root/radiance/ray/src/rt/rview.c
Revision: 2.27
Committed: Fri Jan 21 00:52:59 2005 UTC (20 years, 5 months ago) by greg
Changes since 2.26: +9 -5 lines
2 static const char RCSid[] = "$Id: rview.c,v 2.26 2004/11/05 17:36:56 greg Exp $";
5 * rview.c - routines and variables for interactive view generation.
6 *
7 * External symbols declared in rpaint.h
8 */
9
10 #include "copyright.h"
11
12 #include <signal.h>
13 #include <ctype.h>
14
15 #include "ray.h"
16 #include "rpaint.h"
17
18
19 CUBE thescene; /* our scene */
20 OBJECT nsceneobjs; /* number of objects in our scene */
21
22 int dimlist[MAXDIM]; /* sampling dimensions */
23 int ndims = 0; /* number of sampling dimensions */
24 int samplendx = 0; /* index for this sample */
25
26 extern void ambnotify();
27 void (*addobjnotify[])() = {ambnotify, NULL};
28
29 VIEW ourview = STDVIEW; /* viewing parameters */
30 int hresolu, vresolu; /* image resolution */
31
32 void (*trace)() = NULL; /* trace call */
33
34 int do_irrad = 0; /* compute irradiance? */
35
36 int psample = 8; /* pixel sample size */
37 double maxdiff = .15; /* max. sample difference */
38
39 double exposure = 1.0; /* exposure for scene */
40
41 double dstrsrc = 0.0; /* square source distribution */
42 double shadthresh = .1; /* shadow threshold */
43 double shadcert = .25; /* shadow certainty */
44 int directrelay = 0; /* number of source relays */
45 int vspretest = 128; /* virtual source pretest density */
46 int directvis = 1; /* sources visible? */
47 double srcsizerat = 0.; /* maximum ratio source size/dist. */
48
49 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
50 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
51 double seccg = 0.; /* global scattering eccentricity */
52 double ssampdist = 0.; /* scatter sampling distance */
53
54 double specthresh = .3; /* specular sampling threshold */
55 double specjitter = 1.; /* specular sampling jitter */
56
57 int backvis = 1; /* back face visibility */
58
59 int maxdepth = 6; /* maximum recursion depth */
60 double minweight = 1e-2; /* minimum ray weight */
61
62 char *ambfile = NULL; /* ambient file name */
63 COLOR ambval = BLKCOLOR; /* ambient value */
64 int ambvwt = 0; /* initial weight for ambient value */
65 double ambacc = 0.3; /* ambient accuracy */
66 int ambres = 32; /* ambient resolution */
67 int ambdiv = 256; /* ambient divisions */
68 int ambssamp = 64; /* ambient super-samples */
69 int ambounce = 0; /* ambient bounces */
70 char *amblist[AMBLLEN]; /* ambient include/exclude list */
71 int ambincl = -1; /* include == 1, exclude == 0 */
72
73 int greyscale = 0; /* map colors to brightness? */
74 char *dvcname = dev_default; /* output device name */
75
76 struct driver *dev = NULL; /* driver functions */
77
78 char rifname[128]; /* rad input file name */
79
80 VIEW oldview; /* previous view parameters */
81
82 PNODE ptrunk; /* the base of our image */
83 RECT pframe; /* current frame boundaries */
84 int pdepth; /* image depth in current frame */
85
86 static char *reserve_mem = NULL; /* pre-allocated reserve memory */
87
88 #define RESERVE_AMT 32768 /* amount of memory to reserve */
89
90 #define CTRL(c) ((c)-'@')
91
92
93 void
94 quit(code) /* quit program */
95 int code;
96 {
97 #ifdef MSTATS
98 if (code == 2 && errno == ENOMEM)
99 printmemstats(stderr);
100 #endif
101 devclose();
