#ifndef lint static const char RCSid[] = "$Id: rxfluxmtx.cpp,v 2.1 2025/10/22 02:38:27 greg Exp $"; #endif /* * Calculate flux transfer matrix or matrices using RcontribSimulManager class * * Much of this is cribbed from util/rfluxmtx.c * Implementation here improves efficiency and overcomes receiver limits */ #include "copyright.h" #include #include #include "RcontribSimulManager.h" #include "bsdf.h" #include "bsdf_m.h" #include "func.h" #include "random.h" #include "triangulate.h" #include "view.h" int verby = 0; /* verbose mode? */ const char *reinhfn = "reinhartb.cal"; const char *shirchiufn = "disk2square.cal"; const char *kfullfn = "klems_full.cal"; const char *khalffn = "klems_half.cal"; const char *kquarterfn = "klems_quarter.cal"; const char *ciefn = "cieskyscan.cal"; const char *sigerr[NSIG]; /* signal error messages */ int inpfmt = 'a'; /* input format */ int outfmt = 'f'; /* output format */ RcontribSimulManager myRCmanager; // global rcontrib simulation manager #define PARAMSNAME "rfluxmtx" /* string indicating parameters */ /* surface type IDs */ #define ST_NONE 0 #define ST_POLY 1 #define ST_RING 2 #define ST_SOURCE 3 /* surface structure */ struct SURF { SURF *next; /* next surface in list */ void *priv; /* private data (malloc'ed) */ char sname[32]; /* surface name */ FVECT snrm; /* surface normal */ double area; /* surface area / proj. solid angle */ short styp; /* surface type */ short nfargs; /* number of real arguments */ double farg[1]; /* real values (extends struct) */ }; /* triangle */ struct PTRI { double afrac; /* fraction of total area */ short vndx[3]; /* vertex indices */ }; /* triangulated polygon */ struct POLYTRIS { FVECT uva[2]; /* tangent axes */ int ntris; /* number of triangles */ PTRI tri[1]; /* triangle array (extends struct) */ }; /* sender/receiver parameters */ struct PARAMS { char sign; /* '-' for axis reversal */ char hemis[31]; /* hemispherical sampling spec. */ int hsiz; /* hemisphere basis size */ int nsurfs; /* number of surfaces */ SURF *slist; /* list of surfaces */ FVECT vup; /* up vector (zero if unset) */ FVECT nrm; /* average normal direction */ FVECT udir, vdir; /* tangent axes */ char outfn[256]; /* output file name (receiver) */ int (*sample_basis)(PARAMS *p, int b, FVECT orig_dir[]); }; PARAMS curparams; char curmod[MAXSTR]; char newparams[1024]; typedef int SURFSAMP(FVECT, SURF *, double); SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring; SURFSAMP *orig_in_surf[4] = { ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad }; VIEW ourview = STDVIEW; // view parameters (if set) double dstrpix = 0; // pixel jitter double dblur = 0; // depth-of-field /* Clear parameter set */ void clear_params(PARAMS *p, bool reset_only = true) { while (p->slist != NULL) { SURF *sdel = p->slist; p->slist = sdel->next; if (sdel->priv != NULL) free(sdel->priv); free(sdel); } if (reset_only) { p->nsurfs = 0; p->slist = NULL; memset(p->nrm, 0, sizeof(FVECT)); memset(p->vup, 0, sizeof(FVECT)); } else memset(p, 0, sizeof(PARAMS)); } /* Get surface type from name */ int surf_type(const char *otype) { if (!strcmp(otype, "polygon")) return(ST_POLY); if (!strcmp(otype, "ring")) return(ST_RING); if (!strcmp(otype, "source")) return(ST_SOURCE); return(ST_NONE); } /* Add arguments to oconv command */ char * oconv_command(int ac, char *av[]) { static char oconvbuf[4096] = "!oconv -f "; char *cp = oconvbuf + 10; char *recv = *av++; if (ac-- <= 0) return(NULL); if (erract[WARNING].pf == NULL) { /* warnings off? */ strcpy(cp, "-w "); cp += 3; } while (ac-- > 0) { /* copy each argument */ int len = strlen(*av); if (cp+len+4 >= oconvbuf+sizeof(oconvbuf)) goto overrun; if (matchany(*av, SPECIALS)) { *cp++ = QUOTCHAR; strcpy(cp, *av++); cp += len; *cp++ = QUOTCHAR; } else { strcpy(cp, *av++); cp += len; } *cp++ = ' '; } /* receiver goes last */ if (matchany(recv, SPECIALS)) { *cp++ = QUOTCHAR; while (*recv) { if (cp >= oconvbuf+(sizeof(oconvbuf)-3)) goto overrun; *cp++ = *recv++; } *cp++ = QUOTCHAR; *cp = '\0'; } else strcpy(cp, recv); return(oconvbuf); overrun: error(USER, "too many file arguments!"); return(NULL); /* pro forma return */ } /* Get normalized direction vector from string specification */ int get_direction(FVECT dv, const char *s) { int sign = 1; int axis = 0; memset(dv, 0, sizeof(FVECT)); nextchar: switch (*s) { case '+': ++s; goto nextchar; case '-': sign = -sign; ++s; goto nextchar; case 'z': case 'Z': ++axis; case 'y': case 'Y': ++axis; case 'x': case 'X': dv[axis] = sign; return(!s[1] | isspace(s[1])); default: break; } #ifdef SMLFLT if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3) #else