| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rvmain.c,v 2.18 2023/01/24 21:54:49 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rvmain.c - main for rview interactive viewer
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <signal.h>
| 11 |
#include <time.h>
| 12 |
| 13 |
#include "platform.h"
| 14 |
#include "ray.h"
| 15 |
#include "source.h"
| 16 |
#include "ambient.h"
| 17 |
#include "rpaint.h"
| 18 |
#include "random.h"
| 19 |
#include "paths.h"
| 20 |
#include "view.h"
| 21 |
#include "pmapray.h"
| 22 |
| 23 |
extern char *progname; /* global argv[0] */
| 24 |
| 25 |
VIEW ourview = STDVIEW; /* viewing parameters */
| 26 |
int hresolu, vresolu; /* image resolution */
| 27 |
| 28 |
int psample = 8; /* pixel sample size */
| 29 |
double maxdiff = .15; /* max. sample difference */
| 30 |
| 31 |
int greyscale = 0; /* map colors to brightness? */
| 32 |
char *dvcname = dev_default; /* output device name */
| 33 |
| 34 |
double exposure = 1.0; /* exposure for scene */
| 35 |
| 36 |
int newparam = 1; /* parameter setting changed */
| 37 |
| 38 |
struct driver *dev = NULL; /* driver functions */
| 39 |
| 40 |
char rifname[128]; /* rad input file name */
| 41 |
| 42 |
VIEW oldview; /* previous view parameters */
| 43 |
| 44 |
PNODE ptrunk; /* the base of our image */
| 45 |
RECT pframe; /* current frame boundaries */
| 46 |
int pdepth; /* image depth in current frame */
| 47 |
| 48 |
char *errfile = NULL; /* error output file */
| 49 |
| 50 |
int nproc = 1; /* number of processes */
| 51 |
| 52 |
char *sigerr[NSIG]; /* signal error messages */
| 53 |
| 54 |
static void onsig(int signo);
| 55 |
static void sigdie(int signo, char *msg);
| 56 |
static void printdefaults(void);
| 57 |
| 58 |
int
| 59 |
main(int argc, char *argv[])
| 60 |
| 61 |
#define check(ol,al) if (argv[i][ol] || \
| 62 |
badarg(argc-i-1,argv+i+1,al)) \
| 63 |
goto badopt
| 64 |
#define check_bool(olen,var) switch (argv[i][olen]) { \
| 65 |
case '\0': var = !var; break; \
| 66 |
case 'y': case 'Y': case 't': case 'T': \
| 67 |
case '+': case '1': var = 1; break; \
| 68 |
case 'n': case 'N': case 'f': case 'F': \
| 69 |
case '-': case '0': var = 0; break; \
| 70 |
default: goto badopt; }
| 71 |
char *octnm = NULL;
| 72 |
char *err;
| 73 |
int rval;
| 74 |
int i;
| 75 |
/* global program name */
| 76 |
progname = argv[0] = fixargv0(argv[0]);
| 77 |
/* set our defaults */
| 78 |
shadthresh = .1;
| 79 |
shadcert = .25;
| 80 |
directrelay = 0;
| 81 |
vspretest = 128;
| 82 |
srcsizerat = 0.;
| 83 |
specthresh = .3;
| 84 |
specjitter = 1.;
| 85 |
maxdepth = 6;
| 86 |
minweight = 1e-3;
| 87 |
ambacc = 0.3;
| 88 |
ambres = 32;
| 89 |
ambdiv = 256;
| 90 |
ambssamp = 64;
| 91 |
/* option city */
| 92 |
for (i = 1; i < argc; i++) {
| 93 |
/* expand arguments */
| 94 |
while ((rval = expandarg(&argc, &argv, i)) > 0)
| 95 |
| 96 |
if (rval < 0) {
| 97 |
sprintf(errmsg, "cannot expand '%s'", argv[i]);
| 98 |
error(SYSTEM, errmsg);
| 99 |
| 100 |
if (argv[i] == NULL || argv[i][0] != '-')
| 101 |
break; /* break from options */
| 102 |
if (!strcmp(argv[i], "-version")) {
| 103 |
puts(VersionID);
| 104 |
quit(0);
| 105 |
| 106 |
if (!strcmp(argv[i], "-defaults") ||
| 107 |
!strcmp(argv[i], "-help")) {
| 108 |
printdefaults();
| 109 |
quit(0);
| 110 |
| 111 |
if (!strcmp(argv[i], "-devices")) {
| 112 |
printdevices();
| 113 |
quit(0);
| 114 |
| 115 |
rval = getrenderopt(argc-i, argv+i);
| 116 |
