| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rxpiece.cpp,v 2.7 2024/11/06 18:28:52 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rxpiece.cpp - main for rxpiece tile rendering program
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <time.h>
| 11 |
#include <signal.h>
| 12 |
#include <sys/mman.h>
| 13 |
#include <unistd.h>
| 14 |
| 15 |
#include "platform.h"
| 16 |
#include "RpictSimulManager.h"
| 17 |
#include "ambient.h"
| 18 |
#include "pmapray.h"
| 19 |
#include "random.h"
| 20 |
| 21 |
extern char *progname; /* argv[0] */
| 22 |
const char *sigerr[NSIG]; /* signal error messages */
| 23 |
| 24 |
VIEW ourview = STDVIEW; /* global view parameters */
| 25 |
int hresolu = 1024; /* horizontal resolution */
| 26 |
int vresolu = 1024; /* vertical resolution */
| 27 |
double pixaspect = 1.0; /* pixel aspect ratio */
| 28 |
int hres, vres; /* current image resolution for srcdraw.c */
| 29 |
| 30 |
int tileGrid[2] = {5,5}; // tile subdivisions
| 31 |
| 32 |
int psample = 4; /* pixel sample size */
| 33 |
double maxdiff = .05; /* max. difference for interpolation */
| 34 |
double dstrpix = 0.67; /* square pixel distribution */
| 35 |
| 36 |
double mblur = 0.; /* motion blur parameter (unused) */
| 37 |
| 38 |
double dblur = 0.; /* depth-of-field blur parameter */
| 39 |
| 40 |
int nproc = 1; /* number of processes to run (-1 in child) */
| 41 |
| 42 |
RpictSimulManager myRPmanager; // global simulation manager
| 43 |
| 44 |
static void onsig(int signo);
| 45 |
static void onalrm(int signo);
| 46 |
static void sigdie(int signo, const char *msg);
| 47 |
static void printdefaults(void);
| 48 |
static RenderDataType rpiece(char *pout, RenderDataType dt, char *zout);
| 49 |
| 50 |
/* rxpiece additional features */
| 51 |
#define RXPIECE_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
| 52 |
"ParticipatingMedia=Mist\n" \
| 53 |
"HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
| 54 |
"PixelJitter\nPixelSampling\nPixelDepthOfField\n" \
| 55 |
"SmallSourceDrawing\n" \
| 56 |
"AdaptiveShadowTesting\nOutputs=v,l\n" \
| 57 |
"OutputCS=RGB,XYZ,prims,spec\n"
| 58 |
| 59 |
// Exit program
| 60 |
void
| 61 |
quit(int code) /* quit program */
| 62 |
| 63 |
if (nproc < 0) {
| 64 |
ray_pnprocs = -1; // hack to avoid cleanup in child
| 65 |
_exit(code);
| 66 |
| 67 |
exit(code); // parent still frees everything (*yawn*)
| 68 |
| 69 |
| 70 |
/* Set default options */
| 71 |
static void
| 72 |
default_options(void)
| 73 |
| 74 |
shadthresh = .05;
| 75 |
shadcert = .5;
| 76 |
srcsizerat = .25;
| 77 |
directrelay = 1;
| 78 |
ambacc = 0.2;
| 79 |
ambres = 64;
| 80 |
ambdiv = 512;
| 81 |
ambssamp = 128;
| 82 |
maxdepth = 7;
| 83 |
| 84 |
| 85 |
int
| 86 |
main(int argc, char *argv[])
| 87 |
| 88 |
#define check(ol,al) if (argv[i][ol] || \
| 89 |
badarg(argc-i-1,argv+i+1,al)) \
| 90 |
goto badopt
| 91 |
#define check_bool(olen,var) switch (argv[i][olen]) { \
| 92 |
case '\0': var = !var; break; \
| 93 |
case 'y': case 'Y': case 't': case 'T': \
| 94 |
case '+': case '1': var = 1; break; \
| 95 |
case 'n': case 'N': case 'f': case 'F': \
| 96 |
case '-': case '0': var = 0; break; \
| 97 |
default: goto badopt; }
| 98 |
RGBPRIMS our_prims; /* private output color primitives */
