| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rxpmain.cpp,v 2.7 2025/01/02 20:19:48 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rxpmain.cpp - main for rxpict batch rendering program
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <time.h>
| 11 |
#include <signal.h>
| 12 |
| 13 |
#include "rtprocess.h" /* getpid() */
| 14 |
#include "platform.h"
| 15 |
#include "RpictSimulManager.h"
| 16 |
#include "func.h"
| 17 |
| 18 |
extern char *progname; /* argv[0] */
| 19 |
const char *sigerr[NSIG]; /* signal error messages */
| 20 |
char *errfile = NULL; /* error output file */
| 21 |
| 22 |
VIEW ourview = STDVIEW; /* view parameters */
| 23 |
int hresolu = 512; /* horizontal resolution */
| 24 |
int vresolu = 512; /* vertical resolution */
| 25 |
double pixaspect = 1.0; /* pixel aspect ratio */
| 26 |
int hres, vres; /* current image resolution for srcdraw.c */
| 27 |
| 28 |
int psample = 4; /* pixel sample size */
| 29 |
double maxdiff = .05; /* max. difference for interpolation */
| 30 |
double dstrpix = 0.67; /* square pixel distribution */
| 31 |
| 32 |
double mblur = 0.; /* motion blur parameter */
| 33 |
| 34 |
double dblur = 0.; /* depth-of-field blur parameter */
| 35 |
| 36 |
int nproc = 1; /* number of processes to run */
| 37 |
| 38 |
int ralrm = 0; /* seconds between reports */
| 39 |
| 40 |
double pctdone = 0.0; /* percentage done */
| 41 |
time_t tlastrept = 0L; /* time at last report */
| 42 |
time_t tstart; /* starting time */
| 43 |
| 44 |
RenderDataType dtype = RDTrgbe; // output data flags
| 45 |
| 46 |
RpictSimulManager myRPmanager; // global simulation manager
| 47 |
| 48 |
static void onsig(int signo);
| 49 |
static void sigdie(int signo, const char *msg);
| 50 |
static void printdefaults(void);
| 51 |
| 52 |
/* rxpict additional features */
| 53 |
#define RXPICT_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
| 54 |
"ParticipatingMedia=Mist\n" \
| 55 |
"HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
| 56 |
"PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
| 57 |
"SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
| 58 |
"AdaptiveShadowTesting\nOutputs=v,l\n" \
| 59 |
"OutputCS=RGB,XYZ,prims,spec\n"
| 60 |
| 61 |
void
| 62 |
quit(int code) /* quit program */
| 63 |
| 64 |
exit(code); // don't bother about freeing anything
| 65 |
| 66 |
| 67 |
/* Set default options */
| 68 |
static void
| 69 |
default_options(void)
| 70 |
| 71 |
shadthresh = .05;
| 72 |
shadcert = .5;
| 73 |
srcsizerat = .25;
| 74 |
directrelay = 1;
| 75 |
ambacc = 0.2;
| 76 |
ambres = 64;
| 77 |
ambdiv = 512;
| 78 |
ambssamp = 128;
| 79 |
maxdepth = 7;
| 80 |
| 81 |
| 82 |
int
| 83 |
main(int argc, char *argv[])
| 84 |
| 85 |
#define check(ol,al) if (argv[i][ol] || \
| 86 |
badarg(argc-i-1,argv+i+1,al)) \
| 87 |
goto badopt
| 88 |
#define check_bool(olen,var) switch (argv[i][olen]) { \
| 89 |
case '\0': var = !var; break; \
| 90 |
case 'y': case 'Y': case 't': case 'T': \
| 91 |
case '+': case '1': var = 1; break; \
| 92 |
case 'n': case 'N': case 'f': case 'F': \
| 93 |
case '-': case '0': var = 0; break; \
| 94 |
default: goto badopt; }
| 95 |
RGBPRIMS our_prims; /* private output color primitives */
| 96 |
int seqstart = 0;
| 97 |
char *recover = NULL;
| 98 |
char *outfile = NULL;
| 99 |
char *zfile = NULL;
| 100 |
int outfmt = 'c';
| 101 |
int rval;
| 102 |
