root/radiance/ray/src/rt/rxtmain.cpp
Revision: 2.1
Committed: Mon Aug 21 22:39:05 2023 UTC (20 months, 2 weeks ago) by greg
Renamed ratrace to rxtrace
2 static const char RCSid[] = "$Id: ratmain.cpp,v 2.1 2023/02/08 17:41:48 greg Exp $";
5 * rtmain.c - main for rtrace per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "rtprocess.h" /* getpid() */
13 #include "platform.h"
14 #include "RtraceSimulManager.h"
15
16 extern char *progname; /* global argv[0] */
17
18 static const char *sigerr[NSIG]; /* signal error messages */
19 char *errfile = NULL; /* error output file */
20
21 extern const char *formstr(int f); /* string from format */
22 extern int setrtoutput(const char *outvals); /* set output values */
23
24 int inform = 'a'; /* input format */
25 int outform = 'a'; /* output format */
26
27 int hresolu = 0; /* horizontal (scan) size */
28 int vresolu = 0; /* vertical resolution */
29
30 RtraceSimulManager myRTmanager; // global simulation manager
31
32 static const char *outvals = "v"; /* output specification */
33 static int nproc = 1; /* number of requested threads */
34 static int doheader = 1; /* include information header? */
35
36 #ifndef MAXMODLIST
37 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
38 #endif
39
40 extern void (*addobjnotify[])(OBJECT); /* object notification calls */
41 extern void tranotify(OBJECT obj);
42
43 char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
44 int traincl = -1; /* include == 1, exclude == 0 */
45
46 static void onsig(int signo);
47 static void sigdie(int signo, const char *msg);
48 static void printdefaults(void);
49
50 #define RATRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \
51 "HessianAmbientCache\nAmbientAveraging\n" \
52 "AmbientValueSharing\nAdaptiveShadowTesting\n" \
53 "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n"
54
55 int
56 main(int argc, char *argv[])
57 {
58 #define check(ol,al) if (argv[i][ol] || \
59 badarg(argc-i-1,argv+i+1,al)) \
60 goto badopt
61 #define check_bool(olen,var) switch (argv[i][olen]) { \
62 case '\0': var = !var; break; \
63 case 'y': case 'Y': case 't': case 'T': \
64 case '+': case '1': var = 1; break; \
65 case 'n': case 'N': case 'f': case 'F': \
66 case '-': case '0': var = 0; break; \
67 default: goto badopt; }
68 char **tralp = NULL;
69 int rval;
70 int i;
71 /* global program name */
72 progname = argv[0] = fixargv0(argv[0]);
73 /* feature check only? */
74 strcat(RFeatureList, RATRACE_FEATURES);
75 if (argc > 1 && !strcmp(argv[1], "-features"))
76 return feature_status(argc-2, argv+2);
77 /* add trace notify function */
78 for (i = 0; addobjnotify[i] != NULL; i++)
79 ;
80 addobjnotify[i] = tranotify;
81 /* option city */
82 for (i = 1; i < argc; i++) {
83 /* expand arguments */
84 while ((rval = expandarg(&argc, &argv, i)) > 0)
85 ;
86 if (rval < 0) {
87 sprintf(errmsg, "cannot expand '%s'", argv[i]);
88 error(SYSTEM, errmsg);
89 }
90 if (argv[i] == NULL || argv[i][0] != '-')
91 break; /* break from options */
92 if (!strcmp(argv[i], "-version")) {
93 puts(VersionID);
94 quit(0);
95 }
96 if (!strcmp(argv[i], "-defaults") ||
97 !strcmp(argv[i], "-help")) {
98 printdefaults();
99 quit(0);
100 }
101 rval = getrenderopt(argc-i, argv+i);
102 if (rval >= 0) {
103 i += rval;
104 continue;
105 }
106 switch (argv[i][1]) {
107 case 'n': /* number of cores */
108 check(2,"i");
109 nproc = atoi(argv[++i]);
110 if (nproc < 0)
111 error(USER, "bad number of processes");
112 break;
113 case 'x': /* x resolution */
114 check(2,"i");
115 hresolu = atoi(argv[++i]);
116 break;
117 case 'y': /* y resolution */
118 check(2,"i");
119 vresolu = atoi(argv[++i]);
120 break;
121 case 'w': /* warnings */
