root/radiance/ray/src/rt/rxcmain.cpp
Revision: 2.9
Committed: Tue Dec 3 17:39:42 2024 UTC (8 months ago) by greg
Changes since 2.8: +1 -13 lines
refactor(rxcontrib): Moved definition of formstr() to make it more accessible
2 static const char RCSid[] = "$Id: rxcmain.cpp,v 2.8 2024/11/07 20:56:09 greg Exp $";
5 * rxcmain.c - main for rxcontrib ray contribution tracer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11 #include <time.h>
12 #include <ctype.h>
13 #include "RcontribSimulManager.h"
14 #include "platform.h"
15 #include "func.h"
16
17 const char *sigerr[NSIG]; /* signal error messages */
18
19 int nproc = 1; /* number of processes requested */
20
21 int inpfmt = 'a'; /* input format */
22 int outfmt = 'f'; /* output format */
23
24 int report_intvl = 0; /* reporting interval (seconds) */
25
26 extern char * progname; // global argv[0]
27
28 RcontribSimulManager myRCmanager; // global rcontrib simulation manager
29
30 #define RCONTRIB_FEATURES "Multiprocessing\n" \
31 "Accumulation\nRecovery\n" \
32 "ImmediateIrradiance\n" \
33 "ProgressReporting\nDistanceLimiting\n" \
34 "InputFormats=a,f,d\nOutputFormats=f,d,c\n" \
35 "Outputs=V,W\n" \
36 "OutputCS=RGB,spec\n"
37
38 static void rxcontrib(const int rstart = 0);
39
40 static void
41 printdefaults(void) /* print default values to stdout */
42 {
43 printf("-c %-5d\t\t\t# accumulated rays per record\n", myRCmanager.accum);
44 printf(myRCmanager.HasFlag(RCcontrib) ?
45 "-V+\t\t\t\t# output contributions\n" :
46 "-V-\t\t\t\t# output coefficients\n");
47 if (myRCmanager.HasFlag(RTimmIrrad))
48 printf("-I+\t\t\t\t# immediate irradiance on\n");
49 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
50 if (myRCmanager.xres > 0)
51 printf("-x %-9d\t\t\t# x resolution\n", myRCmanager.xres);
52 printf("-y %-9d\t\t\t# y resolution\n", myRCmanager.yres);
53 printf(myRCmanager.HasFlag(RTlimDist) ?
54 "-ld+\t\t\t\t# limit distance on\n" :
55 "-ld-\t\t\t\t# limit distance off\n");
56 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
57 inpfmt, outfmt, formstr(inpfmt), formstr(outfmt));
58 if (report_intvl > 0)
59 printf("-t %-9d\t\t\t# time between reports\n", report_intvl);
60 printf(erract[WARNING].pf != NULL ?
61 "-w+\t\t\t\t# warning messages on\n" :
62 "-w-\t\t\t\t# warning messages off\n");
63 print_rdefaults();
64 }
65
66
67 static void
68 onsig( /* fatal signal */
69 int signo
70 )
71 {
72 static int gotsig = 0;
73
74 if (gotsig++) /* two signals and we're gone! */
75 _exit(signo);
76
77 #ifdef SIGALRM
78 alarm(180); /* allow 3 minutes to clean up */
79 signal(SIGALRM, SIG_DFL); /* make certain we do die */
80 #endif
81 eputs("signal - ");
82 eputs(sigerr[signo]);
83 eputs("\n");
84 quit(3);
85 }
86
87
88 static void
89 sigdie( /* set fatal signal */
90 int signo,
91 const char *msg
92 )
93 {
94 if (signal(signo, onsig) == SIG_IGN)
95 signal(signo, SIG_IGN);
96 sigerr[signo] = msg;
97 }
98
99 /* set input/output format */
100 static void
101 setformat(const char *fmt)
102 {
103 switch (fmt[0]) {
104 case 'f':
105 case 'd':
106 SET_FILE_BINARY(stdin);
107 /* fall through */
108 case 'a':
109 inpfmt = fmt[0];
110 break;
111 default:
112 goto fmterr;
113 }
114 switch (fmt[1]) {
115 case '\0':
116 if (inpfmt == 'a')
117 goto fmterr;
118 outfmt = inpfmt;
119 return;
120 case 'f':
121 case 'd':
122 case 'c':
123 outfmt = fmt[1];
124 break;
125 default:
126 goto fmterr;
127 }
128 if (!fmt[2])
129 return;
130 fmterr:
131 sprintf(errmsg, "Unsupported i/o format: -f%s", fmt);
132 error(USER, errmsg);
133 }
134
135
136 /* Set overriding options */
137 static void
138 override_options(void)
139 {
140 shadthresh = 0;
141 ambssamp = 0;
142 ambacc = 0;
143 }
144
145
146 int
147 main(int argc, char *argv[])
148 {
149 #define check(ol,al) if (argv[i][ol] || \
150 badarg(argc-i-1,argv+i+1,al)) \
151 goto badopt
152 #define check_bool(olen,var) switch (argv[i][olen]) { \
153 case '\0': var = !var; break; \
154 case 'y': case 'Y': case 't': case 'T': \
155 case '+': case '1': var = 1; break; \
