root/Development/ray/src/rt/rview.c
Revision: 1.1
Committed: Thu Feb 2 10:41:39 1989 UTC (36 years, 9 months ago) by greg
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rview.c - routines and variables for interactive view generation.
9 *
10 * 3/24/87
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "rpaint.h"
18
19 #include <signal.h>
20
21 #include <ctype.h>
22
23 VIEW ourview = STDVIEW(470); /* viewing parameters */
24
25 int psample = 8; /* pixel sample size */
26 double maxdiff = .15; /* max. sample difference */
27
28 double exposure = 1.0; /* exposure for scene */
29
30 double dstrsrc = 0.0; /* square source distribution */
31
32 int maxdepth = 4; /* maximum recursion depth */
33 double minweight = 1e-2; /* minimum ray weight */
34
35 COLOR ambval = BLKCOLOR; /* ambient value */
36 double ambacc = 0.2; /* ambient accuracy */
37 int ambres = 64; /* ambient resolution */
38 int ambdiv = 32; /* ambient divisions */
39 int ambssamp = 0; /* ambient super-samples */
40 int ambounce = 0; /* ambient bounces */
41 char *amblist[128]; /* ambient include/exclude list */
42 int ambincl = -1; /* include == 1, exclude == 0 */
43
44 int greyscale = 0; /* map colors to brightness? */
45 char *devname = "X"; /* output device name */
46
47 struct driver *dev = NULL; /* driver functions */
48
49 VIEW oldview; /* previous view parameters */
50
51 PNODE ptrunk; /* the base of our image */
52 RECT pframe; /* current frame boundaries */
53 int pdepth; /* image depth in current frame */
54
55 #define CTRL(c) ('c'-'@')
56
57
58 quit(code) /* quit program */
59 int code;
60 {
61 devclose();
62 exit(code);
63 }
64
65
66 devopen(dname) /* open device driver */
67 char *dname;
68 {
69 extern char *progname;
70 char *devargv[3];
71 register int i;
72 /* check device table */
73 for (i = 0; devtable[i].name; i++)
74 if (!strcmp(dname, devtable[i].name))
75 if ((dev = (*devtable[i].init)(progname)) == NULL) {
76 sprintf(errmsg, "cannot initialize %s", dname);
77 error(USER, errmsg);
78 } else
79 return;
80 /* not there, try exec */
81 devargv[0] = dname;
82 devargv[1] = progname;
83 devargv[2] = NULL;
84 if ((dev = comm_init(devargv)) == NULL) {
85 sprintf(errmsg, "cannot start device \"%s\"", dname);
86 error(USER, errmsg);
87 }
88 }
89
90
91 devclose() /* close our device */
92 {
93 if (dev != NULL)
94 (*dev->close)();
95 dev = NULL;
96 }
97
98
99 printdevices() /* print list of output devices */
100 {
101 register int i;
102
103 for (i = 0; devtable[i].name; i++)
104 printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
105 }
106
107
108 rview() /* do a view */
109 {
110 char buf[32];
111
112 devopen(devname); /* open device */
113 newimage(); /* set up image */
114
115 for ( ; ; ) { /* quit in command() */
116 while (ourview.hresolu <= 1<<pdepth &&
117 ourview.vresolu <= 1<<pdepth)
118 command("done: ");
119
120 if (ourview.hresolu <= psample<<pdepth &&
121 ourview.vresolu <= psample<<pdepth) {
122 sprintf(buf, "%d sampling...\n", 1<<pdepth);
123 (*dev->comout)(buf);
124 rsample();
125 } else {
126 sprintf(buf, "%d refining...\n", 1<<pdepth);
127 (*dev->comout)(buf);
128 refine(&ptrunk, 0, 0, ourview.hresolu,
129 ourview.vresolu, pdepth+1);
130 }
131 if (dev->inpready)
132 command(": ");