int i;
| 103 |
/* record start time */
| 104 |
tstart = time(NULL);
| 105 |
/* global program name */
| 106 |
progname = argv[0];
| 107 |
/* feature check only? */
| 108 |
strcat(RFeatureList, RXPICT_FEATURES);
| 109 |
if (argc > 1 && !strcmp(argv[1], "-features"))
| 110 |
return feature_status(argc-2, argv+2);
| 111 |
/* initialize calcomp routines */
| 112 |
initfunc();
| 113 |
/* set defaults */
| 114 |
default_options();
| 115 |
/* option city */
| 116 |
for (i = 1; i < argc; i++) {
| 117 |
/* expand arguments */
| 118 |
while ((rval = expandarg(&argc, &argv, i)) > 0)
| 119 |
| 120 |
if (rval < 0) {
| 121 |
sprintf(errmsg, "cannot expand '%s'", argv[i]);
| 122 |
error(SYSTEM, errmsg);
| 123 |
| 124 |
if (argv[i] == NULL || argv[i][0] != '-')
| 125 |
break; /* break from options */
| 126 |
if (!strcmp(argv[i], "-version")) {
| 127 |
puts(VersionID);
| 128 |
quit(0);
| 129 |
| 130 |
if (!strcmp(argv[i], "-defaults") ||
| 131 |
!strcmp(argv[i], "-help")) {
| 132 |
printdefaults();
| 133 |
quit(0);
| 134 |
| 135 |
rval = getrenderopt(argc-i, argv+i);
| 136 |
if (rval >= 0) {
| 137 |
i += rval;
| 138 |
continue;
| 139 |
| 140 |
rval = getviewopt(&ourview, argc-i, argv+i);
| 141 |
if (rval >= 0) {
| 142 |
i += rval;
| 143 |
continue;
| 144 |
| 145 |
/* rxpict options */
| 146 |
switch (argv[i][1]) {
| 147 |
case 'v': /* view file */
| 148 |
if (argv[i][2] != 'f')
| 149 |
goto badopt;
| 150 |
check(3,"s");
| 151 |
rval = viewfile(argv[++i], &ourview, NULL);
| 152 |
if (rval < 0) {
| 153 |
sprintf(errmsg,
| 154 |
"cannot open view file \"%s\"",
| 155 |
argv[i]);
| 156 |
| 157 |
} else if (rval == 0) {
| 158 |
sprintf(errmsg,
| 159 |
"bad view file \"%s\"",
| 160 |
argv[i]);
| 161 |
error(USER, errmsg);
| 162 |
| 163 |
break;
| 164 |
case 'n': /* number of processes */
| 165 |
check(2,"i");
| 166 |
nproc = atoi(argv[++i]);
| 167 |
if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0)
| 168 |
nproc = 1;
| 169 |
break;
| 170 |
case 'f': /* output format */
| 171 |
if ((argv[i][2] != 'c') & (argv[i][2] != 'f')
| 172 |
|| argv[i][3])
| 173 |
goto badopt;
| 174 |
outfmt = argv[i][2];
| 175 |
break;
| 176 |
case 'p': /* pixel */
| 177 |
switch (argv[i][2]) {
| 178 |
case 's': /* sample */
| 179 |
check(3,"i");
| 180 |
psample = atoi(argv[++i]);
| 181 |
if (psample < 1) psample = 1;
| 182 |
break;
| 183 |
case 't': /* threshold */
| 184 |
check(3,"f");
| 185 |
maxdiff = atof(argv[++i]);
| 186 |
break;
| 187 |
case 'j': /* jitter */
| 188 |
check(3,"f");
| 189 |
dstrpix = atof(argv[++i]);
| 190 |
break;
| 191 |
case 'a': /* aspect */
| 192 |
check(3,"f");
| 193 |
pixaspect = atof(argv[++i]);
| 194 |
break;
| 195 |
case 'm': /* motion */
| 196 |
check(3,"f");
| 197 |
mblur = atof(argv[++i]);
| 198 |
mblur *= (mblur > 0);
| 199 |
break;
| 200 |
case 'd': /* aperture */
| 201 |
check(3,"f");
| 202 |
dblur = atof(argv[++i]);
| 203 |
dblur *= (dblur > 0);
| 204 |
break;
| 205 |
case 'R': /* standard RGB output */
| 206 |
if (strcmp(argv[i]+2, "RGB"))
| 207 |
goto badopt;
| 208 |
myRPmanager.prims = stdprims;
| 209 |
dtype = RDTnewCT(dtype, RDTrgbe);
| 210 |
break;
| 211 |
case 'X': /* XYZ output */
| 212 |
if (strcmp(argv[i]+2, "XYZ"))
| 213 |
goto badopt;
| 214 |
myRPmanager.prims = xyzprims;
| 215 |
dtype = RDTnewCT(dtype, RDTxyze);
| 216 |
break;
| 217 |
case 'c': /* chromaticities */
| 218 |
