root/radiance/ray/src/rt/rxpiece.cpp
Revision: 2.4
Committed: Tue Sep 17 02:24:18 2024 UTC (7 months, 2 weeks ago) by greg
Changes since 2.3: +9 -8 lines
feat(rxpiece): Additional error diagnostics
2 static const char RCSid[] = "$Id: rxpiece.cpp,v 2.3 2024/09/17 00:25:41 greg Exp $";
5 * rxpiece.cpp - main for rxpiece tile rendering program
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11 #include <signal.h>
12 #include <sys/mman.h>
13 #include <unistd.h>
14
15 #include "platform.h"
16 #include "RpictSimulManager.h"
17 #include "random.h"
18
19 extern char *progname; /* argv[0] */
20 const char *sigerr[NSIG]; /* signal error messages */
21
22 VIEW ourview = STDVIEW; /* global view parameters */
23 int hresolu = 1024; /* horizontal resolution */
24 int vresolu = 1024; /* vertical resolution */
25 double pixaspect = 1.0; /* pixel aspect ratio */
26 int hres, vres; /* current image resolution for srcdraw.c */
27
28 int tileGrid[2] = {5,5}; // tile subdivisions
29
30 int psample = 4; /* pixel sample size */
31 double maxdiff = .05; /* max. difference for interpolation */
32 double dstrpix = 0.67; /* square pixel distribution */
33
34 double mblur = 0.; /* motion blur parameter (unused) */
35
36 double dblur = 0.; /* depth-of-field blur parameter */
37
38 int nproc = 1; /* number of processes to run */
39
40 RpictSimulManager myRPmanager; // global simulation manager
41
42 static void onsig(int signo);
43 static void onalrm(int signo);
44 static void sigdie(int signo, const char *msg);
45 static void printdefaults(void);
46 static RenderDataType rpiece(char *pout, RenderDataType dt, char *zout);
47
48 /* rxpiece additional features */
49 #define RXPIECE_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
50 "ParticipatingMedia=Mist\n" \
51 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
52 "PixelJitter\nPixelSampling\nPixelDepthOfField\n" \
53 "SmallSourceDrawing\n" \
54 "AdaptiveShadowTesting\nOutputs=v,l\n" \
55 "OutputCS=RGB,XYZ,prims,spec\n"
56
57
58 void
59 quit(int code) /* quit program */
60 {
61 exit(code);
62 }
63
64
65 int
66 main(int argc, char *argv[])
67 {
68 #define check(ol,al) if (argv[i][ol] || \
69 badarg(argc-i-1,argv+i+1,al)) \
70 goto badopt
71 #define check_bool(olen,var) switch (argv[i][olen]) { \
72 case '\0': var = !var; break; \
73 case 'y': case 'Y': case 't': case 'T': \
74 case '+': case '1': var = 1; break; \
75 case 'n': case 'N': case 'f': case 'F': \
76 case '-': case '0': var = 0; break; \
77 default: goto badopt; }
78 RGBPRIMS our_prims; /* private output color primitives */
79 RenderDataType dtype = RDTrgbe; // output data flags
80 char *outfile = NULL;
81 char *zfile = NULL;
82 int outfmt = 'c';
83 int rval;
84 int i;
85 /* global program name */
86 progname = argv[0];
87 /* feature check only? */
88 strcat(RFeatureList, RXPIECE_FEATURES);
89 if (argc > 1 && !strcmp(argv[1], "-features"))
90 return feature_status(argc-2, argv+2);
91 /* option city */
92 for (i = 1; i < argc; i++) {
93 /* expand arguments */
94 while ((rval = expandarg(&argc, &argv, i)) > 0)
95 ;
96 if (rval < 0) {
97 sprintf(errmsg, "cannot expand '%s'", argv[i]);
98 error(SYSTEM, errmsg);
