root/radiance/ray/src/rt/rvmain.c
Wed Apr 23 02:35:26 2025 UTC (12 days, 13 hours ago) by greg
Changes since 2.23: +1 -4 lines
Diff to previous 2.23 , to selected 2.17
fix: Added missing calls to initfunc()
Tue Apr 22 17:12:25 2025 UTC (12 days, 22 hours ago) by greg
Changes since 2.22: +23 -14 lines
Diff to previous 2.22 , to selected 2.17
Wed Oct 30 16:47:03 2024 UTC (6 months ago) by greg
Changes since 2.21: +3 -1 lines
Diff to previous 2.21 , to selected 2.17
fix(rpict,rtrace,rcontrib): Removed spurious warnings
Thu Jan 18 00:28:54 2024 UTC (15 months, 2 weeks ago) by greg
Changes since 2.20: +2 -3 lines
Diff to previous 2.20 , to selected 2.17
fix(rcontrib, rpict, rvu): Better check for spectral sampling
Wed Jan 17 01:31:08 2024 UTC (15 months, 2 weeks ago) by greg
Changes since 2.19: +6 -1 lines
Diff to previous 2.19 , to selected 2.17
fix(rpict,rvu,rcontrib): Fixed luminance estimate during spectral rendering
Mon Feb 6 22:40:21 2023 UTC (2 years, 2 months ago) by greg
Diff to previous 2.18 , to selected 2.17
Tue Jan 24 21:54:49 2023 UTC (2 years, 3 months ago) by greg
Diff to previous 2.17
Revision 2.17 - (view) (download) (annotate) - [selected]
Thu Aug 18 00:52:48 2016 UTC (8 years, 8 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16
Sat Mar 19 12:51:36 2016 UTC (9 years, 1 month ago) by schorsch
Changes since 2.15: +8 -3 lines
Diff to previous 2.15 , to selected 2.17
prepare for winrview integration
Thu Mar 10 18:25:46 2016 UTC (9 years, 1 month ago) by schorsch
Changes since 2.14: +5 -5 lines
Diff to previous 2.14 , to selected 2.17
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Sun Mar 6 01:13:18 2016 UTC (9 years, 2 months ago) by schorsch
Diff to previous 2.13 , to selected 2.17
Thu Apr 23 17:42:04 2015 UTC (10 years ago) by greg
Changes since 2.12: +2 -5 lines
Diff to previous 2.12 , to selected 2.17
Fixed assignment of octname and removed redundant call to ray_init_pmap()
Tue Feb 24 19:39:27 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.11: +8 -1 lines
Diff to previous 2.11 , to selected 2.17
Wed Oct 5 17:20:55 2011 UTC (13 years, 7 months ago) by greg
Changes since 2.10: +6 -2 lines
Diff to previous 2.10 , to selected 2.17
Windows compatibility changes from Bill Hoffman
Sat Dec 12 19:01:00 2009 UTC (15 years, 4 months ago) by greg
Diff to previous 2.9 , to selected 2.17
Thu Aug 21 07:05:59 2008 UTC (16 years, 8 months ago) by greg
Changes since 2.8: +55 -43 lines
Diff to previous 2.8 , to selected 2.17
Tue Mar 11 02:21:47 2008 UTC (17 years, 1 month ago) by greg
Diff to previous 2.7 , to selected 2.17
Wed Apr 5 06:22:57 2006 UTC (19 years, 1 month ago) by greg
Changes since 2.6: +8 -3 lines
Diff to previous 2.6 , to selected 2.17
Made -u+ option truly random
Tue Jun 21 00:26:44 2005 UTC (19 years, 10 months ago) by greg
Diff to previous 2.5 , to selected 2.17
Wed Jun 15 15:36:52 2005 UTC (19 years, 10 months ago) by greg
Diff to previous 2.4 , to selected 2.17
Changes since 2.3: +24 -22 lines
Diff to previous 2.3 , to selected 2.17
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.2: +5 -11 lines
Diff to previous 2.2 , to selected 2.17
Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.1 , to selected 2.17
Diff to selected 2.17