102 exit(code);
103 }
104
105
106 void
107 devopen(dname) /* open device driver */
108 char *dname;
109 {
110 extern char *progname, *octname;
111 char *id;
112 register int i;
113
114 id = octname!=NULL ? octname : progname;
115 /* check device table */
116 for (i = 0; devtable[i].name; i++)
117 if (!strcmp(dname, devtable[i].name)) {
118 if ((dev = (*devtable[i].init)(dname, id)) == NULL) {
119 sprintf(errmsg, "cannot initialize %s", dname);
120 error(USER, errmsg);
121 } else
122 return;
123 }
124 /* not there, try exec */
125 if ((dev = comm_init(dname, id)) == NULL) {
126 sprintf(errmsg, "cannot start device \"%s\"", dname);
127 error(USER, errmsg);
128 }
129 }
130
131
132 void
133 devclose() /* close our device */
134 {
135 if (dev != NULL)
136 (*dev->close)();
137 dev = NULL;
138 }
139
140
141 void
142 printdevices() /* print list of output devices */
143 {
144 register int i;
145
146 for (i = 0; devtable[i].name; i++)
147 printf("%-16s # %s\n", devtable[i].name, devtable[i].descrip);
148 }
149
150
151 void
152 rview() /* do a view */
153 {
154 char buf[32];
155
156 devopen(dvcname); /* open device */
157 newimage(); /* start image (calls fillreserves) */
158
159 for ( ; ; ) { /* quit in command() */
160 while (hresolu <= 1<<pdepth && vresolu <= 1<<pdepth)
161 command("done: ");
162 while (reserve_mem == NULL)
163 command("out of memory: ");
164 errno = 0;
165 if (hresolu <= psample<<pdepth && vresolu <= psample<<pdepth) {
166 sprintf(buf, "%d sampling...\n", 1<<pdepth);
167 (*dev->comout)(buf);
168 rsample();
169 } else {
170 sprintf(buf, "%d refining...\n", 1<<pdepth);
171 (*dev->comout)(buf);
172 refine(&ptrunk, 0, 0, hresolu, vresolu, pdepth+1);
173 }
174 if (errno == ENOMEM) /* ran out of memory */
175 freereserves();
176 else if (dev->inpready) /* noticed some input */
177 command(": ");
178 else /* finished this depth */
179 pdepth++;
180 }
181 }
182
183
184 void
185 fillreserves() /* fill memory reserves */
186 {
187 if (reserve_mem != NULL)
188 return;
189 reserve_mem = (char *)malloc(RESERVE_AMT);
190 }
191
192
193 void
194 freereserves() /* free memory reserves */
195 {
196 if (reserve_mem == NULL)
197 return;
198 free(reserve_mem);
199 reserve_mem = NULL;
200 }
201
202
203 void
204 command(prompt) /* get/execute command */
205 char *prompt;
206 {
207 #define badcom(s) strncmp(s, inpbuf, args-inpbuf-1)
208 char inpbuf[256];
209 char *args;
210 again:
211 (*dev->comin)(inpbuf, prompt); /* get command + arguments */
212 for (args = inpbuf; *args && *args != ' '; args++)
213 ;
214 if (*args) *args++ = '\0';
215 else *++args = '\0';
216
217 switch (inpbuf[0]) {
218 case 'f': /* new frame (|focus|free) */
219 if (badcom("frame")) {
220 if (badcom("focus")) {
221 if (badcom("free"))
222 goto commerr;
223 free_objmem();
224 break;
225 }
226 getfocus(args);
227 break;
228 }
229 getframe(args);
230 break;
231 case 'v': /* view */
232 if (badcom("view"))
233 goto commerr;
234 getview(args);
235 break;
236 case 'l': /* last view */
237 if (badcom("last"))
238 goto commerr;
239 lastview(args);
240 break;
241 case 'V': /* save view */
242 if (badcom("V"))
243 goto commerr;
244 saveview(args);
245 break;
246 case 'L': /* load view */
247 if (badcom("L"))
248 goto commerr;
249 loadview(args);
250 break;
251 case 'e': /* exposure */
252 if (badcom("exposure"))
253 goto commerr;
