| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rxtrace.cpp,v 2.5 2024/05/02 22:10:43 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* C++ module for individual ray tracing.
| 6 |
| 7 |
| 8 |
| 9 |
* Input is in the form:
| 10 |
| 11 |
* xorg yorg zorg xdir ydir zdir
| 12 |
| 13 |
* The direction need not be normalized. Output is flexible.
| 14 |
* If the direction vector is (0,0,0), then the output is flushed.
| 15 |
* All values default to ascii representation of real
| 16 |
* numbers. Binary representations can be selected
| 17 |
* with '-ff' for float or '-fd' for double. By default,
| 18 |
* radiance is computed. The '-i' or '-I' options indicate that
| 19 |
* irradiance values are desired.
| 20 |
| 21 |
| 22 |
#include "copyright.h"
| 23 |
| 24 |
#include "RtraceSimulManager.h"
| 25 |
#include "platform.h"
| 26 |
#include "otypes.h"
| 27 |
#include "otspecial.h"
| 28 |
#include "source.h"
| 29 |
#include "resolu.h"
| 30 |
| 31 |
extern int inform; /* input format */
| 32 |
extern int outform; /* output format */
| 33 |
| 34 |
extern char *tralist[]; /* list of modifers to trace (or no) */
| 35 |
extern int traincl; /* include == 1, exclude == 0 */
| 36 |
| 37 |
extern int hresolu; /* horizontal resolution */
| 38 |
extern int vresolu; /* vertical resolution */
| 39 |
| 40 |
extern int castonly; /* only doing ray-casting? */
| 41 |
| 42 |
extern double (*sens_curve)(SCOLOR scol); /* spectral conversion for 1-channel */
| 43 |
extern double out_scalefactor; /* output calibration scale factor */
| 44 |
extern RGBPRIMP out_prims; /* output color primitives (NULL if spectral) */
| 45 |
| 46 |
#ifndef MAXTSET
| 47 |
#define MAXTSET 8191 /* maximum number in trace set */
| 48 |
#endif
| 49 |
OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
| 50 |
| 51 |
// global simulation manager
| 52 |
extern RtraceSimulManager myRTmanager;
| 53 |
| 54 |
static FILE *inpfp = NULL; /* input stream pointer */
| 55 |
| 56 |
static FVECT *inp_queue = NULL; /* ray input queue if flushing */
| 57 |
static int inp_qpos = 0; /* next ray to return */
| 58 |
static int inp_qend = 0; /* number of rays in this work group */
| 59 |
| 60 |
typedef void putf_t(RREAL *v, int n);
| 61 |
static putf_t puta, putd, putf, putrgbe;
| 62 |
| 63 |
typedef void oputf_t(RAY *r);
| 64 |
static oputf_t oputo, oputd, oputv, oputV, oputl, oputL, oputc, oputp,
| 65 |
oputr, oputR, oputx, oputX, oputn, oputN, oputs,
| 66 |
oputw, oputW, oputm, oputM, oputtilde;
| 67 |
| 68 |
extern void tranotify(OBJECT obj);
| 69 |
static void tabin(RAY *r);
| 70 |
static RayReportCall ourtrace;
| 71 |
| 72 |
RayReportCall printvals; /* print selected ray values */
| 73 |
| 74 |
void putscolor(COLORV *scol); /* convert/print spectral color */
| 75 |
| 76 |
static oputf_t *ray_out[32], *every_out[32];
| 77 |
| 78 |
putf_t *putreal; /* put out real vector */
| 79 |
| 80 |
void
| 81 |
quit( /* quit program */
| 82 |
int code
| 83 |
| 84 |
| 85 |
if (ray_pnprocs < 0)
| 86 |
_exit(code); /* avoid flush in child */
| 87 |
