root/radiance/ray/src/rt/rview.c
Revision: 2.25
Committed: Sun Mar 28 16:31:14 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.24: +4 -4 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.25 static const char RCSid[] = "$Id: rview.c,v 2.24 2003/09/24 14:55:54 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * rview.c - routines and variables for interactive view generation.
6     *
7 greg 2.18 * External symbols declared in rpaint.h
8     */
9
10 greg 2.19 #include "copyright.h"
11 greg 1.1
12 schorsch 2.20 #include <signal.h>
13     #include <ctype.h>
14
15 greg 1.15 #include "ray.h"
16 greg 1.1 #include "rpaint.h"
17
18
19 greg 2.18 CUBE thescene; /* our scene */
20     OBJECT nsceneobjs; /* number of objects in our scene */
21 greg 1.15
22     int dimlist[MAXDIM]; /* sampling dimensions */
23     int ndims = 0; /* number of sampling dimensions */
24     int samplendx = 0; /* index for this sample */
25 greg 1.1
26 greg 2.18 extern void ambnotify();
27     void (*addobjnotify[])() = {ambnotify, NULL};
28
29     VIEW ourview = STDVIEW; /* viewing parameters */
30     int hresolu, vresolu; /* image resolution */
31
32     void (*trace)() = NULL; /* trace call */
33
34     int do_irrad = 0; /* compute irradiance? */
35
36 greg 1.1 int psample = 8; /* pixel sample size */
37 greg 2.8 double maxdiff = .15; /* max. sample difference */
38 greg 1.1
39 greg 2.8 double exposure = 1.0; /* exposure for scene */
40 greg 1.1
41 greg 2.8 double dstrsrc = 0.0; /* square source distribution */
42     double shadthresh = .1; /* shadow threshold */
43     double shadcert = .25; /* shadow certainty */
44 greg 1.16 int directrelay = 0; /* number of source relays */
45 greg 1.18 int vspretest = 128; /* virtual source pretest density */
46 greg 2.9 int directvis = 1; /* sources visible? */
47 greg 2.8 double srcsizerat = 0.; /* maximum ratio source size/dist. */
48 greg 2.15
49     COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
50 greg 2.17 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
51 greg 2.15 double seccg = 0.; /* global scattering eccentricity */
52     double ssampdist = 0.; /* scatter sampling distance */
53 greg 1.1
54 greg 2.8 double specthresh = .3; /* specular sampling threshold */
55     double specjitter = 1.; /* specular sampling jitter */
56 greg 2.5
57 greg 2.14 int backvis = 1; /* back face visibility */
58
59 greg 2.24 int maxdepth = 6; /* maximum recursion depth */
60 greg 2.8 double minweight = 1e-2; /* minimum ray weight */
61 greg 1.1
62 greg 2.18 char *ambfile = NULL; /* ambient file name */
63 greg 1.1 COLOR ambval = BLKCOLOR; /* ambient value */
64 greg 2.16 int ambvwt = 0; /* initial weight for ambient value */
65 greg 2.25 double ambacc = 0.3; /* ambient accuracy */
66 greg 2.24 int ambres = 32; /* ambient resolution */
67 greg 2.25 int ambdiv = 256; /* ambient divisions */
68     int ambssamp = 64; /* ambient super-samples */
69 greg 1.1 int ambounce = 0; /* ambient bounces */
70     char *amblist[128]; /* ambient include/exclude list */
71     int ambincl = -1; /* include == 1, exclude == 0 */
72
73     int greyscale = 0; /* map colors to brightness? */
74 greg 2.18 char *dvcname = dev_default; /* output device name */
75 greg 1.1
76     struct driver *dev = NULL; /* driver functions */
77
78 greg 2.11 char rifname[128]; /* rad input file name */
79
80 greg 1.1 VIEW oldview; /* previous view parameters */
81
82     PNODE ptrunk; /* the base of our image */
83     RECT pframe; /* current frame boundaries */
84     int pdepth; /* image depth in current frame */
85
86 greg 1.12 static char *reserve_mem = NULL; /* pre-allocated reserve memory */
87
88 greg 1.20 #define RESERVE_AMT 32768 /* amount of memory to reserve */
89 greg 1.12
90 greg 2.8 #define CTRL(c) ((c)-'@')
91 greg 1.1
92
93 greg 2.18 void
94 greg 1.1 quit(code) /* quit program */
95     int code;
96     {
97 greg 2.10 #ifdef MSTATS