156 case 'n': case 'N': case 'f': case 'F': \
157 case '-': case '0': var = 0; break; \
158 default: goto badopt; }
159 int force_open = 0;
160 int recover = 0;
161 char *curout = NULL;
162 char *prms = NULL;
163 char *binval = NULL;
164 int bincnt = 0;
165 int rval;
166 int i;
167 /* global program name */
168 progname = argv[0];
169 /* feature check only? */
170 strcat(RFeatureList, RCONTRIB_FEATURES);
171 if (argc > 1 && !strcmp(argv[1], "-features"))
172 return feature_status(argc-2, argv+2);
173 /* initialize calcomp routines early */
174 initfunc();
175 calcontext(RCCONTEXT);
176 /* option city */
177 for (i = 1; i < argc; i++) {
178 /* expand arguments */
179 while ((rval = expandarg(&argc, &argv, i)) > 0)
180 ;
181 if (rval < 0) {
182 sprintf(errmsg, "cannot expand '%s'", argv[i]);
183 error(SYSTEM, errmsg);
184 }
185 if (argv[i] == NULL || argv[i][0] != '-')
186 break; /* break from options */
187 if (!strcmp(argv[i], "-version")) {
188 puts(VersionID);
189 quit(0);
190 }
191 if (!strcmp(argv[i], "-defaults") ||
192 !strcmp(argv[i], "-help")) {
193 override_options();
194 printdefaults();
195 quit(0);
196 }
197 rval = getrenderopt(argc-i, argv+i);
198 if (rval >= 0) {
199 i += rval;
200 continue;
201 }
202 switch (argv[i][1]) {
203 case 'n': /* number of processes */
204 check(2,"i");
205 nproc = atoi(argv[++i]);
206 if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0)
207 nproc = 1;
208 break;
209 case 'V': /* output contributions? */
210 rval = myRCmanager.HasFlag(RCcontrib);
211 check_bool(2,rval);
212 myRCmanager.SetFlag(RCcontrib, rval);
213 break;
214 case 'x': /* x resolution */
215 check(2,"i");
216 myRCmanager.xres = atoi(argv[++i]);
217 break;
218 case 'y': /* y resolution */
219 check(2,"i");
220 myRCmanager.yres = atoi(argv[++i]);
221 break;
222 case 'w': /* warnings on/off */
223 rval = (erract[WARNING].pf != NULL);
224 check_bool(2,rval);
225 if (rval) erract[WARNING].pf = wputs;
226 else erract[WARNING].pf = NULL;
227 break;
228 case 'e': /* .cal expression */
229 check(2,"s");
230 scompile(argv[++i], NULL, 0);
231 break;
232 case 'l': /* limit distance */
233 if (argv[i][2] != 'd')
234 goto badopt;
235 rval = myRCmanager.HasFlag(RTlimDist);
236 check_bool(3,rval);
237 myRCmanager.SetFlag(RTlimDist, rval);
238 break;
239 case 'I': /* immed. irradiance */
240 rval = myRCmanager.HasFlag(RTimmIrrad);
241 check_bool(2,rval);
242 myRCmanager.SetFlag(RTimmIrrad, rval);
243 break;
244 case 'f': /* .cal file or force or format */
245 if (!argv[i][2]) {
246 check(2,"s");
247 loadfunc(argv[++i]);
248 break;
249 }
250 if (argv[i][2] == 'o') {
251 check_bool(3,force_open);
252 break;
253 }
254 setformat(argv[i]+2);
255 myRCmanager.SetDataFormat(outfmt);
256 break;
257 case 'o': /* output file */
258 check(2,"s");
259 curout = argv[++i];
260 break;
261 case 'r': /* recover output */
262 check_bool(2,recover);
263 break;
264 case 'p': /* parameter setting(s) */
265 check(2,"s");
266 set_eparams(prms = argv[++i]);
267 break;
268 case 'c': /* sample count */
269 check(2,"i");
270 myRCmanager.accum = atoi(argv[++i]);
271 break;
272 case 'b': /* bin expression/count */
273 if (argv[i][2] == 'n') {
274 check(3,"s");
275 bincnt = (int)(eval(argv[++i]) + .5);
276 break;
277 }
278 check(2,"s");
279 binval = argv[++i];
280 break;
281 case 'm': /* modifier name */
282 check(2,"s");
283 myRCmanager.AddModifier(argv[++i], curout, prms, binval, bincnt);
284 break;
285 case 'M': /* file of modifier names */
286 check(2,"s");
287 myRCmanager.AddModFile(argv[++i], curout, prms, binval, bincnt);
288 break;
289 case 't': /* reporting interval */
290 check(2,"i");
291 report_intvl = atoi(argv[++i]);
292 break;
293 default:
294 goto badopt;
295 }
296 }
297 if (i != argc-1)
298 error(USER, "expected single octree argument");
299
300 override_options(); /* override some option settings */
301
302 if (!myRCmanager.GetOutput()) // check that we have work to do
303 error(USER, "missing required modifier argument");
304 // get ready to rock...
