root/radiance/ray/src/rt/rview.c
Sat Dec 12 23:08:13 2009 UTC (14 years, 4 months ago) by greg
Changes since 2.32: +4 -3 lines
Diff to previous 2.32
Bug fixes and performance improvements to rtrace -n option
Sat Dec 12 19:01:00 2009 UTC (14 years, 4 months ago) by greg
Changes since 2.31: +16 -1 lines
Diff to previous 2.31
Fri Sep 5 19:45:42 2008 UTC (15 years, 7 months ago) by greg
Changes since 2.30: +1 -8 lines
Diff to previous 2.30
Fixed bug that broke "exposure" command
Fri Aug 22 17:39:26 2008 UTC (15 years, 8 months ago) by greg
Changes since 2.29: +4 -3 lines
Diff to previous 2.29
Further improvements to interactivity
Thu Aug 21 07:05:59 2008 UTC (15 years, 8 months ago) by greg
Changes since 2.28: +64 -172 lines
Diff to previous 2.28
Mon Jun 13 20:07:56 2005 UTC (18 years, 10 months ago) by greg
Diff to previous 2.27
Fri Jan 21 00:52:59 2005 UTC (19 years, 3 months ago) by greg
Changes since 2.26: +9 -5 lines
Diff to previous 2.26
Fri Nov 5 17:36:56 2004 UTC (19 years, 5 months ago) by greg
Diff to previous 2.25
Sun Mar 28 16:31:14 2004 UTC (20 years ago) by greg
Changes since 2.24: +4 -4 lines
Diff to previous 2.24
Diff to previous 2.23
Changes since 2.22: +3 -2 lines
Diff to previous 2.22
Thu Jul 3 15:00:19 2003 UTC (20 years, 9 months ago) by greg
Changes since 2.21: +1 -2 lines
Diff to previous 2.21
Wed Jul 2 01:15:20 2003 UTC (20 years, 9 months ago) by greg
Changes since 2.20: +1 -3 lines
Diff to previous 2.20
Fixed broken use of RHAS_FORK_EXEC
Mon Jun 30 14:59:13 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 2.19: +6 -6 lines
Diff to previous 2.19
Tue Feb 25 02:47:23 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.18: +1 -56 lines
Diff to previous 2.18
Changes since 2.17: +88 -14 lines
Diff to previous 2.17
Wed Apr 17 14:02:16 1996 UTC (28 years ago) by greg
Diff to previous 2.16
Wed Feb 14 15:18:09 1996 UTC (28 years, 2 months ago) by greg
Changes since 2.15: +1 -0 lines
Diff to previous 2.15
Fri Dec 8 18:49:24 1995 UTC (28 years, 4 months ago) by greg
Changes since 2.14: +6 -1 lines
Diff to previous 2.14
Wed Dec 21 09:52:07 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.13: +2 -0 lines
Diff to previous 2.13
added -bv option for back face visibility (normally on)
Wed Sep 14 18:35:21 1994 UTC (29 years, 7 months ago) by greg
Changes since 2.12: +19 -6 lines
Diff to previous 2.12
added "redraw" and "stop" and "pause" equivalents to ^R, ^Z and ^C
Tue Sep 7 16:11:12 1993 UTC (30 years, 7 months ago) by greg
bug fix for 16-bit integers in psample()
Wed Aug 25 13:44:17 1993 UTC (30 years, 8 months ago) by greg
Changes since 2.10: +12 -0 lines
added -R option and L and V commands for rview
Wed Feb 10 14:03:01 1993 UTC (31 years, 2 months ago) by greg
Changes since 2.9: +12 -4 lines
Thu Nov 19 20:25:55 1992 UTC (31 years, 5 months ago) by greg
changed -di to ! -dv
Mon Sep 21 12:08:00 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.7: +20 -18 lines
Changes for PC port
Wed Sep 9 22:19:42 1992 UTC (31 years, 7 months ago) by greg
minor oversight in rsample()
Thu Jan 16 12:05:26 1992 UTC (32 years, 3 months ago) by greg
changed default values and handling of specthresh
Tue Jan 14 16:16:00 1992 UTC (32 years, 3 months ago) by greg
added -sj and -st options and changed old -s options to -p
Mon Dec 23 23:18:29 1991 UTC (32 years, 4 months ago) by greg
Changes since 2.3: +4 -4 lines
fixed CTRL(c) macro for ANSII compilers
Thu Dec 19 14:54:46 1991 UTC (32 years, 4 months ago) by greg
removed atof() declarations for NeXT
Mon Nov 25 10:11:01 1991 UTC (32 years, 5 months ago) by greg
Changes since 2.1: +9 -0 lines
added "memory" command to report memory statistics (#define MSTATS)
Tue Nov 12 17:08:43 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.21
Mon Oct 21 12:58:00 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.20: +1 -0 lines
Diff to previous 1.20
Mon Aug 26 12:53:17 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.19: +4 -4 lines
Diff to previous 1.19
improved memory handing
Thu Jul 18 14:42:58 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.18: +1 -0 lines
Diff to previous 1.18
Tue Jun 25 14:06:15 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.17
increased defaults for -dp parameter
Mon Jun 24 16:10:49 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.16: +1 -0 lines
Diff to previous 1.16
Wed Jun 19 16:36:39 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.15: +1 -0 lines
Diff to previous 1.15
added virtual sources
Tue May 21 17:41:32 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.14: +5 -3 lines
Diff to previous 1.14
Fri May 3 16:12:34 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.13: +19 -27 lines
Diff to previous 1.13
Fri May 3 15:43:32 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.12: +7 -2 lines
Diff to previous 1.12
added longjmp for memory errors
Fri May 3 15:22:24 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.11: +31 -3 lines
Diff to previous 1.11
added minimal memory recovery
Fri Mar 9 14:00:06 1990 UTC (34 years, 1 month ago) by greg
Diff to previous 1.10
moved naming of default device to devtable.c
Tue Jan 30 11:37:41 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.9: +1 -2 lines
Diff to previous 1.9
Mon Jan 8 13:38:12 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.8: +15 -17 lines
Diff to previous 1.8
Fri Oct 27 11:48:25 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.7: +7 -3 lines
Diff to previous 1.7
added repaint command
Wed Oct 25 15:37:19 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.6: +4 -6 lines
Diff to previous 1.6
Sat Jul 29 00:11:31 1989 UTC (34 years, 9 months ago) by greg
Changes since 1.5: +6 -5 lines
Diff to previous 1.5
Changed identifier to use octree name for client ID
Mon Jul 10 15:21:25 1989 UTC (34 years, 9 months ago) by greg
Diff to previous 1.4
Reduced default ambient resolution
Tue Jun 13 10:57:49 1989 UTC (34 years, 10 months ago) by greg
Diff to previous 1.3
Wed Jun 7 21:00:54 1989 UTC (34 years, 10 months ago) by greg
Wed Jun 7 08:35:29 1989 UTC (34 years, 10 months ago) by greg
Glow type changed
Spot type eliminated
Thu Feb 2 10:41:39 1989 UTC (35 years, 2 months ago) by greg
