root/radiance/ray/src/rt/rxpiece.cpp
Revision: 2.9
Committed: Thu Jan 2 20:19:48 2025 UTC (7 months ago) by greg
perf(rxpiece,rxcontrib): Don't bother to free data structs on exit
2 static const char RCSid[] = "$Id: rxpiece.cpp,v 2.8 2024/12/13 22:17:33 greg Exp $";
5 * rxpiece.cpp - main for rxpiece tile rendering program
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11 #include <signal.h>
12 #include <sys/mman.h>
13 #include <unistd.h>
14
15 #include "platform.h"
16 #include "RpictSimulManager.h"
17 #include "ambient.h"
18 #include "pmapray.h"
19 #include "random.h"
20
21 extern char *progname; /* argv[0] */
22 const char *sigerr[NSIG]; /* signal error messages */
23
24 VIEW ourview = STDVIEW; /* global view parameters */
25 int hresolu = 1024; /* horizontal resolution */
26 int vresolu = 1024; /* vertical resolution */
27 double pixaspect = 1.0; /* pixel aspect ratio */
28 int hres, vres; /* current image resolution for srcdraw.c */
29
30 int tileGrid[2] = {5,5}; // tile subdivisions
31
32 int psample = 4; /* pixel sample size */
33 double maxdiff = .05; /* max. difference for interpolation */
34 double dstrpix = 0.67; /* square pixel distribution */
35
36 double mblur = 0.; /* motion blur parameter (unused) */
37
38 double dblur = 0.; /* depth-of-field blur parameter */
39
40 int nproc = 1; /* number of processes to run (-1 in child) */
41
42 RpictSimulManager myRPmanager; // global simulation manager
43
44 static void onsig(int signo);
45 static void onalrm(int signo);
46 static void sigdie(int signo, const char *msg);
47 static void printdefaults(void);
48 static RenderDataType rpiece(char *pout, RenderDataType dt, char *zout);
49
50 /* rxpiece additional features */
51 #define RXPIECE_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
52 "ParticipatingMedia=Mist\n" \
53 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
54 "PixelJitter\nPixelSampling\nPixelDepthOfField\n" \
55 "SmallSourceDrawing\n" \
56 "AdaptiveShadowTesting\nOutputs=v,l\n" \
57 "OutputCS=RGB,XYZ,prims,spec\n"
58
59 // Exit program
60 void
61 quit(int code) /* quit program */
62 {
63 if (nproc < 0) {
64 ray_pnprocs = -1; // hack to avoid cleanup in child
65 _exit(code);
66 }
67 exit(code); // don't bother to free data structs
68 }
69
70 /* Set default options */
71 static void
72 default_options(void)
73 {
74 shadthresh = .05;
75 shadcert = .5;
76 srcsizerat = .25;
77 directrelay = 1;
78 ambacc = 0.2;
79 ambres = 64;
80 ambdiv = 512;
81 ambssamp = 128;
82 maxdepth = 7;
83 }
84
85 int
86 main(int argc, char *argv[])
87 {
88 #define check(ol,al) if (argv[i][ol] || \
89 badarg(argc-i-1,argv+i+1,al)) \
90 goto badopt
91 #define check_bool(olen,var) switch (argv[i][olen]) { \
92 case '\0': var = !var; break; \
93 case 'y': case 'Y': case 't': case 'T': \
94 case '+': case '1': var = 1; break; \
95 case 'n': case 'N': case 'f': case 'F': \
96 case '-': case '0': var = 0; break; \
97 default: goto badopt; }
98 RGBPRIMS our_prims; /* private output color primitives */
99 RenderDataType dtype = RDTrgbe; // output data flags
100 char *outfile = NULL;
101 char *zfile = NULL;
102 int outfmt = 'c';
103 int rval;
104 int i;
105 /* global program name */
106 progname = argv[0];
107 /* feature check only? */