98     if (code == 2 && errno == ENOMEM)
99     printmemstats(stderr);
100     #endif
101 greg 1.1 devclose();
102     exit(code);
103     }
104
105
106 greg 2.18 void
107 greg 1.1 devopen(dname) /* open device driver */
108     char *dname;
109     {
110 greg 1.6 extern char *progname, *octname;
111 greg 1.7 char *id;
112 greg 1.1 register int i;
113 greg 1.6
114 greg 1.7 id = octname!=NULL ? octname : progname;
115 greg 1.1 /* check device table */
116     for (i = 0; devtable[i].name; i++)
117 schorsch 2.23 if (!strcmp(dname, devtable[i].name)) {
118 greg 1.7 if ((dev = (*devtable[i].init)(dname, id)) == NULL) {
119 greg 1.1 sprintf(errmsg, "cannot initialize %s", dname);
120     error(USER, errmsg);
121     } else
122     return;
123 schorsch 2.23 }
124 greg 1.1 /* not there, try exec */
125 greg 1.7 if ((dev = comm_init(dname, id)) == NULL) {
126 greg 1.1 sprintf(errmsg, "cannot start device \"%s\"", dname);
127     error(USER, errmsg);
128     }
129     }
130
131
132 greg 2.18 void
133 greg 1.1 devclose() /* close our device */
134     {
135     if (dev != NULL)
136     (*dev->close)();
137     dev = NULL;
138     }
139
140
141 greg 2.18 void
142 greg 1.1 printdevices() /* print list of output devices */
143     {
144     register int i;
145
146     for (i = 0; devtable[i].name; i++)
147     printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
148     }
149
150
151 greg 2.18 void
152 greg 1.1 rview() /* do a view */
153     {
154     char buf[32];
155
156 greg 2.18 devopen(dvcname); /* open device */
157 greg 1.14 newimage(); /* start image (calls fillreserves) */
158
159 greg 1.1 for ( ; ; ) { /* quit in command() */
160 greg 1.14 while (hresolu <= 1<<pdepth && vresolu <= 1<<pdepth)
161 greg 1.1 command("done: ");
162 greg 1.14 while (reserve_mem == NULL)
163     command("out of memory: ");
164     errno = 0;
165     if (hresolu <= psample<<pdepth && vresolu <= psample<<pdepth) {
166 greg 1.1 sprintf(buf, "%d sampling...\n", 1<<pdepth);
167     (*dev->comout)(buf);
168     rsample();
169     } else {
170     sprintf(buf, "%d refining...\n", 1<<pdepth);
171     (*dev->comout)(buf);
172 greg 1.9 refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1);
173 greg 1.1 }
174 greg 1.14 if (errno == ENOMEM) /* ran out of memory */
175     freereserves();
176     else if (dev->inpready) /* noticed some input */
177 greg 1.1 command(": ");
178 greg 1.14 else /* finished this depth */
179 greg 1.1 pdepth++;
180     }
181     }
182
183
184 greg 2.18 void
185 greg 1.14 fillreserves() /* fill memory reserves */
186 greg 1.12 {
187     if (reserve_mem != NULL)
188 greg 1.14 return;
189 greg 2.18 reserve_mem = (char *)malloc(RESERVE_AMT);
190 greg 1.12 }
191
192
193 greg 2.18 void
194 greg 1.14 freereserves() /* free memory reserves */
195 greg 1.12 {
196 greg 1.14 if (reserve_mem == NULL)
197     return;
198 greg 1.12 free(reserve_mem);
199     reserve_mem = NULL;
200     }
201
202
203 greg 2.18 void
204 greg 1.1 command(prompt) /* get/execute command */
205     char *prompt;
206     {
207 greg 2.8 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
208 greg 1.1 char inpbuf[256];
209     char *args;
210     again:
211 greg 1.10 (*dev->comin)(inpbuf, prompt); /* get command + arguments */
212 greg 1.1 for (args = inpbuf; *args && *args != ' '; args++)
213     ;
214     if (*args) *args++ = '\0';
215     else *++args = '\0';
216
217     switch (inpbuf[0]) {
218 greg 2.10 case 'f': /* new frame (or free mem.) */
219     if (badcom("frame")) {
220     if (badcom("free"))
221     goto commerr;
222     free_objmem();
223     break;
224     }
225 greg 1.1 getframe(args);
226     break;
227     case 'v': /* view */
228     if (badcom("view"))
229     goto commerr;
230     getview(args);
231     break;
232     case 'l': /* last view */
233     if (badcom("last"))
234     goto commerr;
235     lastview(args);
236 greg 2.11 break;