122 rval = erract[WARNING].pf != NULL;
123 check_bool(2,rval);
124 if (rval) erract[WARNING].pf = wputs;
125 else erract[WARNING].pf = NULL;
126 break;
127 case 'e': /* error file */
128 check(2,"s");
129 errfile = argv[++i];
130 break;
131 case 'l': /* limit distance */
132 if (argv[i][2] != 'd')
133 goto badopt;
134 rval = myRTmanager.rtFlags & RTlimDist;
135 check_bool(3,rval);
136 if (rval) myRTmanager.rtFlags |= RTlimDist;
137 else myRTmanager.rtFlags &= ~RTlimDist;
138 break;
139 case 'I': /* immed. irradiance */
140 rval = myRTmanager.rtFlags & RTimmIrrad;
141 check_bool(3,rval);
142 if (rval) myRTmanager.rtFlags |= RTimmIrrad;
143 else myRTmanager.rtFlags &= ~RTimmIrrad;
144 break;
145 case 'f': /* format i/o */
146 switch (argv[i][2]) {
147 case 'a': /* ascii */
148 case 'f': /* float */
149 case 'd': /* double */
150 inform = argv[i][2];
151 break;
152 default:
153 goto badopt;
154 }
155 switch (argv[i][3]) {
156 case '\0':
157 outform = inform;
158 break;
159 case 'a': /* ascii */
160 case 'f': /* float */
161 case 'd': /* double */
162 case 'c': /* color */
163 check(4,"");
164 outform = argv[i][3];
165 break;
166 default:
167 goto badopt;
168 }
169 break;
170 case 'o': /* output */
171 outvals = argv[i]+2;
172 break;
173 case 'h': /* header output */
174 check_bool(2,doheader);
175 break;
176 case 't': /* trace */
177 switch (argv[i][2]) {
178 case 'i': /* include */
179 case 'I':
180 check(3,"s");
181 if (traincl != 1) {
182 traincl = 1;
183 tralp = tralist;
184 }
185 if (argv[i][2] == 'I') { /* file */
186 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
187 getpath(argv[++i],getrlibpath(),R_OK));
188 if (rval < 0) {
189 sprintf(errmsg,
190 "cannot open trace include file \"%s\"",
191 argv[i]);
192 error(SYSTEM, errmsg);
193 }
194 tralp += rval;
195 } else {
196 *tralp++ = argv[++i];
197 *tralp = NULL;
198 }
199 break;
200 case 'e': /* exclude */
201 case 'E':
202 check(3,"s");
203 if (traincl != 0) {
204 traincl = 0;
205 tralp = tralist;
206 }
207 if (argv[i][2] == 'E') { /* file */
208 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
209 getpath(argv[++i],getrlibpath(),R_OK));
210 if (rval < 0) {
211 sprintf(errmsg,
212 "cannot open trace exclude file \"%s\"",
213 argv[i]);
214 error(SYSTEM, errmsg);
215 }
216 tralp += rval;
217 } else {
218 *tralp++ = argv[++i];
219 *tralp = NULL;
220 }
221 break;
222 default:
223 goto badopt;
224 }
225 break;
226 default:
227 goto badopt;
228 }
229 }
230 /* set up signal handling */
231 sigdie(SIGINT, "Interrupt");
232 #ifdef SIGHUP
233 sigdie(SIGHUP, "Hangup");
234 #endif
235 sigdie(SIGTERM, "Terminate");
236 #ifdef SIGPIPE
237 sigdie(SIGPIPE, "Broken pipe");
238 #endif
239 #ifdef SIGALRM
240 sigdie(SIGALRM, "Alarm clock");
241 #endif
242 #ifdef SIGXCPU
243 sigdie(SIGXCPU, "CPU limit exceeded");
244 sigdie(SIGXFSZ, "File size exceeded");
245 #endif
246 /* open error file */
247 if (errfile != NULL) {
248 if (freopen(errfile, "a", stderr) == NULL)
249 quit(2);
250 fprintf(stderr, "**************\n*** PID %5d: ",
251 getpid());
252 printargs(argc, argv, stderr);
253 putc('\n', stderr);
254 fflush(stderr);
255 }
256 #ifdef NICE
257 nice(NICE); /* lower priority */
258 #endif
259 /* get octree name */
260 if (i == argc)
261 error(USER, "missing octree argument");
262 if (i != argc-1)
263 goto badopt;
264 /* set output options */
265 rval = setrtoutput(outvals);
266 /* load octree */
267 if (!myRTmanager.LoadOctree(argv[i]))
268 quit(1);
269 /* set up output */
270 if (outform != 'a')
271 SET_FILE_BINARY(stdout);
272 if (doheader) { /* print header? */
273 static char fmt[] = OCTFMT;
274 FILE * octfp = fopen(argv[i], "rb");
