root/Development/ray/src/rt/source.c
Revision: 2.72
Committed: Mon Apr 6 21:09:07 2020 UTC (5 years, 8 months ago) by greg
Changes since 2.71: +55 -6 lines
Fixes and improvements from last change, making ray-casting faster
2 static const char RCSid[] = "$Id: source.c,v 2.71 2020/03/12 17:19:18 greg Exp $";
5 * source.c - routines dealing with illumination sources.
6 *
7 * External symbols declared in source.h
8 */
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "otspecial.h"
13 #include "rtotypes.h"
14 #include "source.h"
15 #include "random.h"
16 #include "pmapsrc.h"
17 #include "pmapmat.h"
18
19 #ifndef MAXSSAMP
20 #define MAXSSAMP 16 /* maximum samples per ray */
21 #endif
22
23 /*
24 * Structures used by direct()
25 */
26
27 typedef struct {
28 int sno; /* source number */
29 FVECT dir; /* source direction */
30 COLOR coef; /* material coefficient */
31 COLOR val; /* contribution */
32 } CONTRIB; /* direct contribution */
33
34 typedef struct {
35 int sndx; /* source index (to CONTRIB array) */
36 float brt; /* brightness (for comparison) */
37 } CNTPTR; /* contribution pointer */
38
39 static CONTRIB *srccnt; /* source contributions in direct() */
40 static CNTPTR *cntord; /* source ordering in direct() */
41 static int maxcntr = 0; /* size of contribution arrays */
42
43 static int cntcmp(const void *p1, const void *p2);
44
45
46 void
47 marksources(void) /* find and mark source objects */
48 {
49 int foundsource = 0;
50 int i;
51 OBJREC *o, *m;
52 int ns;
53 /* initialize dispatch table */
54 initstypes();
55 /* find direct sources */
56 for (i = 0; i < nsceneobjs; i++) {
57
58 o = objptr(i);
59
60 if (!issurface(o->otype) || o->omod == OVOID)
61 continue;
62 /* find material */
63 m = findmaterial(objptr(o->omod));
64 if (m == NULL)
65 continue;
66 if (m->otype == MAT_CLIP) {
67 markclip(m); /* special case for antimatter */
68 continue;
69 }
70 if (!islight(m->otype))
71 continue; /* not source modifier */
72
73 if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
74 m->otype == MAT_SPOT ? 7 : 3))
75 objerror(m, USER, "bad # arguments");
76
77 if (m->oargs.farg[0] <= FTINY && (m->oargs.farg[1] <= FTINY) &
78 (m->oargs.farg[2] <= FTINY))
79 continue; /* don't bother */
80 if (m->otype == MAT_GLOW &&
81 o->otype != OBJ_SOURCE &&
82 m->oargs.farg[3] <= FTINY) {
83 foundsource += (ambounce > 0);
84 continue; /* don't track these */
85 }
86 if (sfun[o->otype].of == NULL ||
87 sfun[o->otype].of->setsrc == NULL)
88 objerror(o, USER, "illegal material");
89
90 if ((ns = newsource()) < 0)
91 goto memerr;
92
93 setsource(&source[ns], o);
94
95 if (m->otype == MAT_GLOW) {
96 source[ns].sflags |= SPROX;
97 source[ns].sl.prox = m->oargs.farg[3];
98 if (source[ns].sflags & SDISTANT) {
99 source[ns].sflags |= SSKIP;
100 foundsource += (ambounce > 0);
101 }
102 } else if (m->otype == MAT_SPOT) {
103 if (source[ns].sflags & SDISTANT)
104 objerror(o, WARNING,
105 "distant source is a spotlight");
106 source[ns].sflags |= SSPOT;
107 if ((source[ns].sl.s = makespot(m)) == NULL)
108 goto memerr;
109 if (source[ns].sflags & SFLAT &&
110 !checkspot(source[ns].sl.s,source[ns].snorm)) {
