root/Development/ray/src/rt/rxfluxmtx.cpp
Revision: 2.2
Committed: Thu Oct 23 01:26:48 2025 UTC (2 months, 1 week ago) by greg
Changes since 2.1: +73 -31 lines
fix(rxfluxmtx): Added -t option and numerous bug fixes
2 static const char RCSid[] = "$Id: rxfluxmtx.cpp,v 2.1 2025/10/22 02:38:27 greg Exp $";
5 * Calculate flux transfer matrix or matrices using RcontribSimulManager class
6 *
7 * Much of this is cribbed from util/rfluxmtx.c
8 * Implementation here improves efficiency and overcomes receiver limits
9 */
10
11 #include "copyright.h"
12
13 #include <ctype.h>
14 #include <signal.h>
15 #include <time.h>
16 #include "RcontribSimulManager.h"
17 #include "bsdf.h"
18 #include "bsdf_m.h"
19 #include "func.h"
20 #include "random.h"
21 #include "triangulate.h"
22 #include "view.h"
23
24 int verby = 0; /* verbose mode? */
25
26 const char *reinhfn = "reinhartb.cal";
27 const char *shirchiufn = "disk2square.cal";
28 const char *kfullfn = "klems_full.cal";
29 const char *khalffn = "klems_half.cal";
30 const char *kquarterfn = "klems_quarter.cal";
31 const char *ciefn = "cieskyscan.cal";
32
33 const char *sigerr[NSIG]; /* signal error messages */
34
35 int inpfmt = 'a'; /* input format */
36 int outfmt = 'f'; /* output format */
37
38 int report_intvl = 0; /* reporting interval (seconds) */
39
40 RcontribSimulManager myRCmanager; // global rcontrib simulation manager
41
42 #define PARAMSNAME "rfluxmtx" /* string indicating parameters */
43
44 /* surface type IDs */
45 #define ST_NONE 0
46 #define ST_POLY 1
47 #define ST_RING 2
48 #define ST_SOURCE 3
49 /* surface structure */
50 struct SURF {
51 SURF *next; /* next surface in list */
52 void *priv; /* private data (malloc'ed) */
53 char sname[32]; /* surface name */
54 FVECT snrm; /* surface normal */
55 double area; /* surface area / proj. solid angle */
56 short styp; /* surface type */
57 short nfargs; /* number of real arguments */
58 double farg[1]; /* real values (extends struct) */
59 };
60 /* triangle */
61 struct PTRI {
62 double afrac; /* fraction of total area */
63 short vndx[3]; /* vertex indices */
64 };
65 /* triangulated polygon */
66 struct POLYTRIS {
67 FVECT uva[2]; /* tangent axes */
68 int ntris; /* number of triangles */
69 PTRI tri[1]; /* triangle array (extends struct) */
70 };
71 /* sender/receiver parameters */
72 struct PARAMS {
73 char sign; /* '-' for axis reversal */
74 char hemis[31]; /* hemispherical sampling spec. */
75 int hsiz; /* hemisphere basis size */
76 int nsurfs; /* number of surfaces */
77 SURF *slist; /* list of surfaces */
78 FVECT vup; /* up vector (zero if unset) */
79 FVECT nrm; /* average normal direction */
80 FVECT udir, vdir; /* tangent axes */
81 char outfn[256]; /* output file name (receiver) */
82 int (*sample_basis)(PARAMS *p, int b, FVECT orig_dir[]);
83 };
84
85 PARAMS curparams;
86 char curmod[MAXSTR];
87 char newparams[1024];
88
89 typedef int SURFSAMP(FVECT, SURF *, double);
90
91 SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
92
93 SURFSAMP *orig_in_surf[4] = {
94 ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
95 };
96
97 VIEW ourview = STDVIEW; // view parameters (if set)
98 double dstrpix = 0; // pixel jitter
99 double dblur = 0; // depth-of-field
100
101 /* Clear parameter set */
102 void
103 clear_params(PARAMS *p, bool reset_only = true)
104 {
105 while (p->slist != NULL) {
106 SURF *sdel = p->slist;
107 p->slist = sdel->next;
108 if (sdel->priv != NULL)
109 free(sdel->priv);
110 free(sdel);
111 }
112 if (reset_only) {
113 p->nsurfs = 0;
114 p->slist = NULL;
115 memset(p->nrm, 0, sizeof(FVECT));
116 memset(p->vup, 0, sizeof(FVECT));
117 } else
118 memset(p, 0, sizeof(PARAMS));
119 }
120
121 /* Get surface type from name */
122 int
123 surf_type(const char *otype)
124 {
125 if (!strcmp(otype, "polygon"))
126 return(ST_POLY);
127 if (!strcmp(otype, "ring"))
128 return(ST_RING);
129 if (!strcmp(otype, "source"))
130 return(ST_SOURCE);
131 return(ST_NONE);
132 }
133
134 /* Add arguments to oconv command */
135 char *
136 oconv_command(int ac, char *av[])
137 {
138 static char oconvbuf[4096] = "!oconv -f ";
139 char *cp = oconvbuf + 10;
140 char *recv = *av++;
141
142 if (ac-- <= 0)
143 return(NULL);
144 if (erract[WARNING].pf == NULL) { /* warnings off? */
145 strcpy(cp, "-w ");
146 cp += 3;
147 }
148 while (ac-- > 0) { /* copy each argument */
149 int len = strlen(*av);
150 if (cp+len+4 >= oconvbuf+sizeof(oconvbuf))
151 goto overrun;
152 if (matchany(*av, SPECIALS)) {
153 *cp++ = QUOTCHAR;
154 strcpy(cp, *av++);
155 cp += len;
156 *cp++ = QUOTCHAR;
157 } else {
158 strcpy(cp, *av++);
159 cp += len;
160 }
161 *cp++ = ' ';
162 }
163 /* receiver goes last */
164 if (matchany(recv, SPECIALS)) {
165 *cp++ = QUOTCHAR;
166 while (*recv) {
167 if (cp >= oconvbuf+(sizeof(oconvbuf)-3))
168 goto overrun;
169 *cp++ = *recv++;
170 }
171 *cp++ = QUOTCHAR;
172 *cp = '\0';
173 } else
174 strcpy(cp, recv);
175 return(oconvbuf);
176 overrun:
177 error(USER, "too many file arguments!");
178 return(NULL); /* pro forma return */
179 }
180
181 /* Get normalized direction vector from string specification */
182 int
183 get_direction(FVECT dv, const char *s)
184 {
185 int sign = 1;
186 int axis = 0;
187
188 memset(dv, 0, sizeof(FVECT));
189 nextchar:
190 switch (*s) {
191 case '+':
192 ++s;
193 goto nextchar;
194 case '-':
195 sign = -sign;
196 ++s;
197 goto nextchar;
198 case 'z':
199 case 'Z':
200 ++axis;
201 case 'y':
202 case 'Y':
203 ++axis;
204 case 'x':
205 case 'X':
206 dv[axis] = sign;
207 return(!s[1] | isspace(s[1]));
208 default:
209 break;
210 }
211 #ifdef SMLFLT
212 if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
