1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rxpmain.cpp,v 2.8 2025/04/22 17:12:25 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rxpmain.cpp - main for rxpict batch rendering program |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <time.h> |
11 |
#include <signal.h> |
12 |
13 |
#include "rtprocess.h" /* getpid() */ |
14 |
#include "platform.h" |
15 |
#include "RpictSimulManager.h" |
16 |
#include "func.h" |
17 |
18 |
const char *sigerr[NSIG]; /* signal error messages */ |
19 |
char *errfile = NULL; /* error output file */ |
20 |
21 |
VIEW ourview = STDVIEW; /* view parameters */ |
22 |
int hresolu = 512; /* horizontal resolution */ |
23 |
int vresolu = 512; /* vertical resolution */ |
24 |
double pixaspect = 1.0; /* pixel aspect ratio */ |
25 |
int hres, vres; /* current image resolution for srcdraw.c */ |
26 |
27 |
int psample = 4; /* pixel sample size */ |
28 |
double maxdiff = .05; /* max. difference for interpolation */ |
29 |
double dstrpix = 0.67; /* square pixel distribution */ |
30 |
31 |
double mblur = 0.; /* motion blur parameter */ |
32 |
33 |
double dblur = 0.; /* depth-of-field blur parameter */ |
34 |
35 |
int nproc = 1; /* number of processes to run */ |
36 |
37 |
int ralrm = 0; /* seconds between reports */ |
38 |
39 |
double pctdone = 0.0; /* percentage done */ |
40 |
time_t tlastrept = 0L; /* time at last report */ |
41 |
time_t tstart; /* starting time */ |
42 |
43 |
RenderDataType dtype = RDTrgbe; // output data flags |
44 |
45 |
RpictSimulManager myRPmanager; // global simulation manager |
46 |
47 |
static void onsig(int signo); |
48 |
static void sigdie(int signo, const char *msg); |
49 |
static void printdefaults(void); |
50 |
51 |
/* rxpict additional features */ |
52 |
#define RXPICT_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \ |
53 |
"ParticipatingMedia=Mist\n" \ |
54 |
"HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \ |
55 |
"PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \ |
56 |
"SmallSourceDrawing\nViewSequence\nProgressReporting\n" \ |
57 |
"AdaptiveShadowTesting\nOutputs=v,l\n" \ |
58 |
"OutputCS=RGB,XYZ,prims,spec\n" |
59 |
60 |
void |
61 |
quit(int code) /* quit program */ |
62 |
63 |
exit(code); // don't bother about freeing anything |
64 |
65 |
66 |
/* Set default options */ |
67 |
static void |
68 |
default_options(void) |
69 |
70 |
shadthresh = .05; |
71 |
shadcert = .5; |
72 |
srcsizerat = .25; |
73 |
directrelay = 1; |
74 |
ambacc = 0.2; |
75 |
ambres = 64; |
76 |
ambdiv = 512; |
77 |
ambssamp = 128; |
78 |
maxdepth = 7; |
79 |
80 |
81 |
int |
82 |
main(int argc, char *argv[]) |
83 |
84 |
#define check(ol,al) if (argv[i][ol] || \ |
85 |
badarg(argc-i-1,argv+i+1,al)) \ |
86 |
goto badopt |
87 |
#define check_bool(olen,var) switch (argv[i][olen]) { \ |
88 |
case '\0': var = !var; break; \ |
89 |
case 'y': case 'Y': case 't': case 'T': \ |
90 |
case '+': case '1': var = 1; break; \ |
91 |
case 'n': case 'N': case 'f': case 'F': \ |
92 |
case '-': case '0': var = 0; break; \ |
93 |
default: goto badopt; } |
94 |
RGBPRIMS our_prims; /* private output color primitives */ |
95 |
int seqstart = 0; |
96 |
char *recover = NULL; |
97 |
char *outfile = NULL; |
98 |
char *zfile = NULL; |
99 |
int outfmt = 'c'; |
100 |
int rval; |
101 |
int i; |
