--- ray/src/rt/rvmain.c 2008/03/11 02:21:47 2.8 +++ ray/src/rt/rvmain.c 2008/08/21 07:05:59 2.9 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rvmain.c,v 2.8 2008/03/11 02:21:47 greg Exp $"; +static const char RCSid[] = "$Id: rvmain.c,v 2.9 2008/08/21 07:05:59 greg Exp $"; #endif /* * rvmain.c - main for rview interactive viewer @@ -19,37 +19,44 @@ static const char RCSid[] = "$Id: rvmain.c,v 2.8 2008/ #include "paths.h" #include "view.h" -char *progname; /* argv[0] */ +extern char *progname; /* global argv[0] */ -char *octname; /* octree name */ +VIEW ourview = STDVIEW; /* viewing parameters */ +int hresolu, vresolu; /* image resolution */ -char *sigerr[NSIG]; /* signal error messages */ +int psample = 8; /* pixel sample size */ +double maxdiff = .15; /* max. sample difference */ -char *shm_boundary = NULL; /* boundary of shared memory */ +int greyscale = 0; /* map colors to brightness? */ +char *dvcname = dev_default; /* output device name */ -char *errfile = NULL; /* error output file */ +double exposure = 1.0; /* exposure for scene */ -extern int greyscale; /* map colors to brightness? */ -extern char *dvcname; /* output device name */ -extern double exposure; /* exposure compensation */ +int newparam = 1; /* parameter setting changed */ + +struct driver *dev = NULL; /* driver functions */ -extern VIEW ourview; /* viewing parameters */ +char rifname[128]; /* rad input file name */ -extern char rifname[]; /* rad input file name */ +VIEW oldview; /* previous view parameters */ -extern int hresolu; /* horizontal resolution */ -extern int vresolu; /* vertical resolution */ +PNODE ptrunk; /* the base of our image */ +RECT pframe; /* current frame boundaries */ +int pdepth; /* image depth in current frame */ -extern int psample; /* pixel sample size */ -extern double maxdiff; /* max. sample difference */ +char *errfile = NULL; /* error output file */ +int nproc = 1; /* number of processes */ + +char *sigerr[NSIG]; /* signal error messages */ + static void onsig(int signo); static void sigdie(int signo, char *msg); static void printdefaults(void); int -main(int argc, char *argv[]) +main(int argc, char *argv[]) { #define check(ol,al) if (argv[i][ol] || \ badarg(argc-i-1,argv+i+1,al)) \ @@ -61,11 +68,26 @@ main(int argc, char *argv[]) case 'n': case 'N': case 'f': case 'F': \ case '-': case '0': var = 0; break; \ default: goto badopt; } + char *octnm = NULL; char *err; int rval; int i; /* global program name */ progname = argv[0] = fixargv0(argv[0]); + /* set our defaults */ + shadthresh = .1; + shadcert = .25; + directrelay = 0; + vspretest = 128; + srcsizerat = 0.; + specthresh = .3; + specjitter = 1.; + maxdepth = 6; + minweight = 1e-2; + ambacc = 0.3; + ambres = 32; + ambdiv = 256; + ambssamp = 64; /* option city */ for (i = 1; i < argc; i++) { /* expand arguments */ @@ -101,6 +123,12 @@ main(int argc, char *argv[]) continue; } switch (argv[i][1]) { + case 'n': /* # processes */ + check(2,"i"); + nproc = atoi(argv[++i]); + if (nproc <= 0) + error(USER, "bad number of processes"); + break; case 'v': /* view file */ if (argv[i][2] != 'f') goto badopt; @@ -166,26 +194,12 @@ main(int argc, char *argv[]) err = setview(&ourview); /* set viewing parameters */ if (err != NULL) error(USER, err); - /* initialize object types */ - initotypes(); - /* initialize urand */ - if (rand_samp) { - srandom((long)time(0)); - initurand(0); - } else { - srandom(0L); - initurand(2048); - } - /* set up signal handling */ + /* set up signal handling */ sigdie(SIGINT, "Interrupt"); sigdie(SIGHUP, "Hangup"); sigdie(SIGTERM, "Terminate"); sigdie(SIGPIPE, "Broken pipe"); sigdie(SIGALRM, "Alarm clock"); -#ifdef SIGXCPU - sigdie(SIGXCPU, "CPU limit exceeded"); - sigdie(SIGXFSZ, "File size exceeded"); -#endif /* open error file */ if (errfile != NULL) { if (freopen(errfile, "a", stderr) == NULL) @@ -201,25 +215,21 @@ main(int argc, char *argv[]) #endif /* get octree */ if (i == argc) - octname = NULL; + octnm = NULL; else if (i == argc-1) - octname = argv[i]; + octnm = argv[i]; else goto badopt; - if (octname == NULL) + if (octnm == NULL) error(USER, "missing octree argument"); - /* set up output */ + /* set up output & start process(es) */ SET_FILE_BINARY(stdout); - readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL); - nsceneobjs = nobjects; + + ray_pinit(octnm, 0); - marksources(); /* find and mark sources */ - - setambient(); /* initialize ambient calculation */ - rview(); /* run interactive viewer */ - ambsync(); /* flush ambient file */ + devclose(); /* close output device */ quit(0); @@ -246,7 +256,7 @@ wputs( /* warning output function */ void eputs( /* put string to stderr */ - register char *s + char *s ) { static int midline = 0; @@ -280,6 +290,7 @@ onsig( /* fatal signal */ eputs("signal - "); eputs(sigerr[signo]); eputs("\n"); + devclose(); quit(3); } @@ -299,6 +310,7 @@ sigdie( /* set fatal signal */ static void printdefaults(void) /* print default values to stdout */ { + printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); printf(greyscale ? "-b+\t\t\t\t# greyscale on\n" : "-b-\t\t\t\t# greyscale off\n"); printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
