root/radiance/ray/src/rt/rvmain.c
Fri Jun 20 16:34:23 2025 UTC (6 weeks, 4 days ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.25: +1 -3 lines
Diff to previous 2.25 , to selected 2.8
fix: Avoid array bounds errors in dimlist[] in deep ray trees
Sat Jun 7 05:09:46 2025 UTC (8 weeks, 4 days ago) by greg
Changes since 2.24: +1 -2 lines
Diff to previous 2.24 , to selected 2.8
Wed Apr 23 02:35:26 2025 UTC (3 months, 2 weeks ago) by greg
Changes since 2.23: +1 -4 lines
Diff to previous 2.23 , to selected 2.8
fix: Added missing calls to initfunc()
Tue Apr 22 17:12:25 2025 UTC (3 months, 2 weeks ago) by greg
Changes since 2.22: +23 -14 lines
Diff to previous 2.22 , to selected 2.8
Wed Oct 30 16:47:03 2024 UTC (9 months ago) by greg
Changes since 2.21: +3 -1 lines
Diff to previous 2.21 , to selected 2.8
fix(rpict,rtrace,rcontrib): Removed spurious warnings
Thu Jan 18 00:28:54 2024 UTC (18 months, 2 weeks ago) by greg
Changes since 2.20: +2 -3 lines
Diff to previous 2.20 , to selected 2.8
fix(rcontrib, rpict, rvu): Better check for spectral sampling
Wed Jan 17 01:31:08 2024 UTC (18 months, 2 weeks ago) by greg
Changes since 2.19: +6 -1 lines
Diff to previous 2.19 , to selected 2.8
fix(rpict,rvu,rcontrib): Fixed luminance estimate during spectral rendering
Mon Feb 6 22:40:21 2023 UTC (2 years, 5 months ago) by greg
Diff to previous 2.18 , to selected 2.8
Tue Jan 24 21:54:49 2023 UTC (2 years, 6 months ago) by greg
Diff to previous 2.17 , to selected 2.8
Thu Aug 18 00:52:48 2016 UTC (8 years, 11 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16 , to selected 2.8
Sat Mar 19 12:51:36 2016 UTC (9 years, 4 months ago) by schorsch
Changes since 2.15: +8 -3 lines
prepare for winrview integration
Thu Mar 10 18:25:46 2016 UTC (9 years, 4 months ago) by schorsch
Changes since 2.14: +5 -5 lines
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Sun Mar 6 01:13:18 2016 UTC (9 years, 5 months ago) by schorsch
Thu Apr 23 17:42:04 2015 UTC (10 years, 3 months ago) by greg
Changes since 2.12: +2 -5 lines
Fixed assignment of octname and removed redundant call to ray_init_pmap()
Tue Feb 24 19:39:27 2015 UTC (10 years, 5 months ago) by greg
Changes since 2.11: +8 -1 lines
Wed Oct 5 17:20:55 2011 UTC (13 years, 10 months ago) by greg
Changes since 2.10: +6 -2 lines
Windows compatibility changes from Bill Hoffman
Sat Dec 12 19:01:00 2009 UTC (15 years, 7 months ago) by greg
Thu Aug 21 07:05:59 2008 UTC (16 years, 11 months ago) by greg
Changes since 2.8: +55 -43 lines
Tue Mar 11 02:21:47 2008 UTC (17 years, 5 months ago) by greg
Wed Apr 5 06:22:57 2006 UTC (19 years, 4 months ago) by greg
Changes since 2.6: +8 -3 lines
Made -u+ option truly random
Tue Jun 21 00:26:44 2005 UTC (20 years, 1 month ago) by greg
Wed Jun 15 15:36:52 2005 UTC (20 years, 1 month ago) by greg
Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.3: +24 -22 lines
Thu Jun 5 19:29:34 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.2: +5 -11 lines
Tue Feb 25 02:47:23 2003 UTC (22 years, 5 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 5 months ago) by greg
Diff to selected 2.8