if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3) #endif return(0); dv[0] *= (RREAL)sign; return(normalize(dv) > 0); } /* Parse program parameters (directives) */ int parse_params(PARAMS *p, char *pargs) { char *cp = pargs; int nparams = 0; int quot; int i; for ( ; ; ) { switch (*cp++) { case 'h': if (*cp++ != '=') break; if ((*cp == '+') | (*cp == '-')) p->sign = *cp++; else p->sign = '+'; p->hsiz = 0; i = 0; while (*cp && !isspace(*cp)) { if (isdigit(*cp)) p->hsiz = 10*p->hsiz + *cp - '0'; p->hemis[i++] = *cp++; } if (!i) break; p->hemis[i] = '\0'; p->hsiz += !p->hsiz; ++nparams; continue; case 'u': if (*cp++ != '=') break; if (!get_direction(p->vup, cp)) break; while (*cp && !isspace(*cp++)) ; ++nparams; continue; case 'o': if (*cp++ != '=') break; quot = 0; if ((*cp == '"') | (*cp == '\'')) quot = *cp++; i = 0; while (*cp && (quot ? (*cp != quot) : !isspace(*cp))) { i++; cp++; } if (!i) break; if (!*cp) { if (quot) break; cp[1] = '\0'; } *cp = '\0'; strlcpy(p->outfn, cp-i, sizeof(p->outfn)); *cp++ = quot ? quot : ' '; ++nparams; continue; case ' ': case '\t': case '\r': case '\n': continue; case '\0': return(nparams); default: break; } break; } sprintf(errmsg, "bad parameter string: %s", pargs); error(USER, errmsg); return(-1); /* pro forma return */ } /* Add receiver modifier and associated parameters */ void finish_receiver() { bool uniform = false; const char *calfn = NULL; char binv[64] = ""; char params[128] = ""; const char *binf = NULL; const char *nbins = NULL; /* check arguments */ if (!curmod[0]) error(USER, "missing receiver surface"); if (!curparams.outfn[0]) error(USER, "missing output file for receiver"); if (!curparams.hemis[0]) error(USER, "missing hemisphere sampling type"); if (normalize(curparams.nrm) == 0) error(USER, "undefined normal for hemisphere sampling"); if (normalize(curparams.vup) == 0) { if (fabs(curparams.nrm[2]) < .7) curparams.vup[2] = 1; else curparams.vup[1] = 1; } /* determine sample type/bin */ if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1')) { sprintf(binv, "if(-Dx*%g-Dy*%g-Dz*%g,0,-1)", curparams.nrm[0], curparams.nrm[1], curparams.nrm[2]); uniform = true; /* uniform sampling -- one bin */ } else if (tolower(curparams.hemis[0]) == 's' && tolower(curparams.hemis[1]) == 'c') { /* assign parameters */ if (curparams.hsiz <= 1) error(USER, "missing size for Shirley-Chiu sampling"); calfn = shirchiufn; shirchiufn = NULL; sprintf(params, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1", curparams.hsiz, curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], curparams.vup[0], curparams.vup[1], curparams.vup[2], curparams.sign); strcpy(binv, "scbin"); nbins = "SCdim*SCdim"; } else if ((tolower(curparams.hemis[0]) == 'r') | (tolower(curparams.hemis[0]) == 't')) { calfn = reinhfn; reinhfn = NULL; sprintf(params, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1", curparams.hsiz, curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], curparams.vup[0], curparams.vup[1], curparams.vup[2], curparams.sign); strcpy(binv, "rbin"); nbins = "Nrbins"; } else if (tolower(curparams.hemis[0]) == 'k' && !curparams.hemis[1] | (tolower(curparams.hemis[1]) == 'f') | (curparams.hemis[1] == '1')) { calfn = kfullfn; kfullfn = NULL; binf = "kbin"; nbins = "Nkbins"; } else if (tolower(curparams.hemis[0]) == 'k' && (tolower(curparams.hemis[1]) == 'h') | (curparams.hemis[1] == '2')) { calfn = khalffn; khalffn = NULL; binf = "khbin"; nbins = "Nkhbins"; } else if (tolower(curparams.hemis[0]) == 'k' && (tolower(curparams.hemis[1]) == 'q') | (curparams.hemis[1] == '4')) { calfn = kquarterfn; kquarterfn = NULL; binf = "kqbin"; nbins = "Nkqbins"; } else if (!strcasecmp(curparams.hemis, "cie")) { calfn = ciefn; ciefn = NULL; sprintf(params, "rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1", curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], curparams.vup[0], curparams.vup[1], curparams.vup[2], curparams.sign); strcpy(binv, "cbin"); nbins = "Ncbins"; } else { sprintf(errmsg, "unrecognized hemisphere sampling: h=%s", curparams.hemis); error(USER, errmsg); } if (tolower(curparams.hemis[0]) == 'k') { sprintf(params, "RHS=%c1", curparams.sign); } if (!uniform) for (SURF *sp = curparams.slist; sp != NULL; sp = sp->next) if (sp->styp == ST_SOURCE && fabs(sp->area - PI) > 1e-3) { sprintf(errmsg, "source '%s' must be 180-degrees", sp->sname); error(USER, errmsg); } if (binf != NULL) { /* complete bin function? */ sprintf(binv, "%s(%g,%g,%g,%g,%g,%g)", binf, curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], curparams.vup[0], curparams.vup[1], curparams.vup[2]); } if (calfn != NULL) /* load cal file if needed */ loadfunc(const_cast(calfn)); if (params[0]) /* set parameters if any */ set_eparams(params); // add modifier to rcontrib object if (!myRCmanager.AddModifier(curmod, curparams.outfn, params, binv, nbins==NULL ? 