| 88 |
int ec = myRTmanager.Cleanup();
| 89 |
| 90 |
if (ec) code = ec;
| 91 |
| 92 |
exit(code);
| 93 |
| 94 |
| 95 |
const char *
| 96 |
formstr( /* return format identifier */
| 97 |
int f
| 98 |
| 99 |
| 100 |
switch (f) {
| 101 |
case 'a': return("ascii");
| 102 |
case 'f': return("float");
| 103 |
case 'd': return("double");
| 104 |
case 'c':
| 105 |
if (out_prims == NULL)
| 106 |
return(SPECFMT);
| 107 |
if (out_prims == xyzprims)
| 108 |
return(CIEFMT);
| 109 |
return(COLRFMT);
| 110 |
| 111 |
return("unknown");
| 112 |
| 113 |
| 114 |
static bool
| 115 |
getvec( /* get a vector from fp */
| 116 |
FVECT vec,
| 117 |
int fmt,
| 118 |
FILE *fp
| 119 |
| 120 |
| 121 |
static char buf[32];
| 122 |
float * vf = (float *)buf;
| 123 |
double * vd = (double *)buf;
| 124 |
int i;
| 125 |
| 126 |
switch (fmt) {
| 127 |
case 'a': /* ascii */
| 128 |
for (i = 0; i < 3; i++) {
| 129 |
if (fgetword(buf, sizeof(buf), fp) == NULL ||
| 130 |
!isflt(buf))
| 131 |
return false;
| 132 |
vec[i] = atof(buf);
| 133 |
| 134 |
break;
| 135 |
#ifdef SMLFLT
| 136 |
case 'f': /* binary float */
| 137 |
if (getbinary(vec, sizeof(RREAL), 3, fp) != 3)
| 138 |
return false;
| 139 |
break;
| 140 |
case 'd': /* binary double */
| 141 |
if (getbinary(vd, sizeof(double), 3, fp) != 3)
| 142 |
return false;
| 143 |
VCOPY(vec, vd);
| 144 |
break;
| 145 |
#else
| 146 |
| 147 |
if (getbinary(vf, sizeof(float), 3, fp) != 3)
| 148 |
return false;
| 149 |
VCOPY(vec, vf);
| 150 |
break;
| 151 |
| 152 |
| 153 |
return false;
| 154 |
break;
| 155 |
#endif
| 156 |
default:
| 157 |
error(CONSISTENCY, "botched input format");
| 158 |
| 159 |
return true;
| 160 |
| 161 |
| 162 |
// read ray list from inpfp
| 163 |
static int
| 164 |
getrays(FVECT org_dir[], int n)
| 165 |
| 166 |
int nread = 0;
| 167 |
| 168 |
while (n-- > 0) {
| 169 |
if (!getvec(org_dir[0], inform, inpfp) ||
| 170 |
!getvec(org_dir[1], inform, inpfp))
| 171 |
break;
| 172 |
++nread;
| 173 |
if (IsZeroVec(org_dir[1]))
| 174 |
break;
| 175 |
org_dir += 2;
| 176 |
| 177 |
return nread;
| 178 |
| 179 |
| 180 |
void
| 181 |
rtrace( /* trace rays from stdin or file */
| 182 |
char *fname,
| 183 |
int nproc
| 184 |
| 185 |
| 186 |
RNUMBER vcount = (hresolu > 1) ? (RNUMBER)hresolu*vresolu
| 187 |
: (RNUMBER)vresolu;
| 188 |
const int flushIntvl = (!vresolu | (hresolu <= 1)) * hresolu;
| 189 |
FVECT * ivbuf = (FVECT *)malloc(2*sizeof(FVECT) *
| 190 |
(flushIntvl + !flushIntvl));
| 191 |
if (ivbuf == NULL)
| 192 |
error(SYSTEM, "cannot allocate input vector buffer");
| 193 |
/* set up input */
| 194 |
if (fname == NULL)
| 195 |
inpfp = stdin;
| 196 |
else if ((inpfp = fopen(fname, "r")) == NULL) {
| 197 |
sprintf(errmsg, "cannot open input file \"%s\"", fname);
| 198 |
error(SYSTEM, errmsg);
| 199 |
| 200 |
if (inform != 'a')
| 201 |
SET_FILE_BINARY(inpfp);
| 202 |
/* set up output */
| 203 |
if (castonly || every_out[0] != NULL) {
| 204 |
nproc = 1; /* don't bother multiprocessing */
| 205 |
} else if (nproc <= 0) { // need to get default for system?
