root/radiance/ray/src/rt/rxtmain.cpp
Revision: 2.11
Committed: Tue Nov 19 16:27:21 2024 UTC (6 months, 2 weeks ago) by greg
fix(rxtrace): The -I option wasn't being set properly
2 static const char RCSid[] = "$Id: rxtmain.cpp,v 2.10 2024/10/31 19:02:38 greg Exp $";
5 * rxtmain.cpp - main for per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "rtprocess.h" /* getpid() */
13 #include "platform.h"
14 #include "RtraceSimulManager.h"
15
16 extern char *progname; /* global argv[0] */
17
18 static const char *sigerr[NSIG]; /* signal error messages */
19 char *errfile = NULL; /* error output file */
20
21 extern const char *formstr(int f); /* string from format */
22 extern int setrtoutput(const char *outvals); /* set output values */
23
24 int inform = 'a'; /* input format */
25 int outform = 'a'; /* output format */
26
27 int hresolu = 0; /* horizontal (scan) size */
28 int vresolu = 0; /* vertical resolution */
29
30 RtraceSimulManager myRTmanager; // global simulation manager
31
32 static const char *outvals = "v"; /* output specification */
33 static int nproc = 1; /* number of requested threads */
34 static int doheader = 1; /* include information header? */
35
36 #ifndef MAXMODLIST
37 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
38 #endif
39
40 extern void (*addobjnotify[])(OBJECT); /* object notification calls */
41 extern void tranotify(OBJECT obj);
42
43 char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
44 int traincl = -1; /* include == 1, exclude == 0 */
45
46 double (*sens_curve)(const SCOLOR scol) = NULL; /* spectral conversion for 1-channel */
47 double out_scalefactor = 1; /* output calibration scale factor */
48 RGBPRIMP out_prims = stdprims; /* output color primitives (NULL if spectral) */
49 static RGBPRIMS our_prims; /* private output color primitives */
50
51 static void onsig(int signo);
52 static void sigdie(int signo, const char *msg);
53 static void printdefaults(void);
54
55 #define RXTRACE_FEATURES "IrradianceCalc\nMultiprocessing\nDistanceLimiting\n" \
56 "HessianAmbientCache\nAmbientAveraging\n" \
57 "AmbientValueSharing\nAdaptiveShadowTesting\n" \
58 "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \
59 "OutputCS=RGB,XYZ,Y,S,M,prims,spec\n"
60
61 int
62 main(int argc, char *argv[])
63 {
64 #define check(ol,al) if (argv[i][ol] || \
65 badarg(argc-i-1,argv+i+1,al)) \
66 goto badopt
67 #define check_bool(olen,var) switch (argv[i][olen]) { \
68 case '\0': var = !var; break; \
69 case 'y': case 'Y': case 't': case 'T': \
70 case '+': case '1': var = 1; break; \
71 case 'n': case 'N': case 'f': case 'F': \
72 case '-': case '0': var = 0; break; \
73 default: goto badopt; }
74 char **tralp = NULL;
75 int rval;
76 int i;
77 /* global program name */
78 progname = argv[0];
79 /* feature check only? */
80 strcat(RFeatureList, RXTRACE_FEATURES);
81 if (argc > 1 && !strcmp(argv[1], "-features"))
82 return feature_status(argc-2, argv+2);
83 /* add trace notify function */
84 for (i = 0; addobjnotify[i] != NULL; i++)
85 ;
86 addobjnotify[i] = tranotify;
87 /* option city */
88 for (i = 1; i < argc; i++) {
89 /* expand arguments */
90 while ((rval = expandarg(&argc, &argv, i)) > 0)
91 ;
92 if (rval < 0) {
93 sprintf(errmsg, "cannot expand '%s'", argv[i]);
94 error(SYSTEM, errmsg);
95 }
96 if (argv[i] == NULL || argv[i][0] != '-')
97 break; /* break from options */
98 if (!strcmp(argv[i], "-version")) {
99 puts(VersionID);
100 quit(0);
101 }
102 if (!strcmp(argv[i], "-defaults") ||
103 !strcmp(argv[i], "-help")) {
104 printdefaults();
105 quit(0);