275 if (checkheader(octfp, fmt, stdout) < 0)
276 error(USER, "bad octree header");
277 fclose(octfp);
278 printargs(i, argv, stdout);
279 printf("SOFTWARE= %s\n", VersionID);
280 fputnow(stdout);
281 if (rval > 0) /* saved from setrtoutput() call */
282 printf("NCOMP=%d\n", rval);
283 if ((outform == 'f') | (outform == 'd'))
284 fputendian(stdout);
285 fputformat(formstr(outform), stdout);
286 putchar('\n');
287 }
288 rtrace(NULL, nproc); /* trace rays */
289 quit(0); /* clean up & exit */
290
291 badopt:
292 sprintf(errmsg, "command line error at '%s'", argv[i]);
293 error(USER, errmsg);
294 return 1; /* pro forma return */
295
296 #undef check
297 #undef check_bool
298 }
299
300 void
301 wputs( /* warning output function */
302 char *s
303 )
304 {
305 int lasterrno = errno;
306 eputs(s);
307 errno = lasterrno;
308 }
309
310 void
311 eputs( /* put string to stderr */
312 char *s
313 )
314 {
315 static int midline = 0;
316
317 if (!*s)
318 return;
319 if (!midline++) {
320 fputs(progname, stderr);
321 fputs(": ", stderr);
322 }
323 fputs(s, stderr);
324 if (s[strlen(s)-1] == '\n') {
325 fflush(stderr);
326 midline = 0;
327 }
328 }
329
330 static void
331 onsig( /* fatal signal */
332 int signo
333 )
334 {
335 static int gotsig = 0;
336
337 if (gotsig++) /* two signals and we're gone! */
338 _exit(signo);
339
340 #ifdef SIGALRM
341 alarm(15); /* allow 15 seconds to clean up */
342 signal(SIGALRM, SIG_DFL); /* make certain we do die */
343 #endif
344 eputs("signal - ");
345 eputs(sigerr[signo]);
346 eputs("\n");
347 quit(3);
348 }
349
350 static void
351 sigdie( /* set fatal signal */
352 int signo,
353 const char *msg
354 )
355 {
356 if (signal(signo, onsig) == SIG_IGN)
357 signal(signo, SIG_IGN);
358 sigerr[signo] = msg;
359 }
360
361 static void
362 printdefaults(void) /* print default values to stdout */
363 {
364 const char *cp;
365
366 if (myRTmanager.rtFlags & RTimmIrrad)
367 printf("-I+\t\t\t\t# immediate irradiance on\n");
368 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
369 printf("-x %-9d\t\t\t# %s\n", hresolu,
370 vresolu && hresolu ? "x resolution" : "flush interval");
371 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
372 printf(myRTmanager.rtFlags&RTlimDist ? "-ld+\t\t\t\t# limit distance on\n" :
373 "-ld-\t\t\t\t# limit distance off\n");
374 printf("-h%c\t\t\t\t# %s header\n", doheader ? '+' : '-',
375 doheader ? "output" : "no");
376 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
377 inform, outform, formstr(inform), formstr(outform));
378 printf("-o%-9s\t\t\t# output", outvals);
379 for (cp = outvals; *cp; cp++)
380 switch (*cp) {
381 case 't': case 'T': printf(" trace"); break;
382 case 'o': printf(" origin"); break;
383 case 'd': printf(" direction"); break;
384 case 'r': printf(" reflect_contrib"); break;
385 case 'R': printf(" reflect_length"); break;
386 case 'x': printf(" unreflect_contrib"); break;
387 case 'X': printf(" unreflect_length"); break;
388 case 'v': printf(" value"); break;
389 case 'V': printf(" contribution"); break;
390 case 'l': printf(" length"); break;
391 case 'L': printf(" first_length"); break;
392 case 'p': printf(" point"); break;
393 case 'n': printf(" normal"); break;
394 case 'N': printf(" unperturbed_normal"); break;
395 case 's': printf(" surface"); break;
396 case 'w': printf(" weight"); break;
397 case 'W': printf(" coefficient"); break;
398 case 'm': printf(" modifier"); break;
399 case 'M': printf(" material"); break;
400 case '~': printf(" tilde"); break;
401 }
402 putchar('\n');
403 printf(erract[WARNING].pf != NULL ?
404 "-w+\t\t\t\t# warning messages on\n" :
405 "-w-\t\t\t\t# warning messages off\n");
406 print_rdefaults();
407 }