1 : int(eval(const_cast(nbins)) + .5))) error(INTERNAL, "AddModifier() call failed"); clear_params(&curparams, true); /* clear for next receiver */ curmod[0] = '\0'; } /* Make randomly oriented tangent plane axes for given normal direction */ void make_axes(FVECT uva[2], const FVECT nrm) { int i; if (!getperpendicular(uva[0], nrm, 1)) error(USER, "bad surface normal in make_axes()"); VCROSS(uva[1], nrm, uva[0]); } /* Illegal sender surfaces end up here */ int ssamp_bad(FVECT orig, SURF *sp, double x) { sprintf(errmsg, "illegal sender surface '%s'", sp->sname); error(INTERNAL, errmsg); return(0); } /* Generate origin on ring surface from uniform random variable */ int ssamp_ring(FVECT orig, SURF *sp, double x) { FVECT *uva = (FVECT *)sp->priv; double samp2[2]; double uv[2]; int i; if (uva == NULL) { /* need tangent axes */ uva = (FVECT *)malloc(sizeof(FVECT)*2); if (uva == NULL) { error(SYSTEM, "out of memory in ssamp_ring()"); return(0); } make_axes(uva, sp->snrm); sp->priv = uva; } SDmultiSamp(samp2, 2, x); samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]); samp2[1] *= 2.*PI; uv[0] = samp2[0]*tcos(samp2[1]); uv[1] = samp2[0]*tsin(samp2[1]); for (i = 3; i--; ) orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i]; return(1); } /* Add triangle to polygon's list (call-back function) */ int add_triangle(const Vert2_list *tp, int a, int b, int c) { POLYTRIS *ptp = (POLYTRIS *)tp->p; PTRI *trip = ptp->tri + ptp->ntris++; trip->vndx[0] = a; trip->vndx[1] = b; trip->vndx[2] = c; return(1); } /* Generate origin on polygon surface from uniform random variable */ int ssamp_poly(FVECT orig, SURF *sp, double x) { POLYTRIS *ptp = (POLYTRIS *)sp->priv; double samp2[2]; double *v0, *v1, *v2; int i; if (ptp == NULL) { /* need to triangulate */ ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) + sizeof(PTRI)*(sp->nfargs/3 - 3)); if (ptp == NULL) goto memerr; if (sp->nfargs == 3) { /* simple case */ ptp->ntris = 1; ptp->tri[0].vndx[0] = 0; ptp->tri[0].vndx[1] = 1; ptp->tri[0].vndx[2] = 2; ptp->tri[0].afrac = 1; } else { Vert2_list *v2l = polyAlloc(sp->nfargs/3); if (v2l == NULL) goto memerr; make_axes(ptp->uva, sp->snrm); for (i = v2l->nv; i--; ) { v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]); v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]); } ptp->ntris = 0; v2l->p = ptp; if (!polyTriangulate(v2l, add_triangle)) { sprintf(errmsg, "cannot triangulate polygon '%s'", sp->sname); error(USER, errmsg); return(0); } for (i = ptp->ntris; i--; ) { int a = ptp->tri[i].vndx[0]; int b = ptp->tri[i].vndx[1]; int c = ptp->tri[i].vndx[2]; ptp->tri[i].afrac = (v2l->v[a].mX*v2l->v[b].mY - v2l->v[b].mX*v2l->v[a].mY + v2l->v[b].mX*v2l->v[c].mY - v2l->v[c].mX*v2l->v[b].mY + v2l->v[c].mX*v2l->v[a].mY - v2l->v[a].mX*v2l->v[c].mY) / (2.*sp->area); } polyFree(v2l); } sp->priv = ptp; } /* pick triangle by partial area */ for (i = 0; i < ptp->ntris-1 && x > ptp->tri[i].afrac; i++) x -= ptp->tri[i].afrac; SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac); samp2[0] *= samp2[1] = sqrt(samp2[1]); samp2[1] = 1. - samp2[1]; v0 = sp->farg + 3*ptp->tri[i].vndx[0]; v1 = sp->farg + 3*ptp->tri[i].vndx[1]; v2 = sp->farg + 3*ptp->tri[i].vndx[2]; for (i = 3; i--; ) orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i]) + samp2[1]*(v2[i] - v0[i]) ; return(1); memerr: error(SYSTEM, "out of memory in ssamp_poly"); return(0); } /* Compute sample origin based on projected areas of sender subsurfaces */ int sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x) { static double *projsa; static int nall; double tarea = 0; int i; SURF *sp; /* special case for lone surface */ if (p->nsurfs == 1) { sp = p->slist; if (DOT(sp->snrm, rdir) >= FTINY) { sprintf(errmsg, "sample behind sender '%s'", sp->sname); error(INTERNAL, errmsg); return(0); } return((*orig_in_surf[sp->styp])(orig, sp, x)); } if (p->nsurfs > nall) { /* (re)allocate surface area cache */ if (projsa) free(projsa); projsa = (double *)malloc(sizeof(double)*p->nsurfs); if (projsa == NULL) error(SYSTEM, "out of memory in sample_origin()"); nall = p->nsurfs; } /* compute projected areas */ for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) { projsa[i] = -DOT(sp->snrm, rdir) * sp->area; tarea += projsa[i] *= (double)(projsa[i] > 0); } if (tarea < FTINY*FTINY) { /* wrong side of sender? */ error(INTERNAL, "sample behind all sender