102 |
/* record start time */ |
103 |
tstart = time(NULL); |
104 |
/* global program name */ |
105 |
progname = argv[0]; |
106 |
/* feature check only? */ |
107 |
strcat(RFeatureList, RXPICT_FEATURES); |
108 |
if (argc > 1 && !strcmp(argv[1], "-features")) |
109 |
return feature_status(argc-2, argv+2); |
110 |
/* initialize calcomp routines */ |
111 |
initfunc(); |
112 |
/* set defaults */ |
113 |
default_options(); |
114 |
/* option city */ |
115 |
for (i = 1; i < argc; i++) { |
116 |
/* expand arguments */ |
117 |
while ((rval = expandarg(&argc, &argv, i)) > 0) |
118 |
119 |
if (rval < 0) { |
120 |
sprintf(errmsg, "cannot expand '%s'", argv[i]); |
121 |
error(SYSTEM, errmsg); |
122 |
123 |
if (argv[i] == NULL || argv[i][0] != '-') |
124 |
break; /* break from options */ |
125 |
if (!strcmp(argv[i], "-version")) { |
126 |
puts(VersionID); |
127 |
quit(0); |
128 |
129 |
if (!strcmp(argv[i], "-defaults") || |
130 |
!strcmp(argv[i], "-help")) { |
131 |
printdefaults(); |
132 |
quit(0); |
133 |
134 |
rval = getrenderopt(argc-i, argv+i); |
135 |
if (rval >= 0) { |
136 |
i += rval; |
137 |
continue; |
138 |
139 |
rval = getviewopt(&ourview, argc-i, argv+i); |
140 |
if (rval >= 0) { |
141 |
i += rval; |
142 |
continue; |
143 |
144 |
/* rxpict options */ |
145 |
switch (argv[i][1]) { |
146 |
case 'v': /* view file */ |
147 |
if (argv[i][2] != 'f') |
148 |
goto badopt; |
149 |
check(3,"s"); |
150 |
rval = viewfile(argv[++i], &ourview, NULL); |
151 |
if (rval < 0) { |
152 |
sprintf(errmsg, |
153 |
"cannot open view file \"%s\"", |
154 |
argv[i]); |
155 |
156 |
} else if (rval == 0) { |
157 |
sprintf(errmsg, |
158 |
"bad view file \"%s\"", |
159 |
argv[i]); |
160 |
error(USER, errmsg); |
161 |
162 |
break; |
163 |
case 'n': /* number of processes */ |
164 |
check(2,"i"); |
165 |
nproc = atoi(argv[++i]); |
166 |
if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0) |
167 |
nproc = 1; |
168 |
break; |
169 |
case 'f': /* output format */ |
170 |
if ((argv[i][2] != 'c') & (argv[i][2] != 'f') |
171 |
|| argv[i][3]) |
172 |
goto badopt; |
173 |
outfmt = argv[i][2]; |
174 |
break; |
175 |
case 'p': /* pixel */ |
176 |
switch (argv[i][2]) { |
177 |
case 's': /* sample */ |
178 |
check(3,"i"); |
179 |
psample = atoi(argv[++i]); |
180 |
if (psample < 1) psample = 1; |
181 |
break; |
182 |
case 't': /* threshold */ |
183 |
check(3,"f"); |
184 |
maxdiff = atof(argv[++i]); |
185 |
break; |
186 |
case 'j': /* jitter */ |
187 |
check(3,"f"); |
188 |
dstrpix = atof(argv[++i]); |
189 |
break; |
190 |
case 'a': /* aspect */ |
191 |
check(3,"f"); |
192 |
pixaspect = atof(argv[++i]); |
193 |
break; |
194 |
case 'm': /* motion */ |
195 |
check(3,"f"); |
196 |
mblur = atof(argv[++i]); |
197 |
mblur *= (mblur > 0); |
198 |
break; |
199 |
case 'd': /* aperture */ |
200 |
check(3,"f"); |
201 |
dblur = atof(argv[++i]); |
202 |
dblur *= (dblur > 0); |
203 |
break; |
204 |
case 'R': /* standard RGB output */ |
205 |
if (strcmp(argv[i]+2, "RGB")) |
206 |
goto badopt; |
207 |
myRPmanager.prims = stdprims; |
208 |
dtype = RDTnewCT(dtype, RDTrgbe); |
209 |
break; |
210 |
case 'X': /* XYZ output */ |
211 |
if (strcmp(argv[i]+2, "XYZ")) |
212 |
goto badopt; |
213 |
myRPmanager.prims = xyzprims; |
214 |
dtype = RDTnewCT(dtype, RDTxyze); |
215 |
break; |
