| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rview.c,v 2.25 2004/03/28 16:31:14 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rview.c - routines and variables for interactive view generation.
| 6 |
| 7 |
* External symbols declared in rpaint.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#include <signal.h>
| 13 |
#include <ctype.h>
| 14 |
| 15 |
#include "ray.h"
| 16 |
#include "rpaint.h"
| 17 |
| 18 |
| 19 |
CUBE thescene; /* our scene */
| 20 |
OBJECT nsceneobjs; /* number of objects in our scene */
| 21 |
| 22 |
int dimlist[MAXDIM]; /* sampling dimensions */
| 23 |
int ndims = 0; /* number of sampling dimensions */
| 24 |
int samplendx = 0; /* index for this sample */
| 25 |
| 26 |
extern void ambnotify();
| 27 |
void (*addobjnotify[])() = {ambnotify, NULL};
| 28 |
| 29 |
VIEW ourview = STDVIEW; /* viewing parameters */
| 30 |
int hresolu, vresolu; /* image resolution */
| 31 |
| 32 |
void (*trace)() = NULL; /* trace call */
| 33 |
| 34 |
int do_irrad = 0; /* compute irradiance? */
| 35 |
| 36 |
int psample = 8; /* pixel sample size */
| 37 |
double maxdiff = .15; /* max. sample difference */
| 38 |
| 39 |
double exposure = 1.0; /* exposure for scene */
| 40 |
| 41 |
double dstrsrc = 0.0; /* square source distribution */
| 42 |
double shadthresh = .1; /* shadow threshold */
| 43 |
double shadcert = .25; /* shadow certainty */
| 44 |
int directrelay = 0; /* number of source relays */
| 45 |
int vspretest = 128; /* virtual source pretest density */
| 46 |
int directvis = 1; /* sources visible? */
| 47 |
double srcsizerat = 0.; /* maximum ratio source size/dist. */
| 48 |
| 49 |
COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
| 50 |
COLOR salbedo = BLKCOLOR; /* global scattering albedo */
| 51 |
double seccg = 0.; /* global scattering eccentricity */
| 52 |
double ssampdist = 0.; /* scatter sampling distance */
| 53 |
| 54 |
double specthresh = .3; /* specular sampling threshold */
| 55 |
double specjitter = 1.; /* specular sampling jitter */
| 56 |
| 57 |
int backvis = 1; /* back face visibility */
| 58 |
| 59 |
int maxdepth = 6; /* maximum recursion depth */
| 60 |
double minweight = 1e-2; /* minimum ray weight */
| 61 |
| 62 |
char *ambfile = NULL; /* ambient file name */
| 63 |
COLOR ambval = BLKCOLOR; /* ambient value */
| 64 |
int ambvwt = 0; /* initial weight for ambient value */
| 65 |
double ambacc = 0.3; /* ambient accuracy */
| 66 |
int ambres = 32; /* ambient resolution */
| 67 |
int ambdiv = 256; /* ambient divisions */
| 68 |
int ambssamp = 64; /* ambient super-samples */
| 69 |
int ambounce = 0; /* ambient bounces */
| 70 |
char *amblist[AMBLLEN]; /* ambient include/exclude list */
| 71 |
int ambincl = -1; /* include == 1, exclude == 0 */
| 72 |
| 73 |
int greyscale = 0; /* map colors to brightness? */
| 74 |
char *dvcname = dev_default; /* output device name */
| 75 |
| 76 |
struct driver *dev = NULL; /* driver functions */