133 else
134 pdepth++;
135 }
136 }
137
138
139 command(prompt) /* get/execute command */
140 char *prompt;
141 {
142 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
143 double atof();
144 char inpbuf[256];
145 char *args;
146 again:
147 (*dev->comout)(prompt); /* get command + arguments */
148 (*dev->comin)(inpbuf);
149 for (args = inpbuf; *args && *args != ' '; args++)
150 ;
151 if (*args) *args++ = '\0';
152 else *++args = '\0';
153
154 switch (inpbuf[0]) {
155 case 'f': /* new frame */
156 if (badcom("frame"))
157 goto commerr;
158 getframe(args);
159 break;
160 case 'v': /* view */
161 if (badcom("view"))
162 goto commerr;
163 getview(args);
164 break;
165 case 'l': /* last view */
166 if (badcom("last"))
167 goto commerr;
168 lastview(args);
169 break;
170 case 'e': /* exposure */
171 if (badcom("exposure"))
172 goto commerr;
173 getexposure(args);
174 break;
175 case 's': /* set a parameter */
176 if (badcom("set"))
177 goto commerr;
178 setparam(args);
179 break;
180 case 'n': /* new picture */
181 if (badcom("new"))
182 goto commerr;
183 newimage();
184 break;
185 case 't': /* trace a ray */
186 if (badcom("trace"))
187 goto commerr;
188 traceray(args);
189 break;
190 case 'a': /* aim camera */
191 if (badcom("aim"))
192 goto commerr;
193 getaim(args);
194 break;
195 case 'm': /* move camera */
196 if (badcom("move"))
197 goto commerr;
198 getmove(args);
199 break;
200 case 'r': /* rotate camera */
201 if (badcom("rotate"))
202 goto commerr;
203 getrotate(args);
204 break;
205 case 'p': /* pivot view */
206 if (badcom("pivot"))
207 goto commerr;
208 getpivot(args);
209 break;
210 case CTRL(R): /* redraw */
211 redraw();
212 break;
213 case 'w': /* write */
214 if (badcom("write"))
215 goto commerr;
216 writepict(args);
217 break;
218 case 'q': /* quit */
219 if (badcom("quit"))
220 goto commerr;
221 quit(0);
222 case CTRL(C): /* interrupt */
223 goto again;
224 #ifdef SIGTSTP
225 case CTRL(Z): /* stop */
226 devclose();
227 kill(0, SIGTSTP);
228 /* pc stops here */
229 devopen(devname);
230 redraw();
231 break;
232 #endif
233 case '\0': /* continue */
234 break;
235 default:;
236 commerr:
237 if (iscntrl(inpbuf[0]))
238 sprintf(errmsg, "^%c: unknown control",
239 inpbuf[0]|0100);
240 else
241 sprintf(errmsg, "%s: unknown command", inpbuf);
242 error(COMMAND, errmsg);
243 break;
244 }
245 #undef badcom
246 }
247
248
249 rsample() /* sample the image */
250 {
251 int xsiz, ysiz, y;
252 RECT r;
253 PNODE *p;
254 register RECT *rl;
255 register PNODE **pl;
256 register int x;
257 /*
258 * We initialize the bottom row in the image at our current
259 * resolution. During sampling, we check super-pixels to the
260 * right and above by calling bigdiff(). If there is a significant
261 * difference, we subsample the super-pixels. The testing process
262 * includes initialization of the next row.
263 */
264 xsiz = (((pframe.r-pframe.l)<<pdepth)+ourview.hresolu-1) /
265 ourview.hresolu;
266 ysiz = (((pframe.u-pframe.d)<<pdepth)+ourview.vresolu-1) /
267 ourview.vresolu;
268 rl = (RECT *)malloc(xsiz*sizeof(RECT));
269 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
270 if (rl == NULL || pl == NULL)
271 error(SYSTEM, "out of memory in rsample");
272 /*
273 * Initialize the bottom row.