237     case 'V': /* save view */
238     if (badcom("V"))
239     goto commerr;
240     saveview(args);
241     break;
242     case 'L': /* load view */
243     if (badcom("L"))
244     goto commerr;
245     loadview(args);
246 greg 1.1 break;
247     case 'e': /* exposure */
248     if (badcom("exposure"))
249     goto commerr;
250     getexposure(args);
251     break;
252     case 's': /* set a parameter */
253 greg 2.13 if (badcom("set")) {
254     #ifdef SIGTSTP
255     if (!badcom("stop"))
256     goto dostop;
257     #endif
258 greg 1.1 goto commerr;
259 greg 2.13 }
260 greg 1.1 setparam(args);
261     break;
262     case 'n': /* new picture */
263     if (badcom("new"))
264     goto commerr;
265     newimage();
266     break;
267     case 't': /* trace a ray */
268     if (badcom("trace"))
269     goto commerr;
270     traceray(args);
271     break;
272     case 'a': /* aim camera */
273     if (badcom("aim"))
274     goto commerr;
275     getaim(args);
276     break;
277 greg 2.10 case 'm': /* move camera (or memstats) */
278 greg 1.1 if (badcom("move"))
279 greg 2.8 #ifdef MSTATS
280 greg 2.2 {
281     if (badcom("memory"))
282     goto commerr;
283     printmemstats(stderr);
284     break;
285     }
286     #else
287 greg 1.1 goto commerr;
288 greg 2.2 #endif
289 greg 1.1 getmove(args);
290     break;
291 greg 1.8 case 'r': /* rotate/repaint */
292     if (badcom("rotate")) {
293 greg 2.13 if (badcom("repaint")) {
294     if (badcom("redraw"))
295     goto commerr;
296     redraw();
297     break;
298     }
299 greg 1.8 getrepaint(args);
300     break;
301     }
302 greg 1.1 getrotate(args);
303     break;
304     case 'p': /* pivot view */
305 greg 2.13 if (badcom("pivot")) {
306     if (badcom("pause"))
307     goto commerr;
308     goto again;
309     }
310 greg 1.1 getpivot(args);
311     break;
312 greg 2.4 case CTRL('R'): /* redraw */
313 greg 1.1 redraw();
314     break;
315     case 'w': /* write */
316     if (badcom("write"))
317     goto commerr;
318     writepict(args);
319     break;
320     case 'q': /* quit */
321     if (badcom("quit"))
322     goto commerr;
323     quit(0);
324 greg 2.4 case CTRL('C'): /* interrupt */
325 greg 1.1 goto again;
326 greg 2.8 #ifdef SIGTSTP
327 greg 2.13 case CTRL('Z'):; /* stop */
328     dostop:
329 greg 1.1 devclose();
330     kill(0, SIGTSTP);
331     /* pc stops here */
332 greg 2.18 devopen(dvcname);
333 greg 1.1 redraw();
334     break;
335     #endif
336     case '\0': /* continue */
337     break;
338     default:;
339     commerr:
340     if (iscntrl(inpbuf[0]))
341     sprintf(errmsg, "^%c: unknown control",
342     inpbuf[0]|0100);
343     else
344     sprintf(errmsg, "%s: unknown command", inpbuf);
345     error(COMMAND, errmsg);
346     break;
347     }
348 greg 2.8 #undef badcom
349 greg 1.1 }
350
351
352 greg 2.18 void
353 greg 1.1 rsample() /* sample the image */
354     {
355     int xsiz, ysiz, y;
356     RECT r;
357     PNODE *p;
358     register RECT *rl;
359 greg 2.8 register PNODE **pl;
360 greg 1.1 register int x;
361     /*
362     * We initialize the bottom row in the image at our current
363 greg 2.8 * resolution. During sampling, we check super-pixels to the
364 greg 1.1 * right and above by calling bigdiff(). If there is a significant
365     * difference, we subsample the super-pixels. The testing process
366     * includes initialization of the next row.
367     */
368 greg 2.12 xsiz = (((long)(pframe.r-pframe.l)<<pdepth)+hresolu-1) / hresolu;
369     ysiz = (((long)(pframe.u-pframe.d)<<pdepth)+vresolu-1) / vresolu;
370 greg 1.1 rl = (RECT *)malloc(xsiz*sizeof(RECT));
371 greg 1.12 if (rl == NULL)
372 greg 1.14 return;
373 greg 1.1 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
374 greg 2.7 if (pl == NULL) {
375 greg 2.18 free((void *)rl);
376 greg 1.14 return;
377 greg 2.7 }
378 greg 1.1 /*
379     * Initialize the bottom row.