254 getexposure(args);
255 break;
256 case 's': /* set a parameter */
257 if (badcom("set")) {
258 #ifdef SIGTSTP
259 if (!badcom("stop"))
260 goto dostop;
261 #endif
262 goto commerr;
263 }
264 setparam(args);
265 break;
266 case 'n': /* new picture */
267 if (badcom("new"))
268 goto commerr;
269 newimage();
270 break;
271 case 't': /* trace a ray */
272 if (badcom("trace"))
273 goto commerr;
274 traceray(args);
275 break;
276 case 'a': /* aim camera */
277 if (badcom("aim"))
278 goto commerr;
279 getaim(args);
280 break;
281 case 'm': /* move camera (or memstats) */
282 if (badcom("move"))
283 #ifdef MSTATS
284 {
285 if (badcom("memory"))
286 goto commerr;
287 printmemstats(stderr);
288 break;
289 }
290 #else
291 goto commerr;
292 #endif
293 getmove(args);
294 break;
295 case 'r': /* rotate/repaint */
296 if (badcom("rotate")) {
297 if (badcom("repaint")) {
298 if (badcom("redraw"))
299 goto commerr;
300 redraw();
301 break;
302 }
303 getrepaint(args);
304 break;
305 }
306 getrotate(args);
307 break;
308 case 'p': /* pivot view */
309 if (badcom("pivot")) {
310 if (badcom("pause"))
311 goto commerr;
312 goto again;
313 }
314 getpivot(args);
315 break;
316 case CTRL('R'): /* redraw */
317 redraw();
318 break;
319 case 'w': /* write */
320 if (badcom("write"))
321 goto commerr;
322 writepict(args);
323 break;
324 case 'q': /* quit */
325 if (badcom("quit"))
326 goto commerr;
327 quit(0);
328 case CTRL('C'): /* interrupt */
329 goto again;
330 #ifdef SIGTSTP
331 case CTRL('Z'):; /* stop */
332 dostop:
333 devclose();
334 kill(0, SIGTSTP);
335 /* pc stops here */
336 devopen(dvcname);
337 redraw();
338 break;
339 #endif
340 case '\0': /* continue */
341 break;
342 default:;
343 commerr:
344 if (iscntrl(inpbuf[0]))
345 sprintf(errmsg, "^%c: unknown control",
346 inpbuf[0]|0100);
347 else
348 sprintf(errmsg, "%s: unknown command", inpbuf);
349 error(COMMAND, errmsg);
350 break;
351 }
352 #undef badcom
353 }
354
355
356 void
357 rsample() /* sample the image */
358 {
359 int xsiz, ysiz, y;
360 RECT r;
361 PNODE *p;
362 register RECT *rl;
363 register PNODE **pl;
364 register int x;
365 /*
366 * We initialize the bottom row in the image at our current
367 * resolution. During sampling, we check super-pixels to the
368 * right and above by calling bigdiff(). If there is a significant
369 * difference, we subsample the super-pixels. The testing process
370 * includes initialization of the next row.
371 */
372 xsiz = (((long)(pframe.r-pframe.l)<<pdepth)+hresolu-1) / hresolu;
373 ysiz = (((long)(pframe.u-pframe.d)<<pdepth)+vresolu-1) / vresolu;
374 rl = (RECT *)malloc(xsiz*sizeof(RECT));
375 if (rl == NULL)
376 return;
377 pl = (PNODE **)malloc(xsiz*sizeof(PNODE *));
378 if (pl == NULL) {
379 free((void *)rl);
380 return;
381 }
382 /*
383 * Initialize the bottom row.
384 */
385 rl[0].l = rl[0].d = 0;
386 rl[0].r = hresolu; rl[0].u = vresolu;
387 pl[0] = findrect(pframe.l, pframe.d, &ptrunk, rl, pdepth);
388 for (x = 1; x < xsiz; x++) {
389 rl[x].l = rl[x].d = 0;
390 rl[x].r = hresolu; rl[x].u = vresolu;
391 pl[x] = findrect(pframe.l+((x*hresolu)>>pdepth),
392 pframe.d, &ptrunk, rl+x, pdepth);
393 }
394 /* sample the image */
395 for (y = 0; /* y < ysiz */ ; y++) {
396 for (x = 0; x < xsiz-1; x++) {
397 if (dev->inpready || errno == ENOMEM)
398 goto escape;
399 /*
400 * Test super-pixel to the right.