106 }
107 rval = getrenderopt(argc-i, argv+i);
108 if (rval >= 0) {
109 i += rval;
110 continue;
111 }
112 switch (argv[i][1]) {
113 case 'n': /* number of cores */
114 check(2,"i");
115 nproc = atoi(argv[++i]);
116 break;
117 case 'x': /* x resolution */
118 check(2,"i");
119 hresolu = atoi(argv[++i]);
120 break;
121 case 'y': /* y resolution */
122 check(2,"i");
123 vresolu = atoi(argv[++i]);
124 break;
125 case 'w': /* warnings */
126 rval = erract[WARNING].pf != NULL;
127 check_bool(2,rval);
128 if (rval) erract[WARNING].pf = wputs;
129 else erract[WARNING].pf = NULL;
130 break;
131 case 'e': /* error file */
132 check(2,"s");
133 errfile = argv[++i];
134 break;
135 case 'l': /* limit distance */
136 if (argv[i][2] != 'd')
137 goto badopt;
138 rval = myRTmanager.rtFlags & RTlimDist;
139 check_bool(3,rval);
140 if (rval) myRTmanager.rtFlags |= RTlimDist;
141 else myRTmanager.rtFlags &= ~RTlimDist;
142 break;
143 case 'I': /* immed. irradiance */
144 rval = myRTmanager.rtFlags & RTimmIrrad;
145 check_bool(2,rval);
146 if (rval) myRTmanager.rtFlags |= RTimmIrrad;
147 else myRTmanager.rtFlags &= ~RTimmIrrad;
148 break;
149 case 'f': /* format i/o */
150 switch (argv[i][2]) {
151 case 'a': /* ascii */
152 case 'f': /* float */
153 case 'd': /* double */
154 inform = argv[i][2];
155 break;
156 default:
157 goto badopt;
158 }
159 switch (argv[i][3]) {
160 case '\0':
161 outform = inform;
162 break;
163 case 'a': /* ascii */
164 case 'f': /* float */
165 case 'd': /* double */
166 case 'c': /* color */
167 check(4,"");
168 outform = argv[i][3];
169 break;
170 default:
171 goto badopt;
172 }
173 break;
174 case 'o': /* output */
175 outvals = argv[i]+2;
176 break;
177 case 'h': /* header output */
178 check_bool(2,doheader);
179 break;
180 case 't': /* trace */
181 switch (argv[i][2]) {
182 case 'i': /* include */
183 case 'I':
184 check(3,"s");
185 if (traincl != 1) {
186 traincl = 1;
187 tralp = tralist;
188 }
189 if (argv[i][2] == 'I') { /* file */
190 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
191 getpath(argv[++i],getrlibpath(),R_OK));
192 if (rval < 0) {
193 sprintf(errmsg,
194 "cannot open trace include file \"%s\"",
195 argv[i]);
196 error(SYSTEM, errmsg);
197 }
198 tralp += rval;
199 } else {
200 *tralp++ = argv[++i];
201 *tralp = NULL;
202 }
203 break;
204 case 'e': /* exclude */
205 case 'E':
206 check(3,"s");
207 if (traincl != 0) {
208 traincl = 0;
209 tralp = tralist;
210 }
211 if (argv[i][2] == 'E') { /* file */
212 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
213 getpath(argv[++i],getrlibpath(),R_OK));
214 if (rval < 0) {
215 sprintf(errmsg,
216 "cannot open trace exclude file \"%s\"",
217 argv[i]);
218 error(SYSTEM, errmsg);
219 }
220 tralp += rval;
221 } else {
222 *tralp++ = argv[++i];
223 *tralp = NULL;
224 }
225 break;
226 default:
227 goto badopt;
228 }
229 break;
230 case 'p': /* value output */
231 switch (argv[i][2]) {
232 case 'R': /* standard RGB output */
233 if (strcmp(argv[i]+2, "RGB"))
234 goto badopt;
235 out_prims = stdprims;
236 out_scalefactor = 1;
237 sens_curve = NULL;
238 break;
239 case 'X': /* XYZ output */
240 if (strcmp(argv[i]+2, "XYZ"))
241 goto badopt;
242 out_prims = xyzprims;
243 out_scalefactor = WHTEFFICACY;
244 sens_curve = NULL;
245 break;
246 case 'c': {
247 int j;
248 check(3,"ffffffff");
249 rval = 0;
250 for (j = 0; j < 8; j++) {
251 our_prims[0][j] = atof(argv[++i]);
252 rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
253 }
254 if (rval) {
255 if (!colorprimsOK(our_prims))