108 strcat(RFeatureList, RXPIECE_FEATURES);
109 if (argc > 1 && !strcmp(argv[1], "-features"))
110 return feature_status(argc-2, argv+2);
111 /* set defaults */
112 default_options();
113 /* option city */
114 for (i = 1; i < argc; i++) {
115 /* expand arguments */
116 while ((rval = expandarg(&argc, &argv, i)) > 0)
117 ;
118 if (rval < 0) {
119 sprintf(errmsg, "cannot expand '%s'", argv[i]);
120 error(SYSTEM, errmsg);
121 }
122 if (argv[i] == NULL || argv[i][0] != '-')
123 break; /* break from options */
124 if (!strcmp(argv[i], "-version")) {
125 puts(VersionID);
126 quit(0);
127 }
128 if (!strcmp(argv[i], "-defaults") ||
129 !strcmp(argv[i], "-help")) {
130 printdefaults();
131 quit(0);
132 }
133 rval = getrenderopt(argc-i, argv+i);
134 if (rval >= 0) {
135 i += rval;
136 continue;
137 }
138 rval = getviewopt(&ourview, argc-i, argv+i);
139 if (rval >= 0) {
140 i += rval;
141 continue;
142 }
143 /* rxpiece options */
144 switch (argv[i][1]) {
145 case 'v': /* view file */
146 if (argv[i][2] != 'f')
147 goto badopt;
148 check(3,"s");
149 rval = viewfile(argv[++i], &ourview, NULL);
150 if (rval < 0) {
151 sprintf(errmsg,
152 "cannot open view file \"%s\"",
153 argv[i]);
154 error(SYSTEM, errmsg);
155 } else if (rval == 0) {
156 sprintf(errmsg,
157 "bad view file \"%s\"",
158 argv[i]);
159 error(USER, errmsg);
160 }
161 break;
162 case 'n': /* number of processes */
163 check(2,"i");
164 nproc = atoi(argv[++i]);
165 if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0)
166 nproc = 1;
167 break;
168 case 'f': /* output format */
169 if ((argv[i][2] != 'c') & (argv[i][2] != 'f')
170 || argv[i][3])
171 goto badopt;
172 outfmt = argv[i][2];
173 break;
174 case 'p': /* pixel */
175 switch (argv[i][2]) {
176 case 's': /* sample */
177 check(3,"i");
178 psample = atoi(argv[++i]);
179 if (psample < 1) psample = 1;
180 break;
181 case 't': /* threshold */
182 check(3,"f");
183 maxdiff = atof(argv[++i]);
184 break;
185 case 'j': /* jitter */
186 check(3,"f");
187 dstrpix = atof(argv[++i]);
188 break;
189 case 'a': /* aspect */
190 check(3,"f");
191 pixaspect = atof(argv[++i]);
192 break;
193 case 'd': /* aperture */
194 check(3,"f");
195 dblur = atof(argv[++i]);
196 dblur *= (dblur > 0);
197 break;
198 case 'R': /* standard RGB output */
199 if (strcmp(argv[i]+2, "RGB"))
200 goto badopt;
201 myRPmanager.prims = stdprims;
202 dtype = RDTnewCT(dtype, RDTrgbe);
203 break;
204 case 'X': /* XYZ output */
205 if (strcmp(argv[i]+2, "XYZ"))
206 goto badopt;
207 myRPmanager.prims = xyzprims;
208 dtype = RDTnewCT(dtype, RDTxyze);
209 break;
210 case 'c': /* chromaticities */
211 check(3,"ffffffff");
212 rval = 0;
213 for (int j = 0; j < 8; j++) {
214 our_prims[0][j] = atof(argv[++i]);
215 rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
216 }
217 if (rval) {
218 if (!colorprimsOK(our_prims))
219 error(USER, "illegal primary chromaticities");
220 myRPmanager.prims = our_prims;
221 } else
222 myRPmanager.prims = stdprims;
223 dtype = RDTnewCT(dtype, RDTrgbe);
224 break;
225 default:
226 goto badopt;
227 }
228 break;
229 case 'd': /* reference depth */
230 if (argv[i][2] || !myRPmanager.SetReferenceDepth(argv[++i]))
231 goto badopt;
232 dtype = RDTnewDT(dtype, RDTdshort);
233 break;
234 case 'x': /* x resolution */
235 check(2,"i");
