root/radiance/ray/src/rt/rxpiece.cpp
Revision: 2.12
Committed: Wed Jun 4 20:32:25 2025 UTC (3 weeks, 1 day ago) by greg
Changes since 2.11: +6 -6 lines
feat(rxpiece): Added rxpiece to standard distribution
2 static const char RCSid[] = "$Id: rxpiece.cpp,v 2.11 2025/04/22 17:12:25 greg Exp $";
5 * rxpiece.cpp - main for rxpiece tile rendering program
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11 #include <signal.h>
12 #include <sys/mman.h>
13 #include <unistd.h>
14
15 #include "platform.h"
16 #include "RpictSimulManager.h"
17 #include "func.h"
18 #include "ambient.h"
19 #include "pmapray.h"
20 #include "random.h"
21
22 const char *sigerr[NSIG]; /* signal error messages */
23
24 VIEW ourview = STDVIEW; /* global view parameters */
25 int hresolu = 1024; /* horizontal resolution */
26 int vresolu = 1024; /* vertical resolution */
27 double pixaspect = 1.0; /* pixel aspect ratio */
28 int hres, vres; /* current image resolution for srcdraw.c */
29
30 int tileGrid[2] = {5,5}; // tile subdivisions
31
32 int psample = 4; /* pixel sample size */
33 double maxdiff = .05; /* max. difference for interpolation */
34 double dstrpix = 0.67; /* square pixel distribution */
35
36 double mblur = 0.; /* motion blur parameter (unused) */
37
38 double dblur = 0.; /* depth-of-field blur parameter */
39
40 int nproc = 1; /* number of processes to run (-1 in child) */
41
42 RpictSimulManager myRPmanager; // global simulation manager
43
44 static void onsig(int signo);
45 static void onalrm(int signo);
46 static void sigdie(int signo, const char *msg);
47 static void printdefaults(void);
48 static RenderDataType rpiece(char *pout, RenderDataType dt, char *zout);
49
50 /* rxpiece additional features */
51 #define RXPIECE_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
52 "ParticipatingMedia=Mist\n" \
53 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
54 "PixelJitter\nPixelSampling\nPixelDepthOfField\n" \
55 "SmallSourceDrawing\n" \
56 "AdaptiveShadowTesting\nOutputs=v,l\n" \
57 "OutputCS=RGB,XYZ,prims,spec\n"
58
59 // Exit program
60 void
61 quit(int code) /* quit program */
62 {
63 exit(code); // don't bother to free data structs
64 }
65
66 /* Set default options */
67 static void
68 default_options(void)
69 {
70 shadthresh = .05;
71 shadcert = .5;
72 srcsizerat = .25;
73 directrelay = 1;
74 ambacc = 0.2;
75 ambres = 64;
76 ambdiv = 512;
77 ambssamp = 128;
78 maxdepth = 7;
79 }
80
81 int
82 main(int argc, char *argv[])
83 {
84 #define check(ol,al) if (argv[i][ol] || \
85 badarg(argc-i-1,argv+i+1,al)) \
86 goto badopt
87 #define check_bool(olen,var) switch (argv[i][olen]) { \
88 case '\0': var = !var; break; \
89 case 'y': case 'Y': case 't': case 'T': \
90 case '+': case '1': var = 1; break; \
91 case 'n': case 'N': case 'f': case 'F': \
92 case '-': case '0': var = 0; break; \
93 default: goto badopt; }
94 RGBPRIMS our_prims; /* private output color primitives */
95 RenderDataType dtype = RDTrgbe; // output data flags
96 char *outfile = NULL;
97 char *zfile = NULL;
98 int outfmt = 'c';
99 int rval;
100 int i;
101 /* set global program name */
102 fixargv0(argv[0]);
103 /* feature check only? */
104 strcat(RFeatureList, RXPIECE_FEATURES);
105 if (argc > 1 && !strcmp(argv[1], "-features"))
