblocked(&sr)) /* check shadow cache */
562 continue;
563 #endif
564 copycolor(sr.cext, r->cext);
565 copycolor(sr.albedo, r->albedo);
566 sr.gecc = r->gecc;
567 sr.slights = r->slights;
568 rayvalue(&sr); /* eval. source ray */
569 if (bright(sr.rcol) <= FTINY) {
570 #if SHADCACHE
571 srcblocker(&sr); /* add blocker to cache */
572 #endif
573 continue;
574 }
575 if (r->gecc <= FTINY) /* compute P(theta) */
576 d = 1.;
577 else {
578 d = DOT(r->rdir, sr.rdir);
579 d = 1. + r->gecc*r->gecc - 2.*r->gecc*d;
580 d = (1. - r->gecc*r->gecc) / (d*sqrt(d));
581 }
582 /* other factors */
583 d *= si.dom * r->rot / (4.*PI*nsamps);
584 multcolor(sr.rcol, r->cext);
585 multcolor(sr.rcol, r->albedo);
586 scalecolor(sr.rcol, d);
587 multcolor(sr.rcol, cvext);
588 addcolor(r->rcol, sr.rcol); /* add it in */
589 }
590 }
591 samplendx = oldsampndx;
592 }
593
594
595 /****************************************************************
596 * The following macros were separated from the m_light() routine
597 * because they are very nasty and difficult to understand.
598 */
599
600 /* illumblock *
601 *
602 * We cannot allow an illum to pass to another illum, because that
603 * would almost certainly constitute overcounting.
604 * However, we do allow an illum to pass to another illum
605 * that is actually going to relay to a virtual light source.
606 * We also prevent an illum from passing to a glow; this provides a
607 * convenient mechanism for defining detailed light source
608 * geometry behind (or inside) an effective radiator.
609 */
610
611 static int
612 weaksrcmat(OBJECT obj) /* identify material */
613 {
614 OBJREC *m = findmaterial(objptr(obj));
615
616 if (m == NULL) return(0);
617 return((m->otype==MAT_ILLUM) | (m->otype==MAT_GLOW));
618 }
619
620 #define illumblock(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \
621 r->rod > 0.0 && \
622 weaksrcmat(source[r->rsrc].so->omod))
623
624 /* wrongsource *
625 *
626 * This source is the wrong source (ie. overcounted) if we are
627 * aimed to a different source than the one we hit and the one
628 * we hit is not an illum that should be passed.
629 */
630
631 #define wrongsource(m, r) (r->rsrc>=0 && source[r->rsrc].so!=r->ro && \
632 (m->otype!=MAT_ILLUM || illumblock(m,r)))
633
634 /* distglow *
635 *
636 * A distant glow is an object that sometimes acts as a light source,
637 * but is too far away from the test point to be one in this case.
638 * (Glows with negative radii should NEVER participate in illumination.)
639 */
640
641 #define distglow(m, r, d) (m->otype==MAT_GLOW && \
642 m->oargs.farg[3] >= -FTINY && \
643 d > m->oargs.farg[3])
644
645 /* badcomponent *
646 *
647 * We must avoid counting light sources in the ambient calculation,
648 * since the direct component is handled separately. Therefore, any
649 * ambient ray which hits an active light source must be discarded.
650 * The same is true for stray specular samples, since the specular
651 * contribution from light sources is calculated separately.
652 */
653
654 #define badcomponent(m, r) (r->crtype&(AMBIENT|SPECULAR) && \
655 !(r->crtype&SHADOW || r->rod < 0.0 || \
656 /* not 100% correct */ distglow(m, r, r->rot)))
657
658 /* passillum *
659 *
660 * An illum passes to another material type when we didn't hit it
661 * on purpose (as part of a direct calculation), or it is relaying
662 * a virtual light source.
663 */
664
665 #define passillum(m, r) (m->otype==MAT_ILLUM && \
666 (r->rsrc<0 || source[r->rsrc].so!=r->ro || \
667 source[r->rsrc].sflags&SVIRTUAL))
668
669 /* srcignore *
670 *
671 * The -dv flag is normally on for sources to be visible.
672 */
673
674 #define srcignore(m, r) !(directvis || r->crtype&SHADOW || \
675 distglow(m, r, raydist(r,PRIMARY)))
676
677
678 extern int
679 m_light( /* ray hit a light source */
680 register OBJREC *m,
681 register RAY *r
682 )
683 {
684 /* check for over-counting */
685 if (badcomponent(m, r)) {
686 setcolor(r->rcoef, 0.0, 0.0, 0.0);
687 return(1);
688 }
689 if (wrongsource(m, r)) {
690 setcolor(r->rcoef, 0.0, 0.0, 0.0);
691 return(1);
692 }
693 /* check for passed illum */
694 if (passillum(m, r)) {
695 if (m->oargs.nsargs && strcmp(m->oargs.sarg[0], VOIDID))
696 return(rayshade(r,lastmod(objndx(m),m->oargs.sarg[0])));
697 raytrans(r);
698 return(1);
699 }
700 /* check for invisibility */
701 if (srcignore(m, r)) {
702 setcolor(r->rcoef, 0.0, 0.0, 0.0);
703 return(1);
704 }
705 /* otherwise treat as source */
706 /* check for behind */
707 if (r->rod < 0.0)
708 return(1);
709 /* check for outside spot */
710 if (m->otype==MAT_SPOT && spotout(r, makespot(m)))
711 return(1);
712 /* get distribution pattern */
713 raytexture(r, m->omod);
714 /* get source color */
715 setcolor(r->rcol, m->oargs.farg[0],
716 m->oargs.farg[1],
717 m->oargs.farg[2]);
718 /* modify value */
719 multcolor(r->rcol, r->pcol);
720 return(1);
721 }
