root/radiance/ray/src/rt/rxpiece.cpp
Revision: 2.11
Committed: Tue Apr 22 17:12:25 2025 UTC (4 weeks, 4 days ago) by greg
Changes since 2.10: +4 -1 lines
2 static const char RCSid[] = "$Id: rxpiece.cpp,v 2.10 2025/01/09 17:25:37 greg Exp $";
5 * rxpiece.cpp - main for rxpiece tile rendering program
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11 #include <signal.h>
12 #include <sys/mman.h>
13 #include <unistd.h>
14
15 #include "platform.h"
16 #include "RpictSimulManager.h"
17 #include "func.h"
18 #include "ambient.h"
19 #include "pmapray.h"
20 #include "random.h"
21
22 extern char *progname; /* argv[0] */
23 const char *sigerr[NSIG]; /* signal error messages */
24
25 VIEW ourview = STDVIEW; /* global view parameters */
26 int hresolu = 1024; /* horizontal resolution */
27 int vresolu = 1024; /* vertical resolution */
28 double pixaspect = 1.0; /* pixel aspect ratio */
29 int hres, vres; /* current image resolution for srcdraw.c */
30
31 int tileGrid[2] = {5,5}; // tile subdivisions
32
33 int psample = 4; /* pixel sample size */
34 double maxdiff = .05; /* max. difference for interpolation */
35 double dstrpix = 0.67; /* square pixel distribution */
36
37 double mblur = 0.; /* motion blur parameter (unused) */
38
39 double dblur = 0.; /* depth-of-field blur parameter */
40
41 int nproc = 1; /* number of processes to run (-1 in child) */
42
43 RpictSimulManager myRPmanager; // global simulation manager
44
45 static void onsig(int signo);
46 static void onalrm(int signo);
47 static void sigdie(int signo, const char *msg);
48 static void printdefaults(void);
49 static RenderDataType rpiece(char *pout, RenderDataType dt, char *zout);
50
51 /* rxpiece additional features */
52 #define RXPIECE_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
53 "ParticipatingMedia=Mist\n" \
54 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
55 "PixelJitter\nPixelSampling\nPixelDepthOfField\n" \
56 "SmallSourceDrawing\n" \
57 "AdaptiveShadowTesting\nOutputs=v,l\n" \
58 "OutputCS=RGB,XYZ,prims,spec\n"
59
60 // Exit program
61 void
62 quit(int code) /* quit program */
63 {
64 exit(code); // don't bother to free data structs
65 }
66
67 /* Set default options */
68 static void
69 default_options(void)
70 {
71 shadthresh = .05;
72 shadcert = .5;
73 srcsizerat = .25;
74 directrelay = 1;
75 ambacc = 0.2;
76 ambres = 64;
77 ambdiv = 512;
78 ambssamp = 128;
79 maxdepth = 7;
80 }
81
82 int
83 main(int argc, char *argv[])
84 {
85 #define check(ol,al) if (argv[i][ol] || \
86 badarg(argc-i-1,argv+i+1,al)) \
87 goto badopt
88 #define check_bool(olen,var) switch (argv[i][olen]) { \
89 case '\0': var = !var; break; \
90 case 'y': case 'Y': case 't': case 'T': \
91 case '+': case '1': var = 1; break; \
92 case 'n': case 'N': case 'f': case 'F': \
93 case '-': case '0': var = 0; break; \
94 default: goto badopt; }
95 RGBPRIMS our_prims; /* private output color primitives */
96 RenderDataType dtype = RDTrgbe; // output data flags
97 char *outfile = NULL;
98 char *zfile = NULL;
99 int outfmt = 'c';
100 int rval;
101 int i;
102 /* global program name */
103 progname = argv[0];
104 /* feature check only? */
105 strcat(RFeatureList, RXPIECE_FEATURES);
106 if (argc > 1 && !strcmp(argv[1], "-features"))