| 99 |
RenderDataType dtype = RDTrgbe; // output data flags
| 100 |
char *outfile = NULL;
| 101 |
char *zfile = NULL;
| 102 |
int outfmt = 'c';
| 103 |
int rval;
| 104 |
int i;
| 105 |
/* global program name */
| 106 |
progname = argv[0];
| 107 |
/* feature check only? */
| 108 |
strcat(RFeatureList, RXPIECE_FEATURES);
| 109 |
if (argc > 1 && !strcmp(argv[1], "-features"))
| 110 |
return feature_status(argc-2, argv+2);
| 111 |
/* set defaults */
| 112 |
default_options();
| 113 |
/* option city */
| 114 |
for (i = 1; i < argc; i++) {
| 115 |
/* expand arguments */
| 116 |
while ((rval = expandarg(&argc, &argv, i)) > 0)
| 117 |
| 118 |
if (rval < 0) {
| 119 |
sprintf(errmsg, "cannot expand '%s'", argv[i]);
| 120 |
error(SYSTEM, errmsg);
| 121 |
| 122 |
if (argv[i] == NULL || argv[i][0] != '-')
| 123 |
break; /* break from options */
| 124 |
if (!strcmp(argv[i], "-version")) {
| 125 |
puts(VersionID);
| 126 |
quit(0);
| 127 |
| 128 |
if (!strcmp(argv[i], "-defaults") ||
| 129 |
!strcmp(argv[i], "-help")) {
| 130 |
printdefaults();
| 131 |
quit(0);
| 132 |
| 133 |
rval = getrenderopt(argc-i, argv+i);
| 134 |
if (rval >= 0) {
| 135 |
i += rval;
| 136 |
continue;
| 137 |
| 138 |
rval = getviewopt(&ourview, argc-i, argv+i);
| 139 |
if (rval >= 0) {
| 140 |
i += rval;
| 141 |
continue;
| 142 |
| 143 |
/* rxpiece options */
| 144 |
switch (argv[i][1]) {
| 145 |
case 'v': /* view file */
| 146 |
if (argv[i][2] != 'f')
| 147 |
goto badopt;
| 148 |
check(3,"s");
| 149 |
rval = viewfile(argv[++i], &ourview, NULL);
| 150 |
if (rval < 0) {
| 151 |
sprintf(errmsg,
| 152 |
"cannot open view file \"%s\"",
| 153 |
argv[i]);
| 154 |
| 155 |
} else if (rval == 0) {
| 156 |
sprintf(errmsg,
| 157 |
"bad view file \"%s\"",
| 158 |
argv[i]);
| 159 |
error(USER, errmsg);
| 160 |
| 161 |
break;
| 162 |
case 'n': /* number of processes */
| 163 |
check(2,"i");
| 164 |
nproc = atoi(argv[++i]);
| 165 |
if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0)
| 166 |
nproc = 1;
| 167 |
break;
| 168 |
case 'f': /* output format */
| 169 |
if ((argv[i][2] != 'c') & (argv[i][2] != 'f')
| 170 |
|| argv[i][3])
| 171 |
goto badopt;
| 172 |
outfmt = argv[i][2];
| 173 |
break;
| 174 |
case 'p': /* pixel */
| 175 |
switch (argv[i][2]) {
| 176 |
case 's': /* sample */
| 177 |
check(3,"i");
| 178 |
psample = atoi(argv[++i]);
| 179 |
if (psample < 1) psample = 1;
| 180 |
break;
| 181 |
case 't': /* threshold */
| 182 |
check(3,"f");
| 183 |
maxdiff = atof(argv[++i]);
| 184 |
break;
| 185 |
case 'j': /* jitter */
| 186 |
check(3,"f");
| 187 |
dstrpix = atof(argv[++i]);
| 188 |
break;
| 189 |
case 'a': /* aspect */
| 190 |
check(3,"f");
| 191 |
pixaspect = atof(argv[++i]);
| 192 |
break;
| 193 |
case 'd': /* aperture */
| 194 |
check(3,"f");
| 195 |
dblur = atof(argv[++i]);
| 196 |
dblur *= (dblur > 0);
| 197 |
break;
| 198 |
case 'R': /* standard RGB output */
| 199 |
if (strcmp(argv[i]+2, "RGB"))
| 200 |
goto badopt;
| 201 |
myRPmanager.prims = stdprims;
| 202 |
dtype = RDTnewCT(dtype, RDTrgbe);
| 203 |
break;
| 204 |
case 'X': /* XYZ output */
| 205 |
if (strcmp(argv[i]+2, "XYZ"))
| 206 |
goto badopt;
| 207 |
myRPmanager.prims = xyzprims;
| 208 |
dtype = RDTnewCT(dtype, RDTxyze);
| 209 |
