| 1 |
#ifndef lint |
| 2 |
static const char       RCSid[] = "$Id: rxpmain.cpp,v 2.9 2025/06/05 18:26:46 greg Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
 *  rxpmain.cpp - main for rxpict batch rendering program |
| 6 |
| 7 |
| 8 |
#include "copyright.h" |
| 9 |
| 10 |
#include  <time.h> |
| 11 |
#include  <signal.h> |
| 12 |
| 13 |
#include  "rtprocess.h" /* getpid() */ |
| 14 |
#include  "platform.h" |
| 15 |
#include  "RpictSimulManager.h" |
| 16 |
#include  "func.h" |
| 17 |
| 18 |
const char  *sigerr[NSIG];              /* signal error messages */ |
| 19 |
char  *errfile = NULL;                  /* error output file */ |
| 20 |
| 21 |
VIEW  ourview = STDVIEW;                /* view parameters */ |
| 22 |
int  hresolu = 512;                     /* horizontal resolution */ |
| 23 |
int  vresolu = 512;                     /* vertical resolution */ |
| 24 |
double  pixaspect = 1.0;                /* pixel aspect ratio */ |
| 25 |
int  hres, vres;                        /* current image resolution for srcdraw.c */ |
| 26 |
| 27 |
int  psample = 4;                       /* pixel sample size */ |
| 28 |
double  maxdiff = .05;                  /* max. difference for interpolation */ |
| 29 |
double  dstrpix = 0.67;                 /* square pixel distribution */ |
| 30 |
| 31 |
double  mblur = 0.;                     /* motion blur parameter */ |
| 32 |
| 33 |
double  dblur = 0.;                     /* depth-of-field blur parameter */ |
| 34 |
| 35 |
int  nproc = 1;                         /* number of processes to run */ |
| 36 |
| 37 |
int  ralrm = 0;                         /* seconds between reports */ |
| 38 |
| 39 |
double  pctdone = 0.0;                  /* percentage done */ |
| 40 |
time_t  tlastrept = 0L;                 /* time at last report */ |
| 41 |
time_t  tstart;                         /* starting time */ |
| 42 |
| 43 |
RenderDataType  dtype = RDTrgbe;        // output data flags |
| 44 |
| 45 |
RpictSimulManager       myRPmanager;    // global simulation manager |
| 46 |
| 47 |
static void onsig(int signo); |
| 48 |
static void sigdie(int  signo, const char  *msg); |
| 49 |
static void printdefaults(void); |
| 50 |
| 51 |
                                        /* rxpict additional features */ |
| 52 |
#define RXPICT_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \ |
| 53 |
                "ParticipatingMedia=Mist\n" \ |
| 54 |
                "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \ |
| 55 |
                "PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \ |
| 56 |
                "SmallSourceDrawing\nViewSequence\nProgressReporting\n" \ |
| 57 |
                "AdaptiveShadowTesting\nOutputFormats=f,c\nOutputs=v,l\n" \ |
| 58 |
                "OutputCS=RGB,XYZ,prims,spec\n" |
| 59 |
| 60 |
void |
| 61 |
quit(int code)                  /* quit program */ |
| 62 |
| 63 |
        exit(code);             // don't bother about freeing anything |
| 64 |
| 65 |
| 66 |
/* Set default options */ |
| 67 |
static void |
| 68 |
default_options(void) |
| 69 |
| 70 |
        shadthresh = .05; |
| 71 |
        shadcert = .5; |
| 72 |
        srcsizerat = .25; |
| 73 |
        directrelay = 1; |
| 74 |
        ambacc = 0.2; |
| 75 |
        ambres = 64; |
| 76 |
        ambdiv = 512; |
| 77 |
        ambssamp = 128; |
| 78 |
        maxdepth = 7; |
| 79 |
| 80 |
| 81 |
int |
| 82 |
main(int  argc, char  *argv[]) |
| 83 |
| 84 |
#define  check(ol,al)           if (argv[i][ol] || \ |
| 85 |
                                badarg(argc-i-1,argv+i+1,al)) \ |
| 86 |
                                goto badopt |
| 87 |
#define  check_bool(olen,var)           switch (argv[i][olen]) { \ |
| 88 |
                                case '\0': var = !var; break; \ |
| 89 |
                                case 'y': case 'Y': case 't': case 'T': \ |
| 90 |
                                case '+': case '1': var = 1; break; \ |
| 91 |
