root/radiance/ray/src/rt/rxtmain.cpp
Revision: 2.14
Committed: Thu Jun 5 18:26:46 2025 UTC (2 weeks, 4 days ago) by greg
Changes since 2.13: +1 -3 lines
fix: Removed unnecessary or redundant progname declarations
2 static const char RCSid[] = "$Id: rxtmain.cpp,v 2.13 2025/04/22 17:12:25 greg Exp $";
5 * rxtmain.cpp - main for per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "rtprocess.h" /* getpid() */
13 #include "platform.h"
14 #include "RtraceSimulManager.h"
15 #include "func.h"
16
17 static const char *sigerr[NSIG]; /* signal error messages */
18 char *errfile = NULL; /* error output file */
19
20 extern const char *formstr(int f); /* string from format */
21 extern int setrtoutput(const char *outvals); /* set output values */
22
23 int inform = 'a'; /* input format */
24 int outform = 'a'; /* output format */
25
26 int hresolu = 0; /* horizontal (scan) size */
27 int vresolu = 0; /* vertical resolution */
28
29 RtraceSimulManager myRTmanager; // global simulation manager
30
31 static const char *outvals = "v"; /* output specification */
32 static int nproc = 1; /* number of requested threads */
33 static int doheader = 1; /* include information header? */
34
35 #ifndef MAXMODLIST
36 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
37 #endif
38
39 extern void (*addobjnotify[])(OBJECT); /* object notification calls */
40 extern void tranotify(OBJECT obj);
41
42 char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
43 int traincl = -1; /* include == 1, exclude == 0 */
44
45 double (*sens_curve)(const SCOLOR scol) = NULL; /* spectral conversion for 1-channel */
46 double out_scalefactor = 1; /* output calibration scale factor */
47 RGBPRIMP out_prims = stdprims; /* output color primitives (NULL if spectral) */
48 static RGBPRIMS our_prims; /* private output color primitives */
49
50 static void onsig(int signo);
51 static void sigdie(int signo, const char *msg);
52 static void printdefaults(void);
53
54 #define RXTRACE_FEATURES "IrradianceCalc\nMultiprocessing\nDistanceLimiting\n" \
55 "HessianAmbientCache\nAmbientAveraging\n" \
56 "AmbientValueSharing\nAdaptiveShadowTesting\n" \
57 "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \
58 "OutputCS=RGB,XYZ,Y,S,M,prims,spec\n"
59
60 int
61 main(int argc, char *argv[])
62 {
63 #define check(ol,al) if (argv[i][ol] || \
64 badarg(argc-i-1,argv+i+1,al)) \
65 goto badopt
66 #define check_bool(olen,var) switch (argv[i][olen]) { \
67 case '\0': var = !var; break; \
68 case 'y': case 'Y': case 't': case 'T': \
69 case '+': case '1': var = 1; break; \
70 case 'n': case 'N': case 'f': case 'F': \
71 case '-': case '0': var = 0; break; \
72 default: goto badopt; }
73 char **tralp = NULL;
74 int rval;
75 int i;
76 /* global program name */
77 progname = argv[0];
78 /* feature check only? */
79 strcat(RFeatureList, RXTRACE_FEATURES);
80 if (argc > 1 && !strcmp(argv[1], "-features"))
81 return feature_status(argc-2, argv+2);
82 /* initialize calcomp routines */
83 initfunc();
84 /* add trace notify function */
85 for (i = 0; addobjnotify[i] != NULL; i++)
86 ;
87 addobjnotify[i] = tranotify;
88 /* option city */
89 for (i = 1; i < argc; i++) {
90 /* expand arguments */
91 while ((rval = expandarg(&argc, &argv, i)) > 0)
92 ;
93 if (rval < 0) {
94 sprintf(errmsg, "cannot expand '%s'", argv[i]);
95 error(SYSTEM, errmsg);
96 }
97 if (argv[i] == NULL || argv[i][0] != '-')
98 break; /* break from options */
99 if (!strcmp(argv[i], "-version")) {
100 puts(VersionID);
101 quit(0);
102 }
103 if (!strcmp(argv[i], "-defaults") ||
104 !strcmp(argv[i], "-help")) {
105 printdefaults();
106 quit(0);