| 206 |
nproc = myRTmanager.GetNCores() + nproc;
| 207 |
if (nproc <= 0) nproc = 1;
| 208 |
| 209 |
if ((flushIntvl > 0) & (nproc > flushIntvl)) {
| 210 |
error(WARNING, "reducing number of processes to match flush interval");
| 211 |
nproc = flushIntvl;
| 212 |
| 213 |
nproc = myRTmanager.SetThreadCount(nproc);
| 214 |
if (ray_out[0])
| 215 |
myRTmanager.SetCookedCall(printvals);
| 216 |
if (every_out[0])
| 217 |
myRTmanager.SetTraceCall(ourtrace);
| 218 |
myRTmanager.rtFlags |= RTdoFIFO;
| 219 |
#ifdef getc_unlocked
| 220 |
flockfile(inpfp); /* avoid lock/unlock overhead */
| 221 |
flockfile(stdout);
| 222 |
#endif
| 223 |
if (hresolu > 0) { // print resolution string if appropriate
| 224 |
if (vresolu > 0)
| 225 |
fprtresolu(hresolu, vresolu, stdout);
| 226 |
else
| 227 |
fflush(stdout);
| 228 |
| 229 |
int n; /* process input rays */
| 230 |
bool pending = false;
| 231 |
while ((n = getrays(ivbuf, flushIntvl + !flushIntvl)) > 0) {
| 232 |
if ((vcount > 0) & (n > vcount)) {
| 233 |
error(WARNING, "extra ray(s) past end of input");
| 234 |
n = vcount;
| 235 |
} // put ray(s) into queue
| 236 |
if (myRTmanager.EnqueueBundle(ivbuf, n) < n)
| 237 |
error(USER, "ray queuing failure");
| 238 |
pending |= (n > 1); // time to flush output?
| 239 |
bool atZero = IsZeroVec(ivbuf[2*n-1]);
| 240 |
if (pending & (atZero | (n == flushIntvl))) {
| 241 |
if (myRTmanager.FlushQueue() <= 0)
| 242 |
error(USER, "ray flush error");
| 243 |
fflush(stdout);
| 244 |
pending = false;
| 245 |
} else
| 246 |
pending |= !atZero;
| 247 |
if (ferror(stdout))
| 248 |
error(SYSTEM, "write error");
| 249 |
if (vcount && !(vcount -= n)) /* check for end */
| 250 |
break;
| 251 |
| 252 |
if (vcount)
| 253 |
error(WARNING, feof(inpfp) ? "unexpected EOF on input" :
| 254 |
"input read error");
| 255 |
if (myRTmanager.FlushQueue() < 0 || fflush(stdout) < 0)
| 256 |
error(SYSTEM, "final flush error");
| 257 |
if (fname != NULL) {
| 258 |
fclose(inpfp);
| 259 |
inpfp = NULL;
| 260 |
| 261 |
free(ivbuf);
| 262 |
| 263 |
| 264 |
int
| 265 |
setrtoutput(const char *outvals) /* set up output tables, return #comp */
| 266 |
| 267 |
const char *vs = outvals;
| 268 |
oputf_t **table = ray_out;
| 269 |
const int nco = (sens_curve != NULL) ? 1 :
| 270 |
(out_prims != NULL) ? 3 : NCSAMP;
| 271 |
int ncomp = 0;
| 272 |
| 273 |
if (!*vs)
| 274 |
error(USER, "empty output specification");
| 275 |
| 276 |
switch (outform) { /* make sure (*putreal)() calls someone! */
| 277 |
case 'a': putreal = puta; break;
| 278 |
case 'f': putreal = putf; break;
| 279 |
case 'd': putreal = putd; break;