236 hresolu = atoi(argv[++i]);
237 break;
238 case 'y': /* y resolution */
239 check(2,"i");
240 vresolu = atoi(argv[++i]);
241 break;
242 case 'X': /* horizontal tile subdivisions */
243 check(2,"i");
244 tileGrid[0] = atoi(argv[++i]);
245 break;
246 case 'Y': /* vertical tile subdivisions */
247 check(2,"i");
248 tileGrid[1] = atoi(argv[++i]);
249 break;
250 case 'o': /* output file */
251 check(2,"s");
252 outfile = argv[++i];
253 break;
254 case 'z': /* z file */
255 check(2,"s");
256 zfile = argv[++i];
257 break;
258 #if MAXCSAMP>3
259 case 'c': /* output spectral results */
260 if (argv[i][2] != 'o')
261 goto badopt;
262 rval = (myRPmanager.prims == NULL);
263 check_bool(3,rval);
264 if (rval)
265 myRPmanager.prims = NULL;
266 else if (myRPmanager.prims == NULL)
267 myRPmanager.prims = stdprims;
268 dtype = RDTnewCT(dtype, rval ? RDTscolr : RDTrgbe);
269 break;
270 #endif
271 case 'w': /* warnings */
272 rval = erract[WARNING].pf != NULL;
273 check_bool(2,rval);
274 if (rval) erract[WARNING].pf = wputs;
275 else erract[WARNING].pf = NULL;
276 break;
277 default:
278 goto badopt;
279 }
280 }
281 if (maxdiff <= FTINY) /* check for useless sampling */
282 psample = 1;
283 if (outfile == NULL)
284 error(USER, "missing output file (-o option)");
285 if (zfile == NULL) /* set up depth output */
286 dtype = RDTnewDT(dtype, RDTnone);
287 else if (!RDTdepthT(dtype))
288 dtype = RDTnewDT(dtype, RDTdfloat);
289 /* check pixel output type */
290 if ((myRPmanager.prims == NULL) & (NCSAMP == 3)) {
291 myRPmanager.prims = stdprims;
292 dtype = RDTnewCT(dtype, RDTrgbe);
293 }
294 if (outfmt == 'f')
295 switch (RDTcolorT(dtype)) {
296 case RDTrgbe:
297 dtype = RDTnewCT(dtype, RDTrgb);
298 break;
299 case RDTxyze:
300 dtype = RDTnewCT(dtype, RDTxyz);
301 break;
302 case RDTscolr:
303 dtype = RDTnewCT(dtype, RDTscolor);
304 break;
305 case RDTrgb:
306 case RDTxyz:
307 case RDTscolor:
308 break;
309 default:
310 error(INTERNAL, "botched color output type");
311 }
312 /* set up signal handling */
313 sigdie(SIGINT, "Interrupt");
314 sigdie(SIGHUP, "Hangup");
315 sigdie(SIGTERM, "Terminate");
316 sigdie(SIGPIPE, "Broken pipe");
317 signal(SIGALRM, onalrm); // used to gracefully terminate
318 #ifdef SIGXCPU
319 sigdie(SIGXCPU, "CPU limit exceeded");
320 sigdie(SIGXFSZ, "File size exceeded");
321 #endif
322 #ifdef NICE
323 nice(NICE); /* lower priority */
324 #endif
325 if (i < argc-1)
326 goto badopt;
327 // load octree
328 if (!myRPmanager.LoadOctree(argv[i]))
329 error(USER, "missing octree argument");
330 // add new header info
331 myRPmanager.AddHeader(i, argv);
332 {
333 char buf[128] = "SOFTWARE= ";
334 strcpy(buf+10, VersionID);
335 myRPmanager.AddHeader(buf);
336 }
337 // render tiles
338 dtype = rpiece(outfile, dtype, zfile);
339
340 ambsync(); // flush ambient cache
341
342 ray_done_pmap(); /* PMAP: free photon maps */
343
344 quit(dtype==RDTnone); // status is 1 on failure
345
346 badopt:
347 sprintf(errmsg, "command line error at '%s'", argv[i]);
348 error(USER, errmsg);
349 return 1; /* pro forma return */
350
351 #undef check
352 #undef check_bool
353 }
354
355
356 void
357 wputs( /* warning output function */
358 const char *s
359 )
360 {
361 if (!erract[WARNING].pf)
362 return; // warnings were disabled!
