| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rxtmain.cpp,v 2.10 2024/10/31 19:02:38 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rxtmain.cpp - main for per-ray calculation program
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <signal.h>
| 11 |
| 12 |
#include "rtprocess.h" /* getpid() */
| 13 |
#include "platform.h"
| 14 |
#include "RtraceSimulManager.h"
| 15 |
| 16 |
extern char *progname; /* global argv[0] */
| 17 |
| 18 |
static const char *sigerr[NSIG]; /* signal error messages */
| 19 |
char *errfile = NULL; /* error output file */
| 20 |
| 21 |
extern const char *formstr(int f); /* string from format */
| 22 |
extern int setrtoutput(const char *outvals); /* set output values */
| 23 |
| 24 |
int inform = 'a'; /* input format */
| 25 |
int outform = 'a'; /* output format */
| 26 |
| 27 |
int hresolu = 0; /* horizontal (scan) size */
| 28 |
int vresolu = 0; /* vertical resolution */
| 29 |
| 30 |
RtraceSimulManager myRTmanager; // global simulation manager
| 31 |
| 32 |
static const char *outvals = "v"; /* output specification */
| 33 |
static int nproc = 1; /* number of requested threads */
| 34 |
static int doheader = 1; /* include information header? */
| 35 |
| 36 |
#ifndef MAXMODLIST
| 37 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */
| 38 |
#endif
| 39 |
| 40 |
extern void (*addobjnotify[])(OBJECT); /* object notification calls */
| 41 |
extern void tranotify(OBJECT obj);
| 42 |
| 43 |
char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
| 44 |
int traincl = -1; /* include == 1, exclude == 0 */
| 45 |
| 46 |
double (*sens_curve)(const SCOLOR scol) = NULL; /* spectral conversion for 1-channel */
| 47 |
double out_scalefactor = 1; /* output calibration scale factor */
| 48 |
RGBPRIMP out_prims = stdprims; /* output color primitives (NULL if spectral) */
| 49 |
static RGBPRIMS our_prims; /* private output color primitives */
| 50 |
| 51 |
static void onsig(int signo);
| 52 |
static void sigdie(int signo, const char *msg);
| 53 |
static void printdefaults(void);
| 54 |
| 55 |
#define RXTRACE_FEATURES "IrradianceCalc\nMultiprocessing\nDistanceLimiting\n" \
| 56 |
"HessianAmbientCache\nAmbientAveraging\n" \
| 57 |
"AmbientValueSharing\nAdaptiveShadowTesting\n" \
| 58 |
"Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \
| 59 |
"OutputCS=RGB,XYZ,Y,S,M,prims,spec\n"
| 60 |
| 61 |
int
| 62 |
main(int argc, char *argv[])
| 63 |
| 64 |
#define check(ol,al) if (argv[i][ol] || \
| 65 |
badarg(argc-i-1,argv+i+1,al)) \
| 66 |
goto badopt
| 67 |
#define check_bool(olen,var) switch (argv[i][olen]) { \
| 68 |
case '\0': var = !var; break; \
| 69 |
case 'y': case 'Y': case 't': case 'T': \
| 70 |
case '+': case '1': var = 1; break; \
| 71 |
case 'n': case 'N': case 'f': case 'F': \
| 72 |
case '-': case '0': var = 0; break; \
| 73 |
default: goto badopt; }
| 74 |
char **tralp = NULL;
| 75 |
int rval;
| 76 |
int i;
| 77 |
/* global program name */
| 78 |
progname = argv[0];
| 79 |
/* feature check only? */
| 80 |
strcat(RFeatureList, RXTRACE_FEATURES);
| 81 |
if (argc > 1 && !strcmp(argv[1], "-features"))
| 82 |
