root/Development/ray/src/rt/rvmain.c
Revision: 2.26
Committed: Fri Jun 20 16:34:23 2025 UTC (4 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.25: +1 -3 lines
fix: Avoid array bounds errors in dimlist[] in deep ray trees
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.26 static const char RCSid[] = "$Id: rvmain.c,v 2.25 2025/06/07 05:09:46 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * rvmain.c - main for rview interactive viewer
6     */
7
8 greg 2.2 #include "copyright.h"
9 greg 2.1
10 schorsch 2.3 #include <signal.h>
11 greg 2.5 #include <time.h>
12 schorsch 2.3
13     #include "platform.h"
14 greg 2.1 #include "ray.h"
15     #include "source.h"
16     #include "ambient.h"
17 schorsch 2.4 #include "rpaint.h"
18 greg 2.1 #include "random.h"
19     #include "view.h"
20 greg 2.12 #include "pmapray.h"
21 greg 2.1
22 greg 2.9 VIEW ourview = STDVIEW; /* viewing parameters */
23     int hresolu, vresolu; /* image resolution */
24 greg 2.1
25 greg 2.9 int psample = 8; /* pixel sample size */
26     double maxdiff = .15; /* max. sample difference */
27
28     int greyscale = 0; /* map colors to brightness? */
29     char *dvcname = dev_default; /* output device name */
30
31     double exposure = 1.0; /* exposure for scene */
32 greg 2.1
33 greg 2.9 int newparam = 1; /* parameter setting changed */
34
35     struct driver *dev = NULL; /* driver functions */
36 greg 2.1
37 greg 2.9 char rifname[128]; /* rad input file name */
38 greg 2.1
39 greg 2.9 VIEW oldview; /* previous view parameters */
40 greg 2.1
41 greg 2.9 PNODE ptrunk; /* the base of our image */
42     RECT pframe; /* current frame boundaries */
43     int pdepth; /* image depth in current frame */
44 greg 2.1
45 greg 2.9 char *errfile = NULL; /* error output file */
46 greg 2.1
47 greg 2.9 int nproc = 1; /* number of processes */
48 greg 2.1
49 greg 2.9 char *sigerr[NSIG]; /* signal error messages */
50 greg 2.1
51 schorsch 2.4 static void onsig(int signo);
52     static void sigdie(int signo, char *msg);
53     static void printdefaults(void);
54 greg 2.1
55 greg 2.23 static void
56     set_defaults(void)
57     {
58     shadthresh = .1;
59     shadcert = .25;
60     directrelay = 0;
61     vspretest = 128;
62     srcsizerat = 0.;
63     specthresh = .3;
64     specjitter = 1.;
65     maxdepth = 6;
66     minweight = 1e-3;
67     ambacc = 0.3;
68     ambres = 32;
69     ambdiv = 256;
70     ambssamp = 64;
71     }
72
73 greg 2.17 int
74 greg 2.9 main(int argc, char *argv[])
75 greg 2.1 {
76     #define check(ol,al) if (argv[i][ol] || \
77     badarg(argc-i-1,argv+i+1,al)) \
78     goto badopt
79 schorsch 2.15 #define check_bool(olen,var) switch (argv[i][olen]) { \
80 greg 2.1 case '\0': var = !var; break; \
81     case 'y': case 'Y': case 't': case 'T': \
82     case '+': case '1': var = 1; break; \
83     case 'n': case 'N': case 'f': case 'F': \
84     case '-': case '0': var = 0; break; \
85     default: goto badopt; }
86 greg 2.9 char *octnm = NULL;
87 greg 2.1 char *err;
88     int rval;
89     int i;
90     /* global program name */
91     progname = argv[0] = fixargv0(argv[0]);
92 greg 2.9 /* set our defaults */
93 greg 2.23 set_defaults();
94 greg 2.1 /* option city */
95     for (i = 1; i < argc; i++) {
96     /* expand arguments */
97     while ((rval = expandarg(&argc, &argv, i)) > 0)
98     ;
99     if (rval < 0) {
100     sprintf(errmsg, "cannot expand '%s'", argv[i]);
101     error(SYSTEM, errmsg);
102     }
103     if (argv[i] == NULL || argv[i][0] != '-')
104     break; /* break from options */
105     if (!strcmp(argv[i], "-version")) {
106     puts(VersionID);
107     quit(0);
108     }
109     if (!strcmp(argv[i], "-defaults") ||
110     !strcmp(argv[i], "-help")) {
111     printdefaults();
112     quit(0);
113     }
114     if (!strcmp(argv[i], "-devices")) {
115     printdevices();