                                case 'n': case 'N': case 'f': case 'F': \ |
| 92 |
                                case '-': case '0': var = 0; break; \ |
| 93 |
                                default: goto badopt; } |
| 94 |
        RGBPRIMS  our_prims;            /* private output color primitives */ |
| 95 |
        int  seqstart = 0; |
| 96 |
        char  *recover = NULL; |
| 97 |
        char  *outfile = NULL; |
| 98 |
        char  *zfile = NULL; |
| 99 |
        int     outfmt = 'c'; |
| 100 |
        int  rval; |
| 101 |
        int  i; |
| 102 |
                                        /* record start time */ |
| 103 |
        tstart = time(NULL); |
| 104 |
                                        /* global program name */ |
| 105 |
        progname = argv[0]; |
| 106 |
                                        /* feature check only? */ |
| 107 |
        strcat(RFeatureList, RXPICT_FEATURES); |
| 108 |
        if (argc > 1 && !strcmp(argv[1], "-features")) |
| 109 |
                return feature_status(argc-2, argv+2); |
| 110 |
                                        /* initialize calcomp routines */ |
| 111 |
        initfunc(); |
| 112 |
                                        /* set defaults */ |
| 113 |
        default_options(); |
| 114 |
                                        /* option city */ |
| 115 |
        for (i = 1; i < argc; i++) { |
| 116 |
                                                /* expand arguments */ |
| 117 |
                while ((rval = expandarg(&argc, &argv, i)) > 0) |
| 118 |
| 119 |
                if (rval < 0) { |
| 120 |
                        sprintf(errmsg, "cannot expand '%s'", argv[i]); |
| 121 |
                        error(SYSTEM, errmsg); |
| 122 |
| 123 |
                if (argv[i] == NULL || argv[i][0] != '-') |
| 124 |
                        break;                  /* break from options */ |
| 125 |
                if (!strcmp(argv[i], "-version")) { |
| 126 |
                        puts(VersionID); |
| 127 |
                        quit(0); |
| 128 |
| 129 |
                if (!strcmp(argv[i], "-defaults") || |
| 130 |
                                !strcmp(argv[i], "-help")) { |
| 131 |
                        printdefaults(); |
| 132 |
                        quit(0); |
| 133 |
| 134 |
                rval = getrenderopt(argc-i, argv+i); |
| 135 |
                if (rval >= 0) { |
| 136 |
                        i += rval; |
| 137 |
                        continue; |
| 138 |
| 139 |
                rval = getviewopt(&ourview, argc-i, argv+i); |
| 140 |
                if (rval >= 0) { |
| 141 |
                        i += rval; |
| 142 |
                        continue; |
| 143 |
| 144 |
                                                /* rxpict options */ |
| 145 |
                switch (argv[i][1]) { |
| 146 |
                case 'v':                               /* view file */ |
| 147 |
                        if (argv[i][2] != 'f') |
| 148 |
                                goto badopt; |
| 149 |
                        check(3,"s"); |
| 150 |
                        rval = viewfile(argv[++i], &ourview, NULL); |
| 151 |
                        if (rval < 0) { |
| 152 |
                                sprintf(errmsg, |
| 153 |
                                "cannot open view file \"%s\"", |
| 154 |
                                                argv[i]); |
| 155 |
| 156 |
                        } else if (rval == 0) { |
| 157 |
                                sprintf(errmsg, |
| 158 |
                                        "bad view file \"%s\"", |
| 159 |
                                                argv[i]); |
| 160 |
                                error(USER, errmsg); |
| 161 |
| 162 |
                        break; |
| 163 |
                case 'n':                               /* number of processes */ |
| 164 |
                        check(2,"i"); |
| 165 |
                        nproc = atoi(argv[++i]); |
| 166 |