106 return feature_status(argc-2, argv+2);
107 /* initialize calcomp routines */
108 initfunc();
109 /* set defaults */
110 default_options();
111 /* option city */
112 for (i = 1; i < argc; i++) {
113 /* expand arguments */
114 while ((rval = expandarg(&argc, &argv, i)) > 0)
115 ;
116 if (rval < 0) {
117 sprintf(errmsg, "cannot expand '%s'", argv[i]);
118 error(SYSTEM, errmsg);
119 }
120 if (argv[i] == NULL || argv[i][0] != '-')
121 break; /* break from options */
122 if (!strcmp(argv[i], "-version")) {
123 puts(VersionID);
124 quit(0);
125 }
126 if (!strcmp(argv[i], "-defaults") ||
127 !strcmp(argv[i], "-help")) {
128 printdefaults();
129 quit(0);
130 }
131 rval = getrenderopt(argc-i, argv+i);
132 if (rval >= 0) {
133 i += rval;
134 continue;
135 }
136 rval = getviewopt(&ourview, argc-i, argv+i);
137 if (rval >= 0) {
138 i += rval;
139 continue;
140 }
141 /* rxpiece options */
142 switch (argv[i][1]) {
143 case 'v': /* view file */
144 if (argv[i][2] != 'f')
145 goto badopt;
146 check(3,"s");
147 rval = viewfile(argv[++i], &ourview, NULL);
148 if (rval < 0) {
149 sprintf(errmsg,
150 "cannot open view file \"%s\"",
151 argv[i]);
152 error(SYSTEM, errmsg);
153 } else if (rval == 0) {
154 sprintf(errmsg,
155 "bad view file \"%s\"",
156 argv[i]);
157 error(USER, errmsg);
158 }
159 break;
160 case 'n': /* number of processes */
161 check(2,"i");
162 nproc = atoi(argv[++i]);
163 if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0)
164 nproc = 1;
165 break;
166 case 'f': /* output format */
167 if ((argv[i][2] != 'c') & (argv[i][2] != 'f')
168 || argv[i][3])
169 goto badopt;
170 outfmt = argv[i][2];
171 break;
172 case 'p': /* pixel */
173 switch (argv[i][2]) {
174 case 's': /* sample */
175 check(3,"i");
176 psample = atoi(argv[++i]);
177 if (psample < 1) psample = 1;
178 break;
179 case 't': /* threshold */
180 check(3,"f");
181 maxdiff = atof(argv[++i]);
182 break;
183 case 'j': /* jitter */
184 check(3,"f");
185 dstrpix = atof(argv[++i]);
186 break;
187 case 'a': /* aspect */
188 check(3,"f");
189 pixaspect = atof(argv[++i]);
190 break;
191 case 'd': /* aperture */
192 check(3,"f");
193 dblur = atof(argv[++i]);
194 dblur *= (dblur > 0);
195 break;
196 case 'R': /* standard RGB output */
197 if (strcmp(argv[i]+2, "RGB"))
198 goto badopt;
199 myRPmanager.prims = stdprims;
200 dtype = RDTnewCT(dtype, RDTrgbe);
201 break;
202 case 'X': /* XYZ output */
203 if (strcmp(argv[i]+2, "XYZ"))
204 goto badopt;
205 myRPmanager.prims = xyzprims;
206 dtype = RDTnewCT(dtype, RDTxyze);
207 break;
208 case 'c': /* chromaticities */
209 check(3,"ffffffff");
210 rval = 0;
211 for (int j = 0; j < 8; j++) {
212 our_prims[0][j] = atof(argv[++i]);
213 rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
214 }
215 if (rval) {
216 if (!colorprimsOK(our_prims))
217 error(USER, "illegal primary chromaticities");
218 myRPmanager.prims = our_prims;
219 } else
220 myRPmanager.prims = stdprims;
221 dtype = RDTnewCT(dtype, RDTrgbe);
222 break;
223 default:
224 goto badopt;
225 }
226 break;
227 case 'd': /* reference depth */
228 if (argv[i][2] || !myRPmanager.SetReferenceDepth(argv[++i]))
229 goto badopt;
230 dtype = RDTnewDT(dtype, RDTdshort);
231 break;
232 case 'x': /* x resolution */
233 check(2,"i");