111 objerror(o, WARNING,
112 "invalid spotlight direction");
113 source[ns].sflags |= SSKIP;
114 }
115 }
116 foundsource += !(source[ns].sflags & SSKIP);
117 }
118 if (!foundsource) {
119 error(WARNING, "no light sources found");
120 return;
121 }
122 #if SHADCACHE
123 for (ns = 0; ns < nsources; ns++) /* initialize obstructor cache */
124 initobscache(ns);
125 #endif
126 /* PMAP: disable virtual sources */
127 if (!photonMapping)
128 markvirtuals(); /* find and add virtual sources */
129
130 /* allocate our contribution arrays */
131 maxcntr = nsources + MAXSPART; /* start with this many */
132 srccnt = (CONTRIB *)malloc(maxcntr*sizeof(CONTRIB));
133 cntord = (CNTPTR *)malloc(maxcntr*sizeof(CNTPTR));
134 if ((srccnt != NULL) & (cntord != NULL))
135 return;
136 memerr:
137 error(SYSTEM, "out of memory in marksources");
138 }
139
140
141 void
142 distantsources(void) /* only mark distant sources */
143 {
144 int i;
145 OBJREC *o, *m;
146 int ns;
147 /* initialize dispatch table */
148 initstypes();
149 /* sources needed for sourcehit() */
150 for (i = 0; i < nsceneobjs; i++) {
151
152 o = objptr(i);
153
154 if ((o->otype != OBJ_SOURCE) | (o->omod == OVOID))
155 continue;
156 /* find material */
157 m = findmaterial(objptr(o->omod));
158 if (m == NULL)
159 continue;
160 if (!islight(m->otype))
161 continue; /* not source modifier */
162
163 if (m->oargs.nfargs != (m->otype == MAT_GLOW ? 4 :
164 m->otype == MAT_SPOT ? 7 : 3))
165 objerror(m, USER, "bad # arguments");
166
167 if (m->oargs.farg[0] <= FTINY && (m->oargs.farg[1] <= FTINY) &
168 (m->oargs.farg[2] <= FTINY))
169 continue; /* don't bother */
170 if (sfun[o->otype].of == NULL ||
171 sfun[o->otype].of->setsrc == NULL)
172 objerror(o, USER, "illegal material");
173
174 if ((ns = newsource()) < 0)
175 error(SYSTEM, "out of memory in distantsources");
176
177 setsource(&source[ns], o);
178
179 if (m->otype == MAT_GLOW) {
180 source[ns].sflags |= SPROX|SSKIP;
181 source[ns].sl.prox = m->oargs.farg[3];
182 } else if (m->otype == MAT_SPOT)
183 objerror(o, WARNING, "distant source is a spotlight");
184 }
185 }
186
187
188 void
189 freesources(void) /* free all source structures */
190 {
191 if (nsources > 0) {
192 #if SHADCACHE
193 while (nsources--)
194 freeobscache(&source[nsources]);
195 #endif
196 free((void *)source);
197 source = NULL;
198 nsources = 0;
199 }
200 markclip(NULL);
201 if (maxcntr <= 0)
202 return;
203 free((void *)srccnt);
204 srccnt = NULL;
205 free((void *)cntord);
206 cntord = NULL;
207 maxcntr = 0;
208 }
209
210
211 int
212 srcray( /* send a ray to a source, return domega */
213 RAY *sr, /* returned source ray */
214 RAY *r, /* ray which hit object */
215 SRCINDEX *si /* source sample index */
216 )
217 {
218 double d; /* distance to source */
219 SRCREC *srcp;
220
221 rayorigin(sr, SHADOW, r, NULL); /* ignore limits */
222
223 if (r == NULL)
224 sr->rmax = 0.0;
225
226 while ((d = nextssamp(sr, si)) != 0.0) {
227 sr->rsrc = si->sn; /* remember source */
228 srcp = source + si->sn;
229 if (srcp->sflags & SDISTANT) {
230 if (srcp->sflags & SSPOT && spotout(sr, srcp->sl.s))
231 continue;
232 return(1); /* sample OK */
233 }
