root/radiance/ray/src/rt/rview.c
Revision: 1.2
Committed: Wed Jun 7 08:35:29 1989 UTC (34 years, 10 months ago) by greg
Glow type changed
Spot type eliminated
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rview.c - routines and variables for interactive view generation.
9 *
10 * 3/24/87
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "rpaint.h"
18
19 #include <signal.h>
20
21 #include <ctype.h>
22
23 VIEW ourview = STDVIEW(470); /* viewing parameters */
24
25 int psample = 8; /* pixel sample size */
26 double maxdiff = .15; /* max. sample difference */
27
28 double exposure = 1.0; /* exposure for scene */
29
30 double dstrsrc = 0.0; /* square source distribution */
31 double shadthresh = .05; /* shadow threshold */
32
33 int maxdepth = 4; /* maximum recursion depth */
34 double minweight = 1e-2; /* minimum ray weight */
35
36 COLOR ambval = BLKCOLOR; /* ambient value */
37 double ambacc = 0.2; /* ambient accuracy */
38 int ambres = 64; /* ambient resolution */
39 int ambdiv = 32; /* ambient divisions */
40 int ambssamp = 0; /* ambient super-samples */
41 int ambounce = 0; /* ambient bounces */
42 char *amblist[128]; /* ambient include/exclude list */
43 int ambincl = -1; /* include == 1, exclude == 0 */
44
45 int greyscale = 0; /* map colors to brightness? */
46 char *devname = "X"; /* output device name */
47
48 struct driver *dev = NULL; /* driver functions */
49
50 VIEW oldview; /* previous view parameters */
51
52 PNODE ptrunk; /* the base of our image */
53 RECT pframe; /* current frame boundaries */
54 int pdepth; /* image depth in current frame */
55
56 #define CTRL(c) ('c'-'@')
57
58
59 quit(code) /* quit program */
60 int code;
61 {
62 devclose();
63 exit(code);
64 }
65
66
67 devopen(dname) /* open device driver */
68 char *dname;
69 {
70 extern char *progname;
71 char *devargv[3];
72 register int i;
73 /* check device table */
74 for (i = 0; devtable[i].name; i++)
75 if (!strcmp(dname, devtable[i].name))
76 if ((dev = (*devtable[i].init)(progname)) == NULL) {
77 sprintf(errmsg, "cannot initialize %s", dname);
78 error(USER, errmsg);
79 } else
80 return;
81 /* not there, try exec */
82 devargv[0] = dname;
83 devargv[1] = progname;
84 devargv[2] = NULL;
85 if ((dev = comm_init(devargv)) == NULL) {
86 sprintf(errmsg, "cannot start device \"%s\"", dname);
87 error(USER, errmsg);
88 }
89 }
90
91
92 devclose() /* close our device */
93 {
94 if (dev != NULL)
95 (*dev->close)();
96 dev = NULL;
97 }
98
99
100 printdevices() /* print list of output devices */
101 {
102 register int i;
103
104 for (i = 0; devtable[i].name; i++)
105 printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
106 }
107
108
109 rview() /* do a view */
110 {
111 char buf[32];
112
113 devopen(devname); /* open device */
114 newimage(); /* set up image */
115
116 for ( ; ; ) { /* quit in command() */
117 while (ourview.hresolu <= 1<<pdepth &&
118 ourview.vresolu <= 1<<pdepth)
119 command("done: ");
120
121 if (ourview.hresolu <= psample<<pdepth &&
122 ourview.vresolu <= psample<<pdepth) {
123 sprintf(buf, "%d sampling...\n", 1<<pdepth);
124 (*dev->comout)(buf);
125 rsample();
126 } else {
127 sprintf(buf, "%d refining...\n", 1<<pdepth);
128 (*dev->comout)(buf);
129 refine(&ptrunk, 0, 0, ourview.hresolu,
130 ourview.vresolu, pdepth+1);
131 }