213 #else
214 if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
215 #endif
216 return(0);
217 dv[0] *= (RREAL)sign;
218 return(normalize(dv) > 0);
219 }
220
221 /* Parse program parameters (directives) */
222 int
223 parse_params(PARAMS *p, char *pargs)
224 {
225 char *cp = pargs;
226 int nparams = 0;
227 int quot;
228 int i;
229
230 for ( ; ; ) {
231 switch (*cp++) {
232 case 'h':
233 if (*cp++ != '=')
234 break;
235 if ((*cp == '+') | (*cp == '-'))
236 p->sign = *cp++;
237 else
238 p->sign = '+';
239 p->hsiz = 0;
240 i = 0;
241 while (*cp && !isspace(*cp)) {
242 if (isdigit(*cp))
243 p->hsiz = 10*p->hsiz + *cp - '0';
244 p->hemis[i++] = *cp++;
245 }
246 if (!i)
247 break;
248 p->hemis[i] = '\0';
249 p->hsiz += !p->hsiz;
250 ++nparams;
251 continue;
252 case 'u':
253 if (*cp++ != '=')
254 break;
255 if (!get_direction(p->vup, cp))
256 break;
257 while (*cp && !isspace(*cp++))
258 ;
259 ++nparams;
260 continue;
261 case 'o':
262 if (*cp++ != '=')
263 break;
264 quot = 0;
265 if ((*cp == '"') | (*cp == '\''))
266 quot = *cp++;
267 i = 0;
268 while (*cp && (quot ? (*cp != quot) : !isspace(*cp))) {
269 i++; cp++;
270 }
271 if (!i)
272 break;
273 if (!*cp) {
274 if (quot)
275 break;
276 cp[1] = '\0';
277 }
278 *cp = '\0';
279 strlcpy(p->outfn, cp-i, sizeof(p->outfn));
280 *cp++ = quot ? quot : ' ';
281 ++nparams;
282 continue;
283 case ' ':
284 case '\t':
285 case '\r':
286 case '\n':
287 continue;
288 case '\0':
289 return(nparams);
290 default:
291 break;
292 }
293 break;
294 }
295 sprintf(errmsg, "bad parameter string: %s", pargs);
296 error(USER, errmsg);
297 return(-1); /* pro forma return */
298 }
299
300 /* Add receiver modifier and associated parameters */
301 void
302 finish_receiver()
303 {
304 bool uniform = false;
305 const char *calfn = NULL;
306 char binv[64] = "0";
307 char params[128] = "";
308 const char *binf = NULL;
309 const char *nbins = NULL;
310 /* check arguments */
311 if (!curmod[0])
312 error(USER, "missing receiver surface");
313 if (!curparams.outfn[0])
314 error(USER, "missing output file for receiver");
315 if (!curparams.hemis[0])
316 error(USER, "missing hemisphere sampling type");
317 if (normalize(curparams.nrm) == 0)
318 error(USER, "undefined normal for hemisphere sampling");
319 if (normalize(curparams.vup) == 0) {
320 if (fabs(curparams.nrm[2]) < .7)
321 curparams.vup[2] = 1;
322 else
323 curparams.vup[1] = 1;
324 }
325 /* determine sample type/bin */
326 if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1')) {
327 if (curparams.slist->styp != ST_SOURCE)
328 sprintf(binv, "if(-Dx*%g-Dy*%g-Dz*%g,0,-1)",
329 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2]);
330 uniform = true; /* uniform sampling -- one bin */
331 } else if (tolower(curparams.hemis[0]) == 's' &&
332 tolower(curparams.hemis[1]) == 'c') {
333 /* assign parameters */
334 if (curparams.hsiz <= 1)
335 error(USER, "missing size for Shirley-Chiu sampling");
336 calfn = shirchiufn; shirchiufn = NULL;
337 sprintf(params, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
338 curparams.hsiz,
339 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
340 curparams.vup[0], curparams.vup[1], curparams.vup[2],
341 curparams.sign);
342 strcpy(binv, "scbin");
343 nbins = "SCdim*SCdim";
344 } else if ((tolower(curparams.hemis[0]) == 'r') |
345 (tolower(curparams.hemis[0]) == 't')) {
346 calfn = reinhfn; reinhfn = NULL;
347 sprintf(params, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
348 curparams.hsiz,
349 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
350 curparams.vup[0], curparams.vup[1], curparams.vup[2],
351 curparams.sign);
352 strcpy(binv, "rbin");
353 nbins = "Nrbins";
354 } else if (tolower(curparams.hemis[0]) == 'k' &&
355 !curparams.hemis[1] |
356 (tolower(curparams.hemis[1]) == 'f') |
357 (curparams.hemis[1] == '1')) {
358 calfn = kfullfn; kfullfn = NULL;
359 binf = "kbin";
360 nbins = "Nkbins";
361 } else if (tolower(curparams.hemis[0]) == 'k' &&
362 (tolower(curparams.hemis[1]) == 'h') |
363 (curparams.hemis[1] == '2')) {
364 calfn = khalffn; khalffn = NULL;
365 binf = "khbin";
366 nbins = "Nkhbins";
367 } else if (tolower(curparams.hemis[0]) == 'k' &&
368 (tolower(curparams.hemis[1]) == 'q') |
369 (curparams.hemis[1] == '4')) {
370 calfn = kquarterfn; kquarterfn = NULL;
371 binf = "kqbin";
372 nbins = "Nkqbins";
373 } else if (!strcasecmp(curparams.hemis, "cie")) {
374 calfn = ciefn; ciefn = NULL;
375 sprintf(params, "rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
376 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
377 curparams.vup[0], curparams.vup[1], curparams.vup[2],
378 curparams.sign);
379 strcpy(binv, "cbin");
380 nbins = "Ncbins";
381 } else {
382 sprintf(errmsg, "unrecognized hemisphere sampling: h=%s",
383 curparams.hemis);
384 error(USER, errmsg);
385 }
386 if (tolower(curparams.hemis[0]) == 'k') {
387 sprintf(params, "RHS=%c1", curparams.sign);
388 }
389 if (!uniform)
390 for (SURF *sp = curparams.slist; sp != NULL; sp = sp->next)
391 if (sp->styp == ST_SOURCE && fabs(sp->area - PI) > 1e-3) {
392 sprintf(errmsg, "source '%s' must be 180-degrees",
393 sp->sname);
394 error(USER, errmsg);
395 }
396 if (binf != NULL) { /* complete bin function? */
397 sprintf(binv, "%s(%g,%g,%g,%g,%g,%g)", binf,
398 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
399 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
400 }
401 if (calfn != NULL) /* load cal file if needed */
402 loadfunc(const_cast<char *>(calfn));
403 if (params[0]) /* set parameters if any */
404 set_eparams(params);
405 // add modifier to rcontrib object