256 error(USER, "illegal primary chromaticities");
257 out_prims = our_prims;
258 } else
259 out_prims = stdprims;
260 out_scalefactor = 1;
261 sens_curve = NULL;
262 } break;
263 case 'Y': /* photopic response */
264 if (argv[i][3])
265 goto badopt;
266 sens_curve = scolor_photopic;
267 out_scalefactor = WHTEFFICACY;
268 break;
269 case 'S': /* scotopic response */
270 if (argv[i][3])
271 goto badopt;
272 sens_curve = scolor_scotopic;
273 out_scalefactor = WHTSCOTOPIC;
274 break;
275 case 'M': /* melanopic response */
276 if (argv[i][3])
277 goto badopt;
278 sens_curve = scolor_melanopic;
279 out_scalefactor = WHTMELANOPIC;
280 break;
281 default:
282 goto badopt;
283 }
284 break;
285 #if MAXCSAMP>3
286 case 'c': /* output spectral results */
287 if (argv[i][2] != 'o')
288 goto badopt;
289 rval = (out_prims == NULL) & (sens_curve == NULL);
290 check_bool(3,rval);
291 if (rval) {
292 out_prims = NULL;
293 sens_curve = NULL;
294 } else if (out_prims == NULL)
295 out_prims = stdprims;
296 break;
297 #endif
298 default:
299 goto badopt;
300 }
301 }
302 /* set/check spectral sampling */
303 rval = setspectrsamp(CNDX, WLPART);
304 if (rval < 0)
305 error(USER, "unsupported spectral sampling");
306 if (out_prims != NULL) {
307 if (!rval)
308 error(WARNING, "spectral range incompatible with color output");
309 } else if (NCSAMP == 3)
310 out_prims = stdprims; /* 3 samples do not a spectrum make */
311 /* set up signal handling */
312 sigdie(SIGINT, "Interrupt");
313 #ifdef SIGHUP
314 sigdie(SIGHUP, "Hangup");
315 #endif
316 sigdie(SIGTERM, "Terminate");
317 #ifdef SIGPIPE
318 sigdie(SIGPIPE, "Broken pipe");
319 #endif
320 #ifdef SIGALRM
321 sigdie(SIGALRM, "Alarm clock");
322 #endif
323 #ifdef SIGXCPU
324 sigdie(SIGXCPU, "CPU limit exceeded");
325 sigdie(SIGXFSZ, "File size exceeded");
326 #endif
327 /* open error file */
328 if (errfile != NULL) {
329 if (freopen(errfile, "a", stderr) == NULL)
330 quit(2);
331 fprintf(stderr, "**************\n*** PID %5d: ",
332 getpid());
333 printargs(argc, argv, stderr);
334 putc('\n', stderr);
335 fflush(stderr);
336 }
337 #ifdef NICE
338 nice(NICE); /* lower priority */
339 #endif
340 /* get octree name */
341 if (i == argc)
342 error(USER, "missing octree argument");
343 if (i != argc-1)
344 goto badopt;
345 /* set output options */
346 rval = setrtoutput(outvals);
347 /* load octree */
348 if (!myRTmanager.LoadOctree(argv[i]))
349 quit(1);
350 /* set up output */
351 if (outform != 'a')
352 SET_FILE_BINARY(stdout);
353 if (doheader) { /* print header? */
354 newheader("RADIANCE", stdout);
355 fputs(myRTmanager.GetHeadStr(), stdout);
356 printargs(i, argv, stdout);
357 printf("SOFTWARE= %s\n", VersionID);
358 fputnow(stdout);
359 if (rval > 0) /* saved from setrtoutput() call */
360 printf("NCOMP=%d\n", rval);
361 if ((outform == 'f') | (outform == 'd'))
362 fputendian(stdout);
363 fputformat(formstr(outform), stdout);
364 fputc('\n', stdout); /* end of header */
365 }
366 rtrace(NULL, nproc); /* trace rays */
367 quit(0); /* clean up & exit */
368
369 badopt:
370 sprintf(errmsg, "command line error at '%s'", argv[i]);
371 error(USER, errmsg);
372 return 1; /* pro forma return */
373
374 #undef check
375 #undef check_bool
376 }
377
378 void
379 wputs( /* warning output function */
380 char *s
381 )
382 {
383 int lasterrno = errno;
384 eputs(s);
385 errno = lasterrno;
386 }
387
388 void
389 eputs( /* put string to stderr */
390 const char *s
391 )
392 {
393 static int midline = 0;
394
395 if (!*s)
396 return;
397 if (!midline++) {
398 fputs(progname, stderr);