| 77 |
| 78 |
char rifname[128]; /* rad input file name */
| 79 |
| 80 |
VIEW oldview; /* previous view parameters */
| 81 |
| 82 |
PNODE ptrunk; /* the base of our image */
| 83 |
RECT pframe; /* current frame boundaries */
| 84 |
int pdepth; /* image depth in current frame */
| 85 |
| 86 |
static char *reserve_mem = NULL; /* pre-allocated reserve memory */
| 87 |
| 88 |
#define RESERVE_AMT 32768 /* amount of memory to reserve */
| 89 |
| 90 |
#define CTRL(c) ((c)-'@')
| 91 |
| 92 |
| 93 |
void
| 94 |
quit(code) /* quit program */
| 95 |
int code;
| 96 |
| 97 |
#ifdef MSTATS
| 98 |
if (code == 2 && errno == ENOMEM)
| 99 |
printmemstats(stderr);
| 100 |
#endif
| 101 |
devclose();
| 102 |
exit(code);
| 103 |
| 104 |
| 105 |
| 106 |
void
| 107 |
devopen(dname) /* open device driver */
| 108 |
char *dname;
| 109 |
| 110 |
extern char *progname, *octname;
| 111 |
char *id;
| 112 |
register int i;
| 113 |
| 114 |
id = octname!=NULL ? octname : progname;
| 115 |
/* check device table */
| 116 |
for (i = 0; devtable[i].name; i++)
| 117 |
if (!strcmp(dname, devtable[i].name)) {
| 118 |
if ((dev = (*devtable[i].init)(dname, id)) == NULL) {
| 119 |
sprintf(errmsg, "cannot initialize %s", dname);
| 120 |
error(USER, errmsg);
| 121 |
} else
| 122 |
return;
| 123 |
| 124 |
/* not there, try exec */
| 125 |
if ((dev = comm_init(dname, id)) == NULL) {
| 126 |
sprintf(errmsg, "cannot start device \"%s\"", dname);
| 127 |
| 128 |
| 129 |
| 130 |
| 131 |
| 132 |
void
| 133 |
devclose() /* close our device */
| 134 |
| 135 |
if (dev != NULL)
| 136 |
(*dev->close)();
| 137 |
dev = NULL;
| 138 |
| 139 |
| 140 |
| 141 |
void
| 142 |
printdevices() /* print list of output devices */
| 143 |
| 144 |
register int i;
| 145 |
| 146 |
| 147 |
printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
| 148 |
| 149 |
| 150 |
| 151 |
void
| 152 |
rview() /* do a view */
| 153 |
| 154 |
char buf[32];
| 155 |
| 156 |
devopen(dvcname); /* open device */
| 157 |
newimage(); /* start image (calls fillreserves) */
| 158 |
| 159 |
for ( ; ; ) { /* quit in command() */
| 160 |
while (hresolu <= 1<<pdepth && vresolu <= 1<<pdepth)
| 161 |
command("done: ");
| 162 |
while (reserve_mem == NULL)
| 163 |
command("out of memory: ");
| 164 |
errno = 0;
| 165 |
if (hresolu <= psample<<pdepth && vresolu <= psample<<pdepth) {
| 166 |
sprintf(buf, "%d sampling...\n", 1<<pdepth);
| 167 |
(*dev->comout)(buf);
| 168 |
rsample();
| 169 |
} else {
| 170 |
sprintf(buf, "%d refining...\n", 1<<pdepth);
| 171 |
| 172 |
refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1);
| 173 |
| 174 |
if (errno == ENOMEM) /* ran out of memory */
| 175 |
freereserves();
| 176 |
else if (dev->inpready) /* noticed some input */
| 177 |
command(": ");
| 178 |
else /* finished this depth */
| 179 |
pdepth++;
| 180 |
| 181 |
| 182 |
| 183 |
| 184 |
void
| 185 |
fillreserves() /* fill memory reserves */
| 186 |
| 187 |
if (reserve_mem != NULL)
