root/radiance/ray/src/rt/rview.c
Revision: 1.12
Committed: Fri May 3 15:22:24 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.11: +31 -3 lines
added minimal memory recovery
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rview.c - routines and variables for interactive view generation.
9 *
10 * 3/24/87
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "rpaint.h"
18
19 #include <signal.h>
20
21 #include <ctype.h>
22
23 VIEW ourview = STDVIEW; /* viewing parameters */
24 int hresolu, vresolu; /* image resolution */
25
26 int psample = 8; /* pixel sample size */
27 double maxdiff = .15; /* max. sample difference */
28
29 double exposure = 1.0; /* exposure for scene */
30
31 double dstrsrc = 0.0; /* square source distribution */
32 double shadthresh = .1; /* shadow threshold */
33 double shadcert = .25; /* shadow certainty */
34
35 int maxdepth = 4; /* maximum recursion depth */
36 double minweight = 1e-2; /* minimum ray weight */
37
38 COLOR ambval = BLKCOLOR; /* ambient value */
39 double ambacc = 0.2; /* ambient accuracy */
40 int ambres = 8; /* ambient resolution */
41 int ambdiv = 32; /* ambient divisions */
42 int ambssamp = 0; /* ambient super-samples */
43 int ambounce = 0; /* ambient bounces */
44 char *amblist[128]; /* ambient include/exclude list */
45 int ambincl = -1; /* include == 1, exclude == 0 */
46
47 int greyscale = 0; /* map colors to brightness? */
48 char *devname = dev_default; /* output device name */
49
50 struct driver *dev = NULL; /* driver functions */
51
52 VIEW oldview; /* previous view parameters */
53
54 PNODE ptrunk; /* the base of our image */
55 RECT pframe; /* current frame boundaries */
56 int pdepth; /* image depth in current frame */
57
58 static char *reserve_mem = NULL; /* pre-allocated reserve memory */
59
60 #define RESERVE_AMT 8192 /* amount of memory to reserve */
61
62 #define CTRL(c) ('c'-'@')
63
64
65 quit(code) /* quit program */
66 int code;
67 {
68 devclose();
69 exit(code);
70 }
71
72
73 devopen(dname) /* open device driver */
74 char *dname;
75 {
76 extern char *progname, *octname;
77 char *id;
78 register int i;
79
80 id = octname!=NULL ? octname : progname;
81 /* check device table */
82 for (i = 0; devtable[i].name; i++)
83 if (!strcmp(dname, devtable[i].name))
84 if ((dev = (*devtable[i].init)(dname, id)) == NULL) {
85 sprintf(errmsg, "cannot initialize %s", dname);
86 error(USER, errmsg);
87 } else
88 return;
89 /* not there, try exec */
90 if ((dev = comm_init(dname, id)) == NULL) {
91 sprintf(errmsg, "cannot start device \"%s\"", dname);
92 error(USER, errmsg);
93 }
94 }
95
96
97 devclose() /* close our device */
98 {
99 if (dev != NULL)
100 (*dev->close)();
101 dev = NULL;
102 }
103
104
105 printdevices() /* print list of output devices */
106 {
107 register int i;
108
109 for (i = 0; devtable[i].name; i++)
110 printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
111 }
112
113
114 rview() /* do a view */
115 {
116 char buf[32];
117
118 devopen(devname); /* open device */
119 newimage(); /* set up image */
120
121 for ( ; ; ) { /* quit in command() */
122 while (hresolu <= 1<<pdepth &&
123 vresolu <= 1<<pdepth)
124 command("done: ");
125
126 if (hresolu <= psample<<pdepth &&
127 vresolu <= psample<<pdepth) {
128 sprintf(buf, "%d sampling...\n", 1<<pdepth);
129 (*dev->comout)(buf);
130 rsample();
131 } else {
132 sprintf(buf, "%d refining...\n", 1<<pdepth);
133 (*dev->comout)(buf);
134 refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1);
135 }
136 if (dev->inpready)
137 command(": ");
138 else
139 pdepth++;
140 }
141 }
142
143
144 memreserve() /* fill memory reserves */
145 {