399 fputs(": ", stderr);
400 }
401 fputs(s, stderr);
402 if (s[strlen(s)-1] == '\n') {
403 fflush(stderr);
404 midline = 0;
405 }
406 }
407
408 static void
409 onsig( /* fatal signal */
410 int signo
411 )
412 {
413 static int gotsig = 0;
414
415 if (gotsig++) /* two signals and we're gone! */
416 _exit(signo);
417
418 #ifdef SIGALRM
419 alarm(15); /* allow 15 seconds to clean up */
420 signal(SIGALRM, SIG_DFL); /* make certain we do die */
421 #endif
422 eputs("signal - ");
423 eputs(sigerr[signo]);
424 eputs("\n");
425 quit(3);
426 }
427
428 static void
429 sigdie( /* set fatal signal */
430 int signo,
431 const char *msg
432 )
433 {
434 if (signal(signo, onsig) == SIG_IGN)
435 signal(signo, SIG_IGN);
436 sigerr[signo] = msg;
437 }
438
439 static void
440 printdefaults(void) /* print default values to stdout */
441 {
442 const char *cp;
443
444 if (myRTmanager.rtFlags & RTimmIrrad)
445 printf("-I+\t\t\t\t# immediate irradiance on\n");
446 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
447 printf("-x %-9d\t\t\t# %s\n", hresolu,
448 vresolu && hresolu ? "x resolution" : "flush interval");
449 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
450 printf(myRTmanager.rtFlags&RTlimDist ? "-ld+\t\t\t\t# limit distance on\n" :
451 "-ld-\t\t\t\t# limit distance off\n");
452 printf("-h%c\t\t\t\t# %s header\n", doheader ? '+' : '-',
453 doheader ? "output" : "no");
454 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
455 inform, outform, formstr(inform), formstr(outform));
456 printf("-o%-9s\t\t\t# output", outvals);
457 for (cp = outvals; *cp; cp++)
458 switch (*cp) {
459 case 't': case 'T': printf(" trace"); break;
460 case 'o': printf(" origin"); break;
461 case 'd': printf(" direction"); break;
462 case 'r': printf(" reflect_contrib"); break;
463 case 'R': printf(" reflect_length"); break;
464 case 'x': printf(" unreflect_contrib"); break;
465 case 'X': printf(" unreflect_length"); break;
466 case 'v': printf(" value"); break;
467 case 'V': printf(" contribution"); break;
468 case 'l': printf(" length"); break;
469 case 'L': printf(" first_length"); break;
470 case 'p': printf(" point"); break;
471 case 'n': printf(" normal"); break;
472 case 'N': printf(" unperturbed_normal"); break;
473 case 's': printf(" surface"); break;
474 case 'w': printf(" weight"); break;
475 case 'W': printf(" coefficient"); break;
476 case 'm': printf(" modifier"); break;
477 case 'M': printf(" material"); break;
478 case '~': printf(" tilde"); break;
479 }
480 putchar('\n');
481 if (sens_curve == scolor_photopic)
482 printf("-pY\t\t\t\t# photopic output\n");
483 else if (sens_curve == scolor_scotopic)
484 printf("-pS\t\t\t\t# scotopic output\n");
485 else if (sens_curve == scolor_melanopic)
486 printf("-pM\t\t\t\t# melanopic output\n");
487 else if (out_prims == stdprims)
488 printf("-pRGB\t\t\t\t# standard RGB color output\n");
489 else if (out_prims == xyzprims)
490 printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
491 else if (out_prims != NULL)
492 printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
493 out_prims[RED][0], out_prims[RED][1],
494 out_prims[GRN][0], out_prims[GRN][1],
495 out_prims[BLU][0], out_prims[BLU][1],
496 out_prims[WHT][0], out_prims[WHT][1]);
497 if ((sens_curve == NULL) & (NCSAMP > 3))
498 printf(out_prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
499 "-co+\t\t\t\t# output spectral values\n");
500 printf(erract[WARNING].pf != NULL ?
501 "-w+\t\t\t\t# warning messages on\n" :
502 "-w-\t\t\t\t# warning messages off\n");
503 print_rdefaults();
504 }