| 280 |
case 'c':
| 281 |
if (outvals[1] || !strchr("vrx", outvals[0]))
| 282 |
error(USER, "color format only with -ov, -or, -ox");
| 283 |
putreal = putrgbe; break;
| 284 |
default:
| 285 |
error(CONSISTENCY, "botched output format");
| 286 |
| 287 |
castonly = 1; /* sets castonly as side-effect */
| 288 |
do
| 289 |
switch (*vs) {
| 290 |
case 'T': /* trace sources */
| 291 |
myRTmanager.rtFlags |= RTtraceSources;
| 292 |
/* fall through */
| 293 |
case 't': /* trace */
| 294 |
if (!vs[1]) break;
| 295 |
*table = NULL;
| 296 |
table = every_out;
| 297 |
castonly = 0;
| 298 |
break;
| 299 |
case 'o': /* origin */
| 300 |
*table++ = oputo;
| 301 |
ncomp += 3;
| 302 |
break;
| 303 |
case 'd': /* direction */
| 304 |
*table++ = oputd;
| 305 |
ncomp += 3;
| 306 |
break;
| 307 |
case 'r': /* reflected contrib. */
| 308 |
*table++ = oputr;
| 309 |
ncomp += nco;
| 310 |
castonly = 0;
| 311 |
break;
| 312 |
case 'R': /* reflected distance */
| 313 |
*table++ = oputR;
| 314 |
ncomp++;
| 315 |
castonly = 0;
| 316 |
break;
| 317 |
case 'x': /* xmit contrib. */
| 318 |
*table++ = oputx;
| 319 |
ncomp += nco;
| 320 |
castonly = 0;
| 321 |
break;
| 322 |
case 'X': /* xmit distance */
| 323 |
*table++ = oputX;
| 324 |
ncomp++;
| 325 |
castonly = 0;
| 326 |
break;
| 327 |
case 'v': /* value */
| 328 |
*table++ = oputv;
| 329 |
ncomp += nco;
| 330 |
castonly = 0;
| 331 |
break;
| 332 |
case 'V': /* contribution */
| 333 |
*table++ = oputV;
| 334 |
ncomp += nco;
| 335 |
castonly = 0;
| 336 |
if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
| 337 |
error(WARNING,
| 338 |
"-otV accuracy depends on -aa 0 -as 0");
| 339 |
break;
| 340 |
case 'l': /* effective distance */
| 341 |
*table++ = oputl;
| 342 |
ncomp++;
| 343 |
castonly = 0;
| 344 |
break;
| 345 |
case 'c': /* local coordinates */
| 346 |
*table++ = oputc;
| 347 |
ncomp += 2;
| 348 |
break;
| 349 |
case 'L': /* single ray length */
| 350 |
*table++ = oputL;
| 351 |
ncomp++;
| 352 |
break;
| 353 |
case 'p': /* point */
| 354 |
*table++ = oputp;
| 355 |
ncomp += 3;
| 356 |
break;
| 357 |
case 'n': /* perturbed normal */
| 358 |
*table++ = oputn;
| 359 |
ncomp += 3;
| 360 |
castonly = 0;
| 361 |
break;
| 362 |
case 'N': /* unperturbed normal */
| 363 |
*table++ = oputN;
| 364 |
ncomp += 3;
| 365 |
break;
| 366 |
case 's': /* surface */
| 367 |
*table++ = oputs;
| 368 |
ncomp++;
| 369 |
break;
| 370 |
case 'w': /* weight */
| 371 |
*table++ = oputw;
| 372 |
ncomp++;
| 373 |
break;
| 374 |
case 'W': /* coefficient */
| 375 |
*table++ = oputW;
| 376 |
ncomp += nco;
| 377 |
castonly = 0;
| 378 |