107 }
108 rval = getrenderopt(argc-i, argv+i);
109 if (rval >= 0) {
110 i += rval;
111 continue;
112 }
113 switch (argv[i][1]) {
114 case 'n': /* number of cores */
115 check(2,"i");
116 nproc = atoi(argv[++i]);
117 break;
118 case 'x': /* x resolution */
119 check(2,"i");
120 hresolu = atoi(argv[++i]);
121 break;
122 case 'y': /* y resolution */
123 check(2,"i");
124 vresolu = atoi(argv[++i]);
125 break;
126 case 'w': /* warnings */
127 rval = erract[WARNING].pf != NULL;
128 check_bool(2,rval);
129 if (rval) erract[WARNING].pf = wputs;
130 else erract[WARNING].pf = NULL;
131 break;
132 case 'e': /* error file */
133 check(2,"s");
134 errfile = argv[++i];
135 break;
136 case 'l': /* limit distance */
137 if (argv[i][2] != 'd')
138 goto badopt;
139 rval = myRTmanager.rtFlags & RTlimDist;
140 check_bool(3,rval);
141 if (rval) myRTmanager.rtFlags |= RTlimDist;
142 else myRTmanager.rtFlags &= ~RTlimDist;
143 break;
144 case 'I': /* immed. irradiance */
145 rval = myRTmanager.rtFlags & RTimmIrrad;
146 check_bool(2,rval);
147 if (rval) myRTmanager.rtFlags |= RTimmIrrad;
148 else myRTmanager.rtFlags &= ~RTimmIrrad;
149 break;
150 case 'f': /* format i/o */
151 switch (argv[i][2]) {
152 case 'a': /* ascii */
153 case 'f': /* float */
154 case 'd': /* double */
155 inform = argv[i][2];
156 break;
157 default:
158 goto badopt;
159 }
160 switch (argv[i][3]) {
161 case '\0':
162 outform = inform;
163 break;
164 case 'a': /* ascii */
165 case 'f': /* float */
166 case 'd': /* double */
167 case 'c': /* color */
168 check(4,"");
169 outform = argv[i][3];
170 break;
171 default:
172 goto badopt;
173 }
174 break;
175 case 'o': /* output */
176 outvals = argv[i]+2;
177 break;
178 case 'h': /* header output */
179 check_bool(2,doheader);
180 break;
181 case 't': /* trace */
182 switch (argv[i][2]) {
183 case 'i': /* include */
184 case 'I':
185 check(3,"s");
186 if (traincl != 1) {
187 traincl = 1;
188 tralp = tralist;
189 }
190 if (argv[i][2] == 'I') { /* file */
191 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
192 getpath(argv[++i],getrlibpath(),R_OK));
193 if (rval < 0) {
194 sprintf(errmsg,
195 "cannot open trace include file \"%s\"",
196 argv[i]);
197 error(SYSTEM, errmsg);
198 }
199 tralp += rval;
200 } else {
201 *tralp++ = argv[++i];
202 *tralp = NULL;
203 }
204 break;
205 case 'e': /* exclude */
206 case 'E':
207 check(3,"s");
208 if (traincl != 0) {
209 traincl = 0;
210 tralp = tralist;
211 }
212 if (argv[i][2] == 'E') { /* file */
213 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
214 getpath(argv[++i],getrlibpath(),R_OK));
215 if (rval < 0) {
216 sprintf(errmsg,
217 "cannot open trace exclude file \"%s\"",
218 argv[i]);
219 error(SYSTEM, errmsg);
220 }
221 tralp += rval;
222 } else {
223 *tralp++ = argv[++i];
224 *tralp = NULL;
225 }
226 break;
227 default:
228 goto badopt;
229 }
230 break;
231 case 'p': /* value output */
232 switch (argv[i][2]) {
233 case 'R': /* standard RGB output */
234 if (strcmp(argv[i]+2, "RGB"))
235 goto badopt;
236 out_prims = stdprims;
237 out_scalefactor = 1;
238 sens_curve = NULL;
239 break;
240 case 'X': /* XYZ output */
241 if (strcmp(argv[i]+2, "XYZ"))
242 goto badopt;
243 out_prims = xyzprims;
244 out_scalefactor = WHTEFFICACY;
245 sens_curve = NULL;
246 break;
247 case 'c': {
248 int j;
249 check(3,"ffffffff");
250 rval = 0;
251 for (j = 0; j < 8; j++) {
252 our_prims[0][j] = atof(argv[++i]);
253 rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
254 }
255 if (rval) {
256 if (!colorprimsOK(our_prims))
257 error(USER, "illegal primary chromaticities");
258 out_prims = our_prims;
259 } else