107 return feature_status(argc-2, argv+2);
108 /* initialize calcomp routines */
109 initfunc();
110 /* set defaults */
111 default_options();
112 /* option city */
113 for (i = 1; i < argc; i++) {
114 /* expand arguments */
115 while ((rval = expandarg(&argc, &argv, i)) > 0)
116 ;
117 if (rval < 0) {
118 sprintf(errmsg, "cannot expand '%s'", argv[i]);
119 error(SYSTEM, errmsg);
120 }
121 if (argv[i] == NULL || argv[i][0] != '-')
122 break; /* break from options */
123 if (!strcmp(argv[i], "-version")) {
124 puts(VersionID);
125 quit(0);
126 }
127 if (!strcmp(argv[i], "-defaults") ||
128 !strcmp(argv[i], "-help")) {
129 printdefaults();
130 quit(0);
131 }
132 rval = getrenderopt(argc-i, argv+i);
133 if (rval >= 0) {
134 i += rval;
135 continue;
136 }
137 rval = getviewopt(&ourview, argc-i, argv+i);
138 if (rval >= 0) {
139 i += rval;
140 continue;
141 }
142 /* rxpiece options */
143 switch (argv[i][1]) {
144 case 'v': /* view file */
145 if (argv[i][2] != 'f')
146 goto badopt;
147 check(3,"s");
148 rval = viewfile(argv[++i], &ourview, NULL);
149 if (rval < 0) {
150 sprintf(errmsg,
151 "cannot open view file \"%s\"",
152 argv[i]);
153 error(SYSTEM, errmsg);
154 } else if (rval == 0) {
155 sprintf(errmsg,
156 "bad view file \"%s\"",
157 argv[i]);
158 error(USER, errmsg);
159 }
160 break;
161 case 'n': /* number of processes */
162 check(2,"i");
163 nproc = atoi(argv[++i]);
164 if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0)
165 nproc = 1;
166 break;
167 case 'f': /* output format */
168 if ((argv[i][2] != 'c') & (argv[i][2] != 'f')
169 || argv[i][3])
170 goto badopt;
171 outfmt = argv[i][2];
172 break;
173 case 'p': /* pixel */
174 switch (argv[i][2]) {
175 case 's': /* sample */
176 check(3,"i");
177 psample = atoi(argv[++i]);
178 if (psample < 1) psample = 1;
179 break;
180 case 't': /* threshold */
181 check(3,"f");
182 maxdiff = atof(argv[++i]);
183 break;
184 case 'j': /* jitter */
185 check(3,"f");
186 dstrpix = atof(argv[++i]);
187 break;
188 case 'a': /* aspect */
189 check(3,"f");
190 pixaspect = atof(argv[++i]);
191 break;
192 case 'd': /* aperture */
193 check(3,"f");
194 dblur = atof(argv[++i]);
195 dblur *= (dblur > 0);
196 break;
197 case 'R': /* standard RGB output */
198 if (strcmp(argv[i]+2, "RGB"))
199 goto badopt;
200 myRPmanager.prims = stdprims;
201 dtype = RDTnewCT(dtype, RDTrgbe);
202 break;
203 case 'X': /* XYZ output */
204 if (strcmp(argv[i]+2, "XYZ"))
205 goto badopt;
206 myRPmanager.prims = xyzprims;
207 dtype = RDTnewCT(dtype, RDTxyze);
208 break;
209 case 'c': /* chromaticities */
210 check(3,"ffffffff");
211 rval = 0;
212 for (int j = 0; j < 8; j++) {
213 our_prims[0][j] = atof(argv[++i]);
214 rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
215 }
216 if (rval) {
217 if (!colorprimsOK(our_prims))
218 error(USER, "illegal primary chromaticities");
219 myRPmanager.prims = our_prims;
220 } else
221 myRPmanager.prims = stdprims;
222 dtype = RDTnewCT(dtype, RDTrgbe);
223 break;
224 default:
225 goto badopt;
226 }
227 break;
228 case 'd': /* reference depth */
229 if (argv[i][2] || !myRPmanager.SetReferenceDepth(argv[++i]))
230 goto badopt;
231 dtype = RDTnewDT(dtype, RDTdshort);
232 break;
233 case 'x': /* x resolution */
234 check(2,"i");
235 hresolu = atoi(argv[++i]);
