root/radiance/ray/src/rt/rxcmain.cpp
Revision: 2.8
Committed: Thu Nov 7 20:56:09 2024 UTC (5 months, 3 weeks ago) by greg
Changes since 2.7: +9 -5 lines
fix(rxcontrib): Improved progress reporting accuracy
2 static const char RCSid[] = "$Id: rxcmain.cpp,v 2.7 2024/11/07 18:09:39 greg Exp $";
5 * rxcmain.c - main for rxcontrib ray contribution tracer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11 #include <time.h>
12 #include <ctype.h>
13 #include "RcontribSimulManager.h"
14 #include "platform.h"
15 #include "func.h"
16
17 const char *sigerr[NSIG]; /* signal error messages */
18
19 int nproc = 1; /* number of processes requested */
20
21 int inpfmt = 'a'; /* input format */
22 int outfmt = 'f'; /* output format */
23
24 int report_intvl = 0; /* reporting interval (seconds) */
25
26 extern char * progname; // global argv[0]
27
28 RcontribSimulManager myRCmanager; // global rcontrib simulation manager
29
30 #define RCONTRIB_FEATURES "Multiprocessing\n" \
31 "Accumulation\nRecovery\n" \
32 "ImmediateIrradiance\n" \
33 "ProgressReporting\nDistanceLimiting\n" \
34 "InputFormats=a,f,d\nOutputFormats=f,d,c\n" \
35 "Outputs=V,W\n" \
36 "OutputCS=RGB,spec\n"
37
38 static void rxcontrib(const int rstart = 0);
39
40 static void
41 printdefaults(void) /* print default values to stdout */
42 {
43 printf("-c %-5d\t\t\t# accumulated rays per record\n", myRCmanager.accum);
44 printf(myRCmanager.HasFlag(RCcontrib) ?
45 "-V+\t\t\t\t# output contributions\n" :
46 "-V-\t\t\t\t# output coefficients\n");
47 if (myRCmanager.HasFlag(RTimmIrrad))
48 printf("-I+\t\t\t\t# immediate irradiance on\n");
49 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
50 if (myRCmanager.xres > 0)
51 printf("-x %-9d\t\t\t# x resolution\n", myRCmanager.xres);
52 printf("-y %-9d\t\t\t# y resolution\n", myRCmanager.yres);
53 printf(myRCmanager.HasFlag(RTlimDist) ?
54 "-ld+\t\t\t\t# limit distance on\n" :
55 "-ld-\t\t\t\t# limit distance off\n");
56 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
57 inpfmt, outfmt, formstr(inpfmt), formstr(outfmt));
58 if (report_intvl > 0)
59 printf("-t %-9d\t\t\t# time between reports\n", report_intvl);
60 printf(erract[WARNING].pf != NULL ?
61 "-w+\t\t\t\t# warning messages on\n" :
62 "-w-\t\t\t\t# warning messages off\n");
63 print_rdefaults();
64 }
65
66
67 static void
68 onsig( /* fatal signal */
69 int signo
70 )
71 {
72 static int gotsig = 0;
73
74 if (gotsig++) /* two signals and we're gone! */
75 _exit(signo);
76
77 #ifdef SIGALRM
78 alarm(180); /* allow 3 minutes to clean up */
79 signal(SIGALRM, SIG_DFL); /* make certain we do die */
80 #endif
81 eputs("signal - ");
82 eputs(sigerr[signo]);
83 eputs("\n");
84 quit(3);
85 }
86
87
88 static void
89 sigdie( /* set fatal signal */
90 int signo,
91 const char *msg
92 )
93 {
94 if (signal(signo, onsig) == SIG_IGN)
95 signal(signo, SIG_IGN);
96 sigerr[signo] = msg;
97 }
98
99 const char *
100 formstr(int f) // return format identifier
101 {
102 switch (f) {
103 case 'a': return("ascii");
104 case 'f': return("float");
105 case 'd': return("double");
106 case 'c': return(NCSAMP==3 ? COLRFMT : SPECFMT);
107 }
108 return("unknown");
109 }
110
111 /* set input/output format */
112 static void
113 setformat(const char *fmt)
114 {
115 switch (fmt[0]) {
116 case 'f':
117 case 'd':
118 SET_FILE_BINARY(stdin);
119 /* fall through */
120 case 'a':
121 inpfmt = fmt[0];
122 break;
123 default:
124 goto fmterr;
125 }
126 switch (fmt[1]) {
127 case '\0':
128 if (inpfmt == 'a')
129 goto fmterr;
130 outfmt = inpfmt;
131 return;
132 case 'f':
133 case 'd':
134 case 'c':
135 outfmt = fmt[1];
136 break;
137 default:
138 goto fmterr;
139 }
140 if (!fmt[2])
141 return;
142 fmterr:
143 sprintf(errmsg, "Unsupported i/o format: -f%s", fmt);
144 error(USER, errmsg);
145 }
146
147
148 /* Set overriding options */
149 static void
150 override_options(void)
151 {
152 shadthresh = 0;
153 ambssamp = 0;
154 ambacc = 0;
155 }
156
157
158 int
159 main(int argc, char *argv[])
160 {
161 #define check(ol,al) if (argv[i][ol] || \
162 badarg(argc-i-1,argv+i+1,al)) \
163 goto badopt
164 #define check_bool(olen,var) switch (argv[i][olen]) { \