401 */
402 if (pl[x] != pl[x+1] && bigdiff(pl[x]->v,
403 pl[x+1]->v, maxdiff)) {
404 refine(pl[x], rl[x].l, rl[x].d,
405 rl[x].r, rl[x].u, 1);
406 refine(pl[x+1], rl[x+1].l, rl[x+1].d,
407 rl[x+1].r, rl[x+1].u, 1);
408 }
409 }
410 if (y >= ysiz-1)
411 break;
412 for (x = 0; x < xsiz; x++) {
413 if (dev->inpready || errno == ENOMEM)
414 goto escape;
415 /*
416 * Find super-pixel at this position in next row.
417 */
418 r.l = r.d = 0;
419 r.r = hresolu; r.u = vresolu;
420 p = findrect(pframe.l+((x*hresolu)>>pdepth),
421 pframe.d+(((y+1)*vresolu)>>pdepth),
422 &ptrunk, &r, pdepth);
423 /*
424 * Test super-pixel in next row.
425 */
426 if (pl[x] != p && bigdiff(pl[x]->v, p->v, maxdiff)) {
427 refine(pl[x], rl[x].l, rl[x].d,
428 rl[x].r, rl[x].u, 1);
429 refine(p, r.l, r.d, r.r, r.u, 1);
430 }
431 /*
432 * Copy into super-pixel array.
433 */
434 rl[x].l = r.l; rl[x].d = r.d;
435 rl[x].r = r.r; rl[x].u = r.u;
436 pl[x] = p;
437 }
438 }
439 escape:
440 free((void *)rl);
441 free((void *)pl);
442 }
443
444
445 int
446 refine(p, xmin, ymin, xmax, ymax, pd) /* refine a node */
447 register PNODE *p;
448 int xmin, ymin, xmax, ymax;
449 int pd;
450 {
451 int growth;
452 int mx, my;
453 int i;
454
455 if (dev->inpready) /* quit for input */
456 return(0);
457
458 if (pd <= 0) /* depth limit */
459 return(0);
460
461 mx = (xmin + xmax) >> 1;
462 my = (ymin + ymax) >> 1;
463 growth = 0;
464
465 if (p->kid == NULL) { /* subdivide */
466
467 if ((p->kid = newptree()) == NULL)
468 return(0);
469 /*
470 * The following paint order can leave a black pixel
471 * if redraw() is called in (*dev->paintr)().
472 */
473 if (p->x >= mx && p->y >= my)
474 pcopy(p, p->kid+UR);
475 else
476 paint(p->kid+UR, mx, my, xmax, ymax);
477 if (p->x < mx && p->y >= my)
478 pcopy(p, p->kid+UL);
479 else
480 paint(p->kid+UL, xmin, my, mx, ymax);
481 if (p->x >= mx && p->y < my)
482 pcopy(p, p->kid+DR);
483 else
484 paint(p->kid+DR, mx, ymin, xmax, my);
485 if (p->x < mx && p->y < my)
486 pcopy(p, p->kid+DL);
487 else
488 paint(p->kid+DL, xmin, ymin, mx, my);
489
490 growth++;
491 }
492 /* do children */
493 if (mx > pframe.l) {
494 if (my > pframe.d)
495 growth += refine(p->kid+DL, xmin, ymin, mx, my, pd-1);
496 if (my < pframe.u)
497 growth += refine(p->kid+UL, xmin, my, mx, ymax, pd-1);
498 }
499 if (mx < pframe.r) {
500 if (my > pframe.d)
501 growth += refine(p->kid+DR, mx, ymin, xmax, my, pd-1);
502 if (my < pframe.u)
503 growth += refine(p->kid+UR, mx, my, xmax, ymax, pd-1);
504 }
505 /* recompute sum */
506 if (growth) {
507 setcolor(p->v, 0.0, 0.0, 0.0);
508 for (i = 0; i < 4; i++)
509 addcolor(p->v, p->kid[i].v);
510 scalecolor(p->v, 0.25);
511 }
512 return(growth);
513 }