363 int lasterrno = errno;
364 eputs(s);
365 errno = lasterrno;
366 }
367
368
369 void
370 eputs( /* put string to stderr */
371 const char *s
372 )
373 {
374 static int midline = 0;
375
376 if (!*s)
377 return;
378 if (!midline++) {
379 fputs(progname, stderr);
380 fputs(": ", stderr);
381 }
382 fputs(s, stderr);
383 if (s[strlen(s)-1] == '\n') {
384 fflush(stderr);
385 midline = 0;
386 }
387 }
388
389
390 static void
391 onsig( /* fatal signal */
392 int signo
393 )
394 {
395 static int gotsig = 0;
396
397 if (gotsig++) /* two signals and we're gone! */
398 _exit(signo);
399
400 alarm(30); /* allow 30 seconds to clean up */
401 signal(SIGALRM, SIG_DFL); /* make certain we do die */
402 eputs("signal - ");
403 eputs(sigerr[signo]);
404 eputs("\n");
405 quit(3);
406 }
407
408
409 static bool gotALRM = false; // flag for ALRM signal
410
411 static void
412 onalrm(int signo)
413 {
414 gotALRM = true;
415 }
416
417
418 static void
419 sigdie( /* set fatal signal */
420 int signo,
421 const char *msg
422 )
423 {
424 if (signal(signo, onsig) == SIG_IGN)
425 signal(signo, SIG_IGN);
426 sigerr[signo] = msg;
427 }
428
429
430 static void
431 printdefaults(void) /* print default values to stdout */
432 {
433 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
434 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
435 ourview.type==VT_PER ? "perspective" :
436 ourview.type==VT_PAR ? "parallel" :
437 ourview.type==VT_HEM ? "hemispherical" :
438 ourview.type==VT_ANG ? "angular" :
439 ourview.type==VT_CYL ? "cylindrical" :
440 ourview.type==VT_PLS ? "planisphere" :
441 "unknown");
442 printf("-vp %f %f %f\t# view point\n",
443 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
444 printf("-vd %f %f %f\t# view direction\n",
445 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
446 printf("-vu %f %f %f\t# view up\n",
447 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
448 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
449 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
450 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
451 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
452 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
453 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
454 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
455 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
456 printf("-X %-9d\t\t\t# horizontal tile divisions\n", tileGrid[0]);
457 printf("-Y %-9d\t\t\t# vertical tile divisions\n", tileGrid[1]);
458 if (myRPmanager.prims == stdprims)
459 printf("-pRGB\t\t\t\t# standard RGB color output\n");
460 else if (myRPmanager.prims == xyzprims)
461 printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
462 else if (myRPmanager.prims != NULL)
463 printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
464 myRPmanager.prims[RED][0], myRPmanager.prims[RED][1],
465 myRPmanager.prims[GRN][0], myRPmanager.prims[GRN][1],
466 myRPmanager.prims[BLU][0], myRPmanager.prims[BLU][1],
467 myRPmanager.prims[WHT][0], myRPmanager.prims[WHT][1]);
468 if (NCSAMP > 3)
469 printf(myRPmanager.prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
470 "-co+\t\t\t\t# output spectral values\n");
471 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
472 printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
473 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
474 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
475 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
476 printf(erract[WARNING].pf != NULL ?