if (ambounce > 0 && (ambacc > FTINY) | (ambssamp > 0))
| 379 |
error(WARNING,
| 380 |
"-otW accuracy depends on -aa 0 -as 0");
| 381 |
break;
| 382 |
case 'm': /* modifier */
| 383 |
*table++ = oputm;
| 384 |
ncomp++;
| 385 |
break;
| 386 |
case 'M': /* material */
| 387 |
*table++ = oputM;
| 388 |
ncomp++;
| 389 |
break;
| 390 |
case '~': /* tilde */
| 391 |
*table++ = oputtilde;
| 392 |
break;
| 393 |
default:
| 394 |
sprintf(errmsg, "unrecognized output option '%c'", *vs);
| 395 |
error(USER, errmsg);
| 396 |
| 397 |
while (*++vs);
| 398 |
| 399 |
*table = NULL;
| 400 |
if (*every_out != NULL)
| 401 |
ncomp = 0;
| 402 |
/* compatibility */
| 403 |
if ((do_irrad | (myRTmanager.rtFlags & RTimmIrrad)) && castonly)
| 404 |
error(USER, "-I+ and -i+ options require some value output");
| 405 |
for (table = ray_out; *table != NULL; table++) {
| 406 |
if ((*table == oputV) | (*table == oputW))
| 407 |
error(WARNING, "-oVW options require trace mode");
| 408 |
| 409 |
(*table == oputr) | (*table == oputR) |
| 410 |
(*table == oputx) | (*table == oputX))
| 411 |
error(WARNING, "-orRxX options incompatible with -I+ and -i+");
| 412 |
| 413 |
return(ncomp);
| 414 |
| 415 |
| 416 |
static int
| 417 |
printvals( /* print requested ray values */
| 418 |
RAY *r, void *cd
| 419 |
| 420 |
| 421 |
oputf_t **tp;
| 422 |
| 423 |
if (ray_out[0] == NULL)
| 424 |
return 0;
| 425 |
for (tp = ray_out; *tp != NULL; tp++)
| 426 |
(**tp)(r);
| 427 |
if (outform == 'a')
| 428 |
putchar('\n');
| 429 |
return 1;
| 430 |
| 431 |
| 432 |
void
| 433 |
tranotify( /* record new modifier */
| 434 |
OBJECT obj
| 435 |
| 436 |
| 437 |
static int hitlimit = 0;
| 438 |
OBJREC *o = objptr(obj);
| 439 |
char **tralp;
| 440 |
| 441 |
if (obj == OVOID) { /* starting over */
| 442 |
traset[0] = 0;
| 443 |
hitlimit = 0;
| 444 |
return;
| 445 |
| 446 |
if (hitlimit || !ismodifier(o->otype))
| 447 |
return;
| 448 |
for (tralp = tralist; *tralp != NULL; tralp++)
| 449 |
if (!strcmp(o->oname, *tralp)) {
| 450 |
if (traset[0] >= MAXTSET) {
| 451 |
error(WARNING, "too many modifiers in trace list");
| 452 |
hitlimit++;
| 453 |
return; /* should this be fatal? */
| 454 |
| 455 |
insertelem(traset, obj);
| 456 |
return;
| 457 |
| 458 |
| 459 |
| 460 |
static int
| 461 |
ourtrace( /* print ray values */
| 462 |
RAY *r, void *cd
| 463 |
| 464 |
| 465 |
oputf_t **tp;
| 466 |
| 467 |
if (every_out[0] == NULL)
| 468 |
return 0;
| 469 |
if (r->ro == NULL) {
| 470 |
if (traincl == 1)
| 471 |
return 0;
| 472 |
} else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
| 473 |
return 0;
| 474 |
tabin(r);