elements!"); return(0); } tarea *= x; /* get surface from list */ for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next) tarea -= projsa[i++]; return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i])); } /* Uniform sample generator */ int sample_uniform(PARAMS *p, int b, FVECT orig_dir[]) { int n = myRCmanager.accum; double samp3[3]; FVECT duvw; int i; if (orig_dir == NULL) /* just requesting number of bins? */ return(1); while (n--) { /* stratified hemisphere sampling */ SDmultiSamp(samp3, 3, (n+frandom())/myRCmanager.accum); square2disk(duvw, samp3[1], samp3[2]); duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]); for (i = 3; i--; ) orig_dir[1][i] = duvw[0]*p->udir[i] + duvw[1]*p->vdir[i] + duvw[2]*p->nrm[i] ; if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0])) return(0); orig_dir += 2; } return(1); } /* Shirly-Chiu sample generator */ int sample_shirchiu(PARAMS *p, int b, FVECT orig_dir[]) { int n = myRCmanager.accum; double samp3[3]; FVECT duvw; int i; if (orig_dir == NULL) /* just requesting number of bins? */ return(p->hsiz*p->hsiz); while (n--) { /* stratified sampling */ SDmultiSamp(samp3, 3, (n+frandom())/myRCmanager.accum); square2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz, (b%p->hsiz + samp3[2])/curparams.hsiz); duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]); for (i = 3; i--; ) orig_dir[1][i] = -duvw[0]*p->udir[i] - duvw[1]*p->vdir[i] - duvw[2]*p->nrm[i] ; if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0])) return(0); orig_dir += 2; } return(1); } /* Reinhart/Tregenza sample generator */ int sample_reinhart(PARAMS *p, int b, FVECT orig_dir[]) { #define T_NALT 7 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6}; const int RowMax = T_NALT*p->hsiz + 1; const double RAH = (.5*PI)/(RowMax-.5); #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz]) int n = myRCmanager.accum; int row, col; double samp3[3]; double alt, azi; double duvw[3]; int i; if (orig_dir == NULL) { /* just requesting number of bins? */ n = 0; for (row = RowMax; row--; ) n += rnaz(row); return(n); } row = 0; /* identify row & column */ col = b; while (col >= rnaz(row)) { col -= rnaz(row); ++row; } while (n--) { /* stratified sampling */ SDmultiSamp(samp3, 3, (n+frandom())/myRCmanager.accum); if (row >= RowMax-1) /* avoid crowding at zenith */ samp3[1] *= samp3[1]; alt = (row+samp3[1])*RAH; azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row); duvw[2] = cos(alt); /* measured from horizon */ duvw[0] = tsin(azi)*duvw[2]; duvw[1] = -tcos(azi)*duvw[2]; duvw[2] = sqrt(1. - duvw[2]*duvw[2]); for (i = 3; i--; ) orig_dir[1][i] = -duvw[0]*p->udir[i] - duvw[1]*p->vdir[i] - duvw[2]*p->nrm[i] ; if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0])) return(0); orig_dir += 2; } return(1); #undef rnaz #undef T_NALT } /* Klems sample generator */ int sample_klems(PARAMS *p, int b, FVECT orig_dir[]) { static const char bname[4][20] = { "LBNL/Klems Full", "LBNL/Klems Half", "INTERNAL ERROR", "LBNL/Klems Quarter" }; static ANGLE_BASIS *kbasis[4]; const int bi = p->hemis[1] - '1'; int n = myRCmanager.accum; double samp2[2]; double duvw[3]; int i; if (!kbasis[bi]) { /* need to get basis, first */ for (i = 4; i--; ) if (!strcasecmp(abase_list[i].name, bname[bi])) { kbasis[bi] = &abase_list[i]; break; } if (i < 0) { sprintf(errmsg, "unknown hemisphere basis '%s'", bname[bi]); error(USER, errmsg); return(0); } } if (orig_dir == NULL) /* just requesting number of bins? */ return(kbasis[bi]->nangles); while (n--) { /* stratified sampling */ SDmultiSamp(samp2, 2, (n+frandom())/myRCmanager.accum); if (!fo_getvec(duvw, b+samp2[1], kbasis[bi])) return(0); for (i = 3; i--; ) orig_dir[1][i] = -duvw[0]*p->udir[i] - duvw[1]*p->vdir[i] - duvw[2]*p->nrm[i] ; if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0])) return(0); orig_dir += 2; } return(1); } /* Prepare hemisphere basis sampler that will send rays to rcontrib */ int prepare_sampler(PARAMS *p) { if (p->slist == NULL) { /* missing sample surface! */ error(USER, "no sender surface"); return(-1); } /* misplaced output file spec. */ if (p->outfn[0]) { sprintf(errmsg, "ignoring output file in sender ('%s')", p->outfn); error(WARNING, errmsg); } /* check/set basis hemisphere */ if (!p->hemis[0]) { error(USER, "missing sender sampling type"); return(-1); } if (normalize(p->nrm) == 0) { error(USER, "undefined normal for sender sampling"); return(-1); } if (normalize(p->vup) == 0) { if (fabs(p->nrm[2]) < .7) p->vup[2] = 1; else p->vup[1] = 1; } fcross(p->udir, p->vup, p->nrm); if (normalize(p->udir) == 0) { error(USER, "up vector coincides with sender