234 /* local source */
235 /* check proximity */
236 if (srcp->sflags & SPROX && d > srcp->sl.prox)
237 continue;
238 /* check angle */
239 if (srcp->sflags & SSPOT) {
240 if (spotout(sr, srcp->sl.s))
241 continue;
242 /* adjust solid angle */
243 si->dom *= d*d;
244 d += srcp->sl.s->flen;
245 si->dom /= d*d;
246 }
247 return(1); /* sample OK */
248 }
249 return(0); /* no more samples */
250 }
251
252
253 void
254 srcvalue( /* punch ray to source and compute value */
255 RAY *r
256 )
257 {
258 SRCREC *sp;
259
260 sp = &source[r->rsrc];
261 if (sp->sflags & SVIRTUAL) { /* virtual source */
262 /* check intersection */
263 if (!(*ofun[sp->so->otype].funp)(sp->so, r))
264 return;
265 if (!rayshade(r, r->ro->omod)) /* compute contribution */
266 goto nomat;
267 rayparticipate(r);
268 return;
269 }
270 /* compute intersection */
271 if (sp->sflags & SDISTANT ? sourcehit(r) :
272 (*ofun[sp->so->otype].funp)(sp->so, r)) {
273 if (sp->sa.success >= 0)
274 sp->sa.success++;
275 if (!rayshade(r, r->ro->omod)) /* compute contribution */
276 goto nomat;
277 rayparticipate(r);
278 return;
279 }
280 /* we missed our mark! */
281 if (sp->sa.success < 0)
282 return; /* bitched already */
283 sp->sa.success -= AIMREQT;
284 if (sp->sa.success >= 0)
285 return; /* leniency */
286 sprintf(errmsg, "aiming failure for light source \"%s\"",
287 sp->so->oname);
288 error(WARNING, errmsg); /* issue warning */
289 return;
290 nomat:
291 objerror(r->ro, USER, "material not found");
292 }
293
294
295 static int
296 transillum( /* check if material is transparent illum */
297 OBJECT obj
298 )
299 {
300 OBJREC *m = findmaterial(objptr(obj));
301
302 if (m == NULL)
303 return(1);
304 if (m->otype != MAT_ILLUM)
305 return(0);
306 return(!m->oargs.nsargs || !strcmp(m->oargs.sarg[0], VOIDID));
307 }
308
309
310 int
311 sourcehit( /* check to see if ray hit distant source */
312 RAY *r
313 )
314 {
315 int glowsrc = -1;
316 int transrc = -1;
317 int first, last;
318 int i;
319
320 if (r->rsrc >= 0) { /* check only one if aimed */
321 first = last = r->rsrc;
322 } else { /* otherwise check all */
323 first = 0; last = nsources-1;
324 }
325 for (i = first; i <= last; i++) {
326 if ((source[i].sflags & (SDISTANT|SVIRTUAL)) != SDISTANT)
327 continue;
328 /*
329 * Check to see if ray is within
330 * solid angle of source.
331 */
332 if (2.*PI*(1. - DOT(source[i].sloc,r->rdir)) > source[i].ss2)
333 continue;
334 /* is it the only possibility? */
335 if (first == last) {
336 r->ro = source[i].so;
337 break;
338 }
339 /*
340 * If it's a glow or transparent illum, just remember it.
341 */
342 if (source[i].sflags & SSKIP) {
343 if (glowsrc < 0)
344 glowsrc = i;
345 continue;
346 }
347 if (transillum(source[i].so->omod)) {
348 if (transrc < 0)
349 transrc = i;
350 continue;
351 }
352 r->ro = source[i].so; /* otherwise, use first hit */
353 break;
354 }
355 /*
356 * Do we need fallback?
357 */
358 if (r->ro == NULL) {
359 if (transrc >= 0 && r->crtype & (AMBIENT|SPECULAR))
360 return(0); /* avoid overcounting */
361 if (glowsrc >= 0)
362 r->ro = source[glowsrc].so;
363 else
364 return(0); /* nothing usable */
365 }
366 /*
367 * Make assignments.