                        if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0) |
| 167 |
                                nproc = 1; |
| 168 |
                        break; |
| 169 |
                case 'f':                               /* output format */ |
| 170 |
                        if ((argv[i][2] != 'c') & (argv[i][2] != 'f') |
| 171 |
                                        || argv[i][3]) |
| 172 |
                                goto badopt; |
| 173 |
                        outfmt = argv[i][2]; |
| 174 |
                        break; |
| 175 |
                case 'p':                               /* pixel */ |
| 176 |
                        switch (argv[i][2]) { |
| 177 |
                        case 's':                               /* sample */ |
| 178 |
                                check(3,"i"); |
| 179 |
                                psample = atoi(argv[++i]); |
| 180 |
                                if (psample < 1) psample = 1; |
| 181 |
                                break; |
| 182 |
                        case 't':                               /* threshold */ |
| 183 |
                                check(3,"f"); |
| 184 |
                                maxdiff = atof(argv[++i]); |
| 185 |
                                break; |
| 186 |
                        case 'j':                               /* jitter */ |
| 187 |
                                check(3,"f"); |
| 188 |
                                dstrpix = atof(argv[++i]); |
| 189 |
                                break; |
| 190 |
                        case 'a':                               /* aspect */ |
| 191 |
                                check(3,"f"); |
| 192 |
                                pixaspect = atof(argv[++i]); |
| 193 |
                                break; |
| 194 |
                        case 'm':                               /* motion */ |
| 195 |
                                check(3,"f"); |
| 196 |
                                mblur = atof(argv[++i]); |
| 197 |
                                mblur *= (mblur > 0); |
| 198 |
                                break; |
| 199 |
                        case 'd':                               /* aperture */ |
| 200 |
                                check(3,"f"); |
| 201 |
                                dblur = atof(argv[++i]); |
| 202 |
                                dblur *= (dblur > 0); |
| 203 |
                                break; |
| 204 |
                        case 'R':                               /* standard RGB output */ |
| 205 |
                                if (strcmp(argv[i]+2, "RGB")) |
| 206 |
                                        goto badopt; |
| 207 |
                                myRPmanager.prims = stdprims; |
| 208 |
                                dtype = RDTnewCT(dtype, RDTrgbe); |
| 209 |
                                break; |
| 210 |
                        case 'X':                               /* XYZ output */ |
| 211 |
                                if (strcmp(argv[i]+2, "XYZ")) |
| 212 |
                                        goto badopt; |
| 213 |
                                myRPmanager.prims = xyzprims; |
| 214 |
                                dtype = RDTnewCT(dtype, RDTxyze); |
| 215 |
                                break; |
| 216 |
                        case 'c':                               /* chromaticities */ |
| 217 |
                                check(3,"ffffffff"); |
| 218 |
                                rval = 0; |
| 219 |
                                for (int j = 0; j < 8; j++) { |
| 220 |
                                        our_prims[0][j] = atof(argv[++i]); |
| 221 |
                                        rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001; |
| 222 |
| 223 |
                                if (rval) { |
| 224 |
                                        if (!colorprimsOK(our_prims)) |
| 225 |