return feature_status(argc-2, argv+2);
| 83 |
/* add trace notify function */
| 84 |
for (i = 0; addobjnotify[i] != NULL; i++)
| 85 |
| 86 |
addobjnotify[i] = tranotify;
| 87 |
/* option city */
| 88 |
for (i = 1; i < argc; i++) {
| 89 |
/* expand arguments */
| 90 |
while ((rval = expandarg(&argc, &argv, i)) > 0)
| 91 |
| 92 |
if (rval < 0) {
| 93 |
sprintf(errmsg, "cannot expand '%s'", argv[i]);
| 94 |
error(SYSTEM, errmsg);
| 95 |
| 96 |
if (argv[i] == NULL || argv[i][0] != '-')
| 97 |
break; /* break from options */
| 98 |
if (!strcmp(argv[i], "-version")) {
| 99 |
puts(VersionID);
| 100 |
quit(0);
| 101 |
| 102 |
if (!strcmp(argv[i], "-defaults") ||
| 103 |
!strcmp(argv[i], "-help")) {
| 104 |
printdefaults();
| 105 |
quit(0);
| 106 |
| 107 |
rval = getrenderopt(argc-i, argv+i);
| 108 |
if (rval >= 0) {
| 109 |
i += rval;
| 110 |
continue;
| 111 |
| 112 |
switch (argv[i][1]) {
| 113 |
case 'n': /* number of cores */
| 114 |
check(2,"i");
| 115 |
nproc = atoi(argv[++i]);
| 116 |
break;
| 117 |
case 'x': /* x resolution */
| 118 |
check(2,"i");
| 119 |
hresolu = atoi(argv[++i]);
| 120 |
break;
| 121 |
case 'y': /* y resolution */
| 122 |
check(2,"i");
| 123 |
vresolu = atoi(argv[++i]);
| 124 |
break;
| 125 |
case 'w': /* warnings */
| 126 |
rval = erract[WARNING].pf != NULL;
| 127 |
check_bool(2,rval);
| 128 |
if (rval) erract[WARNING].pf = wputs;
| 129 |
else erract[WARNING].pf = NULL;
| 130 |
break;
| 131 |
case 'e': /* error file */
| 132 |
check(2,"s");
| 133 |
errfile = argv[++i];
| 134 |
break;
| 135 |
case 'l': /* limit distance */
| 136 |
if (argv[i][2] != 'd')
| 137 |
goto badopt;
| 138 |
rval = myRTmanager.rtFlags & RTlimDist;
| 139 |
check_bool(3,rval);
| 140 |
if (rval) myRTmanager.rtFlags |= RTlimDist;
| 141 |
else myRTmanager.rtFlags &= ~RTlimDist;
| 142 |
break;
| 143 |
case 'I': /* immed. irradiance */
| 144 |
rval = myRTmanager.rtFlags & RTimmIrrad;
| 145 |
check_bool(2,rval);
| 146 |
if (rval) myRTmanager.rtFlags |= RTimmIrrad;
| 147 |
else myRTmanager.rtFlags &= ~RTimmIrrad;
| 148 |
break;
| 149 |
case 'f': /* format i/o */
| 150 |
switch (argv[i][2]) {
| 151 |
case 'a': /* ascii */
| 152 |
case 'f': /* float */
| 153 |
case 'd': /* double */
| 154 |
inform = argv[i][2];
| 155 |
break;
| 156 |
default:
| 157 |
goto badopt;
| 158 |
| 159 |
switch (argv[i][3]) {
| 160 |
case '\0':
| 161 |
outform = inform;
| 162 |
break;
| 163 |
| 164 |
| 165 |
| 166 |
case 'c': /* color */
| 167 |
check(4,"");
| 168 |
outform = argv[i][3];
| 169 |
break;
| 170 |
default:
| 171 |
goto badopt;
| 172 |
| 173 |
break;
| 174 |
case 'o': /* output */
| 175 |
outvals = argv[i]+2;
| 176 |
break;
| 177 |
case 'h': /* header output */
| 178 |
check_bool(2,doheader);
| 179 |
break;
| 180 |
case 't': /* trace */
| 181 |
| 182 |
case 'i': /* include */
| 183 |
case 'I':
| 184 |
check(3,"s");
| 185 |
if (traincl != 1) {
| 186 |
traincl = 1;
| 187 |
tralp = tralist;
| 188 |
| 189 |
if (argv[i][2] == 'I') { /* file */
| 190 |
rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
| 191 |
getpath(argv[++i],getrlibpath(),R_OK));
| 192 |
if (rval < 0) {
| 193 |
sprintf(errmsg,
| 194 |