305 if (setspectrsamp(CNDX, WLPART) < 0)
306 error(USER, "unsupported spectral sampling");
307 /* set up signal handling */
308 sigdie(SIGINT, "Interrupt");
309 #ifdef SIGHUP
310 sigdie(SIGHUP, "Hangup");
311 #endif
312 sigdie(SIGTERM, "Terminate");
313 #ifdef SIGPIPE
314 sigdie(SIGPIPE, "Broken pipe");
315 #endif
316 #ifdef SIGALRM
317 sigdie(SIGALRM, "Alarm clock");
318 #endif
319 #ifdef SIGXCPU
320 sigdie(SIGXCPU, "CPU limit exceeded");
321 sigdie(SIGXFSZ, "File size exceeded");
322 #endif
323 #ifdef NICE
324 nice(NICE); /* lower priority */
325 #endif
326 // load octree
327 myRCmanager.LoadOctree(argv[argc-1]);
328 // add to header
329 myRCmanager.AddHeader(argc-1, argv);
330 // prepare output files
331 if (recover)
332 myRCmanager.outOp = RCOrecover;
333 else if (force_open)
334 myRCmanager.outOp = RCOforce;
335 else
336 myRCmanager.outOp = RCOnew;
337 // rval = # rows recovered
338 rval = myRCmanager.PrepOutput();
339 // check if recovered everything
340 if (rval >= myRCmanager.GetRowMax()) {
341 error(WARNING, "nothing left to compute");
342 quit(0);
343 } // add processes as requested
344 myRCmanager.SetThreadCount(nproc);
345
346 rxcontrib(rval); /* trace ray contributions (loop) */
347
348 quit(0); /* exit clean */
349
350 badopt:
351 fprintf(stderr,
352 "Usage: %s [-V][-c count][-r][-e expr][-f source][-o ospec][-p p1=V1,p2=V2][-b binv][-bn N] {-m mod | -M file} [rtrace options] octree\n",
353 progname);
354 sprintf(errmsg, "command line error at '%s'", argv[i]);
355 error(USER, errmsg);
356 return(1); /* pro forma return */
357
358 #undef check
359 #undef check_bool
360 }
361
362
363 // skip specified number of bytes, return false if EOF
364 static bool
365 skipBytes(int n2skip)
366 {
367 while (n2skip-- > 0)
368 if (getchar() == EOF)
369 return false;
370 return true;
371 }
372
373
374 // skip specified number of whitespace-separated words, return false if EOF
375 static bool
376 skipWords(int n2skip)
377 {
378 int c;
379
380 while (n2skip-- > 0) {
381 do {
382 c = getchar();
383 } while (isspace(c));
384 do {
385 if (c == EOF) return false;
386 c = getchar();
387 } while (!isspace(c));
388 }
389 return true;
390 }
391
392
393 // read a bundle of myRCmanager.accum ray origins and directions
394 static bool
395 getRayBundle(FVECT *orig_dir = NULL)
396 {
397 int n2go = myRCmanager.accum;
398
399 switch (inpfmt) {
400 case 'a': // ASCII input
401 if (!orig_dir)
402 return skipWords(6*n2go);
403 while (n2go-- > 0) {
404 if (scanf(FVFORMAT, &orig_dir[0][0],
405 &orig_dir[0][1], &orig_dir[0][2]) != 3)
406 return false;
407 if (scanf(FVFORMAT, &orig_dir[1][0],
408 &orig_dir[1][1], &orig_dir[1][2]) != 3)
409 return false;
410 orig_dir += 2;
411 }
412 break;
413 case 'f': // float input
414 if (!orig_dir)
415 return skipBytes(6*sizeof(float)*n2go);
416 #ifdef SMLFLT
417 if (getbinary(orig_dir, sizeof(FVECT), 2*n2go, stdin) != 2*n2go)
418 return false;
419 #else
420 while (n2go-- > 0) {
421 float fvecs[6];
422 if (getbinary(fvecs, sizeof(fvecs), 1, stdin) != 1)