                                                error(USER, "illegal primary chromaticities"); |
| 226 |
                                        myRPmanager.prims = our_prims; |
| 227 |
                                } else |
| 228 |
| 229 |
| 230 |
                                break; |
| 231 |
                        default: |
| 232 |
                                goto badopt; |
| 233 |
| 234 |
                        break; |
| 235 |
                case 'd':                               /* reference depth */ |
| 236 |
                        if (argv[i][2] || !myRPmanager.SetReferenceDepth(argv[++i])) |
| 237 |
                                goto badopt; |
| 238 |
                        dtype = RDTnewDT(dtype, RDTdshort); |
| 239 |
                        break; |
| 240 |
                case 'x':                               /* x resolution */ |
| 241 |
                        check(2,"i"); |
| 242 |
                        hresolu = atoi(argv[++i]); |
| 243 |
                        break; |
| 244 |
                case 'y':                               /* y resolution */ |
| 245 |
                        check(2,"i"); |
| 246 |
                        vresolu = atoi(argv[++i]); |
| 247 |
                        break; |
| 248 |
                case 'S':                               /* start index */ |
| 249 |
                        check(2,"i"); |
| 250 |
                        seqstart = atoi(argv[++i]); |
| 251 |
                        seqstart *= (seqstart > 0); |
| 252 |
                        break; |
| 253 |
                case 'o':                               /* output file */ |
| 254 |
                        check(2,"s"); |
| 255 |
                        outfile = argv[++i]; |
| 256 |
                        break; |
| 257 |
                case 'z':                               /* z file */ |
| 258 |
                        check(2,"s"); |
| 259 |
                        zfile = argv[++i]; |
| 260 |
                        break; |
| 261 |
                case 'r':                               /* recover file */ |
| 262 |
                        if (argv[i][2] == 'o') {                /* +output */ |
| 263 |
                                check(3,"s"); |
| 264 |
                                outfile = argv[i+1]; |
| 265 |
                        } else |
| 266 |
                                check(2,"s"); |
| 267 |
                        recover = argv[++i]; |
| 268 |
                        break; |
| 269 |
#if MAXCSAMP>3 |
| 270 |
                case 'c':                               /* output spectral results */ |
| 271 |
                        if (argv[i][2] != 'o') |
| 272 |
                                goto badopt; |
| 273 |
                        rval = (myRPmanager.prims == NULL); |
| 274 |
                        check_bool(3,rval); |
| 275 |
                        if (rval) |
| 276 |
                                myRPmanager.prims = NULL; |
| 277 |
                        else if (myRPmanager.prims == NULL) |
| 278 |
| 279 |
                        dtype = RDTnewCT(dtype, rval ? RDTscolr : RDTrgbe); |
| 280 |
                        break; |
| 281 |
#endif |
| 282 |
                case 't':                               /* timer */ |
| 283 |
                        check(2,"i"); |
| 284 |
                        ralrm = atoi(argv[++i]); |
| 285 |
                        break; |
| 286 |
                case 'w':                               /* warnings */ |
| 287 |
                        rval = erract[WARNING].pf != NULL; |
| 288 |
                        check_bool(2,rval); |
| 289 |
                        if (rval) erract[WARNING].pf = wputs; |
| 290 |
                        else erract[WARNING].pf = NULL; |
| 291 |
                        break; |
| 292 |
                case 'e':                               /* error file */ |
| 293 |
                        check(2,"s"); |
| 294 |
                        errfile = argv[++i]; |
| 295 |
                        break; |