132 if (dev->inpready)
133 command(": ");
134 else
135 pdepth++;
136 }
137 }
138
139
140 command(prompt) /* get/execute command */
141 char *prompt;
142 {
143 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
144 double atof();
145 char inpbuf[256];
146 char *args;
147 again:
148 (*dev->comout)(prompt); /* get command + arguments */
149 (*dev->comin)(inpbuf);
150 for (args = inpbuf; *args && *args != ' '; args++)
151 ;
152 if (*args) *args++ = '\0';
153 else *++args = '\0';
154
155 switch (inpbuf[0]) {
156 case 'f': /* new frame */
157 if (badcom("frame"))
158 goto commerr;
159 getframe(args);
160 break;
161 case 'v': /* view */
162 if (badcom("view"))
163 goto commerr;
164 getview(args);
165 break;
166 case 'l': /* last view */
167 if (badcom("last"))
168 goto commerr;
169 lastview(args);
170 break;
171 case 'e': /* exposure */
172 if (badcom("exposure"))
173 goto commerr;
174 getexposure(args);
175 break;
176 case 's': /* set a parameter */
177 if (badcom("set"))
178 goto commerr;
179 setparam(args);
180 break;
181 case 'n': /* new picture */
182 if (badcom("new"))
183 goto commerr;
184 newimage();
185 break;
186 case 't': /* trace a ray */
187 if (badcom("trace"))
188 goto commerr;
189 traceray(args);
190 break;
191 case 'a': /* aim camera */
192 if (badcom("aim"))
193 goto commerr;
194 getaim(args);
195 break;
196 case 'm': /* move camera */
197 if (badcom("move"))
198 goto commerr;
199 getmove(args);
200 break;
201 case 'r': /* rotate camera */
202 if (badcom("rotate"))
203 goto commerr;
204 getrotate(args);
205 break;
206 case 'p': /* pivot view */
207 if (badcom("pivot"))
208 goto commerr;
209 getpivot(args);
210 break;
211 case CTRL(R): /* redraw */
212 redraw();
213 break;
214 case 'w': /* write */
215 if (badcom("write"))
216 goto commerr;
217 writepict(args);
218 break;
219 case 'q': /* quit */
220 if (badcom("quit"))
221 goto commerr;
222 quit(0);
223 case CTRL(C): /* interrupt */
224 goto again;
225 #ifdef SIGTSTP
226 case CTRL(Z): /* stop */
227 devclose();
228 kill(0, SIGTSTP);
229 /* pc stops here */
230 devopen(devname);
231 redraw();
232 break;
233 #endif
234 case '\0': /* continue */
235 break;
236 default:;
237 commerr:
238 if (iscntrl(inpbuf[0]))
239 sprintf(errmsg, "^%c: unknown control",
240 inpbuf[0]|0100);
241 else
242 sprintf(errmsg, "%s: unknown command", inpbuf);
243 error(COMMAND, errmsg);
244 break;
245 }
246 #undef badcom
247 }
248
249
250 rsample() /* sample the image */
251 {
252 int xsiz, ysiz, y;
253 RECT r;
254 PNODE *p;
255 register RECT *rl;
256 register PNODE **pl;
257 register int x;
258 /*
259 * We initialize the bottom row in the image at our current
260 * resolution. During sampling, we check super-pixels to the
261 * right and above by calling bigdiff(). If there is a significant
262 * difference, we subsample the super-pixels. The testing process
263 * includes initialization of the next row.
264 */
265 xsiz = (((pframe.r-pframe.l)<<pdepth)+ourview.hresolu-1) /
266 ourview.hresolu;
267 ysiz = (((pframe.u-pframe.d)<<pdepth)+ourview.vresolu-1) /
268 ourview.vresolu;
269 rl = (RECT *)malloc(xsiz*sizeof(RECT));
270 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
271 if (rl == NULL || pl == NULL)
272 error(SYSTEM, "out of memory in rsample");
273 /*
274 * Initialize the bottom row.