236 break;
237 case 'y': /* y resolution */
238 check(2,"i");
239 vresolu = atoi(argv[++i]);
240 break;
241 case 'X': /* horizontal tile subdivisions */
242 check(2,"i");
243 tileGrid[0] = atoi(argv[++i]);
244 break;
245 case 'Y': /* vertical tile subdivisions */
246 check(2,"i");
247 tileGrid[1] = atoi(argv[++i]);
248 break;
249 case 'o': /* output file */
250 check(2,"s");
251 outfile = argv[++i];
252 break;
253 case 'z': /* z file */
254 check(2,"s");
255 zfile = argv[++i];
256 break;
257 #if MAXCSAMP>3
258 case 'c': /* output spectral results */
259 if (argv[i][2] != 'o')
260 goto badopt;
261 rval = (myRPmanager.prims == NULL);
262 check_bool(3,rval);
263 if (rval)
264 myRPmanager.prims = NULL;
265 else if (myRPmanager.prims == NULL)
266 myRPmanager.prims = stdprims;
267 dtype = RDTnewCT(dtype, rval ? RDTscolr : RDTrgbe);
268 break;
269 #endif
270 case 'w': /* warnings */
271 rval = erract[WARNING].pf != NULL;
272 check_bool(2,rval);
273 if (rval) erract[WARNING].pf = wputs;
274 else erract[WARNING].pf = NULL;
275 break;
276 default:
277 goto badopt;
278 }
279 }
280 if (maxdiff <= FTINY) /* check for useless sampling */
281 psample = 1;
282 if (outfile == NULL)
283 error(USER, "missing output file (-o option)");
284 if (zfile == NULL) /* set up depth output */
285 dtype = RDTnewDT(dtype, RDTnone);
286 else if (!RDTdepthT(dtype))
287 dtype = RDTnewDT(dtype, RDTdfloat);
288 /* check pixel output type */
289 if ((myRPmanager.prims == NULL) & (NCSAMP == 3)) {
290 myRPmanager.prims = stdprims;
291 dtype = RDTnewCT(dtype, RDTrgbe);
292 }
293 if (outfmt == 'f')
294 switch (RDTcolorT(dtype)) {
295 case RDTrgbe:
296 dtype = RDTnewCT(dtype, RDTrgb);
297 break;
298 case RDTxyze:
299 dtype = RDTnewCT(dtype, RDTxyz);
300 break;
301 case RDTscolr:
302 dtype = RDTnewCT(dtype, RDTscolor);
303 break;
304 case RDTrgb:
305 case RDTxyz:
306 case RDTscolor:
307 break;
308 default:
309 error(INTERNAL, "botched color output type");
310 }
311 /* set up signal handling */
312 sigdie(SIGINT, "Interrupt");
313 sigdie(SIGHUP, "Hangup");
314 sigdie(SIGTERM, "Terminate");
315 sigdie(SIGPIPE, "Broken pipe");
316 signal(SIGALRM, onalrm); // used to gracefully terminate
317 #ifdef SIGXCPU
318 sigdie(SIGXCPU, "CPU limit exceeded");
319 sigdie(SIGXFSZ, "File size exceeded");
320 #endif
321 #ifdef NICE
322 nice(NICE); /* lower priority */
323 #endif
324 if (i < argc-1)
325 goto badopt;
326 // load octree
327 if (!myRPmanager.LoadOctree(argv[i]))
328 error(USER, "missing octree argument");
329 // add new header info
330 myRPmanager.AddHeader(i, argv);
331 {
332 char buf[128] = "SOFTWARE= ";
333 strcpy(buf+10, VersionID);
334 myRPmanager.AddHeader(buf);
335 }
336 // render tiles
337 dtype = rpiece(outfile, dtype, zfile);
338
339 ambsync(); // flush ambient cache
340
341 ray_done_pmap(); /* PMAP: free photon maps */
342
343 quit(dtype==RDTnone); // status is 1 on failure
344
345 badopt:
346 sprintf(errmsg, "command line error at '%s'", argv[i]);
347 error(USER, errmsg);
348 return 1; /* pro forma return */
349
350 #undef check
351 #undef check_bool
352 }
353
354
355 void
356 wputs( /* warning output function */
357 const char *s
358 )
359 {
360 if (!erract[WARNING].pf)
361 return; // warnings were disabled!