| 188 |
return;
| 189 |
reserve_mem = (char *)malloc(RESERVE_AMT);
| 190 |
| 191 |
| 192 |
| 193 |
void
| 194 |
freereserves() /* free memory reserves */
| 195 |
| 196 |
if (reserve_mem == NULL)
| 197 |
return;
| 198 |
free(reserve_mem);
| 199 |
reserve_mem = NULL;
| 200 |
| 201 |
| 202 |
| 203 |
void
| 204 |
command(prompt) /* get/execute command */
| 205 |
char *prompt;
| 206 |
| 207 |
#define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
| 208 |
char inpbuf[256];
| 209 |
char *args;
| 210 |
again:
| 211 |
(*dev->comin)(inpbuf, prompt); /* get command + arguments */
| 212 |
for (args = inpbuf; *args && *args != ' '; args++)
| 213 |
| 214 |
if (*args) *args++ = '\0';
| 215 |
else *++args = '\0';
| 216 |
| 217 |
switch (inpbuf[0]) {
| 218 |
case 'f': /* new frame (or free mem.) */
| 219 |
if (badcom("frame")) {
| 220 |
if (badcom("free"))
| 221 |
goto commerr;
| 222 |
free_objmem();
| 223 |
break;
| 224 |
| 225 |
getframe(args);
| 226 |
break;
| 227 |
case 'v': /* view */
| 228 |
if (badcom("view"))
| 229 |
goto commerr;
| 230 |
getview(args);
| 231 |
break;
| 232 |
case 'l': /* last view */
| 233 |
if (badcom("last"))
| 234 |
goto commerr;
| 235 |
lastview(args);
| 236 |
break;
| 237 |
case 'V': /* save view */
| 238 |
if (badcom("V"))
| 239 |
goto commerr;
| 240 |
saveview(args);
| 241 |
break;
| 242 |
case 'L': /* load view */
| 243 |
if (badcom("L"))
| 244 |
goto commerr;
| 245 |
loadview(args);
| 246 |
break;
| 247 |
case 'e': /* exposure */
| 248 |
if (badcom("exposure"))
| 249 |
goto commerr;
| 250 |
getexposure(args);
| 251 |
break;
| 252 |
case 's': /* set a parameter */
| 253 |
if (badcom("set")) {
| 254 |
#ifdef SIGTSTP
| 255 |
if (!badcom("stop"))
| 256 |
goto dostop;
| 257 |
#endif
| 258 |
goto commerr;
| 259 |
| 260 |
setparam(args);
| 261 |
break;
| 262 |
case 'n': /* new picture */
| 263 |
if (badcom("new"))
| 264 |
goto commerr;
| 265 |
newimage();
| 266 |
break;
| 267 |
case 't': /* trace a ray */
| 268 |
if (badcom("trace"))
| 269 |
goto commerr;
| 270 |
traceray(args);
| 271 |
break;
| 272 |
case 'a': /* aim camera */
| 273 |
if (badcom("aim"))
| 274 |
goto commerr;
| 275 |
getaim(args);
| 276 |
break;
| 277 |
case 'm': /* move camera (or memstats) */
| 278 |
if (badcom("move"))
| 279 |
#ifdef MSTATS
| 280 |
| 281 |
if (badcom("memory"))
| 282 |
goto commerr;
| 283 |
| 284 |
break;
| 285 |
| 286 |
#else
| 287 |
goto commerr;
| 288 |
#endif
| 289 |
getmove(args);
| 290 |
break;
| 291 |
case 'r': /* rotate/repaint */
| 292 |
if (badcom("rotate")) {
| 293 |
if (badcom("repaint")) {
| 294 |
if (badcom("redraw"))
| 295 |
goto commerr;
| 296 |
redraw();
| 297 |
break;
| 298 |
| 299 |
getrepaint(args);
| 300 |
break;
| 301 |
| 302 |
getrotate(args);
| 303 |
break;
| 304 |
case 'p': /* pivot view */
| 305 |
if (badcom("pivot")) {
| 306 |
if (badcom("pause"))
| 307 |
goto commerr;
| 308 |
goto again;
| 309 |
| 310 |
getpivot(args);
| 311 |
break;