146 if (reserve_mem != NULL)
147 return; /* got some already */
148 reserve_mem = malloc(RESERVE_AMT);
149 }
150
151
152 memerror(detail) /* try and rescue a memory error */
153 char *detail;
154 {
155 if (reserve_mem == NULL) {
156 sprintf(errmsg, "out of memory %s", detail);
157 error(SYSTEM, errmsg);
158 }
159 free(reserve_mem);
160 reserve_mem = NULL;
161 for ( ; ; )
162 command("out of memory: ");
163 }
164
165
166 command(prompt) /* get/execute command */
167 char *prompt;
168 {
169 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
170 double atof();
171 char inpbuf[256];
172 char *args;
173 again:
174 (*dev->comin)(inpbuf, prompt); /* get command + arguments */
175 for (args = inpbuf; *args && *args != ' '; args++)
176 ;
177 if (*args) *args++ = '\0';
178 else *++args = '\0';
179
180 switch (inpbuf[0]) {
181 case 'f': /* new frame */
182 if (badcom("frame"))
183 goto commerr;
184 getframe(args);
185 break;
186 case 'v': /* view */
187 if (badcom("view"))
188 goto commerr;
189 getview(args);
190 break;
191 case 'l': /* last view */
192 if (badcom("last"))
193 goto commerr;
194 lastview(args);
195 break;
196 case 'e': /* exposure */
197 if (badcom("exposure"))
198 goto commerr;
199 getexposure(args);
200 break;
201 case 's': /* set a parameter */
202 if (badcom("set"))
203 goto commerr;
204 setparam(args);
205 break;
206 case 'n': /* new picture */
207 if (badcom("new"))
208 goto commerr;
209 newimage();
210 break;
211 case 't': /* trace a ray */
212 if (badcom("trace"))
213 goto commerr;
214 traceray(args);
215 break;
216 case 'a': /* aim camera */
217 if (badcom("aim"))
218 goto commerr;
219 getaim(args);
220 break;
221 case 'm': /* move camera */
222 if (badcom("move"))
223 goto commerr;
224 getmove(args);
225 break;
226 case 'r': /* rotate/repaint */
227 if (badcom("rotate")) {
228 if (badcom("repaint"))
229 goto commerr;
230 getrepaint(args);
231 break;
232 }
233 getrotate(args);
234 break;
235 case 'p': /* pivot view */
236 if (badcom("pivot"))
237 goto commerr;
238 getpivot(args);
239 break;
240 case CTRL(R): /* redraw */
241 redraw();
242 break;
243 case 'w': /* write */
244 if (badcom("write"))
245 goto commerr;
246 writepict(args);
247 break;
248 case 'q': /* quit */
249 if (badcom("quit"))
250 goto commerr;
251 quit(0);
252 case CTRL(C): /* interrupt */
253 goto again;
254 #ifdef SIGTSTP
255 case CTRL(Z): /* stop */
256 devclose();
257 kill(0, SIGTSTP);
258 /* pc stops here */
259 devopen(devname);
260 redraw();
261 break;
262 #endif
263 case '\0': /* continue */
264 break;
265 default:;
266 commerr:
267 if (iscntrl(inpbuf[0]))
268 sprintf(errmsg, "^%c: unknown control",
269 inpbuf[0]|0100);
270 else
271 sprintf(errmsg, "%s: unknown command", inpbuf);
272 error(COMMAND, errmsg);
273 break;
274 }
275 #undef badcom
276 }
277
278
279 rsample() /* sample the image */
280 {
281 int xsiz, ysiz, y;
282 RECT r;
283 PNODE *p;
284 register RECT *rl;
285 register PNODE **pl;
286 register int x;
287 /*
288 * We initialize the bottom row in the image at our current
289 * resolution. During sampling, we check super-pixels to the
290 * right and above by calling bigdiff(). If there is a significant
291 * difference, we subsample the super-pixels. The testing process
292 * includes initialization of the next row.
293 */
294 xsiz = (((pframe.r-pframe.l)<<pdepth)+hresolu-1) / hresolu;
295 ysiz = (((pframe.u-pframe.d)<<pdepth)+vresolu-1) / vresolu;
296 rl = (RECT *)malloc(xsiz*sizeof(RECT));
297 if (rl == NULL)
298 memerror("in rsample");
299 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
300 if (pl == NULL)
301 memerror("in rsample");
302 /*
303 * Initialize the bottom row.