if (rval >= 0) {
| 117 |
i += rval;
| 118 |
continue;
| 119 |
| 120 |
rval = getviewopt(&ourview, argc-i, argv+i);
| 121 |
if (rval >= 0) {
| 122 |
i += rval;
| 123 |
continue;
| 124 |
| 125 |
switch (argv[i][1]) {
| 126 |
case 'n': /* # processes */
| 127 |
check(2,"i");
| 128 |
nproc = atoi(argv[++i]);
| 129 |
if (nproc <= 0)
| 130 |
error(USER, "bad number of processes");
| 131 |
break;
| 132 |
case 'v': /* view file */
| 133 |
if (argv[i][2] != 'f')
| 134 |
goto badopt;
| 135 |
check(3,"s");
| 136 |
rval = viewfile(argv[++i], &ourview, NULL);
| 137 |
if (rval < 0) {
| 138 |
sprintf(errmsg,
| 139 |
"cannot open view file \"%s\"",
| 140 |
argv[i]);
| 141 |
| 142 |
} else if (rval == 0) {
| 143 |
sprintf(errmsg,
| 144 |
"bad view file \"%s\"",
| 145 |
argv[i]);
| 146 |
error(USER, errmsg);
| 147 |
| 148 |
break;
| 149 |
case 'b': /* grayscale */
| 150 |
check_bool(2,greyscale);
| 151 |
break;
| 152 |
case 'p': /* pixel */
| 153 |
switch (argv[i][2]) {
| 154 |
case 's': /* sample */
| 155 |
check(3,"i");
| 156 |
psample = atoi(argv[++i]);
| 157 |
break;
| 158 |
case 't': /* threshold */
| 159 |
check(3,"f");
| 160 |
maxdiff = atof(argv[++i]);
| 161 |
break;
| 162 |
case 'e': /* exposure */
| 163 |
check(3,"f");
| 164 |
exposure = atof(argv[++i]);
| 165 |
if (argv[i][0] == '+' || argv[i][0] == '-')
| 166 |
exposure = pow(2.0, exposure);
| 167 |
break;
| 168 |
default:
| 169 |
goto badopt;
| 170 |
| 171 |
break;
| 172 |
case 'w': /* warnings */
| 173 |
rval = erract[WARNING].pf != NULL;
| 174 |
check_bool(2,rval);
| 175 |
if (rval) erract[WARNING].pf = wputs;
| 176 |
else erract[WARNING].pf = NULL;
| 177 |
break;
| 178 |
case 'e': /* error file */
| 179 |
check(2,"s");
| 180 |
errfile = argv[++i];
| 181 |
break;
| 182 |
case 'o': /* output device */
| 183 |
check(2,"s");
| 184 |
dvcname = argv[++i];
| 185 |
break;
| 186 |
case 'R': /* render input file */
| 187 |
check(2,"s");
| 188 |
strcpy(rifname, argv[++i]);
| 189 |
break;
| 190 |
default:
| 191 |
goto badopt;
| 192 |
| 193 |
| 194 |
err = setview(&ourview); /* set viewing parameters */
| 195 |
if (err != NULL)
| 196 |
error(USER, err);
| 197 |
/* set up signal handling */
| 198 |
sigdie(SIGINT, "Interrupt");
| 199 |
sigdie(SIGTERM, "Terminate");
| 200 |
#if !defined(_WIN32) && !defined(_WIN64)
| 201 |
sigdie(SIGHUP, "Hangup");
| 202 |
sigdie(SIGPIPE, "Broken pipe");
| 203 |
sigdie(SIGALRM, "Alarm clock");
| 204 |
#endif
| 205 |
/* open error file */
| 206 |
if (errfile != NULL) {
| 207 |
if (freopen(errfile, "a", stderr) == NULL)
| 208 |
quit(2);
| 209 |
fprintf(stderr, "**************\n*** PID %5d: ",
| 210 |
getpid());
| 211 |
printargs(argc, argv, stderr);
| 212 |
putc('\n', stderr);
| 213 |
fflush(stderr);
| 214 |
| 215 |
#ifdef NICE
| 216 |
nice(NICE); /* lower priority */
| 217 |
#endif
| 218 |
/* get octree */
| 219 |
if (i == argc)
| 220 |
octnm = NULL;
| 221 |
else if (i == argc-1)
| 222 |
octnm = argv[i];
| 223 |
else
| 224 |
goto badopt;
| 225 |
if (octnm == NULL)
| 226 |
error(USER, "missing octree argument");
| 227 |
/* set up output & start process(es) */
| 228 |
SET_FILE_BINARY(stdout);
| 229 |
| 230 |
ray_init(octnm); /* also calls ray_init_pmap() */
| 231 |
| 232 |
/* temporary shortcut, until winrview is refactored into a "device" */
| 233 |
#ifndef WIN_RVIEW
| 234 |
rview(); /* run interactive viewer */
| 235 |
| 236 |
| 237 |
devclose(); /* close output device */
| 238 |
#endif
| 239 |
| 240 |