break;
| 210 |
case 'c': /* chromaticities */
| 211 |
check(3,"ffffffff");
| 212 |
rval = 0;
| 213 |
for (int j = 0; j < 8; j++) {
| 214 |
our_prims[0][j] = atof(argv[++i]);
| 215 |
rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
| 216 |
| 217 |
if (rval) {
| 218 |
if (!colorprimsOK(our_prims))
| 219 |
error(USER, "illegal primary chromaticities");
| 220 |
myRPmanager.prims = our_prims;
| 221 |
} else
| 222 |
| 223 |
| 224 |
break;
| 225 |
default:
| 226 |
goto badopt;
| 227 |
| 228 |
break;
| 229 |
case 'd': /* reference depth */
| 230 |
if (argv[i][2] || !myRPmanager.SetReferenceDepth(argv[++i]))
| 231 |
goto badopt;
| 232 |
dtype = RDTnewDT(dtype, RDTdshort);
| 233 |
break;
| 234 |
case 'x': /* x resolution */
| 235 |
check(2,"i");
| 236 |
hresolu = atoi(argv[++i]);
| 237 |
break;
| 238 |
case 'y': /* y resolution */
| 239 |
check(2,"i");
| 240 |
vresolu = atoi(argv[++i]);
| 241 |
break;
| 242 |
case 'X': /* horizontal tile subdivisions */
| 243 |
check(2,"i");
| 244 |
tileGrid[0] = atoi(argv[++i]);
| 245 |
break;
| 246 |
case 'Y': /* vertical tile subdivisions */
| 247 |
check(2,"i");
| 248 |
tileGrid[1] = atoi(argv[++i]);
| 249 |
break;
| 250 |
case 'o': /* output file */
| 251 |
check(2,"s");
| 252 |
outfile = argv[++i];
| 253 |
break;
| 254 |
case 'z': /* z file */
| 255 |
check(2,"s");
| 256 |
zfile = argv[++i];
| 257 |
break;
| 258 |
#if MAXCSAMP>3
| 259 |
case 'c': /* output spectral results */
| 260 |
if (argv[i][2] != 'o')
| 261 |
goto badopt;
| 262 |
rval = (myRPmanager.prims == NULL);
| 263 |
check_bool(3,rval);
| 264 |
if (rval)
| 265 |
myRPmanager.prims = NULL;
| 266 |
else if (myRPmanager.prims == NULL)
| 267 |
| 268 |
dtype = RDTnewCT(dtype, rval ? RDTscolr : RDTrgbe);
| 269 |
break;
| 270 |
#endif
| 271 |
case 'w': /* warnings */
| 272 |
rval = erract[WARNING].pf != NULL;
| 273 |
check_bool(2,rval);
| 274 |
if (rval) erract[WARNING].pf = wputs;
| 275 |
else erract[WARNING].pf = NULL;
| 276 |
break;
| 277 |
default:
| 278 |
goto badopt;
| 279 |
| 280 |
| 281 |
if (maxdiff <= FTINY) /* check for useless sampling */
| 282 |
psample = 1;
| 283 |
if (outfile == NULL)
| 284 |
error(USER, "missing output file (-o option)");
| 285 |
if (zfile == NULL) /* set up depth output */
| 286 |
dtype = RDTnewDT(dtype, RDTnone);
| 287 |
else if (!RDTdepthT(dtype))
| 288 |
dtype = RDTnewDT(dtype, RDTdfloat);
| 289 |
/* check pixel output type */
| 290 |
if ((myRPmanager.prims == NULL) & (NCSAMP == 3)) {
| 291 |
| 292 |
| 293 |
| 294 |
if (outfmt == 'f')
| 295 |
switch (RDTcolorT(dtype)) {
| 296 |
case RDTrgbe:
| 297 |
dtype = RDTnewCT(dtype, RDTrgb);
| 298 |
break;
| 299 |
case RDTxyze:
| 300 |
dtype = RDTnewCT(dtype, RDTxyz);
| 301 |
break;
| 302 |
case RDTscolr:
| 303 |
dtype = RDTnewCT(dtype, RDTscolor);
| 304 |
break;
| 305 |
case RDTrgb:
| 306 |
case RDTxyz:
| 307 |
case RDTscolor:
| 308 |
break;
| 309 |
default:
| 310 |
error(INTERNAL, "botched color output type");
| 311 |
| 312 |
/* set up signal handling */
| 313 |
sigdie(SIGINT, "Interrupt");
| 314 |
sigdie(SIGHUP, "Hangup");
| 315 |
sigdie(SIGTERM, "Terminate");
| 316 |
sigdie(SIGPIPE, "Broken pipe");
| 317 |
signal(SIGALRM, onalrm); // used to gracefully terminate
| 318 |
#ifdef SIGXCPU
| 319 |
