root/radiance/ray/src/rt/rxcmain.cpp
Thu Jun 5 18:26:46 2025 UTC (2 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.17: +1 -3 lines
Diff to previous 2.17 , to selected 2.6
fix: Removed unnecessary or redundant progname declarations
Tue Apr 22 17:12:25 2025 UTC (3 months, 3 weeks ago) by greg
Changes since 2.16: +2 -11 lines
Diff to previous 2.16 , to selected 2.6
Wed Mar 5 17:29:57 2025 UTC (5 months, 1 week ago) by greg
Changes since 2.15: +6 -1 lines
feat(rxcontrib): Added SOFTWARE= line to header output
Thu Jan 2 20:19:48 2025 UTC (7 months, 1 week ago) by greg
Changes since 2.14: +2 -3 lines
perf(rxpiece,rxcontrib): Don't bother to free data structs on exit
Thu Jan 2 16:16:49 2025 UTC (7 months, 1 week ago) by greg
Changes since 2.13: +3 -4 lines
fix(rxtrace,rxcontrib): Improvements and bug fixes in flag initialization, handling of light source tracing
Tue Dec 24 16:58:13 2024 UTC (7 months, 2 weeks ago) by greg
Changes since 2.12: +5 -5 lines
fix(rxcontrib): Correct final time reporting
Mon Dec 23 18:14:20 2024 UTC (7 months, 2 weeks ago) by greg
Changes since 2.11: +7 -6 lines
fix(rxcontrib): Wait until everything is done before reporting 100%
Mon Dec 23 16:15:38 2024 UTC (7 months, 3 weeks ago) by greg
Changes since 2.10: +8 -9 lines
fix(rxcontrib): Memory overwrites with -fd format
Fri Dec 13 21:12:40 2024 UTC (8 months ago) by greg
Changes since 2.9: +20 -2 lines
fix(rxcontrib): Assign default options to match those of rcontrib
Tue Dec 3 17:39:42 2024 UTC (8 months, 1 week ago) by greg
Changes since 2.8: +1 -13 lines
refactor(rxcontrib): Moved definition of formstr() to make it more accessible
Thu Nov 7 20:56:09 2024 UTC (9 months ago) by greg
Changes since 2.7: +9 -5 lines
fix(rxcontrib): Improved progress reporting accuracy
Thu Nov 7 18:09:39 2024 UTC (9 months ago) by greg
fix(rxcontrib): Added missing newlines from -defaults output
Wed Nov 6 19:45:59 2024 UTC (9 months, 1 week ago) by greg
Changes since 2.5: +12 -9 lines
feat(rxcontrib): Folded resolution and contrib flag into main class
Wed Oct 30 19:53:37 2024 UTC (9 months, 2 weeks ago) by greg
fix(rxcontrib): error-check on ComputRecord() return was off
Wed Oct 30 17:26:13 2024 UTC (9 months, 2 weeks ago) by greg
Changes since 2.3: +2 -4 lines
fix(rcontrib,rxcontrib): reinstated .cal redefinition warnings
Wed Oct 30 02:22:23 2024 UTC (9 months, 2 weeks ago) by greg
Changes since 2.2: +4 -1 lines
fix(rcontrib,rxcontrib): Eliminated spurious warning messages
Tue Oct 29 19:47:19 2024 UTC (9 months, 2 weeks ago) by greg
Changes since 2.1: +25 -28 lines
fix(rxcontrib): Fixed handling of -ld and -I command-line flags
Tue Oct 29 00:36:54 2024 UTC (9 months, 2 weeks ago) by greg
Diff to selected 2.6
feat(rxcontrib): First compiled version of rxcontrib tool to test new C++ classes