check(3,"ffffffff");
| 219 |
rval = 0;
| 220 |
for (int j = 0; j < 8; j++) {
| 221 |
our_prims[0][j] = atof(argv[++i]);
| 222 |
rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
| 223 |
| 224 |
if (rval) {
| 225 |
if (!colorprimsOK(our_prims))
| 226 |
error(USER, "illegal primary chromaticities");
| 227 |
myRPmanager.prims = our_prims;
| 228 |
} else
| 229 |
| 230 |
| 231 |
break;
| 232 |
default:
| 233 |
goto badopt;
| 234 |
| 235 |
break;
| 236 |
case 'd': /* reference depth */
| 237 |
if (argv[i][2] || !myRPmanager.SetReferenceDepth(argv[++i]))
| 238 |
goto badopt;
| 239 |
dtype = RDTnewDT(dtype, RDTdshort);
| 240 |
break;
| 241 |
case 'x': /* x resolution */
| 242 |
check(2,"i");
| 243 |
hresolu = atoi(argv[++i]);
| 244 |
break;
| 245 |
case 'y': /* y resolution */
| 246 |
check(2,"i");
| 247 |
vresolu = atoi(argv[++i]);
| 248 |
break;
| 249 |
case 'S': /* start index */
| 250 |
check(2,"i");
| 251 |
seqstart = atoi(argv[++i]);
| 252 |
seqstart *= (seqstart > 0);
| 253 |
break;
| 254 |
case 'o': /* output file */
| 255 |
check(2,"s");
| 256 |
outfile = argv[++i];
| 257 |
break;
| 258 |
case 'z': /* z file */
| 259 |
check(2,"s");
| 260 |
zfile = argv[++i];
| 261 |
break;
| 262 |
case 'r': /* recover file */
| 263 |
if (argv[i][2] == 'o') { /* +output */
| 264 |
check(3,"s");
| 265 |
outfile = argv[i+1];
| 266 |
} else
| 267 |
check(2,"s");
| 268 |
recover = argv[++i];
| 269 |
break;
| 270 |
#if MAXCSAMP>3
| 271 |
case 'c': /* output spectral results */
| 272 |
if (argv[i][2] != 'o')
| 273 |
goto badopt;
| 274 |
rval = (myRPmanager.prims == NULL);
| 275 |
check_bool(3,rval);
| 276 |
if (rval)
| 277 |
myRPmanager.prims = NULL;
| 278 |
else if (myRPmanager.prims == NULL)
| 279 |
| 280 |
dtype = RDTnewCT(dtype, rval ? RDTscolr : RDTrgbe);
| 281 |
break;
| 282 |
#endif
| 283 |
case 't': /* timer */
| 284 |
check(2,"i");
| 285 |
ralrm = atoi(argv[++i]);
| 286 |
break;
| 287 |
case 'w': /* warnings */
| 288 |
rval = erract[WARNING].pf != NULL;
| 289 |
check_bool(2,rval);
| 290 |
if (rval) erract[WARNING].pf = wputs;
| 291 |
else erract[WARNING].pf = NULL;
| 292 |
break;
| 293 |
case 'e': /* error file */
| 294 |
check(2,"s");
| 295 |
errfile = argv[++i];
| 296 |
break;
| 297 |
default:
| 298 |
goto badopt;
| 299 |
| 300 |
| 301 |
if (maxdiff <= FTINY) /* check for useless sampling */
| 302 |
psample = 1;
| 303 |
if (zfile == NULL) /* set up depth output */
| 304 |
dtype = RDTnewDT(dtype, RDTnone);
| 305 |
else if (!RDTdepthT(dtype))
| 306 |
dtype = RDTnewDT(dtype, RDTdfloat);
| 307 |
/* check pixel output type */
| 308 |
if ((myRPmanager.prims == NULL) & (NCSAMP == 3)) {
| 309 |
| 310 |
| 311 |
| 312 |
if (outfmt == 'f')
| 313 |
switch (RDTcolorT(dtype)) {
| 314 |
case RDTrgbe:
| 315 |
dtype = RDTnewCT(dtype, RDTrgb);
| 316 |
break;
| 317 |
case RDTxyze:
| 318 |
dtype = RDTnewCT(dtype, RDTxyz);
| 319 |
break;
| 320 |
case RDTscolr:
| 321 |
dtype = RDTnewCT(dtype, RDTscolor);
| 322 |
break;
| 323 |
case RDTrgb:
| 324 |
case RDTxyz:
| 325 |
case RDTscolor:
| 326 |
break;
| 327 |
default:
| 328 |
error(INTERNAL, "botched color output type");
| 329 |
| 330 |
/* set up signal handling */
| 331 |
sigdie(SIGINT, "Interrupt");
| 332 |
#ifdef SIGHUP
| 333 |
sigdie(SIGHUP, "Hangup");
| 334 |
#endif
| 335 |
sigdie(SIGTERM, "Terminate");
| 336 |
#ifdef SIGPIPE
| 337 |
sigdie(SIGPIPE, "Broken pipe");
| 338 |