216 |
case 'c': /* chromaticities */ |
217 |
check(3,"ffffffff"); |
218 |
rval = 0; |
219 |
for (int j = 0; j < 8; j++) { |
220 |
our_prims[0][j] = atof(argv[++i]); |
221 |
rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001; |
222 |
223 |
if (rval) { |
224 |
if (!colorprimsOK(our_prims)) |
225 |
error(USER, "illegal primary chromaticities"); |
226 |
myRPmanager.prims = our_prims; |
227 |
} else |
228 |
229 |
230 |
break; |
231 |
default: |
232 |
goto badopt; |
233 |
234 |
break; |
235 |
case 'd': /* reference depth */ |
236 |
if (argv[i][2] || !myRPmanager.SetReferenceDepth(argv[++i])) |
237 |
goto badopt; |
238 |
dtype = RDTnewDT(dtype, RDTdshort); |
239 |
break; |
240 |
case 'x': /* x resolution */ |
241 |
check(2,"i"); |
242 |
hresolu = atoi(argv[++i]); |
243 |
break; |
244 |
case 'y': /* y resolution */ |
245 |
check(2,"i"); |
246 |
vresolu = atoi(argv[++i]); |
247 |
break; |
248 |
case 'S': /* start index */ |
249 |
check(2,"i"); |
250 |
seqstart = atoi(argv[++i]); |
251 |
seqstart *= (seqstart > 0); |
252 |
break; |
253 |
case 'o': /* output file */ |
254 |
check(2,"s"); |
255 |
outfile = argv[++i]; |
256 |
break; |
257 |
case 'z': /* z file */ |
258 |
check(2,"s"); |
259 |
zfile = argv[++i]; |
260 |
break; |
261 |
case 'r': /* recover file */ |
262 |
if (argv[i][2] == 'o') { /* +output */ |
263 |
check(3,"s"); |
264 |
outfile = argv[i+1]; |
265 |
} else |
266 |
check(2,"s"); |
267 |
recover = argv[++i]; |
268 |
break; |
269 |
#if MAXCSAMP>3 |
270 |
case 'c': /* output spectral results */ |
271 |
if (argv[i][2] != 'o') |
272 |
goto badopt; |
273 |
rval = (myRPmanager.prims == NULL); |
274 |
check_bool(3,rval); |
275 |
if (rval) |
276 |
myRPmanager.prims = NULL; |
277 |
else if (myRPmanager.prims == NULL) |
278 |
279 |
dtype = RDTnewCT(dtype, rval ? RDTscolr : RDTrgbe); |
280 |
break; |
281 |
#endif |
282 |
case 't': /* timer */ |
283 |
check(2,"i"); |
284 |
ralrm = atoi(argv[++i]); |
285 |
break; |
286 |
case 'w': /* warnings */ |
287 |
rval = erract[WARNING].pf != NULL; |
288 |
check_bool(2,rval); |
289 |
if (rval) erract[WARNING].pf = wputs; |
290 |
else erract[WARNING].pf = NULL; |
291 |
break; |
292 |
case 'e': /* error file */ |
293 |
check(2,"s"); |
294 |
errfile = argv[++i]; |
295 |
break; |
296 |
default: |
297 |
goto badopt; |
298 |
299 |
300 |
if (maxdiff <= FTINY) /* check for useless sampling */ |
301 |
psample = 1; |
302 |
if (zfile == NULL) /* set up depth output */ |
303 |
dtype = RDTnewDT(dtype, RDTnone); |
304 |
else if (!RDTdepthT(dtype)) |
305 |
dtype = RDTnewDT(dtype, RDTdfloat); |
306 |
/* check pixel output type */ |
307 |
if ((myRPmanager.prims == NULL) & (NCSAMP == 3)) { |
308 |
309 |
310 |
311 |
if (outfmt == 'f') |
312 |
switch (RDTcolorT(dtype)) { |
313 |
case RDTrgbe: |
314 |
dtype = RDTnewCT(dtype, RDTrgb); |
315 |
break; |
316 |
case RDTxyze: |
317 |
dtype = RDTnewCT(dtype, RDTxyz); |
318 |
break; |
319 |
case RDTscolr: |
320 |
dtype = RDTnewCT(dtype, RDTscolor); |
321 |
break; |
322 |
case RDTrgb: |
323 |
case RDTxyz: |
324 |
case RDTscolor: |
325 |
break; |
326 |
default: |
327 |
error(INTERNAL, "botched color output type"); |
328 |
329 |
/* set up signal handling */ |
330 |
sigdie(SIGINT, "Interrupt"); |
331 |
#ifdef SIGHUP |
332 |
sigdie(SIGHUP, "Hangup"); |
333 |