368 */
369 r->robj = objndx(r->ro);
370 for (i = 0; i < 3; i++)
371 r->ron[i] = -r->rdir[i];
372 r->rod = 1.0;
373 r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
374 r->uv[0] = r->uv[1] = 0.0;
375 r->rox = NULL;
376 return(1);
377 }
378
379
380 static int
381 cntcmp( /* contribution compare (descending) */
382 const void *p1,
383 const void *p2
384 )
385 {
386 const CNTPTR *sc1 = (const CNTPTR *)p1;
387 const CNTPTR *sc2 = (const CNTPTR *)p2;
388
389 if (sc1->brt > sc2->brt)
390 return(-1);
391 if (sc1->brt < sc2->brt)
392 return(1);
393 return(0);
394 }
395
396
397 void
398 direct( /* add direct component */
399 RAY *r, /* ray that hit surface */
400 srcdirf_t *f, /* direct component coefficient function */
401 void *p /* data for f */
402 )
403 {
404 int sn;
405 CONTRIB *scp;
406 SRCINDEX si;
407 int nshadcheck, ncnts;
408 int nhits;
409 double prob, ourthresh, hwt;
410 RAY sr;
411
412 /* PMAP: Factor in direct photons (primarily for debugging/validation) */
413 if (directPhotonMapping) {
414 (*f)(r -> rcol, p, r -> ron, PI);
415 multDirectPmap(r);
416 return;
417 }
418
419 /* NOTE: srccnt and cntord global so no recursion */
420 if (nsources <= 0)
421 return; /* no sources?! */
422 /* potential contributions */
423 initsrcindex(&si);
424 for (sn = 0; srcray(&sr, r, &si); sn++) {
425 if (sn >= maxcntr) {
426 maxcntr = sn + MAXSPART;
427 srccnt = (CONTRIB *)realloc((void *)srccnt,
428 maxcntr*sizeof(CONTRIB));
429 cntord = (CNTPTR *)realloc((void *)cntord,
430 maxcntr*sizeof(CNTPTR));
431 if ((srccnt == NULL) | (cntord == NULL))
432 error(SYSTEM, "out of memory in direct");
433 }
434 cntord[sn].sndx = sn;
435 scp = srccnt + sn;
436 scp->sno = sr.rsrc;
437 /* compute coefficient */
438 (*f)(scp->coef, p, sr.rdir, si.dom);
439 cntord[sn].brt = intens(scp->coef);
440 if (cntord[sn].brt <= 0.0)
441 continue;
442 #if SHADCACHE
443 /* check shadow cache */
444 if (si.np == 1 && srcblocked(&sr)) {
445 cntord[sn].brt = 0.0;
446 continue;
447 }
448 #endif
449 VCOPY(scp->dir, sr.rdir);
450 copycolor(sr.rcoef, scp->coef);
451 /* compute potential */
452 sr.revf = srcvalue;
453 rayvalue(&sr);
454 multcolor(sr.rcol, sr.rcoef);
455 copycolor(scp->val, sr.rcol);
456 cntord[sn].brt = bright(sr.rcol);
457 }
458 /* sort contributions */
459 qsort(cntord, sn, sizeof(CNTPTR), cntcmp);
460 { /* find last */
461 int l, m;
462
463 ncnts = l = sn;
464 sn = 0;
465 while ((m = (sn + ncnts) >> 1) != l) {
466 if (cntord[m].brt > 0.0)
467 sn = m;
468 else
469 ncnts = m;
470 l = m;
471 }
472 }
473 if (ncnts == 0)
474 return; /* no contributions! */
475 /* accumulate tail */
476 for (sn = ncnts-1; sn > 0; sn--)
477 cntord[sn-1].brt += cntord[sn].brt;
478 /* compute number to check */
479 nshadcheck = pow((double)ncnts, shadcert) + .5;
480 /* modify threshold */
481 if (ncnts > MINSHADCNT)
482 ourthresh = shadthresh / r->rweight;
483 else
484 ourthresh = 0;