116     quit(0);
117     }
118     rval = getrenderopt(argc-i, argv+i);
119     if (rval >= 0) {
120     i += rval;
121     continue;
122     }
123     rval = getviewopt(&ourview, argc-i, argv+i);
124     if (rval >= 0) {
125     i += rval;
126     continue;
127     }
128     switch (argv[i][1]) {
129 greg 2.9 case 'n': /* # processes */
130     check(2,"i");
131     nproc = atoi(argv[++i]);
132     if (nproc <= 0)
133     error(USER, "bad number of processes");
134     break;
135 greg 2.1 case 'v': /* view file */
136     if (argv[i][2] != 'f')
137     goto badopt;
138     check(3,"s");
139     rval = viewfile(argv[++i], &ourview, NULL);
140     if (rval < 0) {
141     sprintf(errmsg,
142     "cannot open view file \"%s\"",
143     argv[i]);
144     error(SYSTEM, errmsg);
145     } else if (rval == 0) {
146     sprintf(errmsg,
147     "bad view file \"%s\"",
148     argv[i]);
149     error(USER, errmsg);
150     }
151     break;
152     case 'b': /* grayscale */
153 schorsch 2.15 check_bool(2,greyscale);
154 greg 2.1 break;
155     case 'p': /* pixel */
156     switch (argv[i][2]) {
157     case 's': /* sample */
158     check(3,"i");
159     psample = atoi(argv[++i]);
160     break;
161     case 't': /* threshold */
162     check(3,"f");
163     maxdiff = atof(argv[++i]);
164     break;
165     case 'e': /* exposure */
166     check(3,"f");
167     exposure = atof(argv[++i]);
168     if (argv[i][0] == '+' || argv[i][0] == '-')
169     exposure = pow(2.0, exposure);
170     break;
171     default:
172     goto badopt;
173     }
174     break;
175     case 'w': /* warnings */
176     rval = erract[WARNING].pf != NULL;
177 schorsch 2.15 check_bool(2,rval);
178 greg 2.1 if (rval) erract[WARNING].pf = wputs;
179     else erract[WARNING].pf = NULL;
180     break;
181     case 'e': /* error file */
182     check(2,"s");
183     errfile = argv[++i];
184     break;
185     case 'o': /* output device */
186     check(2,"s");
187     dvcname = argv[++i];
188     break;
189     case 'R': /* render input file */
190     check(2,"s");
191     strcpy(rifname, argv[++i]);
192     break;
193     default:
194     goto badopt;
195     }
196     }
197 greg 2.20 /* set/check spectral sampling */
198 greg 2.21 if (setspectrsamp(CNDX, WLPART) <= 0)
199 greg 2.20 error(USER, "unsupported spectral sampling");
200
201 greg 2.1 err = setview(&ourview); /* set viewing parameters */
202     if (err != NULL)
203     error(USER, err);
204 greg 2.9 /* set up signal handling */
205 greg 2.1 sigdie(SIGINT, "Interrupt");
206 greg 2.11 sigdie(SIGTERM, "Terminate");
207 schorsch 2.14 #if !defined(_WIN32) && !defined(_WIN64)
208 greg 2.1 sigdie(SIGHUP, "Hangup");
209     sigdie(SIGPIPE, "Broken pipe");
210     sigdie(SIGALRM, "Alarm clock");
211 greg 2.11 #endif
212 greg 2.1 /* open error file */
213     if (errfile != NULL) {
214     if (freopen(errfile, "a", stderr) == NULL)
215     quit(2);
216     fprintf(stderr, "**************\n*** PID %5d: ",
217     getpid());
218     printargs(argc, argv, stderr);
219     putc('\n', stderr);
220     fflush(stderr);
221     }
222     #ifdef NICE
223     nice(NICE); /* lower priority */
224     #endif
225     /* get octree */
226     if (i == argc)
227 greg 2.9 octnm = NULL;
228 greg 2.1 else if (i == argc-1)
229 greg 2.9 octnm = argv[i];
230 greg 2.1 else
231     goto badopt;
232 greg 2.9 if (octnm == NULL)
233 greg 2.1 error(USER, "missing octree argument");
234 greg 2.9 /* set up output & start process(es) */
235 schorsch 2.3 SET_FILE_BINARY(stdout);
236 greg 2.9
237 greg 2.13 ray_init(octnm); /* also calls ray_init_pmap() */
238 greg 2.12
239 schorsch 2.16 /* temporary shortcut, until winrview is refactored into a "device" */
240     #ifndef WIN_RVIEW
241 greg 2.1 rview(); /* run interactive viewer */
242
243 schorsch 2.16
244 greg 2.9 devclose(); /* close output device */