99 }
100 if (argv[i] == NULL || argv[i][0] != '-')
101 break; /* break from options */
102 if (!strcmp(argv[i], "-version")) {
103 puts(VersionID);
104 quit(0);
105 }
106 if (!strcmp(argv[i], "-defaults") ||
107 !strcmp(argv[i], "-help")) {
108 printdefaults();
109 quit(0);
110 }
111 rval = getrenderopt(argc-i, argv+i);
112 if (rval >= 0) {
113 i += rval;
114 continue;
115 }
116 rval = getviewopt(&ourview, argc-i, argv+i);
117 if (rval >= 0) {
118 i += rval;
119 continue;
120 }
121 /* rxpiece options */
122 switch (argv[i][1]) {
123 case 'v': /* view file */
124 if (argv[i][2] != 'f')
125 goto badopt;
126 check(3,"s");
127 rval = viewfile(argv[++i], &ourview, NULL);
128 if (rval < 0) {
129 sprintf(errmsg,
130 "cannot open view file \"%s\"",
131 argv[i]);
132 error(SYSTEM, errmsg);
133 } else if (rval == 0) {
134 sprintf(errmsg,
135 "bad view file \"%s\"",
136 argv[i]);
137 error(USER, errmsg);
138 }
139 break;
140 case 'n': /* number of processes */
141 check(2,"i");
142 nproc = atoi(argv[++i]);
143 if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0)
144 nproc = 1;
145 break;
146 case 'f': /* output format */
147 if ((argv[i][2] != 'c') & (argv[i][2] != 'f')
148 || argv[i][3])
149 goto badopt;
150 outfmt = argv[i][2];
151 break;
152 case 'p': /* pixel */
153 switch (argv[i][2]) {
154 case 's': /* sample */
155 check(3,"i");
156 psample = atoi(argv[++i]);
157 if (psample < 1) psample = 1;
158 break;
159 case 't': /* threshold */
160 check(3,"f");
161 maxdiff = atof(argv[++i]);
162 break;
163 case 'j': /* jitter */
164 check(3,"f");
165 dstrpix = atof(argv[++i]);
166 break;
167 case 'a': /* aspect */
168 check(3,"f");
169 pixaspect = atof(argv[++i]);
170 break;
171 case 'd': /* aperture */
172 check(3,"f");
173 dblur = atof(argv[++i]);
174 dblur *= (dblur > 0);
175 break;
176 case 'R': /* standard RGB output */
177 if (strcmp(argv[i]+2, "RGB"))
178 goto badopt;
179 myRPmanager.prims = stdprims;
180 dtype = RDTnewCT(dtype, RDTrgbe);
181 break;
182 case 'X': /* XYZ output */
183 if (strcmp(argv[i]+2, "XYZ"))
184 goto badopt;
185 myRPmanager.prims = xyzprims;
186 dtype = RDTnewCT(dtype, RDTxyze);
187 break;
188 case 'c': /* chromaticities */
189 check(3,"ffffffff");
190 rval = 0;
191 for (int j = 0; j < 8; j++) {
192 our_prims[0][j] = atof(argv[++i]);
193 rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
194 }
195 if (rval) {
196 if (!colorprimsOK(our_prims))
197 error(USER, "illegal primary chromaticities");
198 myRPmanager.prims = our_prims;
199 } else
200 myRPmanager.prims = stdprims;
201 dtype = RDTnewCT(dtype, RDTrgbe);
202 break;
203 default:
204 goto badopt;
205 }
206 break;
207 case 'd': /* reference depth */
208 if (argv[i][2] || !myRPmanager.SetReferenceDepth(argv[++i]))
209 goto badopt;
210 dtype = RDTnewDT(dtype, RDTdshort);
211 break;
212 case 'x': /* x resolution */
213 check(2,"i");
214 hresolu = atoi(argv[++i]);
215 break;
216 case 'y': /* y resolution */
217 check(2,"i");
218 vresolu = atoi(argv[++i]);
219 break;
220 case 'X': /* horizontal tile subdivisions */
221 check(2,"i");
222 tileGrid[0] = atoi(argv[++i]);
223 break;
224 case 'Y': /* vertical tile subdivisions */