#endif
| 339 |
#ifdef SIGALRM
| 340 |
sigdie(SIGALRM, "Alarm clock");
| 341 |
#endif
| 342 |
#ifdef SIGXCPU
| 343 |
sigdie(SIGXCPU, "CPU limit exceeded");
| 344 |
sigdie(SIGXFSZ, "File size exceeded");
| 345 |
#endif
| 346 |
/* open error file */
| 347 |
if (errfile != NULL) {
| 348 |
if (freopen(errfile, "a", stderr) == NULL)
| 349 |
quit(2);
| 350 |
fprintf(stderr, "**************\n*** PID %5d: ",
| 351 |
getpid());
| 352 |
printargs(argc, argv, stderr);
| 353 |
putc('\n', stderr);
| 354 |
fflush(stderr);
| 355 |
| 356 |
#ifdef NICE
| 357 |
nice(NICE); /* lower priority */
| 358 |
#endif
| 359 |
if (i < argc-1)
| 360 |
goto badopt;
| 361 |
// load octree
| 362 |
if (!myRPmanager.LoadOctree(argv[i]))
| 363 |
error(USER, "missing octree argument");
| 364 |
// add new header info
| 365 |
myRPmanager.AddHeader(i, argv);
| 366 |
| 367 |
char buf[128] = "SOFTWARE= ";
| 368 |
strcpy(buf+10, VersionID);
| 369 |
myRPmanager.AddHeader(buf);
| 370 |
| 371 |
// start our engines
| 372 |
nproc = myRPmanager.SetThreadCount(nproc);
| 373 |
// batch render picture(s)
| 374 |
rpict(seqstart, outfile, zfile, recover);
| 375 |
| 376 |
quit(0); // clean up and exit
| 377 |
| 378 |
badopt:
| 379 |
sprintf(errmsg, "command line error at '%s'", argv[i]);
| 380 |
| 381 |
return 1; /* pro forma return */
| 382 |
| 383 |
#undef check
| 384 |
#undef check_bool
| 385 |
| 386 |
| 387 |
| 388 |
void
| 389 |
wputs( /* warning output function */
| 390 |
const char *s
| 391 |
| 392 |
| 393 |
int lasterrno = errno;
| 394 |
eputs(s);
| 395 |
errno = lasterrno;
| 396 |
| 397 |
| 398 |
| 399 |
void
| 400 |
eputs( /* put string to stderr */
| 401 |
const char *s
| 402 |
| 403 |
| 404 |
static int midline = 0;
| 405 |
| 406 |
if (!*s)
| 407 |
return;
| 408 |
if (!midline++) {
| 409 |
fputs(progname, stderr);
| 410 |
fputs(": ", stderr);
| 411 |
| 412 |
fputs(s, stderr);
| 413 |
if (s[strlen(s)-1] == '\n') {
| 414 |
fflush(stderr);
| 415 |
midline = 0;
| 416 |
| 417 |
| 418 |
| 419 |
| 420 |
static void
| 421 |
onsig( /* fatal signal */
| 422 |
int signo
| 423 |
| 424 |
| 425 |
static int gotsig = 0;
| 426 |
| 427 |
if (gotsig++) /* two signals and we're gone! */
| 428 |
_exit(signo);
| 429 |
| 430 |
#ifdef SIGALRM /* XXX how critical is this? */
| 431 |
alarm(30); /* allow 30 seconds to clean up */
| 432 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */
| 433 |
#endif
| 434 |
eputs("signal - ");
| 435 |
eputs(sigerr[signo]);
| 436 |
eputs("\n");
| 437 |
quit(3);
| 438 |
| 439 |
| 440 |
| 441 |
static void
| 442 |
sigdie( /* set fatal signal */
| 443 |
int signo,
| 444 |
const char *msg
| 445 |
| 446 |
| 447 |
if (signal(signo, onsig) == SIG_IGN)
| 448 |
signal(signo, SIG_IGN);
| 449 |
sigerr[signo] = msg;
| 450 |
| 451 |
| 452 |
| 453 |
static void
| 454 |
printdefaults(void) /* print default values to stdout */
| 455 |
| 456 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
| 457 |
printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
| 458 |
ourview.type==VT_PER ? "perspective" :
| 459 |
ourview.type==VT_PAR ? "parallel" :
| 460 |
ourview.type==VT_HEM ? "hemispherical" :
| 461 |
ourview.type==VT_ANG ? "angular" :
| 462 |
ourview.type==VT_CYL ? "cylindrical" :
| 463 |
ourview.type==VT_PLS ? "planisphere" :
| 464 |
"unknown");
| 465 |
printf("-vp %f %f %f\t# view point\n",
| 466 |
ourview.vp[0], ourview.vp[1], ourview.vp[2]);
