root/radiance/ray/src/rt/rvmain.c
Revision: 2.23
Committed: Tue Apr 22 17:12:25 2025 UTC (13 days, 21 hours ago) by greg
Changes since 2.22: +23 -14 lines
2 static const char RCSid[] = "$Id: rvmain.c,v 2.22 2024/10/30 16:47:03 greg Exp $";
5 * rvmain.c - main for rview interactive viewer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11 #include <time.h>
12
13 #include "platform.h"
14 #include "ray.h"
15 #include "func.h"
16 #include "source.h"
17 #include "ambient.h"
18 #include "rpaint.h"
19 #include "random.h"
20 #include "paths.h"
21 #include "view.h"
22 #include "pmapray.h"
23
24 extern char *progname; /* global argv[0] */
25
26 VIEW ourview = STDVIEW; /* viewing parameters */
27 int hresolu, vresolu; /* image resolution */
28
29 int psample = 8; /* pixel sample size */
30 double maxdiff = .15; /* max. sample difference */
31
32 int greyscale = 0; /* map colors to brightness? */
33 char *dvcname = dev_default; /* output device name */
34
35 double exposure = 1.0; /* exposure for scene */
36
37 int newparam = 1; /* parameter setting changed */
38
39 struct driver *dev = NULL; /* driver functions */
40
41 char rifname[128]; /* rad input file name */
42
43 VIEW oldview; /* previous view parameters */
44
45 PNODE ptrunk; /* the base of our image */
46 RECT pframe; /* current frame boundaries */
47 int pdepth; /* image depth in current frame */
48
49 char *errfile = NULL; /* error output file */
50
51 int nproc = 1; /* number of processes */
52
53 char *sigerr[NSIG]; /* signal error messages */
54
55 static void onsig(int signo);
56 static void sigdie(int signo, char *msg);
57 static void printdefaults(void);
58
59 static void
60 set_defaults(void)
61 {
62 shadthresh = .1;
63 shadcert = .25;
64 directrelay = 0;
65 vspretest = 128;
66 srcsizerat = 0.;
67 specthresh = .3;
68 specjitter = 1.;
69 maxdepth = 6;
70 minweight = 1e-3;
71 ambacc = 0.3;
72 ambres = 32;
73 ambdiv = 256;
74 ambssamp = 64;
75 }
76
77 int
78 main(int argc, char *argv[])
79 {
80 #define check(ol,al) if (argv[i][ol] || \
81 badarg(argc-i-1,argv+i+1,al)) \
82 goto badopt
83 #define check_bool(olen,var) switch (argv[i][olen]) { \
84 case '\0': var = !var; break; \
85 case 'y': case 'Y': case 't': case 'T': \
86 case '+': case '1': var = 1; break; \
87 case 'n': case 'N': case 'f': case 'F': \
88 case '-': case '0': var = 0; break; \
89 default: goto badopt; }
90 char *octnm = NULL;
91 char *err;
92 int rval;
93 int i;
94 /* global program name */
95 progname = argv[0] = fixargv0(argv[0]);
96 /* set our defaults */
97 set_defaults();
98 /* initialize calcomp routines */
99 initfunc();
100 /* option city */
101 for (i = 1; i < argc; i++) {
102 /* expand arguments */
103 while ((rval = expandarg(&argc, &argv, i)) > 0)
104 ;
105 if (rval < 0) {
106 sprintf(errmsg, "cannot expand '%s'", argv[i]);
107 error(SYSTEM, errmsg);
108 }
109 if (argv[i] == NULL || argv[i][0] != '-')
110 break; /* break from options */
111 if (!strcmp(argv[i], "-version")) {
112 puts(VersionID);
113 quit(0);
114 }
115 if (!strcmp(argv[i], "-defaults") ||
116 !strcmp(argv[i], "-help")) {
117 printdefaults();
118 quit(0);
119 }
120 if (!strcmp(argv[i], "-devices")) {
121 printdevices();
122 quit(0);
123 }
124 rval = getrenderopt(argc-i, argv+i);
125 if (rval >= 0) {
126 i += rval;
127 continue;
128 }
129 rval = getviewopt(&ourview, argc-i, argv+i);
130 if (rval >= 0) {
131 i += rval;
132 continue;
133 }
134 switch (argv[i][1]) {
135 case 'n': /* # processes */
136 check(2,"i");
137 nproc = atoi(argv[++i]);
138 if (nproc <= 0)
139 error(USER, "bad number of processes");
140 break;
141 case 'v': /* view file */
142 if (argv[i][2] != 'f')
143 goto badopt;
144 check(3,"s");
145 rval = viewfile(argv[++i], &ourview, NULL);
146 if (rval < 0) {
147 sprintf(errmsg,
148 "cannot open view file \"%s\"",
149 argv[i]);
150 error(SYSTEM, errmsg);
151 } else if (rval == 0) {
152 sprintf(errmsg,
153 "bad view file \"%s\"",
154 argv[i]);
155 error(USER, errmsg);
156 }
157 break;
158 case 'b': /* grayscale */
159 check_bool(2,greyscale);
160 break;
161 case 'p': /* pixel */
162 switch (argv[i][2]) {
163 case 's': /* sample */
164 check(3,"i");
165 psample = atoi(argv[++i]);
166 break;
167 case 't': /* threshold */
168 check(3,"f");
169 maxdiff = atof(argv[++i]);
170 break;
171 case 'e': /* exposure */
172 check(3,"f");
173 exposure = atof(argv[++i]);
174 if (argv[i][0] == '+' || argv[i][0] == '-')
175 exposure = pow(2.0, exposure);
176 break;
177 default:
178 goto badopt;
179 }
180 break;
181 case 'w': /* warnings */
182 rval = erract[WARNING].pf != NULL;
183 check_bool(2,rval);
184 if (rval) erract[WARNING].pf = wputs;
185 else erract[WARNING].pf = NULL;
186 break;
187 case 'e': /* error file */
188 check(2,"s");
189 errfile = argv[++i];