| 296 |
                default: |
| 297 |
                        goto badopt; |
| 298 |
| 299 |
| 300 |
        if (maxdiff <= FTINY)           /* check for useless sampling */ |
| 301 |
                psample = 1; |
| 302 |
        if (zfile == NULL)              /* set up depth output */ |
| 303 |
                dtype = RDTnewDT(dtype, RDTnone); |
| 304 |
        else if (!RDTdepthT(dtype)) |
| 305 |
                dtype = RDTnewDT(dtype, RDTdfloat); |
| 306 |
                                        /* check pixel output type */ |
| 307 |
        if ((myRPmanager.prims == NULL) & (NCSAMP == 3)) { |
| 308 |
| 309 |
| 310 |
| 311 |
        if (outfmt == 'f') |
| 312 |
                switch (RDTcolorT(dtype)) { |
| 313 |
                case RDTrgbe: |
| 314 |
                        dtype = RDTnewCT(dtype, RDTrgb); |
| 315 |
                        break; |
| 316 |
                case RDTxyze: |
| 317 |
                        dtype = RDTnewCT(dtype, RDTxyz); |
| 318 |
                        break; |
| 319 |
                case RDTscolr: |
| 320 |
                        dtype = RDTnewCT(dtype, RDTscolor); |
| 321 |
                        break; |
| 322 |
                case RDTrgb: |
| 323 |
                case RDTxyz: |
| 324 |
                case RDTscolor: |
| 325 |
                        break; |
| 326 |
                default: |
| 327 |
                        error(INTERNAL, "botched color output type"); |
| 328 |
| 329 |
                                        /* set up signal handling */ |
| 330 |
        sigdie(SIGINT, "Interrupt"); |
| 331 |
#ifdef SIGHUP |
| 332 |
        sigdie(SIGHUP, "Hangup"); |
| 333 |
#endif |
| 334 |
        sigdie(SIGTERM, "Terminate"); |
| 335 |
#ifdef SIGPIPE |
| 336 |
        sigdie(SIGPIPE, "Broken pipe"); |
| 337 |
#endif |
| 338 |
#ifdef SIGALRM |
| 339 |
        sigdie(SIGALRM, "Alarm clock"); |
| 340 |
#endif |
| 341 |
#ifdef  SIGXCPU |
| 342 |
        sigdie(SIGXCPU, "CPU limit exceeded"); |
| 343 |
        sigdie(SIGXFSZ, "File size exceeded"); |
| 344 |
#endif |
| 345 |
                                        /* open error file */ |
| 346 |
        if (errfile != NULL) { |
| 347 |
                if (freopen(errfile, "a", stderr) == NULL) |
| 348 |
                        quit(2); |
| 349 |
                fprintf(stderr, "**************\n*** PID %5d: ", |
| 350 |
                                getpid()); |
| 351 |
                printargs(argc, argv, stderr); |
| 352 |
                putc('\n', stderr); |
| 353 |
                fflush(stderr); |
| 354 |
| 355 |
#ifdef  NICE |
| 356 |
        nice(NICE);                     /* lower priority */ |
| 357 |
#endif |
| 358 |
        if (i < argc-1) |
| 359 |
                goto badopt; |
| 360 |
                                        // load octree |
| 361 |
        if (!myRPmanager.LoadOctree(argv[i])) |
| 362 |
                error(USER, "missing octree argument"); |
| 363 |
                                        // add new header info |
| 364 |
        myRPmanager.AddHeader(i, argv); |
| 365 |
| 366 |
                char    buf[128] = "SOFTWARE= "; |
| 367 |
                strcpy(buf+10, VersionID); |
| 368 |
                myRPmanager.AddHeader(buf); |
| 369 |
| 370 |
                                        // start our engines |
| 371 |
        nproc = myRPmanager.SetThreadCount(nproc); |
| 372 |
                                        // batch render picture(s) |
| 373 |
        rpict(seqstart, outfile, zfile, recover); |
| 374 |
| 375 |
        quit(0);                        // clean up and exit |
| 376 |
| 377 |
badopt: |
| 378 |
        sprintf(errmsg, "command line error at '%s'", argv[i]); |
| 379 |
| 380 |
        return 1; /* pro forma return */ |
| 381 |
| 382 |
#undef  check |
| 383 |
#undef  check_bool |
| 384 |
| 385 |
| 386 |
| 387 |
void |
| 388 |
wputs(                          /* warning output function */ |
| 389 |
        const char      *s |