| 467 |
printf("-vd %f %f %f\t# view direction\n",
| 468 |
ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
| 469 |
printf("-vu %f %f %f\t# view up\n",
| 470 |
ourview.vup[0], ourview.vup[1], ourview.vup[2]);
| 471 |
printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
| 472 |
printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
| 473 |
printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
| 474 |
printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
| 475 |
printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
| 476 |
printf("-vl %f\t\t\t# view lift\n", ourview.voff);
| 477 |
printf("-x %-9d\t\t\t# x resolution\n", hresolu);
| 478 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu);
| 479 |
if (myRPmanager.prims == stdprims)
| 480 |
printf("-pRGB\t\t\t\t# standard RGB color output\n");
| 481 |
else if (myRPmanager.prims == xyzprims)
| 482 |
printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
| 483 |
else if (myRPmanager.prims != NULL)
| 484 |
printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
| 485 |
myRPmanager.prims[RED][0], myRPmanager.prims[RED][1],
| 486 |
myRPmanager.prims[GRN][0], myRPmanager.prims[GRN][1],
| 487 |
myRPmanager.prims[BLU][0], myRPmanager.prims[BLU][1],
| 488 |
myRPmanager.prims[WHT][0], myRPmanager.prims[WHT][1]);
| 489 |
if (NCSAMP > 3)
| 490 |
printf(myRPmanager.prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
| 491 |
"-co+\t\t\t\t# output spectral values\n");
| 492 |
printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
| 493 |
printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
| 494 |
printf("-pm %f\t\t\t# pixel motion\n", mblur);
| 495 |
printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
| 496 |
printf("-ps %-9d\t\t\t# pixel sample\n", psample);
| 497 |
printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
| 498 |
printf("-t %-9d\t\t\t# time between reports\n", ralrm);
| 499 |
printf(erract[WARNING].pf != NULL ?
| 500 |
"-w+\t\t\t\t# warning messages on\n" :
| 501 |
"-w-\t\t\t\t# warning messages off\n");
| 502 |
print_rdefaults();
| 503 |
| 504 |
| 505 |
| 506 |
// my progress report call-back
| 507 |
static void
| 508 |
progReporter(double pct)
| 509 |
| 510 |
static time_t lastReportTime = 0;
| 511 |
time_t tnow = time(NULL);
| 512 |
| 513 |
if (pct < 100.-FTINY && tnow - lastReportTime < ralrm)
| 514 |
return; // too soon, my Precious...
| 515 |
| 516 |
sprintf(errmsg, "%7.3f%% done after %7.3f hours\n", pct, (tnow-tstart)/3600.);
| 517 |
eputs(errmsg);
| 518 |
// reset timer at 100%
| 519 |
lastReportTime = tnow * (pct < 100.-FTINY);
| 520 |
| 521 |
| 522 |
| 523 |
// Principal function for rpict execution (prototype in ray.h for some reason)
| 524 |
void
| 525 |
rpict(int seq, char *pout, char *zout, char *prvr)
| 526 |
| 527 |
* If seq is greater than zero, we will render a sequence of
| 528 |
* images based on view parameter strings read from the standard input.
| 529 |
* If pout is NULL, then all images will be sent to the standard ouput.
| 530 |
* If seq is greater than zero and prvr is an integer, then it is the
| 531 |
* frame number at which rendering should begin. Preceeding view parameter
| 532 |
* strings will be skipped in the input.
| 533 |
* Note that pout and zout should contain %d format specifications for
| 534 |
* sequenced file naming.