165 case '\0': var = !var; break; \
166 case 'y': case 'Y': case 't': case 'T': \
167 case '+': case '1': var = 1; break; \
168 case 'n': case 'N': case 'f': case 'F': \
169 case '-': case '0': var = 0; break; \
170 default: goto badopt; }
171 int force_open = 0;
172 int recover = 0;
173 char *curout = NULL;
174 char *prms = NULL;
175 char *binval = NULL;
176 int bincnt = 0;
177 int rval;
178 int i;
179 /* global program name */
180 progname = argv[0];
181 /* feature check only? */
182 strcat(RFeatureList, RCONTRIB_FEATURES);
183 if (argc > 1 && !strcmp(argv[1], "-features"))
184 return feature_status(argc-2, argv+2);
185 /* initialize calcomp routines early */
186 initfunc();
187 calcontext(RCCONTEXT);
188 /* option city */
189 for (i = 1; i < argc; i++) {
190 /* expand arguments */
191 while ((rval = expandarg(&argc, &argv, i)) > 0)
192 ;
193 if (rval < 0) {
194 sprintf(errmsg, "cannot expand '%s'", argv[i]);
195 error(SYSTEM, errmsg);
196 }
197 if (argv[i] == NULL || argv[i][0] != '-')
198 break; /* break from options */
199 if (!strcmp(argv[i], "-version")) {
200 puts(VersionID);
201 quit(0);
202 }
203 if (!strcmp(argv[i], "-defaults") ||
204 !strcmp(argv[i], "-help")) {
205 override_options();
206 printdefaults();
207 quit(0);
208 }
209 rval = getrenderopt(argc-i, argv+i);
210 if (rval >= 0) {
211 i += rval;
212 continue;
213 }
214 switch (argv[i][1]) {
215 case 'n': /* number of processes */
216 check(2,"i");
217 nproc = atoi(argv[++i]);
218 if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0)
219 nproc = 1;
220 break;
221 case 'V': /* output contributions? */
222 rval = myRCmanager.HasFlag(RCcontrib);
223 check_bool(2,rval);
224 myRCmanager.SetFlag(RCcontrib, rval);
225 break;
226 case 'x': /* x resolution */
227 check(2,"i");
228 myRCmanager.xres = atoi(argv[++i]);
229 break;
230 case 'y': /* y resolution */
231 check(2,"i");
232 myRCmanager.yres = atoi(argv[++i]);
233 break;
234 case 'w': /* warnings on/off */
235 rval = (erract[WARNING].pf != NULL);
236 check_bool(2,rval);
237 if (rval) erract[WARNING].pf = wputs;
238 else erract[WARNING].pf = NULL;
239 break;
240 case 'e': /* .cal expression */
241 check(2,"s");
242 scompile(argv[++i], NULL, 0);
243 break;
244 case 'l': /* limit distance */
245 if (argv[i][2] != 'd')
246 goto badopt;
247 rval = myRCmanager.HasFlag(RTlimDist);
248 check_bool(3,rval);
249 myRCmanager.SetFlag(RTlimDist, rval);
250 break;
251 case 'I': /* immed. irradiance */
252 rval = myRCmanager.HasFlag(RTimmIrrad);
253 check_bool(2,rval);
254 myRCmanager.SetFlag(RTimmIrrad, rval);
255 break;
256 case 'f': /* .cal file or force or format */
257 if (!argv[i][2]) {
258 check(2,"s");
259 loadfunc(argv[++i]);
260 break;
261 }
262 if (argv[i][2] == 'o') {
263 check_bool(3,force_open);
264 break;
265 }
266 setformat(argv[i]+2);
267 myRCmanager.SetDataFormat(outfmt);
268 break;
269 case 'o': /* output file */
270 check(2,"s");
271 curout = argv[++i];
272 break;
273 case 'r': /* recover output */
274 check_bool(2,recover);
275 break;
276 case 'p': /* parameter setting(s) */
277 check(2,"s");
278 set_eparams(prms = argv[++i]);
279 break;
280 case 'c': /* sample count */
281 check(2,"i");
282 myRCmanager.accum = atoi(argv[++i]);
283 break;
284 case 'b': /* bin expression/count */
285 if (argv[i][2] == 'n') {
286 check(3,"s");
287 bincnt = (int)(eval(argv[++i]) + .5);
288 break;
289 }
290 check(2,"s");
291 binval = argv[++i];
292 break;
293 case 'm': /* modifier name */
294 check(2,"s");
295 myRCmanager.AddModifier(argv[++i], curout, prms, binval, bincnt);
296 break;
297 case 'M': /* file of modifier names */
298 check(2,"s");
299 myRCmanager.AddModFile(argv[++i], curout, prms, binval, bincnt);
300 break;
301 case 't': /* reporting interval */
302 check(2,"i");
303 report_intvl = atoi(argv[++i]);
304 break;
305 default:
306 goto badopt;
307 }
308 }
309 if (i != argc-1)
310 error(USER, "expected single octree argument");
311
312 override_options(); /* override some option settings */
313
314 if (!myRCmanager.GetOutput()) // check that we have work to do
315 error(USER, "missing required modifier argument");
316 // get ready to rock...