304 */
305 rl[0].l = rl[0].d = 0;
306 rl[0].r = hresolu; rl[0].u = vresolu;
307 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
308 for (x = 1; x < xsiz; x++) {
309 rl[x].l = rl[x].d = 0;
310 rl[x].r = hresolu; rl[x].u = vresolu;
311 pl[x] = findrect(pframe.l+((x*hresolu)>>pdepth),
312 pframe.d, &ptrunk, rl+x, pdepth);
313 }
314 /* sample the image */
315 for (y = 0; /* y < ysiz */ ; y++) {
316 for (x = 0; x < xsiz-1; x++) {
317 if (dev->inpready)
318 goto escape;
319 /*
320 * Test super-pixel to the right.
321 */
322 if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
323 pl[x+1]->v, maxdiff)) {
324 refine(pl[x], rl[x].l, rl[x].d,
325 rl[x].r, rl[x].u, 1);
326 refine(pl[x+1], rl[x+1].l, rl[x+1].d,
327 rl[x+1].r, rl[x+1].u, 1);
328 }
329 }
330 if (y >= ysiz-1)
331 break;
332 for (x = 0; x < xsiz; x++) {
333 if (dev->inpready)
334 goto escape;
335 /*
336 * Find super-pixel at this position in next row.
337 */
338 r.l = r.d = 0;
339 r.r = hresolu; r.u = vresolu;
340 p = findrect(pframe.l+((x*hresolu)>>pdepth),
341 pframe.d+(((y+1)*vresolu)>>pdepth),
342 &ptrunk, &r, pdepth);
343 /*
344 * Test super-pixel in next row.
345 */
346 if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
347 refine(pl[x], rl[x].l, rl[x].d,
348 rl[x].r, rl[x].u, 1);
349 refine(p, r.l, r.d, r.r, r.u, 1);
350 }
351 /*
352 * Copy into super-pixel array.
353 */
354 rl[x].l = r.l; rl[x].d = r.d;
355 rl[x].r = r.r; rl[x].u = r.u;
356 pl[x] = p;
357 }
358 }
359 escape:
360 free((char *)rl);
361 free((char *)pl);
362 }
363
364
365 int
366 refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
367 register PNODE *p;
368 int xmin, ymin, xmax, ymax;
369 int pd;
370 {
371 int growth;
372 int mx, my;
373 int i;
374
375 if (dev->inpready) /* quit for input */
376 return(0);
377
378 if (pd <= 0) /* depth limit */
379 return(0);
380
381 mx = (xmin + xmax) >> 1;
382 my = (ymin + ymax) >> 1;
383 growth = 0;
384
385 if (p->kid == NULL) { /* subdivide */
386
387 if ((p->kid = newptree()) == NULL)
388 memerror("in refine");
389 /*
390 * The following paint order can leave a black pixel
391 * when redraw() is called in (*dev->paintr)().
392 */
393 if (p->x >= mx && p->y >= my)
394 pcopy(p, p->kid+UR);
395 else
396 paint(p->kid+UR, mx, my, xmax, ymax);
397 if (p->x < mx && p->y >= my)
398 pcopy(p, p->kid+UL);
399 else
400 paint(p->kid+UL, xmin, my, mx, ymax);
401 if (p->x >= mx && p->y < my)
402 pcopy(p, p->kid+DR);
403 else
404 paint(p->kid+DR, mx, ymin, xmax, my);
405 if (p->x < mx && p->y < my)
406 pcopy(p, p->kid+DL);
407 else
408 paint(p->kid+DL, xmin, ymin, mx, my);
409
410 growth++;
411 }
412 /* do children */
413 if (mx > pframe.l) {
414 if (my > pframe.d)
415 growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
416 if (my < pframe.u)
417 growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
418 }
419 if (mx < pframe.r) {
420 if (my > pframe.d)
421 growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
422 if (my < pframe.u)
423 growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
424 }
425 /* recompute sum */
426 if (growth) {
427 setcolor(p->v, 0.0, 0.0, 0.0);
428 for (i = 0; i < 4; i++)
429 addcolor(p->v, p->kid[i].v);
430 scalecolor(p->v, 0.25);
431 }
432 return(growth);
433 }