"cannot open trace include file \"%s\"",
| 195 |
argv[i]);
| 196 |
| 197 |
| 198 |
tralp += rval;
| 199 |
} else {
| 200 |
*tralp++ = argv[++i];
| 201 |
*tralp = NULL;
| 202 |
| 203 |
break;
| 204 |
case 'e': /* exclude */
| 205 |
case 'E':
| 206 |
check(3,"s");
| 207 |
if (traincl != 0) {
| 208 |
traincl = 0;
| 209 |
tralp = tralist;
| 210 |
| 211 |
if (argv[i][2] == 'E') { /* file */
| 212 |
| 213 |
| 214 |
if (rval < 0) {
| 215 |
sprintf(errmsg,
| 216 |
"cannot open trace exclude file \"%s\"",
| 217 |
argv[i]);
| 218 |
| 219 |
| 220 |
tralp += rval;
| 221 |
} else {
| 222 |
| 223 |
*tralp = NULL;
| 224 |
| 225 |
break;
| 226 |
default:
| 227 |
goto badopt;
| 228 |
| 229 |
break;
| 230 |
case 'p': /* value output */
| 231 |
| 232 |
case 'R': /* standard RGB output */
| 233 |
if (strcmp(argv[i]+2, "RGB"))
| 234 |
goto badopt;
| 235 |
| 236 |
| 237 |
sens_curve = NULL;
| 238 |
break;
| 239 |
case 'X': /* XYZ output */
| 240 |
if (strcmp(argv[i]+2, "XYZ"))
| 241 |
goto badopt;
| 242 |
out_prims = xyzprims;
| 243 |
out_scalefactor = WHTEFFICACY;
| 244 |
sens_curve = NULL;
| 245 |
break;
| 246 |
case 'c': {
| 247 |
int j;
| 248 |
check(3,"ffffffff");
| 249 |
rval = 0;
| 250 |
for (j = 0; j < 8; j++) {
| 251 |
our_prims[0][j] = atof(argv[++i]);
| 252 |
rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
| 253 |
| 254 |
if (rval) {
| 255 |
if (!colorprimsOK(our_prims))
| 256 |
error(USER, "illegal primary chromaticities");
| 257 |
out_prims = our_prims;
| 258 |
} else
| 259 |
| 260 |
| 261 |
sens_curve = NULL;
| 262 |
} break;
| 263 |
case 'Y': /* photopic response */
| 264 |
if (argv[i][3])
| 265 |
goto badopt;
| 266 |
sens_curve = scolor_photopic;
| 267 |
| 268 |
break;
| 269 |
case 'S': /* scotopic response */
| 270 |
if (argv[i][3])
| 271 |
goto badopt;
| 272 |
sens_curve = scolor_scotopic;
| 273 |
out_scalefactor = WHTSCOTOPIC;
| 274 |
break;
| 275 |
case 'M': /* melanopic response */
| 276 |
if (argv[i][3])
| 277 |
goto badopt;
| 278 |
sens_curve = scolor_melanopic;
| 279 |
out_scalefactor = WHTMELANOPIC;
| 280 |
break;
| 281 |
default:
| 282 |
goto badopt;
| 283 |
| 284 |
break;
| 285 |
#if MAXCSAMP>3
| 286 |
case 'c': /* output spectral results */
| 287 |
if (argv[i][2] != 'o')
| 288 |
goto badopt;
| 289 |
rval = (out_prims == NULL) & (sens_curve == NULL);
| 290 |
check_bool(3,rval);
| 291 |
if (rval) {
| 292 |
out_prims = NULL;
| 293 |
sens_curve = NULL;
| 294 |
} else if (out_prims == NULL)
| 295 |
| 296 |
break;
| 297 |
#endif
| 298 |
default:
| 299 |
goto badopt;
| 300 |
| 301 |
| 302 |
/* set/check spectral sampling */
| 303 |
rval = setspectrsamp(CNDX, WLPART);
| 304 |
if (rval < 0)
| 305 |
error(USER, "unsupported spectral sampling");
| 306 |
if (out_prims != NULL) {
| 307 |
if (!rval)
| 308 |
error(WARNING, "spectral range incompatible with color output");
| 309 |
} else if (NCSAMP == 3)
| 310 |
out_prims = stdprims; /* 3 samples do not a spectrum make */
| 311 |
/* set up signal handling */
| 312 |
sigdie(SIGINT, "Interrupt");
| 313 |
#ifdef SIGHUP
| 314 |
sigdie(SIGHUP, "Hangup");
| 315 |
#endif
| 316 |
sigdie(SIGTERM, "Terminate");
| 317 |
#ifdef SIGPIPE