406 if (!myRCmanager.AddModifier(curmod, curparams.outfn, params, binv,
407 nbins==NULL ? 1 : int(eval(const_cast<char *>(nbins)) + .5)))
408 error(INTERNAL, "AddModifier() call failed");
409
410 clear_params(&curparams, true); /* clear for next receiver */
411 curmod[0] = '\0';
412 }
413
414 /* Make randomly oriented tangent plane axes for given normal direction */
415 void
416 make_axes(FVECT uva[2], const FVECT nrm)
417 {
418 int i;
419
420 if (!getperpendicular(uva[0], nrm, 1))
421 error(USER, "bad surface normal in make_axes()");
422 VCROSS(uva[1], nrm, uva[0]);
423 }
424
425 /* Illegal sender surfaces end up here */
426 int
427 ssamp_bad(FVECT orig, SURF *sp, double x)
428 {
429 sprintf(errmsg, "illegal sender surface '%s'", sp->sname);
430 error(INTERNAL, errmsg);
431 return(0);
432 }
433
434 /* Generate origin on ring surface from uniform random variable */
435 int
436 ssamp_ring(FVECT orig, SURF *sp, double x)
437 {
438 FVECT *uva = (FVECT *)sp->priv;
439 double samp2[2];
440 double uv[2];
441 int i;
442
443 if (uva == NULL) { /* need tangent axes */
444 uva = (FVECT *)malloc(sizeof(FVECT)*2);
445 if (uva == NULL) {
446 error(SYSTEM, "out of memory in ssamp_ring()");
447 return(0);
448 }
449 make_axes(uva, sp->snrm);
450 sp->priv = uva;
451 }
452 SDmultiSamp(samp2, 2, x);
453 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
454 samp2[1] *= 2.*PI;
455 uv[0] = samp2[0]*tcos(samp2[1]);
456 uv[1] = samp2[0]*tsin(samp2[1]);
457 for (i = 3; i--; )
458 orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
459 return(1);
460 }
461
462 /* Add triangle to polygon's list (call-back function) */
463 int
464 add_triangle(const Vert2_list *tp, int a, int b, int c)
465 {
466 POLYTRIS *ptp = (POLYTRIS *)tp->p;
467 PTRI *trip = ptp->tri + ptp->ntris++;
468
469 trip->vndx[0] = a;
470 trip->vndx[1] = b;
471 trip->vndx[2] = c;
472 return(1);
473 }
474
475 /* Generate origin on polygon surface from uniform random variable */
476 int
477 ssamp_poly(FVECT orig, SURF *sp, double x)
478 {
479 POLYTRIS *ptp = (POLYTRIS *)sp->priv;
480 double samp2[2];
481 double *v0, *v1, *v2;
482 int i;
483
484 if (ptp == NULL) { /* need to triangulate */
485 ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
486 sizeof(PTRI)*(sp->nfargs/3 - 3));
487 if (ptp == NULL)
488 goto memerr;
489 if (sp->nfargs == 3) { /* simple case */
490 ptp->ntris = 1;
491 ptp->tri[0].vndx[0] = 0;
492 ptp->tri[0].vndx[1] = 1;
493 ptp->tri[0].vndx[2] = 2;
494 ptp->tri[0].afrac = 1;
495 } else {
496 Vert2_list *v2l = polyAlloc(sp->nfargs/3);
497 if (v2l == NULL)
498 goto memerr;
499 make_axes(ptp->uva, sp->snrm);
500 for (i = v2l->nv; i--; ) {
501 v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
502 v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
503 }
504 ptp->ntris = 0;
505 v2l->p = ptp;
506 if (!polyTriangulate(v2l, add_triangle)) {
507 sprintf(errmsg, "cannot triangulate polygon '%s'",
508 sp->sname);
509 error(USER, errmsg);
510 return(0);
511 }
512 for (i = ptp->ntris; i--; ) {
513 int a = ptp->tri[i].vndx[0];
514 int b = ptp->tri[i].vndx[1];
515 int c = ptp->tri[i].vndx[2];
516 ptp->tri[i].afrac =
517 (v2l->v[a].mX*v2l->v[b].mY -
518 v2l->v[b].mX*v2l->v[a].mY +
519 v2l->v[b].mX*v2l->v[c].mY -
520 v2l->v[c].mX*v2l->v[b].mY +
521 v2l->v[c].mX*v2l->v[a].mY -
522 v2l->v[a].mX*v2l->v[c].mY) /
523 (2.*sp->area);
524 }
525 polyFree(v2l);
526 }
527 sp->priv = ptp;
528 }
529 /* pick triangle by partial area */
530 for (i = 0; i < ptp->ntris-1 && x > ptp->tri[i].afrac; i++)
531 x -= ptp->tri[i].afrac;
532 SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
533 samp2[0] *= samp2[1] = sqrt(samp2[1]);
534 samp2[1] = 1. - samp2[1];
535 v0 = sp->farg + 3*ptp->tri[i].vndx[0];
536 v1 = sp->farg + 3*ptp->tri[i].vndx[1];
537 v2 = sp->farg + 3*ptp->tri[i].vndx[2];
538 for (i = 3; i--; )
539 orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
540 + samp2[1]*(v2[i] - v0[i]) ;
541 return(1);
542 memerr:
543 error(SYSTEM, "out of memory in ssamp_poly");
544 return(0);
545 }
546
547 /* Compute sample origin based on projected areas of sender subsurfaces */
548 int
549 sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
550 {
551 static double *projsa;
552 static int nall;
553 double tarea = 0;
554 int i;
555 SURF *sp;
556 /* special case for lone surface */
557 if (p->nsurfs == 1) {
558 sp = p->slist;
559 if (DOT(sp->snrm, rdir) >= FTINY) {
560 sprintf(errmsg, "sample behind sender '%s'", sp->sname);
561 error(INTERNAL, errmsg);
562 return(0);
563 }
564 return((*orig_in_surf[sp->styp])(orig, sp, x));
565 }
566 if (p->nsurfs > nall) { /* (re)allocate surface area cache */
567 if (projsa) free(projsa);
568 projsa = (double *)malloc(sizeof(double)*p->nsurfs);
569 if (projsa == NULL)
570 error(SYSTEM, "out of memory in sample_origin()");
571 nall = p->nsurfs;
572 }
573 /* compute projected areas */
574 for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
575 projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
576 tarea += projsa[i] *= (double)(projsa[i] > 0);
577 }
578 if (tarea < FTINY*FTINY) { /* wrong side of sender? */
579 error(INTERNAL, "sample behind all sender elements!");
580 return(0);
581 }
582 tarea *= x; /* get surface from list */
583 for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
584 tarea -= projsa[i++];
585 return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
586 }
587
588 /* Uniform sample generator */
589 int
590 sample_uniform(PARAMS *p, int b, FVECT orig_dir[])
591 {
592 int n = myRCmanager.accum;
593 double samp3[3];
594 FVECT duvw;
595 int i;
596
597 if (orig_dir == NULL) /* just requesting number of bins? */