362 int lasterrno = errno;
363 eputs(s);
364 errno = lasterrno;
365 }
366
367
368 void
369 eputs( /* put string to stderr */
370 const char *s
371 )
372 {
373 static int midline = 0;
374
375 if (!*s)
376 return;
377 if (!midline++) {
378 fputs(progname, stderr);
379 fputs(": ", stderr);
380 }
381 fputs(s, stderr);
382 if (s[strlen(s)-1] == '\n') {
383 fflush(stderr);
384 midline = 0;
385 }
386 }
387
388
389 static void
390 onsig( /* fatal signal */
391 int signo
392 )
393 {
394 static int gotsig = 0;
395
396 if (gotsig++) /* two signals and we're gone! */
397 _exit(signo);
398
399 alarm(30); /* allow 30 seconds to clean up */
400 signal(SIGALRM, SIG_DFL); /* make certain we do die */
401 eputs("signal - ");
402 eputs(sigerr[signo]);
403 eputs("\n");
404 quit(3);
405 }
406
407
408 static bool gotALRM = false; // flag for ALRM signal
409
410 static void
411 onalrm(int signo)
412 {
413 gotALRM = true;
414 }
415
416
417 static void
418 sigdie( /* set fatal signal */
419 int signo,
420 const char *msg
421 )
422 {
423 if (signal(signo, onsig) == SIG_IGN)
424 signal(signo, SIG_IGN);
425 sigerr[signo] = msg;
426 }
427
428
429 static void
430 printdefaults(void) /* print default values to stdout */
431 {
432 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
433 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
434 ourview.type==VT_PER ? "perspective" :
435 ourview.type==VT_PAR ? "parallel" :
436 ourview.type==VT_HEM ? "hemispherical" :
437 ourview.type==VT_ANG ? "angular" :
438 ourview.type==VT_CYL ? "cylindrical" :
439 ourview.type==VT_PLS ? "planisphere" :
440 "unknown");
441 printf("-vp %f %f %f\t# view point\n",
442 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
443 printf("-vd %f %f %f\t# view direction\n",
444 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
445 printf("-vu %f %f %f\t# view up\n",
446 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
447 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
448 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
449 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
450 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
451 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
452 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
453 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
454 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
455 printf("-X %-9d\t\t\t# horizontal tile divisions\n", tileGrid[0]);
456 printf("-Y %-9d\t\t\t# vertical tile divisions\n", tileGrid[1]);
457 if (myRPmanager.prims == stdprims)
458 printf("-pRGB\t\t\t\t# standard RGB color output\n");
459 else if (myRPmanager.prims == xyzprims)
460 printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
461 else if (myRPmanager.prims != NULL)
462 printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
463 myRPmanager.prims[RED][0], myRPmanager.prims[RED][1],
464 myRPmanager.prims[GRN][0], myRPmanager.prims[GRN][1],
465 myRPmanager.prims[BLU][0], myRPmanager.prims[BLU][1],
466 myRPmanager.prims[WHT][0], myRPmanager.prims[WHT][1]);
467 if (NCSAMP > 3)
468 printf(myRPmanager.prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
469 "-co+\t\t\t\t# output spectral values\n");
470 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
471 printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
472 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
473 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
474 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
475 printf(erract[WARNING].pf != NULL ?