| 318 |
sigdie(SIGPIPE, "Broken pipe");
| 319 |
#endif
| 320 |
#ifdef SIGALRM
| 321 |
sigdie(SIGALRM, "Alarm clock");
| 322 |
#endif
| 323 |
#ifdef SIGXCPU
| 324 |
sigdie(SIGXCPU, "CPU limit exceeded");
| 325 |
sigdie(SIGXFSZ, "File size exceeded");
| 326 |
#endif
| 327 |
/* open error file */
| 328 |
if (errfile != NULL) {
| 329 |
if (freopen(errfile, "a", stderr) == NULL)
| 330 |
quit(2);
| 331 |
fprintf(stderr, "**************\n*** PID %5d: ",
| 332 |
getpid());
| 333 |
printargs(argc, argv, stderr);
| 334 |
putc('\n', stderr);
| 335 |
fflush(stderr);
| 336 |
| 337 |
#ifdef NICE
| 338 |
nice(NICE); /* lower priority */
| 339 |
#endif
| 340 |
/* get octree name */
| 341 |
if (i == argc)
| 342 |
error(USER, "missing octree argument");
| 343 |
if (i != argc-1)
| 344 |
goto badopt;
| 345 |
/* set output options */
| 346 |
rval = setrtoutput(outvals);
| 347 |
/* load octree */
| 348 |
if (!myRTmanager.LoadOctree(argv[i]))
| 349 |
quit(1);
| 350 |
/* set up output */
| 351 |
if (outform != 'a')
| 352 |
SET_FILE_BINARY(stdout);
| 353 |
if (doheader) { /* print header? */
| 354 |
newheader("RADIANCE", stdout);
| 355 |
fputs(myRTmanager.GetHeadStr(), stdout);
| 356 |
printargs(i, argv, stdout);
| 357 |
printf("SOFTWARE= %s\n", VersionID);
| 358 |
fputnow(stdout);
| 359 |
if (rval > 0) /* saved from setrtoutput() call */
| 360 |
printf("NCOMP=%d\n", rval);
| 361 |
if ((outform == 'f') | (outform == 'd'))
| 362 |
fputendian(stdout);
| 363 |
fputformat(formstr(outform), stdout);
| 364 |
fputc('\n', stdout); /* end of header */
| 365 |
| 366 |
rtrace(NULL, nproc); /* trace rays */
| 367 |
quit(0); /* clean up & exit */
| 368 |
| 369 |
badopt:
| 370 |
sprintf(errmsg, "command line error at '%s'", argv[i]);
| 371 |
error(USER, errmsg);
| 372 |
return 1; /* pro forma return */
| 373 |
| 374 |
#undef check
| 375 |
#undef check_bool
| 376 |
| 377 |
| 378 |
void
| 379 |
wputs( /* warning output function */
| 380 |
char *s
| 381 |
| 382 |
| 383 |
int lasterrno = errno;
| 384 |
eputs(s);
| 385 |
errno = lasterrno;
| 386 |
| 387 |
| 388 |
void
| 389 |
eputs( /* put string to stderr */
| 390 |
const char *s
| 391 |
| 392 |
| 393 |
static int midline = 0;
| 394 |
| 395 |
if (!*s)
| 396 |
return;
| 397 |
if (!midline++) {
| 398 |
fputs(progname, stderr);
| 399 |
fputs(": ", stderr);
| 400 |
| 401 |
fputs(s, stderr);
| 402 |
if (s[strlen(s)-1] == '\n') {
| 403 |
fflush(stderr);
| 404 |
midline = 0;
| 405 |
| 406 |
| 407 |
| 408 |
static void
| 409 |
onsig( /* fatal signal */
| 410 |
int signo
| 411 |
| 412 |
| 413 |
static int gotsig = 0;
| 414 |
| 415 |
if (gotsig++) /* two signals and we're gone! */
| 416 |
_exit(signo);
| 417 |
| 418 |
#ifdef SIGALRM
| 419 |
alarm(15); /* allow 15 seconds to clean up */
| 420 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */
| 421 |
#endif
| 422 |
eputs("signal - ");
| 423 |
eputs(sigerr[signo]);
| 424 |
eputs("\n");
| 425 |
quit(3);
| 426 |
| 427 |
| 428 |
static void
| 429 |
sigdie( /* set fatal signal */
| 430 |
int signo,
| 431 |
const char *msg
| 432 |
| 433 |
| 434 |
if (signal(signo, onsig) == SIG_IGN)
| 435 |
signal(signo, SIG_IGN);
