root/radiance/ray/src/rt/rxtmain.cpp
Revision: 2.15
Committed: Sun Aug 3 18:20:44 2025 UTC (7 days, 15 hours ago) by greg
fix(rxpiece,rxpict,rxtrace): Added missing i/o -features
2 static const char RCSid[] = "$Id: rxtmain.cpp,v 2.14 2025/06/05 18:26:46 greg Exp $";
5 * rxtmain.cpp - main for per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "rtprocess.h" /* getpid() */
13 #include "platform.h"
14 #include "RtraceSimulManager.h"
15 #include "func.h"
16
17 static const char *sigerr[NSIG]; /* signal error messages */
18 char *errfile = NULL; /* error output file */
19
20 extern const char *formstr(int f); /* string from format */
21 extern int setrtoutput(const char *outvals); /* set output values */
22
23 int inform = 'a'; /* input format */
24 int outform = 'a'; /* output format */
25
26 int hresolu = 0; /* horizontal (scan) size */
27 int vresolu = 0; /* vertical resolution */
28
29 RtraceSimulManager myRTmanager; // global simulation manager
30
31 static const char *outvals = "v"; /* output specification */
32 static int nproc = 1; /* number of requested threads */
33 static int doheader = 1; /* include information header? */
34
35 #ifndef MAXMODLIST
36 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
37 #endif
38
39 extern void (*addobjnotify[])(OBJECT); /* object notification calls */
40 extern void tranotify(OBJECT obj);
41
42 char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
43 int traincl = -1; /* include == 1, exclude == 0 */
44
45 double (*sens_curve)(const SCOLOR scol) = NULL; /* spectral conversion for 1-channel */
46 double out_scalefactor = 1; /* output calibration scale factor */
47 RGBPRIMP out_prims = stdprims; /* output color primitives (NULL if spectral) */
48 static RGBPRIMS our_prims; /* private output color primitives */
49
50 static void onsig(int signo);
51 static void sigdie(int signo, const char *msg);
52 static void printdefaults(void);
53
54 #define RXTRACE_FEATURES "IrradianceCalc\nMultiprocessing\nDistanceLimiting\n" \
55 "HessianAmbientCache\nAmbientAveraging\n" \
56 "AmbientValueSharing\nAdaptiveShadowTesting\n" \
57 "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
58 "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \
59 "OutputCS=RGB,XYZ,Y,S,M,prims,spec\n"
60
61 int
62 main(int argc, char *argv[])
63 {
64 #define check(ol,al) if (argv[i][ol] || \
65 badarg(argc-i-1,argv+i+1,al)) \
66 goto badopt
67 #define check_bool(olen,var) switch (argv[i][olen]) { \
68 case '\0': var = !var; break; \
69 case 'y': case 'Y': case 't': case 'T': \
70 case '+': case '1': var = 1; break; \
71 case 'n': case 'N': case 'f': case 'F': \
72 case '-': case '0': var = 0; break; \
73 default: goto badopt; }
74 char **tralp = NULL;
75 int rval;
76 int i;
77 /* global program name */
78 progname = argv[0];
79 /* feature check only? */
80 strcat(RFeatureList, RXTRACE_FEATURES);
81 if (argc > 1 && !strcmp(argv[1], "-features"))
82 return feature_status(argc-2, argv+2);
83 /* initialize calcomp routines */
84 initfunc();
85 /* add trace notify function */
86 for (i = 0; addobjnotify[i] != NULL; i++)
87 ;
88 addobjnotify[i] = tranotify;
89 /* option city */
90 for (i = 1; i < argc; i++) {
91 /* expand arguments */
92 while ((rval = expandarg(&argc, &argv, i)) > 0)
93 ;
94 if (rval < 0) {
95 sprintf(errmsg, "cannot expand '%s'", argv[i]);
96 error(SYSTEM, errmsg);
97 }
98 if (argv[i] == NULL || argv[i][0] != '-')
99 break; /* break from options */
100 if (!strcmp(argv[i], "-version")) {
101 puts(VersionID);
102 quit(0);
103 }
104 if (!strcmp(argv[i], "-defaults") ||
105 !strcmp(argv[i], "-help")) {
106 printdefaults();