| 535 |
| 536 |
| 537 |
char fbuf[256], dbuf[256];
| 538 |
| 539 |
if (!zout ^ !RDTdepthT(dtype))
| 540 |
error(INTERNAL, "output depth type requires spec and vice versa");
| 541 |
| 542 |
if (prvr && isint(prvr)) { // sequence recovery?
| 543 |
if (!seq)
| 544 |
error(USER, "sequence recovery requires starting frame");
| 545 |
if (!pout)
| 546 |
error(USER, "need output spec for sequence recovery");
| 547 |
int rno = atoi(prvr);
| 548 |
if (rno < seq)
| 549 |
error(USER, "recovery frame before starting frame");
| 550 |
while (seq <= rno) {
| 551 |
if (!fgets(fbuf, sizeof(fbuf), stdin))
| 552 |
error(USER, "recovery frame past end of sequence");
| 553 |
seq += (isview(fbuf) && sscanview(&ourview, fbuf) > 0);
| 554 |
| 555 |
sprintf(prvr=fbuf, pout, rno);
| 556 |
| 557 |
if (ralrm > 0)
| 558 |
myRPmanager.prCB = progReporter;
| 559 |
else
| 560 |
myRPmanager.prCB = NULL;
| 561 |
if (prvr) { // recovering partial render?
| 562 |
if ((seq > 0) & (prvr != fbuf))
| 563 |
error(USER, "recover spec must be number in sequence");
| 564 |
if (zout) sprintf(dbuf, zout, seq);
| 565 |
if (ralrm > 0) {
| 566 |
sprintf(errmsg, "resuming partial rendering '%s'\n", prvr);
| 567 |
eputs(errmsg);
| 568 |
| 569 |
dtype = myRPmanager.ResumeFrame(prvr, zout ? dbuf : zout);
| 570 |
if (!dtype)
| 571 |
error(USER, "ResumeFrame() failed");
| 572 |
if (!seq)
| 573 |
return; // all done if not a sequence
| 574 |
| 575 |
do {
| 576 |
if (prvr) // have view from sequence recovery?
| 577 |
prvr = NULL;
| 578 |
else if (seq) { // else read next view in sequence
| 579 |
while (fgets(fbuf, sizeof(fbuf), stdin))
| 580 |
if (isview(fbuf) && sscanview(&ourview, fbuf) > 0)
| 581 |
break;
| 582 |
if (feof(stdin))
| 583 |
return; // reached end of view input
| 584 |
| 585 |
// get (indexed) output file name(s)
| 586 |
if (pout) sprintf(fbuf, pout, seq);
| 587 |
| 588 |
| 589 |
if (ralrm > 0) { // start report if requested
| 590 |
if (myRPmanager.NThreads() > 1)
| 591 |
sprintf(errmsg, "%2d processes ", myRPmanager.NThreads());
| 592 |
else
| 593 |
sprintf(errmsg, "PID %6d ", getpid());
| 594 |
eputs(errmsg);
| 595 |
if (seq) {
| 596 |
sprintf(errmsg, "rendering frame %5d ", seq);
| 597 |
eputs(errmsg);
| 598 |
} else
| 599 |
eputs("rendering picture ");
| 600 |
if (pout) {
| 601 |
sprintf(errmsg, "to '%s'\n", fbuf);
| 602 |
eputs(errmsg);
| 603 |
} else
| 604 |
eputs("to stdout\n");
| 605 |
if (zout) {
| 606 |
sprintf(errmsg, "\twith %s depth map in '%s'\n",
| 607 |
RDTdepthT(dtype)==RDTdshort ?
| 608 |
"encoded 16-bit" : "raw float",
| 609 |
dbuf);
| 610 |
eputs(errmsg);
| 611 |
| 612 |
| 613 |
// set up view and size
| 614 |
int xydim[2] = {hresolu, vresolu};
| 615 |
if (!myRPmanager.NewFrame(ourview, xydim, &pixaspect))
| 616 |
error(USER, "NewFrame() failed");
| 617 |
| 618 |
myRPmanager.frameNo = seq;
| 619 |
| 620 |
errno = 0; // render frame, skipping if it exists
| 621 |
if (!myRPmanager.RenderFrame(pout ? fbuf : pout, dtype,
| 622 |
zout ? dbuf : zout)
| 623 |
&& !seq | (errno != EEXIST))
| 624 |
error(USER, "RenderFrame() failed");
| 625 |
} while (seq++); // all done if not a sequence
| 626 |