#endif |
334 |
sigdie(SIGTERM, "Terminate"); |
335 |
#ifdef SIGPIPE |
336 |
sigdie(SIGPIPE, "Broken pipe"); |
337 |
#endif |
338 |
#ifdef SIGALRM |
339 |
sigdie(SIGALRM, "Alarm clock"); |
340 |
#endif |
341 |
#ifdef SIGXCPU |
342 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
343 |
sigdie(SIGXFSZ, "File size exceeded"); |
344 |
#endif |
345 |
/* open error file */ |
346 |
if (errfile != NULL) { |
347 |
if (freopen(errfile, "a", stderr) == NULL) |
348 |
quit(2); |
349 |
fprintf(stderr, "**************\n*** PID %5d: ", |
350 |
getpid()); |
351 |
printargs(argc, argv, stderr); |
352 |
putc('\n', stderr); |
353 |
fflush(stderr); |
354 |
355 |
#ifdef NICE |
356 |
nice(NICE); /* lower priority */ |
357 |
#endif |
358 |
if (i < argc-1) |
359 |
goto badopt; |
360 |
// load octree |
361 |
if (!myRPmanager.LoadOctree(argv[i])) |
362 |
error(USER, "missing octree argument"); |
363 |
// add new header info |
364 |
myRPmanager.AddHeader(i, argv); |
365 |
366 |
char buf[128] = "SOFTWARE= "; |
367 |
strcpy(buf+10, VersionID); |
368 |
myRPmanager.AddHeader(buf); |
369 |
370 |
// start our engines |
371 |
nproc = myRPmanager.SetThreadCount(nproc); |
372 |
// batch render picture(s) |
373 |
rpict(seqstart, outfile, zfile, recover); |
374 |
375 |
quit(0); // clean up and exit |
376 |
377 |
badopt: |
378 |
sprintf(errmsg, "command line error at '%s'", argv[i]); |
379 |
380 |
return 1; /* pro forma return */ |
381 |
382 |
#undef check |
383 |
#undef check_bool |
384 |
385 |
386 |
387 |
void |
388 |
wputs( /* warning output function */ |
389 |
const char *s |
390 |
391 |
392 |
int lasterrno = errno; |
393 |
eputs(s); |
394 |
errno = lasterrno; |
395 |
396 |
397 |
398 |
void |
399 |
eputs( /* put string to stderr */ |
400 |
const char *s |
401 |
402 |
403 |
static int midline = 0; |
404 |
405 |
if (!*s) |
406 |
return; |
407 |
if (!midline++) { |
408 |
fputs(progname, stderr); |
409 |
fputs(": ", stderr); |
410 |
411 |
fputs(s, stderr); |
412 |
if (s[strlen(s)-1] == '\n') { |
413 |
fflush(stderr); |
414 |
midline = 0; |
415 |
416 |
417 |
418 |
419 |
static void |
420 |
onsig( /* fatal signal */ |
421 |
int signo |
422 |
423 |
424 |
static int gotsig = 0; |
425 |
426 |
if (gotsig++) /* two signals and we're gone! */ |
427 |
_exit(signo); |
428 |
429 |
#ifdef SIGALRM /* XXX how critical is this? */ |
430 |
alarm(30); /* allow 30 seconds to clean up */ |
431 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */ |
432 |
#endif |
433 |
eputs("signal - "); |
434 |
eputs(sigerr[signo]); |
435 |
eputs("\n"); |
436 |
quit(3); |
437 |
438 |
439 |
440 |
static void |
441 |
sigdie( /* set fatal signal */ |
442 |
int signo, |
443 |
const char *msg |
444 |
445 |
446 |
if (signal(signo, onsig) == SIG_IGN) |
447 |
signal(signo, SIG_IGN); |
448 |
sigerr[signo] = msg; |
449 |
450 |
451 |
452 |
static void |
453 |
printdefaults(void) /* print default values to stdout */ |
454 |
455 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); |
456 |
printf("-vt%c\t\t\t\t# view type %s\n", ourview.type, |
457 |
ourview.type==VT_PER ? "perspective" : |
458 |
ourview.type==VT_PAR ? "parallel" : |
459 |
ourview.type==VT_HEM ? "hemispherical" : |
460 |
ourview.type==VT_ANG ? "angular" : |
461 |
ourview.type==VT_CYL ? "cylindrical" : |
462 |