275 */
276 rl[0].l = rl[0].d = 0;
277 rl[0].r = ourview.hresolu; rl[0].u = ourview.vresolu;
278 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
279 for (x = 1; x < xsiz; x++) {
280 rl[x].l = rl[x].d = 0;
281 rl[x].r = ourview.hresolu; rl[x].u = ourview.vresolu;
282 pl[x] = findrect(pframe.l+((x*ourview.hresolu)>>pdepth),
283 pframe.d, &ptrunk, rl+x, pdepth);
284 }
285 /* sample the image */
286 for (y = 0; /* y < ysiz */ ; y++) {
287 for (x = 0; x < xsiz-1; x++) {
288 if (dev->inpready)
289 goto escape;
290 /*
291 * Test super-pixel to the right.
292 */
293 if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
294 pl[x+1]->v, maxdiff)) {
295 refine(pl[x], rl[x].l, rl[x].d,
296 rl[x].r, rl[x].u, 1);
297 refine(pl[x+1], rl[x+1].l, rl[x+1].d,
298 rl[x+1].r, rl[x+1].u, 1);
299 }
300 }
301 if (y >= ysiz-1)
302 break;
303 for (x = 0; x < xsiz; x++) {
304 if (dev->inpready)
305 goto escape;
306 /*
307 * Find super-pixel at this position in next row.
308 */
309 r.l = r.d = 0;
310 r.r = ourview.hresolu; r.u = ourview.vresolu;
311 p = findrect(pframe.l+((x*ourview.hresolu)>>pdepth),
312 pframe.d+(((y+1)*ourview.vresolu)>>pdepth),
313 &ptrunk, &r, pdepth);
314 /*
315 * Test super-pixel in next row.
316 */
317 if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
318 refine(pl[x], rl[x].l, rl[x].d,
319 rl[x].r, rl[x].u, 1);
320 refine(p, r.l, r.d, r.r, r.u, 1);
321 }
322 /*
323 * Copy into super-pixel array.
324 */
325 rl[x].l = r.l; rl[x].d = r.d;
326 rl[x].r = r.r; rl[x].u = r.u;
327 pl[x] = p;
328 }
329 }
330 escape:
331 free((char *)rl);
332 free((char *)pl);
333 }
334
335
336 int
337 refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
338 register PNODE *p;
339 int xmin, ymin, xmax, ymax;
340 int pd;
341 {
342 int growth;
343 int mx, my;
344 int i;
345
346 if (dev->inpready) /* quit for input */
347 return(0);
348
349 if (pd <= 0) /* depth limit */
350 return(0);
351
352 mx = (xmin + xmax) >> 1;
353 my = (ymin + ymax) >> 1;
354 growth = 0;
355
356 if (p->kid == NULL) { /* subdivide */
357
358 if ((p->kid = newptree()) == NULL)
359 error(SYSTEM, "out of memory in refine");
360 /*
361 * The following paint order can leave a black pixel
362 * when redraw() is called in (*dev->paintr)().
363 */
364 if (p->x >= mx && p->y >= my)
365 pcopy(p, p->kid+UR);
366 else
367 paint(p->kid+UR, mx, my, xmax, ymax);
368 if (p->x < mx && p->y >= my)
369 pcopy(p, p->kid+UL);
370 else
371 paint(p->kid+UL, xmin, my, mx, ymax);
372 if (p->x >= mx && p->y < my)
373 pcopy(p, p->kid+DR);
374 else
375 paint(p->kid+DR, mx, ymin, xmax, my);
376 if (p->x < mx && p->y < my)
377 pcopy(p, p->kid+DL);
378 else
379 paint(p->kid+DL, xmin, ymin, mx, my);
380
381 growth++;
382 }
383 /* do children */
384 if (mx > pframe.l) {
385 if (my > pframe.d)
386 growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
387 if (my < pframe.u)
388 growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
389 }
390 if (mx < pframe.r) {
391 if (my > pframe.d)
392 growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
393 if (my < pframe.u)
394 growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
395 }
396 /* recompute sum */
397 if (growth) {
398 setcolor(p->v, 0.0, 0.0, 0.0);
399 for (i = 0; i < 4; i++)
400 addcolor(p->v, p->kid[i].v);
401 scalecolor(p->v, 0.25);
402 }
403 return(growth);
404 }