sigdie(SIGXCPU, "CPU limit exceeded");
| 320 |
sigdie(SIGXFSZ, "File size exceeded");
| 321 |
#endif
| 322 |
#ifdef NICE
| 323 |
nice(NICE); /* lower priority */
| 324 |
#endif
| 325 |
if (i < argc-1)
| 326 |
goto badopt;
| 327 |
// load octree
| 328 |
if (!myRPmanager.LoadOctree(argv[i]))
| 329 |
error(USER, "missing octree argument");
| 330 |
// add new header info
| 331 |
myRPmanager.AddHeader(i, argv);
| 332 |
| 333 |
char buf[128] = "SOFTWARE= ";
| 334 |
strcpy(buf+10, VersionID);
| 335 |
myRPmanager.AddHeader(buf);
| 336 |
| 337 |
// render tiles
| 338 |
dtype = rpiece(outfile, dtype, zfile);
| 339 |
| 340 |
ambsync(); // flush ambient cache
| 341 |
| 342 |
ray_done_pmap(); /* PMAP: free photon maps */
| 343 |
| 344 |
quit(dtype==RDTnone); // status is 1 on failure
| 345 |
| 346 |
badopt:
| 347 |
sprintf(errmsg, "command line error at '%s'", argv[i]);
| 348 |
| 349 |
return 1; /* pro forma return */
| 350 |
| 351 |
#undef check
| 352 |
#undef check_bool
| 353 |
| 354 |
| 355 |
| 356 |
void
| 357 |
wputs( /* warning output function */
| 358 |
const char *s
| 359 |
| 360 |
| 361 |
if (!erract[WARNING].pf)
| 362 |
return; // warnings were disabled!
| 363 |
int lasterrno = errno;
| 364 |
eputs(s);
| 365 |
errno = lasterrno;
| 366 |
| 367 |
| 368 |
| 369 |
void
| 370 |
eputs( /* put string to stderr */
| 371 |
const char *s
| 372 |
| 373 |
| 374 |
static int midline = 0;
| 375 |
| 376 |
if (!*s)
| 377 |
return;
| 378 |
if (!midline++) {
| 379 |
fputs(progname, stderr);
| 380 |
fputs(": ", stderr);
| 381 |
| 382 |
fputs(s, stderr);
| 383 |
if (s[strlen(s)-1] == '\n') {
| 384 |
fflush(stderr);
| 385 |
midline = 0;
| 386 |
| 387 |
| 388 |
| 389 |
| 390 |
static void
| 391 |
onsig( /* fatal signal */
| 392 |
int signo
| 393 |
| 394 |
| 395 |
static int gotsig = 0;
| 396 |
| 397 |
if (gotsig++) /* two signals and we're gone! */
| 398 |
_exit(signo);
| 399 |
| 400 |
alarm(30); /* allow 30 seconds to clean up */
| 401 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */
| 402 |
eputs("signal - ");
| 403 |
eputs(sigerr[signo]);
| 404 |
eputs("\n");
| 405 |
quit(3);
| 406 |
| 407 |
| 408 |
| 409 |
static bool gotALRM = false; // flag for ALRM signal
| 410 |
| 411 |
static void
| 412 |
onalrm(int signo)
| 413 |
| 414 |
gotALRM = true;
| 415 |
| 416 |
| 417 |
| 418 |
static void
| 419 |
sigdie( /* set fatal signal */
| 420 |
int signo,
| 421 |
const char *msg
| 422 |
| 423 |
| 424 |
if (signal(signo, onsig) == SIG_IGN)
| 425 |
signal(signo, SIG_IGN);
| 426 |
sigerr[signo] = msg;
| 427 |
| 428 |
| 429 |
| 430 |
static void
| 431 |
printdefaults(void) /* print default values to stdout */
| 432 |
| 433 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
| 434 |
printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
| 435 |
ourview.type==VT_PER ? "perspective" :
| 436 |
ourview.type==VT_PAR ? "parallel" :
| 437 |
ourview.type==VT_HEM ? "hemispherical" :
| 438 |
ourview.type==VT_ANG ? "angular" :
| 439 |
ourview.type==VT_CYL ? "cylindrical" :
| 440 |
ourview.type==VT_PLS ? "planisphere" :
| 441 |
"unknown");
| 442 |
printf("-vp %f %f %f\t# view point\n",
| 443 |
ourview.vp[0], ourview.vp[1], ourview.vp[2]);
| 444 |
printf("-vd %f %f %f\t# view direction\n",
| 445 |
ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
| 446 |
printf("-vu %f %f %f\t# view up\n",
| 447 |
ourview.vup[0], ourview.vup[1], ourview.vup[2]);
| 448 |
printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
| 449 |
printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
| 450 |
printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
| 451 |
printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
| 452 |
printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
| 453 |
printf("-vl %f\t\t\t# view lift\n", ourview.voff);
| 454 |
printf("-x %-9d\t\t\t# x resolution\n", hresolu);
| 455 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu);
| 456 |
printf("-X %-9d\t\t\t# horizontal tile divisions\n", tileGrid[0]);
| 457 |
printf("-Y %-9d\t\t\t# vertical tile divisions\n", tileGrid[1]);
| 458 |
if (myRPmanager.prims == stdprims)
| 459 |
printf("-pRGB\t\t\t\t# standard RGB color output\n");
| 460 |
else if (myRPmanager.prims == xyzprims)
| 461 |
printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
| 462 |
else if (myRPmanager.prims != NULL)
| 463 |
printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
| 464 |
myRPmanager.prims[RED][0], myRPmanager.prims[RED][1],
| 465 |
myRPmanager.prims[GRN][0], myRPmanager.prims[GRN][1],
| 466 |
myRPmanager.prims[BLU][0], myRPmanager.prims[BLU][1],
| 467 |
myRPmanager.prims[WHT][0], myRPmanager.prims[WHT][1]);
| 468 |
if (NCSAMP > 3)
| 469 |
printf(myRPmanager.prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
| 470 |
"-co+\t\t\t\t# output spectral values\n");
| 471 |
printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
| 472 |
printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
| 473 |
printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
| 474 |
printf("-ps %-9d\t\t\t# pixel sample\n", psample);
| 475 |
printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
| 476 |
printf(erract[WARNING].pf != NULL ?
| 477 |
"-w+\t\t\t\t# warning messages on\n" :
| 478 |
"-w-\t\t\t\t# warning messages off\n");
| 479 |
print_rdefaults();
| 480 |
| 481 |
| 482 |
| 483 |
// Struct for tracking tiles being rendered in mapped file / shared memory
| 484 |
struct TileProg {
| 485 |
short status; // 0==Unstarted, -1==InProgress, 1==Done
| 486 |
pid_t pID; // process operating on tile
| 487 |
} *tprog = NULL; // shared tile progress array
| 488 |
| 489 |
#define tile_p(ti) (tprog + (ti)[1]*tileGrid[0] + (ti)[0])
| 490 |
| 491 |
// Return true if tile is renderable
| 492 |
static bool
| 493 |
renderable_tile(TileProg *tp)
| 494 |
| 495 |
if (tp->status < 0 && kill(tp->pID, 0) < 0)
| 496 |
tp->status = 0; // dead process - reset
| 497 |
| 498 |
return !tp->status;
| 499 |
| 500 |
| 501 |
| 502 |
// handle multi-processing if requested, return true if all done
| 503 |
static bool
| 504 |
children_finished()
| 505 |
| 506 |
if (nproc <= 1) // single process -> run in parent
| 507 |
return false;
| 508 |
int cnt = 0; // else count ready-to-go tiles
| 509 |
int ti[2];
| 510 |
for (ti[1] = 0; ti[1] < tileGrid[1]; ti[1]++)
| 511 |
for (ti[0] = 0; ti[0] < tileGrid[0]; ti[0]++)
| 512 |
cnt += renderable_tile(tile_p(ti));
| 513 |
if (!cnt)
| 514 |
return false; // parent can do nothing
| 515 |
if (cnt < nproc) {