| 475 |
for (tp = every_out; *tp != NULL; tp++)
| 476 |
(**tp)(r);
| 477 |
if (outform == 'a')
| 478 |
putchar('\n');
| 479 |
return 1;
| 480 |
| 481 |
| 482 |
static void
| 483 |
tabin( /* tab in appropriate amount */
| 484 |
RAY *r
| 485 |
| 486 |
| 487 |
const RAY *rp;
| 488 |
| 489 |
for (rp = r->parent; rp != NULL; rp = rp->parent)
| 490 |
putchar('\t');
| 491 |
| 492 |
| 493 |
static void
| 494 |
oputo( /* print origin */
| 495 |
RAY *r
| 496 |
| 497 |
| 498 |
(*putreal)(r->rorg, 3);
| 499 |
| 500 |
| 501 |
static void
| 502 |
oputd( /* print direction */
| 503 |
RAY *r
| 504 |
| 505 |
| 506 |
(*putreal)(r->rdir, 3);
| 507 |
| 508 |
| 509 |
static void
| 510 |
oputr( /* print mirrored contribution */
| 511 |
RAY *r
| 512 |
| 513 |
| 514 |
putscolor(r->mcol);
| 515 |
| 516 |
| 517 |
static void
| 518 |
oputR( /* print mirrored distance */
| 519 |
RAY *r
| 520 |
| 521 |
| 522 |
(*putreal)(&r->rmt, 1);
| 523 |
| 524 |
| 525 |
static void
| 526 |
oputx( /* print unmirrored contribution */
| 527 |
RAY *r
| 528 |
| 529 |
| 530 |
SCOLOR cdiff;
| 531 |
| 532 |
copyscolor(cdiff, r->rcol);
| 533 |
sopscolor(cdiff, -=, r->mcol);
| 534 |
| 535 |
putscolor(cdiff);
| 536 |
| 537 |
| 538 |
static void
| 539 |
oputX( /* print unmirrored distance */
| 540 |
RAY *r
| 541 |
| 542 |
| 543 |
(*putreal)(&r->rxt, 1);
| 544 |
| 545 |
| 546 |
static void
| 547 |
oputv( /* print value */
| 548 |
RAY *r
| 549 |
| 550 |
| 551 |
putscolor(r->rcol);
| 552 |
| 553 |
| 554 |
static void
| 555 |
oputV( /* print value contribution */
| 556 |
RAY *r
| 557 |
| 558 |
| 559 |
SCOLOR contr;
| 560 |
| 561 |
raycontrib(contr, r, PRIMARY);
| 562 |
smultscolor(contr, r->rcol);
| 563 |
putscolor(contr);
| 564 |
| 565 |
| 566 |
static void
| 567 |
oputl( /* print effective distance */
| 568 |
RAY *r
| 569 |
| 570 |
| 571 |
RREAL d = raydistance(r);
| 572 |
| 573 |
(*putreal)(&d, 1);
| 574 |
| 575 |
| 576 |
static void
| 577 |
oputL( /* print single ray length */
| 578 |
RAY *r
| 579 |
| 580 |
| 581 |
(*putreal)(&r->rot, 1);
| 582 |
| 583 |
| 584 |
static void
| 585 |
oputc( /* print local coordinates */
| 586 |
RAY *r
| 587 |
| 588 |
| 589 |
(*putreal)(r->uv, 2);
| 590 |
| 591 |
| 592 |
static RREAL vdummy[3] = {0.0, 0.0, 0.0};
| 593 |
| 594 |
static void
| 595 |
oputp( /* print intersection point */
| 596 |
RAY *r
| 597 |
| 598 |
| 599 |
(*putreal)(r->rop, 3); /* set to ray origin if distant or no hit */
| 600 |
| 601 |
| 602 |
static void
| 603 |
oputN( /* print unperturbed normal */
| 604 |
RAY *r
| 605 |
| 606 |
| 607 |
if (r->ro == NULL) { /* zero vector if clipped or no hit */