485 /* test for shadows */
486 for (nhits = 0, hwt = 0.0, sn = 0; sn < ncnts;
487 hwt += (double)source[scp->sno].nhits /
488 (double)source[scp->sno].ntests,
489 sn++) {
490 /* check threshold */
491 if ((sn+nshadcheck>=ncnts ? cntord[sn].brt :
492 cntord[sn].brt-cntord[sn+nshadcheck].brt)
493 < ourthresh*bright(r->rcol))
494 break;
495 scp = srccnt + cntord[sn].sndx;
496 /* test for hit */
497 rayorigin(&sr, SHADOW, r, NULL);
498 copycolor(sr.rcoef, scp->coef);
499 VCOPY(sr.rdir, scp->dir);
500 sr.rsrc = scp->sno;
501 /* keep statistics */
502 if (source[scp->sno].ntests++ > 0xfffffff0) {
503 source[scp->sno].ntests >>= 1;
504 source[scp->sno].nhits >>= 1;
505 }
506 if (localhit(&sr, &thescene) &&
507 ( sr.ro != source[scp->sno].so ||
508 source[scp->sno].sflags & SFOLLOW )) {
509 /* follow entire path */
510 raycont(&sr);
511 if (trace != NULL)
512 (*trace)(&sr); /* trace execution */
513 if (bright(sr.rcol) <= FTINY) {
514 #if SHADCACHE
515 if ((scp <= srccnt || scp[-1].sno != scp->sno)
516 && (scp >= srccnt+ncnts-1 ||
517 scp[1].sno != scp->sno))
518 srcblocker(&sr);
519 #endif
520 continue; /* missed! */
521 }
522 rayparticipate(&sr);
523 multcolor(sr.rcol, sr.rcoef);
524 copycolor(scp->val, sr.rcol);
525 } else if (trace != NULL &&
526 (source[scp->sno].sflags & (SDISTANT|SVIRTUAL|SFOLLOW))
527 == (SDISTANT|SFOLLOW) &&
528 sourcehit(&sr) && rayshade(&sr, sr.ro->omod)) {
529 (*trace)(&sr); /* trace execution */
530 /* skip call to rayparticipate() & scp->val update */
531 }
532 /* add contribution if hit */
533 addcolor(r->rcol, scp->val);
534 nhits++;
535 source[scp->sno].nhits++;
536 }
537 /* source hit rate */
538 if (hwt > FTINY)
539 hwt = (double)nhits / hwt;
540 else
541 hwt = 0.5;
542 #ifdef DEBUG
543 sprintf(errmsg, "%d tested, %d untested, %f conditional hit rate\n",
544 sn, ncnts-sn, hwt);
545 eputs(errmsg);
546 #endif
547 /* add in untested sources */
548 for ( ; sn < ncnts; sn++) {
549 scp = srccnt + cntord[sn].sndx;
550 prob = hwt * (double)source[scp->sno].nhits /
551 (double)source[scp->sno].ntests;
552 if (prob < 1.0)
553 scalecolor(scp->val, prob);
554 addcolor(r->rcol, scp->val);
555 }
556 }
557
558
559 void
560 srcscatter( /* compute source scattering into ray */
561 RAY *r
562 )
563 {
564 int oldsampndx;
565 int nsamps;
566 RAY sr;
567 SRCINDEX si;
568 double t, d;
569 double re, ge, be;
570 COLOR cvext;
571 int i, j;
572
573 if (r->rot >= FHUGE*.99 || r->gecc >= 1.-FTINY)
574 return; /* this can never work */
575 /* PMAP: do unconditional inscattering for volume photons */
576 if (!volumePhotonMapping && (r->slights == NULL || r->slights[0] == 0))
577 return;
578
579 if (ssampdist <= FTINY || (nsamps = r->rot/ssampdist + .5) < 1)
580 nsamps = 1;
581 #if MAXSSAMP
582 else if (nsamps > MAXSSAMP)
583 nsamps = MAXSSAMP;
584 #endif
585 oldsampndx = samplendx;
586 samplendx = random()&0x7fff; /* randomize */