477 "-w+\t\t\t\t# warning messages on\n" :
478 "-w-\t\t\t\t# warning messages off\n");
479 print_rdefaults();
480 }
481
482
483 // Struct for tracking tiles being rendered in mapped file / shared memory
484 struct TileProg {
485 short status; // 0==Unstarted, -1==InProgress, 1==Done
486 pid_t pID; // process operating on tile
487 } *tprog = NULL; // shared tile progress array
488
489 #define tile_p(ti) (tprog + (ti)[1]*tileGrid[0] + (ti)[0])
490
491 // Return true if tile is renderable
492 static bool
493 renderable_tile(TileProg *tp)
494 {
495 if (tp->status < 0 && kill(tp->pID, 0) < 0)
496 tp->status = 0; // dead process - reset
497
498 return !tp->status;
499 }
500
501
502 // handle multi-processing if requested, return true if all done
503 static bool
504 children_finished()
505 {
506 if (nproc <= 1) // single process -> run in parent
507 return false;
508 int cnt = 0; // else count ready-to-go tiles
509 int ti[2];
510 for (ti[1] = 0; ti[1] < tileGrid[1]; ti[1]++)
511 for (ti[0] = 0; ti[0] < tileGrid[0]; ti[0]++)
512 cnt += renderable_tile(tile_p(ti));
513 if (!cnt)
514 return false; // parent can do nothing
515 if (cnt < nproc) {
516 sprintf(errmsg, "only %d renderable tiles, reducing process count", cnt);
517 error(WARNING, errmsg);
518 if ((nproc = cnt) == 1)
519 return false; // back to single process
520 }
521 cow_memshare(); // else we'll be sharing memory
522 fflush(NULL); // and forking children
523 pid_t cpid; // create nproc children
524 for (cnt = nproc; cnt && (cpid = fork()) != 0; cnt--)
525 if (cpid < 0)
526 error(SYSTEM, "fork error!");
527
528 if (cpid == 0) { // children render tiles
529 sleep(nproc - cnt); // avoid race conditions
530 nproc = -1; // flag as child
531 return false;
532 }
533 cow_doneshare(); // parent frees memory and waits
534 signal(SIGALRM, SIG_IGN);
535 myRPmanager.Cleanup(true);
536 int nfailed = 0;
537 int status;
538 for (cnt = nproc; cnt && wait(&status) > 0; cnt--)
539 if (status) {
540 sprintf(errmsg, "child exited with status %d", status);
541 error(WARNING, errmsg);
542 if (!nfailed++ & (cnt > 1)) {
543 kill(0, SIGALRM);
544 error(WARNING, "waiting for other tiles to finish...");
545 }
546 }
547 if (cnt) {
548 sprintf(errmsg, "lost track of %d children", cnt);
549 error(WARNING, errmsg);
550 }
551 if (nfailed) {
552 sprintf(errmsg, "%d tiles were not completed", nfailed);
553 error(USER, errmsg);
554 }
555 return true; // all done!
556 }
557
558 // return next renderable tile, false if everything is done
559 static bool
560 nexttile(int ti[2])
561 {
562 static pid_t ourpID = 0;
563 static short * tlist = NULL;
564 static int tlen = 0;
565 static int tnext = 0;
566
567 if (gotALRM) { // pre-empting new work?
568 if (tlist) {
569 sprintf(errmsg, "process %d got alarm, exiting", ourpID);
570 CHECK(tnext<tlen, WARNING, errmsg);
571 free(tlist); tlist = NULL;
572 }
573 return false;
574 }
575 if (!tlist) { // initialize random tile list
576 ABitMap2 todoMap(tileGrid[0], tileGrid[1]);
577 tlen = 0;
578 for (ti[1] = 0; ti[1] < tileGrid[1]; ti[1]++)
579 for (ti[0] = 0; ti[0] < tileGrid[0]; ti[0]++)
580 if (renderable_tile(tile_p(ti))) {
581 todoMap.Set(ti[0], ti[1]);
582 tlen++;
583 }
584 if (!tlen)
585 return false; // nothing to do!
586 tlist = (short *)malloc(sizeof(short)*2*tlen);
587 CHECK(!tlist, SYSTEM, "out of memory in nexttile()");
588 tlen = 0; // assign entries
589 for (ti[0] = ti[1] = 0; todoMap.Find(&ti[0], &ti[1]); ti[0]++) {
590 tlist[2*tlen] = ti[0];
591 tlist[2*tlen+1] = ti[1];
592 tlen++;
593 }
594 // shuffle order w/ Fisher-Yates
595 for (int i = 0; i < tlen-1; i++) {
596 const int ix = irandom(tlen-i) + i;
597 ti[0] = tlist[2*i];
598 ti[1] = tlist[2*i+1];
599 tlist[2*i] = tlist[2*ix];
600 tlist[2*i+1] = tlist[2*ix+1];
601 tlist[2*ix] = ti[0];
602 tlist[2*ix+1] = ti[1];
603 }
604 ourpID = getpid(); // save time on system calls
605 }
606 while (tnext < tlen) { // find first available
607 ti[0] = tlist[2*tnext];
608 ti[1] = tlist[2*tnext+1];
609 tnext++; // take if still unclaimed
610 if (renderable_tile(tile_p(ti))) {
611 tile_p(ti)->status = -1;
612 tile_p(ti)->pID = ourpID;
613 return true;
614 }
615 }
616 free(tlist); tlist = NULL; // exhausted our list?