598 return(1);
599
600 while (n--) { /* stratified hemisphere sampling */
601 SDmultiSamp(samp3, 3, (n+frandom())/myRCmanager.accum);
602 square2disk(duvw, samp3[1], samp3[2]);
603 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
604 for (i = 3; i--; )
605 orig_dir[1][i] = duvw[0]*p->udir[i] +
606 duvw[1]*p->vdir[i] +
607 duvw[2]*p->nrm[i] ;
608 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
609 return(0);
610 orig_dir += 2;
611 }
612 return(1);
613 }
614
615 /* Shirly-Chiu sample generator */
616 int
617 sample_shirchiu(PARAMS *p, int b, FVECT orig_dir[])
618 {
619 int n = myRCmanager.accum;
620 double samp3[3];
621 FVECT duvw;
622 int i;
623
624 if (orig_dir == NULL) /* just requesting number of bins? */
625 return(p->hsiz*p->hsiz);
626
627 while (n--) { /* stratified sampling */
628 SDmultiSamp(samp3, 3, (n+frandom())/myRCmanager.accum);
629 square2disk(duvw, (b/p->hsiz + samp3[1])/p->hsiz,
630 (b%p->hsiz + samp3[2])/p->hsiz);
631 duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
632 for (i = 3; i--; )
633 orig_dir[1][i] = -duvw[0]*p->udir[i] -
634 duvw[1]*p->vdir[i] -
635 duvw[2]*p->nrm[i] ;
636 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
637 return(0);
638 orig_dir += 2;
639 }
640 return(1);
641 }
642
643 /* Reinhart/Tregenza sample generator */
644 int
645 sample_reinhart(PARAMS *p, int b, FVECT orig_dir[])
646 {
647 #define T_NALT 7
648 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
649 const int RowMax = T_NALT*p->hsiz + 1;
650 const double RAH = (.5*PI)/(RowMax-.5);
651 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
652 int n = myRCmanager.accum;
653 int row, col;
654 double samp3[3];
655 double alt, azi;
656 double duvw[3];
657 int i;
658
659 if (orig_dir == NULL) { /* just requesting number of bins? */
660 n = 0;
661 for (row = RowMax; row--; ) n += rnaz(row);
662 return(n);
663 }
664 row = 0; /* identify row & column */
665 col = b;
666 while (col >= rnaz(row)) {
667 col -= rnaz(row);
668 ++row;
669 }
670 while (n--) { /* stratified sampling */
671 SDmultiSamp(samp3, 3, (n+frandom())/myRCmanager.accum);
672 if (row >= RowMax-1) /* avoid crowding at zenith */
673 samp3[1] *= samp3[1];
674 alt = (row+samp3[1])*RAH;
675 azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
676 duvw[2] = cos(alt); /* measured from horizon */
677 duvw[0] = tsin(azi)*duvw[2];
678 duvw[1] = -tcos(azi)*duvw[2];
679 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
680 for (i = 3; i--; )
681 orig_dir[1][i] = -duvw[0]*p->udir[i] -
682 duvw[1]*p->vdir[i] -
683 duvw[2]*p->nrm[i] ;
684 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
685 return(0);
686 orig_dir += 2;
687 }
688 return(1);
689 #undef rnaz
690 #undef T_NALT
691 }
692
693 /* Klems sample generator */
694 int
695 sample_klems(PARAMS *p, int b, FVECT orig_dir[])
696 {
697 static const char bname[4][20] = {
698 "LBNL/Klems Full",
699 "LBNL/Klems Half",
700 "INTERNAL ERROR",
701 "LBNL/Klems Quarter"
702 };
703 static ANGLE_BASIS *kbasis[4];
704 const int bi = p->hemis[1] - '1';
705 int n = myRCmanager.accum;
706 double samp2[2];
707 double duvw[3];
708 int i;
709
710 if (!kbasis[bi]) { /* need to get basis, first */
711 for (i = 4; i--; )
712 if (!strcasecmp(abase_list[i].name, bname[bi])) {
713 kbasis[bi] = &abase_list[i];
714 break;
715 }
716 if (i < 0) {
717 sprintf(errmsg, "unknown hemisphere basis '%s'",
718 bname[bi]);
719 error(USER, errmsg);
720 return(0);
721 }
722 }
723 if (orig_dir == NULL) /* just requesting number of bins? */
724 return(kbasis[bi]->nangles);
725
726 while (n--) { /* stratified sampling */
727 SDmultiSamp(samp2, 2, (n+frandom())/myRCmanager.accum);
728 if (!fo_getvec(duvw, b+samp2[1], kbasis[bi]))
729 return(0);
730 for (i = 3; i--; )
731 orig_dir[1][i] = -duvw[0]*p->udir[i] -
732 duvw[1]*p->vdir[i] -
733 duvw[2]*p->nrm[i] ;
734 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
735 return(0);
736 orig_dir += 2;
737 }
738 return(1);
739 }
740
741 /* Prepare hemisphere basis sampler that will send rays to rcontrib */
742 int
743 prepare_sampler(PARAMS *p)
744 {
745 if (p->slist == NULL) { /* missing sample surface! */
746 error(USER, "no sender surface");
747 return(-1);
748 }
749 /* misplaced output file spec. */
750 if (p->outfn[0]) {
751 sprintf(errmsg, "ignoring output file in sender ('%s')",
752 p->outfn);
753 error(WARNING, errmsg);
754 }
755 /* check/set basis hemisphere */
756 if (!p->hemis[0]) {
757 error(USER, "missing sender sampling type");
758 return(-1);
759 }
760 if (normalize(p->nrm) == 0) {
761 error(USER, "undefined normal for sender sampling");
762 return(-1);
763 }
764 if (normalize(p->vup) == 0) {
765 if (fabs(p->nrm[2]) < .7)
766 p->vup[2] = 1;
767 else
768 p->vup[1] = 1;
769 }
770 fcross(p->udir, p->vup, p->nrm);
771 if (normalize(p->udir) == 0) {
772 error(USER, "up vector coincides with sender normal");
773 return(-1);
774 }
775 fcross(p->vdir, p->nrm, p->udir);
776 if (p->sign == '-') { /* left-handed coordinate system? */
777 p->udir[0] *= -1.;
778 p->udir[1] *= -1.;
779 p->udir[2] *= -1.;
780 }
781 if ((tolower(p->hemis[0]) == 'u') | (p->hemis[0] == '1'))
782 p->sample_basis = sample_uniform;
783 else if (tolower(p->hemis[0]) == 's' &&
784 tolower(p->hemis[1]) == 'c')
785 p->sample_basis = sample_shirchiu;
786 else if ((tolower(p->hemis[0]) == 'r') |
787 (tolower(p->hemis[0]) == 't'))
788 p->sample_basis = sample_reinhart;
789 else if (tolower(p->hemis[0]) == 'k') {
790 switch (p->hemis[1]) {
791 case '1':
792 case '2':
793 case '4':
794 break;
795 case 'f':
796 case 'F':
797 case '\0':
798 p->hemis[1] = '1';
799 break;
800 case 'h':
801 case 'H':