587 for (i = volumePhotonMapping ? 1 : r->slights[0]; i > 0; i--) {
588 /* for each source OR once if volume photon map enabled */
589 for (j = 0; j < nsamps; j++) { /* for each sample position */
590 samplendx++;
591 t = r->rot * (j+frandom())/nsamps;
592 /* extinction */
593 re = t*colval(r->cext,RED);
594 ge = t*colval(r->cext,GRN);
595 be = t*colval(r->cext,BLU);
596 setcolor(cvext, re > 92. ? 0. : exp(-re),
597 ge > 92. ? 0. : exp(-ge),
598 be > 92. ? 0. : exp(-be));
599 if (intens(cvext) <= FTINY)
600 break; /* too far away */
601 sr.rorg[0] = r->rorg[0] + r->rdir[0]*t;
602 sr.rorg[1] = r->rorg[1] + r->rdir[1]*t;
603 sr.rorg[2] = r->rorg[2] + r->rdir[2]*t;
604
605 if (!volumePhotonMapping) {
606 initsrcindex(&si); /* sample ray to this source */
607 si.sn = r->slights[i];
608 nopart(&si, &sr);
609 if (!srcray(&sr, NULL, &si) ||
610 sr.rsrc != r->slights[i])
611 continue; /* no path */
612 #if SHADCACHE
613 if (srcblocked(&sr)) /* check shadow cache */
614 continue;
615 #endif
616 copycolor(sr.cext, r->cext);
617 copycolor(sr.albedo, r->albedo);
618 sr.gecc = r->gecc;
619 sr.slights = r->slights;
620 rayvalue(&sr); /* eval. source ray */
621 if (bright(sr.rcol) <= FTINY) {
622 #if SHADCACHE
623 srcblocker(&sr); /* add blocker to cache */
624 #endif
625 continue;
626 }
627 if (r->gecc <= FTINY) /* compute P(theta) */
628 d = 1.;
629 else {
630 d = DOT(r->rdir, sr.rdir);
631 d = 1. + r->gecc*r->gecc - 2.*r->gecc*d;
632 d = (1. - r->gecc*r->gecc) / (d*sqrt(d));
633 }
634 /* other factors */
635 d *= si.dom * r->rot / (4.*PI*nsamps);
636 scalecolor(sr.rcol, d);
637 } else {
638 /* PMAP: Add ambient inscattering from
639 * volume photons; note we reverse the
640 * incident ray direction since we're
641 * now in *backward* raytracing mode! */
642 sr.rdir [0] = -r -> rdir [0];
643 sr.rdir [1] = -r -> rdir [1];
644 sr.rdir [2] = -r -> rdir [2];
645 sr.gecc = r -> gecc;
646 inscatterVolumePmap(&sr, sr.rcol);
647 scalecolor(sr.rcol, r -> rot / nsamps);
648 }
649 multcolor(sr.rcol, r->cext);
650 multcolor(sr.rcol, r->albedo);
651 multcolor(sr.rcol, cvext);
652 addcolor(r->rcol, sr.rcol); /* add it in */
653 }
654 }
655 samplendx = oldsampndx;
656 }
657
658
659 /****************************************************************
660 * The following macros were separated from the m_light() routine
661 * because they are very nasty and difficult to understand.
662 */
663
664 /* illumblock *
665 *
666 * We cannot allow an illum to pass to another illum, because that
667 * would almost certainly constitute overcounting.
668 * However, we do allow an illum to pass to another illum
669 * that is actually going to relay to a virtual light source.
670 * We also prevent an illum from passing to a glow; this provides a
671 * convenient mechanism for defining detailed light source
672 * geometry behind (or inside) an effective radiator.