260 out_prims = stdprims;
261 out_scalefactor = 1;
262 sens_curve = NULL;
263 } break;
264 case 'Y': /* photopic response */
265 if (argv[i][3])
266 goto badopt;
267 sens_curve = scolor_photopic;
268 out_scalefactor = WHTEFFICACY;
269 break;
270 case 'S': /* scotopic response */
271 if (argv[i][3])
272 goto badopt;
273 sens_curve = scolor_scotopic;
274 out_scalefactor = WHTSCOTOPIC;
275 break;
276 case 'M': /* melanopic response */
277 if (argv[i][3])
278 goto badopt;
279 sens_curve = scolor_melanopic;
280 out_scalefactor = WHTMELANOPIC;
281 break;
282 default:
283 goto badopt;
284 }
285 break;
286 #if MAXCSAMP>3
287 case 'c': /* output spectral results */
288 if (argv[i][2] != 'o')
289 goto badopt;
290 rval = (out_prims == NULL) & (sens_curve == NULL);
291 check_bool(3,rval);
292 if (rval) {
293 out_prims = NULL;
294 sens_curve = NULL;
295 } else if (out_prims == NULL)
296 out_prims = stdprims;
297 break;
298 #endif
299 default:
300 goto badopt;
301 }
302 }
303 /* set/check spectral sampling */
304 rval = setspectrsamp(CNDX, WLPART);
305 if (rval < 0)
306 error(USER, "unsupported spectral sampling");
307 if (sens_curve != NULL)
308 out_prims = NULL;
309 else if (out_prims != NULL) {
310 if (!rval)
311 error(WARNING, "spectral range incompatible with color output");
312 } else if (NCSAMP == 3)
313 out_prims = stdprims; /* 3 samples do not a spectrum make */
314 /* set up signal handling */
315 sigdie(SIGINT, "Interrupt");
316 #ifdef SIGHUP
317 sigdie(SIGHUP, "Hangup");
318 #endif
319 sigdie(SIGTERM, "Terminate");
320 #ifdef SIGPIPE
321 sigdie(SIGPIPE, "Broken pipe");
322 #endif
323 #ifdef SIGALRM
324 sigdie(SIGALRM, "Alarm clock");
325 #endif
326 #ifdef SIGXCPU
327 sigdie(SIGXCPU, "CPU limit exceeded");
328 sigdie(SIGXFSZ, "File size exceeded");
329 #endif
330 /* open error file */
331 if (errfile != NULL) {
332 if (freopen(errfile, "a", stderr) == NULL)
333 quit(2);
334 fprintf(stderr, "**************\n*** PID %5d: ",
335 getpid());
336 printargs(argc, argv, stderr);
337 putc('\n', stderr);
338 fflush(stderr);
339 }
340 #ifdef NICE
341 nice(NICE); /* lower priority */
342 #endif
343 /* get octree name */
344 if (i == argc)
345 error(USER, "missing octree argument");
346 if (i != argc-1)
347 goto badopt;
348 /* set output options */
349 rval = setrtoutput(outvals);
350 /* load octree */
351 if (!myRTmanager.LoadOctree(argv[i]))
352 quit(1);
353 /* set up output */
354 if (outform != 'a')
355 SET_FILE_BINARY(stdout);
356 if (doheader) { /* print header? */
357 newheader("RADIANCE", stdout);
358 fputs(myRTmanager.GetHeadStr(), stdout);
359 printargs(i, argv, stdout);
360 printf("SOFTWARE= %s\n", VersionID);
361 fputnow(stdout);
362 if (rval > 0) /* saved from setrtoutput() call */
363 fputncomp(rval, stdout);
364 if (NCSAMP > 3)
365 fputwlsplit(WLPART, stdout);
366 if ((out_prims != stdprims) & (out_prims != NULL))
367 fputprims(out_prims, stdout);
368 if ((outform == 'f') | (outform == 'd'))
369 fputendian(stdout);
370 fputformat(formstr(outform), stdout);
371 fputc('\n', stdout); /* end of header */
372 }
373 rtrace(NULL, nproc); /* trace rays */
374 quit(0); /* clean up & exit */
375
376 badopt:
377 sprintf(errmsg, "command line error at '%s'", argv[i]);
378 error(USER, errmsg);
379 return 1; /* pro forma return */
380
381 #undef check
382 #undef check_bool
383 }
384
385 void
386 wputs( /* warning output function */
387 char *s
388 )
389 {
390 int lasterrno = errno;
391 eputs(s);
392 errno = lasterrno;
393 }
394
395 void
396 eputs( /* put string to stderr */
397 const char *s
398 )
399 {
400 static int midline = 0;
401
402 if (!*s)
403 return;