317 if (setspectrsamp(CNDX, WLPART) < 0)
318 error(USER, "unsupported spectral sampling");
319 /* set up signal handling */
320 sigdie(SIGINT, "Interrupt");
321 #ifdef SIGHUP
322 sigdie(SIGHUP, "Hangup");
323 #endif
324 sigdie(SIGTERM, "Terminate");
325 #ifdef SIGPIPE
326 sigdie(SIGPIPE, "Broken pipe");
327 #endif
328 #ifdef SIGALRM
329 sigdie(SIGALRM, "Alarm clock");
330 #endif
331 #ifdef SIGXCPU
332 sigdie(SIGXCPU, "CPU limit exceeded");
333 sigdie(SIGXFSZ, "File size exceeded");
334 #endif
335 #ifdef NICE
336 nice(NICE); /* lower priority */
337 #endif
338 // load octree
339 myRCmanager.LoadOctree(argv[argc-1]);
340 // add to header
341 myRCmanager.AddHeader(argc-1, argv);
342 // prepare output files
343 if (recover)
344 myRCmanager.outOp = RCOrecover;
345 else if (force_open)
346 myRCmanager.outOp = RCOforce;
347 else
348 myRCmanager.outOp = RCOnew;
349 // rval = # rows recovered
350 rval = myRCmanager.PrepOutput();
351 // check if recovered everything
352 if (rval >= myRCmanager.GetRowMax()) {
353 error(WARNING, "nothing left to compute");
354 quit(0);
355 } // add processes as requested
356 myRCmanager.SetThreadCount(nproc);
357
358 rxcontrib(rval); /* trace ray contributions (loop) */
359
360 quit(0); /* exit clean */
361
362 badopt:
363 fprintf(stderr,
364 "Usage: %s [-V][-c count][-r][-e expr][-f source][-o ospec][-p p1=V1,p2=V2][-b binv][-bn N] {-m mod | -M file} [rtrace options] octree\n",
365 progname);
366 sprintf(errmsg, "command line error at '%s'", argv[i]);
367 error(USER, errmsg);
368 return(1); /* pro forma return */
369
370 #undef check
371 #undef check_bool
372 }
373
374
375 // skip specified number of bytes, return false if EOF
376 static bool
377 skipBytes(int n2skip)
378 {
379 while (n2skip-- > 0)
380 if (getchar() == EOF)
381 return false;
382 return true;
383 }
384
385
386 // skip specified number of whitespace-separated words, return false if EOF
387 static bool
388 skipWords(int n2skip)
389 {
390 int c;
391
392 while (n2skip-- > 0) {
393 do {
394 c = getchar();
395 } while (isspace(c));
396 do {
397 if (c == EOF) return false;
398 c = getchar();
399 } while (!isspace(c));
400 }
401 return true;
402 }
403
404
405 // read a bundle of myRCmanager.accum ray origins and directions
406 static bool
407 getRayBundle(FVECT *orig_dir = NULL)
408 {
409 int n2go = myRCmanager.accum;
410
411 switch (inpfmt) {
412 case 'a': // ASCII input
413 if (!orig_dir)
414 return skipWords(6*n2go);
415 while (n2go-- > 0) {
416 if (scanf(FVFORMAT, &orig_dir[0][0],
417 &orig_dir[0][1], &orig_dir[0][2]) != 3)
418 return false;
419 if (scanf(FVFORMAT, &orig_dir[1][0],
420 &orig_dir[1][1], &orig_dir[1][2]) != 3)
421 return false;
422 orig_dir += 2;
423 }
424 break;
425 case 'f': // float input
426 if (!orig_dir)
427 return skipBytes(6*sizeof(float)*n2go);
428 #ifdef SMLFLT
429 if (getbinary(orig_dir, sizeof(FVECT), 2*n2go, stdin) != 2*n2go)
430 return false;
431 #else
432 while (n2go-- > 0) {
433 float fvecs[6];
434 if (getbinary(fvecs, sizeof(fvecs), 1, stdin) != 1)