673 */
674
675 static int
676 weaksrcmat(OBJECT obj) /* identify material */
677 {
678 OBJREC *m = findmaterial(objptr(obj));
679
680 if (m == NULL) return(0);
681 return((m->otype==MAT_ILLUM) | (m->otype==MAT_GLOW));
682 }
683
684 #define illumblock(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \
685 r->rod > 0.0 && \
686 weaksrcmat(source[r->rsrc].so->omod))
687
688 /* wrongsource *
689 *
690 * This source is the wrong source (ie. overcounted) if we are
691 * aimed to a different source than the one we hit and the one
692 * we hit is not an illum that should be passed.
693 */
694
695 #define wrongsource(m, r) (r->rsrc>=0 && source[r->rsrc].so!=r->ro && \
696 (m->otype!=MAT_ILLUM || illumblock(m,r)))
697
698 /* distglow *
699 *
700 * A distant glow is an object that sometimes acts as a light source,
701 * but is too far away from the test point to be one in this case.
702 * (Glows with negative radii should NEVER participate in illumination.)
703 */
704
705 #define distglow(m, r, d) (m->otype==MAT_GLOW && \
706 m->oargs.farg[3] >= -FTINY && \
707 d > m->oargs.farg[3])
708
709 /* badcomponent *
710 *
711 * We must avoid counting light sources in the ambient calculation,
712 * since the direct component is handled separately. Therefore, any
713 * ambient ray which hits an active light source must be discarded.
714 * The same is true for stray specular samples, since the specular
715 * contribution from light sources is calculated separately.
716 */
717 /* PMAP: Also avoid counting sources via transferred ambient rays (e.g.
718 * through glass) when photon mapping is enabled, as these indirect
719 * components are already accounted for.
720 */
721 #define badcomponent(m, r) (srcRayInPmap(r) || \
722 (r->crtype&(AMBIENT|SPECULAR) && \
723 !(r->crtype&SHADOW || r->rod < 0.0 || \
724 /* not 100% correct */ distglow(m, r, r->rot))))
725
726 /* passillum *
727 *
728 * An illum passes to another material type when we didn't hit it
729 * on purpose (as part of a direct calculation), or it is relaying
730 * a virtual light source.
731 */
732
733 #define passillum(m, r) (m->otype==MAT_ILLUM && \
734 (r->rsrc<0 || source[r->rsrc].so!=r->ro || \
735 source[r->rsrc].sflags&SVIRTUAL))
736
737 /* srcignore *
738 *
739 * The -dv flag is normally on for sources to be visible.
740 */
741
742 #define srcignore(m, r) !(directvis || r->crtype&SHADOW || \
743 distglow(m, r, raydist(r,PRIMARY)))
744
745
746 int
747 m_light( /* ray hit a light source */
748 OBJREC *m,
749 RAY *r
750 )
751 {
752 /* check for over-counting */
753 if (badcomponent(m, r)) {
754 setcolor(r->rcoef, 0.0, 0.0, 0.0);
755 return(1);
756 }
757 if (wrongsource(m, r)) {
758 setcolor(r->rcoef, 0.0, 0.0, 0.0);
759 return(1);
760 }
761 /* check for passed illum */
762 if (passillum(m, r)) {
763 if (m->oargs.nsargs && strcmp(m->oargs.sarg[0], VOIDID))
764 return(rayshade(r,lastmod(objndx(m),m->oargs.sarg[0])));
765 raytrans(r);
766 return(1);
767 }
768 /* check for invisibility */
769 if (srcignore(m, r)) {
770 setcolor(r->rcoef, 0.0, 0.0, 0.0);
771 return(1);
772 }
773 /* otherwise treat as source */
774 /* check for behind */
775 if (r->rod < 0.0)
776 return(1);
777 /* check for outside spot */
778 if (m->otype==MAT_SPOT && spotout(r, makespot(m)))
779 return(1);
780 /* get distribution pattern */
781 raytexture(r, m->omod);
782 /* get source color */
783 setcolor(r->rcol, m->oargs.farg[0],
784 m->oargs.farg[1],
785 m->oargs.farg[2]);
786 /* modify value */
787 multcolor(r->rcol, r->pcol);
788 return(1);
789 }