ourview.type==VT_PLS ? "planisphere" : |
463 |
"unknown"); |
464 |
printf("-vp %f %f %f\t# view point\n", |
465 |
ourview.vp[0], ourview.vp[1], ourview.vp[2]); |
466 |
printf("-vd %f %f %f\t# view direction\n", |
467 |
ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]); |
468 |
printf("-vu %f %f %f\t# view up\n", |
469 |
ourview.vup[0], ourview.vup[1], ourview.vup[2]); |
470 |
printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz); |
471 |
printf("-vv %f\t\t\t# view vertical size\n", ourview.vert); |
472 |
printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore); |
473 |
printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft); |
474 |
printf("-vs %f\t\t\t# view shift\n", ourview.hoff); |
475 |
printf("-vl %f\t\t\t# view lift\n", ourview.voff); |
476 |
printf("-x %-9d\t\t\t# x resolution\n", hresolu); |
477 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu); |
478 |
if (myRPmanager.prims == stdprims) |
479 |
printf("-pRGB\t\t\t\t# standard RGB color output\n"); |
480 |
else if (myRPmanager.prims == xyzprims) |
481 |
printf("-pXYZ\t\t\t\t# CIE XYZ color output\n"); |
482 |
else if (myRPmanager.prims != NULL) |
483 |
printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n", |
484 |
myRPmanager.prims[RED][0], myRPmanager.prims[RED][1], |
485 |
myRPmanager.prims[GRN][0], myRPmanager.prims[GRN][1], |
486 |
myRPmanager.prims[BLU][0], myRPmanager.prims[BLU][1], |
487 |
myRPmanager.prims[WHT][0], myRPmanager.prims[WHT][1]); |
488 |
if (NCSAMP > 3) |
489 |
printf(myRPmanager.prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" : |
490 |
"-co+\t\t\t\t# output spectral values\n"); |
491 |
printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect); |
492 |
printf("-pj %f\t\t\t# pixel jitter\n", dstrpix); |
493 |
printf("-pm %f\t\t\t# pixel motion\n", mblur); |
494 |
printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur); |
495 |
printf("-ps %-9d\t\t\t# pixel sample\n", psample); |
496 |
printf("-pt %f\t\t\t# pixel threshold\n", maxdiff); |
497 |
printf("-t %-9d\t\t\t# time between reports\n", ralrm); |
498 |
printf(erract[WARNING].pf != NULL ? |
499 |
"-w+\t\t\t\t# warning messages on\n" : |
500 |
"-w-\t\t\t\t# warning messages off\n"); |
501 |
print_rdefaults(); |
502 |
503 |
504 |
505 |
// my progress report call-back |
506 |
static void |
507 |
progReporter(double pct) |
508 |
509 |
static time_t lastReportTime = 0; |
510 |
time_t tnow = time(NULL); |
511 |
512 |
if (pct < 100.-FTINY && tnow - lastReportTime < ralrm) |
513 |
return; // too soon, my Precious... |
514 |
515 |
sprintf(errmsg, "%7.3f%% done after %7.3f hours\n", pct, (tnow-tstart)/3600.); |
516 |
eputs(errmsg); |
517 |
// reset timer at 100% |
518 |
lastReportTime = tnow * (pct < 100.-FTINY); |
519 |
520 |
521 |
522 |
// Principal function for rpict execution (prototype in ray.h for some reason) |
523 |
void |
524 |
rpict(int seq, char *pout, char *zout, char *prvr) |
525 |
526 |
* If seq is greater than zero, we will render a sequence of |
527 |
* images based on view parameter strings read from the standard input. |
528 |
* If pout is NULL, then all images will be sent to the standard ouput. |
529 |
* If seq is greater than zero and prvr is an integer, then it is the |
530 |
* frame number at which rendering should begin. Preceeding view parameter |