234 hresolu = atoi(argv[++i]);
235 break;
236 case 'y': /* y resolution */
237 check(2,"i");
238 vresolu = atoi(argv[++i]);
239 break;
240 case 'X': /* horizontal tile subdivisions */
241 check(2,"i");
242 tileGrid[0] = atoi(argv[++i]);
243 break;
244 case 'Y': /* vertical tile subdivisions */
245 check(2,"i");
246 tileGrid[1] = atoi(argv[++i]);
247 break;
248 case 'o': /* output file */
249 check(2,"s");
250 outfile = argv[++i];
251 break;
252 case 'z': /* z file */
253 check(2,"s");
254 zfile = argv[++i];
255 break;
256 #if MAXCSAMP>3
257 case 'c': /* output spectral results */
258 if (argv[i][2] != 'o')
259 goto badopt;
260 rval = (myRPmanager.prims == NULL);
261 check_bool(3,rval);
262 if (rval)
263 myRPmanager.prims = NULL;
264 else if (myRPmanager.prims == NULL)
265 myRPmanager.prims = stdprims;
266 dtype = RDTnewCT(dtype, rval ? RDTscolr : RDTrgbe);
267 break;
268 #endif
269 case 'w': /* warnings */
270 rval = erract[WARNING].pf != NULL;
271 check_bool(2,rval);
272 if (rval) erract[WARNING].pf = wputs;
273 else erract[WARNING].pf = NULL;
274 break;
275 default:
276 goto badopt;
277 }
278 }
279 if (maxdiff <= FTINY) /* check for useless sampling */
280 psample = 1;
281 if (outfile == NULL)
282 error(USER, "missing output file (-o option)");
283 if (zfile == NULL) /* set up depth output */
284 dtype = RDTnewDT(dtype, RDTnone);
285 else if (!RDTdepthT(dtype))
286 dtype = RDTnewDT(dtype, RDTdfloat);
287 /* check pixel output type */
288 if ((myRPmanager.prims == NULL) & (NCSAMP == 3)) {
289 myRPmanager.prims = stdprims;
290 dtype = RDTnewCT(dtype, RDTrgbe);
291 }
292 if (outfmt == 'f')
293 switch (RDTcolorT(dtype)) {
294 case RDTrgbe:
295 dtype = RDTnewCT(dtype, RDTrgb);
296 break;
297 case RDTxyze:
298 dtype = RDTnewCT(dtype, RDTxyz);
299 break;
300 case RDTscolr:
301 dtype = RDTnewCT(dtype, RDTscolor);
302 break;
303 case RDTrgb:
304 case RDTxyz:
305 case RDTscolor:
306 break;
307 default:
308 error(INTERNAL, "botched color output type");
309 }
310 /* set up signal handling */
311 sigdie(SIGINT, "Interrupt");
312 sigdie(SIGHUP, "Hangup");
313 sigdie(SIGTERM, "Terminate");
314 sigdie(SIGPIPE, "Broken pipe");
315 signal(SIGALRM, onalrm); // used to gracefully terminate
316 #ifdef SIGXCPU
317 sigdie(SIGXCPU, "CPU limit exceeded");
318 sigdie(SIGXFSZ, "File size exceeded");
319 #endif
320 #ifdef NICE
321 nice(NICE); /* lower priority */
322 #endif
323 if (i < argc-1)
324 goto badopt;
325 // load octree
326 if (!myRPmanager.LoadOctree(argv[i]))
327 error(USER, "missing octree argument");
328 // add new header info
329 myRPmanager.AddHeader(i, argv);
330 {
331 char buf[128] = "SOFTWARE= ";
332 strcpy(buf+10, VersionID);
333 myRPmanager.AddHeader(buf);
334 }
335 // render tiles
336 dtype = rpiece(outfile, dtype, zfile);
337
338 ambsync(); // flush ambient cache
339
340 ray_done_pmap(); /* PMAP: free photon maps */
341
342 quit(dtype==RDTnone); // status is 1 on failure
343
344 badopt:
345 sprintf(errmsg, "command line error at '%s'", argv[i]);
346 error(USER, errmsg);
347 return 1; /* pro forma return */
348
349 #undef check
350 #undef check_bool
351 }
352
353
354 void
355 wputs( /* warning output function */
356 const char *s
357 )
358 {
359 if (!erract[WARNING].pf)
360 return; // warnings were disabled!