| 608 |
(*putreal)(vdummy, 3);
| 609 |
return;
| 610 |
| 611 |
if (r->rflips & 1) { /* undo any flippin' flips */
| 612 |
FVECT unrm;
| 613 |
unrm[0] = -r->ron[0];
| 614 |
unrm[1] = -r->ron[1];
| 615 |
unrm[2] = -r->ron[2];
| 616 |
(*putreal)(unrm, 3);
| 617 |
} else
| 618 |
(*putreal)(r->ron, 3);
| 619 |
| 620 |
| 621 |
static void
| 622 |
oputn( /* print perturbed normal */
| 623 |
RAY *r
| 624 |
| 625 |
| 626 |
FVECT pnorm;
| 627 |
| 628 |
if (r->ro == NULL) { /* clipped or no hit */
| 629 |
| 630 |
return;
| 631 |
| 632 |
raynormal(pnorm, r);
| 633 |
(*putreal)(pnorm, 3);
| 634 |
| 635 |
| 636 |
static void
| 637 |
oputs( /* print name */
| 638 |
RAY *r
| 639 |
| 640 |
| 641 |
if (r->ro != NULL)
| 642 |
fputs(r->ro->oname, stdout);
| 643 |
else
| 644 |
putchar('*');
| 645 |
putchar('\t');
| 646 |
| 647 |
| 648 |
static void
| 649 |
oputw( /* print weight */
| 650 |
RAY *r
| 651 |
| 652 |
| 653 |
RREAL rwt = r->rweight;
| 654 |
| 655 |
(*putreal)(&rwt, 1);
| 656 |
| 657 |
| 658 |
static void
| 659 |
oputW( /* print coefficient */
| 660 |
RAY *r
| 661 |
| 662 |
| 663 |
SCOLOR contr;
| 664 |
/* shadow ray not on source? */
| 665 |
if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
| 666 |
scolorblack(contr);
| 667 |
else
| 668 |
| 669 |
| 670 |
putscolor(contr);
| 671 |
| 672 |
| 673 |
static void
| 674 |
oputm( /* print modifier */
| 675 |
RAY *r
| 676 |
| 677 |
| 678 |
if (r->ro != NULL)
| 679 |
if (r->ro->omod != OVOID)
| 680 |
fputs(objptr(r->ro->omod)->oname, stdout);
| 681 |
else
| 682 |
fputs(VOIDID, stdout);
| 683 |
else
| 684 |
putchar('*');
| 685 |
putchar('\t');
| 686 |
| 687 |
| 688 |
static void
| 689 |
oputM( /* print material */
| 690 |
RAY *r
| 691 |
| 692 |
| 693 |
OBJREC *mat;
| 694 |
| 695 |
if (r->ro != NULL) {
| 696 |
if ((mat = findmaterial(r->ro)) != NULL)
| 697 |
fputs(mat->oname, stdout);
| 698 |
else
| 699 |
| 700 |
} else
| 701 |
putchar('*');
| 702 |
putchar('\t');
| 703 |
| 704 |
| 705 |
static void
| 706 |
oputtilde( /* output tilde (spacer) */
| 707 |
RAY *r
| 708 |
| 709 |
| 710 |
fputs("~\t", stdout);
| 711 |
| 712 |
| 713 |
static void
| 714 |
puta( /* print ascii value(s) */
| 715 |
RREAL *v, int n
| 716 |
| 717 |
| 718 |
if (n == 3) {
| 719 |
printf("%e\t%e\t%e\t", v[0], v[1], v[2]);
| 720 |
return;
| 721 |
| 722 |
while (n--)
| 723 |
printf("%e\t", *v++);
| 724 |
| 725 |
| 726 |
static void
| 727 |
putd(RREAL *v, int n) /* output binary double(s) */
| 728 |
| 729 |
#ifdef SMLFLT
| 730 |
double da[3];
| 731 |
int i;
| 732 |
| 733 |
if (n > 3)
| 734 |
error(INTERNAL, "code error in putd()");
| 735 |