/* PMAP: free photon maps */
| 241 |
ray_done_pmap();
| 242 |
| 243 |
#ifdef WIN_RVIEW
| 244 |
return 1;
| 245 |
#endif
| 246 |
quit(0);
| 247 |
| 248 |
badopt:
| 249 |
sprintf(errmsg, "command line error at '%s'", argv[i]);
| 250 |
| 251 |
return 1; /* pro forma return */
| 252 |
| 253 |
#undef check
| 254 |
#undef check_bool
| 255 |
| 256 |
| 257 |
| 258 |
void
| 259 |
wputs( /* warning output function */
| 260 |
const char *s
| 261 |
| 262 |
| 263 |
int lasterrno = errno;
| 264 |
eputs(s);
| 265 |
errno = lasterrno;
| 266 |
| 267 |
| 268 |
| 269 |
void
| 270 |
eputs( /* put string to stderr */
| 271 |
const char *s
| 272 |
| 273 |
| 274 |
static int midline = 0;
| 275 |
| 276 |
if (!*s)
| 277 |
return;
| 278 |
if (!midline++) {
| 279 |
fputs(progname, stderr);
| 280 |
fputs(": ", stderr);
| 281 |
| 282 |
fputs(s, stderr);
| 283 |
if (s[strlen(s)-1] == '\n') {
| 284 |
fflush(stderr);
| 285 |
midline = 0;
| 286 |
| 287 |
| 288 |
| 289 |
| 290 |
static void
| 291 |
onsig( /* fatal signal */
| 292 |
int signo
| 293 |
| 294 |
| 295 |
static int gotsig = 0;
| 296 |
| 297 |
if (gotsig++) /* two signals and we're gone! */
| 298 |
_exit(signo);
| 299 |
| 300 |
| 301 |
alarm(15); /* allow 15 seconds to clean up */
| 302 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */
| 303 |
#endif
| 304 |
eputs("signal - ");
| 305 |
eputs(sigerr[signo]);
| 306 |
eputs("\n");
| 307 |
devclose();
| 308 |
quit(3);
| 309 |
| 310 |
| 311 |
| 312 |
static void
| 313 |
sigdie( /* set fatal signal */
| 314 |
int signo,
| 315 |
char *msg
| 316 |
| 317 |
| 318 |
if (signal(signo, onsig) == SIG_IGN)
| 319 |
signal(signo, SIG_IGN);
| 320 |
sigerr[signo] = msg;
| 321 |
| 322 |
| 323 |
| 324 |
static void
| 325 |
printdefaults(void) /* print default values to stdout */
| 326 |
| 327 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
| 328 |
printf(greyscale ? "-b+\t\t\t\t# greyscale on\n" :
| 329 |
"-b-\t\t\t\t# greyscale off\n");
| 330 |
printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
| 331 |
ourview.type==VT_PER ? "perspective" :
| 332 |
ourview.type==VT_PAR ? "parallel" :
| 333 |
ourview.type==VT_HEM ? "hemispherical" :
| 334 |
ourview.type==VT_ANG ? "angular" :
| 335 |
ourview.type==VT_CYL ? "cylindrical" :
| 336 |
ourview.type==VT_PLS ? "planisphere" :
| 337 |
"unknown");
| 338 |
printf("-vp %f %f %f\t# view point\n",
| 339 |
ourview.vp[0], ourview.vp[1], ourview.vp[2]);
| 340 |
printf("-vd %f %f %f\t# view direction\n",
| 341 |
ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
| 342 |
printf("-vu %f %f %f\t# view up\n",
| 343 |
ourview.vup[0], ourview.vup[1], ourview.vup[2]);
| 344 |
printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
| 345 |
printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
| 346 |
printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
| 347 |
printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
| 348 |
printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
| 349 |
printf("-vl %f\t\t\t# view lift\n", ourview.voff);
| 350 |
printf("-pe %f\t\t\t# pixel exposure\n", exposure);
| 351 |
printf("-ps %-9d\t\t\t# pixel sample\n", psample);
| 352 |
printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
| 353 |
printf("-o %s\t\t\t\t# output device\n", dvcname);
| 354 |
printf(erract[WARNING].pf != NULL ?
| 355 |
"-w+\t\t\t\t# warning messages on\n" :
| 356 |
"-w-\t\t\t\t# warning messages off\n");
| 357 |
print_rdefaults();
| 358 |
