1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rxpmain.cpp,v 2.2 2024/08/18 17:24:48 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rxpmain.cpp - main for rxpict batch rendering program |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <time.h> |
11 |
#include <signal.h> |
12 |
13 |
#include "rtprocess.h" /* getpid() */ |
14 |
#include "platform.h" |
15 |
#include "RpictSimulManager.h" |
16 |
17 |
extern char *progname; /* argv[0] */ |
18 |
const char *sigerr[NSIG]; /* signal error messages */ |
19 |
char *errfile = NULL; /* error output file */ |
20 |
21 |
VIEW ourview = STDVIEW; /* view parameters */ |
22 |
int hresolu = 512; /* horizontal resolution */ |
23 |
int vresolu = 512; /* vertical resolution */ |
24 |
double pixaspect = 1.0; /* pixel aspect ratio */ |
25 |
int hres, vres; /* current image resolution for srcdraw.c */ |
26 |
27 |
int psample = 4; /* pixel sample size */ |
28 |
double maxdiff = .05; /* max. difference for interpolation */ |
29 |
double dstrpix = 0.67; /* square pixel distribution */ |
30 |
31 |
double mblur = 0.; /* motion blur parameter */ |
32 |
33 |
double dblur = 0.; /* depth-of-field blur parameter */ |
34 |
35 |
int nproc = 1; /* number of processes to run */ |
36 |
37 |
int ralrm = 0; /* seconds between reports */ |
38 |
39 |
double pctdone = 0.0; /* percentage done */ |
40 |
time_t tlastrept = 0L; /* time at last report */ |
41 |
time_t tstart; /* starting time */ |
42 |
43 |
RenderDataType dtype = RDTrgbe; // output data flags |
44 |
45 |
RpictSimulManager myRPmanager; // global simulation manager |
46 |
47 |
static void onsig(int signo); |
48 |
static void sigdie(int signo, const char *msg); |
49 |
static void printdefaults(void); |
50 |
51 |
/* rxpict additional features */ |
52 |
#define RXPICT_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \ |
53 |
"ParticipatingMedia=Mist\n" \ |
54 |
"HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \ |
55 |
"PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \ |
56 |
"SmallSourceDrawing\nViewSequence\nProgressReporting\n" \ |
57 |
"AdaptiveShadowTesting\nOutputs=v,l\n" \ |
58 |
"OutputCS=RGB,XYZ,prims,spec\n" |
59 |
60 |
61 |
void |
62 |
quit(int code) /* quit program */ |
63 |
64 |
if (ray_pnprocs < 0) |
65 |
_exit(code); /* avoid flush in child */ |
66 |
67 |
int ec = myRPmanager.Cleanup(); |
68 |
69 |
if (ec) code = ec; |
70 |
71 |
exit(code); |
72 |
73 |
74 |
75 |
int |
76 |
main(int argc, char *argv[]) |
77 |
78 |
#define check(ol,al) if (argv[i][ol] || \ |
79 |
badarg(argc-i-1,argv+i+1,al)) \ |
80 |
goto badopt |
81 |
#define check_bool(olen,var) switch (argv[i][olen]) { \ |
82 |
case '\0': var = !var; break; \ |
83 |
case 'y': case 'Y': case 't': case 'T': \ |
84 |
case '+': case '1': var = 1; break; \ |
85 |
case 'n': case 'N': case 'f': case 'F': \ |
86 |
case '-': case '0': var = 0; break; \ |
87 |
default: goto badopt; } |
88 |
RGBPRIMS our_prims; /* private output color primitives */ |
89 |
int seqstart = 0; |
90 |
char *recover = NULL; |
91 |
char *outfile = NULL; |
92 |
char *zfile = NULL; |
93 |
int outfmt = 'c'; |
94 |
int rval; |
95 |
int i; |
96 |
/* record start time */ |
97 |
tstart = time(NULL); |
98 |
/* global program name */ |
99 |
progname = argv[0]; |
