root/radiance/ray/src/rt/rvmain.c
Revision: 2.5
Committed: Wed Jun 15 15:36:52 2005 UTC (20 years ago) by greg
2 static const char RCSid[] = "$Id: rvmain.c,v 2.4 2004/03/30 16:13:01 schorsch Exp $";
5 * rvmain.c - main for rview interactive viewer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11 #include <time.h>
12
13 #include "platform.h"
14 #include "ray.h"
15 #include "source.h"
16 #include "ambient.h"
17 #include "rpaint.h"
18 #include "random.h"
19 #include "paths.h"
20 #include "view.h"
21
22 char *progname; /* argv[0] */
23
24 char *octname; /* octree name */
25
26 char *sigerr[NSIG]; /* signal error messages */
27
28 char *shm_boundary = NULL; /* boundary of shared memory */
29
30 char *errfile = NULL; /* error output file */
31
32 extern int greyscale; /* map colors to brightness? */
33 extern char *dvcname; /* output device name */
34 extern double exposure; /* exposure compensation */
35
36 extern VIEW ourview; /* viewing parameters */
37
38 extern char rifname[]; /* rad input file name */
39
40 extern int hresolu; /* horizontal resolution */
41 extern int vresolu; /* vertical resolution */
42
43 extern int psample; /* pixel sample size */
44 extern double maxdiff; /* max. sample difference */
45
46 static void onsig(int signo);
47 static void sigdie(int signo, char *msg);
48 static void printdefaults(void);
49
50
51 int
52 main(int argc, char *argv[])
53 {
54 #define check(ol,al) if (argv[i][ol] || \
55 badarg(argc-i-1,argv+i+1,al)) \
56 goto badopt
57 #define bool(olen,var) switch (argv[i][olen]) { \
58 case '\0': var = !var; break; \
59 case 'y': case 'Y': case 't': case 'T': \
60 case '+': case '1': var = 1; break; \
61 case 'n': case 'N': case 'f': case 'F': \
62 case '-': case '0': var = 0; break; \
63 default: goto badopt; }
64 char *err;
65 int rval;
66 int i;
67 /* global program name */
68 progname = argv[0] = fixargv0(argv[0]);
69 /* option city */
70 for (i = 1; i < argc; i++) {
71 /* expand arguments */
72 while ((rval = expandarg(&argc, &argv, i)) > 0)
73 ;
74 if (rval < 0) {
75 sprintf(errmsg, "cannot expand '%s'", argv[i]);
76 error(SYSTEM, errmsg);
77 }
78 if (argv[i] == NULL || argv[i][0] != '-')
79 break; /* break from options */
80 if (!strcmp(argv[i], "-version")) {
81 puts(VersionID);
82 quit(0);
83 }
84 if (!strcmp(argv[i], "-defaults") ||
85 !strcmp(argv[i], "-help")) {
86 printdefaults();
87 quit(0);
88 }
89 if (!strcmp(argv[i], "-devices")) {
90 printdevices();
91 quit(0);
92 }
93 rval = getrenderopt(argc-i, argv+i);
94 if (rval >= 0) {
95 i += rval;
96 continue;
97 }
98 rval = getviewopt(&ourview, argc-i, argv+i);
99 if (rval >= 0) {
100 i += rval;
101 continue;
102 }
103 switch (argv[i][1]) {
104 case 'v': /* view file */
105 if (argv[i][2] != 'f')
106 goto badopt;
107 check(3,"s");
108 rval = viewfile(argv[++i], &ourview, NULL);
109 if (rval < 0) {
110 sprintf(errmsg,
111 "cannot open view file \"%s\"",
112 argv[i]);
113 error(SYSTEM, errmsg);
114 } else if (rval == 0) {
115 sprintf(errmsg,
116 "bad view file \"%s\"",
117 argv[i]);
118 error(USER, errmsg);
119 }
120 break;
121 case 'b': /* grayscale */
122 bool(2,greyscale);
123 break;
124 case 'p': /* pixel */
125 switch (argv[i][2]) {
126 case 's': /* sample */
127 check(3,"i");
128 psample = atoi(argv[++i]);
129 break;
130 case 't': /* threshold */
131 check(3,"f");
132 maxdiff = atof(argv[++i]);
133 break;
134 case 'e': /* exposure */
135 check(3,"f");
136 exposure = atof(argv[++i]);
137 if (argv[i][0] == '+' || argv[i][0] == '-')
138 exposure = pow(2.0, exposure);
139 break;
140 default:
141 goto badopt;
142 }
143 break;
144 case 'w': /* warnings */
145 rval = erract[WARNING].pf != NULL;
146 bool(2,rval);
147 if (rval) erract[WARNING].pf = wputs;
148 else erract[WARNING].pf = NULL;
149 break;
150 case 'e': /* error file */
151 check(2,"s");
152 errfile = argv[++i];
153 break;
154 case 'o': /* output device */
155 check(2,"s");
156 dvcname = argv[++i];
157 break;
158 case 'R': /* render input file */
159 check(2,"s");
160 strcpy(rifname, argv[++i]);
161 break;
162 default:
163 goto badopt;
164 }
165 }
166 err = setview(&ourview); /* set viewing parameters */