423 return false;
424 for (int i = 6; i--; )
425 orig_dir[0][i] = fvecs[i];
426 orig_dir += 2;
427 }
428 #endif
429 break;
430 case 'd': // double input
431 if (!orig_dir)
432 return skipBytes(6*sizeof(double)*n2go);
433 #ifndef SMLFLT
434 if (getbinary(orig_dir, sizeof(FVECT), 2*n2go, stdin) != 2*n2go)
435 return false;
436 #else
437 while (n2go-- > 0) {
438 double dvecs[6];
439 if (getbinary(dvecs, sizeof(dvecs), 1, stdin) != 1)
440 return false;
441 for (int i = 6; i--; )
442 orig_dir[0][i] = dvecs[i];
443 orig_dir += 2;
444 }
445 #endif
446 break;
447 default:
448 error(INTERNAL, "unsupported format in getRayBundle()");
449 return false;
450 }
451 int warned = 0; // normalize directions
452 n2go = myRCmanager.accum;
453 while (n2go-- > 0) {
454 orig_dir -= 2;
455 if (normalize(orig_dir[1]) == 0)
456 if (!warned++)
457 error(WARNING, "zero ray direction on input");
458 }
459 return true;
460 }
461
462
463 // Run loop to load data, report progress, etc.
464 void
465 rxcontrib(const int rstart)
466 {
467 const int totRows = myRCmanager.GetRowMax();
468 FVECT * odarr = (FVECT *)emalloc(sizeof(FVECT)*2*myRCmanager.accum);
469 time_t tstart, last_report;
470 int r = 0;
471
472 while (r < rstart) { // skip input rays already done
473 if (!getRayBundle())
474 goto readerr;
475 r++;
476 }
477 if (report_intvl > 0) { // set up reporting
478 if (r > 0) {
479 sprintf(errmsg, "recovered %.2f%% of total\n",
480 100.*r/totRows);
481 eputs(errmsg);
482 }
483 last_report = tstart = time(0);
484 }
485 while (r < totRows) { // loop until done
486 time_t tnow;
487 if (!getRayBundle(odarr))
488 goto readerr;
489 if (myRCmanager.ComputeRecord(odarr) <= 0)
490 return; // error reported, hopefully...
491 r++;
492 if (report_intvl <= 0)
493 continue;
494 tnow = time(0); // time to report progress?
495 if (r == totRows)
496 myRCmanager.FlushQueue();
497 else if (tnow < last_report+report_intvl)
498 continue;
499 sprintf(errmsg, "%.2f%% done after %.3f hours\n",
500 100.*myRCmanager.GetRowFinished()/totRows,
501 (1./3600.)*(tnow - tstart));
502 eputs(errmsg);
503 last_report = tnow;
504 }
505 efree(odarr);
506 return;
507 readerr:
508 sprintf(errmsg, "unexpected EOF on standard input (record %d of %d)",
509 r, totRows);
510 error(USER, errmsg);
511 }
512
513
514 void
515 wputs( /* warning output function */
516 const char *s
517 )
518 {
519 if (!erract[WARNING].pf) return;
520 int lasterrno = errno;
521 eputs(s);
522 errno = lasterrno;
523 }
524
525
526 void
527 eputs( /* put string to stderr */
528 const char *s
529 )
530 {
531 static int midline = 0;
532
533 if (!*s)
534 return;
535 if (!midline++) {
536 fputs(progname, stderr);
537 fputs(": ", stderr);
538 }
539 fputs(s, stderr);
540 if (s[strlen(s)-1] == '\n') {
541 fflush(stderr);
542 midline = 0;
543 }
544 }
545
546
547 /* Exit program */
548 void
549 quit(
550 int code
551 )
552 {
553 if (!code && myRCmanager.Ready()) // clean up on normal exit
554 code = myRCmanager.Cleanup();
555
556 exit(code);
557 }