100 |
/* feature check only? */ |
101 |
strcat(RFeatureList, RXPICT_FEATURES); |
102 |
if (argc > 1 && !strcmp(argv[1], "-features")) |
103 |
return feature_status(argc-2, argv+2); |
104 |
/* option city */ |
105 |
for (i = 1; i < argc; i++) { |
106 |
/* expand arguments */ |
107 |
while ((rval = expandarg(&argc, &argv, i)) > 0) |
108 |
109 |
if (rval < 0) { |
110 |
sprintf(errmsg, "cannot expand '%s'", argv[i]); |
111 |
error(SYSTEM, errmsg); |
112 |
113 |
if (argv[i] == NULL || argv[i][0] != '-') |
114 |
break; /* break from options */ |
115 |
if (!strcmp(argv[i], "-version")) { |
116 |
puts(VersionID); |
117 |
quit(0); |
118 |
119 |
if (!strcmp(argv[i], "-defaults") || |
120 |
!strcmp(argv[i], "-help")) { |
121 |
printdefaults(); |
122 |
quit(0); |
123 |
124 |
rval = getrenderopt(argc-i, argv+i); |
125 |
if (rval >= 0) { |
126 |
i += rval; |
127 |
continue; |
128 |
129 |
rval = getviewopt(&ourview, argc-i, argv+i); |
130 |
if (rval >= 0) { |
131 |
i += rval; |
132 |
continue; |
133 |
134 |
/* rxpict options */ |
135 |
switch (argv[i][1]) { |
136 |
case 'v': /* view file */ |
137 |
if (argv[i][2] != 'f') |
138 |
goto badopt; |
139 |
check(3,"s"); |
140 |
rval = viewfile(argv[++i], &ourview, NULL); |
141 |
if (rval < 0) { |
142 |
sprintf(errmsg, |
143 |
"cannot open view file \"%s\"", |
144 |
argv[i]); |
145 |
146 |
} else if (rval == 0) { |
147 |
sprintf(errmsg, |
148 |
"bad view file \"%s\"", |
149 |
argv[i]); |
150 |
error(USER, errmsg); |
151 |
152 |
break; |
153 |
case 'n': /* number of processes */ |
154 |
check(2,"i"); |
155 |
nproc = atoi(argv[++i]); |
156 |
if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0) |
157 |
nproc = 1; |
158 |
break; |
159 |
case 'f': /* output format */ |
160 |
if ((argv[i][2] != 'c') & (argv[i][2] != 'f') |
161 |
|| argv[i][3]) |
162 |
goto badopt; |
163 |
outfmt = argv[i][2]; |
164 |
break; |
165 |
case 'p': /* pixel */ |
166 |
switch (argv[i][2]) { |
167 |
case 's': /* sample */ |
168 |
check(3,"i"); |
169 |
psample = atoi(argv[++i]); |
170 |
if (psample < 1) psample = 1; |
171 |
break; |
172 |
case 't': /* threshold */ |
173 |
check(3,"f"); |
174 |
maxdiff = atof(argv[++i]); |
175 |
break; |
176 |
case 'j': /* jitter */ |
177 |
check(3,"f"); |
178 |
dstrpix = atof(argv[++i]); |
179 |
break; |
180 |
case 'a': /* aspect */ |
181 |
check(3,"f"); |
182 |
pixaspect = atof(argv[++i]); |
183 |
break; |
184 |
case 'm': /* motion */ |
185 |
check(3,"f"); |
186 |
mblur = atof(argv[++i]); |
187 |
mblur *= (mblur > 0); |
188 |
break; |
189 |
case 'd': /* aperture */ |
190 |
check(3,"f"); |
191 |
dblur = atof(argv[++i]); |
192 |
dblur *= (dblur > 0); |
193 |
break; |
194 |
case 'R': /* standard RGB output */ |
195 |
if (strcmp(argv[i]+2, "RGB")) |
196 |
goto badopt; |
197 |
myRPmanager.prims = stdprims; |
198 |
dtype = RDTnewCT(dtype, RDTrgbe); |
199 |
break; |
200 |
case 'X': /* XYZ output */ |
201 |
if (strcmp(argv[i]+2, "XYZ")) |
202 |
goto badopt; |
203 |
myRPmanager.prims = xyzprims; |
204 |
dtype = RDTnewCT(dtype, RDTxyze); |
205 |
break; |
206 |
case 'c': /* chromaticities */ |
207 |
check(3,"ffffffff"); |
208 |
rval = 0; |
209 |
for (int j = 0; j < 8; j++) { |
210 |
our_prims[0][j] = atof(argv[++i]); |
211 |
rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001; |
212 |
213 |
if (rval) { |
214 |
if (!colorprimsOK(our_prims)) |
215 |
error(USER, "illegal primary chromaticities"); |
216 |
myRPmanager.prims = our_prims; |
217 |
} else |
218 |
219 |
220 |
break; |
221 |
default: |
222 |
goto badopt; |
223 |
224 |
break; |
225 |
case 'd': /* reference depth */ |
226 |
if (argv[i][2] || !myRPmanager.SetReferenceDepth(argv[++i])) |
227 |
goto badopt; |
228 |
dtype = RDTnewDT(dtype, RDTdshort); |
229 |
break; |
230 |
case 'x': /* x resolution */ |
231 |
check(2,"i"); |
232 |
hresolu = atoi(argv[++i]); |
233 |
break; |
234 |
case 'y': /* y resolution */ |
235 |
check(2,"i"); |
236 |
vresolu = atoi(argv[++i]); |
237 |
break; |
238 |
case 'S': /* start index */ |
239 |
check(2,"i"); |
240 |
seqstart = atoi(argv[++i]); |
241 |
seqstart *= (seqstart > 0); |
242 |
break; |
243 |
case 'o': /* output file */ |
244 |
check(2,"s"); |
245 |
outfile = argv[++i]; |
246 |
break; |
247 |
case 'z': /* z file */ |
248 |
check(2,"s"); |
249 |
zfile = argv[++i]; |
250 |
break; |
251 |
case 'r': /* recover file */ |
252 |
if (argv[i][2] == 'o') { /* +output */ |
253 |
check(3,"s"); |
254 |
outfile = argv[i+1]; |
255 |
} else |
256 |
check(2,"s"); |
257 |
recover = argv[++i]; |
258 |
break; |
259 |
#if MAXCSAMP>3 |
260 |
case 'c': /* output spectral results */ |
261 |
if (argv[i][2] != 'o') |
262 |
goto badopt; |
263 |
rval = (myRPmanager.prims == NULL); |
264 |
check_bool(3,rval); |
265 |
if (rval) |
266 |
myRPmanager.prims = NULL; |
267 |
else if (myRPmanager.prims == NULL) |
268 |
269 |
dtype = RDTnewCT(dtype, rval ? RDTscolr : RDTrgbe); |
270 |
break; |
271 |
#endif |
272 |
case 't': /* timer */ |
273 |
check(2,"i"); |
274 |
ralrm = atoi(argv[++i]); |
275 |
break; |
276 |
case 'w': /* warnings */ |
277 |
rval = erract[WARNING].pf != NULL; |
278 |
check_bool(2,rval); |
279 |
if (rval) erract[WARNING].pf = wputs; |
280 |
else erract[WARNING].pf = NULL; |
281 |
break; |
282 |
case 'e': /* error file */ |
283 |
check(2,"s"); |
284 |
errfile = argv[++i]; |
285 |
break; |
286 |
default: |
287 |
goto badopt; |
288 |
289 |
290 |
if (maxdiff <= FTINY) /* check for useless sampling */ |
291 |
psample = 1; |
292 |
if (zfile == NULL) /* set up depth output */ |
293 |
dtype = RDTnewDT(dtype, RDTnone); |
294 |
else if (!RDTdepthT(dtype)) |
295 |
dtype = RDTnewDT(dtype, RDTdfloat); |
296 |
/* check pixel output type */ |
297 |
if ((myRPmanager.prims == NULL) & (NCSAMP == 3)) { |
298 |
299 |
300 |
301 |
if (outfmt == 'f') |
302 |
switch (RDTcolorT(dtype)) { |
303 |
case RDTrgbe: |
304 |
dtype = RDTnewCT(dtype, RDTrgb); |
305 |
break; |
306 |
case RDTxyze: |
307 |
dtype = RDTnewCT(dtype, RDTxyz); |
308 |
break; |
309 |
case RDTscolr: |
310 |
dtype = RDTnewCT(dtype, RDTscolor); |
311 |
break; |
312 |
case RDTrgb: |
313 |
case RDTxyz: |
314 |
case RDTscolor: |
315 |
break; |
316 |
default: |
317 |
error(INTERNAL, "botched color output type"); |
318 |
319 |
/* set up signal handling */ |
320 |
sigdie(SIGINT, "Interrupt"); |
321 |
#ifdef SIGHUP |
322 |
sigdie(SIGHUP, "Hangup"); |
323 |
#endif |
324 |
sigdie(SIGTERM, "Terminate"); |
325 |
#ifdef SIGPIPE |
326 |
sigdie(SIGPIPE, "Broken pipe"); |
327 |
#endif |
328 |
#ifdef SIGALRM |