361 int lasterrno = errno;
362 eputs(s);
363 errno = lasterrno;
364 }
365
366
367 void
368 eputs( /* put string to stderr */
369 const char *s
370 )
371 {
372 static int midline = 0;
373
374 if (!*s)
375 return;
376 if (!midline++) {
377 fputs(progname, stderr);
378 fputs(": ", stderr);
379 }
380 fputs(s, stderr);
381 if (s[strlen(s)-1] == '\n') {
382 fflush(stderr);
383 midline = 0;
384 }
385 }
386
387
388 static void
389 onsig( /* fatal signal */
390 int signo
391 )
392 {
393 static int gotsig = 0;
394
395 if (gotsig++) /* two signals and we're gone! */
396 _exit(signo);
397
398 alarm(30); /* allow 30 seconds to clean up */
399 signal(SIGALRM, SIG_DFL); /* make certain we do die */
400 eputs("signal - ");
401 eputs(sigerr[signo]);
402 eputs("\n");
403 quit(3);
404 }
405
406
407 static bool gotALRM = false; // flag for ALRM signal
408
409 static void
410 onalrm(int signo)
411 {
412 gotALRM = true;
413 }
414
415
416 static void
417 sigdie( /* set fatal signal */
418 int signo,
419 const char *msg
420 )
421 {
422 if (signal(signo, onsig) == SIG_IGN)
423 signal(signo, SIG_IGN);
424 sigerr[signo] = msg;
425 }
426
427
428 static void
429 printdefaults(void) /* print default values to stdout */
430 {
431 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
432 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
433 ourview.type==VT_PER ? "perspective" :
434 ourview.type==VT_PAR ? "parallel" :
435 ourview.type==VT_HEM ? "hemispherical" :
436 ourview.type==VT_ANG ? "angular" :
437 ourview.type==VT_CYL ? "cylindrical" :
438 ourview.type==VT_PLS ? "planisphere" :
439 "unknown");
440 printf("-vp %f %f %f\t# view point\n",
441 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
442 printf("-vd %f %f %f\t# view direction\n",
443 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
444 printf("-vu %f %f %f\t# view up\n",
445 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
446 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
447 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
448 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
449 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
450 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
451 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
452 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
453 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
454 printf("-X %-9d\t\t\t# horizontal tile divisions\n", tileGrid[0]);
455 printf("-Y %-9d\t\t\t# vertical tile divisions\n", tileGrid[1]);
456 if (myRPmanager.prims == stdprims)
457 printf("-pRGB\t\t\t\t# standard RGB color output\n");
458 else if (myRPmanager.prims == xyzprims)
459 printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
460 else if (myRPmanager.prims != NULL)
461 printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
462 myRPmanager.prims[RED][0], myRPmanager.prims[RED][1],
463 myRPmanager.prims[GRN][0], myRPmanager.prims[GRN][1],
464 myRPmanager.prims[BLU][0], myRPmanager.prims[BLU][1],
465 myRPmanager.prims[WHT][0], myRPmanager.prims[WHT][1]);
466 if (NCSAMP > 3)
467 printf(myRPmanager.prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
468 "-co+\t\t\t\t# output spectral values\n");
469 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
470 printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
471 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
472 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
473 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
474 printf(erract[WARNING].pf != NULL ?