225 check(2,"i");
226 tileGrid[1] = atoi(argv[++i]);
227 break;
228 case 'o': /* output file */
229 check(2,"s");
230 outfile = argv[++i];
231 break;
232 case 'z': /* z file */
233 check(2,"s");
234 zfile = argv[++i];
235 break;
236 #if MAXCSAMP>3
237 case 'c': /* output spectral results */
238 if (argv[i][2] != 'o')
239 goto badopt;
240 rval = (myRPmanager.prims == NULL);
241 check_bool(3,rval);
242 if (rval)
243 myRPmanager.prims = NULL;
244 else if (myRPmanager.prims == NULL)
245 myRPmanager.prims = stdprims;
246 dtype = RDTnewCT(dtype, rval ? RDTscolr : RDTrgbe);
247 break;
248 #endif
249 case 'w': /* warnings */
250 rval = erract[WARNING].pf != NULL;
251 check_bool(2,rval);
252 if (rval) erract[WARNING].pf = wputs;
253 else erract[WARNING].pf = NULL;
254 break;
255 default:
256 goto badopt;
257 }
258 }
259 if (maxdiff <= FTINY) /* check for useless sampling */
260 psample = 1;
261 if (outfile == NULL)
262 error(USER, "missing output file (-o option)");
263 if (zfile == NULL) /* set up depth output */
264 dtype = RDTnewDT(dtype, RDTnone);
265 else if (!RDTdepthT(dtype))
266 dtype = RDTnewDT(dtype, RDTdfloat);
267 /* check pixel output type */
268 if ((myRPmanager.prims == NULL) & (NCSAMP == 3)) {
269 myRPmanager.prims = stdprims;
270 dtype = RDTnewCT(dtype, RDTrgbe);
271 }
272 if (outfmt == 'f')
273 switch (RDTcolorT(dtype)) {
274 case RDTrgbe:
275 dtype = RDTnewCT(dtype, RDTrgb);
276 break;
277 case RDTxyze:
278 dtype = RDTnewCT(dtype, RDTxyz);
279 break;
280 case RDTscolr:
281 dtype = RDTnewCT(dtype, RDTscolor);
282 break;
283 case RDTrgb:
284 case RDTxyz:
285 case RDTscolor:
286 break;
287 default:
288 error(INTERNAL, "botched color output type");
289 }
290 /* set up signal handling */
291 sigdie(SIGINT, "Interrupt");
292 sigdie(SIGHUP, "Hangup");
293 sigdie(SIGTERM, "Terminate");
294 sigdie(SIGPIPE, "Broken pipe");
295 signal(SIGALRM, onalrm); // used to gracefully terminate
296 #ifdef SIGXCPU
297 sigdie(SIGXCPU, "CPU limit exceeded");
298 sigdie(SIGXFSZ, "File size exceeded");
299 #endif
300 #ifdef NICE
301 nice(NICE); /* lower priority */
302 #endif
303 if (i < argc-1)
304 goto badopt;
305 // load octree
306 if (!myRPmanager.LoadOctree(argv[i]))
307 error(USER, "missing octree argument");
308 // add new header info
309 myRPmanager.AddHeader(i, argv);
310 {
311 char buf[128] = "SOFTWARE= ";
312 strcpy(buf+10, VersionID);
313 myRPmanager.AddHeader(buf);
314 }
315 // render tiles
316 dtype = rpiece(outfile, dtype, zfile);
317
318 quit(dtype==RDTnone); // clean up and exit
319
320 badopt:
321 sprintf(errmsg, "command line error at '%s'", argv[i]);
322 error(USER, errmsg);
323 return 1; /* pro forma return */
324
325 #undef check
326 #undef check_bool
327 }
328
329
330 void
331 wputs( /* warning output function */
332 const char *s
333 )
334 {
335 int lasterrno = errno;
336 eputs(s);
337 errno = lasterrno;
338 }
339
340
341 void
342 eputs( /* put string to stderr */
343 const char *s
344 )
345 {
346 static int midline = 0;
347
348 if (!*s)
349 return;
350 if (!midline++) {
351 fputs(progname, stderr);
352 fputs(": ", stderr);
353 }
354 fputs(s, stderr);
355 if (s[strlen(s)-1] == '\n') {
356 fflush(stderr);
