fix: Removed unnecessary or redundant progname declarations
feat(rxcontrib): Added SOFTWARE= line to header output
perf(rxpiece,rxcontrib): Don't bother to free data structs on exit
fix(rxtrace,rxcontrib): Improvements and bug fixes in flag initialization, handling of light source tracing
fix(rxcontrib): Correct final time reporting
fix(rxcontrib): Wait until everything is done before reporting 100%
fix(rxcontrib): Memory overwrites with -fd format
fix(rxcontrib): Assign default options to match those of rcontrib
refactor(rxcontrib): Moved definition of formstr() to make it more accessible
fix(rxcontrib): Improved progress reporting accuracy
fix(rxcontrib): Added missing newlines from -defaults output
feat(rxcontrib): Folded resolution and contrib flag into main class
fix(rxcontrib): error-check on ComputRecord() return was off
fix(rcontrib,rxcontrib): reinstated .cal redefinition warnings
fix(rcontrib,rxcontrib): Eliminated spurious warning messages
fix(rxcontrib): Fixed handling of -ld and -I command-line flags