for (i = n; i--; )
| 736 |
da[i] = v[i];
| 737 |
putbinary(da, sizeof(double), n, stdout);
| 738 |
#else
| 739 |
putbinary(v, sizeof(RREAL), n, stdout);
| 740 |
#endif
| 741 |
| 742 |
| 743 |
static void
| 744 |
putf(RREAL *v, int n) /* output binary float(s) */
| 745 |
| 746 |
#ifndef SMLFLT
| 747 |
float fa[3];
| 748 |
int i;
| 749 |
| 750 |
if (n > 3)
| 751 |
error(INTERNAL, "code error in putf()");
| 752 |
for (i = n; i--; )
| 753 |
fa[i] = v[i];
| 754 |
putbinary(fa, sizeof(float), n, stdout);
| 755 |
#else
| 756 |
| 757 |
#endif
| 758 |
| 759 |
| 760 |
static void
| 761 |
putrgbe(RREAL *v, int n) /* output RGBE color */
| 762 |
| 763 |
COLR cout;
| 764 |
| 765 |
if (n != 3)
| 766 |
error(INTERNAL, "putrgbe() not called with 3 components");
| 767 |
setcolr(cout, v[0], v[1], v[2]);
| 768 |
putbinary(cout, sizeof(cout), 1, stdout);
| 769 |
| 770 |
| 771 |
static void
| 772 |
putscolor(COLORV *scol) /* output (spectral) color */
| 773 |
| 774 |
static COLORMAT xyz2myrgbmat;
| 775 |
SCOLOR my_scol;
| 776 |
COLOR col;
| 777 |
/* single channel output? */
| 778 |
if (sens_curve != NULL) {
| 779 |
RREAL v = (*sens_curve)(scol) * out_scalefactor;
| 780 |
(*putreal)(&v, 1);
| 781 |
return;
| 782 |
| 783 |
if (out_scalefactor != 1.) { /* apply scalefactor if any */
| 784 |
copyscolor(my_scol, scol);
| 785 |
scalescolor(my_scol, out_scalefactor);
| 786 |
scol = my_scol;
| 787 |
| 788 |
if (out_prims == NULL) { /* full spectral reporting */
| 789 |
if (outform == 'c') {
| 790 |
SCOLR sclr;
| 791 |
scolor_scolr(sclr, scol);
| 792 |
putbinary(sclr, LSCOLR, 1, stdout);
| 793 |
} else if (sizeof(RREAL) != sizeof(COLORV)) {
| 794 |
RREAL sreal[MAXCSAMP];
| 795 |
int i = NCSAMP;
| 796 |
while (i--) sreal[i] = scol[i];
| 797 |
(*putreal)(sreal, NCSAMP);
| 798 |
} else
| 799 |
(*putreal)((RREAL *)scol, NCSAMP);
| 800 |
return;
| 801 |
| 802 |
if (out_prims == xyzprims) {
| 803 |
scolor_cie(col, scol);
| 804 |
} else if (out_prims == stdprims) {
| 805 |
scolor_rgb(col, scol);
| 806 |
} else {
| 807 |
COLOR xyz;
| 808 |
if (xyz2myrgbmat[0][0] == 0)
| 809 |
compxyz2rgbWBmat(xyz2myrgbmat, out_prims);
| 810 |
scolor_cie(xyz, scol);
| 811 |
colortrans(col, xyz2myrgbmat, xyz);
| 812 |
clipgamut(col, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite);
| 813 |
| 814 |
| 815 |
COLR clr;
| 816 |
setcolr(clr, colval(col,RED), colval(col,GRN), colval(col,BLU));
| 817 |
putbinary(clr, sizeof(COLR), 1, stdout);
| 818 |
| 819 |
RREAL creal[3];
| 820 |
copycolor(creal, col);
| 821 |
(*putreal)(creal, 3);
| 822 |
} else
| 823 |
(*putreal)((RREAL *)col, 3);
| 824 |