531 |
* strings will be skipped in the input. |
532 |
* Note that pout and zout should contain %d format specifications for |
533 |
* sequenced file naming. |
534 |
535 |
536 |
char fbuf[256], dbuf[256]; |
537 |
538 |
if (!zout ^ !RDTdepthT(dtype)) |
539 |
error(INTERNAL, "output depth type requires spec and vice versa"); |
540 |
541 |
if (prvr && isint(prvr)) { // sequence recovery? |
542 |
if (!seq) |
543 |
error(USER, "sequence recovery requires starting frame"); |
544 |
if (!pout) |
545 |
error(USER, "need output spec for sequence recovery"); |
546 |
int rno = atoi(prvr); |
547 |
if (rno < seq) |
548 |
error(USER, "recovery frame before starting frame"); |
549 |
while (seq <= rno) { |
550 |
if (!fgets(fbuf, sizeof(fbuf), stdin)) |
551 |
error(USER, "recovery frame past end of sequence"); |
552 |
seq += (isview(fbuf) && sscanview(&ourview, fbuf) > 0); |
553 |
554 |
sprintf(prvr=fbuf, pout, rno); |
555 |
556 |
if (ralrm > 0) |
557 |
myRPmanager.prCB = progReporter; |
558 |
else |
559 |
myRPmanager.prCB = NULL; |
560 |
if (prvr) { // recovering partial render? |
561 |
if ((seq > 0) & (prvr != fbuf)) |
562 |
error(USER, "recover spec must be number in sequence"); |
563 |
if (zout) sprintf(dbuf, zout, seq); |
564 |
if (ralrm > 0) { |
565 |
sprintf(errmsg, "resuming partial rendering '%s'\n", prvr); |
566 |
eputs(errmsg); |
567 |
568 |
dtype = myRPmanager.ResumeFrame(prvr, zout ? dbuf : zout); |
569 |
if (!dtype) |
570 |
error(USER, "ResumeFrame() failed"); |
571 |
if (!seq) |
572 |
return; // all done if not a sequence |
573 |
574 |
do { |
575 |
if (prvr) // have view from sequence recovery? |
576 |
prvr = NULL; |
577 |
else if (seq) { // else read next view in sequence |
578 |
while (fgets(fbuf, sizeof(fbuf), stdin)) |
579 |
if (isview(fbuf) && sscanview(&ourview, fbuf) > 0) |
580 |
break; |
581 |
if (feof(stdin)) |
582 |
return; // reached end of view input |
583 |
584 |
// get (indexed) output file name(s) |
585 |
if (pout) sprintf(fbuf, pout, seq); |
586 |
587 |
588 |
if (ralrm > 0) { // start report if requested |
589 |
if (myRPmanager.NThreads() > 1) |
590 |
sprintf(errmsg, "%2d processes ", myRPmanager.NThreads()); |
591 |
else |
592 |
sprintf(errmsg, "PID %6d ", getpid()); |
593 |
eputs(errmsg); |
594 |
if (seq) { |
595 |
sprintf(errmsg, "rendering frame %5d ", seq); |
596 |
eputs(errmsg); |
597 |
} else |
598 |
eputs("rendering picture "); |
599 |
if (pout) { |
600 |
sprintf(errmsg, "to '%s'\n", fbuf); |
601 |
eputs(errmsg); |
602 |
} else |
603 |
eputs("to stdout\n"); |
604 |
if (zout) { |
605 |
sprintf(errmsg, "\twith %s depth map in '%s'\n", |
606 |
RDTdepthT(dtype)==RDTdshort ? |
607 |
"encoded 16-bit" : "raw float", |
608 |
dbuf); |
609 |
eputs(errmsg); |
610 |
611 |
612 |
// set up view and size |
613 |
int xydim[2] = {hresolu, vresolu}; |
614 |
if (!myRPmanager.NewFrame(ourview, xydim, &pixaspect)) |
615 |
error(USER, "NewFrame() failed"); |
616 |
617 |
myRPmanager.frameNo = seq; |
618 |
619 |
errno = 0; // render frame, skipping if it exists |
620 |
if (!myRPmanager.RenderFrame(pout ? fbuf : pout, dtype, |
621 |
zout ? dbuf : zout) |
622 |
&& !seq | (errno != EEXIST)) |
623 |
error(USER, "RenderFrame() failed"); |
624 |
} while (seq++); // all done if not a sequence |
625 |