475 "-w+\t\t\t\t# warning messages on\n" :
476 "-w-\t\t\t\t# warning messages off\n");
477 print_rdefaults();
478 }
479
480
481 // Struct for tracking tiles being rendered in mapped file / shared memory
482 struct TileProg {
483 short status; // 0==Unstarted, -1==InProgress, 1==Done
484 pid_t pID; // process operating on tile
485 } *tprog = NULL; // shared tile progress array
486
487 #define tile_p(ti) (tprog + (ti)[1]*tileGrid[0] + (ti)[0])
488
489 // Return true if tile is renderable
490 static bool
491 renderable_tile(TileProg *tp)
492 {
493 if (tp->status < 0 && kill(tp->pID, 0) < 0)
494 tp->status = 0; // dead process - reset
495
496 return !tp->status;
497 }
498
499
500 // handle multi-processing if requested, return true if all done
501 static bool
502 children_finished()
503 {
504 if (nproc <= 1) // single process -> run in parent
505 return false;
506 int cnt = 0; // else count ready-to-go tiles
507 int ti[2];
508 for (ti[1] = 0; ti[1] < tileGrid[1]; ti[1]++)
509 for (ti[0] = 0; ti[0] < tileGrid[0]; ti[0]++)
510 cnt += renderable_tile(tile_p(ti));
511 if (!cnt)
512 return false; // parent can do nothing
513 if (cnt < nproc) {
514 sprintf(errmsg, "only %d renderable tiles, reducing process count", cnt);
515 error(WARNING, errmsg);
516 if ((nproc = cnt) == 1)
517 return false; // back to single process
518 }
519 cow_memshare(); // else we'll be sharing memory
520 fflush(NULL); // and forking children
521 pid_t cpid; // create nproc children
522 for (cnt = nproc; cnt && (cpid = fork()) != 0; cnt--)
523 if (cpid < 0)
524 error(SYSTEM, "fork error!");
525
526 if (cpid == 0) { // children render tiles
527 sleep(nproc - cnt); // avoid race conditions
528 nproc = -1; // flag as child
529 return false;
530 }
531 cow_doneshare(); // parent frees memory and waits
532 signal(SIGALRM, SIG_IGN);
533 myRPmanager.Cleanup(true);
534 int nfailed = 0;
535 int status;
536 for (cnt = nproc; cnt && wait(&status) > 0; cnt--)
537 if (status) {
538 sprintf(errmsg, "child exited with status %d", status);
539 error(WARNING, errmsg);
540 if (!nfailed++ & (cnt > 1)) {
541 kill(0, SIGALRM);
542 error(WARNING, "waiting for other tiles to finish...");
543 }
544 }
545 if (cnt) {
546 sprintf(errmsg, "lost track of %d children", cnt);
547 error(WARNING, errmsg);
548 }
549 if (nfailed) {
550 sprintf(errmsg, "%d tiles were not completed", nfailed);
551 error(USER, errmsg);
552 }
553 return true; // all done!
554 }
555
556 // return next renderable tile, false if everything is done
557 static bool
558 nexttile(int ti[2])
559 {
560 static pid_t ourpID = 0;
561 static short * tlist = NULL;
562 static int tlen = 0;
563 static int tnext = 0;
564
565 if (gotALRM) { // pre-empting new work?
566 if (tlist) {
567 sprintf(errmsg, "process %d got alarm, exiting", ourpID);
568 CHECK(tnext<tlen, WARNING, errmsg);
569 free(tlist); tlist = NULL;
570 }
571 return false;
572 }
573 if (!tlist) { // initialize random tile list
574 ABitMap2 todoMap(tileGrid[0], tileGrid[1]);
575 tlen = 0;
576 for (ti[1] = 0; ti[1] < tileGrid[1]; ti[1]++)
577 for (ti[0] = 0; ti[0] < tileGrid[0]; ti[0]++)
578 if (renderable_tile(tile_p(ti))) {
579 todoMap.Set(ti[0], ti[1]);
580 tlen++;
581 }
582 if (!tlen)
583 return false; // nothing to do!
584 tlist = (short *)malloc(sizeof(short)*2*tlen);
585 CHECK(!tlist, SYSTEM, "out of memory in nexttile()");
586 tlen = 0; // assign entries
587 for (ti[0] = ti[1] = 0; todoMap.Find(&ti[0], &ti[1]); ti[0]++) {
588 tlist[2*tlen] = ti[0];
589 tlist[2*tlen+1] = ti[1];
590 tlen++;
591 }
592 // shuffle order w/ Fisher-Yates
593 for (int i = 0; i < tlen-1; i++) {
594 const int ix = irandom(tlen-i) + i;
595 ti[0] = tlist[2*i];
596 ti[1] = tlist[2*i+1];
597 tlist[2*i] = tlist[2*ix];
598 tlist[2*i+1] = tlist[2*ix+1];
599 tlist[2*ix] = ti[0];
600 tlist[2*ix+1] = ti[1];
601 }
602 ourpID = getpid(); // save time on system calls
603 }
604 while (tnext < tlen) { // find first available
605 ti[0] = tlist[2*tnext];
606 ti[1] = tlist[2*tnext+1];
607 tnext++; // take if still unclaimed
608 if (renderable_tile(tile_p(ti))) {
609 tile_p(ti)->status = -1;
610 tile_p(ti)->pID = ourpID;
611 return true;
612 }
613 }
614 free(tlist); tlist = NULL; // exhausted our list?