107 quit(0);
108 }
109 rval = getrenderopt(argc-i, argv+i);
110 if (rval >= 0) {
111 i += rval;
112 continue;
113 }
114 switch (argv[i][1]) {
115 case 'n': /* number of cores */
116 check(2,"i");
117 nproc = atoi(argv[++i]);
118 break;
119 case 'x': /* x resolution */
120 check(2,"i");
121 hresolu = atoi(argv[++i]);
122 break;
123 case 'y': /* y resolution */
124 check(2,"i");
125 vresolu = atoi(argv[++i]);
126 break;
127 case 'w': /* warnings */
128 rval = erract[WARNING].pf != NULL;
129 check_bool(2,rval);
130 if (rval) erract[WARNING].pf = wputs;
131 else erract[WARNING].pf = NULL;
132 break;
133 case 'e': /* error file */
134 check(2,"s");
135 errfile = argv[++i];
136 break;
137 case 'l': /* limit distance */
138 if (argv[i][2] != 'd')
139 goto badopt;
140 rval = myRTmanager.rtFlags & RTlimDist;
141 check_bool(3,rval);
142 if (rval) myRTmanager.rtFlags |= RTlimDist;
143 else myRTmanager.rtFlags &= ~RTlimDist;
144 break;
145 case 'I': /* immed. irradiance */
146 rval = myRTmanager.rtFlags & RTimmIrrad;
147 check_bool(2,rval);
148 if (rval) myRTmanager.rtFlags |= RTimmIrrad;
149 else myRTmanager.rtFlags &= ~RTimmIrrad;
150 break;
151 case 'f': /* format i/o */
152 switch (argv[i][2]) {
153 case 'a': /* ascii */
154 case 'f': /* float */
155 case 'd': /* double */
156 inform = argv[i][2];
157 break;
158 default:
159 goto badopt;
160 }
161 switch (argv[i][3]) {
162 case '\0':
163 outform = inform;
164 break;
165 case 'a': /* ascii */
166 case 'f': /* float */
167 case 'd': /* double */
168 case 'c': /* color */
169 check(4,"");
170 outform = argv[i][3];
171 break;
172 default:
173 goto badopt;
174 }
175 break;
176 case 'o': /* output */
177 outvals = argv[i]+2;
178 break;
179 case 'h': /* header output */
180 check_bool(2,doheader);
181 break;
182 case 't': /* trace */
183 switch (argv[i][2]) {
184 case 'i': /* include */
185 case 'I':
186 check(3,"s");
187 if (traincl != 1) {
188 traincl = 1;
189 tralp = tralist;
190 }
191 if (argv[i][2] == 'I') { /* file */
192 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
193 getpath(argv[++i],getrlibpath(),R_OK));
194 if (rval < 0) {
195 sprintf(errmsg,
196 "cannot open trace include file \"%s\"",
197 argv[i]);
198 error(SYSTEM, errmsg);
199 }
200 tralp += rval;
201 } else {
202 *tralp++ = argv[++i];
203 *tralp = NULL;
204 }
205 break;
206 case 'e': /* exclude */
207 case 'E':
208 check(3,"s");
209 if (traincl != 0) {
210 traincl = 0;
211 tralp = tralist;
212 }
213 if (argv[i][2] == 'E') { /* file */
214 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
215 getpath(argv[++i],getrlibpath(),R_OK));
216 if (rval < 0) {
217 sprintf(errmsg,
218 "cannot open trace exclude file \"%s\"",
219 argv[i]);
220 error(SYSTEM, errmsg);
221 }
222 tralp += rval;
223 } else {
224 *tralp++ = argv[++i];
225 *tralp = NULL;
226 }
227 break;
228 default:
229 goto badopt;
230 }
231 break;
232 case 'p': /* value output */
233 switch (argv[i][2]) {
234 case 'R': /* standard RGB output */
235 if (strcmp(argv[i]+2, "RGB"))
236 goto badopt;
237 out_prims = stdprims;
238 out_scalefactor = 1;
239 sens_curve = NULL;
240 break;
241 case 'X': /* XYZ output */
242 if (strcmp(argv[i]+2, "XYZ"))
243 goto badopt;
244 out_prims = xyzprims;
245 out_scalefactor = WHTEFFICACY;
246 sens_curve = NULL;
247 break;
248 case 'c': {
249 int j;
250 check(3,"ffffffff");
251 rval = 0;
252 for (j = 0; j < 8; j++) {
253 our_prims[0][j] = atof(argv[++i]);
254 rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
255 }
256 if (rval) {
257 if (!colorprimsOK(our_prims))
258 error(USER, "illegal primary chromaticities");
259 out_prims = our_prims;
