--- ray/src/rt/rview.c 1995/12/08 18:49:24 2.15 +++ ray/src/rt/rview.c 2003/09/24 14:55:54 2.24 @@ -1,30 +1,38 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: rview.c,v 2.24 2003/09/24 14:55:54 greg Exp $"; #endif - /* * rview.c - routines and variables for interactive view generation. * - * 3/24/87 + * External symbols declared in rpaint.h */ -#include "ray.h" +#include "copyright.h" -#include "rpaint.h" - #include - #include -VIEW ourview = STDVIEW; /* viewing parameters */ -int hresolu, vresolu; /* image resolution */ +#include "ray.h" +#include "rpaint.h" + +CUBE thescene; /* our scene */ +OBJECT nsceneobjs; /* number of objects in our scene */ + int dimlist[MAXDIM]; /* sampling dimensions */ int ndims = 0; /* number of sampling dimensions */ int samplendx = 0; /* index for this sample */ +extern void ambnotify(); +void (*addobjnotify[])() = {ambnotify, NULL}; + +VIEW ourview = STDVIEW; /* viewing parameters */ +int hresolu, vresolu; /* image resolution */ + +void (*trace)() = NULL; /* trace call */ + +int do_irrad = 0; /* compute irradiance? */ + int psample = 8; /* pixel sample size */ double maxdiff = .15; /* max. sample difference */ @@ -39,7 +47,7 @@ int directvis = 1; /* sources visible? */ double srcsizerat = 0.; /* maximum ratio source size/dist. */ COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ -double salbedo = 0.; /* global scattering albedo */ +COLOR salbedo = BLKCOLOR; /* global scattering albedo */ double seccg = 0.; /* global scattering eccentricity */ double ssampdist = 0.; /* scatter sampling distance */ @@ -48,20 +56,22 @@ double specjitter = 1.; /* specular sampling jitter * int backvis = 1; /* back face visibility */ -int maxdepth = 4; /* maximum recursion depth */ +int maxdepth = 6; /* maximum recursion depth */ double minweight = 1e-2; /* minimum ray weight */ +char *ambfile = NULL; /* ambient file name */ COLOR ambval = BLKCOLOR; /* ambient value */ +int ambvwt = 0; /* initial weight for ambient value */ double ambacc = 0.2; /* ambient accuracy */ -int ambres = 8; /* ambient resolution */ -int ambdiv = 32; /* ambient divisions */ -int ambssamp = 0; /* ambient super-samples */ +int ambres = 32; /* ambient resolution */ +int ambdiv = 128; /* ambient divisions */ +int ambssamp = 32; /* ambient super-samples */ int ambounce = 0; /* ambient bounces */ char *amblist[128]; /* ambient include/exclude list */ int ambincl = -1; /* include == 1, exclude == 0 */ int greyscale = 0; /* map colors to brightness? */ -char *devname = dev_default; /* output device name */ +char *dvcname = dev_default; /* output device name */ struct driver *dev = NULL; /* driver functions */ @@ -80,6 +90,7 @@ static char *reserve_mem = NULL; /* pre-allocated res #define CTRL(c) ((c)-'@') +void quit(code) /* quit program */ int code; { @@ -92,6 +103,7 @@ int code; } +void devopen(dname) /* open device driver */ char *dname; { @@ -102,22 +114,22 @@ char *dname; id = octname!=NULL ? octname : progname; /* check device table */ for (i = 0; devtable[i].name; i++) - if (!strcmp(dname, devtable[i].name)) + if (!strcmp(dname, devtable[i].name)) { if ((dev = (*devtable[i].init)(dname, id)) == NULL) { sprintf(errmsg, "cannot initialize %s", dname); error(USER, errmsg); } else return; -#ifndef NIX + } /* not there, try exec */ if ((dev = comm_init(dname, id)) == NULL) { sprintf(errmsg, "cannot start device \"%s\"", dname); error(USER, errmsg); } -#endif } +void devclose() /* close our device */ { if (dev != NULL) @@ -126,6 +138,7 @@ devclose() /* close our device */ } +void printdevices() /* print list of output devices */ { register int i; @@ -135,11 +148,12 @@ printdevices() /* print list of output devices */ } +void rview() /* do a view */ { char buf[32]; - devopen(devname); /* open device */ + devopen(dvcname); /* open device */ newimage(); /* start image (calls fillreserves) */ for ( ; ; ) { /* quit in command() */ @@ -167,14 +181,16 @@ rview() /* do a view */ } +void fillreserves() /* fill memory reserves */ { if (reserve_mem != NULL) return; - reserve_mem = malloc(RESERVE_AMT); + reserve_mem = (char *)malloc(RESERVE_AMT); } +void freereserves() /* free memory reserves */ { if (reserve_mem == NULL) @@ -184,6 +200,7 @@ freereserves() /* free memory reserves */ } +void command(prompt) /* get/execute command */ char *prompt; { @@ -312,7 +329,7 @@ dostop: devclose(); kill(0, SIGTSTP); /* pc stops here */ - devopen(devname); + devopen(dvcname); redraw(); break; #endif @@ -332,6 +349,7 @@ commerr: } +void rsample() /* sample the image */ { int xsiz, ysiz, y; @@ -354,7 +372,7 @@ rsample() /* sample the image */ return; pl = (PNODE **)malloc(xsiz*sizeof(PNODE *)); if (pl == NULL) { - free((char *)rl); + free((void *)rl); return; } /* @@ -415,8 +433,8 @@ rsample() /* sample the image */ } } escape: - free((char *)rl); - free((char *)pl); + free((void *)rl); + free((void *)pl); }
