root/radiance/ray/src/rt/rvmain.c
Revision: 2.17
Committed: Thu Aug 18 00:52:48 2016 UTC (7 years, 9 months ago) by greg
CVS Tags: rad5R2, rad5R1, rad5R3
Changes since 2.16: +2 -1 lines
2 static const char RCSid[] = "$Id: rvmain.c,v 2.16 2016/03/19 12:51:36 schorsch Exp $";
5 * rvmain.c - main for rview interactive viewer
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11 #include <time.h>
12
13 #include "platform.h"
14 #include "ray.h"
15 #include "source.h"
16 #include "ambient.h"
17 #include "rpaint.h"
18 #include "random.h"
19 #include "paths.h"
20 #include "view.h"
21 #include "pmapray.h"
22
23 extern char *progname; /* global argv[0] */
24
25 VIEW ourview = STDVIEW; /* viewing parameters */
26 int hresolu, vresolu; /* image resolution */
27
28 int psample = 8; /* pixel sample size */
29 double maxdiff = .15; /* max. sample difference */
30
31 int greyscale = 0; /* map colors to brightness? */
32 char *dvcname = dev_default; /* output device name */
33
34 double exposure = 1.0; /* exposure for scene */
35
36 int newparam = 1; /* parameter setting changed */
37
38 struct driver *dev = NULL; /* driver functions */
39
40 char rifname[128]; /* rad input file name */
41
42 VIEW oldview; /* previous view parameters */
43
44 PNODE ptrunk; /* the base of our image */
45 RECT pframe; /* current frame boundaries */
46 int pdepth; /* image depth in current frame */
47
48 char *errfile = NULL; /* error output file */
49
50 int nproc = 1; /* number of processes */
51
52 char *sigerr[NSIG]; /* signal error messages */
53
54 static void onsig(int signo);
55 static void sigdie(int signo, char *msg);
56 static void printdefaults(void);
57
58 int
59 main(int argc, char *argv[])
60 {
61 #define check(ol,al) if (argv[i][ol] || \
62 badarg(argc-i-1,argv+i+1,al)) \
63 goto badopt
64 #define check_bool(olen,var) switch (argv[i][olen]) { \
65 case '\0': var = !var; break; \
66 case 'y': case 'Y': case 't': case 'T': \
67 case '+': case '1': var = 1; break; \
68 case 'n': case 'N': case 'f': case 'F': \
69 case '-': case '0': var = 0; break; \
70 default: goto badopt; }
71 char *octnm = NULL;
72 char *err;
73 int rval;
74 int i;
75 /* global program name */
76 progname = argv[0] = fixargv0(argv[0]);
77 /* set our defaults */
78 shadthresh = .1;
79 shadcert = .25;
80 directrelay = 0;
81 vspretest = 128;
82 srcsizerat = 0.;
83 specthresh = .3;
84 specjitter = 1.;
85 maxdepth = 6;
86 minweight = 1e-2;
87 ambacc = 0.3;
88 ambres = 32;
89 ambdiv = 256;
90 ambssamp = 64;
91 /* option city */
92 for (i = 1; i < argc; i++) {
93 /* expand arguments */
94 while ((rval = expandarg(&argc, &argv, i)) > 0)
95 ;
96 if (rval < 0) {
97 sprintf(errmsg, "cannot expand '%s'", argv[i]);
98 error(SYSTEM, errmsg);
99 }
100 if (argv[i] == NULL || argv[i][0] != '-')
101 break; /* break from options */
102 if (!strcmp(argv[i], "-version")) {
103 puts(VersionID);
104 quit(0);
105 }
106 if (!strcmp(argv[i], "-defaults") ||
107 !strcmp(argv[i], "-help")) {
108 printdefaults();
109 quit(0);
110 }
111 if (!strcmp(argv[i], "-devices")) {
112 printdevices();
113 quit(0);
114 }
115 rval = getrenderopt(argc-i, argv+i);
116 if (rval >= 0) {
117 i += rval;
118 continue;
119 }
120 rval = getviewopt(&ourview, argc-i, argv+i);
121 if (rval >= 0) {
122 i += rval;
123 continue;
124 }
125 switch (argv[i][1]) {
126 case 'n': /* # processes */
127 check(2,"i");
128 nproc = atoi(argv[++i]);
129 if (nproc <= 0)
130 error(USER, "bad number of processes");
131 break;
132 case 'v': /* view file */
133 if (argv[i][2] != 'f')
134 goto badopt;
135 check(3,"s");
136 rval = viewfile(argv[++i], &ourview, NULL);
137 if (rval < 0) {
138 sprintf(errmsg,
139 "cannot open view file \"%s\"",
140 argv[i]);
141 error(SYSTEM, errmsg);
142 } else if (rval == 0) {
143 sprintf(errmsg,
144 "bad view file \"%s\"",
145 argv[i]);
146 error(USER, errmsg);
147 }
148 break;
149 case 'b': /* grayscale */
150 check_bool(2,greyscale);
151 break;
152 case 'p': /* pixel */
153 switch (argv[i][2]) {
154 case 's': /* sample */
155 check(3,"i");
156 psample = atoi(argv[++i]);
157 break;
158 case 't': /* threshold */
159 check(3,"f");
160 maxdiff = atof(argv[++i]);
161 break;
162 case 'e': /* exposure */
163 check(3,"f");
164 exposure = atof(argv[++i]);
165 if (argv[i][0] == '+' || argv[i][0] == '-')
166 exposure = pow(2.0, exposure);
167 break;
168 default:
169 goto badopt;
170 }
171 break;
172 case 'w': /* warnings */
173 rval = erract[WARNING].pf != NULL;
174 check_bool(2,rval);
175 if (rval) erract[WARNING].pf = wputs;
176 else erract[WARNING].pf = NULL;
177 break;