329 |
sigdie(SIGALRM, "Alarm clock"); |
330 |
#endif |
331 |
#ifdef SIGXCPU |
332 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
333 |
sigdie(SIGXFSZ, "File size exceeded"); |
334 |
#endif |
335 |
/* open error file */ |
336 |
if (errfile != NULL) { |
337 |
if (freopen(errfile, "a", stderr) == NULL) |
338 |
quit(2); |
339 |
fprintf(stderr, "**************\n*** PID %5d: ", |
340 |
getpid()); |
341 |
printargs(argc, argv, stderr); |
342 |
putc('\n', stderr); |
343 |
fflush(stderr); |
344 |
345 |
#ifdef NICE |
346 |
nice(NICE); /* lower priority */ |
347 |
#endif |
348 |
if (i < argc-1) |
349 |
goto badopt; |
350 |
// load octree |
351 |
if (!myRPmanager.LoadOctree(argv[i])) |
352 |
error(USER, "missing octree argument"); |
353 |
// add new header info |
354 |
myRPmanager.AddHeader(i, argv); |
355 |
356 |
char buf[128] = "SOFTWARE= "; |
357 |
strcpy(buf+10, VersionID); |
358 |
myRPmanager.AddHeader(buf); |
359 |
360 |
// start our engines |
361 |
nproc = myRPmanager.SetThreadCount(nproc); |
362 |
// batch render picture(s) |
363 |
rpict(seqstart, outfile, zfile, recover); |
364 |
365 |
quit(0); // clean up and exit |
366 |
367 |
badopt: |
368 |
sprintf(errmsg, "command line error at '%s'", argv[i]); |
369 |
370 |
return 1; /* pro forma return */ |
371 |
372 |
#undef check |
373 |
#undef check_bool |
374 |
375 |
376 |
377 |
void |
378 |
wputs( /* warning output function */ |
379 |
const char *s |
380 |
381 |
382 |
int lasterrno = errno; |
383 |
eputs(s); |
384 |
errno = lasterrno; |
385 |
386 |
387 |
388 |
void |
389 |
eputs( /* put string to stderr */ |
390 |
const char *s |
391 |
392 |
393 |
static int midline = 0; |
394 |
395 |
if (!*s) |
396 |
return; |
397 |
if (!midline++) { |
398 |
fputs(progname, stderr); |
399 |
fputs(": ", stderr); |
400 |
401 |
fputs(s, stderr); |
402 |
if (s[strlen(s)-1] == '\n') { |
403 |
fflush(stderr); |
404 |
midline = 0; |
405 |
406 |
407 |
408 |
409 |
static void |
410 |
onsig( /* fatal signal */ |
411 |
int signo |
412 |
413 |
414 |
static int gotsig = 0; |
415 |
416 |
if (gotsig++) /* two signals and we're gone! */ |
417 |
_exit(signo); |
418 |
419 |
#ifdef SIGALRM /* XXX how critical is this? */ |
420 |
alarm(30); /* allow 30 seconds to clean up */ |
421 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */ |
422 |
#endif |
423 |
eputs("signal - "); |
424 |
eputs(sigerr[signo]); |
425 |
eputs("\n"); |
426 |
quit(3); |
427 |
428 |
429 |
430 |
static void |
431 |
sigdie( /* set fatal signal */ |
432 |
int signo, |
433 |
const char *msg |
434 |
435 |
436 |
if (signal(signo, onsig) == SIG_IGN) |
437 |
signal(signo, SIG_IGN); |
438 |
sigerr[signo] = msg; |
439 |
440 |
441 |
442 |
static void |
443 |
printdefaults(void) /* print default values to stdout */ |
444 |
445 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); |
446 |
printf("-vt%c\t\t\t\t# view type %s\n", ourview.type, |
447 |
ourview.type==VT_PER ? "perspective" : |
448 |
ourview.type==VT_PAR ? "parallel" : |
449 |
ourview.type==VT_HEM ? "hemispherical" : |
450 |
ourview.type==VT_ANG ? "angular" : |
451 |
ourview.type==VT_CYL ? "cylindrical" : |
452 |
ourview.type==VT_PLS ? "planisphere" : |
453 |
"unknown"); |
454 |
printf("-vp %f %f %f\t# view point\n", |
455 |
