root/radiance/ray/src/rt/rvmain.c
Revision: 2.3
Committed: Thu Jun 5 19:29:34 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.2: +5 -11 lines
2 static const char RCSid[] = "$Id: rvmain.c,v 2.2 2003/02/25 02:47:23 greg Exp $";
5 * rvmain.c - main for rview interactive viewer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "platform.h"
13 #include "ray.h"
14 #include "source.h"
15 #include "ambient.h"
16 #include "random.h"
17 #include "paths.h"
18 #include "view.h"
19
20 char *progname; /* argv[0] */
21
22 char *octname; /* octree name */
23
24 char *sigerr[NSIG]; /* signal error messages */
25
26 char *shm_boundary = NULL; /* boundary of shared memory */
27
28 char *errfile = NULL; /* error output file */
29
30 extern int greyscale; /* map colors to brightness? */
31 extern char *dvcname; /* output device name */
32 extern double exposure; /* exposure compensation */
33
34 extern VIEW ourview; /* viewing parameters */
35
36 extern char rifname[]; /* rad input file name */
37
38 extern int hresolu; /* horizontal resolution */
39 extern int vresolu; /* vertical resolution */
40
41 extern int psample; /* pixel sample size */
42 extern double maxdiff; /* max. sample difference */
43
44 void onsig();
45 void sigdie();
46 void printdefaults();
47
48
49 int
50 main(argc, argv)
51 int argc;
52 char *argv[];
53 {
54 #define check(ol,al) if (argv[i][ol] || \
55 badarg(argc-i-1,argv+i+1,al)) \
56 goto badopt
57 #define bool(olen,var) switch (argv[i][olen]) { \
58 case '\0': var = !var; break; \
59 case 'y': case 'Y': case 't': case 'T': \
60 case '+': case '1': var = 1; break; \
61 case 'n': case 'N': case 'f': case 'F': \
62 case '-': case '0': var = 0; break; \
63 default: goto badopt; }
64 char *err;
65 int rval;
66 int i;
67 /* global program name */
68 progname = argv[0] = fixargv0(argv[0]);
69 /* option city */
70 for (i = 1; i < argc; i++) {
71 /* expand arguments */
72 while ((rval = expandarg(&argc, &argv, i)) > 0)
73 ;
74 if (rval < 0) {
75 sprintf(errmsg, "cannot expand '%s'", argv[i]);
76 error(SYSTEM, errmsg);
77 }
78 if (argv[i] == NULL || argv[i][0] != '-')
79 break; /* break from options */
80 if (!strcmp(argv[i], "-version")) {
81 puts(VersionID);
82 quit(0);
83 }
84 if (!strcmp(argv[i], "-defaults") ||
85 !strcmp(argv[i], "-help")) {
86 printdefaults();
87 quit(0);
88 }
89 if (!strcmp(argv[i], "-devices")) {
90 printdevices();
91 quit(0);
92 }
93 rval = getrenderopt(argc-i, argv+i);
94 if (rval >= 0) {
95 i += rval;
96 continue;
97 }
98 rval = getviewopt(&ourview, argc-i, argv+i);
99 if (rval >= 0) {
100 i += rval;
101 continue;
102 }
103 switch (argv[i][1]) {
104 case 'v': /* view file */
105 if (argv[i][2] != 'f')
106 goto badopt;
107 check(3,"s");
108 rval = viewfile(argv[++i], &ourview, NULL);
109 if (rval < 0) {
110 sprintf(errmsg,
111 "cannot open view file \"%s\"",
112 argv[i]);
113 error(SYSTEM, errmsg);
114 } else if (rval == 0) {
115 sprintf(errmsg,
116 "bad view file \"%s\"",
117 argv[i]);
118 error(USER, errmsg);
119 }
120 break;
121 case 'b': /* grayscale */
122 bool(2,greyscale);
123 break;
124 case 'p': /* pixel */
125 switch (argv[i][2]) {
126 case 's': /* sample */
127 check(3,"i");
128 psample = atoi(argv[++i]);
129 break;
130 case 't': /* threshold */
131 check(3,"f");
132 maxdiff = atof(argv[++i]);
133 break;
134 case 'e': /* exposure */
135 check(3,"f");
136 exposure = atof(argv[++i]);
137 if (argv[i][0] == '+' || argv[i][0] == '-')
138 exposure = pow(2.0, exposure);
139 break;
140 default:
141 goto badopt;
142 }
143 break;
144 case 'w': /* warnings */
145 rval = erract[WARNING].pf != NULL;
146 bool(2,rval);
147 if (rval) erract[WARNING].pf = wputs;
148 else erract[WARNING].pf = NULL;
149 break;
150 case 'e': /* error file */
151 check(2,"s");
152 errfile = argv[++i];
153 break;
154 case 'o': /* output device */
155 check(2,"s");
156 dvcname = argv[++i];
157 break;
158 case 'R': /* render input file */
159 check(2,"s");
160 strcpy(rifname, argv[++i]);
161 break;
162 default:
163 goto badopt;
164 }
165 }
166 err = setview(&ourview); /* set viewing parameters */