476 "-w+\t\t\t\t# warning messages on\n" :
477 "-w-\t\t\t\t# warning messages off\n");
478 print_rdefaults();
479 }
480
481
482 // Struct for tracking tiles being rendered in mapped file / shared memory
483 struct TileProg {
484 short status; // 0==Unstarted, -1==InProgress, 1==Done
485 pid_t pID; // process operating on tile
486 } *tprog = NULL; // shared tile progress array
487
488 #define tile_p(ti) (tprog + (ti)[1]*tileGrid[0] + (ti)[0])
489
490 // Return true if tile is renderable
491 static bool
492 renderable_tile(TileProg *tp)
493 {
494 if (tp->status < 0 && kill(tp->pID, 0) < 0)
495 tp->status = 0; // dead process - reset
496
497 return !tp->status;
498 }
499
500
501 // handle multi-processing if requested, return true if all done
502 static bool
503 children_finished()
504 {
505 if (nproc <= 1) // single process -> run in parent
506 return false;
507 int cnt = 0; // else count ready-to-go tiles
508 int ti[2];
509 for (ti[1] = 0; ti[1] < tileGrid[1]; ti[1]++)
510 for (ti[0] = 0; ti[0] < tileGrid[0]; ti[0]++)
511 cnt += renderable_tile(tile_p(ti));
512 if (!cnt)
513 return false; // parent can do nothing
514 if (cnt < nproc) {
515 sprintf(errmsg, "only %d renderable tiles, reducing process count", cnt);
516 error(WARNING, errmsg);
517 if ((nproc = cnt) == 1)
518 return false; // back to single process
519 }
520 cow_memshare(); // else we'll be sharing memory
521 fflush(NULL); // and forking children
522 pid_t cpid; // create nproc children
523 for (cnt = nproc; cnt && (cpid = fork()) != 0; cnt--)
524 if (cpid < 0)
525 error(SYSTEM, "fork error!");
526
527 if (cpid == 0) { // children render tiles
528 sleep(nproc - cnt); // avoid race conditions
529 nproc = -1; // flag as child
530 return false;
531 }
532 cow_doneshare(); // parent frees memory and waits
533 signal(SIGALRM, SIG_IGN);
534 myRPmanager.Cleanup(true);
535 int nfailed = 0;
536 int status;
537 for (cnt = nproc; cnt && wait(&status) > 0; cnt--)
538 if (status) {
539 sprintf(errmsg, "child exited with status %d", status);
540 error(WARNING, errmsg);
541 if (!nfailed++ & (cnt > 1)) {
542 kill(0, SIGALRM);
543 error(WARNING, "waiting for other tiles to finish...");
544 }
545 }
546 if (cnt) {
547 sprintf(errmsg, "lost track of %d children", cnt);
548 error(WARNING, errmsg);
549 }
550 if (nfailed) {
551 sprintf(errmsg, "%d tiles were not completed", nfailed);
552 error(USER, errmsg);
553 }
554 return true; // all done!
555 }
556
557 // return next renderable tile, false if everything is done
558 static bool
559 nexttile(int ti[2])
560 {
561 static pid_t ourpID = 0;
562 static short * tlist = NULL;
563 static int tlen = 0;
564 static int tnext = 0;
565
566 if (gotALRM) { // pre-empting new work?
567 if (tlist) {
568 sprintf(errmsg, "process %d got alarm, exiting", ourpID);
569 CHECK(tnext<tlen, WARNING, errmsg);
570 free(tlist); tlist = NULL;
571 }
572 return false;
573 }
574 if (!tlist) { // initialize random tile list
575 ABitMap2 todoMap(tileGrid[0], tileGrid[1]);
576 tlen = 0;
577 for (ti[1] = 0; ti[1] < tileGrid[1]; ti[1]++)
578 for (ti[0] = 0; ti[0] < tileGrid[0]; ti[0]++)
579 if (renderable_tile(tile_p(ti))) {
580 todoMap.Set(ti[0], ti[1]);
581 tlen++;
582 }
583 if (!tlen)
584 return false; // nothing to do!
585 tlist = (short *)malloc(sizeof(short)*2*tlen);
586 CHECK(!tlist, SYSTEM, "out of memory in nexttile()");
587 tlen = 0; // assign entries
588 for (ti[0] = ti[1] = 0; todoMap.Find(&ti[0], &ti[1]); ti[0]++) {
589 tlist[2*tlen] = ti[0];
590 tlist[2*tlen+1] = ti[1];
591 tlen++;
592 }
593 // shuffle order w/ Fisher-Yates
594 for (int i = 0; i < tlen-1; i++) {
595 const int ix = irandom(tlen-i) + i;
596 ti[0] = tlist[2*i];
597 ti[1] = tlist[2*i+1];
598 tlist[2*i] = tlist[2*ix];
599 tlist[2*i+1] = tlist[2*ix+1];
600 tlist[2*ix] = ti[0];
601 tlist[2*ix+1] = ti[1];
602 }
603 ourpID = getpid(); // save time on system calls
604 }
605 while (tnext < tlen) { // find first available
606 ti[0] = tlist[2*tnext];
607 ti[1] = tlist[2*tnext+1];
608 tnext++; // take if still unclaimed
609 if (renderable_tile(tile_p(ti))) {
610 tile_p(ti)->status = -1;
611 tile_p(ti)->pID = ourpID;
612 return true;
613 }
614 }
615 free(tlist); tlist = NULL; // exhausted our list?