normal"); return(-1); } fcross(p->vdir, p->nrm, p->udir); if (p->sign == '-') { /* left-handed coordinate system? */ p->udir[0] *= -1.; p->udir[1] *= -1.; p->udir[2] *= -1.; } if ((tolower(p->hemis[0]) == 'u') | (p->hemis[0] == '1')) p->sample_basis = sample_uniform; else if (tolower(p->hemis[0]) == 's' && tolower(p->hemis[1]) == 'c') p->sample_basis = sample_shirchiu; else if ((tolower(p->hemis[0]) == 'r') | (tolower(p->hemis[0]) == 't')) p->sample_basis = sample_reinhart; else if (tolower(p->hemis[0]) == 'k') { switch (p->hemis[1]) { case '1': case '2': case '4': break; case 'f': case 'F': case '\0': p->hemis[1] = '1'; break; case 'h': case 'H': p->hemis[1] = '2'; break; case 'q': case 'Q': p->hemis[1] = '4'; break; default: goto unrecognized; } p->hemis[2] = '\0'; p->sample_basis = sample_klems; } else goto unrecognized; /* return number of bins */ return((*p->sample_basis)(p,0,NULL)); unrecognized: sprintf(errmsg, "unrecognized sender sampling: h=%s", p->hemis); error(USER, errmsg); return(-1); } /* Compute normal and area for polygon */ int finish_polygon(SURF *p) { const int nv = p->nfargs / 3; FVECT e1, e2, vc; int i; memset(p->snrm, 0, sizeof(FVECT)); VSUB(e1, p->farg+3, p->farg); for (i = 2; i < nv; i++) { VSUB(e2, p->farg+3*i, p->farg); VCROSS(vc, e1, e2); p->snrm[0] += vc[0]; p->snrm[1] += vc[1]; p->snrm[2] += vc[2]; VCOPY(e1, e2); } p->area = normalize(p->snrm)*0.5; return(p->area > FTINY*FTINY); } /* Add a surface to our current parameters */ void add_surface(int st, const char *oname, FILE *fp) { SURF *snew; int n; /* get floating-point arguments */ if (!fscanf(fp, "%d", &n)) return; while (n-- > 0) fscanf(fp, "%*s"); if (!fscanf(fp, "%d", &n)) return; while (n-- > 0) fscanf(fp, "%*d"); if (!fscanf(fp, "%d", &n) || n <= 0) return; snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1)); if (snew == NULL) error(SYSTEM, "out of memory in add_surface()"); strncpy(snew->sname, oname, sizeof(snew->sname)-1); snew->sname[sizeof(snew->sname)-1] = '\0'; snew->styp = st; snew->priv = NULL; snew->nfargs = n; for (n = 0; n < snew->nfargs; n++) if (fscanf(fp, "%lf", &snew->farg[n]) != 1) { sprintf(errmsg, "error reading arguments for '%s'", oname); error(USER, errmsg); } switch (st) { case ST_RING: if (snew->nfargs != 8) goto badcount; VCOPY(snew->snrm, snew->farg+3); if (normalize(snew->snrm) == 0) goto badnorm; if (snew->farg[7] < snew->farg[6]) { double t = snew->farg[7]; snew->farg[7] = snew->farg[6]; snew->farg[6] = t; } snew->area = PI*(snew->farg[7]*snew->farg[7] - snew->farg[6]*snew->farg[6]); break; case ST_POLY: if (snew->nfargs < 9 || snew->nfargs % 3) goto badcount; finish_polygon(snew); break; case ST_SOURCE: if (snew->nfargs != 4) goto badcount; for (n = 3; n--; ) /* need to reverse "normal" */ snew->snrm[n] = -snew->farg[n]; if (normalize(snew->snrm) == 0) goto badnorm; snew->area = sin((PI/180./2.)*snew->farg[3]); snew->area *= PI*snew->area; break; } if (snew->area <= FTINY*FTINY) { sprintf(errmsg, "zero area for surface '%s'", oname); error(WARNING, errmsg); free(snew); return; } VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area); snew->next = curparams.slist; curparams.slist = snew; curparams.nsurfs++; return; badcount: sprintf(errmsg, "bad argument count for surface element '%s'", oname); error(USER, errmsg); badnorm: sprintf(errmsg, "bad orientation for surface element '%s'", oname); error(USER, errmsg); } /* Parse a receiver object (look for modifiers to add) */ int add_recv_object(FILE *fp) { int st; char thismod[128], otype[32], oname[128]; int n; if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3) return(0); /* must have hit EOF! */ if (!strcmp(otype, "alias")) { fscanf(fp, "%*s"); /* skip alias */ return(0); } /* is it a new receiver? */ if ((st = surf_type(otype)) != ST_NONE) { if (strcmp(thismod, curmod)) { if (curmod[0]) /* output last receiver? */ finish_receiver(); parse_params(&curparams, newparams); newparams[0] = '\0'; strcpy(curmod, thismod); } add_surface(st, oname, fp); /* read & store surface */ return(1); } /* else skip arguments */ if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*s"); if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*d"); if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*f"); return(0); } /* Parse a sender object */ int add_send_object(FILE *fp) { int st; char thismod[128], otype[32], oname[128]; int n; if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3) return(0); /* must have hit EOF! */ if (!strcmp(otype, "alias")) { fscanf(fp, "%*s"); /* skip alias */ return(0); } /* is it a new surface? */ if ((st = surf_type(otype)) != ST_NONE) { if (st == ST_SOURCE) { error(USER, "cannot use source as a sender"); return(-1); } if (strcmp(thismod, curmod)) { if (curmod[0]) error(WARNING, "multiple modifiers in sender"); strcpy(curmod, thismod); } parse_params(&curparams, newparams); newparams[0] = '\0'; add_surface(st, oname, fp); /* read & store surface */ return(0); } /* else skip arguments */ if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*s"); if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*d"); if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*f"); return(0); } /* Load a Radiance scene using the given callback function for objects */ int load_scene(const char *inspec, int (*ocb)(FILE *)) { int rv = 0; char inpbuf[1024]; FILE *fp; int c; if (*inspec == '!') fp = popen(inspec+1, "r"); else fp = fopen(inspec, "r"); if (fp == NULL) { sprintf(errmsg, "cannot load '%s'", inspec); error(SYSTEM, errmsg); return(-1); } while ((c = getc(fp)) != EOF) { /* load sender/receiver data */ if (isspace(c)) /* skip leading white space */ continue; if (c == '!') { /* read from a new command */ inpbuf[0] = c; if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) { if ((c = load_scene(inpbuf, ocb)) < 0) return(c); rv += c; } continue; } if (c == '#') { /* parameters/comment */ if ((c = getc(fp)) == EOF) break; if (c == '@' && fscanf(fp, "%s", inpbuf) == 1 && (!strcmp(inpbuf, PARAMSNAME) || !strcmp(inpbuf, progname))) { if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL) strlcat(newparams, inpbuf, sizeof(newparams)); continue; } while (c != '\n' && (c = getc(fp)) != EOF) ; /* ...skipping comment */ continue; } ungetc(c, fp); /* else check object for receiver */ c = (*ocb)(fp); if (c < 0) return(c); rv += c; } /* close our input stream */ c = (*inspec == '!') ? pclose(fp) : fclose(fp); if (c != 0) { sprintf(errmsg, "error loading '%s'", inspec); error(SYSTEM, errmsg); return(-1); } return(rv); } void wputs( /* warning output function */ const char *s ) { if (erract[WARNING].pf == NULL) return; int lasterrno = errno; eputs(s); errno = lasterrno; } void eputs( /* put string to stderr */ const char *s ) { static int midline = 0; if (!*s) return; if (!midline++) { fputs(progname, stderr); fputs(": ", stderr); } fputs(s, stderr); if (s[strlen(s)-1] == '\n') { fflush(stderr); midline = 0; } } /* set input/output format */ void setformat(const char *fmt) { switch (fmt[0]) { case 'f': case 'd': SET_FILE_BINARY(stdin); /* fall through */ case 'a': inpfmt = fmt[0]; break; case 'c': if (fmt[1]) goto fmterr; outfmt = fmt[0]; // special case for output-only return; default: goto fmterr; } switch (fmt[1]) { case '\0': if (inpfmt == 'a') goto fmterr; outfmt = inpfmt; return; case 'f': case 'd': case 'c': outfmt = fmt[1]; break; default: goto fmterr; } if (!fmt[2]) return; fmterr: sprintf(errmsg, "unsupported i/o format: -f%s", fmt); error(USER, errmsg); } inline double pixjitter() { return(0.5 + dstrpix*(frandom()-0.5)); } // Compute a set of view rays for the given pixel accumulator bool viewRays(FVECT orig_dir[], int x, int y) { for (int n = 0; n < myRCmanager.accum; orig_dir += 2, n++) { const double d = viewray(orig_dir[0], orig_dir[1], &ourview, (x+pixjitter())/myRCmanager.xres, (y+pixjitter())/myRCmanager.yres); // off-view sample? if (d < -FTINY || !jitteraperture(orig_dir[0], orig_dir[1], &ourview, dblur)) memset(orig_dir+1, 0, sizeof(FVECT)); else // else record distance to aft plane for (int i = 3*(d > FTINY); i--; ) orig_dir[1][i] *= d; // accumulating identical samples? if (!n && (dstrpix <= 0.05) & (dblur <= FTINY)) { while (++n < myRCmanager.accum) memcpy(orig_dir[2*n], orig_dir[0], sizeof(FVECT)*2); break; } } return true; } // Load a set of rays for accumulation (do not normalize direction) int getRays(FVECT orig_dir[]) { int n; // read directly if possible if (inpfmt == "_fd"[sizeof(RREAL)/sizeof(float)]) return(getbinary(orig_dir[0], sizeof(FVECT)*2, myRCmanager.accum, stdin)); for (n = 0; n < myRCmanager.accum; orig_dir += 2, n++) { switch (inpfmt) { #ifdef SMLFLT case 'd': { double dvin[6]; if (getbinary(dvin, sizeof(dvin), 1, stdin) != 1) break; for (int i = 6; i--; ) orig_dir[0][i] = dvin[i]; } continue; #else case 'f': { float fvin[6]; if (getbinary(fvin, sizeof(fvin), 1, stdin) != 1) break; for (int i = 6; i--; ) orig_dir[0][i] = fvin[i]; } continue; #endif case 'a': if (scanf(FVFORMAT, &orig_dir[0][0], &orig_dir[0][1], &orig_dir[0][2]) != 3) break; if (scanf(FVFORMAT, &orig_dir[1][0], &orig_dir[1][1], &orig_dir[1][2]) != 3) break; continue; } break; } return(n); } /* Set default options */ void default_options() { rand_samp = 1; dstrsrc = 0.9; directrelay = 