178 case 'e': /* error file */
179 check(2,"s");
180 errfile = argv[++i];
181 break;
182 case 'o': /* output device */
183 check(2,"s");
184 dvcname = argv[++i];
185 break;
186 case 'R': /* render input file */
187 check(2,"s");
188 strcpy(rifname, argv[++i]);
189 break;
190 default:
191 goto badopt;
192 }
193 }
194 err = setview(&ourview); /* set viewing parameters */
195 if (err != NULL)
196 error(USER, err);
197 /* set up signal handling */
198 sigdie(SIGINT, "Interrupt");
199 sigdie(SIGTERM, "Terminate");
200 #if !defined(_WIN32) && !defined(_WIN64)
201 sigdie(SIGHUP, "Hangup");
202 sigdie(SIGPIPE, "Broken pipe");
203 sigdie(SIGALRM, "Alarm clock");
204 #endif
205 /* open error file */
206 if (errfile != NULL) {
207 if (freopen(errfile, "a", stderr) == NULL)
208 quit(2);
209 fprintf(stderr, "**************\n*** PID %5d: ",
210 getpid());
211 printargs(argc, argv, stderr);
212 putc('\n', stderr);
213 fflush(stderr);
214 }
215 #ifdef NICE
216 nice(NICE); /* lower priority */
217 #endif
218 /* get octree */
219 if (i == argc)
220 octnm = NULL;
221 else if (i == argc-1)
222 octnm = argv[i];
223 else
224 goto badopt;
225 if (octnm == NULL)
226 error(USER, "missing octree argument");
227 /* set up output & start process(es) */
228 SET_FILE_BINARY(stdout);
229
230 ray_init(octnm); /* also calls ray_init_pmap() */
231
232 /* temporary shortcut, until winrview is refactored into a "device" */
233 #ifndef WIN_RVIEW
234 rview(); /* run interactive viewer */
235
236
237 devclose(); /* close output device */
238 #endif
239
240 /* PMAP: free photon maps */
241 ray_done_pmap();
242
243 #ifdef WIN_RVIEW
244 return 1;
245 #endif
246 quit(0);
247
248 badopt:
249 sprintf(errmsg, "command line error at '%s'", argv[i]);
250 error(USER, errmsg);
251 return 1; /* pro forma return */
252
253 #undef check
254 #undef check_bool
255 }
256
257
258 void
259 wputs( /* warning output function */
260 char *s
261 )
262 {
263 int lasterrno = errno;
264 eputs(s);
265 errno = lasterrno;
266 }
267
268
269 void
270 eputs( /* put string to stderr */
271 char *s
272 )
273 {
274 static int midline = 0;
275
276 if (!*s)
277 return;
278 if (!midline++) {
279 fputs(progname, stderr);
280 fputs(": ", stderr);
281 }
282 fputs(s, stderr);
283 if (s[strlen(s)-1] == '\n') {
284 fflush(stderr);
285 midline = 0;
286 }
287 }
288
289
290 static void
291 onsig( /* fatal signal */
292 int signo
293 )
294 {
295 static int gotsig = 0;
296
297 if (gotsig++) /* two signals and we're gone! */
298 _exit(signo);
299
300 #if !defined(_WIN32) && !defined(_WIN64)
301 alarm(15); /* allow 15 seconds to clean up */
302 signal(SIGALRM, SIG_DFL); /* make certain we do die */
303 #endif
304 eputs("signal - ");
305 eputs(sigerr[signo]);
306 eputs("\n");
307 devclose();
308 quit(3);
309 }
310
311
312 static void
313 sigdie( /* set fatal signal */
314 int signo,
315 char *msg
316 )
317 {
318 if (signal(signo, onsig) == SIG_IGN)
319 signal(signo, SIG_IGN);
320 sigerr[signo] = msg;
321 }
322
323
324 static void
325 printdefaults(void) /* print default values to stdout */
326 {
327 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
328 printf(greyscale ? "-b+\t\t\t\t# greyscale on\n" :
329 "-b-\t\t\t\t# greyscale off\n");
330 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
331 ourview.type==VT_PER ? "perspective" :
332 ourview.type==VT_PAR ? "parallel" :
333 ourview.type==VT_HEM ? "hemispherical" :
334 ourview.type==VT_ANG ? "angular" :
335 ourview.type==VT_CYL ? "cylindrical" :
336 ourview.type==VT_PLS ? "planisphere" :
337 "unknown");
338 printf("-vp %f %f %f\t# view point\n",
339 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
340 printf("-vd %f %f %f\t# view direction\n",
341 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
342 printf("-vu %f %f %f\t# view up\n",
343 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
344 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
345 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
346 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
347 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
348 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
349 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
350 printf("-pe %f\t\t\t# pixel exposure\n", exposure);
351 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
352 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
353 printf("-o %s\t\t\t\t# output device\n", dvcname);
354 printf(erract[WARNING].pf != NULL ?
355 "-w+\t\t\t\t# warning messages on\n" :
356 "-w-\t\t\t\t# warning messages off\n");
357 print_rdefaults();
358 }
