root/radiance/ray/src/rt/rxtrace.cpp
Thu Jan 2 02:59:15 2025 UTC (4 months ago) by greg
Changes since 2.8: +3 -4 lines
perf(rxtrace): Avoid final freeing of everything on exit
Thu Jan 2 01:54:49 2025 UTC (4 months ago) by greg
Changes since 2.7: +10 -10 lines
fix(rtrace,rxtrace): Made it so -oW doesn't include luminous efficacy multiplier
Tue Nov 19 16:29:44 2024 UTC (5 months, 2 weeks ago) by greg
fix(rxtrace): Compile error fix
Tue Nov 19 16:28:18 2024 UTC (5 months, 2 weeks ago) by greg
Changes since 2.5: +6 -4 lines
feat: Exposed some formerly static variables for Stephen Wasilewski
Thu May 2 22:10:43 2024 UTC (12 months ago) by greg
fix(rxtrace): Minor fixes
Wed May 1 22:06:09 2024 UTC (12 months ago) by greg
fix(rxtrace): Fixed spectral sampling set-up
Tue Apr 30 23:16:23 2024 UTC (12 months ago) by greg
Changes since 2.2: +103 -51 lines
feat(rxtrace): Added multi-processing and spectral color
Tue Mar 12 16:54:51 2024 UTC (13 months, 3 weeks ago) by greg
Changes since 2.1: +6 -4 lines
Diff to previous 2.1
perf: added datavector() call for quicker spectral interpolation
Mon Aug 21 22:39:05 2023 UTC (20 months, 2 weeks ago) by greg
Renamed ratrace to rxtrace