616 return false;
617 }
618
619
620 // Principal function for rpiece
621 static RenderDataType
622 rpiece(char *pout, RenderDataType dt, char *zout)
623 {
624 if (zout && *zout == '!')
625 error(USER, "cannot send depth to a command");
626
627 const bool newOutput = (access(pout, F_OK) < 0);
628 FILE *pdfp[2];
629 if (newOutput) { // new output file?
630 CHECK((tileGrid[0] <= 1) & (tileGrid[1] <= 1),
631 USER, "bad tiling specification");
632 } else {
633 dt = myRPmanager.ReopenOutput(pdfp, pout, zout);
634 if (dt == RDTnone)
635 return RDTnone;
636 if (!fscnresolu(&hresolu, &vresolu, pdfp[0]))
637 error(USER, "missing picture resolution");
638 pixaspect = .0; // need to leave this as is
639 myRPmanager.NewHeader(pout); // get prev. header info
640 const char * tval = myRPmanager.GetHeadStr("TILED=");
641 if (tval) sscanf(tval, "%d %d", &tileGrid[0], &tileGrid[1]);
642 CHECK(myRPmanager.GetView()==NULL,
643 USER, "missing view in picture file");
644 ourview = *myRPmanager.GetView();
645 }
646 int hvdim[2] = {hresolu, vresolu}; // set up tiled frame
647 if (!myRPmanager.NewFrame(ourview, hvdim, &pixaspect, tileGrid))
648 error(USER, "tiling setup error in rpiece");
649
650 if ((hvdim[0] != hresolu) | (hvdim[1] != vresolu)) {
651 if (!newOutput)
652 error(USER, "unexpected output size adjustment");
653 sprintf(errmsg, "resolution adjusted from %dx%d to %dx%d",
654 hresolu, vresolu, hvdim[0], hvdim[1]);
655 error(WARNING, errmsg);
656 hresolu = hvdim[0];
657 vresolu = hvdim[1];
658 }
659 if (newOutput){ // open new output here
660 char buf[64];
661 sprintf(buf, "TILED= %d %d\n", tileGrid[0], tileGrid[1]);
662 myRPmanager.AddHeader(buf);
663 dt = myRPmanager.NewOutput(pdfp, pout, dt, zout);
664 if (dt == RDTnone)
665 return RDTnone;
666 fprtresolu(hresolu, vresolu, pdfp[0]);
667 fflush(pdfp[0]);
668 if (RDTdepthT(dt) == RDTdshort) {
669 fprtresolu(hresolu, vresolu, pdfp[1]);
670 fflush(pdfp[1]);
671 }
672 } else if (RDTdepthT(dt) == RDTdshort &&
673 (!fscnresolu(&hvdim[0], &hvdim[1], pdfp[1]) ||
674 (hvdim[0] != hresolu) | (hvdim[1] != vresolu)))
675 error(USER, "mismatched depth file resolution");
676 // prepare (flat) pixel buffer
677 const long pdata_beg = ftell(pdfp[0]);
678 const size_t pixSiz = (RDTcolorT(dt)==RDTrgbe)|(RDTcolorT(dt)==RDTxyze) ? sizeof(COLR)
679 : (RDTcolorT(dt)==RDTrgb)|(RDTcolorT(dt)==RDTxyz) ? sizeof(COLORV)*3
680 : RDTcolorT(dt)==RDTscolr ? LSCOLR : sizeof(COLORV)*NCSAMP;
681 size_t pmlen = pdata_beg + pixSiz*hresolu*vresolu;
682 // put tile progress array at end
683 if (pmlen&7) pmlen += 8 - (pmlen&7); // 8-byte alignment to be safe
684 pmlen += sizeof(TileProg)*tileGrid[0]*tileGrid[1];
685 // map picture file to memory
686 if (newOutput && ftruncate(fileno(pdfp[0]), pmlen) < 0)