ourview.vp[0], ourview.vp[1], ourview.vp[2]); |
456 |
printf("-vd %f %f %f\t# view direction\n", |
457 |
ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]); |
458 |
printf("-vu %f %f %f\t# view up\n", |
459 |
ourview.vup[0], ourview.vup[1], ourview.vup[2]); |
460 |
printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz); |
461 |
printf("-vv %f\t\t\t# view vertical size\n", ourview.vert); |
462 |
printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore); |
463 |
printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft); |
464 |
printf("-vs %f\t\t\t# view shift\n", ourview.hoff); |
465 |
printf("-vl %f\t\t\t# view lift\n", ourview.voff); |
466 |
printf("-x %-9d\t\t\t# x resolution\n", hresolu); |
467 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu); |
468 |
if (myRPmanager.prims == stdprims) |
469 |
printf("-pRGB\t\t\t\t# standard RGB color output\n"); |
470 |
else if (myRPmanager.prims == xyzprims) |
471 |
printf("-pXYZ\t\t\t\t# CIE XYZ color output\n"); |
472 |
else if (myRPmanager.prims != NULL) |
473 |
printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n", |
474 |
myRPmanager.prims[RED][0], myRPmanager.prims[RED][1], |
475 |
myRPmanager.prims[GRN][0], myRPmanager.prims[GRN][1], |
476 |
myRPmanager.prims[BLU][0], myRPmanager.prims[BLU][1], |
477 |
myRPmanager.prims[WHT][0], myRPmanager.prims[WHT][1]); |
478 |
if (NCSAMP > 3) |
479 |
printf(myRPmanager.prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" : |
480 |
"-co+\t\t\t\t# output spectral values\n"); |
481 |
printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect); |
482 |
printf("-pj %f\t\t\t# pixel jitter\n", dstrpix); |
483 |
printf("-pm %f\t\t\t# pixel motion\n", mblur); |
484 |
printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur); |
485 |
printf("-ps %-9d\t\t\t# pixel sample\n", psample); |
486 |
printf("-pt %f\t\t\t# pixel threshold\n", maxdiff); |
487 |
printf("-t %-9d\t\t\t# time between reports\n", ralrm); |
488 |
printf(erract[WARNING].pf != NULL ? |
489 |
"-w+\t\t\t\t# warning messages on\n" : |
490 |
"-w-\t\t\t\t# warning messages off\n"); |
491 |
print_rdefaults(); |
492 |
493 |
494 |
495 |
// my progress report call-back |
496 |
static void |
497 |
progReporter(double pct) |
498 |
499 |
static time_t lastReportTime = 0; |
500 |
time_t tnow = time(NULL); |
501 |
502 |
if (pct < 100.-FTINY && tnow - lastReportTime < ralrm) |
503 |
return; // too soon, my Precious... |
504 |
505 |
sprintf(errmsg, "%7.3f%% done after %7.3f hours\n", pct, (tnow-tstart)/3600.); |
506 |
eputs(errmsg); |
507 |
// reset timer at 100% |
508 |
lastReportTime = tnow * (pct < 100.-FTINY); |
509 |
510 |
511 |
512 |
// Principal function for rpict execution (prototype in ray.h for some reason) |
513 |
void |
514 |
rpict(int seq, char *pout, char *zout, char *prvr) |
515 |
516 |
* If seq is greater than zero, then we will render a sequence of |
517 |
* images based on view parameter strings read from the standard input. |
518 |
* If pout is NULL, then all images will be sent to the standard ouput. |
519 |
* If seq is greater than zero and prvr is an integer, then it is the |
520 |
* frame number at which rendering should begin. Preceeding view parameter |
521 |
* strings will be skipped in the input. |