3; vspretest = 512; srcsizerat = .2; specthresh = .02; specjitter = 1.; maxdepth = -10; minweight = 2e-3; ambres = 256; ambdiv = 350; ambounce = 1; } /* Set overriding options */ void override_options() { shadthresh = 0; ambssamp = 0; ambacc = 0; } void onsig( /* fatal signal */ int signo ) { static int gotsig = 0; if (gotsig++) /* two signals and we're gone! */ _exit(signo); #ifdef SIGALRM alarm(600); /* allow 10 minutes to clean up */ signal(SIGALRM, SIG_DFL); /* make certain we do die */ #endif eputs("signal - "); eputs(sigerr[signo]); eputs("\n"); quit(3); } void sigdie( /* set fatal signal */ int signo, const char *msg ) { if (signal(signo, onsig) == SIG_IGN) signal(signo, SIG_IGN); sigerr[signo] = msg; } /* Run rfluxmtx equivalent without leaning on r[x]contrib */ int main(int argc, char *argv[]) { #define check(ol,al) if (argv[a][ol] || \ badarg(argc-a-1,argv+a+1,al)) \ goto userr #define check_bool(olen,var) switch (argv[a][olen]) { \ case '\0': var = !var; break; \ case 'y': case 'Y': case 't': case 'T': \ case '+': case '1': var = 1; break; \ case 'n': case 'N': case 'f': case 'F': \ case '-': case '0': var = 0; break; \ default: goto userr; } bool gotView = false; double pixaspect = 1.; int nproc = 1; int nout = 0; char *outfn = NULL; FVECT *rayarr = NULL; const char *sendfn = ""; PARAMS sendparams; int rval; int a, i; /* set global progname */ fixargv0(argv[0]); // just asking version? if (argc == 2 && !strcmp(argv[1], "-version")) { puts(VersionID); quit(0); } initfunc(); /* initialize calcomp routines first */ calcontext(RCCONTEXT); /* set rcontrib defaults */ default_options(); /* get command-line options */ for (a = 1; a < argc-2; a++) { /* check for argument expansion */ while ((rval = expandarg(&argc, &argv, a)) > 0) ; if (rval < 0) { sprintf(errmsg, "cannot expand '%s'", argv[a]); error(SYSTEM, errmsg); } if (argv[a][0] != '-' || !argv[a][1]) break; // break from options rval = getrenderopt(argc-a, argv+a); if (rval >= 0) { a += rval; continue; } rval = getviewopt(&ourview, argc-a, argv+a); if (rval >= 0) { a += rval; gotView = true; continue; } switch (argv[a][1]) { /* !! Keep consistent !! */ case 'W': /* verbose mode */ check_bool(2,verby); break; case 'v': // view file if (argv[a][2] != 'f') goto userr; check(3,"s"); rval = viewfile(argv[++a], &ourview, NULL); if (rval < 0) { sprintf(errmsg, "cannot open view file '%s'", argv[a]); error(SYSTEM, errmsg); } else if (!rval) { sprintf(errmsg, "bad view file '%s'", argv[a]); error(USER, errmsg); } gotView = true; break; case 'p': // -pj, -pd, or -pa switch (argv[a][2]) { case 'j': /* jitter */ check(3,"f"); dstrpix = atof(argv[++a]); break; case 'd': /* aperture */ check(3,"f"); dblur = atof(argv[++a]); break; case 'a': /* aspect */ check(3,"f"); pixaspect = atof(argv[++a]); break; default: goto userr; } break; case 'n': /* number of processes */ check(2,"i"); nproc = atoi(argv[++a]); if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0) nproc = 1; break; case 'V': /* output contributions? */ rval = myRCmanager.HasFlag(RCcontrib); check_bool(2,rval); myRCmanager.SetFlag(RCcontrib, rval); break; case 'x': /* x resolution */ check(2,"i"); myRCmanager.xres = atoi(argv[++a]); break; case 'y': /* y resolution */ check(2,"i"); myRCmanager.yres = atoi(argv[++a]); break; case 'w': /* warnings on/off */ rval = (erract[WARNING].pf != NULL); check_bool(2,rval); if (rval) erract[WARNING].pf = wputs; else erract[WARNING].pf = NULL; break; case 'l': /* limit distance */ if (argv[a][2] != 'd') goto userr; rval = myRCmanager.HasFlag(RTlimDist); check_bool(3,rval); myRCmanager.SetFlag(RTlimDist, rval); break; case 'I': /* immed. irradiance */ rval = myRCmanager.HasFlag(RTimmIrrad); check_bool(2,rval); myRCmanager.SetFlag(RTimmIrrad, rval); break; case 'f': /* format */ if (argv[a][2] == 'o') goto userr; /* -fo is not optional */ setformat(argv[a]+2); myRCmanager.SetDataFormat(outfmt); break; case 'o': /* output file */ check(2,"s"); outfn = argv[++a]; break; case 'c': /* sample count */ check(2,"i"); myRCmanager.accum = atoi(argv[++a]); break; default: /* anything else is verbotten */ goto userr; } } if (a > argc-2) goto userr; override_options(); /* override critical options */ if (!gotView) sendfn = argv[a++]; else if (argv[a][0] == '-') error(USER, "view specification incompatible with pass-through mode"); /* assign sender & receiver inputs */ if (gotView) { // picture output? const char * err = setview(&ourview); if (err != NULL) error(USER, err); normaspect(viewaspect(&ourview), &pixaspect, &myRCmanager.xres, &myRCmanager.yres); if ((myRCmanager.xres <= 0) | (myRCmanager.yres <= 0)) error(USER, "missing or illegal -x and -y resolution"); myRCmanager.SetFlag(RTlimDist, ourview.vaft > FTINY); if (myRCmanager.accum <= 0) myRCmanager.accum = 1; } else if (sendfn[0] == '-') { // pass-through mode? if (sendfn[1]) goto userr; sendfn = NULL; if (myRCmanager.accum <= 0) myRCmanager.accum = 1; } else { // else surface sampling if (do_irrad | myRCmanager.HasFlag(RTimmIrrad)) error(USER, "-i, -I not allowed in surface-sampling mode"); myRCmanager.SetFlag(RTlimDist, false); if (load_scene(sendfn, add_send_object) < 0) quit(1); sendparams = curparams; // save sender params & clear current memset(&curparams, 0, sizeof(PARAMS)); curmod[0] = '\0'; myRCmanager.yres = prepare_sampler(&sendparams); if (myRCmanager.yres <= 0) quit(1); myRCmanager.xres = 0; if (myRCmanager.accum <= 1) myRCmanager.accum = 10000; } if (outfn != NULL) // saved from -o option above? strlcpy(curparams.outfn, outfn, sizeof(curparams.outfn)); // get ready to rock... if (setspectrsamp(CNDX, WLPART) < 0) error(USER, "unsupported spectral sampling"); /* set up signal handling */ sigdie(SIGINT, "Interrupt"); #ifdef SIGHUP sigdie(SIGHUP, "Hangup"); #endif sigdie(SIGTERM, "Terminate"); #ifdef SIGPIPE sigdie(SIGPIPE, "Broken pipe"); #endif #ifdef SIGALRM sigdie(SIGALRM, "Alarm clock"); #endif #ifdef SIGXCPU sigdie(SIGXCPU, "CPU limit exceeded"); sigdie(SIGXFSZ, "File size exceeded"); #endif #ifdef NICE nice(NICE); /* lower priority */ #endif rayarr = new FVECT [myRCmanager.accum*2]; // load octree if (!myRCmanager.LoadOctree(oconv_command(argc-a, argv+a))) quit(1); // add to header myRCmanager.AddHeader(argc, argv); { char buf[128] = "SOFTWARE= "; strcpy(buf+10, VersionID); myRCmanager.AddHeader(buf); if (gotView) { sprintf(buf, "%s%s", VIEWSTR, viewopt(&ourview)); if (strlen(buf) > VIEWSTRL+3) myRCmanager.AddHeader(buf); } if ((pixaspect > .005) && (pixaspect < .995) | (pixaspect > 1.005)) { sprintf(buf, "%s%f", ASPECTSTR, pixaspect); myRCmanager.AddHeader(buf); } } /* assign receiver modifiers */ if (load_scene(argv[a], add_recv_object) < 0) quit(1); finish_receiver(); // makes final AddModifier() call // prepare output(s) myRCmanager.outOp = RCOforce; // mandatory rcontrib -fo+ mode if (myRCmanager.PrepOutput() < 0) error(USER, "issue creating output file(s)"); if (verby) // get output file count? for (const RcontribOutput *op = myRCmanager.GetOutput(); op != NULL; op = op->Next()) ++nout; if (nproc > 1) { // set #processes if (verby) fprintf(stderr, "%s: starting %d subprocesses\n", progname, nproc); myRCmanager.SetThreadCount(nproc); } if (gotView) { // picture generation mode? if (verby) { fprintf(stderr, "%s: computing %d %dx%d pictures", progname, nout, myRCmanager.xres, myRCmanager.yres); if (myRCmanager.accum > 1) fprintf(stderr, " with %d samples/pixel\n", myRCmanager.accum); else fputc('\n', stderr); } for (i = myRCmanager.yres; i--; ) // from the top! for (int x = 0; x < myRCmanager.xres; x++) { if (!viewRays(rayarr, x, i)) quit(1); if (myRCmanager.ComputeRecord(rayarr) != myRCmanager.accum) error(USER, "failed call to ComputeRecord()"); } } else if (sendfn == NULL) { // pass-through mode? #ifdef getc_unlocked flockfile(stdin); #endif if (verby) fprintf(stderr, "%s: computing %d rows in %d matrices with %d samples/row\n", progname, myRCmanager.GetRowMax(), nout, myRCmanager.accum); for (i = myRCmanager.GetRowMax(); i-- > 0; ) { if (getRays(rayarr) != myRCmanager.accum) { sprintf(errmsg, "ray read error after %d of %d", myRCmanager.GetRowCount(), myRCmanager.GetRowMax()); error(USER, errmsg); } if (myRCmanager.ComputeRecord(rayarr) != myRCmanager.accum) error(USER, "failed call to ComputeRecord()"); } } else { // else surface-sampling mode if (verby) { fprintf(stderr, "%s: sampling %d directions in %d matrices with %d samples/direction", progname, myRCmanager.yres, nout, myRCmanager.accum); if (sendparams.nsurfs > 1) fprintf(stderr, " (%d surface elements)\n", sendparams.nsurfs); else fputc('\n', stderr); } for (i = 0; i < myRCmanager.yres; i++) { if (!(*sendparams.sample_basis)(&sendparams, i, rayarr)) quit(1); if (myRCmanager.ComputeRecord(rayarr) != myRCmanager.accum) error(USER, "failed call to ComputeRecord()"); } clear_params(&sendparams); } delete [] rayarr; quit(0); /* flushes and waits on children */ userr: if (a < argc-2) fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]); fprintf(stderr, "Usage: %s [-W] [rxcontrib options] { sender.rad | view | - } receiver.rad [-i system.oct] [system.rad ..]\n", progname); quit(1); } /* Exit program */ void quit( int code ) { myRCmanager.FlushQueue(); // leave nothing in queue exit(code); }