| 516 |
sprintf(errmsg, "only %d renderable tiles, reducing process count", cnt);
| 517 |
error(WARNING, errmsg);
| 518 |
if ((nproc = cnt) == 1)
| 519 |
return false; // back to single process
| 520 |
| 521 |
cow_memshare(); // else we'll be sharing memory
| 522 |
fflush(NULL); // and forking children
| 523 |
pid_t cpid; // create nproc children
| 524 |
for (cnt = nproc; cnt && (cpid = fork()) != 0; cnt--)
| 525 |
if (cpid < 0)
| 526 |
error(SYSTEM, "fork error!");
| 527 |
| 528 |
if (cpid == 0) { // children render tiles
| 529 |
sleep(nproc - cnt); // avoid race conditions
| 530 |
nproc = -1; // flag as child
| 531 |
return false;
| 532 |
| 533 |
cow_doneshare(); // parent frees memory and waits
| 534 |
signal(SIGALRM, SIG_IGN);
| 535 |
myRPmanager.Cleanup(true);
| 536 |
int nfailed = 0;
| 537 |
int status;
| 538 |
for (cnt = nproc; cnt && wait(&status) > 0; cnt--)
| 539 |
if (status) {
| 540 |
sprintf(errmsg, "child exited with status %d", status);
| 541 |
| 542 |
if (!nfailed++ & (cnt > 1)) {
| 543 |
kill(0, SIGALRM);
| 544 |
error(WARNING, "waiting for other tiles to finish...");
| 545 |
| 546 |
| 547 |
if (cnt) {
| 548 |
sprintf(errmsg, "lost track of %d children", cnt);
| 549 |
| 550 |
| 551 |
if (nfailed) {
| 552 |
sprintf(errmsg, "%d tiles were not completed", nfailed);
| 553 |
| 554 |
| 555 |
return true; // all done!
| 556 |
| 557 |
| 558 |
// return next renderable tile, false if everything is done
| 559 |
static bool
| 560 |
nexttile(int ti[2])
| 561 |
| 562 |
static pid_t ourpID = 0;
| 563 |
static short * tlist = NULL;
| 564 |
static int tlen = 0;
| 565 |
static int tnext = 0;
| 566 |
| 567 |
if (gotALRM) { // pre-empting new work?
| 568 |
if (tlist) {
| 569 |
sprintf(errmsg, "process %d got alarm, exiting", ourpID);
| 570 |
CHECK(tnext<tlen, WARNING, errmsg);
| 571 |
free(tlist); tlist = NULL;
| 572 |
| 573 |
return false;
| 574 |
| 575 |
if (!tlist) { // initialize random tile list
| 576 |
ABitMap2 todoMap(tileGrid[0], tileGrid[1]);
| 577 |
tlen = 0;
| 578 |
| 579 |
| 580 |
if (renderable_tile(tile_p(ti))) {
| 581 |
todoMap.Set(ti[0], ti[1]);
| 582 |
tlen++;
| 583 |
| 584 |
if (!tlen)
| 585 |
return false; // nothing to do!
| 586 |
tlist = (short *)malloc(sizeof(short)*2*tlen);
| 587 |
CHECK(!tlist, SYSTEM, "out of memory in nexttile()");
| 588 |
tlen = 0; // assign entries
| 589 |
for (ti[0] = ti[1] = 0; todoMap.Find(&ti[0], &ti[1]); ti[0]++) {
| 590 |
tlist[2*tlen] = ti[0];
| 591 |
tlist[2*tlen+1] = ti[1];
| 592 |
tlen++;
| 593 |
| 594 |
// shuffle order w/ Fisher-Yates
| 595 |
for (int i = 0; i < tlen-1; i++) {
| 596 |
const int ix = irandom(tlen-i) + i;
| 597 |
ti[0] = tlist[2*i];
| 598 |
ti[1] = tlist[2*i+1];
| 599 |
tlist[2*i] = tlist[2*ix];
| 600 |
tlist[2*i+1] = tlist[2*ix+1];
| 601 |
tlist[2*ix] = ti[0];
| 602 |
tlist[2*ix+1] = ti[1];
| 603 |
| 604 |
ourpID = getpid(); // save time on system calls
| 605 |
| 606 |
while (tnext < tlen) { // find first available
| 607 |
ti[0] = tlist[2*tnext];
| 608 |
ti[1] = tlist[2*tnext+1];
| 609 |
tnext++; // take if still unclaimed
| 610 |
| 611 |
tile_p(ti)->status = -1;
| 612 |
tile_p(ti)->pID = ourpID;
| 613 |
return true;
| 614 |
| 615 |
| 616 |
free(tlist); tlist = NULL; // exhausted our list?