522 |
* Note that pout and zout should contain %d format specifications for |
523 |
* sequenced file naming. |
524 |
525 |
526 |
char fbuf[256], dbuf[256]; |
527 |
528 |
if (!zout ^ !RDTdepthT(dtype)) |
529 |
error(INTERNAL, "output depth type requires spec and vice versa"); |
530 |
531 |
if (prvr && isint(prvr)) { // sequence recovery? |
532 |
if (!seq) |
533 |
error(USER, "sequence recovery requires starting frame"); |
534 |
if (!pout) |
535 |
error(USER, "need output spec for sequence recovery"); |
536 |
int rno = atoi(prvr); |
537 |
if (rno < seq) |
538 |
error(USER, "recovery frame before starting frame"); |
539 |
while (seq <= rno) { |
540 |
if (!fgets(fbuf, sizeof(fbuf), stdin)) |
541 |
error(USER, "recovery frame past end of sequence"); |
542 |
seq += (isview(fbuf) && sscanview(&ourview, fbuf) > 0); |
543 |
544 |
sprintf(prvr=fbuf, pout, rno); |
545 |
546 |
if (ralrm > 0) |
547 |
myRPmanager.prCB = progReporter; |
548 |
else |
549 |
myRPmanager.prCB = NULL; |
550 |
if (prvr) { // recovering partial render? |
551 |
if ((seq > 0) & (prvr != fbuf)) |
552 |
error(USER, "recover spec must be number in sequence"); |
553 |
if (zout) sprintf(dbuf, zout, seq); |
554 |
if (ralrm > 0) { |
555 |
sprintf(errmsg, "resuming partial rendering '%s'\n", prvr); |
556 |
eputs(errmsg); |
557 |
558 |
dtype = myRPmanager.ResumeFrame(prvr, zout ? dbuf : zout); |
559 |
if (!dtype) |
560 |
error(USER, "ResumeFrame() failed"); |
561 |
if (!seq) |
562 |
return; // all done if we're running a sequence |
563 |
564 |
do { |
565 |
if (prvr) // have view from sequence recovery? |
566 |
prvr = NULL; |
567 |
else if (seq) { // else read next view in sequence |
568 |
while (fgets(fbuf, sizeof(fbuf), stdin)) |
569 |
if (isview(fbuf) && sscanview(&ourview, fbuf) > 0) |
570 |
break; |
571 |
if (feof(stdin)) |
572 |
return; // reached end of view input |
573 |
574 |
// get (indexed) output file name(s) |
575 |
if (pout) sprintf(fbuf, pout, seq); |
576 |
577 |
578 |
if (ralrm > 0) { // start report if requested |
579 |
if (myRPmanager.NThreads() > 1) |
580 |
sprintf(errmsg, "%2d processes ", myRPmanager.NThreads()); |
581 |
else |
582 |
sprintf(errmsg, "PID %6d ", getpid()); |
583 |
eputs(errmsg); |
584 |
if (seq) { |
585 |
sprintf(errmsg, "rendering frame %5d ", seq); |
586 |
eputs(errmsg); |
587 |
} else |
588 |
eputs("rendering picture "); |
589 |
if (pout) { |
590 |
sprintf(errmsg, "to '%s'\n", fbuf); |
591 |
eputs(errmsg); |
592 |
} else |
593 |
eputs("to stdout\n"); |
594 |
if (zout) { |
595 |
sprintf(errmsg, "\twith %s depth map in '%s'\n", |
596 |
RDTdepthT(dtype)==RDTdshort ? |
597 |
"encoded 16-bit" : "raw float", |
598 |
dbuf); |
599 |
eputs(errmsg); |
600 |
601 |
602 |
// set up view and size |
603 |
int xydim[2] = {hresolu, vresolu}; |
604 |
if (!myRPmanager.NewFrame(ourview, xydim, &pixaspect)) |
605 |
error(USER, "NewFrame() failed"); |
606 |
607 |
myRPmanager.frameNo = seq; |
608 |
609 |
errno = 0; // render frame, skipping if it exists |
610 |
if (!myRPmanager.RenderFrame(pout ? fbuf : pout, dtype, |
611 |
zout ? dbuf : zout) |
612 |
&& !seq | (errno != EEXIST)) |
613 |
error(USER, "RenderFrame() failed"); |
614 |
} while (seq++); // all done if we're running a sequence |
615 |
