root/radiance/ray/src/rt/rvmain.c
Mon Feb 6 22:40:21 2023 UTC (2 years, 2 months ago) by greg
Diff to previous 2.18 , to selected 2.16
Tue Jan 24 21:54:49 2023 UTC (2 years, 3 months ago) by greg
Diff to previous 2.17 , to selected 2.16
Thu Aug 18 00:52:48 2016 UTC (8 years, 8 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16
Revision 2.16 - (view) (download) (annotate) - [selected]
Sat Mar 19 12:51:36 2016 UTC (9 years, 1 month ago) by schorsch
Changes since 2.15: +8 -3 lines
Diff to previous 2.15
prepare for winrview integration
Thu Mar 10 18:25:46 2016 UTC (9 years, 1 month ago) by schorsch
Changes since 2.14: +5 -5 lines
Diff to previous 2.14 , to selected 2.16
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Sun Mar 6 01:13:18 2016 UTC (9 years, 1 month ago) by schorsch
Diff to previous 2.13 , to selected 2.16
Thu Apr 23 17:42:04 2015 UTC (10 years ago) by greg
Changes since 2.12: +2 -5 lines
Diff to previous 2.12 , to selected 2.16
Fixed assignment of octname and removed redundant call to ray_init_pmap()
Tue Feb 24 19:39:27 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.11: +8 -1 lines
Diff to previous 2.11 , to selected 2.16
Wed Oct 5 17:20:55 2011 UTC (13 years, 7 months ago) by greg
Changes since 2.10: +6 -2 lines
Diff to previous 2.10 , to selected 2.16
Windows compatibility changes from Bill Hoffman
Sat Dec 12 19:01:00 2009 UTC (15 years, 4 months ago) by greg
Diff to previous 2.9 , to selected 2.16
Thu Aug 21 07:05:59 2008 UTC (16 years, 8 months ago) by greg
Changes since 2.8: +55 -43 lines
Diff to previous 2.8 , to selected 2.16
Tue Mar 11 02:21:47 2008 UTC (17 years, 1 month ago) by greg
Diff to previous 2.7 , to selected 2.16
Wed Apr 5 06:22:57 2006 UTC (19 years, 1 month ago) by greg
Changes since 2.6: +8 -3 lines
Diff to previous 2.6 , to selected 2.16
Made -u+ option truly random
Tue Jun 21 00:26:44 2005 UTC (19 years, 10 months ago) by greg
Diff to previous 2.5 , to selected 2.16
Wed Jun 15 15:36:52 2005 UTC (19 years, 10 months ago) by greg
Diff to previous 2.4 , to selected 2.16
Changes since 2.3: +24 -22 lines
Diff to previous 2.3 , to selected 2.16
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.2: +5 -11 lines
Diff to previous 2.2 , to selected 2.16
Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.1 , to selected 2.16
Diff to selected 2.16