435 return false;
436 for (int i = 6; i--; )
437 orig_dir[0][i] = fvecs[i];
438 orig_dir += 2;
439 }
440 #endif
441 break;
442 case 'd': // double input
443 if (!orig_dir)
444 return skipBytes(6*sizeof(double)*n2go);
445 #ifndef SMLFLT
446 if (getbinary(orig_dir, sizeof(FVECT), 2*n2go, stdin) != 2*n2go)
447 return false;
448 #else
449 while (n2go-- > 0) {
450 double dvecs[6];
451 if (getbinary(dvecs, sizeof(dvecs), 1, stdin) != 1)
452 return false;
453 for (int i = 6; i--; )
454 orig_dir[0][i] = dvecs[i];
455 orig_dir += 2;
456 }
457 #endif
458 break;
459 default:
460 error(INTERNAL, "unsupported format in getRayBundle()");
461 return false;
462 }
463 int warned = 0; // normalize directions
464 n2go = myRCmanager.accum;
465 while (n2go-- > 0) {
466 orig_dir -= 2;
467 if (normalize(orig_dir[1]) == 0)
468 if (!warned++)
469 error(WARNING, "zero ray direction on input");
470 }
471 return true;
472 }
473
474
475 // Run loop to load data, report progress, etc.
476 void
477 rxcontrib(const int rstart)
478 {
479 const int totRows = myRCmanager.GetRowMax();
480 FVECT * odarr = (FVECT *)emalloc(sizeof(FVECT)*2*myRCmanager.accum);
481 time_t tstart, last_report;
482 int r = 0;
483
484 while (r < rstart) { // skip input rays already done
485 if (!getRayBundle())
486 goto readerr;
487 r++;
488 }
489 if (report_intvl > 0) { // set up reporting
490 if (r > 0) {
491 sprintf(errmsg, "recovered %.2f%% of total\n",
492 100.*r/totRows);
493 eputs(errmsg);
494 }
495 last_report = tstart = time(0);
496 }
497 while (r < totRows) { // loop until done
498 time_t tnow;
499 if (!getRayBundle(odarr))
500 goto readerr;
501 if (myRCmanager.ComputeRecord(odarr) <= 0)
502 return; // error reported, hopefully...
503 r++;
504 if (report_intvl <= 0)
505 continue;
506 tnow = time(0); // time to report progress?
507 if (r == totRows)
508 myRCmanager.FlushQueue();
509 else if (tnow < last_report+report_intvl)
510 continue;
511 sprintf(errmsg, "%.2f%% done after %.3f hours\n",
512 100.*myRCmanager.GetRowFinished()/totRows,
513 (1./3600.)*(tnow - tstart));
514 eputs(errmsg);
515 last_report = tnow;
516 }
517 efree(odarr);
518 return;
519 readerr:
520 sprintf(errmsg, "unexpected EOF on standard input (record %d of %d)",
521 r, totRows);
522 error(USER, errmsg);
523 }
524
525
526 void
527 wputs( /* warning output function */
528 const char *s
529 )
530 {
531 if (!erract[WARNING].pf) return;
532 int lasterrno = errno;
533 eputs(s);
534 errno = lasterrno;
535 }
536
537
538 void
539 eputs( /* put string to stderr */
540 const char *s
541 )
542 {
543 static int midline = 0;
544
545 if (!*s)
546 return;
547 if (!midline++) {
548 fputs(progname, stderr);
549 fputs(": ", stderr);
550 }
551 fputs(s, stderr);
552 if (s[strlen(s)-1] == '\n') {
553 fflush(stderr);
554 midline = 0;
555 }
556 }
557
558
559 /* Exit program */
560 void
561 quit(
562 int code
563 )
564 {
565 if (!code && myRCmanager.Ready()) // clean up on normal exit
566 code = myRCmanager.Cleanup();
567
568 exit(code);
569 }