357 midline = 0;
358 }
359 }
360
361
362 static void
363 onsig( /* fatal signal */
364 int signo
365 )
366 {
367 static int gotsig = 0;
368
369 if (gotsig++) /* two signals and we're gone! */
370 _exit(signo);
371
372 alarm(30); /* allow 30 seconds to clean up */
373 signal(SIGALRM, SIG_DFL); /* make certain we do die */
374 eputs("signal - ");
375 eputs(sigerr[signo]);
376 eputs("\n");
377 quit(3);
378 }
379
380
381 static bool gotALRM = false; // flag for ALRM signal
382
383 static void
384 onalrm(int signo)
385 {
386 gotALRM = true;
387 }
388
389
390 static void
391 sigdie( /* set fatal signal */
392 int signo,
393 const char *msg
394 )
395 {
396 if (signal(signo, onsig) == SIG_IGN)
397 signal(signo, SIG_IGN);
398 sigerr[signo] = msg;
399 }
400
401
402 static void
403 printdefaults(void) /* print default values to stdout */
404 {
405 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
406 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
407 ourview.type==VT_PER ? "perspective" :
408 ourview.type==VT_PAR ? "parallel" :
409 ourview.type==VT_HEM ? "hemispherical" :
410 ourview.type==VT_ANG ? "angular" :
411 ourview.type==VT_CYL ? "cylindrical" :
412 ourview.type==VT_PLS ? "planisphere" :
413 "unknown");
414 printf("-vp %f %f %f\t# view point\n",
415 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
416 printf("-vd %f %f %f\t# view direction\n",
417 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
418 printf("-vu %f %f %f\t# view up\n",
419 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
420 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
421 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
422 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
423 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
424 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
425 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
426 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
427 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
428 printf("-X %-9d\t\t\t# horizontal tile divisions\n", tileGrid[0]);
429 printf("-Y %-9d\t\t\t# vertical tile divisions\n", tileGrid[1]);
430 if (myRPmanager.prims == stdprims)
431 printf("-pRGB\t\t\t\t# standard RGB color output\n");
432 else if (myRPmanager.prims == xyzprims)
433 printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
434 else if (myRPmanager.prims != NULL)
435 printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
436 myRPmanager.prims[RED][0], myRPmanager.prims[RED][1],
437 myRPmanager.prims[GRN][0], myRPmanager.prims[GRN][1],
438 myRPmanager.prims[BLU][0], myRPmanager.prims[BLU][1],
439 myRPmanager.prims[WHT][0], myRPmanager.prims[WHT][1]);
440 if (NCSAMP > 3)
441 printf(myRPmanager.prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
442 "-co+\t\t\t\t# output spectral values\n");
443 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
444 printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
445 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
446 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
447 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
448 printf(erract[WARNING].pf != NULL ?