167 if (err != NULL)
168 error(USER, err);
169 /* initialize object types */
170 initotypes();
171 /* initialize urand */
172 initurand(2048);
173 srandom(rand_samp ? (long)time(0) : 0L);
174 /* set up signal handling */
175 sigdie(SIGINT, "Interrupt");
176 sigdie(SIGHUP, "Hangup");
177 sigdie(SIGTERM, "Terminate");
178 sigdie(SIGPIPE, "Broken pipe");
179 sigdie(SIGALRM, "Alarm clock");
180 #ifdef SIGXCPU
181 sigdie(SIGXCPU, "CPU limit exceeded");
182 sigdie(SIGXFSZ, "File size exceeded");
183 #endif
184 /* open error file */
185 if (errfile != NULL) {
186 if (freopen(errfile, "a", stderr) == NULL)
187 quit(2);
188 fprintf(stderr, "**************\n*** PID %5d: ",
189 getpid());
190 printargs(argc, argv, stderr);
191 putc('\n', stderr);
192 fflush(stderr);
193 }
194 #ifdef NICE
195 nice(NICE); /* lower priority */
196 #endif
197 /* get octree */
198 if (i == argc)
199 octname = NULL;
200 else if (i == argc-1)
201 octname = argv[i];
202 else
203 goto badopt;
204 if (octname == NULL)
205 error(USER, "missing octree argument");
206 /* set up output */
207 SET_FILE_BINARY(stdout);
208 readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
209 nsceneobjs = nobjects;
210
211 marksources(); /* find and mark sources */
212
213 setambient(); /* initialize ambient calculation */
214
215 rview(); /* run interactive viewer */
216
217 ambsync(); /* flush ambient file */
218
219 quit(0);
220
221 badopt:
222 sprintf(errmsg, "command line error at '%s'", argv[i]);
223 error(USER, errmsg);
224 return 1; /* pro forma return */
225
226 #undef check
227 #undef bool
228 }
229
230
231 void
232 wputs( /* warning output function */
233 char *s
234 )
235 {
236 int lasterrno = errno;
237 eputs(s);
238 errno = lasterrno;
239 }
240
241
242 void
243 eputs( /* put string to stderr */
244 register char *s
245 )
246 {
247 static int midline = 0;
248
249 if (!*s)
250 return;
251 if (!midline++) {
252 fputs(progname, stderr);
253 fputs(": ", stderr);
254 }
255 fputs(s, stderr);
256 if (s[strlen(s)-1] == '\n') {
257 fflush(stderr);
258 midline = 0;
259 }
260 }
261
262
263 static void
264 onsig( /* fatal signal */
265 int signo
266 )
267 {
268 static int gotsig = 0;
269
270 if (gotsig++) /* two signals and we're gone! */
271 _exit(signo);
272
273 alarm(15); /* allow 15 seconds to clean up */
274 signal(SIGALRM, SIG_DFL); /* make certain we do die */
275 eputs("signal - ");
276 eputs(sigerr[signo]);
277 eputs("\n");
278 quit(3);
279 }
280
281
282 static void
283 sigdie( /* set fatal signal */
284 int signo,
285 char *msg
286 )
287 {
288 if (signal(signo, onsig) == SIG_IGN)
289 signal(signo, SIG_IGN);
290 sigerr[signo] = msg;
291 }
292
293
294 static void
295 printdefaults(void) /* print default values to stdout */
296 {
297 printf(greyscale ? "-b+\t\t\t\t# greyscale on\n" :
298 "-b-\t\t\t\t# greyscale off\n");
299 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
300 ourview.type==VT_PER ? "perspective" :
301 ourview.type==VT_PAR ? "parallel" :
302 ourview.type==VT_HEM ? "hemispherical" :
303 ourview.type==VT_ANG ? "angular" :
304 ourview.type==VT_CYL ? "cylindrical" :
305 "unknown");
306 printf("-vp %f %f %f\t# view point\n",
307 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
308 printf("-vd %f %f %f\t# view direction\n",
309 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
310 printf("-vu %f %f %f\t# view up\n",
311 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
312 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
313 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
314 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
315 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
316 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
317 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
318 printf("-pe %f\t\t\t# pixel exposure\n", exposure);
319 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
320 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
321 printf("-o %s\t\t\t\t# output device\n", dvcname);
322 printf(erract[WARNING].pf != NULL ?
323 "-w+\t\t\t\t# warning messages on\n" :
324 "-w-\t\t\t\t# warning messages off\n");
325 print_rdefaults();
326 }