802 p->hemis[1] = '2';
803 break;
804 case 'q':
805 case 'Q':
806 p->hemis[1] = '4';
807 break;
808 default:
809 goto unrecognized;
810 }
811 p->hemis[2] = '\0';
812 p->sample_basis = sample_klems;
813 } else
814 goto unrecognized;
815 /* return number of bins */
816 return((*p->sample_basis)(p,0,NULL));
817 unrecognized:
818 sprintf(errmsg, "unrecognized sender sampling: h=%s", p->hemis);
819 error(USER, errmsg);
820 return(-1);
821 }
822
823 /* Compute normal and area for polygon */
824 int
825 finish_polygon(SURF *p)
826 {
827 const int nv = p->nfargs / 3;
828 FVECT e1, e2, vc;
829 int i;
830
831 memset(p->snrm, 0, sizeof(FVECT));
832 VSUB(e1, p->farg+3, p->farg);
833 for (i = 2; i < nv; i++) {
834 VSUB(e2, p->farg+3*i, p->farg);
835 VCROSS(vc, e1, e2);
836 p->snrm[0] += vc[0];
837 p->snrm[1] += vc[1];
838 p->snrm[2] += vc[2];
839 VCOPY(e1, e2);
840 }
841 p->area = normalize(p->snrm)*0.5;
842 return(p->area > FTINY*FTINY);
843 }
844
845 /* Add a surface to our current parameters */
846 void
847 add_surface(int st, const char *oname, FILE *fp)
848 {
849 SURF *snew;
850 int n;
851 /* get floating-point arguments */
852 if (!fscanf(fp, "%d", &n)) return;
853 while (n-- > 0) fscanf(fp, "%*s");
854 if (!fscanf(fp, "%d", &n)) return;
855 while (n-- > 0) fscanf(fp, "%*d");
856 if (!fscanf(fp, "%d", &n) || n <= 0) return;
857 snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
858 if (snew == NULL)
859 error(SYSTEM, "out of memory in add_surface()");
860 strncpy(snew->sname, oname, sizeof(snew->sname)-1);
861 snew->sname[sizeof(snew->sname)-1] = '\0';
862 snew->styp = st;
863 snew->priv = NULL;
864 snew->nfargs = n;
865 for (n = 0; n < snew->nfargs; n++)
866 if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
867 sprintf(errmsg, "error reading arguments for '%s'",
868 oname);
869 error(USER, errmsg);
870 }
871 switch (st) {
872 case ST_RING:
873 if (snew->nfargs != 8)
874 goto badcount;
875 VCOPY(snew->snrm, snew->farg+3);
876 if (normalize(snew->snrm) == 0)
877 goto badnorm;
878 if (snew->farg[7] < snew->farg[6]) {
879 double t = snew->farg[7];
880 snew->farg[7] = snew->farg[6];
881 snew->farg[6] = t;
882 }
883 snew->area = PI*(snew->farg[7]*snew->farg[7] -
884 snew->farg[6]*snew->farg[6]);
885 break;
886 case ST_POLY:
887 if (snew->nfargs < 9 || snew->nfargs % 3)
888 goto badcount;
889 finish_polygon(snew);
890 break;
891 case ST_SOURCE:
892 if (snew->nfargs != 4)
893 goto badcount;
894 for (n = 3; n--; ) /* need to reverse "normal" */
895 snew->snrm[n] = -snew->farg[n];
896 if (normalize(snew->snrm) == 0)
897 goto badnorm;
898 snew->area = sin((PI/180./2.)*snew->farg[3]);
899 snew->area *= PI*snew->area;
900 break;
901 }
902 if (snew->area <= FTINY*FTINY) {
903 sprintf(errmsg, "zero area for surface '%s'", oname);
904 error(WARNING, errmsg);
905 free(snew);
906 return;
907 }
908 VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
909 snew->next = curparams.slist;
910 curparams.slist = snew;
911 curparams.nsurfs++;
912 return;
913 badcount:
914 sprintf(errmsg, "bad argument count for surface element '%s'", oname);
915 error(USER, errmsg);
916 badnorm:
917 sprintf(errmsg, "bad orientation for surface element '%s'", oname);
918 error(USER, errmsg);
919 }
920
921 /* Parse a receiver object (look for modifiers to add) */
922 int
923 add_recv_object(FILE *fp)
924 {
925 int st;
926 char thismod[128], otype[32], oname[128];
927 int n;
928
929 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
930 return(0); /* must have hit EOF! */
931 if (!strcmp(otype, "alias")) {
932 fscanf(fp, "%*s"); /* skip alias */
933 return(0);
934 }
935 /* is it a new receiver? */
936 if ((st = surf_type(otype)) != ST_NONE) {
937 if (strcmp(thismod, curmod)) {
938 if (curmod[0]) /* output last receiver? */
939 finish_receiver();
940 parse_params(&curparams, newparams);
941 newparams[0] = '\0';
942 strcpy(curmod, thismod);
943 }
944 add_surface(st, oname, fp); /* read & store surface */
945 return(1);
946 }
947 /* else skip arguments */
948 if (!fscanf(fp, "%d", &n)) return(0);
949 while (n-- > 0) fscanf(fp, "%*s");
950 if (!fscanf(fp, "%d", &n)) return(0);
951 while (n-- > 0) fscanf(fp, "%*d");
952 if (!fscanf(fp, "%d", &n)) return(0);
953 while (n-- > 0) fscanf(fp, "%*f");
954 return(0);
955 }
956
957 /* Parse a sender object */
958 int
959 add_send_object(FILE *fp)
960 {
961 int st;
962 char thismod[128], otype[32], oname[128];
963 int n;
964
965 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
966 return(0); /* must have hit EOF! */
967 if (!strcmp(otype, "alias")) {
968 fscanf(fp, "%*s"); /* skip alias */
969 return(0);
970 }
971 /* is it a new surface? */
972 if ((st = surf_type(otype)) != ST_NONE) {
973 if (st == ST_SOURCE) {
974 error(USER, "cannot use source as a sender");
975 return(-1);
976 }
977 if (strcmp(thismod, curmod)) {
978 if (curmod[0])
979 error(WARNING, "multiple modifiers in sender");
980 strcpy(curmod, thismod);
981 }
982 parse_params(&curparams, newparams);
983 newparams[0] = '\0';
984 add_surface(st, oname, fp); /* read & store surface */
985 return(0);
986 }
987 /* else skip arguments */
988 if (!fscanf(fp, "%d", &n)) return(0);
989 while (n-- > 0) fscanf(fp, "%*s");
990 if (!fscanf(fp, "%d", &n)) return(0);
991 while (n-- > 0) fscanf(fp, "%*d");
992 if (!fscanf(fp, "%d", &n)) return(0);
993 while (n-- > 0) fscanf(fp, "%*f");
994 return(0);
995 }
996
997 /* Load a Radiance scene using the given callback function for objects */
998 int
999 load_scene(const char *inspec, int (*ocb)(FILE *))
1000 {
1001 int rv = 0;
1002 char inpbuf[1024];
1003 FILE *fp;
1004 int c;
1005
1006 if (*inspec == '!')