| 436 |
sigerr[signo] = msg;
| 437 |
| 438 |
| 439 |
static void
| 440 |
printdefaults(void) /* print default values to stdout */
| 441 |
| 442 |
const char *cp;
| 443 |
| 444 |
if (myRTmanager.rtFlags & RTimmIrrad)
| 445 |
printf("-I+\t\t\t\t# immediate irradiance on\n");
| 446 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
| 447 |
printf("-x %-9d\t\t\t# %s\n", hresolu,
| 448 |
vresolu && hresolu ? "x resolution" : "flush interval");
| 449 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu);
| 450 |
printf(myRTmanager.rtFlags&RTlimDist ? "-ld+\t\t\t\t# limit distance on\n" :
| 451 |
"-ld-\t\t\t\t# limit distance off\n");
| 452 |
printf("-h%c\t\t\t\t# %s header\n", doheader ? '+' : '-',
| 453 |
doheader ? "output" : "no");
| 454 |
printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
| 455 |
inform, outform, formstr(inform), formstr(outform));
| 456 |
printf("-o%-9s\t\t\t# output", outvals);
| 457 |
for (cp = outvals; *cp; cp++)
| 458 |
switch (*cp) {
| 459 |
case 't': case 'T': printf(" trace"); break;
| 460 |
case 'o': printf(" origin"); break;
| 461 |
case 'd': printf(" direction"); break;
| 462 |
case 'r': printf(" reflect_contrib"); break;
| 463 |
case 'R': printf(" reflect_length"); break;
| 464 |
case 'x': printf(" unreflect_contrib"); break;
| 465 |
case 'X': printf(" unreflect_length"); break;
| 466 |
case 'v': printf(" value"); break;
| 467 |
case 'V': printf(" contribution"); break;
| 468 |
case 'l': printf(" length"); break;
| 469 |
case 'L': printf(" first_length"); break;
| 470 |
case 'p': printf(" point"); break;
| 471 |
case 'n': printf(" normal"); break;
| 472 |
case 'N': printf(" unperturbed_normal"); break;
| 473 |
case 's': printf(" surface"); break;
| 474 |
case 'w': printf(" weight"); break;
| 475 |
case 'W': printf(" coefficient"); break;
| 476 |
case 'm': printf(" modifier"); break;
| 477 |
case 'M': printf(" material"); break;
| 478 |
case '~': printf(" tilde"); break;
| 479 |
| 480 |
putchar('\n');
| 481 |
if (sens_curve == scolor_photopic)
| 482 |
printf("-pY\t\t\t\t# photopic output\n");
| 483 |
else if (sens_curve == scolor_scotopic)
| 484 |
printf("-pS\t\t\t\t# scotopic output\n");
| 485 |
else if (sens_curve == scolor_melanopic)
| 486 |
printf("-pM\t\t\t\t# melanopic output\n");
| 487 |
else if (out_prims == stdprims)
| 488 |
printf("-pRGB\t\t\t\t# standard RGB color output\n");
| 489 |
else if (out_prims == xyzprims)
| 490 |
printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
| 491 |
else if (out_prims != NULL)
| 492 |
printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
| 493 |
out_prims[RED][0], out_prims[RED][1],
| 494 |
out_prims[GRN][0], out_prims[GRN][1],
| 495 |
out_prims[BLU][0], out_prims[BLU][1],
| 496 |
out_prims[WHT][0], out_prims[WHT][1]);
| 497 |
if ((sens_curve == NULL) & (NCSAMP > 3))
| 498 |
printf(out_prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
| 499 |
"-co+\t\t\t\t# output spectral values\n");
| 500 |
printf(erract[WARNING].pf != NULL ?
| 501 |
"-w+\t\t\t\t# warning messages on\n" :
| 502 |
"-w-\t\t\t\t# warning messages off\n");
| 503 |
print_rdefaults();
| 504 |