404 if (!midline++) {
405 fputs(progname, stderr);
406 fputs(": ", stderr);
407 }
408 fputs(s, stderr);
409 if (s[strlen(s)-1] == '\n') {
410 fflush(stderr);
411 midline = 0;
412 }
413 }
414
415 static void
416 onsig( /* fatal signal */
417 int signo
418 )
419 {
420 static int gotsig = 0;
421
422 if (gotsig++) /* two signals and we're gone! */
423 _exit(signo);
424
425 #ifdef SIGALRM
426 alarm(15); /* allow 15 seconds to clean up */
427 signal(SIGALRM, SIG_DFL); /* make certain we do die */
428 #endif
429 eputs("signal - ");
430 eputs(sigerr[signo]);
431 eputs("\n");
432 quit(3);
433 }
434
435 static void
436 sigdie( /* set fatal signal */
437 int signo,
438 const char *msg
439 )
440 {
441 if (signal(signo, onsig) == SIG_IGN)
442 signal(signo, SIG_IGN);
443 sigerr[signo] = msg;
444 }
445
446 static void
447 printdefaults(void) /* print default values to stdout */
448 {
449 const char *cp;
450
451 if (myRTmanager.rtFlags & RTimmIrrad)
452 printf("-I+\t\t\t\t# immediate irradiance on\n");
453 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
454 printf("-x %-9d\t\t\t# %s\n", hresolu,
455 vresolu && hresolu ? "x resolution" : "flush interval");
456 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
457 printf(myRTmanager.rtFlags&RTlimDist ? "-ld+\t\t\t\t# limit distance on\n" :
458 "-ld-\t\t\t\t# limit distance off\n");
459 printf("-h%c\t\t\t\t# %s header\n", doheader ? '+' : '-',
460 doheader ? "output" : "no");
461 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
462 inform, outform, formstr(inform), formstr(outform));
463 printf("-o%-9s\t\t\t# output", outvals);
464 for (cp = outvals; *cp; cp++)
465 switch (*cp) {
466 case 't': case 'T': printf(" trace"); break;
467 case 'o': printf(" origin"); break;
468 case 'd': printf(" direction"); break;
469 case 'r': printf(" reflect_contrib"); break;
470 case 'R': printf(" reflect_length"); break;
471 case 'x': printf(" unreflect_contrib"); break;
472 case 'X': printf(" unreflect_length"); break;
473 case 'v': printf(" value"); break;
474 case 'V': printf(" contribution"); break;
475 case 'l': printf(" length"); break;
476 case 'L': printf(" first_length"); break;
477 case 'p': printf(" point"); break;
478 case 'n': printf(" normal"); break;
479 case 'N': printf(" unperturbed_normal"); break;
480 case 's': printf(" surface"); break;
481 case 'w': printf(" weight"); break;
482 case 'W': printf(" coefficient"); break;
483 case 'm': printf(" modifier"); break;
484 case 'M': printf(" material"); break;
485 case '~': printf(" tilde"); break;
486 }
487 putchar('\n');
488 if (sens_curve == scolor_photopic)
489 printf("-pY\t\t\t\t# photopic output\n");
490 else if (sens_curve == scolor_scotopic)
491 printf("-pS\t\t\t\t# scotopic output\n");
492 else if (sens_curve == scolor_melanopic)
493 printf("-pM\t\t\t\t# melanopic output\n");
494 else if (out_prims == stdprims)
495 printf("-pRGB\t\t\t\t# standard RGB color output\n");
496 else if (out_prims == xyzprims)
497 printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
498 else if (out_prims != NULL)
499 printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
500 out_prims[RED][0], out_prims[RED][1],
501 out_prims[GRN][0], out_prims[GRN][1],
502 out_prims[BLU][0], out_prims[BLU][1],
503 out_prims[WHT][0], out_prims[WHT][1]);
504 if ((sens_curve == NULL) & (NCSAMP > 3))
505 printf(out_prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
506 "-co+\t\t\t\t# output spectral values\n");
507 printf(erract[WARNING].pf != NULL ?
508 "-w+\t\t\t\t# warning messages on\n" :
509 "-w-\t\t\t\t# warning messages off\n");
510 print_rdefaults();
511 }