| 390 |
| 391 |
| 392 |
        int  lasterrno = errno; |
| 393 |
        eputs(s); |
| 394 |
        errno = lasterrno; |
| 395 |
| 396 |
| 397 |
| 398 |
void |
| 399 |
eputs(                          /* put string to stderr */ |
| 400 |
        const char  *s |
| 401 |
| 402 |
| 403 |
        static int  midline = 0; |
| 404 |
| 405 |
        if (!*s) |
| 406 |
                return; |
| 407 |
        if (!midline++) { |
| 408 |
                fputs(progname, stderr); |
| 409 |
                fputs(": ", stderr); |
| 410 |
| 411 |
        fputs(s, stderr); |
| 412 |
        if (s[strlen(s)-1] == '\n') { |
| 413 |
                fflush(stderr); |
| 414 |
                midline = 0; |
| 415 |
| 416 |
| 417 |
| 418 |
| 419 |
static void |
| 420 |
onsig(                          /* fatal signal */ |
| 421 |
        int  signo |
| 422 |
| 423 |
| 424 |
        static int  gotsig = 0; |
| 425 |
| 426 |
        if (gotsig++)                   /* two signals and we're gone! */ |
| 427 |
                _exit(signo); |
| 428 |
| 429 |
#ifdef SIGALRM /* XXX how critical is this? */ |
| 430 |
        alarm(30);                      /* allow 30 seconds to clean up */ |
| 431 |
        signal(SIGALRM, SIG_DFL);       /* make certain we do die */ |
| 432 |
#endif |
| 433 |
        eputs("signal - "); |
| 434 |
        eputs(sigerr[signo]); |
| 435 |
        eputs("\n"); |
| 436 |
        quit(3); |
| 437 |
| 438 |
| 439 |
| 440 |
static void |
| 441 |
sigdie(                 /* set fatal signal */ |
| 442 |
        int  signo, |
| 443 |
        const char  *msg |
| 444 |
| 445 |
| 446 |
        if (signal(signo, onsig) == SIG_IGN) |
| 447 |
                signal(signo, SIG_IGN); |
| 448 |
        sigerr[signo] = msg; |
| 449 |
| 450 |
| 451 |
| 452 |
static void |
| 453 |
printdefaults(void)                     /* print default values to stdout */ |
| 454 |
| 455 |
        printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); |
| 456 |
        printf("-vt%c\t\t\t\t# view type %s\n", ourview.type, |
| 457 |
                        ourview.type==VT_PER ? "perspective" : |
| 458 |
                        ourview.type==VT_PAR ? "parallel" : |
| 459 |
                        ourview.type==VT_HEM ? "hemispherical" : |
| 460 |
                        ourview.type==VT_ANG ? "angular" : |
| 461 |
                        ourview.type==VT_CYL ? "cylindrical" : |
| 462 |
                        ourview.type==VT_PLS ? "planisphere" : |
| 463 |
                        "unknown"); |
| 464 |
        printf("-vp %f %f %f\t# view point\n", |
| 465 |
                        ourview.vp[0], ourview.vp[1], ourview.vp[2]); |
| 466 |
        printf("-vd %f %f %f\t# view direction\n", |
| 467 |
                        ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]); |
| 468 |
        printf("-vu %f %f %f\t# view up\n", |
| 469 |
                        ourview.vup[0], ourview.vup[1], ourview.vup[2]); |
| 470 |
        printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz); |
| 471 |
        printf("-vv %f\t\t\t# view vertical size\n", ourview.vert); |
| 472 |
        printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore); |
| 473 |
        printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft); |
| 474 |
        printf("-vs %f\t\t\t# view shift\n", ourview.hoff); |
| 475 |
        printf("-vl %f\t\t\t# view lift\n", ourview.voff); |
| 476 |
        printf("-x  %-9d\t\t\t# x resolution\n", hresolu); |
| 477 |
        printf("-y  %-9d\t\t\t# y resolution\n", vresolu); |
| 478 |
        if (myRPmanager.prims == stdprims) |
| 479 |
                printf("-pRGB\t\t\t\t# standard RGB color output\n"); |
| 480 |
        else if (myRPmanager.prims == xyzprims) |
| 481 |
                printf("-pXYZ\t\t\t\t# CIE XYZ color output\n"); |
| 482 |
        else if (myRPmanager.prims != NULL) |
| 483 |
                printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n", |
| 484 |
