root/Development/ray/src/rt/rvmain.c
Revision: 2.2
Committed: Tue Feb 25 02:47:23 2003 UTC (22 years, 10 months ago) by greg
5 * rvmain.c - main for rview interactive viewer
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11
12 #include "source.h"
13
14 #include "ambient.h"
15
16 #include "random.h"
17
18 #include "paths.h"
19
20 #include <signal.h>
21
22 #include "view.h"
23
24 char *progname; /* argv[0] */
25
26 char *octname; /* octree name */
27
28 char *sigerr[NSIG]; /* signal error messages */
29
30 char *shm_boundary = NULL; /* boundary of shared memory */
31
32 char *errfile = NULL; /* error output file */
33
34 extern int greyscale; /* map colors to brightness? */
35 extern char *dvcname; /* output device name */
36 extern double exposure; /* exposure compensation */
37
38 extern VIEW ourview; /* viewing parameters */
39
40 extern char rifname[]; /* rad input file name */
41
42 extern int hresolu; /* horizontal resolution */
43 extern int vresolu; /* vertical resolution */
44
45 extern int psample; /* pixel sample size */
46 extern double maxdiff; /* max. sample difference */
47
48 void onsig();
49 void sigdie();
50 void printdefaults();
51
52
53 int
54 main(argc, argv)
55 int argc;
56 char *argv[];
57 {
58 #define check(ol,al) if (argv[i][ol] || \
59 badarg(argc-i-1,argv+i+1,al)) \
60 goto badopt
61 #define bool(olen,var) switch (argv[i][olen]) { \
62 case '\0': var = !var; break; \
63 case 'y': case 'Y': case 't': case 'T': \
64 case '+': case '1': var = 1; break; \
65 case 'n': case 'N': case 'f': case 'F': \
66 case '-': case '0': var = 0; break; \
67 default: goto badopt; }
68 char *err;
69 int rval;
70 int i;
71 /* global program name */
72 progname = argv[0] = fixargv0(argv[0]);
73 /* option city */
74 for (i = 1; i < argc; i++) {
75 /* expand arguments */
76 while ((rval = expandarg(&argc, &argv, i)) > 0)
77 ;
78 if (rval < 0) {
79 sprintf(errmsg, "cannot expand '%s'", argv[i]);
80 error(SYSTEM, errmsg);
81 }
82 if (argv[i] == NULL || argv[i][0] != '-')
83 break; /* break from options */
84 if (!strcmp(argv[i], "-version")) {
85 puts(VersionID);
86 quit(0);
87 }
88 if (!strcmp(argv[i], "-defaults") ||
89 !strcmp(argv[i], "-help")) {
90 printdefaults();
91 quit(0);
92 }
93 if (!strcmp(argv[i], "-devices")) {
94 printdevices();
95 quit(0);
96 }
97 rval = getrenderopt(argc-i, argv+i);
98 if (rval >= 0) {
99 i += rval;
100 continue;
101 }
102 rval = getviewopt(&ourview, argc-i, argv+i);
103 if (rval >= 0) {
104 i += rval;
105 continue;
106 }
107 switch (argv[i][1]) {
108 case 'v': /* view file */
109 if (argv[i][2] != 'f')
110 goto badopt;
111 check(3,"s");
112 rval = viewfile(argv[++i], &ourview, NULL);
113 if (rval < 0) {
114 sprintf(errmsg,
115 "cannot open view file \"%s\"",
116 argv[i]);
117 error(SYSTEM, errmsg);
118 } else if (rval == 0) {
119 sprintf(errmsg,
120 "bad view file \"%s\"",
121 argv[i]);
122 error(USER, errmsg);
123 }
124 break;
125 case 'b': /* grayscale */
126 bool(2,greyscale);
127 break;
128 case 'p': /* pixel */
129 switch (argv[i][2]) {
130 case 's': /* sample */
131 check(3,"i");
132 psample = atoi(argv[++i]);
133 break;
134 case 't': /* threshold */
135 check(3,"f");
136 maxdiff = atof(argv[++i]);
137 break;
138 case 'e': /* exposure */
139 check(3,"f");
140 exposure = atof(argv[++i]);
141 if (argv[i][0] == '+' || argv[i][0] == '-')
142 exposure = pow(2.0, exposure);
143 break;
144 default:
145 goto badopt;
146 }
147 break;
148 case 'w': /* warnings */
149 rval = erract[WARNING].pf != NULL;
150 bool(2,rval);
151 if (rval) erract[WARNING].pf = wputs;
152 else erract[WARNING].pf = NULL;
153 break;
154 case 'e': /* error file */
155 check(2,"s");
156 errfile = argv[++i];
157 break;
158 case 'o': /* output device */
159 check(2,"s");
160 dvcname = argv[++i];
161 break;
162 case 'R': /* render input file */
163 check(2,"s");
164 strcpy(rifname, argv[++i]);
165 break;
166 default:
167 goto badopt;
168 }
169 }
170 err = setview(&ourview); /* set viewing parameters */
171 if (err != NULL)
172 error(USER, err);
173 /* initialize object types */