245 schorsch 2.16 #endif
246 greg 2.1
247 greg 2.12 /* PMAP: free photon maps */
248     ray_done_pmap();
249
250 schorsch 2.16 #ifdef WIN_RVIEW
251     return 1;
252     #endif
253 greg 2.1 quit(0);
254
255     badopt:
256     sprintf(errmsg, "command line error at '%s'", argv[i]);
257     error(USER, errmsg);
258 schorsch 2.4 return 1; /* pro forma return */
259 greg 2.1
260     #undef check
261 schorsch 2.15 #undef check_bool
262 greg 2.1 }
263
264
265     void
266 schorsch 2.4 wputs( /* warning output function */
267 greg 2.19 const char *s
268 schorsch 2.4 )
269 greg 2.1 {
270     int lasterrno = errno;
271 greg 2.22 if (erract[WARNING].pf == NULL)
272     return; /* called by calcomp or someone */
273 greg 2.1 eputs(s);
274     errno = lasterrno;
275     }
276
277
278     void
279 schorsch 2.4 eputs( /* put string to stderr */
280 greg 2.19 const char *s
281 schorsch 2.4 )
282 greg 2.1 {
283     static int midline = 0;
284
285     if (!*s)
286     return;
287     if (!midline++) {
288     fputs(progname, stderr);
289     fputs(": ", stderr);
290     }
291     fputs(s, stderr);
292     if (s[strlen(s)-1] == '\n') {
293     fflush(stderr);
294     midline = 0;
295     }
296     }
297
298
299 schorsch 2.4 static void
300     onsig( /* fatal signal */
301     int signo
302     )
303 greg 2.1 {
304     static int gotsig = 0;
305
306     if (gotsig++) /* two signals and we're gone! */
307     _exit(signo);
308
309 schorsch 2.14 #if !defined(_WIN32) && !defined(_WIN64)
310 greg 2.1 alarm(15); /* allow 15 seconds to clean up */
311     signal(SIGALRM, SIG_DFL); /* make certain we do die */
312 greg 2.11 #endif
313 greg 2.1 eputs("signal - ");
314     eputs(sigerr[signo]);
315     eputs("\n");
316 greg 2.9 devclose();
317 greg 2.1 quit(3);
318     }
319
320
321 schorsch 2.4 static void
322     sigdie( /* set fatal signal */
323     int signo,
324     char *msg
325     )
326 greg 2.1 {
327     if (signal(signo, onsig) == SIG_IGN)
328     signal(signo, SIG_IGN);
329     sigerr[signo] = msg;
330     }
331
332
333 schorsch 2.4 static void
334     printdefaults(void) /* print default values to stdout */
335 greg 2.1 {
336 greg 2.9 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
337 greg 2.1 printf(greyscale ? "-b+\t\t\t\t# greyscale on\n" :
338     "-b-\t\t\t\t# greyscale off\n");
339     printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
340     ourview.type==VT_PER ? "perspective" :
341     ourview.type==VT_PAR ? "parallel" :
342     ourview.type==VT_HEM ? "hemispherical" :
343     ourview.type==VT_ANG ? "angular" :
344     ourview.type==VT_CYL ? "cylindrical" :
345 greg 2.8 ourview.type==VT_PLS ? "planisphere" :
346 greg 2.1 "unknown");
347     printf("-vp %f %f %f\t# view point\n",
348     ourview.vp[0], ourview.vp[1], ourview.vp[2]);
349     printf("-vd %f %f %f\t# view direction\n",
350     ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
351     printf("-vu %f %f %f\t# view up\n",
352     ourview.vup[0], ourview.vup[1], ourview.vup[2]);
353     printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
354     printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
355     printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
356     printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
357     printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
358     printf("-vl %f\t\t\t# view lift\n", ourview.voff);
359     printf("-pe %f\t\t\t# pixel exposure\n", exposure);
360     printf("-ps %-9d\t\t\t# pixel sample\n", psample);
361     printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
362     printf("-o %s\t\t\t\t# output device\n", dvcname);
363     printf(erract[WARNING].pf != NULL ?
364     "-w+\t\t\t\t# warning messages on\n" :
365     "-w-\t\t\t\t# warning messages off\n");
366     print_rdefaults();
367     }