| 617 |
return false;
| 618 |
| 619 |
| 620 |
| 621 |
// Principal function for rpiece
| 622 |
| 623 |
| 624 |
| 625 |
if (zout && *zout == '!')
| 626 |
error(USER, "cannot send depth to a command");
| 627 |
| 628 |
const bool newOutput = (access(pout, F_OK) < 0);
| 629 |
FILE *pdfp[2];
| 630 |
if (newOutput) { // new output file?
| 631 |
CHECK((tileGrid[0] <= 1) & (tileGrid[1] <= 1),
| 632 |
USER, "bad tiling specification");
| 633 |
} else {
| 634 |
dt = myRPmanager.ReopenOutput(pdfp, pout, zout);
| 635 |
if (dt == RDTnone)
| 636 |
return RDTnone;
| 637 |
if (!fscnresolu(&hresolu, &vresolu, pdfp[0]))
| 638 |
error(USER, "missing picture resolution");
| 639 |
pixaspect = .0; // need to leave this as is
| 640 |
myRPmanager.NewHeader(pout); // get prev. header info
| 641 |
const char * tval = myRPmanager.GetHeadStr("TILED=");
| 642 |
if (tval) sscanf(tval, "%d %d", &tileGrid[0], &tileGrid[1]);
| 643 |
CHECK(myRPmanager.GetView()==NULL,
| 644 |
USER, "missing view in picture file");
| 645 |
ourview = *myRPmanager.GetView();
| 646 |
| 647 |
int hvdim[2] = {hresolu, vresolu}; // set up tiled frame
| 648 |
if (!myRPmanager.NewFrame(ourview, hvdim, &pixaspect, tileGrid))
| 649 |
error(USER, "tiling setup error in rpiece");
| 650 |
| 651 |
if ((hvdim[0] != hresolu) | (hvdim[1] != vresolu)) {
| 652 |
if (!newOutput)
| 653 |
error(USER, "unexpected output size adjustment");
| 654 |
sprintf(errmsg, "resolution adjusted from %dx%d to %dx%d",
| 655 |
hresolu, vresolu, hvdim[0], hvdim[1]);
| 656 |
| 657 |
hresolu = hvdim[0];
| 658 |
vresolu = hvdim[1];
| 659 |
| 660 |
if (newOutput){ // open new output here
| 661 |
char buf[64];
| 662 |
sprintf(buf, "TILED= %d %d\n", tileGrid[0], tileGrid[1]);
| 663 |
| 664 |
dt = myRPmanager.NewOutput(pdfp, pout, dt, zout);
| 665 |
if (dt == RDTnone)
| 666 |
return RDTnone;
| 667 |
fprtresolu(hresolu, vresolu, pdfp[0]);
| 668 |
fflush(pdfp[0]);
| 669 |
if (RDTdepthT(dt) == RDTdshort) {
| 670 |
fprtresolu(hresolu, vresolu, pdfp[1]);
| 671 |
fflush(pdfp[1]);
| 672 |
| 673 |
} else if (RDTdepthT(dt) == RDTdshort &&
| 674 |
(!fscnresolu(&hvdim[0], &hvdim[1], pdfp[1]) ||
| 675 |
(hvdim[0] != hresolu) | (hvdim[1] != vresolu)))
| 676 |
error(USER, "mismatched depth file resolution");
| 677 |
// prepare (flat) pixel buffer
| 678 |
const long pdata_beg = ftell(pdfp[0]);
| 679 |
const size_t pixSiz = (RDTcolorT(dt)==RDTrgbe)|(RDTcolorT(dt)==RDTxyze) ? sizeof(COLR)
| 680 |
: (RDTcolorT(dt)==RDTrgb)|(RDTcolorT(dt)==RDTxyz) ? sizeof(COLORV)*3
| 681 |
: RDTcolorT(dt)==RDTscolr ? LSCOLR : sizeof(COLORV)*NCSAMP;
| 682 |
size_t pmlen = pdata_beg + pixSiz*hresolu*vresolu;
| 683 |
// put tile progress array at end
| 684 |
if (pmlen&7) pmlen += 8 - (pmlen&7); // 8-byte alignment to be safe
| 685 |
pmlen += sizeof(TileProg)*tileGrid[0]*tileGrid[1];
| 686 |
// map picture file to memory
| 687 |