190 break;
191 case 'o': /* output device */
192 check(2,"s");
193 dvcname = argv[++i];
194 break;
195 case 'R': /* render input file */
196 check(2,"s");
197 strcpy(rifname, argv[++i]);
198 break;
199 default:
200 goto badopt;
201 }
202 }
203 /* set/check spectral sampling */
204 if (setspectrsamp(CNDX, WLPART) <= 0)
205 error(USER, "unsupported spectral sampling");
206
207 err = setview(&ourview); /* set viewing parameters */
208 if (err != NULL)
209 error(USER, err);
210 /* set up signal handling */
211 sigdie(SIGINT, "Interrupt");
212 sigdie(SIGTERM, "Terminate");
213 #if !defined(_WIN32) && !defined(_WIN64)
214 sigdie(SIGHUP, "Hangup");
215 sigdie(SIGPIPE, "Broken pipe");
216 sigdie(SIGALRM, "Alarm clock");
217 #endif
218 /* open error file */
219 if (errfile != NULL) {
220 if (freopen(errfile, "a", stderr) == NULL)
221 quit(2);
222 fprintf(stderr, "**************\n*** PID %5d: ",
223 getpid());
224 printargs(argc, argv, stderr);
225 putc('\n', stderr);
226 fflush(stderr);
227 }
228 #ifdef NICE
229 nice(NICE); /* lower priority */
230 #endif
231 /* get octree */
232 if (i == argc)
233 octnm = NULL;
234 else if (i == argc-1)
235 octnm = argv[i];
236 else
237 goto badopt;
238 if (octnm == NULL)
239 error(USER, "missing octree argument");
240 /* set up output & start process(es) */
241 SET_FILE_BINARY(stdout);
242
243 ray_init(octnm); /* also calls ray_init_pmap() */
244
245 /* temporary shortcut, until winrview is refactored into a "device" */
246 #ifndef WIN_RVIEW
247 rview(); /* run interactive viewer */
248
249
250 devclose(); /* close output device */
251 #endif
252
253 /* PMAP: free photon maps */
254 ray_done_pmap();
255
256 #ifdef WIN_RVIEW
257 return 1;
258 #endif
259 quit(0);
260
261 badopt:
262 sprintf(errmsg, "command line error at '%s'", argv[i]);
263 error(USER, errmsg);
264 return 1; /* pro forma return */
265
266 #undef check
267 #undef check_bool
268 }
269
270
271 void
272 wputs( /* warning output function */
273 const char *s
274 )
275 {
276 int lasterrno = errno;
277 if (erract[WARNING].pf == NULL)
278 return; /* called by calcomp or someone */
279 eputs(s);
280 errno = lasterrno;
281 }
282
283
284 void
285 eputs( /* put string to stderr */
286 const char *s
287 )
288 {
289 static int midline = 0;
290
291 if (!*s)
292 return;
293 if (!midline++) {
294 fputs(progname, stderr);
295 fputs(": ", stderr);
296 }
297 fputs(s, stderr);
298 if (s[strlen(s)-1] == '\n') {
299 fflush(stderr);
300 midline = 0;
301 }
302 }
303
304
305 static void
306 onsig( /* fatal signal */
307 int signo
308 )
309 {
310 static int gotsig = 0;
311
312 if (gotsig++) /* two signals and we're gone! */
313 _exit(signo);
314
315 #if !defined(_WIN32) && !defined(_WIN64)
316 alarm(15); /* allow 15 seconds to clean up */
317 signal(SIGALRM, SIG_DFL); /* make certain we do die */
318 #endif
319 eputs("signal - ");
320 eputs(sigerr[signo]);
321 eputs("\n");
322 devclose();
323 quit(3);
324 }
325
326
327 static void
328 sigdie( /* set fatal signal */
329 int signo,
330 char *msg
331 )
332 {
333 if (signal(signo, onsig) == SIG_IGN)
334 signal(signo, SIG_IGN);
335 sigerr[signo] = msg;
336 }
337
338
339 static void
340 printdefaults(void) /* print default values to stdout */
341 {
342 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
343 printf(greyscale ? "-b+\t\t\t\t# greyscale on\n" :
344 "-b-\t\t\t\t# greyscale off\n");
345 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
346 ourview.type==VT_PER ? "perspective" :
347 ourview.type==VT_PAR ? "parallel" :
348 ourview.type==VT_HEM ? "hemispherical" :
349 ourview.type==VT_ANG ? "angular" :
350 ourview.type==VT_CYL ? "cylindrical" :
351 ourview.type==VT_PLS ? "planisphere" :
352 "unknown");
353 printf("-vp %f %f %f\t# view point\n",
354 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
355 printf("-vd %f %f %f\t# view direction\n",
356 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
357 printf("-vu %f %f %f\t# view up\n",
358 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
359 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
360 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
361 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
362 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
363 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
364 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
365 printf("-pe %f\t\t\t# pixel exposure\n", exposure);
366 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
367 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
368 printf("-o %s\t\t\t\t# output device\n", dvcname);
369 printf(erract[WARNING].pf != NULL ?
370 "-w+\t\t\t\t# warning messages on\n" :
371 "-w-\t\t\t\t# warning messages off\n");
372 print_rdefaults();
373 }
