root/radiance/ray/src/rt/rvmain.c
Revision: 2.4
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.3: +24 -22 lines
2 static const char RCSid[] = "$Id: rvmain.c,v 2.3 2003/06/05 19:29:34 schorsch Exp $";
5 * rvmain.c - main for rview interactive viewer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "platform.h"
13 #include "ray.h"
14 #include "source.h"
15 #include "ambient.h"
16 #include "rpaint.h"
17 #include "random.h"
18 #include "paths.h"
19 #include "view.h"
20
21 char *progname; /* argv[0] */
22
23 char *octname; /* octree name */
24
25 char *sigerr[NSIG]; /* signal error messages */
26
27 char *shm_boundary = NULL; /* boundary of shared memory */
28
29 char *errfile = NULL; /* error output file */
30
31 extern int greyscale; /* map colors to brightness? */
32 extern char *dvcname; /* output device name */
33 extern double exposure; /* exposure compensation */
34
35 extern VIEW ourview; /* viewing parameters */
36
37 extern char rifname[]; /* rad input file name */
38
39 extern int hresolu; /* horizontal resolution */
40 extern int vresolu; /* vertical resolution */
41
42 extern int psample; /* pixel sample size */
43 extern double maxdiff; /* max. sample difference */
44
45 static void onsig(int signo);
46 static void sigdie(int signo, char *msg);
47 static void printdefaults(void);
48
49
50 int
51 main(int argc, char *argv[])
52 {
53 #define check(ol,al) if (argv[i][ol] || \
54 badarg(argc-i-1,argv+i+1,al)) \
55 goto badopt
56 #define bool(olen,var) switch (argv[i][olen]) { \
57 case '\0': var = !var; break; \
58 case 'y': case 'Y': case 't': case 'T': \
59 case '+': case '1': var = 1; break; \
60 case 'n': case 'N': case 'f': case 'F': \
61 case '-': case '0': var = 0; break; \
62 default: goto badopt; }
63 char *err;
64 int rval;
65 int i;
66 /* global program name */
67 progname = argv[0] = fixargv0(argv[0]);
68 /* option city */
69 for (i = 1; i < argc; i++) {
70 /* expand arguments */
71 while ((rval = expandarg(&argc, &argv, i)) > 0)
72 ;
73 if (rval < 0) {
74 sprintf(errmsg, "cannot expand '%s'", argv[i]);
75 error(SYSTEM, errmsg);
76 }
77 if (argv[i] == NULL || argv[i][0] != '-')
78 break; /* break from options */
79 if (!strcmp(argv[i], "-version")) {
80 puts(VersionID);
81 quit(0);
82 }
83 if (!strcmp(argv[i], "-defaults") ||
84 !strcmp(argv[i], "-help")) {
85 printdefaults();
86 quit(0);
87 }
88 if (!strcmp(argv[i], "-devices")) {
89 printdevices();
90 quit(0);
91 }
92 rval = getrenderopt(argc-i, argv+i);
93 if (rval >= 0) {
94 i += rval;
95 continue;
96 }
97 rval = getviewopt(&ourview, argc-i, argv+i);
98 if (rval >= 0) {
99 i += rval;
100 continue;
101 }
102 switch (argv[i][1]) {
103 case 'v': /* view file */
104 if (argv[i][2] != 'f')
105 goto badopt;
106 check(3,"s");
107 rval = viewfile(argv[++i], &ourview, NULL);
108 if (rval < 0) {
109 sprintf(errmsg,
110 "cannot open view file \"%s\"",
111 argv[i]);
112 error(SYSTEM, errmsg);
113 } else if (rval == 0) {
114 sprintf(errmsg,
115 "bad view file \"%s\"",
116 argv[i]);
117 error(USER, errmsg);
118 }
119 break;
120 case 'b': /* grayscale */
121 bool(2,greyscale);
122 break;
123 case 'p': /* pixel */
124 switch (argv[i][2]) {
125 case 's': /* sample */
126 check(3,"i");
127 psample = atoi(argv[++i]);
128 break;
129 case 't': /* threshold */
130 check(3,"f");
131 maxdiff = atof(argv[++i]);
132 break;
133 case 'e': /* exposure */
134 check(3,"f");
135 exposure = atof(argv[++i]);
136 if (argv[i][0] == '+' || argv[i][0] == '-')
137 exposure = pow(2.0, exposure);
138 break;
139 default:
140 goto badopt;
141 }
142 break;
143 case 'w': /* warnings */
144 rval = erract[WARNING].pf != NULL;
145 bool(2,rval);
146 if (rval) erract[WARNING].pf = wputs;
147 else erract[WARNING].pf = NULL;
148 break;
149 case 'e': /* error file */
150 check(2,"s");
151 errfile = argv[++i];
152 break;
153 case 'o': /* output device */
154 check(2,"s");
155 dvcname = argv[++i];
156 break;
157 case 'R': /* render input file */
158 check(2,"s");
159 strcpy(rifname, argv[++i]);
160 break;
161 default:
162 goto badopt;
163 }
164 }
165 err = setview(&ourview); /* set viewing parameters */