449 "-w+\t\t\t\t# warning messages on\n" :
450 "-w-\t\t\t\t# warning messages off\n");
451 print_rdefaults();
452 }
453
454
455 // Struct for tracking tiles being rendered in mapped file / shared memory
456 struct TileProg {
457 short status; // 0==Unstarted, -1==InProgress, 1==Done
458 pid_t pID; // process operating on tile
459 } *tprog = NULL; // shared tile progress array
460
461 #define tile_p(ti) (tprog + (ti)[1]*tileGrid[0] + (ti)[0])
462
463 // Return true if tile is renderable
464 static bool
465 renderable_tile(TileProg *tp)
466 {
467 if (tp->status < 0 && kill(tp->pID, 0) < 0)
468 tp->status = 0; // dead process - reset
469
470 return !tp->status;
471 }
472
473
474 // handle multi-processing if requested, return true if all done
475 static bool
476 children_finished()
477 {
478 if (nproc <= 1) // single process -> run in parent
479 return false;
480 int cnt = 0; // else count ready-to-go tiles
481 int ti[2];
482 for (ti[1] = 0; ti[1] < tileGrid[1]; ti[1]++)
483 for (ti[0] = 0; ti[0] < tileGrid[0]; ti[0]++)
484 cnt += renderable_tile(tile_p(ti));
485 if (!cnt)
486 return false; // parent can do nothing
487 if (cnt < nproc) {
488 sprintf(errmsg, "only %d renderable tiles, reducing process count", cnt);
489 error(WARNING, errmsg);
490 if ((nproc = cnt) == 1)
491 return false; // back to single process
492 }
493 cow_memshare(); // else we'll be sharing memory
494 fflush(NULL); // and forking children
495 pid_t cpid; // create nproc children
496 for (cnt = nproc; cnt && (cpid = fork()) != 0; cnt--)
497 if (cpid < 0)
498 error(SYSTEM, "fork error!");
499
500 if (cpid == 0) { // children render tiles
501 sleep(nproc - cnt); // avoid race conditions
502 return false;
503 }
504 cow_doneshare(); // parent frees memory and waits
505 signal(SIGALRM, SIG_IGN);
506 myRPmanager.Cleanup(true);
507 int nfailed = 0;
508 int status;
509 for (cnt = nproc; cnt && wait(&status) > 0; cnt--)
510 if (status) {
511 sprintf(errmsg, "child exited with status %d", status);
512 error(WARNING, errmsg);
513 if (!nfailed++ & (cnt > 1)) {
514 kill(0, SIGALRM);
515 error(WARNING, "waiting for other tiles to finish...");
516 }
517 }
518 if (cnt) {
519 sprintf(errmsg, "lost track of %d children", cnt);
520 error(WARNING, errmsg);
521 }
522 if (nfailed) {
523 sprintf(errmsg, "%d tiles were not completed", nfailed);
524 error(USER, errmsg);
525 }
526 return true; // all done!
527 }
528
529 // return next renderable tile, false if everything is done
530 static bool
531 nexttile(int ti[2])
532 {
533 static pid_t ourpID = 0;
534 static short * tlist = NULL;
535 static int tlen = 0;
536 static int tnext = 0;
537
538 if (gotALRM) { // pre-empting new work?
539 if (tlist) {
540 sprintf(errmsg, "process %d got alarm, exiting", ourpID);
541 CHECK(tnext<tlen, WARNING, errmsg);
542 free(tlist); tlist = NULL;
543 }
544 return false;
545 }
546 if (!tlist) { // initialize random tile list
547 ABitMap2 todoMap(tileGrid[0], tileGrid[1]);
548 tlen = 0;
549 for (ti[1] = 0; ti[1] < tileGrid[1]; ti[1]++)
550 for (ti[0] = 0; ti[0] < tileGrid[0]; ti[0]++)
551 if (renderable_tile(tile_p(ti))) {
552 todoMap.Set(ti[0], ti[1]);
553 tlen++;
554 }
555 if (!tlen)
556 return false; // nothing to do!
557 tlist = (short *)malloc(sizeof(short)*2*tlen);
558 CHECK(!tlist, SYSTEM, "out of memory in nexttile()");
559 tlen = 0; // assign entries
560 for (ti[0] = ti[1] = 0; todoMap.Find(&ti[0], &ti[1]); ti[0]++) {
561 tlist[2*tlen] = ti[0];
562 tlist[2*tlen+1] = ti[1];
563 tlen++;
564 }
565 // shuffle order w/ Fisher-Yates
566 for (int i = 0; i < tlen-1; i++) {
567 const int ix = irandom(tlen-i) + i;
568 ti[0] = tlist[2*i];
569 ti[1] = tlist[2*i+1];
570 tlist[2*i] = tlist[2*ix];
571 tlist[2*i+1] = tlist[2*ix+1];
572 tlist[2*ix] = ti[0];
573 tlist[2*ix+1] = ti[1];
574 }
575 ourpID = getpid(); // save time on system calls
576 }
577 while (tnext < tlen) { // find first available
578 ti[0] = tlist[2*tnext];
579 ti[1] = tlist[2*tnext+1];
580 tnext++; // take if still unclaimed
581 if (renderable_tile(tile_p(ti))) {
582 tile_p(ti)->status = -1;
583 tile_p(ti)->pID = ourpID;
584 return true;
585 }
586 }
587 free(tlist); tlist = NULL; // exhausted our list?