615 return false;
616 }
617
618
619 // Principal function for rpiece
620 static RenderDataType
621 rpiece(char *pout, RenderDataType dt, char *zout)
622 {
623 if (zout && *zout == '!')
624 error(USER, "cannot send depth to a command");
625
626 const bool newOutput = (access(pout, F_OK) < 0);
627 FILE *pdfp[2];
628 if (newOutput) { // new output file?
629 CHECK((tileGrid[0] <= 1) & (tileGrid[1] <= 1),
630 USER, "bad tiling specification");
631 } else {
632 dt = myRPmanager.ReopenOutput(pdfp, pout, zout);
633 if (dt == RDTnone)
634 return RDTnone;
635 if (!fscnresolu(&hresolu, &vresolu, pdfp[0]))
636 error(USER, "missing picture resolution");
637 pixaspect = .0; // need to leave this as is
638 myRPmanager.NewHeader(pout); // get prev. header info
639 const char * tval = myRPmanager.GetHeadStr("TILED=");
640 if (!tval || sscanf(tval, "%d %d", &tileGrid[0], &tileGrid[1]) != 2)
641 error(USER, "existing picture must be tiled");
642 CHECK(myRPmanager.GetView()==NULL,
643 USER, "missing view in picture file");
644 ourview = *myRPmanager.GetView();
645 }
646 int hvdim[2] = {hresolu, vresolu}; // set up tiled frame
647 if (!myRPmanager.NewFrame(ourview, hvdim, &pixaspect, tileGrid))
648 error(USER, "tiling setup error in rpiece");
649
650 if ((hvdim[0] != hresolu) | (hvdim[1] != vresolu)) {
651 if (!newOutput)
652 error(USER, "unexpected output size adjustment");
653 sprintf(errmsg, "resolution adjusted from %dx%d to %dx%d",
654 hresolu, vresolu, hvdim[0], hvdim[1]);
655 error(WARNING, errmsg);
656 hresolu = hvdim[0];
657 vresolu = hvdim[1];
658 }
659 if (newOutput){ // open new output here
660 char buf[64];
661 sprintf(buf, "TILED= %d %d\n", tileGrid[0], tileGrid[1]);
662 myRPmanager.AddHeader(buf);
663 dt = myRPmanager.NewOutput(pdfp, pout, dt, zout);
664 if (dt == RDTnone)
665 return RDTnone;
666 fprtresolu(hresolu, vresolu, pdfp[0]);
667 fflush(pdfp[0]);
668 if (RDTdepthT(dt) == RDTdshort) {
669 fprtresolu(hresolu, vresolu, pdfp[1]);
670 fflush(pdfp[1]);
671 }
672 } else if (RDTdepthT(dt) == RDTdshort &&
673 (!fscnresolu(&hvdim[0], &hvdim[1], pdfp[1]) ||
674 (hvdim[0] != hresolu) | (hvdim[1] != vresolu)))
675 error(USER, "mismatched depth file resolution");
676 // prepare (flat) pixel buffer
677 const long pdata_beg = ftell(pdfp[0]);
678 const size_t pixSiz = (RDTcolorT(dt)==RDTrgbe)|(RDTcolorT(dt)==RDTxyze) ? sizeof(COLR)
679 : (RDTcolorT(dt)==RDTrgb)|(RDTcolorT(dt)==RDTxyz) ? sizeof(COLORV)*3
680 : RDTcolorT(dt)==RDTscolr ? LSCOLR : sizeof(COLORV)*NCSAMP;
681 size_t pmlen = pdata_beg + pixSiz*hresolu*vresolu;
682 // put tile progress array at end
683 if (pmlen&7) pmlen += 8 - (pmlen&7); // 8-byte alignment to be safe
684 pmlen += sizeof(TileProg)*tileGrid[0]*tileGrid[1];
685 // map picture file to memory