687 error(SYSTEM, "cannot extend picture buffer");
688 uby8 * pixMap = (uby8 *)mmap(NULL, pmlen, PROT_READ|PROT_WRITE,
689 MAP_SHARED, fileno(pdfp[0]), 0);
690 if ((void *)pixMap == MAP_FAILED)
691 error(SYSTEM, "cannot map picture file into memory");
692 // map depth buffer to memory
693 const long zdata_beg = RDTdepthT(dt) ? ftell(pdfp[1]) : 0L;
694 const size_t zdpSiz = RDTdepthT(dt)==RDTdshort ? sizeof(short) :
695 RDTdepthT(dt)==RDTdfloat ? sizeof(float) : 0;
696 const size_t zmlen = zdata_beg + zdpSiz*hresolu*vresolu;
697 uby8 * zdMap = NULL;
698 if (RDTdepthT(dt)) {
699 if (newOutput && ftruncate(fileno(pdfp[1]), zmlen) < 0)
700 error(SYSTEM, "cannot extend depth buffer");
701 zdMap = (uby8 *)mmap(NULL, zmlen, PROT_READ|PROT_WRITE,
702 MAP_SHARED, fileno(pdfp[1]), 0);
703 if ((void *)zdMap == MAP_FAILED)
704 error(SYSTEM, "cannot map depth file into memory");
705 }
706 fclose(pdfp[0]); // done with file pointers
707 if (RDTdepthT(dt)) fclose(pdfp[1]);
708 // point to tile progress array
709 tprog = (TileProg *)(pixMap + pmlen - sizeof(TileProg)*tileGrid[0]*tileGrid[1]);
710
711 if (children_finished()) // work done in children?
712 return dt;
713
714 int ndone = 0; // else render tiles
715 int ti[2];
716 while (nexttile(ti)) {
717 const int offset = (tileGrid[1]-1-ti[1])*myRPmanager.GetWidth()*myRPmanager.THeight() +
718 (myRPmanager.THeight()-1)*myRPmanager.GetWidth() +
719 ti[0]*myRPmanager.TWidth();
720 uby8 * pptr = pixMap + pdata_beg + pixSiz*offset;
721 uby8 * zptr = zdMap + zdata_beg + zdpSiz*offset;
722 bool ok = false;
723 switch (RDTcommonE(dt)<<1 | (RDTdepthT(dt)==RDTdshort)) {
724 case 2: // common-exponent color, float/no depth
725 ok = myRPmanager.RenderTile((COLRV *)pptr, -myRPmanager.GetWidth(),
726 (float *)zptr, ti);
727 break;
728 case 0: // float color, float/no depth
729 ok = myRPmanager.RenderTile((COLORV *)pptr, -myRPmanager.GetWidth(),
730 (float *)zptr, ti);
731 break;
732 case 3: // common-exponent color, encoded depth
733 ok = myRPmanager.RenderTile((COLRV *)pptr, -myRPmanager.GetWidth(),
734 (short *)zptr, ti);
735 break;
736 case 1: // float color, encoded depth
737 ok = myRPmanager.RenderTile((COLORV *)pptr, -myRPmanager.GetWidth(),
738 (short *)zptr, ti);
739 break;
740 }
741 if (!ok) { // got an error
742 sprintf(errmsg, "error rendering tile (%d,%d)/(%d,%d)",
743 ti[0], ti[1], tileGrid[0], tileGrid[1]);
744 error(USER, errmsg);
745 }
746 tile_p(ti)->status = 1; // mark tile completed
747 ndone++;
748 }
749 if (!ndone)
750 error(WARNING, "no tiles need rendering, exit");
751 /*
752 munmap(pixMap, pmlen); // technically unnecessary...
753 if (zdMap) munmap(zdMap, zmlen);
754 */
755 return dt; // we're done here
756 }