588 return false;
589 }
590
591
592 // Principal function for rpiece
593 static RenderDataType
594 rpiece(char *pout, RenderDataType dt, char *zout)
595 {
596 if (zout && *zout == '!')
597 error(USER, "cannot send depth to a command");
598
599 const bool newOutput = (access(pout, F_OK) < 0);
600 FILE *pdfp[2];
601 if (newOutput) { // new output file?
602 CHECK((tileGrid[0] <= 1) & (tileGrid[1] <= 1),
603 USER, "bad tiling specification");
604 } else {
605 dt = myRPmanager.ReopenOutput(pdfp, pout, zout);
606 if (dt == RDTnone)
607 quit(1);
608 if (!fscnresolu(&hresolu, &vresolu, pdfp[0]))
609 error(USER, "missing picture resolution");
610 pixaspect = .0; // need to leave this as is
611 myRPmanager.NewHeader(pout); // get prev. header info
612 const char * tval = myRPmanager.GetHeadStr("TILED=");
613 if (tval) sscanf(tval, "%d %d", &tileGrid[0], &tileGrid[1]);
614 CHECK(myRPmanager.GetView()==NULL,
615 USER, "missing view in picture file");
616 ourview = *myRPmanager.GetView();
617 }
618 int hvdim[2] = {hresolu, vresolu}; // set up tiled frame
619 if (!myRPmanager.NewFrame(ourview, hvdim, &pixaspect, tileGrid))
620 error(USER, "tiling setup error in rpiece");
621
622 if ((hvdim[0] != hresolu) | (hvdim[1] != vresolu)) {
623 if (!newOutput)
624 error(USER, "unexpected output size adjustment");
625 sprintf(errmsg, "resolution adjusted from %dx%d to %dx%d",
626 hresolu, vresolu, hvdim[0], hvdim[1]);
627 error(WARNING, errmsg);
628 hresolu = hvdim[0];
629 vresolu = hvdim[1];
630 }
631 if (newOutput){ // open new output here
632 char buf[64];
633 sprintf(buf, "TILED= %d %d\n", tileGrid[0], tileGrid[1]);
634 myRPmanager.AddHeader(buf);
635 dt = myRPmanager.NewOutput(pdfp, pout, dt, zout);
636 if (dt == RDTnone)
637 quit(1);
638 fprtresolu(hresolu, vresolu, pdfp[0]);
639 }
640 if (RDTdepthT(dt) == RDTdshort) {
641 if (newOutput)
642 fprtresolu(hresolu, vresolu, pdfp[1]);
643 else if (!fscnresolu(&hvdim[0], &hvdim[1], pdfp[1]) ||
644 (hvdim[0] != hresolu) | (hvdim[1] != vresolu))
645 error(USER, "mismatched depth file resolution");
646 }
647 // prepare (flat) pixel buffer
648 const long pdata_beg = ftell(pdfp[0]);
649 const size_t pixSiz = (RDTcolorT(dt)==RDTrgbe)|(RDTcolorT(dt)==RDTxyze) ? sizeof(COLR)
650 : (RDTcolorT(dt)==RDTrgb)|(RDTcolorT(dt)==RDTxyz) ? sizeof(COLORV)*3
651 : RDTcolorT(dt)==RDTscolr ? LSCOLR : sizeof(COLORV)*NCSAMP;
652 size_t pmlen = pdata_beg + pixSiz*hresolu*vresolu;
653 // put tile progress array at end
654 if (pmlen&7) pmlen += 8 - (pmlen&7); // 8-byte alignment to be safe
655 pmlen += sizeof(TileProg)*tileGrid[0]*tileGrid[1];
656 // map picture file to memory
657 if (newOutput && ftruncate(fileno(pdfp[0]), pmlen) < 0)
