--- ray/src/rt/rxtmain.cpp 2024/05/01 22:06:09 2.4 +++ ray/src/rt/rxtmain.cpp 2025/03/05 18:56:28 2.12 @@ -1,8 +1,8 @@ #ifndef lint -static const char RCSid[] = "$Id: rxtmain.cpp,v 2.4 2024/05/01 22:06:09 greg Exp $"; +static const char RCSid[] = "$Id: rxtmain.cpp,v 2.12 2025/03/05 18:56:28 greg Exp $"; #endif /* - * rxtmain.c - main for per-ray calculation program + * rxtmain.cpp - main for per-ray calculation program */ #include "copyright.h" @@ -43,7 +43,7 @@ extern void tranotify(OBJECT obj); char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */ int traincl = -1; /* include == 1, exclude == 0 */ -double (*sens_curve)(SCOLOR scol) = NULL; /* spectral conversion for 1-channel */ +double (*sens_curve)(const SCOLOR scol) = NULL; /* spectral conversion for 1-channel */ double out_scalefactor = 1; /* output calibration scale factor */ RGBPRIMP out_prims = stdprims; /* output color primitives (NULL if spectral) */ static RGBPRIMS our_prims; /* private output color primitives */ @@ -52,7 +52,7 @@ static void onsig(int signo); static void sigdie(int signo, const char *msg); static void printdefaults(void); -#define RXTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \ +#define RXTRACE_FEATURES "IrradianceCalc\nMultiprocessing\nDistanceLimiting\n" \ "HessianAmbientCache\nAmbientAveraging\n" \ "AmbientValueSharing\nAdaptiveShadowTesting\n" \ "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \ @@ -142,7 +142,7 @@ main(int argc, char *argv[]) break; case 'I': /* immed. irradiance */ rval = myRTmanager.rtFlags & RTimmIrrad; - check_bool(3,rval); + check_bool(2,rval); if (rval) myRTmanager.rtFlags |= RTimmIrrad; else myRTmanager.rtFlags &= ~RTimmIrrad; break; @@ -303,7 +303,9 @@ main(int argc, char *argv[]) rval = setspectrsamp(CNDX, WLPART); if (rval < 0) error(USER, "unsupported spectral sampling"); - if (out_prims != NULL) { + if (sens_curve != NULL) + out_prims = NULL; + else if (out_prims != NULL) { if (!rval) error(WARNING, "spectral range incompatible with color output"); } else if (NCSAMP == 3) @@ -351,16 +353,17 @@ main(int argc, char *argv[]) if (outform != 'a') SET_FILE_BINARY(stdout); if (doheader) { /* print header? */ - static char fmt[] = OCTFMT; - FILE * octfp = fopen(argv[i], "rb"); - if (checkheader(octfp, fmt, stdout) < 0) - error(USER, "bad octree header"); - fclose(octfp); + newheader("RADIANCE", stdout); + fputs(myRTmanager.GetHeadStr(), stdout); printargs(i, argv, stdout); printf("SOFTWARE= %s\n", VersionID); fputnow(stdout); if (rval > 0) /* saved from setrtoutput() call */ - printf("NCOMP=%d\n", rval); + fputncomp(rval, stdout); + if (NCSAMP > 3) + fputwlsplit(WLPART, stdout); + if ((out_prims != stdprims) & (out_prims != NULL)) + fputprims(out_prims, stdout); if ((outform == 'f') | (outform == 'd')) fputendian(stdout); fputformat(formstr(outform), stdout); @@ -390,7 +393,7 @@ wputs( /* warning output function */ void eputs( /* put string to stderr */ - char *s + const char *s ) { static int midline = 0;