1007 fp = popen(inspec+1, "r");
1008 else
1009 fp = fopen(inspec, "r");
1010 if (fp == NULL) {
1011 sprintf(errmsg, "cannot load '%s'", inspec);
1012 error(SYSTEM, errmsg);
1013 return(-1);
1014 }
1015 while ((c = getc(fp)) != EOF) { /* load sender/receiver data */
1016 if (isspace(c)) /* skip leading white space */
1017 continue;
1018 if (c == '!') { /* read from a new command */
1019 inpbuf[0] = c;
1020 if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1021 if ((c = load_scene(inpbuf, ocb)) < 0)
1022 return(c);
1023 rv += c;
1024 }
1025 continue;
1026 }
1027 if (c == '#') { /* parameters/comment */
1028 if ((c = getc(fp)) == EOF)
1029 break;
1030 if (c == '@' && fscanf(fp, "%s", inpbuf) == 1 &&
1031 (!strcmp(inpbuf, PARAMSNAME) ||
1032 !strcmp(inpbuf, progname))) {
1033 if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1034 strlcat(newparams, inpbuf, sizeof(newparams));
1035 continue;
1036 }
1037 while (c != '\n' && (c = getc(fp)) != EOF)
1038 ; /* ...skipping comment */
1039 continue;
1040 }
1041 ungetc(c, fp); /* else check object for receiver */
1042 c = (*ocb)(fp);
1043 if (c < 0)
1044 return(c);
1045 rv += c;
1046 }
1047 /* close our input stream */
1048 c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1049 if (c != 0) {
1050 sprintf(errmsg, "error loading '%s'", inspec);
1051 error(SYSTEM, errmsg);
1052 return(-1);
1053 }
1054 return(rv);
1055 }
1056
1057 void
1058 wputs( /* warning output function */
1059 const char *s
1060 )
1061 {
1062 if (erract[WARNING].pf == NULL)
1063 return;
1064 int lasterrno = errno;
1065 eputs(s);
1066 errno = lasterrno;
1067 }
1068
1069 void
1070 eputs( /* put string to stderr */
1071 const char *s
1072 )
1073 {
1074 static int midline = 0;
1075
1076 if (!*s)
1077 return;
1078 if (!midline++) {
1079 fputs(progname, stderr);
1080 fputs(": ", stderr);
1081 }
1082 fputs(s, stderr);
1083 if (s[strlen(s)-1] == '\n') {
1084 fflush(stderr);
1085 midline = 0;
1086 }
1087 }
1088
1089 /* set input/output format */
1090 void
1091 setformat(const char *fmt)
1092 {
1093 switch (fmt[0]) {
1094 case 'f':
1095 case 'd':
1096 SET_FILE_BINARY(stdin);
1097 /* fall through */
1098 case 'a':
1099 inpfmt = fmt[0];
1100 break;
1101 case 'c':
1102 if (fmt[1])
1103 goto fmterr;
1104 outfmt = fmt[0]; // special case for output-only
1105 return;
1106 default:
1107 goto fmterr;
1108 }
1109 switch (fmt[1]) {
1110 case '\0':
1111 if (inpfmt == 'a')
1112 goto fmterr;
1113 outfmt = inpfmt;
1114 return;
1115 case 'f':
1116 case 'd':
1117 case 'c':
1118 outfmt = fmt[1];
1119 break;
1120 default:
1121 goto fmterr;
1122 }
1123 if (!fmt[2])
1124 return;
1125 fmterr:
1126 sprintf(errmsg, "unsupported i/o format: -f%s", fmt);
1127 error(USER, errmsg);
1128 }
1129
1130 inline double
1131 pixjitter()
1132 {
1133 return(0.5 + dstrpix*(frandom()-0.5));
1134 }
1135
1136 // Compute a set of view rays for the given pixel accumulator
1137 bool
1138 viewRays(FVECT orig_dir[], int x, int y)
1139 {
1140 for (int n = 0; n < myRCmanager.accum; orig_dir += 2, n++) {
1141 const double d = viewray(orig_dir[0], orig_dir[1], &ourview,
1142 (x+pixjitter())/myRCmanager.xres,
1143 (y+pixjitter())/myRCmanager.yres);
1144 // off-view sample?
1145 if (d < -FTINY || !jitteraperture(orig_dir[0], orig_dir[1],
1146 &ourview, dblur))
1147 memset(orig_dir+1, 0, sizeof(FVECT));
1148 else // else record distance to aft plane
1149 for (int i = 3*(d > FTINY); i--; )
1150 orig_dir[1][i] *= d;
1151 // accumulating identical samples?
1152 if (!n && (dstrpix <= 0.05) & (dblur <= FTINY)) {
1153 while (++n < myRCmanager.accum)
1154 memcpy(orig_dir[2*n], orig_dir[0], sizeof(FVECT)*2);
1155 break;
1156 }
1157 }
1158 return true;
1159 }
1160
1161 // Load a set of rays for accumulation (do not normalize direction)
1162 int
1163 getRays(FVECT orig_dir[])
1164 {
1165 int n;
1166 // read directly if possible
1167 if (inpfmt == "_fd"[sizeof(RREAL)/sizeof(float)])
1168 return(getbinary(orig_dir[0], sizeof(FVECT)*2,
1169 myRCmanager.accum, stdin));
1170
1171 for (n = 0; n < myRCmanager.accum; orig_dir += 2, n++) {
1172 switch (inpfmt) {
1173 #ifdef SMLFLT
1174 case 'd': { double dvin[6];
1175 if (getbinary(dvin, sizeof(dvin), 1, stdin) != 1)
1176 break;
1177 for (int i = 6; i--; ) orig_dir[0][i] = dvin[i];
1178 } continue;
1179 #else
1180 case 'f': { float fvin[6];
1181 if (getbinary(fvin, sizeof(fvin), 1, stdin) != 1)
1182 break;
1183 for (int i = 6; i--; ) orig_dir[0][i] = fvin[i];
1184 } continue;
1185 #endif
1186 case 'a':
1187 if (scanf(FVFORMAT, &orig_dir[0][0], &orig_dir[0][1],
1188 &orig_dir[0][2]) != 3)
1189 break;
1190 if (scanf(FVFORMAT, &orig_dir[1][0], &orig_dir[1][1],
1191 &orig_dir[1][2]) != 3)
1192 break;
1193 continue;
1194 }
1195 break;
1196 }
1197 return(n);
1198 }
1199
1200 /* Set default options */
1201 void
1202 default_options()
1203 {
1204 rand_samp = 1;
1205 dstrsrc = 0.9;
1206 directrelay = 3;
1207 vspretest = 512;
1208 srcsizerat = .2;
1209 specthresh = .02;
1210 specjitter = 1.;
1211 maxdepth = -10;
1212 minweight = 2e-3;
1213 ambres = 256;
1214 ambdiv = 350;
1215 ambounce = 1;
1216 }
1217
1218 /* Set overriding options */
1219 void
1220 override_options()
1221 {
1222 shadthresh = 0;
1223 ambssamp = 0;
1224 ambacc = 0;
1225 }
1226
1227 void
1228 onsig( /* fatal signal */
1229 int signo
1230 )
1231 {
1232 static int gotsig = 0;
1233
1234 if (gotsig++) /* two signals and we're gone! */
1235 _exit(signo);
1236
1237 #ifdef SIGALRM
1238 alarm(600); /* allow 10 minutes to clean up */
1239 signal(SIGALRM, SIG_DFL); /* make certain we do die */
1240 #endif
1241 eputs("signal - ");
1242 eputs(sigerr[signo]);
1243 eputs("\n");
1244 quit(3);
1245 }
1246
1247 void
1248 sigdie( /* set fatal signal */
1249 int signo,
1250 const char *msg
1251 )
1252 {
1253 if (signal(signo, onsig) == SIG_IGN)
1254 signal(signo, SIG_IGN);
1255 sigerr[signo] = msg;
1256 }
1257
1258 // report progress
1259 void
1260 report_progress(bool force = false)
1261 {
1262 static time_t last_report=0, tstart=time(0);
1263 time_t tnow;
1264
1265 if (!force & (report_intvl <= 0))
1266 return;
1267
1268 tnow = time(0);
1269 if (!force & (tnow < last_report + report_intvl))
1270 return;
1271
1272 sprintf(errmsg, "%.2f%% done after %.3f hours\n",
1273 100. * myRCmanager.GetRowFinished() /
1274 (double)myRCmanager.GetRowMax(),
1275 (tnow - tstart)*(1./3600.));
1276 eputs(errmsg);
1277 last_report = tnow;
1278 }
1279
1280 /* Run rfluxmtx equivalent without leaning on r[x]contrib */
1281 int
1282 main(int argc, char *argv[])
1283 {
1284 #define check(ol,al) if (argv[a][ol] || \
1285 badarg(argc-a-1,argv+a+1,al)) \
1286 goto userr
1287 #define check_bool(olen,var) switch (argv[a][olen]) { \
1288 case '\0': var = !var; break; \
1289 case 'y': case 'Y': case 't': case 'T': \
1290 case '+': case '1': var = 1; break; \
1291 case 'n': case 'N': case 'f': case 'F': \
1292 case '-': case '0': var = 0; break; \
1293 default: goto userr; }
1294 bool gotView = false;
1295 double pixaspect = 1.;
1296 int nproc = 1;
1297 int nout = 0;
1298 char *outfn = NULL;
1299 FVECT *rayarr = NULL;
1300 const char *sendfn = "";
1301 PARAMS sendparams;
1302 int rval;
1303 int a, i;
1304 /* set global progname */
1305 fixargv0(argv[0]);
1306 // just asking version?