658 error(SYSTEM, "cannot extend picture buffer");
659 uby8 * pixMap = (uby8 *)mmap(NULL, pmlen, PROT_READ|PROT_WRITE,
660 MAP_SHARED, fileno(pdfp[0]), 0);
661 if ((void *)pixMap == MAP_FAILED)
662 error(SYSTEM, "cannot map picture file into memory");
663 // map depth buffer to memory
664 const long zdata_beg = RDTdepthT(dt) ? ftell(pdfp[1]) : 0L;
665 const size_t zdpSiz = RDTdepthT(dt)==RDTdshort ? sizeof(short) :
666 RDTdepthT(dt)==RDTdfloat ? sizeof(float) : 0;
667 const size_t zmlen = zdata_beg + zdpSiz*hresolu*vresolu;
668 uby8 * zdMap = NULL;
669 if (RDTdepthT(dt)) {
670 if (newOutput && ftruncate(fileno(pdfp[1]), zmlen) < 0)
671 error(SYSTEM, "cannot extend depth buffer");
672 zdMap = (uby8 *)mmap(NULL, zmlen, PROT_READ|PROT_WRITE,
673 MAP_SHARED, fileno(pdfp[1]), 0);
674 if ((void *)zdMap == MAP_FAILED)
675 error(SYSTEM, "cannot map depth file into memory");
676 }
677 fclose(pdfp[0]); // done with file pointers
678 if (RDTdepthT(dt)) fclose(pdfp[1]);
679 // point to tile progress array
680 tprog = (TileProg *)(pixMap + pmlen - sizeof(TileProg)*tileGrid[0]*tileGrid[1]);
681
682 if (children_finished()) // work done in children?
683 return dt;
684
685 int ndone = 0; // else render tiles
686 int ti[2];
687 while (nexttile(ti)) {
688 const int offset = (tileGrid[1]-1-ti[1])*myRPmanager.GetWidth()*myRPmanager.THeight() +
689 (myRPmanager.THeight()-1)*myRPmanager.GetWidth() +
690 ti[0]*myRPmanager.TWidth();
691 uby8 * pptr = pixMap + pdata_beg + pixSiz*offset;
692 uby8 * zptr = zdMap + zdata_beg + zdpSiz*offset;
693 bool ok = false;
694 switch (RDTcommonE(dt)<<1 | (RDTdepthT(dt)==RDTdshort)) {
695 case 2: // common-exponent color, float/no depth
696 ok = myRPmanager.RenderTile((COLRV *)pptr, -myRPmanager.GetWidth(),
697 (float *)zptr, ti);
698 break;
699 case 0: // float color, float/no depth
700 ok = myRPmanager.RenderTile((COLORV *)pptr, -myRPmanager.GetWidth(),
701 (float *)zptr, ti);
702 break;
703 case 3: // common-exponent color, encoded depth
704 ok = myRPmanager.RenderTile((COLRV *)pptr, -myRPmanager.GetWidth(),
705 (short *)zptr, ti);
706 break;
707 case 1: // float color, encoded depth
708 ok = myRPmanager.RenderTile((COLORV *)pptr, -myRPmanager.GetWidth(),
709 (short *)zptr, ti);
710 break;
711 }
712 if (!ok) { // got an error
713 sprintf(errmsg, "error rendering tile (%d,%d)/(%d,%d)",
714 ti[0], ti[1], tileGrid[0], tileGrid[1]);
715 error(USER, errmsg);
716 }
717 tile_p(ti)->status = 1; // mark tile completed
718 ndone++;
719 }
720 if (!ndone)
721 error(WARNING, "no tiles need rendering, exit");
722 /*
723 munmap(pixMap, pmlen); // technically unnecessary...
724 if (zdMap) munmap(zdMap, zmlen);
725 */
726 return dt; // we're done here
727 }