260 } else
261 out_prims = stdprims;
262 out_scalefactor = 1;
263 sens_curve = NULL;
264 } break;
265 case 'Y': /* photopic response */
266 if (argv[i][3])
267 goto badopt;
268 sens_curve = scolor_photopic;
269 out_scalefactor = WHTEFFICACY;
270 break;
271 case 'S': /* scotopic response */
272 if (argv[i][3])
273 goto badopt;
274 sens_curve = scolor_scotopic;
275 out_scalefactor = WHTSCOTOPIC;
276 break;
277 case 'M': /* melanopic response */
278 if (argv[i][3])
279 goto badopt;
280 sens_curve = scolor_melanopic;
281 out_scalefactor = WHTMELANOPIC;
282 break;
283 default:
284 goto badopt;
285 }
286 break;
287 #if MAXCSAMP>3
288 case 'c': /* output spectral results */
289 if (argv[i][2] != 'o')
290 goto badopt;
291 rval = (out_prims == NULL) & (sens_curve == NULL);
292 check_bool(3,rval);
293 if (rval) {
294 out_prims = NULL;
295 sens_curve = NULL;
296 } else if (out_prims == NULL)
297 out_prims = stdprims;
298 break;
299 #endif
300 default:
301 goto badopt;
302 }
303 }
304 /* set/check spectral sampling */
305 rval = setspectrsamp(CNDX, WLPART);
306 if (rval < 0)
307 error(USER, "unsupported spectral sampling");
308 if (sens_curve != NULL)
309 out_prims = NULL;
310 else if (out_prims != NULL) {
311 if (!rval)
312 error(WARNING, "spectral range incompatible with color output");
313 } else if (NCSAMP == 3)
314 out_prims = stdprims; /* 3 samples do not a spectrum make */
315 /* set up signal handling */
316 sigdie(SIGINT, "Interrupt");
317 #ifdef SIGHUP
318 sigdie(SIGHUP, "Hangup");
319 #endif
320 sigdie(SIGTERM, "Terminate");
321 #ifdef SIGPIPE
322 sigdie(SIGPIPE, "Broken pipe");
323 #endif
324 #ifdef SIGALRM
325 sigdie(SIGALRM, "Alarm clock");
326 #endif
327 #ifdef SIGXCPU
328 sigdie(SIGXCPU, "CPU limit exceeded");
329 sigdie(SIGXFSZ, "File size exceeded");
330 #endif
331 /* open error file */
332 if (errfile != NULL) {
333 if (freopen(errfile, "a", stderr) == NULL)
334 quit(2);
335 fprintf(stderr, "**************\n*** PID %5d: ",
336 getpid());
337 printargs(argc, argv, stderr);
338 putc('\n', stderr);
339 fflush(stderr);
340 }
341 #ifdef NICE
342 nice(NICE); /* lower priority */
343 #endif
344 /* get octree name */
345 if (i == argc)
346 error(USER, "missing octree argument");
347 if (i != argc-1)
348 goto badopt;
349 /* set output options */
350 rval = setrtoutput(outvals);
351 /* load octree */
352 if (!myRTmanager.LoadOctree(argv[i]))
353 quit(1);
354 /* set up output */
355 if (outform != 'a')
356 SET_FILE_BINARY(stdout);
357 if (doheader) { /* print header? */
358 newheader("RADIANCE", stdout);
359 fputs(myRTmanager.GetHeadStr(), stdout);
360 printargs(i, argv, stdout);
361 printf("SOFTWARE= %s\n", VersionID);
362 fputnow(stdout);
363 if (rval > 0) /* saved from setrtoutput() call */
364 fputncomp(rval, stdout);
365 if (NCSAMP > 3)
366 fputwlsplit(WLPART, stdout);
367 if ((out_prims != stdprims) & (out_prims != NULL))
368 fputprims(out_prims, stdout);
369 if ((outform == 'f') | (outform == 'd'))
370 fputendian(stdout);
371 fputformat(formstr(outform), stdout);
372 fputc('\n', stdout); /* end of header */
373 }
374 rtrace(NULL, nproc); /* trace rays */
375 quit(0); /* clean up & exit */
376
377 badopt:
378 sprintf(errmsg, "command line error at '%s'", argv[i]);
379 error(USER, errmsg);
380 return 1; /* pro forma return */
381
382 #undef check
383 #undef check_bool
384 }
385
386 void
387 wputs( /* warning output function */
388 char *s
389 )
390 {
391 int lasterrno = errno;
392 eputs(s);
393 errno = lasterrno;
394 }
395
396 void
397 eputs( /* put string to stderr */
398 const char *s
399 )
400 {
401 static int midline = 0;
402
403 if (!*s)