1307 if (argc == 2 && !strcmp(argv[1], "-version")) {
1308 puts(VersionID);
1309 quit(0);
1310 }
1311 initfunc(); /* initialize calcomp routines first */
1312 calcontext(RCCONTEXT);
1313 /* set rcontrib defaults */
1314 default_options();
1315 /* get command-line options */
1316 for (a = 1; a < argc; a++) {
1317 /* check for argument expansion */
1318 while ((rval = expandarg(&argc, &argv, a)) > 0)
1319 ;
1320 if (rval < 0) {
1321 sprintf(errmsg, "cannot expand '%s'", argv[a]);
1322 error(SYSTEM, errmsg);
1323 }
1324 if (argv[a][0] != '-' || !argv[a][1])
1325 break; // break from options
1326 rval = getrenderopt(argc-a, argv+a);
1327 if (rval >= 0) {
1328 a += rval;
1329 continue;
1330 }
1331 rval = getviewopt(&ourview, argc-a, argv+a);
1332 if (rval >= 0) {
1333 a += rval;
1334 gotView = true;
1335 continue;
1336 }
1337 switch (argv[a][1]) { /* !! Keep consistent !! */
1338 case 'W': /* verbose mode */
1339 check_bool(2,verby);
1340 break;
1341 case 'v': // view file
1342 if (argv[a][2] != 'f')
1343 goto userr;
1344 check(3,"s");
1345 rval = viewfile(argv[++a], &ourview, NULL);
1346 if (rval < 0) {
1347 sprintf(errmsg, "cannot open view file '%s'", argv[a]);
1348 error(SYSTEM, errmsg);
1349 } else if (!rval) {
1350 sprintf(errmsg, "bad view file '%s'", argv[a]);
1351 error(USER, errmsg);
1352 }
1353 gotView = true;
1354 break;
1355 case 'p': // -pj, -pd, or -pa
1356 switch (argv[a][2]) {
1357 case 'j': /* jitter */
1358 check(3,"f");
1359 dstrpix = atof(argv[++a]);
1360 break;
1361 case 'd': /* aperture */
1362 check(3,"f");
1363 dblur = atof(argv[++a]);
1364 break;
1365 case 'a': /* aspect */
1366 check(3,"f");
1367 pixaspect = atof(argv[++a]);
1368 break;
1369 default:
1370 goto userr;
1371 }
1372 break;
1373 case 'n': /* number of processes */
1374 check(2,"i");
1375 nproc = atoi(argv[++a]);
1376 if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0)
1377 nproc = 1;
1378 break;
1379 case 'V': /* output contributions? */
1380 rval = myRCmanager.HasFlag(RCcontrib);
1381 check_bool(2,rval);
1382 myRCmanager.SetFlag(RCcontrib, rval);
1383 break;
1384 case 'x': /* x resolution */
1385 check(2,"i");
1386 myRCmanager.xres = atoi(argv[++a]);
1387 break;
1388 case 'y': /* y resolution */
1389 check(2,"i");
1390 myRCmanager.yres = atoi(argv[++a]);
1391 break;
1392 case 'w': /* warnings on/off */
1393 rval = (erract[WARNING].pf != NULL);
1394 check_bool(2,rval);
1395 if (rval) erract[WARNING].pf = wputs;
1396 else erract[WARNING].pf = NULL;
1397 break;
1398 case 'l': /* limit distance */
1399 if (argv[a][2] != 'd')
1400 goto userr;
1401 rval = myRCmanager.HasFlag(RTlimDist);
1402 check_bool(3,rval);
1403 myRCmanager.SetFlag(RTlimDist, rval);
1404 break;
1405 case 'I': /* immed. irradiance */
1406 rval = myRCmanager.HasFlag(RTimmIrrad);
1407 check_bool(2,rval);
1408 myRCmanager.SetFlag(RTimmIrrad, rval);
1409 break;
1410 case 'f': /* format */
1411 if (argv[a][2] == 'o')
1412 goto userr; /* -fo is not optional */
1413 setformat(argv[a]+2);
1414 myRCmanager.SetDataFormat(outfmt);
1415 break;
1416 case 'o': /* output file */
1417 check(2,"s");
1418 outfn = argv[++a];
1419 break;
1420 case 'c': /* sample count */
1421 check(2,"i");
1422 myRCmanager.accum = atoi(argv[++a]);
1423 break;
1424 case 't': /* reporting interval */
1425 check(2,"i");
1426 report_intvl = atoi(argv[++a]);
1427 break;
1428 default: /* anything else is verbotten */
1429 goto userr;
1430 }
1431 }
1432 if (a > argc-1)
1433 goto userr;
1434
1435 override_options(); /* override critical options */
1436
1437 if (!gotView) {
1438 sendfn = argv[a++];
1439 if (a > argc-1)
1440 goto userr;
1441 } else if (argv[a][0] == '-')
1442 error(USER, "view specification incompatible with pass-through mode");
1443 /* assign sender & receiver inputs */
1444 if (gotView) { // picture output?
1445 const char * err = setview(&ourview);
1446 if (err != NULL)
1447 error(USER, err);
1448 normaspect(viewaspect(&ourview), &pixaspect,
1449 &myRCmanager.xres, &myRCmanager.yres);
1450 if ((myRCmanager.xres <= 0) | (myRCmanager.yres <= 0))
1451 error(USER, "missing or illegal -x and -y resolution");
1452 myRCmanager.SetFlag(RTlimDist, ourview.vaft > FTINY);
1453 if (myRCmanager.accum <= 0)
1454 myRCmanager.accum = 1;
1455 } else if (sendfn[0] == '-') { // pass-through mode?