                                myRPmanager.prims[RED][0], myRPmanager.prims[RED][1], |
| 485 |
                                myRPmanager.prims[GRN][0], myRPmanager.prims[GRN][1], |
| 486 |
                                myRPmanager.prims[BLU][0], myRPmanager.prims[BLU][1], |
| 487 |
                                myRPmanager.prims[WHT][0], myRPmanager.prims[WHT][1]); |
| 488 |
        if (NCSAMP > 3) |
| 489 |
                printf(myRPmanager.prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" : |
| 490 |
                                "-co+\t\t\t\t# output spectral values\n"); |
| 491 |
        printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect); |
| 492 |
        printf("-pj %f\t\t\t# pixel jitter\n", dstrpix); |
| 493 |
        printf("-pm %f\t\t\t# pixel motion\n", mblur); |
| 494 |
        printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur); |
| 495 |
        printf("-ps %-9d\t\t\t# pixel sample\n", psample); |
| 496 |
        printf("-pt %f\t\t\t# pixel threshold\n", maxdiff); |
| 497 |
        printf("-t  %-9d\t\t\t# time between reports\n", ralrm); |
| 498 |
        printf(erract[WARNING].pf != NULL ? |
| 499 |
                        "-w+\t\t\t\t# warning messages on\n" : |
| 500 |
                        "-w-\t\t\t\t# warning messages off\n"); |
| 501 |
        print_rdefaults(); |
| 502 |
| 503 |
| 504 |
| 505 |
// my progress report call-back |
| 506 |
static void |
| 507 |
progReporter(double pct) |
| 508 |
| 509 |
        static time_t   lastReportTime = 0; |
| 510 |
        time_t          tnow = time(NULL); |
| 511 |
| 512 |
        if (pct < 100.-FTINY && tnow - lastReportTime < ralrm) |
| 513 |
                return;                 // too soon, my Precious... |
| 514 |
| 515 |
        sprintf(errmsg, "%7.3f%% done after %7.3f hours\n", pct, (tnow-tstart)/3600.); |
| 516 |
        eputs(errmsg); |
| 517 |
                                        // reset timer at 100% |
| 518 |
        lastReportTime = tnow * (pct < 100.-FTINY); |
| 519 |
| 520 |
| 521 |
| 522 |
// Principal function for rpict execution (prototype in ray.h for some reason) |
| 523 |
void |
| 524 |
rpict(int seq, char *pout, char *zout, char *prvr) |
| 525 |
| 526 |
 * If seq is greater than zero, we will render a sequence of |
| 527 |
 * images based on view parameter strings read from the standard input. |
| 528 |
 * If pout is NULL, then all images will be sent to the standard ouput. |
| 529 |
 * If seq is greater than zero and prvr is an integer, then it is the |
| 530 |
 * frame number at which rendering should begin.  Preceeding view parameter |
| 531 |
 * strings will be skipped in the input. |
| 532 |
 * Note that pout and zout should contain %d format specifications for |
| 533 |
 * sequenced file naming. |
| 534 |
| 535 |
| 536 |
        char  fbuf[256], dbuf[256]; |
| 537 |
| 538 |
        if (!zout ^ !RDTdepthT(dtype)) |
| 539 |
                error(INTERNAL, "output depth type requires spec and vice versa"); |
| 540 |
| 541 |
        if (prvr && isint(prvr)) {      // sequence recovery? |
| 542 |
                if (!seq) |
| 543 |
                        error(USER, "sequence recovery requires starting frame"); |
| 544 |
                if (!pout) |
| 545 |
                        error(USER, "need output spec for sequence recovery"); |
| 546 |
                int     rno = atoi(prvr); |
| 547 |
                if (rno < seq) |
| 548 |
                        error(USER, "recovery frame before starting frame"); |
| 549 |
                while (seq <= rno) { |
| 550 |
                        if (!fgets(fbuf, sizeof(fbuf), stdin)) |
| 551 |
                                error(USER, "recovery frame past end of sequence"); |
| 552 |
                        seq += (isview(fbuf) && sscanview(&ourview, fbuf) > 0); |
| 553 |
| 554 |
                sprintf(prvr=fbuf, pout, rno); |
| 555 |
| 556 |
        if (ralrm > 0) |
| 557 |
                myRPmanager.prCB = progReporter; |