617 return false;
618 }
619
620
621 // Principal function for rpiece
622 static RenderDataType
623 rpiece(char *pout, RenderDataType dt, char *zout)
624 {
625 if (zout && *zout == '!')
626 error(USER, "cannot send depth to a command");
627
628 const bool newOutput = (access(pout, F_OK) < 0);
629 FILE *pdfp[2];
630 if (newOutput) { // new output file?
631 CHECK((tileGrid[0] <= 1) & (tileGrid[1] <= 1),
632 USER, "bad tiling specification");
633 } else {
634 dt = myRPmanager.ReopenOutput(pdfp, pout, zout);
635 if (dt == RDTnone)
636 return RDTnone;
637 if (!fscnresolu(&hresolu, &vresolu, pdfp[0]))
638 error(USER, "missing picture resolution");
639 pixaspect = .0; // need to leave this as is
640 myRPmanager.NewHeader(pout); // get prev. header info
641 const char * tval = myRPmanager.GetHeadStr("TILED=");
642 if (tval) sscanf(tval, "%d %d", &tileGrid[0], &tileGrid[1]);
643 CHECK(myRPmanager.GetView()==NULL,
644 USER, "missing view in picture file");
645 ourview = *myRPmanager.GetView();
646 }
647 int hvdim[2] = {hresolu, vresolu}; // set up tiled frame
648 if (!myRPmanager.NewFrame(ourview, hvdim, &pixaspect, tileGrid))
649 error(USER, "tiling setup error in rpiece");
650
651 if ((hvdim[0] != hresolu) | (hvdim[1] != vresolu)) {
652 if (!newOutput)
653 error(USER, "unexpected output size adjustment");
654 sprintf(errmsg, "resolution adjusted from %dx%d to %dx%d",
655 hresolu, vresolu, hvdim[0], hvdim[1]);
656 error(WARNING, errmsg);
657 hresolu = hvdim[0];
658 vresolu = hvdim[1];
659 }
660 if (newOutput){ // open new output here
661 char buf[64];
662 sprintf(buf, "TILED= %d %d\n", tileGrid[0], tileGrid[1]);
663 myRPmanager.AddHeader(buf);
664 dt = myRPmanager.NewOutput(pdfp, pout, dt, zout);
665 if (dt == RDTnone)
666 return RDTnone;
667 fprtresolu(hresolu, vresolu, pdfp[0]);
668 fflush(pdfp[0]);
669 if (RDTdepthT(dt) == RDTdshort) {
670 fprtresolu(hresolu, vresolu, pdfp[1]);
671 fflush(pdfp[1]);
672 }
673 } else if (RDTdepthT(dt) == RDTdshort &&
674 (!fscnresolu(&hvdim[0], &hvdim[1], pdfp[1]) ||
675 (hvdim[0] != hresolu) | (hvdim[1] != vresolu)))
676 error(USER, "mismatched depth file resolution");
677 // prepare (flat) pixel buffer
678 const long pdata_beg = ftell(pdfp[0]);
679 const size_t pixSiz = (RDTcolorT(dt)==RDTrgbe)|(RDTcolorT(dt)==RDTxyze) ? sizeof(COLR)
680 : (RDTcolorT(dt)==RDTrgb)|(RDTcolorT(dt)==RDTxyz) ? sizeof(COLORV)*3
681 : RDTcolorT(dt)==RDTscolr ? LSCOLR : sizeof(COLORV)*NCSAMP;
682 size_t pmlen = pdata_beg + pixSiz*hresolu*vresolu;
683 // put tile progress array at end
684 if (pmlen&7) pmlen += 8 - (pmlen&7); // 8-byte alignment to be safe
685 pmlen += sizeof(TileProg)*tileGrid[0]*tileGrid[1];
686 // map picture file to memory
687 if (newOutput && ftruncate(fileno(pdfp[0]), pmlen) < 0)