174 initotypes();
175 /* initialize urand */
176 initurand(2048);
177 /* set up signal handling */
178 sigdie(SIGINT, "Interrupt");
179 sigdie(SIGHUP, "Hangup");
180 sigdie(SIGTERM, "Terminate");
181 sigdie(SIGPIPE, "Broken pipe");
182 sigdie(SIGALRM, "Alarm clock");
183 #ifdef SIGXCPU
184 sigdie(SIGXCPU, "CPU limit exceeded");
185 sigdie(SIGXFSZ, "File size exceeded");
186 #endif
187 /* open error file */
188 if (errfile != NULL) {
189 if (freopen(errfile, "a", stderr) == NULL)
190 quit(2);
191 fprintf(stderr, "**************\n*** PID %5d: ",
192 getpid());
193 printargs(argc, argv, stderr);
194 putc('\n', stderr);
195 fflush(stderr);
196 }
197 #ifdef NICE
198 nice(NICE); /* lower priority */
199 #endif
200 /* get octree */
201 if (i == argc)
202 octname = NULL;
203 else if (i == argc-1)
204 octname = argv[i];
205 else
206 goto badopt;
207 if (octname == NULL)
208 error(USER, "missing octree argument");
209 /* set up output */
210 #ifdef MSDOS
211 setmode(fileno(stdout), O_BINARY);
212 #endif
213 readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
214 nsceneobjs = nobjects;
215
216 marksources(); /* find and mark sources */
217
218 setambient(); /* initialize ambient calculation */
219
220 rview(); /* run interactive viewer */
221
222 ambsync(); /* flush ambient file */
223
224 quit(0);
225
226 badopt:
227 sprintf(errmsg, "command line error at '%s'", argv[i]);
228 error(USER, errmsg);
229
230 #undef check
231 #undef bool
232 }
233
234
235 void
236 wputs(s) /* warning output function */
237 char *s;
238 {
239 int lasterrno = errno;
240 eputs(s);
241 errno = lasterrno;
242 }
243
244
245 void
246 eputs(s) /* put string to stderr */
247 register char *s;
248 {
249 static int midline = 0;
250
251 if (!*s)
252 return;
253 if (!midline++) {
254 fputs(progname, stderr);
255 fputs(": ", stderr);
256 }
257 fputs(s, stderr);
258 if (s[strlen(s)-1] == '\n') {
259 fflush(stderr);
260 midline = 0;
261 }
262 }
263
264
265 void
266 onsig(signo) /* fatal signal */
267 int signo;
268 {
269 static int gotsig = 0;
270
271 if (gotsig++) /* two signals and we're gone! */
272 _exit(signo);
273
274 alarm(15); /* allow 15 seconds to clean up */
275 signal(SIGALRM, SIG_DFL); /* make certain we do die */
276 eputs("signal - ");
277 eputs(sigerr[signo]);
278 eputs("\n");
279 quit(3);
280 }
281
282
283 void
284 sigdie(signo, msg) /* set fatal signal */
285 int signo;
286 char *msg;
287 {
288 if (signal(signo, onsig) == SIG_IGN)
289 signal(signo, SIG_IGN);
290 sigerr[signo] = msg;
291 }
292
293
294 void
295 printdefaults() /* print default values to stdout */
296 {
297 register char *cp;
298
299 printf(greyscale ? "-b+\t\t\t\t# greyscale on\n" :
300 "-b-\t\t\t\t# greyscale off\n");
301 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
302 ourview.type==VT_PER ? "perspective" :
303 ourview.type==VT_PAR ? "parallel" :
304 ourview.type==VT_HEM ? "hemispherical" :
305 ourview.type==VT_ANG ? "angular" :
306 ourview.type==VT_CYL ? "cylindrical" :
307 "unknown");
308 printf("-vp %f %f %f\t# view point\n",
309 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
310 printf("-vd %f %f %f\t# view direction\n",
311 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
312 printf("-vu %f %f %f\t# view up\n",
313 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
314 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
315 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
316 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
317 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
318 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
319 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
320 printf("-pe %f\t\t\t# pixel exposure\n", exposure);
321 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
322 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
323 printf("-o %s\t\t\t\t# output device\n", dvcname);
324 printf(erract[WARNING].pf != NULL ?
325 "-w+\t\t\t\t# warning messages on\n" :
326 "-w-\t\t\t\t# warning messages off\n");
327 print_rdefaults();
328 }