166 if (err != NULL)
167 error(USER, err);
168 /* initialize object types */
169 initotypes();
170 /* initialize urand */
171 initurand(2048);
172 /* set up signal handling */
173 sigdie(SIGINT, "Interrupt");
174 sigdie(SIGHUP, "Hangup");
175 sigdie(SIGTERM, "Terminate");
176 sigdie(SIGPIPE, "Broken pipe");
177 sigdie(SIGALRM, "Alarm clock");
178 #ifdef SIGXCPU
179 sigdie(SIGXCPU, "CPU limit exceeded");
180 sigdie(SIGXFSZ, "File size exceeded");
181 #endif
182 /* open error file */
183 if (errfile != NULL) {
184 if (freopen(errfile, "a", stderr) == NULL)
185 quit(2);
186 fprintf(stderr, "**************\n*** PID %5d: ",
187 getpid());
188 printargs(argc, argv, stderr);
189 putc('\n', stderr);
190 fflush(stderr);
191 }
192 #ifdef NICE
193 nice(NICE); /* lower priority */
194 #endif
195 /* get octree */
196 if (i == argc)
197 octname = NULL;
198 else if (i == argc-1)
199 octname = argv[i];
200 else
201 goto badopt;
202 if (octname == NULL)
203 error(USER, "missing octree argument");
204 /* set up output */
205 SET_FILE_BINARY(stdout);
206 readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
207 nsceneobjs = nobjects;
208
209 marksources(); /* find and mark sources */
210
211 setambient(); /* initialize ambient calculation */
212
213 rview(); /* run interactive viewer */
214
215 ambsync(); /* flush ambient file */
216
217 quit(0);
218
219 badopt:
220 sprintf(errmsg, "command line error at '%s'", argv[i]);
221 error(USER, errmsg);
222 return 1; /* pro forma return */
223
224 #undef check
225 #undef bool
226 }
227
228
229 void
230 wputs( /* warning output function */
231 char *s
232 )
233 {
234 int lasterrno = errno;
235 eputs(s);
236 errno = lasterrno;
237 }
238
239
240 void
241 eputs( /* put string to stderr */
242 register char *s
243 )
244 {
245 static int midline = 0;
246
247 if (!*s)
248 return;
249 if (!midline++) {
250 fputs(progname, stderr);
251 fputs(": ", stderr);
252 }
253 fputs(s, stderr);
254 if (s[strlen(s)-1] == '\n') {
255 fflush(stderr);
256 midline = 0;
257 }
258 }
259
260
261 static void
262 onsig( /* fatal signal */
263 int signo
264 )
265 {
266 static int gotsig = 0;
267
268 if (gotsig++) /* two signals and we're gone! */
269 _exit(signo);
270
271 alarm(15); /* allow 15 seconds to clean up */
272 signal(SIGALRM, SIG_DFL); /* make certain we do die */
273 eputs("signal - ");
274 eputs(sigerr[signo]);
275 eputs("\n");
276 quit(3);
277 }
278
279
280 static void
281 sigdie( /* set fatal signal */
282 int signo,
283 char *msg
284 )
285 {
286 if (signal(signo, onsig) == SIG_IGN)
287 signal(signo, SIG_IGN);
288 sigerr[signo] = msg;
289 }
290
291
292 static void
293 printdefaults(void) /* print default values to stdout */
294 {
295 printf(greyscale ? "-b+\t\t\t\t# greyscale on\n" :
296 "-b-\t\t\t\t# greyscale off\n");
297 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
298 ourview.type==VT_PER ? "perspective" :
299 ourview.type==VT_PAR ? "parallel" :
300 ourview.type==VT_HEM ? "hemispherical" :
301 ourview.type==VT_ANG ? "angular" :
302 ourview.type==VT_CYL ? "cylindrical" :
303 "unknown");
304 printf("-vp %f %f %f\t# view point\n",
305 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
306 printf("-vd %f %f %f\t# view direction\n",
307 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
308 printf("-vu %f %f %f\t# view up\n",
309 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
310 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
311 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
312 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
313 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
314 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
315 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
316 printf("-pe %f\t\t\t# pixel exposure\n", exposure);
317 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
318 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
319 printf("-o %s\t\t\t\t# output device\n", dvcname);
320 printf(erract[WARNING].pf != NULL ?
321 "-w+\t\t\t\t# warning messages on\n" :
322 "-w-\t\t\t\t# warning messages off\n");
323 print_rdefaults();
324 }