167 if (err != NULL)
168 error(USER, err);
169 /* initialize object types */
170 initotypes();
171 /* initialize urand */
172 initurand(2048);
173 /* set up signal handling */
174 sigdie(SIGINT, "Interrupt");
175 sigdie(SIGHUP, "Hangup");
176 sigdie(SIGTERM, "Terminate");
177 sigdie(SIGPIPE, "Broken pipe");
178 sigdie(SIGALRM, "Alarm clock");
179 #ifdef SIGXCPU
180 sigdie(SIGXCPU, "CPU limit exceeded");
181 sigdie(SIGXFSZ, "File size exceeded");
182 #endif
183 /* open error file */
184 if (errfile != NULL) {
185 if (freopen(errfile, "a", stderr) == NULL)
186 quit(2);
187 fprintf(stderr, "**************\n*** PID %5d: ",
188 getpid());
189 printargs(argc, argv, stderr);
190 putc('\n', stderr);
191 fflush(stderr);
192 }
193 #ifdef NICE
194 nice(NICE); /* lower priority */
195 #endif
196 /* get octree */
197 if (i == argc)
198 octname = NULL;
199 else if (i == argc-1)
200 octname = argv[i];
201 else
202 goto badopt;
203 if (octname == NULL)
204 error(USER, "missing octree argument");
205 /* set up output */
206 SET_FILE_BINARY(stdout);
207 readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
208 nsceneobjs = nobjects;
209
210 marksources(); /* find and mark sources */
211
212 setambient(); /* initialize ambient calculation */
213
214 rview(); /* run interactive viewer */
215
216 ambsync(); /* flush ambient file */
217
218 quit(0);
219
220 badopt:
221 sprintf(errmsg, "command line error at '%s'", argv[i]);
222 error(USER, errmsg);
223
224 #undef check
225 #undef bool
226 }
227
228
229 void
230 wputs(s) /* warning output function */
231 char *s;
232 {
233 int lasterrno = errno;
234 eputs(s);
235 errno = lasterrno;
236 }
237
238
239 void
240 eputs(s) /* put string to stderr */
241 register char *s;
242 {
243 static int midline = 0;
244
245 if (!*s)
246 return;
247 if (!midline++) {
248 fputs(progname, stderr);
249 fputs(": ", stderr);
250 }
251 fputs(s, stderr);
252 if (s[strlen(s)-1] == '\n') {
253 fflush(stderr);
254 midline = 0;
255 }
256 }
257
258
259 void
260 onsig(signo) /* fatal signal */
261 int signo;
262 {
263 static int gotsig = 0;
264
265 if (gotsig++) /* two signals and we're gone! */
266 _exit(signo);
267
268 alarm(15); /* allow 15 seconds to clean up */
269 signal(SIGALRM, SIG_DFL); /* make certain we do die */
270 eputs("signal - ");
271 eputs(sigerr[signo]);
272 eputs("\n");
273 quit(3);
274 }
275
276
277 void
278 sigdie(signo, msg) /* set fatal signal */
279 int signo;
280 char *msg;
281 {
282 if (signal(signo, onsig) == SIG_IGN)
283 signal(signo, SIG_IGN);
284 sigerr[signo] = msg;
285 }
286
287
288 void
289 printdefaults() /* print default values to stdout */
290 {
291 register char *cp;
292
293 printf(greyscale ? "-b+\t\t\t\t# greyscale on\n" :
294 "-b-\t\t\t\t# greyscale off\n");
295 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
296 ourview.type==VT_PER ? "perspective" :
297 ourview.type==VT_PAR ? "parallel" :
298 ourview.type==VT_HEM ? "hemispherical" :
299 ourview.type==VT_ANG ? "angular" :
300 ourview.type==VT_CYL ? "cylindrical" :
301 "unknown");
302 printf("-vp %f %f %f\t# view point\n",
303 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
304 printf("-vd %f %f %f\t# view direction\n",
305 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
306 printf("-vu %f %f %f\t# view up\n",
307 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
308 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
309 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
310 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
311 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
312 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
313 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
314 printf("-pe %f\t\t\t# pixel exposure\n", exposure);
315 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
316 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
317 printf("-o %s\t\t\t\t# output device\n", dvcname);
318 printf(erract[WARNING].pf != NULL ?
319 "-w+\t\t\t\t# warning messages on\n" :
320 "-w-\t\t\t\t# warning messages off\n");
321 print_rdefaults();
322 }