if (newOutput && ftruncate(fileno(pdfp[0]), pmlen) < 0)
| 688 |
error(SYSTEM, "cannot extend picture buffer");
| 689 |
uby8 * pixMap = (uby8 *)mmap(NULL, pmlen, PROT_READ|PROT_WRITE,
| 690 |
MAP_SHARED, fileno(pdfp[0]), 0);
| 691 |
if ((void *)pixMap == MAP_FAILED)
| 692 |
error(SYSTEM, "cannot map picture file into memory");
| 693 |
// map depth buffer to memory
| 694 |
const long zdata_beg = RDTdepthT(dt) ? ftell(pdfp[1]) : 0L;
| 695 |
const size_t zdpSiz = RDTdepthT(dt)==RDTdshort ? sizeof(short) :
| 696 |
RDTdepthT(dt)==RDTdfloat ? sizeof(float) : 0;
| 697 |
const size_t zmlen = zdata_beg + zdpSiz*hresolu*vresolu;
| 698 |
uby8 * zdMap = NULL;
| 699 |
if (RDTdepthT(dt)) {
| 700 |
if (newOutput && ftruncate(fileno(pdfp[1]), zmlen) < 0)
| 701 |
error(SYSTEM, "cannot extend depth buffer");
| 702 |
zdMap = (uby8 *)mmap(NULL, zmlen, PROT_READ|PROT_WRITE,
| 703 |
MAP_SHARED, fileno(pdfp[1]), 0);
| 704 |
if ((void *)zdMap == MAP_FAILED)
| 705 |
error(SYSTEM, "cannot map depth file into memory");
| 706 |
| 707 |
fclose(pdfp[0]); // done with file pointers
| 708 |
if (RDTdepthT(dt)) fclose(pdfp[1]);
| 709 |
// point to tile progress array
| 710 |
tprog = (TileProg *)(pixMap + pmlen - sizeof(TileProg)*tileGrid[0]*tileGrid[1]);
| 711 |
| 712 |
if (children_finished()) // work done in children?
| 713 |
return dt;
| 714 |
| 715 |
int ndone = 0; // else render tiles
| 716 |
int ti[2];
| 717 |
while (nexttile(ti)) {
| 718 |
const int offset = (tileGrid[1]-1-ti[1])*myRPmanager.GetWidth()*myRPmanager.THeight() +
| 719 |
(myRPmanager.THeight()-1)*myRPmanager.GetWidth() +
| 720 |
ti[0]*myRPmanager.TWidth();
| 721 |
uby8 * pptr = pixMap + pdata_beg + pixSiz*offset;
| 722 |
uby8 * zptr = zdMap + zdata_beg + zdpSiz*offset;
| 723 |
bool ok = false;
| 724 |
switch (RDTcommonE(dt)<<1 | (RDTdepthT(dt)==RDTdshort)) {
| 725 |
case 2: // common-exponent color, float/no depth
| 726 |
ok = myRPmanager.RenderTile((COLRV *)pptr, -myRPmanager.GetWidth(),
| 727 |
(float *)zptr, ti);
| 728 |
break;
| 729 |
case 0: // float color, float/no depth
| 730 |
ok = myRPmanager.RenderTile((COLORV *)pptr, -myRPmanager.GetWidth(),
| 731 |
(float *)zptr, ti);
| 732 |
break;
| 733 |
case 3: // common-exponent color, encoded depth
| 734 |
| 735 |
(short *)zptr, ti);
| 736 |
break;
| 737 |
case 1: // float color, encoded depth
| 738 |
| 739 |
(short *)zptr, ti);
| 740 |
break;
| 741 |
| 742 |
if (!ok) { // got an error
| 743 |
sprintf(errmsg, "error rendering tile (%d,%d)/(%d,%d)",
| 744 |
ti[0], ti[1], tileGrid[0], tileGrid[1]);
| 745 |
| 746 |
| 747 |
tile_p(ti)->status = 1; // mark tile completed
| 748 |
ndone++;
| 749 |
| 750 |
if (!ndone)
| 751 |
error(WARNING, "no tiles need rendering, exit");
| 752 |
| 753 |
munmap(pixMap, pmlen); // technically unnecessary...
| 754 |
if (zdMap) munmap(zdMap, zmlen);
| 755 |
| 756 |
return dt; // we're done here
| 757 |