1456 if (sendfn[1]) goto userr;
1457 sendfn = NULL;
1458 if (myRCmanager.accum <= 0)
1459 myRCmanager.accum = 1;
1460 } else { // else surface sampling
1461 if (do_irrad | myRCmanager.HasFlag(RTimmIrrad))
1462 error(USER, "-i, -I not allowed in surface-sampling mode");
1463 myRCmanager.SetFlag(RTlimDist, false);
1464 if (load_scene(sendfn, add_send_object) < 0)
1465 quit(1);
1466 sendparams = curparams; // save sender params & clear current
1467 memset(&curparams, 0, sizeof(PARAMS));
1468 curmod[0] = '\0';
1469 myRCmanager.yres = prepare_sampler(&sendparams);
1470 if (myRCmanager.yres <= 0)
1471 quit(1);
1472 myRCmanager.xres = 0;
1473 if (myRCmanager.accum <= 1)
1474 myRCmanager.accum = 10000;
1475 }
1476 if (outfn != NULL) // saved from -o option above?
1477 strlcpy(curparams.outfn, outfn, sizeof(curparams.outfn));
1478 // get ready to rock...
1479 if (setspectrsamp(CNDX, WLPART) < 0)
1480 error(USER, "unsupported spectral sampling");
1481 /* set up signal handling */
1482 sigdie(SIGINT, "Interrupt");
1483 #ifdef SIGHUP
1484 sigdie(SIGHUP, "Hangup");
1485 #endif
1486 sigdie(SIGTERM, "Terminate");
1487 #ifdef SIGPIPE
1488 sigdie(SIGPIPE, "Broken pipe");
1489 #endif
1490 #ifdef SIGALRM
1491 sigdie(SIGALRM, "Alarm clock");
1492 #endif
1493 #ifdef SIGXCPU
1494 sigdie(SIGXCPU, "CPU limit exceeded");
1495 sigdie(SIGXFSZ, "File size exceeded");
1496 #endif
1497 #ifdef NICE
1498 nice(NICE); /* lower priority */
1499 #endif
1500 rayarr = new FVECT [myRCmanager.accum*2];
1501 // load octree
1502 if (!myRCmanager.LoadOctree(oconv_command(argc-a, argv+a)))
1503 quit(1);
1504 // add to header
1505 myRCmanager.AddHeader(argc, argv);
1506 {
1507 char buf[128] = "SOFTWARE= ";
1508 strcpy(buf+10, VersionID);
1509 myRCmanager.AddHeader(buf);
1510 if (gotView) {
1511 sprintf(buf, "%s%s", VIEWSTR, viewopt(&ourview));
1512 if (strlen(buf) > VIEWSTRL+3)
1513 myRCmanager.AddHeader(buf);
1514 }
1515 if ((pixaspect > .005) && (pixaspect < .995) |
1516 (pixaspect > 1.005)) {
1517 sprintf(buf, "%s%f", ASPECTSTR, pixaspect);
1518 myRCmanager.AddHeader(buf);
1519 }
1520 }
1521 /* assign receiver modifiers */
1522 if (load_scene(argv[a], add_recv_object) < 0)
1523 quit(1);
1524 finish_receiver(); // makes final AddModifier() call
1525 // prepare output(s)
1526 myRCmanager.outOp = RCOforce; // mandatory rcontrib -fo+ mode
1527 if (myRCmanager.PrepOutput() < 0)
1528 error(USER, "issue creating output file(s)");
1529 if (verby) // get output file count?
1530 for (const RcontribOutput *op = myRCmanager.GetOutput();
1531 op != NULL; op = op->Next())
1532 ++nout;
1533 if (nproc > 1) { // set #processes
1534 if (verby) {
1535 sprintf(errmsg, "starting %d subprocesses\n", nproc);
1536 eputs(errmsg);
1537 }
1538 myRCmanager.SetThreadCount(nproc);
1539 }
1540 if (gotView) { // picture generation mode?
1541 if (verby) {
1542 sprintf(errmsg, "computing %d %dx%d pictures\n",
1543 nout, myRCmanager.xres, myRCmanager.yres);
1544 if (myRCmanager.accum > 1)
1545 sprintf(errmsg+strlen(errmsg)-1, " with %d samples/pixel\n",
1546 myRCmanager.accum);
1547 eputs(errmsg);
1548 }
1549 for (i = myRCmanager.yres; i--; ) // from the top!
1550 for (int x = 0; x < myRCmanager.xres; x++) {
1551 report_progress();
1552 if (!viewRays(rayarr, x, i))
1553 quit(1);
1554 if (myRCmanager.ComputeRecord(rayarr) != myRCmanager.accum)
1555 error(USER, "failed call to ComputeRecord()");
1556 }
1557 } else if (sendfn == NULL) { // pass-through mode?
1558 #ifdef getc_unlocked
1559 flockfile(stdin);
1560 #endif
1561 if (verby) {
1562 sprintf(errmsg, "computing %d rows in %d matrices\n",
1563 myRCmanager.GetRowMax(), nout);
1564 if (myRCmanager.accum > 1)
1565 sprintf(errmsg+strlen(errmsg)-1, " with %d samples/row\n",
1566 myRCmanager.accum);
1567 eputs(errmsg);
1568 }
1569 for (i = 0; i < myRCmanager.GetRowMax(); i++) {
1570 report_progress();
1571 if (getRays(rayarr) != myRCmanager.accum) {
1572 sprintf(errmsg, "ray read error after %d of %d",
1573 myRCmanager.GetRowCount(),
1574 myRCmanager.GetRowMax());
1575 error(USER, errmsg);
1576 }
1577 if (myRCmanager.ComputeRecord(rayarr) != myRCmanager.accum)
1578 error(USER, "failed call to ComputeRecord()");
1579 }
1580 } else { // else surface-sampling mode
1581 if (verby) {
1582 sprintf(errmsg, "sampling %d directions in %d matrices with %d samples/direction\n",
1583 myRCmanager.yres, nout, myRCmanager.accum);
1584 if (sendparams.nsurfs > 1)
1585 sprintf(errmsg+strlen(errmsg)-1, " (%d surface elements)\n", sendparams.nsurfs);
1586 eputs(errmsg);
1587 }
1588 for (i = 0; i < myRCmanager.yres; i++) {
1589 report_progress();
1590 if (!(*sendparams.sample_basis)(&sendparams, i, rayarr))
1591 quit(1);
1592 if (myRCmanager.ComputeRecord(rayarr) != myRCmanager.accum)
1593 error(USER, "failed call to ComputeRecord()");
1594 }
1595 clear_params(&sendparams);
1596 }
1597 delete [] rayarr;
1598 myRCmanager.FlushQueue();
1599 report_progress((report_intvl > 0) | verby);
1600 quit(0); /* waits on children */
1601 userr:
1602 if (a < argc-2)
1603 fprintf(stderr, "%s: unsupported option '%s'\n", progname, argv[a]);
1604 fprintf(stderr, "Usage: %s [-W] [rxcontrib options] { sender.rad | view | - } receiver.rad [-i system.oct] [system.rad ..]\n",
1605 progname);
1606 quit(1);
1607 }
1608
1609 /* Exit program */
1610 void
1611 quit(
1612 int code
1613 )
1614 {
1615 if (!code)
1616 myRCmanager.ClearModifiers();
1617
1618 exit(code);
1619 }