380     */
381     rl[0].l = rl[0].d = 0;
382 greg 1.9 rl[0].r = hresolu; rl[0].u = vresolu;
383 greg 1.1 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
384     for (x = 1; x < xsiz; x++) {
385     rl[x].l = rl[x].d = 0;
386 greg 1.9 rl[x].r = hresolu; rl[x].u = vresolu;
387     pl[x] = findrect(pframe.l+((x*hresolu)>>pdepth),
388 greg 1.1 pframe.d, &ptrunk, rl+x, pdepth);
389     }
390     /* sample the image */
391     for (y = 0; /* y < ysiz */ ; y++) {
392     for (x = 0; x < xsiz-1; x++) {
393 greg 1.20 if (dev->inpready || errno == ENOMEM)
394 greg 1.1 goto escape;
395     /*
396     * Test super-pixel to the right.
397     */
398     if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
399     pl[x+1]->v, maxdiff)) {
400     refine(pl[x], rl[x].l, rl[x].d,
401     rl[x].r, rl[x].u, 1);
402     refine(pl[x+1], rl[x+1].l, rl[x+1].d,
403     rl[x+1].r, rl[x+1].u, 1);
404     }
405     }
406     if (y >= ysiz-1)
407     break;
408     for (x = 0; x < xsiz; x++) {
409 greg 1.20 if (dev->inpready || errno == ENOMEM)
410 greg 1.1 goto escape;
411     /*
412     * Find super-pixel at this position in next row.
413     */
414     r.l = r.d = 0;
415 greg 1.9 r.r = hresolu; r.u = vresolu;
416     p = findrect(pframe.l+((x*hresolu)>>pdepth),
417     pframe.d+(((y+1)*vresolu)>>pdepth),
418 greg 1.1 &ptrunk, &r, pdepth);
419     /*
420     * Test super-pixel in next row.
421     */
422     if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
423     refine(pl[x], rl[x].l, rl[x].d,
424     rl[x].r, rl[x].u, 1);
425     refine(p, r.l, r.d, r.r, r.u, 1);
426     }
427     /*
428     * Copy into super-pixel array.
429     */
430     rl[x].l = r.l; rl[x].d = r.d;
431     rl[x].r = r.r; rl[x].u = r.u;
432     pl[x] = p;
433     }
434     }
435     escape:
436 greg 2.18 free((void *)rl);
437     free((void *)pl);
438 greg 1.1 }
439
440
441     int
442     refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
443 greg 2.8 register PNODE *p;
444 greg 1.1 int xmin, ymin, xmax, ymax;
445     int pd;
446     {
447     int growth;
448     int mx, my;
449     int i;
450
451     if (dev->inpready) /* quit for input */
452     return(0);
453
454     if (pd <= 0) /* depth limit */
455     return(0);
456
457     mx = (xmin + xmax) >> 1;
458     my = (ymin + ymax) >> 1;
459     growth = 0;
460
461     if (p->kid == NULL) { /* subdivide */
462
463     if ((p->kid = newptree()) == NULL)
464 greg 1.20 return(0);
465 greg 1.1 /*
466     * The following paint order can leave a black pixel
467 greg 2.7 * if redraw() is called in (*dev->paintr)().
468 greg 1.1 */
469     if (p->x >= mx && p->y >= my)
470     pcopy(p, p->kid+UR);
471     else
472     paint(p->kid+UR, mx, my, xmax, ymax);
473     if (p->x < mx && p->y >= my)
474     pcopy(p, p->kid+UL);
475     else
476     paint(p->kid+UL, xmin, my, mx, ymax);
477     if (p->x >= mx && p->y < my)
478     pcopy(p, p->kid+DR);
479     else
480     paint(p->kid+DR, mx, ymin, xmax, my);
481     if (p->x < mx && p->y < my)
482     pcopy(p, p->kid+DL);
483     else
484     paint(p->kid+DL, xmin, ymin, mx, my);
485
486     growth++;
487     }
488     /* do children */
489     if (mx > pframe.l) {
490     if (my > pframe.d)
491     growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
492     if (my < pframe.u)
493     growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
494     }
495     if (mx < pframe.r) {
496     if (my > pframe.d)
497     growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
498     if (my < pframe.u)
499     growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
500     }
501     /* recompute sum */
502     if (growth) {
503     setcolor(p->v, 0.0, 0.0, 0.0);
504     for (i = 0; i < 4; i++)
505     addcolor(p->v, p->kid[i].v);
506     scalecolor(p->v, 0.25);
507     }
508     return(growth);
509     }
