--- ray/src/rt/rxcmain.cpp 2024/10/29 00:36:54 2.1 +++ ray/src/rt/rxcmain.cpp 2024/10/29 19:47:19 2.2 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rxcmain.cpp,v 2.1 2024/10/29 00:36:54 greg Exp $"; +static const char RCSid[] = "$Id: rxcmain.cpp,v 2.2 2024/10/29 19:47:19 greg Exp $"; #endif /* * rxcmain.c - main for rxcontrib ray contribution tracer @@ -21,14 +21,6 @@ int nproc = 1; /* number of processes requested */ int inpfmt = 'a'; /* input format */ int outfmt = 'f'; /* output format */ -int contrib = 0; /* computing contributions? */ - -int xres = 0; /* horizontal (scan) size */ -int yres = 0; /* vertical resolution */ - -int imm_irrad = 0; /* compute immediate irradiance? */ -int lim_dist = 0; /* limit distance? */ - int report_intvl = 0; /* reporting interval (seconds) */ extern char * progname; // global argv[0] @@ -38,7 +30,7 @@ RcontribSimulManager myRCmanager; // global rcontrib s #define RCONTRIB_FEATURES "Multiprocessing\n" \ "Accumulation\nRecovery\n" \ "ImmediateIrradiance\n" \ - "ProgressReporting?\nDistanceLimiting\n" \ + "ProgressReporting\nDistanceLimiting\n" \ "InputFormats=a,f,d\nOutputFormats=f,d,c\n" \ "Outputs=V,W\n" \ "OutputCS=RGB,spec\n" @@ -51,13 +43,14 @@ printdefaults(void) /* print default values to stdou printf("-c %-5d\t\t\t# accumulated rays per record\n", myRCmanager.accum); printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-', contrib ? "contributions" : "coefficients"); - if (imm_irrad) + if (myRCmanager.HasFlag(RTimmIrrad)) printf("-I+\t\t\t\t# immediate irradiance on\n"); printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); if (xres > 0) printf("-x %-9d\t\t\t# x resolution\n", xres); printf("-y %-9d\t\t\t# y resolution\n", yres); - printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : + printf(myRCmanager.HasFlag(RTlimDist) ? + "-ld+\t\t\t\t# limit distance on\n" : "-ld-\t\t\t\t# limit distance off\n"); printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", inpfmt, outfmt, formstr(inpfmt), formstr(outfmt)); @@ -218,13 +211,13 @@ main(int argc, char *argv[]) continue; } switch (argv[i][1]) { - case 'n': /* number of cores */ + case 'n': /* number of processes */ check(2,"i"); nproc = atoi(argv[++i]); if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0) nproc = 1; break; - case 'V': /* output contributions */ + case 'V': /* output contributions? */ check_bool(2,contrib); break; case 'x': /* x resolution */ @@ -235,25 +228,29 @@ main(int argc, char *argv[]) check(2,"i"); yres = atoi(argv[++i]); break; - case 'w': /* warnings */ + case 'w': /* warnings on/off */ rval = (erract[WARNING].pf != NULL); check_bool(2,rval); if (rval) erract[WARNING].pf = wputs; else erract[WARNING].pf = NULL; break; - case 'e': /* expression */ + case 'e': /* .cal expression */ check(2,"s"); scompile(argv[++i], NULL, 0); break; case 'l': /* limit distance */ if (argv[i][2] != 'd') goto badopt; - check_bool(3,lim_dist); + rval = myRCmanager.HasFlag(RTlimDist); + check_bool(3,rval); + myRCmanager.SetFlag(RTlimDist, rval); break; case 'I': /* immed. irradiance */ - check_bool(2,imm_irrad); + rval = myRCmanager.HasFlag(RTimmIrrad); + check_bool(2,rval); + myRCmanager.SetFlag(RTimmIrrad, rval); break; - case 'f': /* file or force or format */ + case 'f': /* .cal file or force or format */ if (!argv[i][2]) { check(2,"s"); loadfunc(argv[++i]); @@ -266,7 +263,7 @@ main(int argc, char *argv[]) setformat(argv[i]+2); myRCmanager.SetDataFormat(outfmt); break; - case 'o': /* output */ + case 'o': /* output file */ check(2,"s"); curout = argv[++i]; break; @@ -294,7 +291,7 @@ main(int argc, char *argv[]) check(2,"s"); myRCmanager.AddModifier(argv[++i], curout, prms, binval, bincnt); break; - case 'M': /* modifier file */ + case 'M': /* file of modifier names */ check(2,"s"); myRCmanager.AddModFile(argv[++i], curout, prms, binval, bincnt); break; @@ -308,14 +305,14 @@ main(int argc, char *argv[]) } if (i != argc-1) error(USER, "expected single octree argument"); + + override_options(); /* override some option settings */ + + if (!myRCmanager.GetOutput()) // check that we have work to do + error(USER, "missing required modifier argument"); // get ready to rock... if (setspectrsamp(CNDX, WLPART) < 0) error(USER, "unsupported spectral sampling"); - - if (!myRCmanager.GetOutputs(NULL)) // check that we're ready - error(USER, "missing required modifier argument"); - /* override some option settings */ - override_options(); /* set up signal handling */ sigdie(SIGINT, "Interrupt"); #ifdef SIGHUP @@ -348,7 +345,7 @@ main(int argc, char *argv[]) myRCmanager.outOp = RCOnew; // rval = # rows recovered rval = myRCmanager.PrepOutput(); - // check if all done + // check if recovered everything if (recover && rval >= myRCmanager.GetRowMax()) { error(WARNING, "nothing left to compute"); quit(0); @@ -551,7 +548,7 @@ eputs( /* put string to stderr */ } -/* Quit program */ +/* Exit program */ void quit( int code