686 if (newOutput && ftruncate(fileno(pdfp[0]), pmlen) < 0)
687 error(SYSTEM, "cannot extend picture buffer");
688 uby8 * pixMap = (uby8 *)mmap(NULL, pmlen, PROT_READ|PROT_WRITE,
689 MAP_SHARED, fileno(pdfp[0]), 0);
690 if ((void *)pixMap == MAP_FAILED)
691 error(SYSTEM, "cannot map picture file into memory");
692 // map depth buffer to memory
693 const long zdata_beg = RDTdepthT(dt) ? ftell(pdfp[1]) : 0L;
694 const size_t zdpSiz = RDTdepthT(dt)==RDTdshort ? sizeof(short) :
695 RDTdepthT(dt)==RDTdfloat ? sizeof(float) : 0;
696 const size_t zmlen = zdata_beg + zdpSiz*hresolu*vresolu;
697 uby8 * zdMap = NULL;
698 if (RDTdepthT(dt)) {
699 if (newOutput && ftruncate(fileno(pdfp[1]), zmlen) < 0)
700 error(SYSTEM, "cannot extend depth buffer");
701 zdMap = (uby8 *)mmap(NULL, zmlen, PROT_READ|PROT_WRITE,
702 MAP_SHARED, fileno(pdfp[1]), 0);
703 if ((void *)zdMap == MAP_FAILED)
704 error(SYSTEM, "cannot map depth file into memory");
705 }
706 fclose(pdfp[0]); // done with file pointers
707 if (RDTdepthT(dt)) fclose(pdfp[1]);
708 // point to tile progress array
709 tprog = (TileProg *)(pixMap + pmlen - sizeof(TileProg)*tileGrid[0]*tileGrid[1]);
710
711 if (children_finished()) // work done in children?
712 return dt;
713
714 int ndone = 0; // else render tiles
715 int ti[2];
716 while (nexttile(ti)) {
717 const int offset = (tileGrid[1]-1-ti[1])*myRPmanager.GetWidth()*myRPmanager.THeight() +
718 (myRPmanager.THeight()-1)*myRPmanager.GetWidth() +
719 ti[0]*myRPmanager.TWidth();
720 uby8 * pptr = pixMap + pdata_beg + pixSiz*offset;
721 uby8 * zptr = zdMap + zdata_beg + zdpSiz*offset;
722 bool ok = false;
723 switch (RDTcommonE(dt)<<1 | (RDTdepthT(dt)==RDTdshort)) {
724 case 2: // common-exponent color, float/no depth
725 ok = myRPmanager.RenderTile((COLRV *)pptr, -myRPmanager.GetWidth(),
726 (float *)zptr, ti);
727 break;
728 case 0: // float color, float/no depth
729 ok = myRPmanager.RenderTile((COLORV *)pptr, -myRPmanager.GetWidth(),
730 (float *)zptr, ti);
731 break;
732 case 3: // common-exponent color, encoded depth
733 ok = myRPmanager.RenderTile((COLRV *)pptr, -myRPmanager.GetWidth(),
734 (short *)zptr, ti);
735 break;
736 case 1: // float color, encoded depth
737 ok = myRPmanager.RenderTile((COLORV *)pptr, -myRPmanager.GetWidth(),
738 (short *)zptr, ti);
739 break;
740 }
741 if (!ok) { // got an error
742 sprintf(errmsg, "error rendering tile (%d,%d)/(%d,%d)",
743 ti[0], ti[1], tileGrid[0], tileGrid[1]);
744 error(USER, errmsg);
745 }
746 tile_p(ti)->status = 1; // mark tile completed
747 ndone++;
748 }
749 if (!ndone)
750 error(WARNING, "no tiles to render, exiting");
751 /*
752 munmap(pixMap, pmlen); // technically unnecessary...
753 if (zdMap) munmap(zdMap, zmlen);
754 */
755 return dt; // we're done here
756 }