274 */
275 rl[0].l = rl[0].d = 0;
276 rl[0].r = ourview.hresolu; rl[0].u = ourview.vresolu;
277 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
278 for (x = 1; x < xsiz; x++) {
279 rl[x].l = rl[x].d = 0;
280 rl[x].r = ourview.hresolu; rl[x].u = ourview.vresolu;
281 pl[x] = findrect(pframe.l+((x*ourview.hresolu)>>pdepth),
282 pframe.d, &ptrunk, rl+x, pdepth);
283 }
284 /* sample the image */
285 for (y = 0; /* y < ysiz */ ; y++) {
286 for (x = 0; x < xsiz-1; x++) {
287 if (dev->inpready)
288 goto escape;
289 /*
290 * Test super-pixel to the right.
291 */
292 if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
293 pl[x+1]->v, maxdiff)) {
294 refine(pl[x], rl[x].l, rl[x].d,
295 rl[x].r, rl[x].u, 1);
296 refine(pl[x+1], rl[x+1].l, rl[x+1].d,
297 rl[x+1].r, rl[x+1].u, 1);
298 }
299 }
300 if (y >= ysiz-1)
301 break;
302 for (x = 0; x < xsiz; x++) {
303 if (dev->inpready)
304 goto escape;
305 /*
306 * Find super-pixel at this position in next row.
307 */
308 r.l = r.d = 0;
309 r.r = ourview.hresolu; r.u = ourview.vresolu;
310 p = findrect(pframe.l+((x*ourview.hresolu)>>pdepth),
311 pframe.d+(((y+1)*ourview.vresolu)>>pdepth),
312 &ptrunk, &r, pdepth);
313 /*
314 * Test super-pixel in next row.
315 */
316 if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
317 refine(pl[x], rl[x].l, rl[x].d,
318 rl[x].r, rl[x].u, 1);
319 refine(p, r.l, r.d, r.r, r.u, 1);
320 }
321 /*
322 * Copy into super-pixel array.
323 */
324 rl[x].l = r.l; rl[x].d = r.d;
325 rl[x].r = r.r; rl[x].u = r.u;
326 pl[x] = p;
327 }
328 }
329 escape:
330 free((char *)rl);
331 free((char *)pl);
332 }
333
334
335 int
336 refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
337 register PNODE *p;
338 int xmin, ymin, xmax, ymax;
339 int pd;
340 {
341 int growth;
342 int mx, my;
343 int i;
344
345 if (dev->inpready) /* quit for input */
346 return(0);
347
348 if (pd <= 0) /* depth limit */
349 return(0);
350
351 mx = (xmin + xmax) >> 1;
352 my = (ymin + ymax) >> 1;
353 growth = 0;
354
355 if (p->kid == NULL) { /* subdivide */
356
357 if ((p->kid = newptree()) == NULL)
358 error(SYSTEM, "out of memory in refine");
359 /*
360 * The following paint order can leave a black pixel
361 * when redraw() is called in (*dev->paintr)().
362 */
363 if (p->x >= mx && p->y >= my)
364 pcopy(p, p->kid+UR);
365 else
366 paint(p->kid+UR, mx, my, xmax, ymax);
367 if (p->x < mx && p->y >= my)
368 pcopy(p, p->kid+UL);
369 else
370 paint(p->kid+UL, xmin, my, mx, ymax);
371 if (p->x >= mx && p->y < my)
372 pcopy(p, p->kid+DR);
373 else
374 paint(p->kid+DR, mx, ymin, xmax, my);
375 if (p->x < mx && p->y < my)
376 pcopy(p, p->kid+DL);
377 else
378 paint(p->kid+DL, xmin, ymin, mx, my);
379
380 growth++;
381 }
382 /* do children */
383 if (mx > pframe.l) {
384 if (my > pframe.d)
385 growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
386 if (my < pframe.u)
387 growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
388 }
389 if (mx < pframe.r) {
390 if (my > pframe.d)
391 growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
392 if (my < pframe.u)
393 growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
394 }
395 /* recompute sum */
396 if (growth) {
397 setcolor(p->v, 0.0, 0.0, 0.0);
398 for (i = 0; i < 4; i++)
399 addcolor(p->v, p->kid[i].v);
400 scalecolor(p->v, 0.25);
401 }
402 return(growth);
403 }