688 error(SYSTEM, "cannot extend picture buffer");
689 uby8 * pixMap = (uby8 *)mmap(NULL, pmlen, PROT_READ|PROT_WRITE,
690 MAP_SHARED, fileno(pdfp[0]), 0);
691 if ((void *)pixMap == MAP_FAILED)
692 error(SYSTEM, "cannot map picture file into memory");
693 // map depth buffer to memory
694 const long zdata_beg = RDTdepthT(dt) ? ftell(pdfp[1]) : 0L;
695 const size_t zdpSiz = RDTdepthT(dt)==RDTdshort ? sizeof(short) :
696 RDTdepthT(dt)==RDTdfloat ? sizeof(float) : 0;
697 const size_t zmlen = zdata_beg + zdpSiz*hresolu*vresolu;
698 uby8 * zdMap = NULL;
699 if (RDTdepthT(dt)) {
700 if (newOutput && ftruncate(fileno(pdfp[1]), zmlen) < 0)
701 error(SYSTEM, "cannot extend depth buffer");
702 zdMap = (uby8 *)mmap(NULL, zmlen, PROT_READ|PROT_WRITE,
703 MAP_SHARED, fileno(pdfp[1]), 0);
704 if ((void *)zdMap == MAP_FAILED)
705 error(SYSTEM, "cannot map depth file into memory");
706 }
707 fclose(pdfp[0]); // done with file pointers
708 if (RDTdepthT(dt)) fclose(pdfp[1]);
709 // point to tile progress array
710 tprog = (TileProg *)(pixMap + pmlen - sizeof(TileProg)*tileGrid[0]*tileGrid[1]);
711
712 if (children_finished()) // work done in children?
713 return dt;
714
715 int ndone = 0; // else render tiles
716 int ti[2];
717 while (nexttile(ti)) {
718 const int offset = (tileGrid[1]-1-ti[1])*myRPmanager.GetWidth()*myRPmanager.THeight() +
719 (myRPmanager.THeight()-1)*myRPmanager.GetWidth() +
720 ti[0]*myRPmanager.TWidth();
721 uby8 * pptr = pixMap + pdata_beg + pixSiz*offset;
722 uby8 * zptr = zdMap + zdata_beg + zdpSiz*offset;
723 bool ok = false;
724 switch (RDTcommonE(dt)<<1 | (RDTdepthT(dt)==RDTdshort)) {
725 case 2: // common-exponent color, float/no depth
726 ok = myRPmanager.RenderTile((COLRV *)pptr, -myRPmanager.GetWidth(),
727 (float *)zptr, ti);
728 break;
729 case 0: // float color, float/no depth
730 ok = myRPmanager.RenderTile((COLORV *)pptr, -myRPmanager.GetWidth(),
731 (float *)zptr, ti);
732 break;
733 case 3: // common-exponent color, encoded depth
734 ok = myRPmanager.RenderTile((COLRV *)pptr, -myRPmanager.GetWidth(),
735 (short *)zptr, ti);
736 break;
737 case 1: // float color, encoded depth
738 ok = myRPmanager.RenderTile((COLORV *)pptr, -myRPmanager.GetWidth(),
739 (short *)zptr, ti);
740 break;
741 }
742 if (!ok) { // got an error
743 sprintf(errmsg, "error rendering tile (%d,%d)/(%d,%d)",
744 ti[0], ti[1], tileGrid[0], tileGrid[1]);
745 error(USER, errmsg);
746 }
747 tile_p(ti)->status = 1; // mark tile completed
748 ndone++;
749 }
750 if (!ndone)
751 error(WARNING, "no tiles need rendering, exit");
752 /*
753 munmap(pixMap, pmlen); // technically unnecessary...
754 if (zdMap) munmap(zdMap, zmlen);
755 */
756 return dt; // we're done here
757 }