404 return;
405 if (!midline++) {
406 fputs(progname, stderr);
407 fputs(": ", stderr);
408 }
409 fputs(s, stderr);
410 if (s[strlen(s)-1] == '\n') {
411 fflush(stderr);
412 midline = 0;
413 }
414 }
415
416 static void
417 onsig( /* fatal signal */
418 int signo
419 )
420 {
421 static int gotsig = 0;
422
423 if (gotsig++) /* two signals and we're gone! */
424 _exit(signo);
425
426 #ifdef SIGALRM
427 alarm(15); /* allow 15 seconds to clean up */
428 signal(SIGALRM, SIG_DFL); /* make certain we do die */
429 #endif
430 eputs("signal - ");
431 eputs(sigerr[signo]);
432 eputs("\n");
433 quit(3);
434 }
435
436 static void
437 sigdie( /* set fatal signal */
438 int signo,
439 const char *msg
440 )
441 {
442 if (signal(signo, onsig) == SIG_IGN)
443 signal(signo, SIG_IGN);
444 sigerr[signo] = msg;
445 }
446
447 static void
448 printdefaults(void) /* print default values to stdout */
449 {
450 const char *cp;
451
452 if (myRTmanager.rtFlags & RTimmIrrad)
453 printf("-I+\t\t\t\t# immediate irradiance on\n");
454 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
455 printf("-x %-9d\t\t\t# %s\n", hresolu,
456 vresolu && hresolu ? "x resolution" : "flush interval");
457 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
458 printf(myRTmanager.rtFlags&RTlimDist ? "-ld+\t\t\t\t# limit distance on\n" :
459 "-ld-\t\t\t\t# limit distance off\n");
460 printf("-h%c\t\t\t\t# %s header\n", doheader ? '+' : '-',
461 doheader ? "output" : "no");
462 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
463 inform, outform, formstr(inform), formstr(outform));
464 printf("-o%-9s\t\t\t# output", outvals);
465 for (cp = outvals; *cp; cp++)
466 switch (*cp) {
467 case 't': case 'T': printf(" trace"); break;
468 case 'o': printf(" origin"); break;
469 case 'd': printf(" direction"); break;
470 case 'r': printf(" reflect_contrib"); break;
471 case 'R': printf(" reflect_length"); break;
472 case 'x': printf(" unreflect_contrib"); break;
473 case 'X': printf(" unreflect_length"); break;
474 case 'v': printf(" value"); break;
475 case 'V': printf(" contribution"); break;
476 case 'l': printf(" length"); break;
477 case 'L': printf(" first_length"); break;
478 case 'p': printf(" point"); break;
479 case 'n': printf(" normal"); break;
480 case 'N': printf(" unperturbed_normal"); break;
481 case 's': printf(" surface"); break;
482 case 'w': printf(" weight"); break;
483 case 'W': printf(" coefficient"); break;
484 case 'm': printf(" modifier"); break;
485 case 'M': printf(" material"); break;
486 case '~': printf(" tilde"); break;
487 }
488 putchar('\n');
489 if (sens_curve == scolor_photopic)
490 printf("-pY\t\t\t\t# photopic output\n");
491 else if (sens_curve == scolor_scotopic)
492 printf("-pS\t\t\t\t# scotopic output\n");
493 else if (sens_curve == scolor_melanopic)
494 printf("-pM\t\t\t\t# melanopic output\n");
495 else if (out_prims == stdprims)
496 printf("-pRGB\t\t\t\t# standard RGB color output\n");
497 else if (out_prims == xyzprims)
498 printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
499 else if (out_prims != NULL)
500 printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
501 out_prims[RED][0], out_prims[RED][1],
502 out_prims[GRN][0], out_prims[GRN][1],
503 out_prims[BLU][0], out_prims[BLU][1],
504 out_prims[WHT][0], out_prims[WHT][1]);
505 if ((sens_curve == NULL) & (NCSAMP > 3))
506 printf(out_prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
507 "-co+\t\t\t\t# output spectral values\n");
508 printf(erract[WARNING].pf != NULL ?
509 "-w+\t\t\t\t# warning messages on\n" :
510 "-w-\t\t\t\t# warning messages off\n");
511 print_rdefaults();
512 }