| 312 |
case CTRL('R'): /* redraw */
| 313 |
redraw();
| 314 |
break;
| 315 |
case 'w': /* write */
| 316 |
if (badcom("write"))
| 317 |
goto commerr;
| 318 |
writepict(args);
| 319 |
break;
| 320 |
case 'q': /* quit */
| 321 |
if (badcom("quit"))
| 322 |
goto commerr;
| 323 |
quit(0);
| 324 |
case CTRL('C'): /* interrupt */
| 325 |
goto again;
| 326 |
#ifdef SIGTSTP
| 327 |
case CTRL('Z'):; /* stop */
| 328 |
dostop:
| 329 |
devclose();
| 330 |
kill(0, SIGTSTP);
| 331 |
/* pc stops here */
| 332 |
devopen(dvcname);
| 333 |
redraw();
| 334 |
break;
| 335 |
#endif
| 336 |
case '\0': /* continue */
| 337 |
break;
| 338 |
default:;
| 339 |
commerr:
| 340 |
if (iscntrl(inpbuf[0]))
| 341 |
sprintf(errmsg, "^%c: unknown control",
| 342 |
inpbuf[0]|0100);
| 343 |
else
| 344 |
sprintf(errmsg, "%s: unknown command", inpbuf);
| 345 |
error(COMMAND, errmsg);
| 346 |
break;
| 347 |
| 348 |
#undef badcom
| 349 |
| 350 |
| 351 |
| 352 |
void
| 353 |
rsample() /* sample the image */
| 354 |
| 355 |
int xsiz, ysiz, y;
| 356 |
RECT r;
| 357 |
PNODE *p;
| 358 |
register RECT *rl;
| 359 |
register PNODE **pl;
| 360 |
register int x;
| 361 |
| 362 |
* We initialize the bottom row in the image at our current
| 363 |
* resolution. During sampling, we check super-pixels to the
| 364 |
* right and above by calling bigdiff(). If there is a significant
| 365 |
* difference, we subsample the super-pixels. The testing process
| 366 |
* includes initialization of the next row.
| 367 |
| 368 |
xsiz = (((long)(pframe.r-pframe.l)<<pdepth)+hresolu-1) / hresolu;
| 369 |
ysiz = (((long)(pframe.u-pframe.d)<<pdepth)+vresolu-1) / vresolu;
| 370 |
rl = (RECT *)malloc(xsiz*sizeof(RECT));
| 371 |
if (rl == NULL)
| 372 |
return;
| 373 |
pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
| 374 |
if (pl == NULL) {
| 375 |
free((void *)rl);
| 376 |
return;
| 377 |
| 378 |
| 379 |
* Initialize the bottom row.
| 380 |
| 381 |
rl[0].l = rl[0].d = 0;
| 382 |
rl[0].r = hresolu; rl[0].u = vresolu;
| 383 |
pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
| 384 |
for (x = 1; x < xsiz; x++) {
| 385 |
rl[x].l = rl[x].d = 0;
| 386 |
rl[x].r = hresolu; rl[x].u = vresolu;
| 387 |
pl[x] = findrect(pframe.l+((x*hresolu)>>pdepth),
| 388 |
pframe.d, &ptrunk, rl+x, pdepth);
| 389 |
| 390 |
| 391 |
for (y = 0; /* y < ysiz */ ; y++) {
| 392 |
for (x = 0; x < xsiz-1; x++) {
| 393 |
if (dev->inpready || errno == ENOMEM)
| 394 |
goto escape;
| 395 |
| 396 |
* Test super-pixel to the right.
| 397 |
| 398 |
if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
| 399 |
pl[x+1]->v, maxdiff)) {
| 400 |
refine(pl[x], rl[x].l, rl[x].d,
| 401 |
rl[x].r, rl[x].u, 1);
| 402 |
refine(pl[x+1], rl[x+1].l, rl[x+1].d,
| 403 |
rl[x+1].r, rl[x+1].u, 1);
| 404 |
| 405 |
| 406 |
if (y >= ysiz-1)
| 407 |
break;
| 408 |
for (x = 0; x < xsiz; x++) {
| 409 |
| 410 |
goto escape;
| 411 |
| 412 |
* Find super-pixel at this position in next row.