| 558 |
        else |
| 559 |
                myRPmanager.prCB = NULL; |
| 560 |
        if (prvr) {                     // recovering partial render? |
| 561 |
                if ((seq > 0) & (prvr != fbuf)) |
| 562 |
                        error(USER, "recover spec must be number in sequence"); |
| 563 |
                if (zout) sprintf(dbuf, zout, seq); |
| 564 |
                if (ralrm > 0) { |
| 565 |
                        sprintf(errmsg, "resuming partial rendering '%s'\n", prvr); |
| 566 |
                        eputs(errmsg); |
| 567 |
| 568 |
                dtype = myRPmanager.ResumeFrame(prvr, zout ? dbuf : zout); |
| 569 |
                if (!dtype) |
| 570 |
                        error(USER, "ResumeFrame() failed"); |
| 571 |
                if (!seq) |
| 572 |
                        return;         // all done if not a sequence |
| 573 |
| 574 |
        do { |
| 575 |
                if (prvr)               // have view from sequence recovery? |
| 576 |
                        prvr = NULL; |
| 577 |
                else if (seq) {         // else read next view in sequence |
| 578 |
                        while (fgets(fbuf, sizeof(fbuf), stdin)) |
| 579 |
                                if (isview(fbuf) && sscanview(&ourview, fbuf) > 0) |
| 580 |
                                        break; |
| 581 |
                        if (feof(stdin)) |
| 582 |
                                return; // reached end of view input |
| 583 |
| 584 |
                                        // get (indexed) output file name(s) |
| 585 |
                if (pout) sprintf(fbuf, pout, seq); |
| 586 |
| 587 |
| 588 |
                if (ralrm > 0) {        // start report if requested |
| 589 |
                        if (myRPmanager.NThreads() > 1) |
| 590 |
                                sprintf(errmsg, "%2d processes ", myRPmanager.NThreads()); |
| 591 |
                        else |
| 592 |
                                sprintf(errmsg, "PID %6d ", getpid()); |
| 593 |
                        eputs(errmsg); |
| 594 |
                        if (seq) { |
| 595 |
                                sprintf(errmsg, "rendering frame %5d ", seq); |
| 596 |
                                eputs(errmsg); |
| 597 |
                        } else |
| 598 |
                                eputs("rendering picture "); |
| 599 |
                        if (pout) { |
| 600 |
                                sprintf(errmsg, "to '%s'\n", fbuf); |
| 601 |
                                eputs(errmsg); |
| 602 |
                        } else |
| 603 |
                                eputs("to stdout\n"); |
| 604 |
                        if (zout) { |
| 605 |
                                sprintf(errmsg, "\twith %s depth map in '%s'\n", |
| 606 |
                                                RDTdepthT(dtype)==RDTdshort ? |
| 607 |
                                                        "encoded 16-bit" : "raw float", |
| 608 |
                                                dbuf); |
| 609 |
                                eputs(errmsg); |
| 610 |
| 611 |
| 612 |
                                        // set up view and size |
| 613 |
                int     xydim[2] = {hresolu, vresolu}; |
| 614 |
                if (!myRPmanager.NewFrame(ourview, xydim, &pixaspect)) |
| 615 |
                        error(USER, "NewFrame() failed"); |
| 616 |
| 617 |
                myRPmanager.frameNo = seq; |
| 618 |
| 619 |
                errno = 0;              // render frame, skipping if it exists |
| 620 |
                if (!myRPmanager.RenderFrame(pout ? fbuf : pout, dtype, |
| 621 |
                                                        zout ? dbuf : zout) |
| 622 |
                                        && !seq | (errno != EEXIST)) |
| 623 |
                        error(USER, "RenderFrame() failed"); |
| 624 |
        } while (seq++);                // all done if not a sequence |
| 625 |