| 413 |
| 414 |
r.l = r.d = 0;
| 415 |
r.r = hresolu; r.u = vresolu;
| 416 |
p = findrect(pframe.l+((x*hresolu)>>pdepth),
| 417 |
pframe.d+(((y+1)*vresolu)>>pdepth),
| 418 |
&ptrunk, &r, pdepth);
| 419 |
| 420 |
* Test super-pixel in next row.
| 421 |
| 422 |
if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
| 423 |
| 424 |
| 425 |
refine(p, r.l, r.d, r.r, r.u, 1);
| 426 |
| 427 |
| 428 |
* Copy into super-pixel array.
| 429 |
| 430 |
rl[x].l = r.l; rl[x].d = r.d;
| 431 |
rl[x].r = r.r; rl[x].u = r.u;
| 432 |
pl[x] = p;
| 433 |
| 434 |
| 435 |
escape:
| 436 |
free((void *)rl);
| 437 |
free((void *)pl);
| 438 |
| 439 |
| 440 |
| 441 |
int
| 442 |
refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
| 443 |
register PNODE *p;
| 444 |
int xmin, ymin, xmax, ymax;
| 445 |
int pd;
| 446 |
| 447 |
int growth;
| 448 |
int mx, my;
| 449 |
int i;
| 450 |
| 451 |
if (dev->inpready) /* quit for input */
| 452 |
return(0);
| 453 |
| 454 |
if (pd <= 0) /* depth limit */
| 455 |
return(0);
| 456 |
| 457 |
mx = (xmin + xmax) >> 1;
| 458 |
my = (ymin + ymax) >> 1;
| 459 |
growth = 0;
| 460 |
| 461 |
if (p->kid == NULL) { /* subdivide */
| 462 |
| 463 |
if ((p->kid = newptree()) == NULL)
| 464 |
return(0);
| 465 |
| 466 |
* The following paint order can leave a black pixel
| 467 |
* if redraw() is called in (*dev->paintr)().
| 468 |
| 469 |
if (p->x >= mx && p->y >= my)
| 470 |
pcopy(p, p->kid+UR);
| 471 |
else
| 472 |
paint(p->kid+UR, mx, my, xmax, ymax);
| 473 |
if (p->x < mx && p->y >= my)
| 474 |
pcopy(p, p->kid+UL);
| 475 |
else
| 476 |
paint(p->kid+UL, xmin, my, mx, ymax);
| 477 |
if (p->x >= mx && p->y < my)
| 478 |
pcopy(p, p->kid+DR);
| 479 |
else
| 480 |
paint(p->kid+DR, mx, ymin, xmax, my);
| 481 |
if (p->x < mx && p->y < my)
| 482 |
pcopy(p, p->kid+DL);
| 483 |
else
| 484 |
paint(p->kid+DL, xmin, ymin, mx, my);
| 485 |
| 486 |
growth++;
| 487 |
| 488 |
/* do children */
| 489 |
if (mx > pframe.l) {
| 490 |
if (my > pframe.d)
| 491 |
growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
| 492 |
if (my < pframe.u)
| 493 |
growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
| 494 |
| 495 |
if (mx < pframe.r) {
| 496 |
if (my > pframe.d)
| 497 |
growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
| 498 |
if (my < pframe.u)
| 499 |
growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
| 500 |
| 501 |
/* recompute sum */
| 502 |
if (growth) {
| 503 |
setcolor(p->v, 0.0, 0.0, 0.0);
| 504 |
for (i = 0; i < 4; i++)
| 505 |
addcolor(p->v, p->kid[i].v);
| 506 |
scalecolor(p->v, 0.25);
| 507 |
| 508 |
return(growth);
| 509 |
